58 static const char BUILD_DATE_KW[] =
"build_date";
59 static const char CAN_OPEN_KW[] =
"can_open";
60 static const char CENTER_GROUND_KW[] =
"center_ground";
61 static const char CENTER_IMAGE_KW[] =
"center_image";
62 static const char CONFIGURATION_KW[] =
"configuration";
63 static const char DATUMS_KW[] =
"datums";
64 static const char DEG2RAD_KW[] =
"deg2rad";
65 static const char DUMP_KW[] =
"dump";
66 static const char DUMP_NO_OVERVIEWS_KW[] =
"dump_no_overviews";
67 static const char EXTENSIONS_KW[] =
"extensions";
68 static const char FACTORIES_KW[] =
"factories";
69 static const char FACTORY_KEYWORD_LIST_KW[] =
"factory_keyword_list";
70 static const char FONTS_KW[] =
"fonts";
71 static const char FORMAT_KW[] =
"format";
72 static const char FT2MTRS_KW[] =
"ft2mtrs";
73 static const char FT2MTRS_US_SURVEY_KW[] =
"ft2mtrs_us_survey";
74 static const char GEOM_INFO_KW[] =
"geometry_info";
75 static const char HEIGHT_KW[] =
"height";
76 static const char IMAGE_BOUNDS_KW[] =
"image_bounds";
77 static const char IMAGE_CENTER_KW[] =
"image_center";
78 static const char IMAGE_FILE_KW[] =
"image_file";
79 static const char IMAGE_INFO_KW[] =
"image_info";
80 static const char IMAGE_RECT_KW[] =
"image_rect";
81 static const char IMG2GRD_KW[] =
"img2grd";
82 static const char GRD2IMG_KW[] =
"grd2img";
83 static const char METADATA_KW[] =
"metadata";
84 static const char MTRS2FT_KW[] =
"mtrs2ft";
85 static const char MTRS2FT_US_SURVEY_KW[] =
"mtrs2ft_us_survey";
86 static const char MTRSPERDEG_KW[] =
"mtrs_per_deg";
87 static const char NORTH_UP_KW[] =
"north_up_angle";
88 static const char OUTPUT_FILE_KW[] =
"output_file";
89 static const char OVERVIEW_TYPES_KW[] =
"overview_types";
90 static const char OVERWRITE_KW[] =
"overwrite";
91 static const char PALETTE_KW[] =
"palette";
92 static const char PLUGINS_KW[] =
"plugins";
93 static const char PLUGIN_TEST_KW[] =
"plugin_test";
94 static const char PRETTY_PRINT_KW[] =
"pretty_print";
95 static const char PROJECTIONS_KW[] =
"projections";
96 static const char RAD2DEG_KW[] =
"rad2deg";
97 static const char READER_PROPS_KW[] =
"reader_props";
98 static const char RESAMPLER_FILTERS_KW[] =
"resampler_filters";
99 static const char REVISION_NUMBER_KW[] =
"revision_number";
100 static const char UP_IS_UP_KW[] =
"up_is_up";
101 static const char UP_IS_UP_GPT_KW[] =
"up_is_up_gpt";
102 static const char UP_IS_UP_IPT_KW[] =
"up_is_up_ipt";
103 static const char VERSION_KW[] =
"version";
104 static const char WRITERS_KW[] =
"writers_kw";
105 static const char WRITER_PROPS_KW[] =
"writer_props";
106 static const char ZOOM_LEVEL_GSDS_KW[] =
"zoom_level_gsds";
107 static const char ECEF2LLH_KW[] =
"ecef2llh";
108 static const char DUMP_STATE_KW[] =
"dump_state";
109 static const char STATE_KW[] =
"state";
112 "Dumps metadata information about input image and OSSIM in general.";
134 usageString +=
" [options] <optional-image | optional-state>";
152 au->
addCommandLineOption(
"-D",
"A human-readable (i.e., not necessarily key:value pairs) dump of the image.");
160 au->
"--dno",
"A generic dump if one is available. This option ignores overviews.");
162 au->
"--dump-state",
"If the image supports a state object then the state object will be dumped.");
164 au->
"--ecef2llh",
"<X> <Y> <Z> in ECEF coordinates and returns latitude longitude height position.");
168 au->
"-f",
"<format> Will output the information specified format [KWL | XML]. Default is KWL.");
170 au->
"--factories",
"<keyword_list_flag> Prints factory list. If keyword_list_flag is true, the result of a saveState will be output for each object.");
174 au->
"--ft2mtrs",
"<feet> Gives meters from feet (0.3048 meters per foot).");
176 au->
"--ft2mtrs-us-survey",
"<feet> Gives meters from feet (0.3048006096 meters per foot).");
180 au->
"--height",
"<latitude-in-degrees> <longitude-in-degrees> Returns the MSL and ellipoid height given a latitude longitude position.");
184 au->
"--img2grd",
"<x> <y> Gives ground point from zero based image point. Returns \"nan\" if point is outside of image area.");
185 au->
"--grd2img",
"<lat> <lon> <height> Gives full res image point from lat lon height.");
189 au->
"--mtrsPerDeg",
"<latitude> Gives meters per degree and meters per minute for a given latitude.");
191 au->
"--mtrs2ft",
"<meters> Gives feet from meters (0.3048 meters per foot).");
193 au->
"--mtrs2ft-us-survey",
"<meters> Gives feet from meters (0.3048006096 meters per foot).");
197 au->
"-o",
"<output-file> Will output the information to the file specified. Default is to standard out.");
223 au->
"--up-is-up or -u",
"Rotation angle to \"up is up\" for an image.\nWill return 0 if image's projection is not affected by elevation.");
225 au->
"--up-is-up-ipt",
"Computes up angle given full res image point: <x> <y>");
234 au->
"--zoom-level-gsds",
"Prints zoom level gsds for projections EPSG:4326 and EPSG:3857.");
238 <<
" ossim-info --version\n" 239 <<
" ossim-info -i ./myfile.tif\n" 240 <<
" prints out only general image information\n\n" 241 <<
" ossim-info -p ./myfile.tif\n" 242 <<
" prints out only image projection information\n\n" 243 <<
" ossim-info -p -s wge ./myfile.tif\n" 244 <<
" prints out only image projection information and shifts to wgs84\n\n" 245 <<
" ossim-info -p -i ./myfile.tif\n" 246 <<
" prints out both image and projection information\n\n" 247 <<
" ossim-info -p -i ./myfile.tif -o ./myfile.geom\n" 248 <<
" writes geometry file with both image and projection information\n\n" 249 <<
" ossim-info -p -i ./myfile.tif -v -o ./myfile.geom\n" 250 <<
" writes geometry file with both image and projection information\n" 251 <<
" while overwriting existing .geom file.\n\n" 252 <<
" ossim-info -f XML ./myfile.tif\n" 253 <<
" prints out image and projection information as an XML document\n\n" 254 <<
" ossim-info -d myfile.ntf\n" 255 <<
" Dumps all data available, in this case, all nitf tags, from file.\n\n" 256 <<
" ossim-info -d a.toc\n" 257 <<
" Dumps all data available, in this case, all nitf and rpf tags, from file.\n\n" 258 <<
" ossim-info --dno a.toc\n" 259 <<
" \"dno\" for \"dump no overviews\" Dumps all data available,\n" 260 <<
" in this case, all nitf and rpf tags, from file ignoring overviews.\n\n" 261 <<
" ossim-info -d -i -p myfile.ntf\n" 262 <<
" Typical usage case, i.e. do a dump of tags and print out image and\n" 263 <<
" projection information.\n\n" 271 static const char M[] =
"ossimInfo::initialize(ossimArgumentParser&)";
289 bool requiresInputImage =
false;
300 const char TRUE_KW[] =
"true";
302 if( ap.
read(
"--bounds") )
304 m_kwl.
add( IMAGE_BOUNDS_KW, TRUE_KW );
311 if( ap.
read(
"--build-date") )
313 m_kwl.
add( BUILD_DATE_KW, TRUE_KW );
322 m_kwl.
add( IMAGE_CENTER_KW, TRUE_KW );
329 if( ap.
read(
"--can-open") )
332 requiresInputImage =
true;
340 if( ap.
read(
"--cg") )
342 m_kwl.
add( CENTER_GROUND_KW, TRUE_KW );
349 if( ap.
read(
"--ci") )
351 m_kwl.
add( CENTER_IMAGE_KW, TRUE_KW );
358 if( ap.
read(
"--config") || ap.
read(
"--configuration") )
360 m_kwl.
add( CONFIGURATION_KW, TRUE_KW );
367 if( ap.
read(
"--datums") )
376 if( ap.
read(
"--deg2rad", sp1) )
378 m_kwl.
add( DEG2RAD_KW, ts1.c_str() );
387 m_kwl.
add( PRETTY_PRINT_KW, TRUE_KW );
388 requiresInputImage =
true;
398 requiresInputImage =
true;
405 if( ap.
read(
"--dump-state") )
407 m_kwl.
add( DUMP_STATE_KW, TRUE_KW );
408 requiresInputImage =
true;
415 if( ap.
read(
"--dno") )
418 m_kwl.
add( DUMP_NO_OVERVIEWS_KW, TRUE_KW );
419 requiresInputImage =
true;
426 if( ap.
read(
"--extensions") )
428 m_kwl.
add( EXTENSIONS_KW, TRUE_KW );
433 if( ap.
read(
"-f", sp1) )
442 if( ap.
read(
"--factories", sp1) )
445 m_kwl.
add( FACTORY_KEYWORD_LIST_KW, ts1.c_str());
452 if( ap.
read(
"--fonts") )
461 if( ap.
read(
"--ft2mtrs", sp1) )
463 m_kwl.
add( FT2MTRS_KW, ts1.c_str());
470 if( ap.
read(
"--ft2mtrs-us-survey", sp1) )
472 m_kwl.
473 m_kwl.
add( FT2MTRS_US_SURVEY_KW, TRUE_KW);
480 if( ap.
read(
"--height", sp1, sp2) )
493 if( ap.
read(
"--ecef2llh", sp1, sp2, sp3))
499 m_kwl.
add( ECEF2LLH_KW, ecefPoint.toString().c_str() );
508 m_kwl.
add( IMAGE_INFO_KW, TRUE_KW );
509 requiresInputImage =
true;
516 if( ap.
read(
"--img2grd", sp1, sp2) )
518 requiresInputImage =
true;
522 dpt.
x =
x.toFloat64();
523 dpt.
y =
y.toFloat64();
531 if( ap.
read(
"--grd2img", sp1, sp2, sp3) )
533 requiresInputImage =
true;
555 requiresInputImage =
true;
562 if( ap.
read(
"--mtrs2ft", sp1) )
564 m_kwl.
add( MTRS2FT_KW, ts1.c_str());
571 if( ap.
read(
"--mtrs2ft-us-survey", sp1) )
573 m_kwl.
574 m_kwl.
add( MTRS2FT_US_SURVEY_KW, TRUE_KW);
581 if( ap.
read(
"--mtrsPerDeg", sp1) )
583 m_kwl.
add( MTRSPERDEG_KW, ts1.c_str());
590 if( ap.
read(
"-n") || ap.
read(
"--north-up") )
599 if( ap.
read(
"-o", sp1) )
601 m_kwl.
add( OUTPUT_FILE_KW, ts1.c_str());
608 if( ap.
read(
"--overview-types") )
610 m_kwl.
add( OVERVIEW_TYPES_KW, TRUE_KW );
620 requiresInputImage =
true;
627 if( ap.
read(
"--palette") )
630 requiresInputImage =
true;
637 if( ap.
read(
"--plugins") )
646 if( ap.
read(
"--plugin-test", sp1) )
648 m_kwl.
add( PLUGIN_TEST_KW, ts1.c_str());
655 if( ap.
read(
"--projections") )
657 m_kwl.
add( PROJECTIONS_KW, TRUE_KW );
666 m_kwl.
add( IMAGE_RECT_KW, TRUE_KW );
667 requiresInputImage =
true;
674 if( ap.
read(
"--rad2deg", sp1) )
676 m_kwl.
add( RAD2DEG_KW, ts1.c_str());
683 if( ap.
read(
"--reader-props") )
685 m_kwl.
add( READER_PROPS_KW, TRUE_KW );
692 if( ap.
read(
"--resampler-filters") )
694 m_kwl.
add( RESAMPLER_FILTERS_KW, TRUE_KW );
701 if( ap.
read(
"--revision") ||
702 ap.
read(
"--revision-number") )
704 m_kwl.
add( REVISION_NUMBER_KW, TRUE_KW );
711 if( ap.
read(
"-u") || ap.
read(
"--up-is-up") )
713 requiresInputImage =
true;
720 if( ap.
read(
"--up-is-up-ipt", sp1, sp2))
722 requiresInputImage =
true;
724 m_kwl.
add( UP_IS_UP_IPT_KW, (ts1 +
" "+ts2).c_str() );
730 if(ap.
read(
"--up-is-up-gpt",sp1, sp2))
732 requiresInputImage =
true;
734 m_kwl.
add( UP_IS_UP_GPT_KW, (ts1 +
" "+ ts2).c_str() );
750 if( ap.
read(
"--version") || ap.
read(
"-V") )
759 if( ap.
read(
"--writer-props") )
761 m_kwl.
add( WRITER_PROPS_KW, TRUE_KW );
768 if( ap.
read(
"--writers") )
777 if( ap.
read(
"--zoom-level-gsds") )
779 m_kwl.
add( ZOOM_LEVEL_GSDS_KW, TRUE_KW );
791 std::string errMsg =
"Unknown option...";
799 if ( ap.
argc() == 2 )
806 if ( requiresInputImage )
819 <<
"m_kwl:\n" <<
m_kwl <<
"\n" 820 << M <<
" exit result = " << (result?
"true":
"false")
829 static const char M[] =
"ossimInfo::execute()";
836 << M <<
" entered..." 837 <<
"\nMap size: " << KEY_COUNT <<
"\n";
855 if ( consumedKeys < KEY_COUNT )
859 if (
keyIsTrue( std::string(BUILD_DATE_KW)) )
863 << BUILD_DATE_KW <<
": " << value <<
"\n";
922 bool keywordListFlag =
false;
923 lookup =
m_kwl.
find(FACTORY_KEYWORD_LIST_KW);
948 bool us_survey =
false;
949 lookup =
m_kwl.
find(FT2MTRS_US_SURVEY_KW);
973 bool us_survey =
false;
974 lookup =
m_kwl.
find(MTRS2FT_US_SURVEY_KW);
1051 lookup =
m_kwl.
find(RESAMPLER_FILTERS_KW);
1062 if (
keyIsTrue( std::string(REVISION_NUMBER_KW) ) )
1066 << REVISION_NUMBER_KW <<
": " << value <<
"\n";
1069 if (
keyIsTrue( std::string(VERSION_KW) ) )
1073 << VERSION_KW <<
": " << value <<
"\n";
1098 lookup =
m_kwl.
find(ZOOM_LEVEL_GSDS_KW);
1114 <<
"KEY_COUNT: " << KEY_COUNT
1115 <<
"\nconsumedKeys: " << consumedKeys <<
"\n";
1129 static const char M[] =
"ossimInfo::executeImageOptions()";
1139 const char* lookup = 0;
1142 bool dnoFlag =
false;
1143 bool overwriteFlag =
false;
1144 bool xmlOutFlag =
false;
1151 overwriteFlag = value.
toBool();
1160 if ( format.
upcase() ==
"XML" )
1171 outputFile = lookup;
1186 lookup =
m_kwl.
find( DUMP_NO_OVERVIEWS_KW );
1191 dnoFlag = value.
toBool();
1212 bool centerGroundFlag =
false;
1213 bool centerImageFlag =
false;
1214 bool imageBoundsFlag =
false;
1215 bool imageCenterFlag =
false;
1216 bool imageGeomFlag =
false;
1217 bool imageInfoFlag =
false;
1218 bool imageRectFlag =
false;
1219 bool img2grdFlag =
false;
1220 bool grd2imgFlag =
false;
1221 bool metaDataFlag =
false;
1222 bool northUpFlag =
false;
1223 bool paletteFlag =
false;
1224 bool upIsUpFlag =
false;
1225 bool imageToGroundFlag =
false;
1226 bool groundToImageFlag =
false;
1227 bool dumpState =
false;
1228 bool canOpenFlag =
false;
1235 dumpState = value.
toBool();
1239 lookup =
m_kwl.
find( CENTER_GROUND_KW );
1244 centerGroundFlag = value.
toBool();
1253 centerImageFlag = value.
toBool();
1262 metaDataFlag = value.
toBool();
1271 paletteFlag = value.
toBool();
1280 imageBoundsFlag = value.
toBool();
1289 imageCenterFlag = value.
toBool();
1298 imageRectFlag = value.
toBool();
1310 imageInfoFlag = value.
toBool();
1336 imageGeomFlag = value.
toBool();
1345 northUpFlag = value.
toBool();
1354 upIsUpFlag = value.
toBool();
1363 canOpenFlag = value.
toBool();
1367 if ( consumedKeys == 0 )
1369 imageInfoFlag =
true;
1370 imageGeomFlag =
true;
1373 if ( centerGroundFlag || centerImageFlag || imageBoundsFlag || imageCenterFlag ||
1374 imageRectFlag || img2grdFlag || grd2imgFlag || metaDataFlag || paletteFlag ||
1375 imageInfoFlag || imageGeomFlag || northUpFlag || upIsUpFlag || dumpState ||
1376 imageToGroundFlag || groundToImageFlag || canOpenFlag)
1388 okwl.
add(
"can_open",
"true",
true);
1392 okwl.
add(
"can_open",
"false",
true);
1396 if ( centerGroundFlag )
1401 if ( centerImageFlag )
1406 if ( imageCenterFlag )
1413 if ( imageBoundsFlag )
1418 if ( imageRectFlag )
1442 if ( imageInfoFlag )
1447 if ( imageGeomFlag )
1452 if ( imageRectFlag )
1498 if ( !overwriteFlag && outputFile.
exists() )
1501 <<
"ERROR: File already exists: " << outputFile
1502 <<
"\nUse -v option to overwrite." 1509 okwl.
write( outputFile );
1524 <<
"consumedKeys: " << consumedKeys <<
"\n" 1525 << M <<
" exited...\n";
1528 return consumedKeys;
1541 if ( dumpFlag || dnoFlag )
1547 if ( imageGeomFlag || imageInfoFlag || metaDataFlag || paletteFlag )
1561 if ( imageInfoFlag )
1565 if ( imageGeomFlag )
1577 bool result =
false;
1593 errMsg <<
"ossimInfo::getImageInfo ERROR:\nInvalid entry: " << entry
1616 std::shared_ptr<ossim::ImageHandlerState> state;
1634 std::shared_ptr<ossim::ImageHandlerState> state;
1650 openConnection(file);
1657 std::string errMsg =
"ossimInfo::openImage ERROR:\nCould not open: ";
1698 <<
"No print available for: " << file.
c_str() << std::endl;
1711 info->setProcessOverviewFlag(
false);
1713 info->getKeywordlist(kwl);
1719 <<
"No dump available for: " << file.
1734 std::vector< ossimRefPtr< ossimProperty > > list;
1736 std::vector< ossimRefPtr< ossimProperty > >::const_iterator i = list.begin();
1737 while (i != list.end())
1745 if ((*i)->getClassName() ==
"ossimContainerProperty")
1750 std::vector< ossimRefPtr< ossimProperty > > list2;
1753 std::vector< ossimRefPtr< ossimProperty > >::const_iterator i2 = list2.begin();
1754 while (i2 != list2.end())
1756 key = (*i2)->getName();
1757 value = (*i2)->valueToString();
1765 key = (*i)->getName();
1766 value = (*i)->valueToString();
1792 std::vector<ossim_uint32> entryList;
1823 std::vector<ossim_uint32> entryList;
1826 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
1827 while ( i != entryList.end() )
1843 bool result =
false;
1854 bool result =
false;
1860 bool outputEntry =
true;
1865 outputEntry =
false;
1879 std::string entryName;
1881 if ( entryName.size() )
1883 kwl.
add(prefix.
c_str(),
"entry_name", entryName.c_str(),
true);
1901 kwl.
add(prefix,
"overview.type",
1916 boundingRect.
height(),
true);
1918 boundingRect.
width(),
true);
1934 kwl.
add(prefix,
"radiometry", rad.
c_str(),
true);
1962 std::vector<ossim_uint32> entryList;
1965 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
1966 while ( i != entryList.end() )
1982 bool result =
false;
1995 bool result =
false;
2001 bool outputEntry =
true;
2006 outputEntry =
false;
2046 if ((ulg.
lon == 180.0) && (urg.
lon == 180.0))
2050 if ((llg.
lon == 180.0) && (lrg.
lon == 180.0))
2055 kwl.
add(prefix,
"ul_lat", ulg.
latd(),
true);
2056 kwl.
add(prefix,
"ul_lon", ulg.
lond(),
true);
2057 kwl.
add(prefix,
"ll_lat", llg.
latd(),
true);
2058 kwl.
add(prefix,
"ll_lon", llg.
lond(),
true);
2059 kwl.
add(prefix,
"lr_lat", lrg.
latd(),
true);
2060 kwl.
add(prefix,
"lr_lon", lrg.
lond(),
true);
2061 kwl.
add(prefix,
"ur_lat", urg.
latd(),
true);
2062 kwl.
add(prefix,
"ur_lon", urg.
lond(),
true);
2078 fabs(ulg.
lond()-urg.
lond())/(outputRect.
width()-1.0),
true);
2095 <<
"No geometry for file " << ih->
getFilename() << std::endl;
2116 std::vector<ossim_uint32> entryList;
2119 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
2120 while ( i != entryList.end() )
2150 <<
"Could not get image center for: " << ih->
2168 std::vector<ossim_uint32> entryList;
2171 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
2172 while ( i != entryList.end() )
2210 <<
"Could not get ground center for: " << ih->
2228 std::vector<ossim_uint32> entryList;
2231 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
2232 while ( i != entryList.end() )
2282 <<
"Could not get image bounds for: " << ih->
2300 std::vector<ossim_uint32> entryList;
2303 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
2304 while ( i != entryList.end() )
2351 kwl.
add(prefix,
"ground_point",
"nan",
true);
2361 <<
2379 std::vector<ossim_uint32> entryList;
2382 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
2383 while ( i != entryList.end() )
2421 <<
2439 std::vector<ossim_uint32> entryList;
2442 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
2443 while ( i != entryList.end() )
2465 bool result =
false;
2501 kwl.
add(prefix, UP_IS_UP_KW, upIsUp,
true);
2512 <<
"Could not get up is up angle for: " << ih->
2531 std::vector<ossim_uint32> entryList;
2534 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
2535 while ( i != entryList.end() )
2557 bool result =
false;
2568 kwl.
add(prefix, NORTH_UP_KW, northUp,
true);
2578 <<
"Could not get north up angle for: " << ih->
2596 std::vector<ossim_uint32> entryList;
2599 std::vector<ossim_uint32>::const_iterator i = entryList.begin();
2600 while ( i != entryList.end() )
2611 bool result =
false;
2614 std::vector<ossim_uint32> bandList;
2616 if ( result && ( bandList.size() == 3 ) )
2619 ossim::toSimpleStringList<ossim_uint32>(os, bandList);
2624 kwl.
add(prefix,
"rgb_bands", os.
c_str(),
true);
2657 <<
"Could not get image rectangle for: " << ih->
2667 bool result =
false;
2677 bool result =
false;
2702 out <<
"\npreferences_keyword_file: " 2704 <<
"preferences_keyword_list:\n" 2712 std::vector<ossimString> typeList;
2714 for(
int i = 0; i < (int)typeList.size(); ++i)
2721 cout << typeList[i] << endl;
2722 cout <<
"______________________________________________________" << endl;
2725 cout << kwl << endl;
2726 cout <<
2732 cout << typeList[i] << endl;
2745 std::ios_base::fmtflags f = out.flags();
2747 std::vector<ossimString> datumList;
2750 std::vector<ossimString>::const_iterator i = datumList.begin();
2752 while ( i != datumList.end() )
2759 out << setiosflags(ios::left)
2773 out <<
"No ellipsoid for code: " << (*i) << std::endl;
2778 out <<
"No datum for code: " << (*i) << std::endl;
2797 std::vector<ossimFontInformation> fontInfoList;
2800 std::vector<ossimFontInformation>::const_iterator i = fontInfoList.begin();
2802 while ( i != fontInfoList.end() )
2804 out << *(i) << endl;
2810 if ( defaultFont.
valid() )
2812 out <<
"default_font: " << defaultFont->
getFamilyName() << std::endl;
2828 std::ios_base::fmtflags f = out.flags();
2830 out << std::setiosflags(std::ios::fixed) << std::setprecision(15)
2831 <<
"\n" << degrees <<
" degrees = " 2832 << radians <<
" radians.\n" << std::endl;
2842 out <<
"ECEF: " << ecefPoint.
toString() <<
"\n" 2858 std::ios_base::fmtflags f = out.flags();
2860 out << std::setiosflags(std::ios::fixed) << std::setprecision(15)
2861 <<
"\n" << radians <<
" radians = " 2862 << degrees <<
" degrees.\n" << std::endl;
2880 std::string conversionString;
2884 conversionString =
"0.3048006096";
2889 conversionString =
"0.3048";
2893 std::ios_base::fmtflags f = out.flags();
2895 out << setiosflags(ios::fixed) << setprecision(15)
2896 << feet <<
" * " << conversionString <<
" = " 2897 << meters <<
" meters." << std::endl;
2915 std::ios_base::fmtflags f = out.flags();
2918 std::string conversionString;
2923 conversionString =
"0.3048006096";
2928 conversionString =
"0.3048";
2931 out << setiosflags(ios::fixed) << setprecision(15)
2932 << meters <<
" / " << conversionString <<
" = " 2933 << feet <<
" feet." << std::endl;
2953 out << setiosflags(ios::fixed) << setprecision(15)
2954 <<
"Meters per degree and minute at latitude of " << latitude <<
":\n" 2955 <<
"Meters per degree latitude: " 2956 << setw(20) << mpd.
y <<
"\n" 2957 <<
"Meters per degree longitude: " 2958 << setw(20) << mpd.
x <<
"\n" 2959 <<
"Meters per minute latitude: " 2960 << setw(20) << arcLengthLat <<
"\n" 2961 <<
"Meters per minute longitude: " 2962 << setw(20) << arcLengthLon <<
"\n" 2963 <<
"Geodetic radius: " 2964 << setw(20) << radius <<
"\n" 2977 std::ios_base::fmtflags f = out.flags();
2995 mslOffset = hgtAboveEllipsoid - hgtAboveMsl;
2998 std::vector<ossimFilename> cellList;
3001 if (!cellList.empty())
3003 out <<
"Opened cell: " << cellList[0] <<
"\n";
3007 out <<
"Did not find cell for point: " << gpt <<
"\n";
3010 out <<
"MSL to ellipsoid delta: ";
3013 out << std::setprecision(15) << mslOffset;
3019 out <<
"\nHeight above MSL: ";
3022 out << std::setprecision(15) << hgtAboveMsl;
3028 out <<
"\nHeight above ellipsoid: ";
3031 out << std::setprecision(15) << hgtAboveEllipsoid <<
"\n";
3035 out <<
"nan" <<
"\n";
3037 out <<
"Geoid value: ";
3041 out << std::setprecision(15) << geoidOffset << std::endl;
3045 out <<
"nan" << std::endl;
3063 const vector<ossimString>& list = extList.
getList();
3067 out <<
"No image file extensions handled. This should never happen!" << std::endl;
3071 out<<
"\nImage Entensions Supported:"<< endl;
3072 for (
const auto& extension : list)
3073 out<<
" "<<extension<<endl;
3092 out <<
"No plugins loaded in the OSSIM core library" << std::endl;
3106 out <<
"Plugin loaded: " << plugin << std::endl;
3110 out <<
"Unable to load plugin: " << plugin << std::endl;
3122 out <<
"\nValid overview types: " << std::endl;
3124 std::vector<ossimString> outputType;
3127 std::copy(outputType.begin(),
3129 std::ostream_iterator<ossimString>(out,
"\t\n"));
3140 out <<
"Projections:\n";
3142 std::vector<ossimString> list;
3144 getAllTypeNamesFromRegistry(list);
3146 std::vector<ossimString>::const_iterator i = list.begin();
3147 while ( i != list.end() )
3174 std::vector<ossimString> list;
3177 std::vector<ossimString>::const_iterator i = list.begin();
3178 while ( i != list.end() )
3205 std::ios_base::fmtflags f = out.flags();
3207 out << setprecision(15)<< setiosflags(std::ios_base::fixed|std::ios_base::right);
3209 const int MAX_LEVEL = 24;
3210 const double TILE_SIZE = 256.0;
3211 const double EPSG_4326_BOUNDS = 180.0;
3212 const double EPSG_3857_BOUNDS = 40075016.685578488;
3215 const double MTRS_PER_DEGREE_AT_EQUATOR = 111319.490793273565941;
3218 <<
"tile size: 256\n" 3219 <<
"dpp = \"degrees per pixel\"\n" 3220 <<
"mpp = \"meters per pixel\"\n\n";
3223 double level_0_gsd = EPSG_4326_BOUNDS / TILE_SIZE;
3224 double level_gsd = 0.0;
3229 out <<
"EPSG:4326 level info:\n" 3230 <<
"Note: Assuming square pixels, level 0 having (2x1) tiles.\n" 3231 <<
"bounds: 360.0 X 180.0\n" 3232 <<
"level[" << std::setw(2) << std::setfill(
'0') << i <<
"] dpp:" 3233 << std::setw(18) << std::setfill(
' ') << level_0_gsd
3234 <<
" equivalent mpp:" << std::setw(22)
3235 << (level_0_gsd * MTRS_PER_DEGREE_AT_EQUATOR)
3236 <<
" (" << tilesX <<
"x" << tilesY <<
"\n";
3238 for ( i = 1; i <= MAX_LEVEL; ++i )
3240 tilesX = tilesX << 1;
3241 tilesY = tilesY << 1;
3242 level_gsd = level_0_gsd / std::pow( 2.0, i );
3243 out <<
'0') << i <<
"] dpp:" 3244 << std::setw(18) << std::setfill(
' ') << level_gsd
3245 <<
3246 << (level_gsd * MTRS_PER_DEGREE_AT_EQUATOR)
3247 <<
" (" << tilesX <<
"x" << tilesY <<
"\n";
3252 level_0_gsd = EPSG_3857_BOUNDS / TILE_SIZE;
3257 out <<
"\n\nEPSG:3857 level info:\n" 3258 <<
"Note: Assuming square pixels, level 0 having (1x1) tile.\n" 3259 <<
"bounds: 40075016.685578488 X 40075016.685578488\n" 3260 <<
'0') << i <<
"] mpp:" 3261 << std::setw(23) << std::setfill(
' ') << level_0_gsd
3262 <<
" (" << tilesX <<
"x" << tilesX <<
"\n";
3264 for ( i = 1; i <= MAX_LEVEL; ++i )
3266 tilesX = tilesX << 1;
3267 level_gsd = level_0_gsd / std::pow( 2.0, i );
3268 out <<
'0') << i <<
"] mpp:" 3269 << std::setw(23) << std::setfill(
' ') << level_gsd
3270 <<
" (" << tilesX <<
"x" << tilesX <<
"\n";
3327 s =
"16-bit unsigned";
3332 s =
"16-bit signed";
3337 s =
"32-bit unsigned";
3342 s =
"32-bit signed";
3352 s =
"64-bit double float";
3357 s =
"normalized 32-bit float";
3362 s =
"normalized 64-bit double float";
3375 #ifdef OSSIM_BUILD_DATE 3384 #ifdef OSSIM_REVISION 3393 #ifdef OSSIM_VERSION 3411 document.
write( file );
3416 bool result =
false;
void mtrs2ft(const ossim_float64 &meters, bool us_survey) const
Converts meters to feet and outputs to stdout.
virtual void valueToString(ossimString &valueResult) const =0
static const char * DESCRIPTION
Used by ossimUtilityFactory.
void write(std::ostream &output, const UsageMap &um, unsigned int widthOfOutput=80)
std::string getApplicationName() const
return the application name, as specified by argv[0]
const ossimKeywordlist & preferencesKWL() const
void addCommandLineOption(const ossimString &option, const ossimString &explanation)
void printResamplerFilters() const
Prints resampler filters to stdout.
bool pointWithin(const ossimDpt &pt, double epsilon=0.0) const
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
virtual void getSupportedExtensions(ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
void getPropertyList(std::vector< ossimRefPtr< ossimProperty > > &propertyList) const
virtual std::ostream & print(std::ostream &os) const
virtual void getFilterTypes(std::vector< ossimString > &filterTypes) const
void getUpIsUpAngle(ossimKeywordlist &kwl)
Populates keyword list with up_is_up_angle.
static ossimString upcase(const ossimString &aString)
void printReaderProps() const
Prints reader properties to stdout.
ossimInfo()
default constructor
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
bool isAffectedByElevation() const
Returns TRUE if this geometry is sensitive to elevation.
void getOpenCellList(std::vector< ossimFilename > &list) const
virtual ossimRefPtr< ossimNBandLutDataObject > getLut() const
ossim_float64 width() const
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
virtual void getPropertyList(std::vector< ossimRefPtr< ossimProperty > > &children) const
void printAllPluginInformation(std::ostream &out)
void getCenterGround(ossimKeywordlist &kwl)
Populates keyword list with image center ground point.
virtual ossimImageHandler * open(const ossimFilename &fileName, bool trySuffixFirst=true, bool openOverview=true) const
open that takes a filename.
void printConfiguration() const
Dumps ossim preferences/configuration data.
double lond() const
Will convert the radian measure to degrees.
bool addFile(const char *file)
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
bool write(const ossimFilename &file)
static const char * LR_X_KW
static ossimDatumFactoryRegistry * instance()
instance method
void getNorthUpAngle(ossimKeywordlist &kwl)
Populates keyword list with north_up_angle.
void addOptions(ossimArgumentParser &parser)
ossimRefPtr< ossimImageHandler > openImageHandler(const ossimFilename &file) const
Opens image.
ossimFilename expand() const
Method to do file name expansion.
virtual bool execute()
execute method.
void rad2deg(const ossim_float64 &radians) const
Converts radians to degrees and outputs to stdout.
virtual ossim_uint32 epsgCode() const
bool read(const std::string &str)
search for an occurance of a string in the argument list, on sucess remove that occurance from the li...
double nan()
void getBoundingRect(ossimIrect &bounding_rect) const
Get the bounding rect of (0, 0) to (imageSize.x-1, imageSize.y-1).
const ossimDpt & ul() const
bool keyIsTrue(const std::string &key) const
void openImageFromState(const ossimFilename &file)
Opens image handler and stores in m_img data member.
void mtrsPerDeg(const ossim_float64 &latitude) const
Get meters per degree for a given latitude and outputs to stdout.
virtual const ossimString & code() const
static ossimImageWriterFactoryRegistry * instance()
void getRadiometry(ossimScalarType scalar, std::string &s) const
Gets the radiometry string, i.e.
Numeric to string methods.
static const char * NUMBER_LINES_KW
void openImage(const ossimFilename &file)
static const char * TIE_POINT_LON_KW
virtual const ossimImageHandler * getOverview() const
static const char * NUMBER_INPUT_BANDS_KW
virtual const ossimString & name() const
void printOverviewTypes() const
Prints overview types to stdout.
std::shared_ptr< ossim::ImageHandlerState > getState()
virtual void getEntryName(ossim_uint32 entryIdx, std::string &name) const
Get the name of entry as a string.
static ossimObjectFactoryRegistry * instance()
void testPlugin(const ossimFilename &plugin) const
Test a plugin load and outputs to stdout.
static const char * NUMBER_ENTRIES_KW
virtual ossimString getClassName() const
std::ostream & ecef2llh(const ossimEcefPoint &ecefPoint, std::ostream &out) const
Converts ecef point to lat lon height.
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
void setCommandLineUsage(const ossimString &explanation)
void outputXml(const ossimKeywordlist &kwl) const
Convert keyword list to xml then outputs to standard out.
ossimApplicationUsage * getApplicationUsage()
ossimRefPtr< ossimImageHandler > getImageHandler()
double latd() const
void wrap()
Wrap method to maintain longitude between -180 and +180 and latitude between -90 and +90...
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
std::ostream & printWriterProps(std::ostream &out) const
Prints list of writers from getImageTypeList.
virtual ossimString getShortName() const
const ossimDrect & expand(const ossimDpt &padding)
static const char * METERS_PER_PIXEL_Y_KW
void toPoint(const std::string &s)
Initializes this point from string.
void getImg2grd(ossimKeywordlist &kwl)
Populates keyword list with ground point for image point.
void ft2mtrs(const ossim_float64 &feet, bool us_survey) const
Converts feet to meters and outputs to stdout.
const ossimDatum * datum() const
datum().
ossimRefPtr< ossimImageHandler > m_img
Holds the open image.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
Retuns the min pixel value.
void getImageInfo(const ossimFilename &file, bool dumpFlag, bool dnoFlag, bool imageGeomFlag, bool imageInfoFlag, bool metaDataFlag, bool paletteFlag, ossimKeywordlist &kwl) const
getImageInfo Method to open image "file" and get image info in the form of a ossimKeywordlist.
void reportRemainingOptionsAsUnrecognized(ossimErrorSeverity severity=OSSIM_BENIGN)
for each remaining option report it as an unrecongnized.
ossimString toString() const
void printDatums() const
Dumps datum list to stdout.
void printFonts() const
Prints fonts list to stdout.
void outputHeight(const ossimGpt &gpt) const
Gets the height for ground point (latitude, longitude).
std::shared_ptr< ossimInfoBase > create(const ossimFilename &file) const
Create method.
bool getRgbBands(ossimImageHandler *ih, ossim_uint32 entry, ossimKeywordlist &kwl) const
Populates keyword list with rgb bands if available.
void getFontInformation(std::vector< ossimFontInformation > &informationList) const
static const char * LR_Y_KW
void getImageMetadata(ossimKeywordlist &kwl) const
Populates keyword list with metadata.
static ossimSharedPluginRegistry * instance()
static const char * UL_X_KW
bool errors(ossimErrorSeverity severity=OSSIM_BENIGN) const
void fromKwl(const ossimKeywordlist &kwl)
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual const ossimFilename & getFilename() const
Returns the filename.
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
void getRevisionNumber(std::string &s) const
Gets revision number.
virtual ossimString getFamilyName() const
virtual double getHeightAboveEllipsoid(const ossimGpt &gpt)
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
Method to populate a list of supported types of all factories registered to this registry.
bool toBool() const
String to numeric methods.
void deg2rad(const ossim_float64 °rees) const
Converts degrees to radians and outputs to stdout.
unsigned int ossim_uint32
virtual ~ossimInfo()
virtual destructor
virtual const ossimDatum * create(const ossimString &code) const
create method
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
virtual const ossimEllipsoid * ellipsoid() const
static const char * NUMBER_OUTPUT_BANDS_KW
static ossimGeoidManager * instance()
Implements singelton pattern:
ossim_float64 toFloat64() const
virtual bool getRgbBandList(std::vector< ossim_uint32 > &bandList) const
Convenience method to get the zero based rgb output band list.
virtual void getList(std::vector< ossimString > &list) const
getList method to return a combined list of all datums from registered datum factories.
ossim_uint32 executeImageOptions(const ossimFilename &file)
handles image options.
void closeImage()
Closes image if open.
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
void prettyPrint(const ossimFilename &file) const
Dumps the image information from ossimInfoFactoryRegistry.
ossim_float32 toFloat32() const
virtual bool initialize(ossimArgumentParser &ap)
Initial method.
ossimFont * getDefaultFont() const
static const char * UL_Y_KW
const std::vector< T > & getList() const
void printExtensions() const
Prints supported image file extensions to stdout.
virtual ossim_uint32 getNumberOfEntries() const
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
ossim_float64 height() const
void save(ossimKeywordlist &kwl, const char *prefix) const
Output list to the kwl.
bool isImageEntryOverview() const
void getGrd2img(ossimKeywordlist &kwl)
Populates keyword list with image point for grund point.
static ossimPreferences * instance()
void dumpImage(const ossimFilename &file, bool dnoFlag, ossimKeywordlist &kwl) const
Dumps the image information from ossimInfoFactoryRegistry to keyword list.
static ossimProjectionFactoryRegistry * instance()
void printWriters() const
Prints list of available writers to stdout.
void printZoomLevelGsds() const
Prints zoom levels to stdout.
static const char * ENTRY_KW
static ossimOverviewBuilderFactoryRegistry * instance()
instance method for access to theInstance pointer.
ossimString toString(ossim_uint32 precision=15) const
virtual void setUsage(ossimArgumentParser &ap)
Adds application arguments to the argument parser.
static ossimFontFactoryRegistry * instance()
virtual double getHeightAboveMSL(const ossimGpt &gpt)
Height access methods:
static ossimInfoFactoryRegistry * instance()
instance method
This class defines an abstract Handler which all image handlers(loaders) should derive from...
void getImageBounds(ossimKeywordlist &kwl)
Populates keyword list with edge to edge image bounds.
ossimDpt midPoint() const
void getVersion(std::string &s) const
Gets version.
void setDescription(const ossimString &desc)
void printProjections() const
Prints projections to stdout.
double geodeticRadius(const double &latitude) const
const ossimDpt & ur() const
virtual ossimObject * createObject(const ossimString &name) const
void printFactories(bool keywordListFlag) const
Prints factories.
ossim_uint32 getSize() const
void printPlugins() const
Prints loaded plugins to stdout.
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
static std::shared_ptr< ImageHandlerStateRegistry > instance()
static ossimInit * instance()
ossim_float64 upIsUpAngle(const ossimDpt &) const
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossimDpt metersPerDegree() const
Saves the transform (if any) and projection (if any) states to the KWL.
void getCenterImage(ossimKeywordlist &kwl)
Populates keyword list with image center point.
static ossimImageHandlerRegistry * instance()
Returns zero-based bounding rectangle of the image.
std::ostream & printImageTypeList(std::ostream &out) const
std::ostream & printReaderProps(std::ostream &out) const
Prints list of readers and properties.
const ossimDpt & ll() const
static const char * TIE_POINT_LAT_KW
static ossimSupportFilesList * instance()
void getImagePalette(ossimKeywordlist &kwl)
Populates keyword list with palette data.
std::basic_istringstream< char > istringstream
Class for char input memory streams.
void getImageGeometryInfo(ossimKeywordlist &kwl, bool dnoFlag)
Populates keyword list with image geometry/projection information.
void printWriterProps() const
Prints writer properties to stdout.
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
ossim_float64 northUpAngle() const
virtual double offsetFromEllipsoid(const ossimGpt &gpt)
const ossimDpt & lr() const
void getImageRect(ossimKeywordlist &kwl)
Populates keyword list with image rectangle.
int & argc()
return the argument count.
static const char * METERS_PER_PIXEL_X_KW
static const char * NUMBER_SAMPLES_KW
void getBuildDate(std::string &s) const
Gets build date.
ossimFilename getPreferencesFilename() const
std::basic_ostream< char > ostream
Base class for char output streams.
To string method.
void writeErrorMessages(std::ostream &output, ossimErrorSeverity sevrity=OSSIM_BENIGN)
write out error messages at an above specified .
const std::string & string() const
bool isnan(const float &v)
