ossimToolClient Class Reference
Utility class providing an interface to ossimTool-derived functionality via TCP sockets Results are returned either as streamed text (for non-image responses such as image info) or streamed binary file representing imagery or vector products. More...
#include <ossimToolClient.h>
Public Member Functions
 ossimToolClient ()
 ~ossimToolClient ()
 Closes any open connections. More...
int connectToServer (char *hostname, char *portname=NULL)
 Accepts hostname and portname as a string. More...
bool setProductFilePath (const char *filepath)
 Sets the local destination directory for file product. More...
const char * getProductFilePath () const
 Returns the filename (including full client-side path) of the local product file waiting after execute(), or NULL if none. More...
bool execute (const char *command_spec)
 Executes OSSIM tool command with options. More...
const char * getTextResponse () const
 Returns the server's text response generated by the execute() call, or NULL if no response available. More...
bool disconnect ()
 Closes connection to server and ready to connect again. More...
Protected Member Functions
void error (const char *msg)
bool receiveText ()
bool receiveFile ()
bool acknowledgeRcv ()
Protected Attributes
int m_svrsockfd
char * m_buffer
ossimFilename m_prodFilePath
ossimString m_textResponse
Detailed Description
Code interfacing to this class should know the commands available (or execute the command "help" and view the text response).
Definition at line 20 of file ossimToolClient.h.
◆ ossimToolClient()
ossimToolClient::ossimToolClient ( )
Definition at line 31 of file ossimToolClient.cpp.
References m_buffer, MAX_BUF_LEN, and setProductFilePath().
32 : m_svrsockfd(-1),
33  m_buffer(new char[MAX_BUF_LEN])
34 {
35  ossimFilename tmpdir = "/tmp";
36 #ifdef _MSC_VER
37  if (GetTempPath(MAX_BUF_LEN, m_buffer))
38  tmpdir = m_buffer;
39 #endif
40  setProductFilePath(tmpdir);
41 }
#define MAX_BUF_LEN
bool setProductFilePath(const char *filepath)
◆ ~ossimToolClient()
ossimToolClient::~ossimToolClient ( )
Definition at line 43 of file ossimToolClient.cpp.
References disconnect().
44 {
45  disconnect();
46 }
bool disconnect()
Member Function Documentation
◆ acknowledgeRcv()
bool ossimToolClient::acknowledgeRcv ( )
protected
Definition at line 288 of file ossimToolClient.cpp.
References _DEBUG_, error(), and m_svrsockfd.
Referenced by receiveFile(), and receiveText().
289 {
290  if (_DEBUG_) cout<<"ossimToolClient:"<<__LINE__<<" sending \"ok_to_send\"..."<<endl; //TODO REMOVE DEBUG
291  int r = send(m_svrsockfd, "ok_to_send", 11, 0);
292  if (r < 0)
293  {
294  error("ERROR writing to socket");
295  return false;
296  }
297  if (_DEBUG_) cout << "Receive acknowledged."<<endl;
298  return true;
299 }
#define _DEBUG_
void error(const char *msg)
◆ connectToServer()
int ossimToolClient::connectToServer ( char *  hostname,
char *  portname = NULL
Returns socket file descriptor or -1 if error.
Definition at line 73 of file ossimToolClient.cpp.
References ossimString::after(), ossimString::before(), ossimString::contains(), disconnect(), ossimString::empty(), error(), if(), m_svrsockfd, and ossimString::stringDup().
74 {
75  m_svrsockfd = -1;
76  while (1)
77  {
78  // Consider port number in host URL:
79  ossimString host (hostname);
80  ossimString port;
81  if (portname)
82  port = portname;
83  else if (host.contains(":"))
84  {
85  port = host.after(":");
86  host = host.before(":");
87  }
88
89  if (port.empty())
90  {
91  // Maybe implied port then '/':
92  port = host.after("/");
93  port = "/" + port;
94  host = host.before("/");
95  }
96
97  // Establish full server address including port:
98  struct addrinfo hints;
99  memset(&hints, 0, sizeof hints); // make sure the struct is empty
100  hints.ai_family = AF_INET; // don't care IPv4 or IPv6
101  hints.ai_socktype = SOCK_STREAM; // TCP stream sockets
102  hints.ai_canonname = host.stringDup(); // fill in my IP for me
103  struct addrinfo *res;
104  int failed = getaddrinfo(host.stringDup(), port.stringDup(), &hints, &res);
105  if (failed)
106  {
107  error(gai_strerror(failed));
108  break;
109  }
110
111  // Create socket for this server by walking the linked list of available addresses:
112  struct addrinfo *server_info = res;
113  while (server_info)
114  {
115  m_svrsockfd =
116  socket(server_info->ai_family, server_info->ai_socktype, server_info->ai_protocol);
117  if (m_svrsockfd >= 0)
118  break;
119  server_info = server_info->ai_next;
120  }
121  if ((m_svrsockfd < 0) || (server_info == NULL))
122  {
123  error("Error opening socket");
124  break;
125  }
126
127  // Connect to the server:portno:
128  struct sockaddr_in* serv_addr = (sockaddr_in*) server_info->ai_addr;
129  serv_addr->sin_family = AF_INET;
130  if (connect(m_svrsockfd,(struct sockaddr*) serv_addr, server_info->ai_addrlen) < 0)
131  {
132  error("ERROR connecting");
133  disconnect();
134  }
135
136  break;
137  }
138  return m_svrsockfd;
139 }
ossimString before(const ossimString &str, std::string::size_type pos=0) const
METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If strin...
char * stringDup() const
if(yy_init)
bool empty() const
Definition: ossimString.h:411
bool disconnect()
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
◆ disconnect()
bool ossimToolClient::disconnect ( )
Definition at line 48 of file ossimToolClient.cpp.
References error(), and m_svrsockfd.
Referenced by connectToServer(), and ~ossimToolClient().
49 {
50  bool success = true;
51
52  if (m_svrsockfd < 0)
53  return success;
54
55  // Need to send close request to server:
56  if (close(m_svrsockfd) < 0)
57  {
58  error("Error closing socket");
59  success = false;
60  }
61
62  m_svrsockfd = -1;
63  return success;
64 }
◆ error()
void ossimToolClient::error ( const char *  msg)
protected
Definition at line 67 of file ossimToolClient.cpp.
Referenced by acknowledgeRcv(), connectToServer(), disconnect(), execute(), receiveFile(), receiveText(), and setProductFilePath().
68 {
69  perror(msg);
70 }
◆ execute()
bool ossimToolClient::execute ( const char *  command_spec)
Examples:
"info -p <server-side-filename>" – Fetches projection info for server side file specified "shoreline -i <server/path/band3.tif>, <server/path/band6.tif> <server/path/output.json>"
Returns TRUE if product generated and received. setProductFilePath() must be called prior to execute() for operations generating file products, otherwise the products are written to the client's temp directory.
Definition at line 142 of file ossimToolClient.cpp.
References _DEBUG_, ossimString::contains(), error(), ossimFilename::isDir(), m_buffer, m_prodFilePath, m_svrsockfd, MAX_BUF_LEN, n, ossimFilename::path(), receiveFile(), and receiveText().
143 {
144  // Clear previous file path of product filename:
145  if (!m_prodFilePath.isDir())
147
148  if (command_spec == NULL)
149  return false;
150
151  // Write command to the OSSIM tool server socket:
152  if (_DEBUG_) cout<<"ossimToolClient:"<<__LINE__<<" sending <"<<command_spec<<">..."<<endl; //TODO REMOVE DEBUG
153  int n = send(m_svrsockfd, command_spec, strlen(command_spec), 0);
154  if (n < 0)
155  {
156  error("ERROR writing to socket");
157  return false;
158  }
159  while (n < (int) strlen(command_spec))
160  {
161  // Partial send, try remainder of buffer:
162  if (_DEBUG_) cout<<"ossimToolClient:"<<__LINE__<<" sending <"<<&(command_spec[n])<<">..."<<endl; //TODO REMOVE DEBUG
163  int r = send(m_svrsockfd, &(command_spec[n]), strlen(command_spec)-n, 0);
164  if (r < 0)
165  {
166  error("ERROR writing to socket");
167  return false;
168  }
169  n += r;
170  }
171
172  // Process response from server. First read the response type. Can be either:
173  // "TEXT" -- only text is streamed
174  // "FILE" -- a file is treamed
175  // "MIXED" -- Both file and text
176  // "ERROR" -- only text with error message. No product generated.
177  // "ADIOS" -- Server acknowledges disconnect
178  bool success = false;
179  memset(m_buffer, 0, MAX_BUF_LEN);
180  if (_DEBUG_) cout<<"ossimToolClient:"<<__LINE__<<" Waiting to recv"<<endl; //TODO REMOVE DEBUG
181  n = recv(m_svrsockfd, m_buffer, 5, 0);
182  if (_DEBUG_) cout<<"ossimToolClient:"<<__LINE__<<" Received <"<<m_buffer<<">"<<endl; //TODO REMOVE DEBUG
183  if (n < 0)
184  {
185  error("ERROR reading from socket");
186  return false;
187  }
188  ossimString response (string(m_buffer, n));
189  if (response.contains("TEXT"))
190  success = receiveText();
191  else if (response.contains("FILE"))
192  success = receiveFile();
193  else if (response.contains("MIXED"))
194  success = receiveText() && receiveFile();
195  else if (response.contains("ERROR"))
196  receiveText(); // success = false;
197  else if (response.contains("ADIOS"))
198  error("Received unexpected disconnect message from server.");
199  else
200  error("Unknown type in response header");
201
202  return success;
203 }
bool isDir() const
#define MAX_BUF_LEN
os2<< "> n<< " > nendobj n
#define _DEBUG_
ossimFilename path() const
◆ getProductFilePath()
const char* ossimToolClient::getProductFilePath ( ) const
inline
Definition at line 49 of file ossimToolClient.h.
49 { return m_prodFilePath; }
◆ getTextResponse()
const char* ossimToolClient::getTextResponse ( ) const
inline
Some operations generate both text and file products.
Definition at line 67 of file ossimToolClient.h.
67 { return m_textResponse.chars(); }
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
◆ receiveFile()
bool ossimToolClient::receiveFile ( )
protected
Definition at line 231 of file ossimToolClient.cpp.
References acknowledgeRcv(), ossimString::after(), ossimString::chars(), ossimFilename::dirCat(), error(), m_buffer, m_prodFilePath, m_svrsockfd, m_textResponse, MAX_BUF_LEN, n, receiveText(), and ossimString::toInt().
Referenced by execute().
232 {
233  ostringstream xmsg;
234  cout << "Server requesting file send. " <<endl;
235
236  // Fetch the file size in bytes as the next message "SIZE: GGGMMMKKKBBB", (18 bytes)
237  if (!receiveText())
238  return false;
239  int filesize = m_textResponse.after("SIZE: ").toInt();
240  cout << "File size = " <<filesize<<endl;
241
242  // Fetch the filename as next message "NAME: AAAAA...", (256 bytes)
243  if (!receiveText())
244  return false;
245  ossimFilename fileName (m_textResponse.after("NAME: "));
247  cout << "File name = " <<m_prodFilePath<<endl;
248
249  // Open file for writing:
250  ofstream fout (m_prodFilePath.chars());
251  if (fout.fail())
252  {
253  xmsg <<"ERROR opening output file: <"<<m_prodFilePath<<">"<<ends;
254  error(xmsg.str().c_str());
255  return false;
256  }
257
258  memset(m_buffer, 0, MAX_BUF_LEN);
259  int n = MAX_BUF_LEN;
260  int numBytes = 0;
261  while ((n == MAX_BUF_LEN) && (numBytes < filesize))
262  {
263  n = recv(m_svrsockfd, m_buffer, MAX_BUF_LEN, 0);
264  if (n < 0)
265  {
266  error("ERROR reading from socket");
267  return false;
268  }
269  fout.write(m_buffer, n);
270  if (fout.fail())
271  {
272  error("ERROR on file write().");
273  return false;
274  }
275  numBytes += n;
276  }
277
278  if (!acknowledgeRcv())
279  return false;
280
281  cout<<"\nossim-client: Received and wrote "<<numBytes<<" bytes to: <"<<m_prodFilePath<<">."<<endl;;
282  fout.close();
283
284  return true;
285 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
#define MAX_BUF_LEN
ossimFilename dirCat(const ossimFilename &file) const
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
int toInt() const
◆ receiveText()
bool ossimToolClient::receiveText ( )
protected
Definition at line 206 of file ossimToolClient.cpp.
References _DEBUG_, acknowledgeRcv(), ossimString::append(), ossimString::c_str(), ossimString::clear(), error(), m_buffer, m_svrsockfd, m_textResponse, MAX_BUF_LEN, and n.
Referenced by execute(), and receiveFile().
207 {
208  int n = MAX_BUF_LEN;
210  while (n == MAX_BUF_LEN)
211  {
212  memset(m_buffer, 0, MAX_BUF_LEN);
213  if (_DEBUG_) cout<<"ossimToolClient:"<<__LINE__<<" Waiting to recv"<<endl; //TODO REMOVE DEBUG
214  n = recv(m_svrsockfd, m_buffer, MAX_BUF_LEN, 0);
215  if (_DEBUG_) cout<<"ossimToolClient:"<<__LINE__<<" Received <"<<m_buffer<<">"<<endl; //TODO REMOVE DEBUG
216  if (n < 0)
217  {
218  error("ERROR reading from socket");
219  return false;
220  }
222  }
223  if (!acknowledgeRcv())
224  return false;
225
226  printf("Text response:\n-----------------\n%s\n-----------------\n",m_textResponse.c_str());
227  return true;
228 }
void clear()
Erases the entire container.
Definition: ossimString.h:432
const ossimString & append(const ossimString &s)
Definition: ossimString.h:831
#define MAX_BUF_LEN
#define _DEBUG_
const char * c_str() const
Definition: ossimString.h:396
◆ setProductFilePath()
bool ossimToolClient::setProductFilePath ( const char *  filepath)
The product file name used will match the server-side's file name. This method must be called prior to execute() for operations generating file products, otherwise the products are written to the client's temp directory. If the path directory specified does not exist, it will be created. Returns true if successful.
Definition at line 302 of file ossimToolClient.cpp.
References ossimFilename::createDirectory(), error(), ossimFilename::exists(), ossimFilename::isWriteable(), and m_prodFilePath.
Referenced by ossimToolClient().
303 {
304  if (filepath == NULL)
305  m_prodFilePath = "./";
306  else
307  m_prodFilePath = filepath;
308
309  ostringstream xmsg;
311  {
312  xmsg <<"ERROR creating output directory: <"<<m_prodFilePath<<">"<<ends;
313  error(xmsg.str().c_str());
314  }
315  else if (!m_prodFilePath.isWriteable())
316  {
317  xmsg <<"ERROR output directory: <"<<m_prodFilePath<<"> is not writable."<<ends;
318  error(xmsg.str().c_str());
319  }
320  return true;
321 }
bool isWriteable() const
bool exists() const
bool createDirectory(bool recurseFlag=true, int perm=0775) const
Member Data Documentation
◆ m_buffer
char* ossimToolClient::m_buffer
protected
Definition at line 83 of file ossimToolClient.h.
Referenced by execute(), ossimToolClient(), receiveFile(), and receiveText().
◆ m_prodFilePath
ossimFilename ossimToolClient::m_prodFilePath
protected
Definition at line 84 of file ossimToolClient.h.
Referenced by execute(), receiveFile(), and setProductFilePath().
◆ m_svrsockfd
int ossimToolClient::m_svrsockfd
protected
◆ m_textResponse
ossimString ossimToolClient::m_textResponse
protected
Definition at line 85 of file ossimToolClient.h.
