Public Member Functions | Protected Member Functions | Static Private Attributes | List of all members
ossimU11ImageData Class Reference
#include <ossimU11ImageData.h>
Inheritance diagram for ossimU11ImageData:
ossimImageData ossimRectilinearDataObject ossimDataObject ossimObject ossimReferenced
 ossimU11ImageData (ossimSource *source, ossim_uint32 bands=1)
 ossimU11ImageData (ossimSource *source, ossim_uint32 bands, ossim_uint32 width, ossim_uint32 height)
 ossimU11ImageData (const ossimU11ImageData &rhs)
void fill (ossim_uint32 band, double value)
bool isNull (ossim_uint32 offset) const
void setNull (ossim_uint32 offset)
virtual ossimDataObjectStatus validate () const
virtual void getNormalizedFloat (ossim_uint32 offset, ossim_uint32 bandNumber, float &result) const
virtual void setNormalizedFloat (ossim_uint32 offset, ossim_uint32 bandNumber, float input)
virtual void convertToNormalizedFloat (ossimImageData *result) const
virtual void convertToNormalizedDouble (ossimImageData *result) const
virtual void unnormalizeInput (ossimImageData *normalizedInput)
virtual double computeAverageBandValue (ossim_uint32 bandNumber=0)
virtual double computeMeanSquaredError (double meanValue, ossim_uint32 bandNumber=0)
virtual void setValue (long x, long y, double color)
virtual void copyTileToNormalizedBuffer (double *buf) const
virtual void copyNormalizedBufferToTile (double *buf)
virtual void copyTileToNormalizedBuffer (ossim_uint32 band, double *buf) const
virtual void copyTileToNormalizedBuffer (ossim_uint32 band, float *buf) const
virtual void copyTileToNormalizedBuffer (float *buf) const
virtual void copyNormalizedBufferToTile (float *buf)
virtual void copyNormalizedBufferToTile (ossim_uint32 band, double *buf)
virtual void copyNormalizedBufferToTile (ossim_uint32 band, float *buf)
virtual ossim_float64 getMinNormalizedPix () const
- Public Member Functions inherited from ossimImageData
 ossimImageData (const ossimImageData &rhs)
 copy constructor More...
 ossimImageData ()
 ossimImageData (ossimSource *source, ossimScalarType scalar, ossim_uint32 bands=1)
 Constructor. More...
 ossimImageData (ossimSource *source, ossimScalarType scalar, ossim_uint32 bands, ossim_uint32 width, ossim_uint32 height)
virtual ~ossimImageData ()
 virtual destructor More...
virtual const ossimImageDataoperator= (const ossimImageData &rhs)
 assignment operator= More...
virtual ossim_uint32 getWidth () const
virtual ossim_uint32 getHeight () const
virtual ossimIrect getImageRectangle () const
virtual void getWidthHeight (ossim_uint32 &w, ossim_uint32 &h)
virtual void setWidth (ossim_uint32 width)
virtual void setHeight (ossim_uint32 height)
virtual void setWidthHeight (ossim_uint32 w, ossim_uint32 h)
virtual void setImageRectangleAndBands (const ossimIrect &rect, ossim_uint32 numberOfBands)
virtual void setImageRectangle (const ossimIrect &rect)
virtual void setOrigin (const ossimIpt &origin)
virtual void assign (const ossimDataObject *data)
virtual void assign (const ossimImageData *data)
virtual void assignBand (const ossimImageData *data, ossim_uint32 source_band, ossim_uint32 output_band)
virtual ossim_uint32 getHashId () const
 Uses prime numbers as coefficients for this summation. More...
virtual void setNullPix (ossim_float64 null_pix)
virtual void setNullPix (ossim_float64 null_pix, ossim_uint32 band)
virtual void setNullPix (const ossim_float64 *nullPixArray, ossim_uint32 numberOfValues)
virtual void setMinPix (ossim_float64 min_pix)
virtual void setMinPix (ossim_float64 min_pix, ossim_uint32 band)
virtual void setMinPix (const ossim_float64 *minPixArray, ossim_uint32 numberOfValues)
virtual void setMaxPix (ossim_float64 max_pix)
virtual void setMaxPix (ossim_float64 max_pix, ossim_uint32 band)
virtual void setMaxPix (const ossim_float64 *maxPixArray, ossim_uint32 numberOfValues)
virtual const ossimIptgetOrigin () const
virtual void computeMinMaxPix (std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands) const
 If the minBands and maxBands are empty or not equal to the imageData's current number of bands it will erase the contents, resize, and then replace the values in the passed in array with this objects min max values. More...
virtual void computeMinMaxNulPix (std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands, std::vector< ossim_float64 > &nulBands) const
 Scans tile for min, max, nulls. More...
virtual const ossim_float64getNullPix () const
virtual const ossim_float64getMinPix () const
virtual const ossim_float64getMaxPix () const
virtual ossim_float64 getNullPix (ossim_uint32 band) const
virtual ossim_float64 getMinPix (ossim_uint32 band) const
virtual ossim_float64 getMaxPix (ossim_uint32 band) const
virtual ossimString getScalarTypeAsString () const
virtual ossim_uint32 getNumberOfBands () const
virtual void setNumberOfBands (ossim_uint32 bands, bool reallocate=false)
virtual ossim_float64 getPix (const ossimIpt &position, ossim_uint32 band=0) const
 Will return the pixel at location position. More...
virtual ossim_float64 getPix (ossim_uint32 offset, ossim_uint32 band=0) const
 Will return the pixel at offset and band number. More...
void fill (ossim_uint32 band, ossim_float64 value)
 will fill the entire band with the value. More...
void fill (ossim_float64 value)
 will fill all bands with the passed in value. More...
void createTestTile ()
 Creates a step wedge for testing only. More...
bool isNull (ossim_uint32 offset, ossim_uint32 band) const
void setNull (ossim_uint32 offset, ossim_uint32 band)
bool isNull (const ossimIpt &pt) const
void setNull (const ossimIpt &pt)
bool isNull (const ossimIpt &pt, ossim_uint32 band) const
void setNull (const ossimIpt &pt, ossim_uint32 band)
virtual bool isValidBand (ossim_uint32 band) const
virtual ossimRefPtr< ossimImageDatanewNormalizedFloat () const
 Will take this tile and normalize it to a newly allocated floating point tile. More...
virtual ossimImageDatanewNormalizedDouble () const
 Will take this tile and normalize it to a newly allocated double point tile. More...
template<class T >
void copyTileToFloatBuffer (T, ossim_float32 *buf) const
virtual ossim_float64 computeAverageBandValue (ossim_uint32 bandNumber=0) const
 This will compute the average value for the band. More...
virtual ossim_float64 computeMeanSquaredError (ossim_float64 meanValue, ossim_uint32 bandNumber=0) const
 This will call the compute average band value and then use that in the calculation of: More...
virtual void populateHistogram (ossimRefPtr< ossimMultiBandHistogram > histo)
virtual void setHistogram (ossimRefPtr< ossimMultiResLevelHistogram > histo)
ossimRefPtr< ossimMultiResLevelHistogramgetHistogram ()
virtual bool hasAlpha () const
virtual const ossim_uint8getAlphaBuf () const
virtual ossim_uint8getAlphaBuf ()
virtual const void * getBuf () const
virtual const ossim_uint8getUcharBuf () const
virtual const ossim_uint16getUshortBuf () const
virtual const ossim_sint16getSshortBuf () const
virtual const ossim_float32getFloatBuf () const
virtual const ossim_float64getDoubleBuf () const
virtual void * getBuf ()
virtual ossim_uint8getUcharBuf ()
virtual ossim_uint16getUshortBuf ()
virtual ossim_sint16getSshortBuf ()
virtual ossim_float32getFloatBuf ()
virtual ossim_float64getDoubleBuf ()
virtual const void * getBuf (ossim_uint32 band) const
virtual const ossim_uint8getUcharBuf (ossim_uint32 band) const
virtual const ossim_uint16getUshortBuf (ossim_uint32 band) const
virtual const ossim_sint16getSshortBuf (ossim_uint32 band) const
virtual const ossim_float32getFloatBuf (ossim_uint32 band) const
virtual const ossim_float64getDoubleBuf (ossim_uint32 band) const
virtual void * getBuf (ossim_uint32 band)
virtual ossim_uint8getUcharBuf (ossim_uint32 band)
virtual ossim_uint16getUshortBuf (ossim_uint32 band)
virtual ossim_sint16getSshortBuf (ossim_uint32 band)
virtual ossim_float32getFloatBuf (ossim_uint32 band)
virtual ossim_float64getDoubleBuf (ossim_uint32 band)
virtual ossim_uint32 getSize () const
 Returns the total number of pixels in a tile for all bands. More...
virtual ossim_uint32 getSizePerBand () const
 Returns the number of pixels in a single band in a tile. More...
virtual ossim_uint32 getSizePerBandInBytes () const
 Returns the number of bytes in single band of the tile. More...
virtual ossim_uint32 getDataSizeInBytes () const
virtual ossim_uint32 getSizeInBytes () const
 Returns the total number of bytes for all bands. More...
virtual void makeBlank ()
 Initializes data to null pixel values. More...
virtual void initialize ()
 Initialize the data buffer. More...
virtual bool write (const ossimFilename &f) const
 Writes tile to stream. More...
virtual void copyTileBandToNormalizedBuffer (ossim_uint32 band, ossim_float64 *buf) const
 Will copy this tiles specified band number to the normalized buffer. More...
virtual void copyTileBandToNormalizedBuffer (ossim_uint32 band, ossim_float32 *buf) const
virtual bool isWithin (ossim_int32 x, ossim_int32 y)
virtual void setValue (ossim_int32 x, ossim_int32 y, ossim_float64 color)
virtual void loadBand (const void *src, const ossimIrect &src_rect, ossim_uint32 band)
virtual void loadBand (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, ossim_uint32 band)
virtual void loadTile (const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual void loadTileWithAlpha (const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual void loadTile (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, ossimInterleaveType il_type)
virtual void nullTileAlpha (const ossim_uint8 *src, const ossimIrect &src_rect, bool mutliplyAlphaFlag=false)
virtual void nullTileAlpha (const ossim_uint8 *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, bool multiplyAlphaFlag=false)
virtual void loadTile (const ossimImageData *src)
 Will load a tile of different types. More...
virtual void loadTileFrom1Band (const ossimImageData *data)
virtual void loadTileFrom1Band (const void *src, const ossimIrect &src_rect)
virtual void loadShortBand (const void *src, const ossimIrect &src_rect, ossim_uint32 band, bool swap_bytes=false)
 Specialized to load a tile from a short (16 bit scalar type) buffer. More...
virtual void unloadBand (void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, ossimInterleaveType il_type=OSSIM_BSQ, OverwriteBandRule ow_type=NULL_RULE) const
 This routine is designed for overwriting a selected band of the destination buffer 'dest' by an independent selected band of the source buffer according to a user-selected rule, defined by OverwriteBandRule. More...
virtual void unloadBand (void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, const ossimIrect &clip_rect, ossimInterleaveType il_type=OSSIM_BSQ, OverwriteBandRule ow_type=NULL_RULE) const
virtual void unloadBand (void *dest, const ossimIrect &dest_rect, ossim_uint32 src_band) const
virtual void unloadBand (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect, ossim_uint32 src_band) const
virtual void unloadTile (void *dest, const ossimIrect &dest_rect, ossimInterleaveType il_type) const
virtual void unloadTile (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect, ossimInterleaveType il_type) const
virtual void unloadTileToBipAlpha (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const
virtual bool isPointWithin (const ossimIpt &point) const
virtual bool isPointWithin (ossim_int32 x, ossim_int32 y) const
 Generic print method. More...
virtual void stretchMinMax ()
 Performs linear stretch on tile data from min/max to limits of scalar type. More...
virtual void computeAlphaChannel ()
 Computes the alpha channel. More...
virtual void copyLine (const void *src, ossim_int32 lineNumber, ossim_int32 lineStartSample, ossim_int32 lineStopSample, ossimInterleaveType lineInterleave)
 Method to copy a single line to the tile. More...
void setIndexedFlag (bool flag)
 Sets the indexed flag. More...
bool getIndexedFlag () const
ossim_float64 percentFull () const
 Returns the percentage (0-100) of data buffer containing non-null (valid) entries. More...
virtual bool isEqualTo (const ossimDataObject &rhs, bool deepTest=false) const
template<class T >
void computeMinMaxPix (T, vector< ossim_float64 > &minBands, vector< ossim_float64 > &maxBands) const
template<class T >
void computeMinMaxNulPix (T, vector< ossim_float64 > &minBands, vector< ossim_float64 > &maxBands, vector< ossim_float64 > &nulBands) const
- Public Member Functions inherited from ossimRectilinearDataObject
 ossimRectilinearDataObject ()
 default constructor More...
 ossimRectilinearDataObject (const ossimRectilinearDataObject &rhs)
 ossimRectilinearDataObject (ossim_uint32 numberOfSpatialComponents, ossimSource *owner, ossim_uint32 numberOfDataComponents, ossimScalarType scalarType=OSSIM_SCALAR_UNKNOWN, ossimDataObjectStatus status=OSSIM_NULL)
 ossimRectilinearDataObject (ossimSource *owner, ossim_uint32 numberOfDataComponents, ossim_uint32 length, ossimScalarType scalarType=OSSIM_SCALAR_UNKNOWN, ossimDataObjectStatus status=OSSIM_NULL)
 This is a helper constructor that allows one to instantiate a one dimensional Spatial component with N number of data components. More...
 ossimRectilinearDataObject (ossimSource *owner, ossim_uint32 numberOfDataComponents, ossim_uint32 width, ossim_uint32 height, ossimScalarType scalarType=OSSIM_SCALAR_UNKNOWN, ossimDataObjectStatus status=OSSIM_NULL)
 This is a helper constructor that allows one to instantiate a two dimensional Spatial component (WidthxHeight) with N number of data components. More...
 ossimRectilinearDataObject (ossimSource *owner, ossim_uint32 numberOfDataComponents, ossim_uint32 width, ossim_uint32 height, ossim_uint32 depth, ossimScalarType scalarType=OSSIM_SCALAR_UNKNOWN, ossimDataObjectStatus status=OSSIM_NULL)
 This is a helper constructor that allows one to instantiate a two dimensional Spatial component (WidthxHeightxDepth) with N number of data components. More...
virtual ~ossimRectilinearDataObject ()
virtual void setNumberOfDataComponents (ossim_uint32 n)
 How many components make up this data object. More...
virtual void setSpatialExtents (ossim_uint32 *extents, ossim_uint32 size)
virtual void setScalarType (ossimScalarType type)
 See ossimScalarType in ossimConstants for a full list. More...
virtual ossim_uint32 getNumberOfDataComponents () const
virtual ossim_uint32 getNumberOfSpatialComponents () const
virtual const ossim_uint32getSpatialExtents () const
virtual ossimScalarType getScalarType () const
virtual ossim_uint32 getScalarSizeInBytes () const
virtual void assign (const ossimRectilinearDataObject *data)
virtual ossim_uint32 computeSpatialProduct () const
virtual const ossimRectilinearDataObjectoperator= (const ossimRectilinearDataObject &rhs)
- Public Member Functions inherited from ossimDataObject
 ossimDataObject (ossimSource *source=0, ossimDataObjectStatus status=OSSIM_STATUS_UNKNOWN)
 ossimDataObject (const ossimDataObject &rhs)
virtual ~ossimDataObject ()
virtual void setOwner (ossimSource *aSource)
 Sets the owner of this Data object. More...
virtual ossimSourcegetOwner ()
virtual const ossimSourcegetOwner () const
virtual void setDataObjectStatus (ossimDataObjectStatus status) const
 Full list found in ossimConstants.h. More...
virtual ossimDataObjectStatus getDataObjectStatus () const
virtual ossimString getDataObjectStatusString () const
virtual ossim_uint32 getObjectSizeInBytes () const
virtual bool isInitialize () const
 This is to be overriden in the derived classes so they can check If their data is null. More...
virtual const ossimDataObjectoperator= (const ossimDataObject *rhs)
virtual const ossimDataObjectoperator= (const ossimDataObject &rhs)
virtual bool operator== (const ossimDataObject &rhs) const
virtual bool operator!= (const ossimDataObject &rhs) const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
virtual ~ossimU11ImageData ()
- Protected Member Functions inherited from ossimImageData
template<class T >
void copyLineTemplate (T dummyTemplate, const void *src, ossim_int32 lineNumber, ossim_int32 lineStartSample, ossim_int32 lineStopSample, ossimInterleaveType lineInterleave)
 Templated copy line method. More...
template<class T >
void stretchMinMax (T dummyTemplate)
 Templated stretch method. More...
template<class T >
void computeAlphaChannel (T dummyTemplate)
 Templated compute alpha channel. More...
template<class T >
ossimDataObjectStatus validate (T dummyTemplate) const
 Templated validate method. More...
template<class T >
void makeBlank (T dummyTemplate)
 Templated makeBlank method. More...
template<class T >
ossim_float64 computeMeanSquaredError (T dummyTemplate, ossim_float64 meanValue, ossim_uint32 bandNumber) const
 Templated computeMeanSquaredError method. More...
template<class T >
ossim_float64 computeAverageBandValue (T dummyTemplate, ossim_uint32 bandNumber) const
 Templated computeAverageBandValue method. More...
void loadTileFromBip (const void *src, const ossimIrect &src_rect)
void loadTileFromBipAlpha (const void *src, const ossimIrect &src_rect)
void loadTileFromBil (const void *src, const ossimIrect &src_rect)
void loadTileFromBsq (const void *src, const ossimIrect &src_rect)
void loadTileFromBip (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect)
void loadTileFromBil (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect)
void loadTileFromBsq (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect)
void unloadTileToBip (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const
void unloadTileToBil (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const
void unloadTileToBsq (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const
virtual void unloadBandToBsq (void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, const ossimIrect &clip_rect, OverwriteBandRule ow_type=NULL_RULE) const
 Called from public unloadBand() routines that have an OverwriteBandRule interface. More...
template<class T >
void copyTileToNormalizedBuffer (T dummyTemplate, ossim_float64 *buf) const
 Copies entire tile to buf passed in. More...
template<class T >
void copyTileToNormalizedBuffer (T dummyTemplate, ossim_float32 *buf) const
template<class T >
void copyTileToNormalizedBuffer (T dummyTemplate, ossim_uint32 band, ossim_float64 *buf) const
template<class T >
void copyTileToNormalizedBuffer (T dummyTemplate, ossim_uint32 band, ossim_float32 *buf) const
template<class T >
void copyNormalizedBufferToTile (T dummyTemplate, ossim_float64 *buf)
 Copies buf passed in to tile. More...
template<class T >
void copyNormalizedBufferToTile (T dummyTemplate, ossim_float32 *buf)
template<class T >
void copyNormalizedBufferToTile (T dummyTemplate, ossim_uint32 band, ossim_float64 *buf)
template<class T >
void copyNormalizedBufferToTile (T dummyTemplate, ossim_uint32 band, ossim_float32 *buf)
template<class T >
void computeMinMaxPix (T dummyValue, std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands) const
template<class T >
void computeMinMaxNulPix (T dummyValue, std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands, std::vector< ossim_float64 > &nulBands) const
template<class T >
void loadBandTemplate (T, const void *src, const ossimIrect &src_rect, ossim_uint32 band)
template<class T >
void loadBandTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, ossim_uint32 band)
template<class T >
void nullTileAlphaTemplate (T, const ossim_uint8 *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, bool multiplyAlphaFlag=false)
template<class T >
void loadTileFromBipTemplate (T, const void *src, const ossimIrect &src_rect)
template<class T >
void loadTileFromBipAlphaTemplate (T, const void *src, const ossimIrect &src_rect)
template<class T >
void loadTileFromBipTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect)
template<class T >
void loadTileFromBipAlphaTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect)
template<class T >
void loadTileFromBilTemplate (T, const void *src, const ossimIrect &src_rect)
template<class T >
void loadTileFromBilTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect)
template<class T >
void loadTileFromBsqTemplate (T, const void *src, const ossimIrect &src_rect)
template<class T >
void loadTileFromBsqTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect)
template<class T >
void unloadTileToBipTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const
template<class T >
void unloadTileToBipAlphaTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const
template<class T >
void unloadTileToBilTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const
template<class T >
void unloadTileToBsqTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const
template<class T >
void unloadBandTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect, ossim_uint32 band) const
template<class T >
void unloadBandToBsqTemplate (T, void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, const ossimIrect &clip_rect, OverwriteBandRule ow_type=NULL_RULE) const
template<class T >
void createTestTile (T)
 Creates a test tile for scalar type for testing only. More...
virtual void initializeDefaults ()
 initializeDefaults() Resizes and sets min/max/null arrays to number of bands and some default value for scalar type. More...
virtual void initializeMinDefault ()
 initializeMinDefault() Resizes theMinPixelValue array to number of bands and initializes to the default min for scalar type. More...
virtual void initializeMaxDefault ()
 initializeMaxDefault() Resizes theMaxPixelValue array to number of bands and initializes to the default max for scalar type. More...
virtual void initializeNullDefault ()
 initializeNullDefault() Resizes theNullPixelValue array to number of bands and initializes to the default null for scalar type. More...
bool hasSameDimensionsAs (ossimImageData *data) const
virtual ~ossimReferenced ()
static const ossimNormalizedU11RemapTable m_remapTable
Additional Inherited Members
- Public Types inherited from ossimImageData
enum  OverwriteBandRule {
  COLOR_DISCREPANCY = 0, COLOR_DISCREPANCY_OF_ANY_FROM_DEST = 1, COLOR_DISCREPANCY_OF_ALL_FROM_DEST = 2, COLOR_EQUALITY_OF_ANY_TO_SRC = 3,
  COLOR_EQUALITY_OF_ALL_TO_SRC = 4, NULL_RULE = 5
 Definitions for the unloadBand routines. More...
- Protected Attributes inherited from ossimImageData
std::vector< ossim_float64m_nullPixelValue
 Null pixel value for each band. More...
std::vector< ossim_float64m_minPixelValue
 Min pixel value for each band. More...
std::vector< ossim_float64m_maxPixelValue
 Max pixel value for each band. More...
std::vector< ossim_uint8m_alpha
 Alpha channel. More...
ossimIpt m_origin
bool m_indexedFlag
 Indicates data contains palette indexes. More...
ossimRefPtr< ossimMultiResLevelHistogramm_histogram
ossim_float64 m_percentFull
 percentage (0-100) of image tile that has valid (non-null) pixel values. More...
- Protected Attributes inherited from ossimRectilinearDataObject
ossim_uint32 m_numberOfDataComponents
ossimScalarType m_scalarType
std::vector< ossim_uint8m_dataBuffer
std::vector< ossim_uint32m_spatialExtents
- Protected Attributes inherited from ossimDataObject
ossimSourcetheOwner
ossimDataObjectStatus theDataObjectStatus
Detailed Description
Definition at line 30 of file ossimU11ImageData.h.
◆ ossimU11ImageData() [1/4]
ossimU11ImageData::ossimU11ImageData ( ossimSource source,
ossim_uint32  bands = 1
Definition at line 40 of file ossimU11ImageData.cpp.
42  :
43  ossimImageData(source,
45  bands)
46 {
47 }
◆ ossimU11ImageData() [2/4]
ossim_uint32  bands,
ossim_uint32  width,
ossim_uint32  height
Definition at line 49 of file ossimU11ImageData.cpp.
53  :
54  ossimImageData(source,
56  bands,
57  width,
58  height)
59 {
60 }
◆ ossimU11ImageData() [3/4]
ossimU11ImageData::ossimU11ImageData ( const ossimU11ImageData rhs)
Definition at line 62 of file ossimU11ImageData.cpp.
63  :
64  ossimImageData(rhs)
65 {}
◆ ~ossimU11ImageData()
ossimU11ImageData::~ossimU11ImageData ( )
protectedvirtual
Definition at line 67 of file ossimU11ImageData.cpp.
68 {
69 }
◆ ossimU11ImageData() [4/4]
ossimU11ImageData::ossimU11ImageData ( )
protected
Definition at line 33 of file ossimU11ImageData.cpp.
References ossimRectilinearDataObject::m_scalarType, and OSSIM_USHORT11.
Referenced by dup().
34  :
36 {
38 }
Member Function Documentation
◆ computeAverageBandValue()
double ossimU11ImageData::computeAverageBandValue ( ossim_uint32  bandNumber = 0)
virtual
Definition at line 286 of file ossimU11ImageData.cpp.
References ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), and isNull().
287 {
288  double result = 0.0;
289  ossim_uint32 index = 0;
290  ossim_uint32 validPixelCount=0;
291
292  ossim_uint16* buffer = getUshortBuf(bandNumber);
293  if(buffer)
294  {
295  ossim_uint32 bounds = getSizePerBand();
296  for(index = 0; index < bounds; ++index)
297  {
298  if(!isNull(index))
299  {
300  result += *buffer;
301  ++validPixelCount;
302  }
303  ++buffer;
304  }
305  if(validPixelCount > 0)
306  {
307  result /= validPixelCount;
308  }
309  }
310
311  return result;
312 }
bool isNull(ossim_uint32 offset) const
virtual const ossim_uint16 * getUshortBuf() const
unsigned short ossim_uint16
virtual ossim_uint32 getSizePerBand() const
unsigned int ossim_uint32
◆ computeMeanSquaredError()
double ossimU11ImageData::computeMeanSquaredError ( double  meanValue,
virtual
It will then do a SUM[(Mean - Actual)^2]/width*height.
This is the average variance from the passed in mean. Basically think of the mean as a completely grey image and we would like to see how this image varies from the passed in mean.
Definition at line 255 of file ossimU11ImageData.cpp.
References ossimImageData::getHeight(), ossimImageData::getUshortBuf(), ossimImageData::getWidth(), and isNull().
257 {
258  double result = -1; // invalid MSE
259  ossim_uint32 index = 0;
260  double delta = 0;
261  ossim_uint32 validPixelCount=0;
262
263  ossim_uint16* buffer = getUshortBuf(bandNumber);
264  if(buffer)
265  {
266  ossim_uint32 bounds = getWidth()*getHeight();
267  for(index = 0; index < bounds; ++index)
268  {
269  if(!isNull(index))
270  {
271  delta = *buffer - meanValue;
272  result += (delta*delta);
273  ++validPixelCount;
274  }
275  ++buffer;
276  }
277  if(validPixelCount > 0)
278  {
279  result /= validPixelCount;
280  }
281  }
282
283  return result;
284 }
◆ convertToNormalizedDouble()
void ossimU11ImageData::convertToNormalizedDouble ( ossimImageData result) const
virtual
Will use the memory that you pass in to normalize this data object.
Reimplemented from ossimImageData.
Definition at line 170 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), ossimImageData::getWidth(), ossimRectilinearDataObject::m_numberOfDataComponents, m_remapTable, ossimNormalizedU11RemapTable::normFromPix(), OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, and size.
171 {
172  if(!result)
173  {
174  return;
175  }
176
177  // make sure that the types and width and height are
178  // good.
179  if( (result->getScalarType() != OSSIM_NORMALIZED_FLOAT) ||
180  (result->getNumberOfBands() != this->getNumberOfBands())||
181  (result->getWidth() != this->getWidth()) ||
182  (result->getHeight() != this->getHeight())||
183  (result->getDataObjectStatus() == OSSIM_NULL) ||
185  {
186  return;
187  }
188
190
191  if(size > 0)
192  {
193  for(ossim_uint32 bandCount = 0; bandCount < m_numberOfDataComponents; ++bandCount)
194  {
195  const ossim_uint16* sourceBuf = getUshortBuf(bandCount);
196  double* resultBuf = static_cast<double*>(result->getBuf(bandCount));
197  for(ossim_uint32 counter = 0; counter < size; ++counter)
198  {
199  resultBuf[counter] = m_remapTable.normFromPix(sourceBuf[counter]);
200  }
201  }
202  }
203
204 }
virtual ossim_float64 normFromPix(ossim_int32 pix) const
Gets a normalized value (between &#39;0.0&#39; and &#39;1.0&#39;) from a pixel value.
yy_size_t size
◆ convertToNormalizedFloat()
void ossimU11ImageData::convertToNormalizedFloat ( ossimImageData result) const
virtual
Definition at line 134 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), ossimImageData::getWidth(), ossimRectilinearDataObject::m_numberOfDataComponents, m_remapTable, OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, and size.
135 {
136  if(!result)
137  {
138  return;
139  }
140  // make sure that the types and width and height are
141  // good.
142  if( (result->getScalarType() != OSSIM_NORMALIZED_FLOAT) ||
143  (result->getNumberOfBands() != this->getNumberOfBands())||
144  (result->getWidth() != this->getWidth()) ||
145  (result->getHeight() != this->getHeight())||
146  (result->getDataObjectStatus() == OSSIM_NULL) ||
148  {
149  return;
150  }
151
153
154  if(size > 0)
155  {
156  for(ossim_uint32 bandCount = 0; bandCount < m_numberOfDataComponents; ++bandCount)
157  {
158  const ossim_uint16* sourceBuf = getUshortBuf(bandCount);
159  float* resultBuf = static_cast<float*>(result->getBuf(bandCount));
160  for(ossim_uint32 counter = 0; counter < size; ++counter)
161  {
162  resultBuf[counter]
163  = static_cast<float>(m_remapTable.
164  normFromPix(sourceBuf[counter]));
165  }
166  }
167  }
168 }
yy_size_t size
◆ copyNormalizedBufferToTile() [1/4]
void ossimU11ImageData::copyNormalizedBufferToTile ( double *  buf)
virtual
Copies buf passed in to tile. Data is unnormalized to the tile's scalar type. The "buf" passed to method is assumed to be at least as big as the tiles: "getSize() * sizeof(double)"
Definition at line 439 of file ossimU11ImageData.cpp.
References ossimObject::getClassName(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), m_remapTable, ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossimNormalizedU11RemapTable::pixFromNorm(), and size.
440 {
441  if (!buf)
442  {
445  "ossimU11ImageData::copyTileToNormalizedBuffer File %s line %d\nNull pointer passed to method!",
446  __FILE__,
447  __LINE__);
448  return;
449  }
450
452
453  if(size > 0)
454  {
455  for(ossim_uint32 band = 0; band < getNumberOfBands(); band++)
456  {
457  double* s = buf + (band*size); // source
458  ossim_uint16* d = getUshortBuf(band); // destination
459
460  for(ossim_uint32 index = 0; index < size; index++)
461  {
462  d[index] = m_remapTable.pixFromNorm(s[index]);
463  }
464  }
465  }
466 }
OSSIMDLLEXPORT void ossimSetError(const char *className, ossim_int32 error, const char *fmtString=0,...)
virtual ossim_int32 pixFromNorm(ossim_float64 normPix) const
Returns an pixel value as an int from a normalized value.
static const ossimErrorCode OSSIM_ERROR
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
yy_size_t size
◆ copyNormalizedBufferToTile() [2/4]
void ossimU11ImageData::copyNormalizedBufferToTile ( float *  buf)
virtual
Definition at line 556 of file ossimU11ImageData.cpp.
557 {
558  if (!buf)
559  {
562  "ossimU11ImageData::copyTileToNormalizedBuffer File %s line %d\nNull pointer passed to method!",
563  __FILE__,
564  __LINE__);
565  return;
566  }
567
569
570  if(size > 0)
571  {
572  for(ossim_uint32 band = 0; band < getNumberOfBands(); ++band)
573  {
574  float* s = buf + (band*size); // source
575  ossim_uint16* d = getUshortBuf(band); // destination
576
577  for(ossim_uint32 index = 0; index < size; ++index)
578  {
579  d[index] = m_remapTable.pixFromNorm(s[index]);
580  }
581  }
582  }
583 }
yy_size_t size
◆ copyNormalizedBufferToTile() [3/4]
void ossimU11ImageData::copyNormalizedBufferToTile ( ossim_uint32  band,
double *  buf
virtual
Will copy the normalized buffer to this tiles specified band. If band is out of range then nothing is done and returns.
Definition at line 468 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimObject::getClassName(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), m_remapTable, ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossimNormalizedU11RemapTable::pixFromNorm(), and size.
470 {
471  if (!buf)
472  {
475  "ossimU11ImageData::copyTileToNormalizedBuffer File %s line %d\nNull pointer passed to method!",
476  __FILE__,
477  __LINE__);
478  return;
479  }
480
482
483  if((size > 0)&&getBuf(band))
484  {
485  double* s = buf; // source
486  ossim_uint16* d = getUshortBuf(band); // destination
487
488  for(ossim_uint32 index = 0; index < size; ++index)
489  {
490  *d = m_remapTable.pixFromNorm(*s);
491  ++d;
492  ++s;
493  }
494  }
495 }
yy_size_t size
◆ copyNormalizedBufferToTile() [4/4]
float *  buf
virtual
Definition at line 586 of file ossimU11ImageData.cpp.
588 {
589  if (!buf)
590  {
593  "ossimU11ImageData::copyTileToNormalizedBuffer File %s line %d\nNull pointer passed to method!",
594  __FILE__,
595  __LINE__);
596  return;
597  }
598
600
601  if((size > 0)&&getBuf(band))
602  {
603  float* s = buf; // source
604  ossim_uint16* d = getUshortBuf(band); // destination
605
606  for(ossim_uint32 index = 0; index < size; ++index)
607  {
608  *d = m_remapTable.pixFromNorm(*s);
609  ++d;
610  ++s;
611  }
612  }
613 }
yy_size_t size
◆ copyTileToNormalizedBuffer() [1/4]
void ossimU11ImageData::copyTileToNormalizedBuffer ( double *  buf) const
virtual
Copies entire tile to buf passed in. Data put in buf is normalized. The "buf" passed to method is assumed to be at least as big as: "getSize() * sizeof(double)"
Definition at line 379 of file ossimU11ImageData.cpp.
References ossimObject::getClassName(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), m_remapTable, ossimErrorCodes::OSSIM_ERROR, ossimSetError(), and size.
380 {
381  if (!buf)
382  {
385  "ossimU11ImageData::copyTileToNormalizedBuffer File %s line %d\nNull pointer passed to method!",
386  __FILE__,
387  __LINE__);
388  return;
389  }
390
392
393  if(size > 0)
394  {
395  for(ossim_uint32 band = 0; band < getNumberOfBands(); ++band)
396  {
397  const ossim_uint16* s = getUshortBuf(band); // source
398  double* d = buf + (band*size); // destination
399
400  for(ossim_uint32 index = 0; index < size; ++index)
401  {
402  d[index] = m_remapTable.
403  normFromPix(static_cast<ossim_int32>(s[index]));
404  }
405
406  }
407  }
408 }
yy_size_t size
◆ copyTileToNormalizedBuffer() [2/4]
void ossimU11ImageData::copyTileToNormalizedBuffer ( ossim_uint32  band,
double *  buf
) const
virtual
Will copy this tiles specified band number to the normalized buffer. if the band is out of range then nothing is done and returns.
Definition at line 410 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimObject::getClassName(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), m_remapTable, ossimNormalizedU11RemapTable::normFromPix(), ossimErrorCodes::OSSIM_ERROR, ossimSetError(), and size.
412 {
413  if (!buf)
414  {
417  "ossimU11ImageData::copyTileToNormalizedBuffer File %s line %d\nNull pointer passed to method!",
418  __FILE__,
419  __LINE__);
420  return;
421  }
422
423  if(!getBuf(band)) return;
424
426
427  if(size > 0)
428  {
429  const ossim_uint16* s = getUshortBuf(band); // source
430  double* d = buf; // destination
431
432  for(ossim_uint32 index = 0; index < size; index++)
433  {
434  *d = m_remapTable.normFromPix(static_cast<ossim_int32>(*s));
435  }
436  }
437 }
yy_size_t size
◆ copyTileToNormalizedBuffer() [3/4]
float *  buf
) const
virtual
Definition at line 528 of file ossimU11ImageData.cpp.
530 {
531  if (!buf)
532  {
535  "ossimU11ImageData::copyTileToNormalizedBuffer File %s line %d\nNull pointer passed to method!",
536  __FILE__,
537  __LINE__);
538  return;
539  }
540  if(!getBuf(band)) return;
541
543
544  if(size > 0)
545  {
546  const ossim_uint16* s = getUshortBuf(band); // source
547  float* d = buf; // destination
548
549  for(ossim_uint32 index = 0; index < size; ++index)
550  {
551  *d = m_remapTable.normFromPix(static_cast<ossim_int32>(*s));
552  }
553  }
554 }
yy_size_t size
◆ copyTileToNormalizedBuffer() [4/4]
void ossimU11ImageData::copyTileToNormalizedBuffer ( float *  buf) const
virtual
Definition at line 498 of file ossimU11ImageData.cpp.
499 {
500  if (!buf)
501  {
504  "ossimU11ImageData::copyTileToNormalizedBuffer File %s line %d\nNull pointer passed to method!",
505  __FILE__,
506  __LINE__);
507  return;
508  }
509
511
512  if(size > 0)
513  {
514  for(ossim_uint32 band = 0; band < getNumberOfBands(); band++)
515  {
516  const ossim_uint16* s = getUshortBuf(band); // source
517  float* d = buf + (band*size); // destination
518
519  for(ossim_uint32 index = 0; index < size; index++)
520  {
521  d[index] = m_remapTable.
522  normFromPix(static_cast<ossim_int32>(s[index]));
523  }
524  }
525  }
526 }
yy_size_t size
◆ dup()
ossimObject * ossimU11ImageData::dup ( ) const
virtual
Definition at line 71 of file ossimU11ImageData.cpp.
References ossimU11ImageData().
72 {
73  return new ossimU11ImageData(*this);
74 }
◆ fill()
void ossimU11ImageData::fill ( ossim_uint32  band,
double  value
Definition at line 336 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), OSSIM_STATUS_UNKNOWN, and ossimDataObject::setDataObjectStatus().
337 {
338  void* s = getBuf(band);
339
340  if (s == NULL) return; // nothing to do...
341
342  ossim_uint32 size_in_pixels = getSizePerBand();
343  ossim_uint16* p = getUshortBuf(band);
344  ossim_uint16 np = static_cast<ossim_uint16>(value);
345
346  for (ossim_uint32 i=0; i<size_in_pixels; i++) p[i] = np;
347
348  // Set the status to unknown since we don't know about the other bands.
350 }
virtual void setDataObjectStatus(ossimDataObjectStatus status) const
◆ getMinNormalizedPix()
ossim_float64 ossimU11ImageData::getMinNormalizedPix ( ) const
inlinevirtual
Returns
The first non-null index of the normalized remap table.
Definition at line 183 of file ossimU11ImageData.h.
References m_remapTable.
184 {
185  return m_remapTable[1];
186 }
◆ getNormalizedFloat()
void ossimU11ImageData::getNormalizedFloat ( ossim_uint32  offset,
float &  result
) const
virtual
will go to the band and offset and compute the normalized float and return it back to the caller through the result argument.
Definition at line 109 of file ossimU11ImageData.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageData::getUshortBuf(), ossimImageData::isValidBand(), m_remapTable, ossimNormalizedU11RemapTable::normFromPix(), and OSSIM_NULL.
112 {
113  if( (getDataObjectStatus() != OSSIM_NULL) && isValidBand(bandNumber) )
114  {
115  const ossim_uint16* sourceBuf = getUshortBuf(bandNumber);
116  result =
117  static_cast<float>(m_remapTable.normFromPix(sourceBuf[offset]));
118  }
119 }
virtual bool isValidBand(ossim_uint32 band) const
◆ isNull()
bool ossimU11ImageData::isNull ( ossim_uint32  offset) const
Definition at line 353 of file ossimU11ImageData.cpp.
References ossimImageData::getNumberOfBands(), ossimImageData::getUshortBuf(), and ossimImageData::m_nullPixelValue.
Referenced by computeAverageBandValue(), and computeMeanSquaredError().
354 {
355  for(ossim_uint32 band = 0; band < getNumberOfBands(); ++band)
356  {
357  const ossim_uint16* buf = getUshortBuf(band)+offset;
358
359  if((*buf) != m_nullPixelValue[band])
360  {
361  return false;
362  }
363  }
364
365  return true;
366 }
std::vector< ossim_float64 > m_nullPixelValue
◆ setNormalizedFloat()
void ossimU11ImageData::setNormalizedFloat ( ossim_uint32  offset,
float  input
virtual
This will assign to this object a normalized value by unnormalizing to its native type.
Definition at line 121 of file ossimU11ImageData.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageData::getUshortBuf(), ossimImageData::isValidBand(), m_remapTable, OSSIM_NULL, and ossimNormalizedU11RemapTable::pixFromNorm().
124 {
125  if( (getDataObjectStatus() != OSSIM_NULL) && isValidBand(bandNumber) )
126  {
127  ossim_uint16* sourceBuf = getUshortBuf(bandNumber);
128  sourceBuf[offset]
129  = static_cast<ossim_uint16>(m_remapTable.pixFromNorm(inputValue));
130  }
131 }
◆ setNull()
void ossimU11ImageData::setNull ( ossim_uint32  offset)
Definition at line 368 of file ossimU11ImageData.cpp.
369 {
370  ossim_uint32 bands = getNumberOfBands();
371  for(ossim_uint32 band = 0; band < bands; ++band)
372  {
373  ossim_uint16* buf = getUshortBuf(band)+offset;
374  *buf = (ossim_uint16)m_nullPixelValue[band];
375  }
376 }
◆ setValue()
void ossimU11ImageData::setValue ( long  x,
long  y,
double  color
virtual
Definition at line 314 of file ossimU11ImageData.cpp.
References ossimImageData::getUshortBuf(), ossimImageData::isWithin(), ossimRectilinearDataObject::m_dataBuffer, ossimRectilinearDataObject::m_numberOfDataComponents, ossimImageData::m_origin, ossimRectilinearDataObject::m_spatialExtents, ossimIpt::x, x, ossimIpt::y, and y.
315 {
316  if(m_dataBuffer.size() > 0 && isWithin(x, y))
317  {
318  //***
319  // Compute the offset into the buffer for (x,y). This should always
320  // come out positive.
321  //***
322  ossim_uint32 ux = static_cast<ossim_uint32>(x - m_origin.x);
323  ossim_uint32 uy = static_cast<ossim_uint32>(y - m_origin.y);
324
325  ossim_uint32 offset = uy * m_spatialExtents[0] + ux;
326
327  for(ossim_uint32 band = 0; offset < m_dataBuffer.size() && // prevent buffer overrun
328  band < m_numberOfDataComponents; band++)
329  {
330  ossim_uint16* buf = getUshortBuf(band)+offset;
331  *buf = (ossim_uint16)color;
332  }
333  }
334 }
ossim_uint32 x
ossim_uint32 y
std::vector< ossim_uint8 > m_dataBuffer
std::vector< ossim_uint32 > m_spatialExtents
virtual bool isWithin(ossim_int32 x, ossim_int32 y)
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
◆ unnormalizeInput()
void ossimU11ImageData::unnormalizeInput ( ossimImageData normalizedInput)
virtual
Will take the normalized input and convert it to this tile's data type. Example: if this tile is of type UCHAR and its input is of type NORALIZED_FLOAT it will unnormalize the data by doing:
minPix + normalizedInput*(maxPix-minPix)
on a per band basis.
Definition at line 206 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), ossimRectilinearDataObject::m_numberOfDataComponents, m_remapTable, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, and size.
207 {
208  if((normalizedInput->getScalarType() != OSSIM_NORMALIZED_FLOAT) &&
209  (normalizedInput->getScalarType() != OSSIM_NORMALIZED_DOUBLE) )
210  {
211  //ERROR
212  return;
213  }
214
215  ossim_uint32 counter = 0;
216  ossim_uint32 bandCount = 0;
218  ossimScalarType scalarType = normalizedInput->getScalarType();
219
220  if(size > 0)
221  {
222  if(scalarType == OSSIM_NORMALIZED_FLOAT)
223  {
224  for(bandCount = 0; bandCount < m_numberOfDataComponents; ++bandCount)
225  {
226  float* sourceBuf =
227  static_cast<float*>(normalizedInput->getBuf(bandCount));
228  ossim_uint16* resultBuf = getUshortBuf(bandCount);
229  for(counter = 0; counter < size; ++counter)
230  {
231  resultBuf[counter]
232  = static_cast<ossim_uint16>(m_remapTable.
233  pixFromNorm(sourceBuf[counter]));
234  }
235  }
236  }
237  else // Double
238  {
239  for(bandCount = 0; bandCount < m_numberOfDataComponents; ++bandCount)
240  {
241  double* sourceBuf =
242  static_cast<double*>(normalizedInput->getBuf(bandCount));
243  ossim_uint16* resultBuf = getUshortBuf(bandCount);
244  for(counter = 0; counter < size; ++counter)
245  {
246  resultBuf[counter]
247  = static_cast<ossim_uint16>(m_remapTable.
248  pixFromNorm(sourceBuf[counter]));
249  }
250  }
251  }
252  }
253 }
yy_size_t size
ossimScalarType
◆ validate()
ossimDataObjectStatus ossimU11ImageData::validate ( ) const
virtual
Definition at line 76 of file ossimU11ImageData.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimImageData::getSize(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), ossimRectilinearDataObject::m_dataBuffer, OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, OSSIM_PARTIAL, and ossimDataObject::setDataObjectStatus().
77 {
78  if (m_dataBuffer.size() == 0)
79  {
81  return OSSIM_NULL;
82  }
83
84  ossim_uint32 count = 0;
85  const ossim_uint32 SIZE = getSize();
86  const ossim_uint32 BOUNDS = getSizePerBand();
87  const ossim_uint32 NUMBER_OF_BANDS = getNumberOfBands();
88
89  for(ossim_uint32 band = 0; band < NUMBER_OF_BANDS; ++band)
90  {
91  const ossim_uint16* p = getUshortBuf(band);
92  for (ossim_uint32 i=0; i<BOUNDS; ++i)
93  {
94  // check if the band is null
95  if (p[i] != 0) ++count;
96  }
97  }
98
99  if (!count)
101  else if (count == SIZE)
103  else
105
106  return getDataObjectStatus();
107 }
virtual ossim_uint32 getSize() const
Member Data Documentation
◆ m_remapTable
const ossimNormalizedU11RemapTable ossimU11ImageData::m_remapTable
staticprivate
