Visitor to update view and then propagate property event to outputs. More...
#include <ossimVisitor.h>
ossimViewInterfaceVisitor (ossimObject *view, int visitorType=(VISIT_OUTPUTS|VISIT_CHILDREN)) | |
ossimViewInterfaceVisitor (const ossimViewInterfaceVisitor &src) | |
virtual ossimRefPtr< ossimVisitor > | dup () const |
virtual void | visit (ossimObject *obj) |
Calls ossimViewInterface::setView if obj cast to ossimViewInterface*. More... | |
ossimObject * | getView () |
const ossimObject * | getView () const |
ossimVisitor (int visitorType=VISIT_NONE) | |
ossimVisitor (const ossimVisitor &src) | |
virtual void | reset () |
virtual void | visit (ossimConnectableObject *obj) |
VisitorType | getVisitorType () const |
void | setVisitorType (int vType, bool on=true) |
void | turnOffVisitorType (int vType) |
bool | hasVisited (ossimObject *obj) const |
bool | stopTraversal () const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
Protected Attributes | |
ossimRefPtr< ossimObject > | m_view |
VisitorType | m_visitorType |
Collection | m_markNode |
bool | m_stopTraversalFlag |
enum | VisitorType { VISIT_NONE = 0, VISIT_CHILDREN = 1, VISIT_INPUTS = 2, VISIT_OUTPUTS = 4, VISIT_ALL = (VISIT_CHILDREN|VISIT_INPUTS|VISIT_OUTPUTS) } |
Enumeration type can be a mask and will traverse a graph of connectables based on the values. More... | |
typedef std::set< ossimRefPtr< ossimObject > > | MarkCollectionRef |
typedef std::set< ossimRefPtr< ossimObject > > | CollectionRef |
typedef std::vector< ossimRefPtr< ossimObject > > | ListRef |
typedef std::set< ossimObject * > | Collection |
typedef std::vector< ossimObject *> | List |
virtual | ~ossimReferenced () |
Definition at line 179 of file ossimVisitor.h.
ossimViewInterfaceVisitor::ossimViewInterfaceVisitor | ( | ossimObject * | view, |
int | visitorType = (VISIT_OUTPUTS|VISIT_CHILDREN) |
ossimViewInterfaceVisitor::ossimViewInterfaceVisitor | ( | const ossimViewInterfaceVisitor & | src | ) |
Definition at line 336 of file ossimVisitor.cpp.
Implements ossimVisitor.
Definition at line 343 of file ossimVisitor.cpp.
References ossimViewInterfaceVisitor().
ossimObject * ossimViewInterfaceVisitor::getView | ( | ) |
const ossimObject * ossimViewInterfaceVisitor::getView | ( | ) | const |
On success a property event is sent to output side so that things like ossimCombiner can reinitialize if needed.
obj | Object to visit. |
Reimplemented from ossimVisitor.
Definition at line 358 of file ossimVisitor.cpp.
References ossimObject::accept(), ossimRefPtr< T >::get(), ossimVisitor::hasVisited(), m_view, ossimViewInterface::setView(), ossimVisitor::visit(), and ossimVisitor::VISIT_OUTPUTS.
protected |
Definition at line 201 of file ossimVisitor.h.
