Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimConnectableObject Class Referenceabstract
#include <ossimConnectableObject.h>
Inheritance diagram for ossimConnectableObject:
ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimAtbController ossimConnectableContainer ossimMetadataFileWriter ossimResampler ossimSource ossimEnviHeaderFileWriter ossimERSFileWriter ossimFgdcFileWriter ossimGeomFileWriter ossimReadmeFileWriter ossimWorldFileWriter ossimElevSource ossimHistogramSource ossimImageSource ossimImageStatisticsSource ossimOutputSource ossimOverviewBuilderBase ossimPointCloudSource ossimVideoSource ossimViewController
Public Types
const ossimIdgetId () const
virtual bool canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
virtual ~ossimReferenced ()
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
Detailed Description
Definition at line 30 of file ossimConnectableObject.h.
Member Typedef Documentation
◆ ConnectableObjectList
Definition at line 35 of file ossimConnectableObject.h.
◆ ossimConnectableObjectDirectionType
◆ ossimConnectableObject() [1/2]
ossimConnectableObject::ossimConnectableObject ( ossimObject owner = 0)
Base constructor of this object.
Definition at line 31 of file ossimConnectableObject.cpp.
References ossimIdManager::generateId(), ossimIdManager::instance(), theId, and theOwner.
32 :ossimObject(),
36 {
38  theOwner = owner;
39 }
ossimId generateId()
Indicates whether the theInputObjectList is fixed.
Indicates whether the theOutputObjectList is fixed.
static ossimIdManager * instance()
◆ ossimConnectableObject() [2/2]
ossimConnectableObject::ossimConnectableObject ( ossimObject owner,
ossim_int32  inputListSize,
ossim_int32  outputListSize,
bool  inputListIsFixedFlag = true,
bool  outputListIsFixedFlag = true
Definition at line 41 of file ossimConnectableObject.cpp.
References ossimIdManager::generateId(), ossimIdManager::instance(), setNumberOfInputs(), setNumberOfOutputs(), theId, and theOwner.
46 :ossimObject(),
48 theInputListIsFixedFlag(inputListIsFixedFlag),
49 theOutputListIsFixedFlag(outputListIsFixedFlag)
50 {
52  theOwner = owner;
53
54  setNumberOfInputs(inputListSize);
55  setNumberOfOutputs(outputListSize);
56 }
virtual void setNumberOfInputs(ossim_int32 numberOfInputs)
Will set the number of inputs.
virtual void setNumberOfOutputs(ossim_int32 numberOfInputs)
Will set the number of outputs.
◆ ~ossimConnectableObject()
ossimConnectableObject::~ossimConnectableObject ( )
virtual
Definition at line 58 of file ossimConnectableObject.cpp.
59 {
60
61  // tell the immediate listeners that we are destructing.
62  // RP - Probably not a great change, but the multithread sequencer boms
63  // here due to one image handler with multiple connected thread image
64  // chains
65  //ossimObjectDestructingEvent event(this);
66
67  // if(theOwner)
68  // {
69  // ossimListenerManager* manager = PTR_CAST(ossimListenerManager, theOwner);
70
71  // if(manager)
72  // {
73  // // notify the owner that you are destructing
74  // //
75  // manager->fireEvent(event);
76  // }
77  // }
78
79  // notify all other listeners that you are destructing
80  //
81  //fireEvent(event);
82
83  }
Member Function Documentation
◆ accept()
void ossimConnectableObject::accept ( ossimVisitor visitor)
virtual
We will add a visitor interface for all connectable objects.
Reimplemented in ossimImageChain, ossimConnectableContainer, and ossimElevManager.
Definition at line 2237 of file ossimConnectableObject.cpp.
References CONNECTABLE_DIRECTION_OUTPUT, getNumberOfOutputs(), ossimVisitor::getVisitorType(), ossimVisitor::hasVisited(), isConnected(), ossimVisitor::setVisitorType(), ossimVisitor::stopTraversal(), theInputObjectList, theOutputObjectList, theOwner, ossimVisitor::turnOffVisitorType(), ossimVisitor::visit(), ossimVisitor::VISIT_INPUTS, and ossimVisitor::VISIT_OUTPUTS.
Referenced by ossimConnectableContainer::accept(), ossimImageChain::accept(), ossimNitf20Writer::addTags(), ossimHistogramMatchFilter::autoLoadInputHistogram(), ossimBitMaskWriter::connectMyInputTo(), disconnect(), ossimLandsatTopoCorrectionFilter::findLandsatHeader(), findObjectOfType(), ossimBandSelector::getBandSelectableImageHandler(), ossimBandSelector::getRgbBandList(), ossimSFIMFusion::initialize(), ossimKmlSuperOverlayWriter::propagateViewChange(), ossimGpkgWriter::reInitializeCombiners(), ossimGpkgWriter::reInitializeCutters(), ossimGpkgWriter::setView(), and ossimIvtGeomXformVisitor::visit().
2238 {
2239  if(!visitor.stopTraversal())
2240  {
2241  if(!visitor.hasVisited(this))
2242  {
2243  visitor.visit(this);
2244  }
2245
2246  if(!visitor.stopTraversal())
2247  {
2248
2250  {
2251  ConnectableObjectList::iterator current = theInputObjectList.begin();
2252  while(current != theInputObjectList.end())
2253  {
2254  if((*current).get()&&!visitor.hasVisited((*current).get())) (*current)->accept(visitor);
2255  ++current;
2256  }
2257  }
2258
2260  {
2261  // go through the outputs
2262  ConnectableObjectList::iterator current = theOutputObjectList.begin();
2263  while(current != theOutputObjectList.end())
2264  {
2265  if((*current).get()&&!visitor.hasVisited((*current).get())) (*current)->accept(visitor);
2266  ++current;
2267  }
2269
2271  {
2272  ossimVisitor::VisitorType currentType = visitor.getVisitorType();
2273  // lets make sure inputs and outputs are turned off for we are traversing all children and we should not have
2274  // to have that enabled
2275  //
2276  visitor.turnOffVisitorType(ossimVisitor::VISIT_INPUTS);// |ossimVisitor::VISIT_CHILDREN);
2277
2278  //obj->accept(visitor);
2279  visitor.setVisitorType(currentType);
2280  // visitor.turnOffVisitorType(ossimVisitor::VISIT_INPUTS);
2281  // now go through outputs
2282  //
2283  ConnectableObjectList::iterator current = obj->theOutputObjectList.begin();
2284  while(current != obj->theOutputObjectList.end())
2285  {
2286  if((*current).get()&&!visitor.hasVisited((*current).get())) (*current)->accept(visitor);
2287  ++current;
2288  }
2289
2290  visitor.setVisitorType(currentType);
2291
2292  }
2293  }
2294  }
2295  }
2296 }
virtual void visit(ossimObject *obj)
void setVisitorType(int vType, bool on=true)
virtual ossim_uint32 getNumberOfOutputs() const
Return the number of output objects.
void turnOffVisitorType(int vType)
virtual bool isConnected(ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const
will check the direction specified to see if all slots are full.
bool hasVisited(ossimObject *obj) const
ConnectableObjectList theInputObjectList
Holds a list of input objects.
VisitorType getVisitorType() const
ConnectableObjectList theOutputObjectList
Holds a list of output objects.
VisitorType
Enumeration type can be a mask and will traverse a graph of connectables based on the values...
Definition: ossimVisitor.h:27
bool stopTraversal() const
◆ canConnectMyInputTo()
virtual bool ossimConnectableObject::canConnectMyInputTo ( ossim_int32  myInputIndex,
const ossimConnectableObject object
) const
pure virtual
◆ canConnectMyOutputTo()
bool ossimConnectableObject::canConnectMyOutputTo ( ossim_int32  myOutputIndex,
) const
virtual
default implementation is to allow anyone to connect to us.
Reimplemented in ossimConnectableContainer, and ossimVideoSource.
Definition at line 2047 of file ossimConnectableObject.cpp.
References theOutputListIsFixedFlag, and theOutputObjectList.
Referenced by ossimBandSeparateHandler::canConnectMyOutputTo(), connectOutputList(), and getMyOutputIndexToConnectTo().
2049 {
2051  {
2052  return ((myOutputIndex >= 0) &&
2053  (myOutputIndex < (ossim_int32)theOutputObjectList.size()));
2054  }
2055
2056  return ((myOutputIndex >= 0) &&
2057  (myOutputIndex <= (ossim_int32)theOutputObjectList.size()));
2058 }
int ossim_int32
◆ changeOwner()
void ossimConnectableObject::changeOwner ( ossimObject owner)
virtual
◆ connectInputList()
bool ossimConnectableObject::connectInputList ( ConnectableObjectList inputList)
virtual
Will disconnect itself from all inputs and reset to the passed in input list.
It will return true if all objects were successfully added.
Definition at line 1384 of file ossimConnectableObject.cpp.
References connectMyInputTo(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_CONNECT_ID, OSSIM_EVENT_CONNECTION_DISCONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, theInputListIsFixedFlag, and theInputObjectList.
Referenced by ossimImageChain::add(), ossimImageChain::addLast(), ossimImageChain::insertLeft(), and ossimImageChain::replace().
1385 {
1386  bool result = true;
1387  ossim_uint32 i = 0;
1389  ConnectableObjectList newInputs;
1390  ConnectableObjectList::iterator currentInput = inputList.begin();
1391  ConnectableObjectList tempOld;
1392  if(theInputObjectList.size())
1393  {
1394  for(i = 0; i < theInputObjectList.size(); ++i)
1395  {
1396  if(oldInputs[i].valid())
1397  {
1398  tempOld.push_back(oldInputs[i].get());
1399  }
1400  theInputObjectList[i] = 0;
1401  }
1402  }
1403  if(theInputListIsFixedFlag && (theInputObjectList.size()==0))
1404  {
1405  return false;
1406  }
1407
1409  {
1410  theInputObjectList.clear();
1411  }
1412  if(tempOld.size())
1413  {
1414  for(i = 0; i < tempOld.size(); ++ i)
1415  {
1416  tempOld[i]->disconnectMyOutput(this, false);
1417  }
1418  }
1419  // disconnectAllInputs();
1420
1421  if(inputList.size() == 1)
1422  {
1423  return (connectMyInputTo(inputList[0].get())>=0);
1424  }
1425  i = 0;
1426  // now connect the new outputs
1427  //
1428  currentInput = inputList.begin();
1429  result = false;
1430
1431  while(currentInput != inputList.end())
1432  {
1433  if((*currentInput).valid())
1434  {
1435  if(connectMyInputTo((*currentInput).get(), false) >= 0)
1436  {
1437  newInputs.push_back((*currentInput).get());
1438  result = true;
1439  }
1440  }
1441  ++currentInput;
1442  }
1443  ossimConnectionEvent event(this,
1445  newInputs,
1446  oldInputs,
1448
1449  if(theInputObjectList.size())
1450  {
1451  fireEvent(event);
1452  }
1453
1454  newInputs = theInputObjectList;
1455
1456
1457
1458  event = ossimConnectionEvent(this,
1460  newInputs,
1461  oldInputs,
1463  fireEvent(event);
1464
1465  return result;
1466 }
#define OSSIM_EVENT_CONNECTION_DISCONNECT_ID
Definition: ossimEventIds.h:21
virtual void fireEvent(ossimEvent &event)
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
#define OSSIM_EVENT_CONNECTION_CONNECT_ID
Definition: ossimEventIds.h:22
unsigned int ossim_uint32
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
◆ connectMyInputTo() [1/3]
ossim_int32 ossimConnectableObject::connectMyInputTo ( ossimConnectableObject inputObject,
bool  makeOutputConnection = true,
bool  createEventFlag = true
virtual
It will return a valid index >= 0 if successful. Will use the getMyInputIndexToConnectTo method to implement the connection
Reimplemented in ossimBitMaskWriter.
Definition at line 1027 of file ossimConnectableObject.cpp.
References findInputIndex(), ossimListenerManager::fireEvent(), ossimObject::getClassName(), getMyInputIndexToConnectTo(), OSSIM_EVENT_CONNECTION_CONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, ossimNotify(), ossimNotifyLevel_WARN, theInputListIsFixedFlag, and theInputObjectList.
Referenced by ossimImageChain::addLast(), ossimEquationCombiner::applyBlurr(), ossimEquationCombiner::applyConvolution(), ossimEquationCombiner::applyShift(), ATP::AtpTileSource::AtpTileSource(), ossimImageHandler::buildHistogram(), ossimImageFileWriter::changeSequencer(), ossimChipProcTool::combineLayers(), ossimImageHistogramSource::computeNormalModeHistogram(), ossimImageStatisticsSource::computeStatisticsTemplate(), ossimConnectableContainer::connectAllObjects(), ossimImageChain::connectAllSources(), ossimImageSharpenFilter::connectInputEvent(), ossimImageGaussianFilter::connectInputEvent(), ossimHistogramMatchFilter::connectInputEvent(), ossimImageFileWriter::connectInputEvent(), connectInputList(), ossimBitMaskWriter::connectMyInputTo(), connectMyInputTo(), connectMyOutputTo(), ossimImageChainMtAdaptor::connectSharedHandlers(), ossimImageSharpenFilter::disconnectInputEvent(), ossimImageGaussianFilter::disconnectInputEvent(), ossimHistogramMatchFilter::disconnectInputEvent(), ossimDemTool::doOMG(), ossimPointCloudTool::execute(), ossimChipProcTool::execute(), ossimEquationCombiner::getImageData(), ossimKakaduJpipHandler::getTile(), ossimFftFilter::initialize(), ossimTrimFilter::initialize(), ossimBrightnessMatch::initialize(), ossimImageSharpenFilter::initialize(), ossimSFIMFusion::initialize(), ossimLocalCorrelationFusion::initialize(), ossimKMeansFilter::initialize(), ossimChipperUtil::initialize2CmvChain(), ossimBitMaskWriter::initializeFlipper(), ossimChipperUtil::initializePsmChain(), ossimEquationUtil::initInputSources(), ossimHillshadeTool::initProcessingChain(), ossimHlzTool::initProcessingChain(), ossimViewshedTool::initProcessingChain(), ossimImageChain::insertLeft(), ossimImageChain::insertRight(), main(), ossimTiledElevationDatabase::mapRegion(), ossimBandSeparateHandler::open(), ossimHistogramMatchFilter::ossimHistogramMatchFilter(), ossimHistogramWriter::ossimHistogramWriter(), ossimImageCombiner::ossimImageCombiner(), ossimImageGaussianFilter::ossimImageGaussianFilter(), ossimImageSourceFilter::ossimImageSourceFilter(), ossimImageSourceSequencer::ossimImageSourceSequencer(), ossimTopographicCorrectionFilter::ossimTopographicCorrectionFilter(), ossimVertexExtractor::ossimVertexExtractor(), ossimIgen::outputProduct(), ossimEquationCombiner::setOutputScalarType(), ATP::AtpAnnotatedImage::write(), ossimImageFileWriter::writeEnviHeaderFile(), ossimImageFileWriter::writeErsHeaderFile(), ossimImageFileWriter::writeExternalGeometryFile(), ossimImageFileWriter::writeFgdcFile(), ossimArcInfoGridWriter::writeFile(), ossimJpegWriter::writeFile(), ossimHistogramWriter::writeHistogram(), ossimImageFileWriter::writeHistogramFile(), writeRaster(), ossimImageFileWriter::writeReadmeFile(), ossimHlzTool::writeSlopeImage(), and ossimImageFileWriter::writeWorldFile().
1030 {
1031  if(!object) return false;
1032
1033  ossim_int32 index = findInputIndex(object);
1034  if(index >= 0) return index;
1035
1036  index = getMyInputIndexToConnectTo(object);
1037
1038  if(index>-1)
1039  {
1040  if(index >= (ossim_int32)theInputObjectList.size())
1041  {
1042  if(theInputListIsFixedFlag) return -1;
1043
1044  index = (ossim_int32)theInputObjectList.size();
1045  theInputObjectList.push_back(object);
1046  }
1047  else
1048  {
1049  if(!theInputObjectList[index])
1050  {
1051  theInputObjectList[index] = object;
1052  }
1053  else
1054  {
1055  ossimNotify(ossimNotifyLevel_WARN) << "Must issue a detach first!! trying to attach object " << object->getClassName()
1056  << "\n to input index " << index << " in " << getClassName() << "\n";
1057
1058  return -1;
1059  }
1060  }
1061  if(createEventFlag)
1062  {
1063  ossimConnectionEvent event(this, // owner of message
1065  theInputObjectList[index].get(), // new object
1066  0,// old object
1068  // send event to any listener.
1069  //
1070  fireEvent(event);
1071  }
1072
1073  if(makeOutputConnection&&object)
1074  {
1075  // make sure we tell the input not to connect
1076  // back to us or infinite loop
1077  //
1078  object->connectMyOutputTo(this, false, createEventFlag);
1079  }
1080  }
1081  else
1082  {
1083  return index;
1084  }
1085
1086  return index;
1087 }
virtual ossim_int32 findInputIndex(const ossimConnectableObject *object)
Return a valid index of the input list if the passed in object is found else return -1...
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
virtual ossim_int32 getMyInputIndexToConnectTo(ossimConnectableObject *object) const
Should return the first available index to connect to.
int ossim_int32
◆ connectMyInputTo() [2/3]
ossim_int32 ossimConnectableObject::connectMyInputTo ( ossim_int32  inputIndex,
virtual
Will connect the specified input to the passed in object.
Definition at line 1089 of file ossimConnectableObject.cpp.
References canConnectMyInputTo(), connectMyOutputTo(), disconnectMyOutput(), findInputIndex(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_CONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, theInputListIsFixedFlag, and theInputObjectList.
1093 {
1094  if(!inputObject)
1095  {
1096  if(inputIndex < (ossim_int32)theInputObjectList.size())
1097  {
1098  ossimConnectableObject* oldObject = theInputObjectList[inputIndex].get();
1100  {
1101  theInputObjectList[inputIndex] = 0;
1102  }
1103  else
1104  {
1105  theInputObjectList.erase(theInputObjectList.begin() + inputIndex);
1106  }
1107  if(createEventFlag)
1108  {
1109  ossimConnectionEvent event(this, // owner of message
1111  0, // new object
1112  oldObject,// old object
1114  // send event to any listener.
1115  //
1116  fireEvent(event);
1117  }
1118  return -1;
1119  }
1120  return -1;
1121  }
1122
1123  ossim_int32 index = findInputIndex(inputObject);
1124
1125  if((index >= 0)&&!inputObject) return index;
1126  if(!inputObject) return -1;
1127
1128  if(canConnectMyInputTo(inputIndex, inputObject))
1129  {
1130  if(inputIndex>-1)
1131  {
1132  ossimConnectableObject* oldObject=0;
1133  if(inputIndex >= (ossim_int32)theInputObjectList.size())
1134  {
1135  if(theInputListIsFixedFlag) return -1;
1136
1137  inputIndex = (ossim_int32)theInputObjectList.size();
1138  theInputObjectList.push_back(inputObject);
1139  }
1140  else
1141  {
1142  oldObject = theInputObjectList[inputIndex].get();
1143  theInputObjectList[inputIndex] = inputObject;
1144  if(oldObject)
1145  {
1146  oldObject->disconnectMyOutput(this, false);
1147  }
1148  }
1149
1150  if(createEventFlag)
1151  {
1152  ossimConnectionEvent event(this, // owner of message
1154  theInputObjectList[inputIndex].get(), // new object
1155  oldObject,// old object
1157  // send event to any listener.
1158  //
1159  fireEvent(event);
1160  }
1161
1162  if(makeOutputConnection&&inputObject)
1163  {
1164  // make sure we tell the input not to connect
1165  // back to us or infinite loop
1166  //
1167  inputObject->connectMyOutputTo(this, false, createEventFlag);
1168  }
1169  }
1170  else
1171  {
1172  return inputIndex;
1173  }
1174
1175  return inputIndex;
1176  }
1177
1178  return -1;
1179 }
virtual ossim_int32 connectMyOutputTo(ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true)
Will try to connect this objects output to the passed in object.
virtual ossimRefPtr< ossimConnectableObject > disconnectMyOutput(ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true)
Will disconnect the object at the given output index and generate a connection event.
virtual bool canConnectMyInputTo(ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0
required to be overriden by derived classes
int ossim_int32
◆ connectMyInputTo() [3/3]
bool ossimConnectableObject::connectMyInputTo ( ConnectableObjectList inputList,
virtual
Definition at line 1181 of file ossimConnectableObject.cpp.
References connectMyInputTo(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_CONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, theInputListIsFixedFlag, and theInputObjectList.
1184 {
1185  bool result = true;
1186  ConnectableObjectList oldInputs;
1187  ConnectableObjectList newInputs;
1188
1189  if(inputList.size() == 1)
1190  {
1191  if(inputList[0].valid())
1192  {
1193  return (connectMyInputTo(inputList[0].get(), makeOutputConnection, createEventFlag) >= 0);
1194  }
1195  else
1196  {
1198  {
1199  theInputObjectList[0] = 0;
1200  }
1201  else
1202  {
1203  theInputObjectList.clear();
1204  }
1205  if(createEventFlag)
1206  {
1207  ossimConnectionEvent event(this,
1209  0,
1210  theInputObjectList[0].get(),
1212  fireEvent(event);
1213  }
1214
1215  return true;
1216  }
1217  }
1218  ossim_int32 i = 0;
1219  for(i = 0; i < (ossim_int32)inputList.size(); ++i)
1220  {
1221  if(inputList[i].valid())
1222  {
1223  if(connectMyInputTo(inputList[i].get(), makeOutputConnection, false)<0)
1224  {
1225  result = false;
1226  }
1227  else
1228  {
1229  newInputs.push_back(inputList[i]);
1230  }
1231  }
1232  else
1233  {
1234  newInputs.push_back(0);
1235  }
1236  }
1237  if(createEventFlag)
1238  {
1239  ossimConnectionEvent event(this,
1241  newInputs,
1242  oldInputs,
1244  fireEvent(event);
1245  }
1246  return result;
1247 }
int ossim_int32
◆ connectMyOutputTo() [1/2]
ossim_int32 ossimConnectableObject::connectMyOutputTo ( ossimConnectableObject outputObject,
bool  makeInputConnection = true,
virtual
It will return a valid index >= 0 if successful. It will in turn call the passed in objects connect input command if makeInputConnection is set to true.
Will use the getMyOutputIndexToConnectTo to implement this method
Reimplemented in ossimImageChainMtAdaptor.
Definition at line 1249 of file ossimConnectableObject.cpp.
References connectMyInputTo(), findOutputIndex(), ossimListenerManager::fireEvent(), ossimObject::getClassName(), getMyOutputIndexToConnectTo(), OSSIM_EVENT_CONNECTION_CONNECT_ID, ossimConnectionEvent::OSSIM_OUTPUT_DIRECTION, ossimNotify(), ossimNotifyLevel_WARN, theOutputListIsFixedFlag, and theOutputObjectList.
Referenced by connectMyInputTo(), ossimImageChainMtAdaptor::connectMyOutputTo(), connectMyOutputTo(), connectOutputList(), ossimImageSourceFilter::ossimImageSourceFilter(), and ossimImageHandlerMtAdaptor::setAdaptee().
1252 {
1253  ossim_int32 index = findOutputIndex(output);
1254  if(index >= 0) return index;
1255
1256  index = getMyOutputIndexToConnectTo(output);
1257
1258  if(index > -1)
1259  {
1260  if((index >= (ossim_int32)theOutputObjectList.size())&&
1262  {
1263  index = (ossim_int32)theOutputObjectList.size();
1264  theOutputObjectList.push_back(output);
1265  }
1266  else
1267  {
1268  if(!theOutputObjectList[index])
1269  {
1270  theOutputObjectList[index] = output;
1271  }
1272  else
1273  {
1274  ossimNotify(ossimNotifyLevel_WARN) << "Must issue a disconnect first!! trying to connect object " << output->getClassName()
1275  << "\n to output index " << index << " in " << getClassName() << "\n";
1276
1277  return -1;
1278  }
1279  }
1280  if(createEventFlag)
1281  {
1282  ossimConnectionEvent event(this, // owner of message
1284  theOutputObjectList[index].get(), // new object
1285  0,// old object
1287  // send event to any listener.
1288  //
1289  fireEvent(event);
1290  }
1291  if(makeInputConnection&&output)
1292  {
1293  // tell the output object not to connect back
1294  // to us since this is already done.
1295  //
1296  output->connectMyInputTo(this, false, createEventFlag);
1297  }
1298  }
1299  else
1300  {
1301  return index;
1302  }
1303
1304  return index;
1305 }
virtual ossim_int32 findOutputIndex(const ossimConnectableObject *object)
Return a valid index of the output list if the passed in object is found else return -1...
virtual ossim_int32 getMyOutputIndexToConnectTo(ossimConnectableObject *object) const
int ossim_int32
◆ connectMyOutputTo() [2/2]
bool ossimConnectableObject::connectMyOutputTo ( ConnectableObjectList outputList,
virtual
Definition at line 1307 of file ossimConnectableObject.cpp.
References connectMyOutputTo(), disconnectAllOutputs(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_CONNECT_ID, and ossimConnectionEvent::OSSIM_OUTPUT_DIRECTION.
1310 {
1311  bool result = true;
1312  ConnectableObjectList oldOutputs;
1313  ConnectableObjectList newOutputs;
1314
1315  if(outputList.size() == 0)
1316  {
1318  return true;
1319  }
1320  if((outputList.size() == 1)&&outputList[0].valid())
1321  {
1322  if(outputList[0].valid())
1323  {
1324  return (connectMyOutputTo(outputList[0].get(), makeInputConnection, createEventFlag) >= 0);
1325  }
1326  else
1327  {
1329  }
1330  }
1331
1332  ossim_int32 i = 0;
1333  for(i = 0; i < (ossim_int32)outputList.size(); ++i)
1334  {
1335  if((connectMyOutputTo(outputList[i].get(), makeInputConnection, false)<0)&&outputList[i].valid())
1336  {
1337  newOutputs.push_back(outputList[i].get());
1338  result = false;
1339  }
1340  }
1341  if(createEventFlag&&newOutputs.size())
1342  {
1343  ossimConnectionEvent event(this,
1345  newOutputs,
1346  oldOutputs,
1348  fireEvent(event);
1349  }
1350
1351  return result;
1352 }
virtual void disconnectAllOutputs()
Will disconnect all of the output objects.
int ossim_int32
◆ connectOutputList()
bool ossimConnectableObject::connectOutputList ( ConnectableObjectList outputList)
virtual
Will disconnect itself from all outputs and reset to the passed in output list.
Definition at line 1468 of file ossimConnectableObject.cpp.
References canConnectMyOutputTo(), connectMyOutputTo(), disconnectAllOutputs(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_CONNECT_ID, ossimConnectionEvent::OSSIM_OUTPUT_DIRECTION, and theOutputObjectList.
Referenced by ossimImageChain::insertRight(), and ossimImageChain::replace().
1469 {
1470  bool result = true;
1471  ossim_int32 index = 0;
1473  ConnectableObjectList newOutputs;
1474  ConnectableObjectList::const_iterator currentOutput = outputList.begin();
1475
1477
1478  if(outputList.size() == 1)
1479  {
1480  return (connectMyOutputTo(outputList[0].get())>=0);
1481  }
1482  while(currentOutput != outputList.end())
1483  {
1484  if(!canConnectMyOutputTo(index, (*currentOutput).get()))
1485  {
1486  result = false;
1487  }
1488  ++currentOutput;
1489  }
1490
1491  if(!result)
1492  {
1493  return false;
1494  }
1495
1496  theOutputObjectList = outputList;
1497  newOutputs = theOutputObjectList;
1498
1499  ossimConnectionEvent event(this,
1501  newOutputs,
1502  oldOutputs,
1504  fireEvent(event);
1505
1506  return result;
1507 }
virtual bool canConnectMyOutputTo(ossim_int32 myOutputIndex, const ossimConnectableObject *object) const
int ossim_int32
◆ disconnect() [1/2]
void ossimConnectableObject::disconnect ( ossimConnectableObject object = 0)
virtual
Will disconnect the object passed in.
Definition at line 721 of file ossimConnectableObject.cpp.
References disconnectAllInputs(), disconnectAllOutputs(), disconnectMyInput(), disconnectMyOutput(), findInputIndex(), and findOutputIndex().
Referenced by ossimEquationCombiner::applyBlurr(), ossimEquationCombiner::applyConvolution(), ossimEquationCombiner::applyShift(), ossimImageHandler::buildHistogram(), ossimChipperUtil::clear(), ossimImageHistogramSource::computeNormalModeHistogram(), ossimImageStatisticsSource::computeStatisticsTemplate(), ossimConnectableContainer::deleteAllChildren(), disconnect(), ossimKakaduJpipHandler::getTile(), ossimLocalCorrelationFusion::initialize(), ossimIgen::outputProduct(), ossimImageChain::prepareForRemoval(), ossimImageFileWriter::writeHistogramFile(), ossimEquationCombiner::~ossimEquationCombiner(), ossimFftFilter::~ossimFftFilter(), ossimIgen::~ossimIgen(), and ossimImageGaussianFilter::~ossimImageGaussianFilter().
722 {
723  if( (object==this) || (object==0) )
724  {
727  }
728  else
729  {
730  ossim_int32 index = findInputIndex(object);
731  if(index > -1)
732  {
733  disconnectMyInput(index);
734  }
735  index = findOutputIndex(object);
736  if(index > -1)
737  {
738  disconnectMyOutput(index, object);
739  }
740  }
741 }
virtual ossimRefPtr< ossimConnectableObject > disconnectMyInput(ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true)
Will disconnect the object at the given input index and generate a connection event.
virtual void disconnectAllInputs()
Will disconnect all of the input objects.
int ossim_int32
◆ disconnect() [2/2]
void ossimConnectableObject::disconnect ( const ossimId id)
virtual
Definition at line 743 of file ossimConnectableObject.cpp.
References accept(), disconnect(), ossimIdVisitor::getObject(), theId, ossimVisitor::VISIT_CHILDREN, ossimVisitor::VISIT_INPUTS, and ossimVisitor::VISIT_OUTPUTS.
744 {
745  if(id == theId)
746  {
747  disconnect(this);
748  }
749  else
750  {
751  ossimIdVisitor visitor( id,
755  accept( visitor );
756  disconnect( visitor.getObject() );
757  }
758 }
virtual void disconnect(ossimConnectableObject *object=0)
virtual void accept(ossimVisitor &visitor)
◆ disconnectAllInputs()
void ossimConnectableObject::disconnectAllInputs ( )
virtual
Definition at line 930 of file ossimConnectableObject.cpp.
References disconnectMyInput(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_DISCONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, theInputListIsFixedFlag, and theInputObjectList.
Referenced by ossimImageChain::addLast(), ossimBitMaskWriter::connectMyInputTo(), disconnect(), ossimImageSharpenFilter::initialize(), ossimSFIMFusion::initialize(), and ossimImageChain::insertLeft().
931 {
932  if(theInputObjectList.size() == 0) return;
933  if(theInputObjectList.size() == 1)
934  {
935  // ossimConnectableObject* obj = disconnectMyInput((ossim_int32)0, false);
937  // if(obj)
938  // {
939  // obj->disconnectMyOutput(this, false);
940  // }
941  return;
942  }
943  ConnectableObjectList::iterator current;
945  ConnectableObjectList newInputs;
946
947
948  current = theInputObjectList.begin();
949  while(current != theInputObjectList.end())
950  {
952  {
953  current = theInputObjectList.erase(current);
954  }
955  else
956  {
957  *current = 0;
958  ++current;
959  }
960  }
961  ossimConnectionEvent event(this,
963  newInputs,
964  oldInputs,
966  fireEvent(event);
967
968  for(ossim_uint32 index = 0; index < oldInputs.size(); ++index)
969  {
970  if(oldInputs[index].valid())
971  {
972  oldInputs[index]->disconnectMyOutput(this, false);
973  }
974  }
975 }
int ossim_int32
◆ disconnectAllOutputs()
void ossimConnectableObject::disconnectAllOutputs ( )
virtual
Definition at line 977 of file ossimConnectableObject.cpp.
References disconnectMyOutput(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_DISCONNECT_ID, ossimConnectionEvent::OSSIM_OUTPUT_DIRECTION, theOutputListIsFixedFlag, and theOutputObjectList.
Referenced by ossimImageChain::add(), ossimImageHandlerMtAdaptor::close(), connectMyOutputTo(), connectOutputList(), disconnect(), ossimImageChain::insertRight(), and ossimMultiThreadSequencer::setToStartOfSequence().
978 {
979  if(theOutputObjectList.size() == 0) return;
980  if(theOutputObjectList.size() == 1)
981  {
982  // ossimConnectableObject* obj = disconnectMyOutput((ossim_int32)0, false);
983  // RP - another probably bad change to keep the multithread adapter from
984  // crashing on the destructor
985  disconnectMyOutput((ossim_int32)0, false, false);
986  // if(obj)
987  // {
988  // obj->disconnectMyInput(this,
989  // false);
990  // }
991  return;
992  }
993  ConnectableObjectList::iterator current;
994
996  ConnectableObjectList newOutputs;
997
998  current = theOutputObjectList.begin();
999  while(current != theOutputObjectList.end())
1000  {
1002  {
1003  current = theOutputObjectList.erase(current);
1004  }
1005  else
1006  {
1007  *current = 0;
1008  ++current;
1009  }
1010  }
1011  ossimConnectionEvent event(this,
1013  newOutputs,
1014  oldOutputs,
1016  fireEvent(event);
1017
1018  for(ossim_uint32 index = 0; index < oldOutputs.size(); ++index)
1019  {
1020  if(oldOutputs[index].valid())
1021  {
1022  oldOutputs[index]->disconnectMyInput(this, false);
1023  }
1024  }
1025 }
int ossim_int32
◆ disconnectMyInput() [1/2]
ossimRefPtr< ossimConnectableObject > ossimConnectableObject::disconnectMyInput ( ossim_int32  inputIndex,
bool  disconnectOutputFlag = true,
virtual
Definition at line 760 of file ossimConnectableObject.cpp.
References disconnectMyOutput(), ossimListenerManager::fireEvent(), ossimRefPtr< T >::get(), OSSIM_EVENT_CONNECTION_DISCONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, theInputListIsFixedFlag, theInputObjectList, and ossimRefPtr< T >::valid().
Referenced by ossimImageChain::connectAllSources(), ossimImageGaussianFilter::connectInputEvent(), ossimHistogramMatchFilter::connectInputEvent(), disconnect(), disconnectAllInputs(), ossimImageGaussianFilter::disconnectInputEvent(), ossimHistogramMatchFilter::disconnectInputEvent(), ossimImageFileWriter::disconnectInputEvent(), disconnectMyInput(), disconnectMyInputs(), disconnectMyOutput(), and ossimTrimFilter::initialize().
763 {
764  if(theInputObjectList.size() == 0)
765  {
766  return 0;
767  }
768
769  ConnectableObjectList::iterator current;
771
772  if( (inputIndex > -1)&&
773  (inputIndex < (ossim_int32)theInputObjectList.size()))
774  {
775  current = (theInputObjectList.begin()+inputIndex);
776  result = (*current).get();
777
779  {
780  current = theInputObjectList.erase(current);
781  }
782  else
783  {
784  *current = 0;
785  }
786  if(createEventFlag&&result.valid())
787  {
788  ossimConnectionEvent event(this, // owner of message
790  0, // new object
791  result.get(),// old object
793
794  // send event to all listeners.
795  //
796  fireEvent(event);
797  }
798
799  if(disconnectOutputFlag&&result.valid())
800  {
801  result->disconnectMyOutput(this, false, createEventFlag);
802  }
803  }
804  return result;
805 }
bool valid() const
Definition: ossimRefPtr.h:75
int ossim_int32
◆ disconnectMyInput() [2/2]
void ossimConnectableObject::disconnectMyInput ( ossimConnectableObject input,
virtual
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);.
Definition at line 808 of file ossimConnectableObject.cpp.
References disconnectMyInput(), and findInputIndex().
811 {
813  disconnectOutputFlag,
814  createEventFlag);
815 }
◆ disconnectMyInputs()
void ossimConnectableObject::disconnectMyInputs ( ConnectableObjectList inputList,
virtual
Definition at line 817 of file ossimConnectableObject.cpp.
References disconnectMyInput(), findInputIndex(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_DISCONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, and theInputObjectList.
Referenced by setNumberOfInputs().
820 {
821  if(theInputObjectList.size() == 0) return;
822  ConnectableObjectList oldInputs;
823  ConnectableObjectList newInputs;
824  ossim_int32 i = 0;
825
826  for(i = 0; i < (ossim_int32)inputList.size(); ++i)
827  {
828  if(findInputIndex(inputList[i].get()) >= 0)
829  {
830  disconnectMyInput(inputList[i].get(), disconnectOutputFlag, false);
831  oldInputs.push_back(inputList[i]);
832  }
833  }
834  if(createEventFlag && oldInputs.size())
835  {
836  ossimConnectionEvent event(this,
838  newInputs,
839  oldInputs,
841  fireEvent(event);
842  }
843 }
int ossim_int32
◆ disconnectMyOutput() [1/2]
ossimRefPtr< ossimConnectableObject > ossimConnectableObject::disconnectMyOutput ( ossim_int32  outputIndex,
bool  disconnectInputFlag = true,
virtual
If there is no object at that index then no event is generated and NULL is returned. The disconnectOutputFlag says do you want this method to disconnect the output pointer to this object.
Definition at line 845 of file ossimConnectableObject.cpp.
References disconnectMyInput(), ossimListenerManager::fireEvent(), ossimRefPtr< T >::get(), OSSIM_EVENT_CONNECTION_DISCONNECT_ID, ossimConnectionEvent::OSSIM_OUTPUT_DIRECTION, theOutputListIsFixedFlag, theOutputObjectList, and ossimRefPtr< T >::valid().
Referenced by connectMyInputTo(), disconnect(), disconnectAllOutputs(), disconnectMyInput(), disconnectMyOutput(), and disconnectMyOutputs().
848 {
849  if(theOutputObjectList.size() == 0)
850  {
851  return 0;
852  }
853
854  ConnectableObjectList::iterator current;
856  if( (outputIndex > -1)&&
857  (outputIndex < (ossim_int32)theOutputObjectList.size()))
858  {
859  current = (theOutputObjectList.begin()+outputIndex);
860  result = (*current).get();
862  {
863  current = theOutputObjectList.erase(current);
864  }
865  else
866  {
867  *current = 0;
868  }
869  if(createEvent)
870  {
871  ossimConnectionEvent event(this, // owner of message
873  0, // new object
874  result.get(),// old object
876
877  // send event to all listeners.
878  //
879  fireEvent(event);
880  }
881
882  if(disconnectInputFlag&&result.valid())
883  {
884  result->disconnectMyInput(this, false, createEvent);
885  }
886  }
887  return result;
888 }
bool valid() const
int ossim_int32
◆ disconnectMyOutput() [2/2]
void ossimConnectableObject::disconnectMyOutput ( ossimConnectableObject output,
virtual
Will disconnect the output object.
It will get the index of the object and call disconnectMyOutput(index, disconnectOutputFlag).
Definition at line 890 of file ossimConnectableObject.cpp.
References disconnectMyOutput(), and findOutputIndex().
893 {
894  disconnectMyOutput(findOutputIndex(output), disconnectInputFlag, createEventFlag);
895 }
◆ disconnectMyOutputs()
void ossimConnectableObject::disconnectMyOutputs ( ConnectableObjectList outputList,
virtual
Definition at line 897 of file ossimConnectableObject.cpp.
References disconnectMyOutput(), findOutputIndex(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_DISCONNECT_ID, ossimConnectionEvent::OSSIM_OUTPUT_DIRECTION, and theOutputObjectList.
Referenced by ossimImageHandlerMtAdaptor::setAdaptee(), and setNumberOfOutputs().
900 {
901  if(theOutputObjectList.size() == 0) return;
902
903  if(theOutputObjectList.size() == 1)
904  {
906  return;
907  }
908  ConnectableObjectList oldOutputs;
909  ConnectableObjectList newOutputs;
910  ossim_int32 i = 0;
911  for(i = 0; i < (ossim_int32)outputList.size(); ++i)
912  {
913  if(findOutputIndex(outputList[i].get()) >= 0)
914  {
915  disconnectMyOutput(outputList[i].get(), disconnectInputFlag, false);
916  oldOutputs.push_back(outputList[i]);
917  }
918  }
919  if(createEventFlag && oldOutputs.size())
920  {
921  ossimConnectionEvent event(this,
923  newOutputs,
924  oldOutputs,
926  fireEvent(event);
927  }
928 }
int ossim_int32
◆ fillContainer()
bool ossimConnectableObject::fillContainer ( ossimConnectableContainer container)
virtual
Inserts this object and all of its children and inputs into the container provided.
Returns
Returns TRUE if successful.
Reimplemented in ossimConnectableContainer.
Definition at line 2028 of file ossimConnectableObject.cpp.
References ossimConnectableContainer::addChild(), fillContainer(), getInput(), and getNumberOfInputs().
Referenced by fillContainer(), and ossimImageChainMtAdaptor::setOriginalChain().
2029 {
2030  // Insert inputs into the container:
2031  bool good_fill = true;
2032  ossim_uint32 num_inputs = getNumberOfInputs();
2033  for(ossim_uint32 i=0; (i<num_inputs) && good_fill; ++i)
2034  {
2035  ossimConnectableObject* input = getInput(i);
2036  if (input)
2037  good_fill = input->fillContainer(container);
2038  }
2039
2040  // Insert this object and all of its children and inputs into the container provided:
2041  if (good_fill)
2042  good_fill = container.addChild(this);
2043
2044  return good_fill;
2045 }
virtual bool addChild(ossimConnectableObject *attachableObject)
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
virtual bool fillContainer(ossimConnectableContainer &container)
◆ findInputIndex() [1/2]
ossim_int32 ossimConnectableObject::findInputIndex ( const ossimConnectableObject object)
virtual
Definition at line 603 of file ossimConnectableObject.cpp.
References theInputObjectList.
Referenced by ossimImageChain::connectInputEvent(), connectMyInputTo(), disconnect(), disconnectMyInput(), disconnectMyInputs(), moveInputDown(), and moveInputUp().
604 {
605  ossim_int32 i = 0;
606  for(i = 0; i < (ossim_int32)theInputObjectList.size(); ++i)
607  {
608  if(theInputObjectList[i].get() == object)
609  {
610  return i;
611  }
612  }
613
614  return -1;
615 }
int ossim_int32
◆ findInputIndex() [2/2]
ossim_int32 ossimConnectableObject::findInputIndex ( const ossimId id)
virtual
Return a valid index of the input list if the passed id is found else return -1.
Definition at line 617 of file ossimConnectableObject.cpp.
618 {
619  ossim_int32 i = 0;
620  for(i = 0; i < (ossim_int32)theInputObjectList.size(); ++i)
621  {
622  if(theInputObjectList[i].valid() &&
623  (theInputObjectList[i]->getId() == id))
624  {
625  return i;
626  }
627  }
628
629  return -1;
630 }
int ossim_int32
◆ findObjectOfType()
ossimConnectableObject * ossimConnectableObject::findObjectOfType ( ConnectableObjectList connectableList,
protected
Definition at line 181 of file ossimConnectableObject.cpp.
References accept(), CONNECTABLE_DIRECTION_INPUT, CONNECTABLE_DIRECTION_NONE, ossimCollectionVisitor::getObject(), theInputObjectList, theOutputObjectList, ossimVisitor::VISIT_CHILDREN, ossimVisitor::VISIT_INPUTS, ossimVisitor::VISIT_NONE, and ossimVisitor::VISIT_OUTPUTS.
185 {
186  ossimConnectableObject* result = 0;
187
188  if(directionType != CONNECTABLE_DIRECTION_NONE)
189  {
190  ConnectableObjectList* connectableList = 0;
191
193  {
194  connectableList = &theInputObjectList;
195  }
196  else // (directionType == CONNECTABLE_DIRECTION_OUTPUT)
197  {
198  connectableList = &theOutputObjectList;
199  }
200
201  // see if it is in the immediate list
202  for(ossim_uint32 index = 0; index < connectableList->size(); ++index)
203  {
204  if( (*connectableList)[index].valid() )
205  {
206  if( (*connectableList)[index]->canCastTo( typeId ) )
207  {
208  result = (*connectableList)[index].get();
209  break;
210  }
211  }
212  }
213
214  if ( !result )
215  {
217
219  {
220  if ( recurse )
221  {
222  // Cast needed for compiler...
223  vType = (ossimVisitor::VisitorType)
225  }
226  else
227  {
229  }
230  }
231  else // (directionType == CONNECTABLE_DIRECTION_OUTPUT)
232  {
233  if ( recurse )
234  {
235  // Cast needed for compiler...
236  vType = (ossimVisitor::VisitorType)
238  }
239  else
240  {
242  }
243  }
244
245  ossimTypeIdVisitor visitor( typeId,
246  true, // firstofTypeFlag
247  vType );
248
249
250  this->accept( visitor );
251  result = dynamic_cast<ossimConnectableObject*>( visitor.getObject(0) );
252  }
253
254  } // Matches: if(directionType != CONNECTABLE_DIRECTION_NONE)
255
256  return result;
257
258 } // End: findObjectOfType( RTTItypeid ...
VisitorType
◆ findOutputIndex() [1/2]
ossim_int32 ossimConnectableObject::findOutputIndex ( const ossimConnectableObject object)
virtual
Definition at line 632 of file ossimConnectableObject.cpp.
References theOutputObjectList.
Referenced by connectMyOutputTo(), disconnect(), disconnectMyOutput(), and disconnectMyOutputs().
633 {
634  ossim_int32 i = 0;
635  for(i = 0; i < (ossim_int32)theOutputObjectList.size(); ++i)
636  {
637  if(theOutputObjectList[i] == object)
638  {
639  return i;
640  }
641  }
642
643  return -1;
644 }
int ossim_int32
◆ findOutputIndex() [2/2]
ossim_int32 ossimConnectableObject::findOutputIndex ( const ossimId id)
virtual
Definition at line 646 of file ossimConnectableObject.cpp.
647 {
648  ossim_int32 i = 0;
649  for(i = 0; i < (ossim_int32)theOutputObjectList.size(); ++i)
650  {
651  if(theOutputObjectList[i].valid() &&
652  (theOutputObjectList[i]->getId() == id))
653  {
654  return i;
655  }
656  }
657
658  return -1;
659 }
int ossim_int32
◆ getDescription()
ossimString ossimConnectableObject::getDescription ( ) const
virtual
Reimplemented in ossimWatermarkFilter, and ossimMaxMosaic.
Definition at line 95 of file ossimConnectableObject.cpp.
References theDescription.
96 {
97  return theDescription;
98 }
◆ getId()
const ossimId & ossimConnectableObject::getId ( ) const
◆ getInput() [1/2]
ossimConnectableObject * ossimConnectableObject::getInput ( ossim_uint32  index = 0)
if the index is not valid then NULL is returned
Definition at line 1354 of file ossimConnectableObject.cpp.
Referenced by ossimElevationMosaic::allocate(), ossimImageMosaic::allocate(), ossimMaxMosaic::allocate(), ossimTopographicCorrectionFilter::allocate(), ossimMaskFilter::allocate(), ossimEquationCombiner::applyBlurr(), ossimEquationCombiner::applyConvolution(), ossimEquationCombiner::applyShift(), ossimImageFileWriter::changeSequencer(), ossimImageRenderer::checkIVT(), ossimImageHistogramSource::computeFastModeHistogram(), ossimImageHistogramSource::computeNormalModeHistogram(), ossimBandMergeSource::computeNumberOfInputBands(), ossimImageStatisticsSource::computeStatistics(), ossimImageStatisticsSource::computeStatisticsTemplate(), ossimImageSourceHistogramFilter::connectInputEvent(), ossimImageSharpenFilter::connectInputEvent(), ossimImageGaussianFilter::connectInputEvent(), ossimHistogramMatchFilter::connectInputEvent(), ossimHistogramWriter::connectInputEvent(), ossimImageRenderer::connectInputEvent(), ossimImageFileWriter::connectInputEvent(), ossimVideoSource::currentFrameTime(), ossimAtbController::disableImage(), ossimImageSharpenFilter::disconnectInputEvent(), ossimImageGaussianFilter::disconnectInputEvent(), ossimHistogramMatchFilter::disconnectInputEvent(), ossimHistogramWriter::disconnectInputEvent(), ossimImageSourceSequencer::disconnectInputEvent(), ossimImageFileWriter::disconnectInputEvent(), ossimVideoSource::duration(), ossimAtbController::enableImage(), ossimImageHistogramSource::execute(), fillContainer(), ossimLandsatTopoCorrectionFilter::findLandsatHeader(), ossimIgenGenerator::generateChainForMultiInputRecurse(), ossimIgenGenerator::generateInputKwl(), ossimImageHistogramSource::getBinInformation(), ossimOrthoImageMosaic::getBoundingRect(), ossimImageCombiner::getBoundingRect(), ossimTopographicCorrectionFilter::getBoundingRect(), ossimEsriShapeFileFilter::getBoundingRect(), ossimImageSource::getBoundingRect(), ossimImageChain::getBoundingRect(), ossimImageSource::getDecimationFactor(), ossimTopographicCorrectionFilter::getDecimationFactor(), ossimImageChain::getDecimationFactor(), ossimTopographicCorrectionFilter::getDecimationFactors(), ossimImageSource::getDecimationFactors(), ossimImageChain::getDecimationFactors(), ossimPointCloudSource::getFieldCode(), ossimImageSourceHistogramFilter::getHistogram(), ossimHistogramRemapper::getHistogram(), ossimEquationCombiner::getImageData(), ossimOrthoImageMosaic::getImageGeometry(), ossimVideoImageSource::getImageGeometry(), ossimImageChain::getImageGeometry(), ossimImageSource::getImageGeometry(), ossimBandMergeSource::getMaxPixelValue(), ossimImageCombiner::getMaxPixelValue(), ossimTopographicCorrectionFilter::getMaxPixelValue(), ossimImageSource::getMaxPixelValue(), ossimImageChain::getMaxPixelValue(), ossimEquationCombiner::getMaxPixelValue(), ossimPointCloudSource::getMaxPoint(), ossimBandMergeSource::getMinPixelValue(), ossimImageCombiner::getMinPixelValue(), ossimTopographicCorrectionFilter::getMinPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageChain::getMinPixelValue(), ossimEquationCombiner::getMinPixelValue(), ossimPointCloudSource::getMinPoint(), ossimOrthoImageMosaic::getNextTile(), ossimImageCombiner::getNextTile(), ossimBandMergeSource::getNullPixelValue(), ossimImageCombiner::getNullPixelValue(), ossimTopographicCorrectionFilter::getNullPixelValue(), ossimImageSource::getNullPixelValue(), ossimImageChain::getNullPixelValue(), ossimEquationCombiner::getNullPixelValue(), ossimTopographicCorrectionFilter::getNumberOfDecimationLevels(), ossimImageSource::getNumberOfDecimationLevels(), ossimImageChain::getNumberOfDecimationLevels(), ossimImageChain::getNumberOfInputBands(), ossimMaskFilter::getNumberOfInputBands(), ossimTopographicCorrectionFilter::getNumberOfOutputBands(), ossimOrthoImageMosaic::getNumberOfOverlappingImages(), ossimImageCombiner::getOutputScalarType(), ossimTopographicCorrectionFilter::getOutputScalarType(), ossimImageSource::getOutputScalarType(), ossimImageChain::getOutputScalarType(), ossimEquationCombiner::getOutputScalarType(), ossimOrthoImageMosaic::getOverlappingImages(), ossimOrthoImageMosaic::getRelativeRect(), ossimBandMergeSource::getTile(), ossimSFIMFusion::getTile(), ossimImageSource::getTile(), ossimLocalCorrelationFusion::getTile(), ossimTopographicCorrectionFilter::getTile(), ossimBumpShadeTileSource::getTile(), ossimImageChain::getTile(), ossimMaskFilter::getTile(), ossimEquationCombiner::getTile(), ossimImageCombiner::getTileHeight(), ossimImageSource::getTileHeight(), ossimImageChain::getTileHeight(), ossimImageCombiner::getTileWidth(), ossimImageSource::getTileWidth(), ossimImageChain::getTileWidth(), ossimImageChain::getValidImageVertices(), ossimImageSource::getValidImageVertices(), ossimVideoSource::getVideoGeometry(), ossimFftFilter::initialize(), ossimTrimFilter::initialize(), ossimBrightnessMatch::initialize(), ossimFusionCombiner::initialize(), ossimFeatherMosaic::initialize(), ossimImageSharpenFilter::initialize(), ossimImageCombiner::initialize(), ossimSFIMFusion::initialize(), ossimImageSourceFilter::initialize(), ossimImageSourceSequencer::initialize(), ossimMetadataFileWriter::initialize(), ossimVideoImageSource::initialize(), ossimTwoColorView::initialize(), ossimMaskFilter::initialize(), ossimBumpShadeTileSource::initialize(), ossimImageSource::isIndexedData(), ossimAtbController::lockImage(), ossimVideoSource::nextFrame(), ossimImageCombiner::precomputeBounds(), propagateEventToInputs(), ossimTopographicCorrectionFilter::resizeArrays(), ossimVideoSource::rewind(), ossimImageSource::saveImageGeometry(), saveStateOfAllInputs(), ossimVideoSource::seek(), ossimPointCloudSource::setFieldCode(), ossimVideoImageSource::setFrameTime(), ossimImageSource::setImageGeometry(), ossimPdfWriter::setupInputChain(), ossimHistogramRemapper::setupTable(), ossimAtbController::unlockImage(), ossimVideoSource::videoFrameRate(), ossimIvtGeomXformVisitor::visit(), ossimJpegWriter::writeFile(), and ossimHistogramWriter::writeHistogram().
1355 {
1356  if(idx < theInputObjectList.size())
1357  {
1358  return theInputObjectList[idx].get();
1359  }
1360
1361  return 0;
1362 }
◆ getInput() [2/2]
const ossimConnectableObject * ossimConnectableObject::getInput ( ossim_uint32  index = 0) const
Definition at line 1364 of file ossimConnectableObject.cpp.
1365 {
1366  if( idx < theInputObjectList.size())
1367  {
1368  return theInputObjectList[idx].get();
1369  }
1370
1371  return 0;
1372 }
◆ getInputList() [1/2]
const ossimConnectableObject::ConnectableObjectList & ossimConnectableObject::getInputList ( ) const
◆ getInputList() [2/2]
Definition at line 2343 of file ossimConnectableObject.cpp.
2344 {
2345  return theInputObjectList;
2346 }
◆ getInputListIsFixedFlag()
bool ossimConnectableObject::getInputListIsFixedFlag ( ) const
virtual
Definition at line 2323 of file ossimConnectableObject.cpp.
References theInputListIsFixedFlag.
Referenced by ossimImageChain::add(), and ossimImageChain::addLast().
2324 {
2325  return theInputListIsFixedFlag;
2326 }
◆ getMyInputIndexToConnectTo()
ossim_int32 ossimConnectableObject::getMyInputIndexToConnectTo ( ossimConnectableObject object) const
virtual
The connectMyInputTo that just takes another ossimConnectableObject as input and not an index will call this method. By default this method will find the first open slot (not null) or append o the list if it's dynamic. If the list is dynamic it calls conConnectMyInputTo(index, object) on an index = to listSize.
Definition at line 661 of file ossimConnectableObject.cpp.
References canConnectMyInputTo(), theInputListIsFixedFlag, and theInputObjectList.
Referenced by connectMyInputTo().
662 {
663  ConnectableObjectList::const_iterator current;
664
665  ossim_int32 index = 0;
666  current = theInputObjectList.begin();
667  while(current != theInputObjectList.end())
668  {
669  if(!(*current))
670  {
671  if(canConnectMyInputTo(index, object))
672  {
673  return index;
674  }
675  }
676  ++current;
677  ++index;
678  }
680  {
682  object))
683  {
684  return (ossim_int32)theInputObjectList.size();
685  }
686  }
687  return -1;
688 }
int ossim_int32
◆ getMyOutputIndexToConnectTo()
ossim_int32 ossimConnectableObject::getMyOutputIndexToConnectTo ( ossimConnectableObject object) const
virtual
The connectMyOutputTo that just takes another ossimConnectableObject as input\ and not an index will call this method. By default this method will find the first open slot (not null) or append to the list if it's dynamic. If the list is dynamic it calls canConnectMyOutputTo(index, object) on an index = to listSize.
Definition at line 690 of file ossimConnectableObject.cpp.
References canConnectMyOutputTo(), theOutputListIsFixedFlag, and theOutputObjectList.
Referenced by connectMyOutputTo().
691 {
692  ConnectableObjectList::const_iterator current;
693
694  ossim_int32 index = 0;
695  current = theOutputObjectList.begin();
696  while(current != theOutputObjectList.end())
697  {
698  if(!(*current))
699  {
700  if(canConnectMyOutputTo(index, object))
701  {
702  return index;
703  }
704  }
705  ++current;
706  ++index;
707  }
709  {
711  object))
712  {
713  return (ossim_int32)theOutputObjectList.size();
714  }
715  }
716  // default to return the size. This will force an append.
717  //
718  return -1;
719 }
int ossim_int32
◆ getNumberOfInputs()
ossim_uint32 ossimConnectableObject::getNumberOfInputs ( ) const
virtual
Definition at line 2313 of file ossimConnectableObject.cpp.
Referenced by ossimImageChain::addLast(), ossimImageMosaic::allocate(), ossimElevationMosaic::allocate(), ossimMaxMosaic::allocate(), ATP::AtpTileSource::allocate(), ossimBandMergeSource::computeNumberOfInputBands(), ossimAtbController::disableImage(), ossimAtbController::enableImage(), fillContainer(), ossimIgenGenerator::generateChainForMultiInputRecurse(), ossimImageCombiner::getBoundingRect(), ossimBandMergeSource::getMaxPixelValue(), ossimImageCombiner::getMaxPixelValue(), ossimBandMergeSource::getMinPixelValue(), ossimImageCombiner::getMinPixelValue(), ossimImageCombiner::getNextNormTile(), ossimOrthoImageMosaic::getNextTile(), ossimImageCombiner::getNextTile(), ossimBandMergeSource::getNullPixelValue(), ossimImageCombiner::getNumberOfOverlappingImages(), ossimImageCombiner::getOverlappingImages(), ossimBlendMosaic::getTile(), ossimFeatherMosaic::getTile(), ATP::ossimCorrelationSource::getTile(), ossimImageMosaic::getTile(), ossimElevationMosaic::getTile(), ATP::ossimDescriptorSource::getTile(), ossimMaxMosaic::getTile(), ossimBandMergeSource::getTile(), ossimFeatherMosaic::initialize(), ATP::AtpTileSource::initialize(), ossimImageCombiner::initialize(), ossimTwoColorView::initialize(), isConnected(), ossimHistogramWriter::loadState(), ossimImageHistogramSource::loadState(), ossimAtbController::lockImage(), ossimImageCombiner::precomputeBounds(), propagateEventToInputs(), saveStateOfAllInputs(), and ossimAtbController::unlockImage().
2314 {
2315  return (ossim_uint32)theInputObjectList.size();
2316 }
◆ getNumberOfOutputs()
ossim_uint32 ossimConnectableObject::getNumberOfOutputs ( ) const
virtual
Definition at line 2318 of file ossimConnectableObject.cpp.
Referenced by accept(), and propagateEventToOutputs().
2319 {
2320  return (ossim_uint32)theOutputObjectList.size();
2321 }
◆ getOutput() [1/2]
ossimConnectableObject * ossimConnectableObject::getOutput ( ossim_uint32  index = 0)
Definition at line 1374 of file ossimConnectableObject.cpp.
Referenced by propagateEventToOutputs().
1375 {
1376  if(idx < theOutputObjectList.size())
1377  {
1378  return theOutputObjectList[idx].get();
1379  }
1380
1381  return 0;
1382 }
◆ getOutput() [2/2]
const ossimConnectableObject * ossimConnectableObject::getOutput ( ossim_uint32  index = 0) const
Definition at line 1585 of file ossimConnectableObject.cpp.
1586 {
1587  if(idx < theOutputObjectList.size())
1588  {
1589  return theOutputObjectList[idx].get();
1590  }
1591
1592  return 0;
1593 }
◆ getOutputList() [1/2]
const ossimConnectableObject::ConnectableObjectList & ossimConnectableObject::getOutputList ( ) const
Definition at line 2338 of file ossimConnectableObject.cpp.
Referenced by ossimImageChain::insertRight(), ossimImageChain::processEvent(), ossimImageChain::replace(), and ossimImageHandlerMtAdaptor::setAdaptee().
2339 {
2340  return theOutputObjectList;
2341 }
◆ getOutputList() [2/2]
Definition at line 2348 of file ossimConnectableObject.cpp.
2349 {
2350  return theOutputObjectList;
2351 }
◆ getOutputListIsFixedFlag()
bool ossimConnectableObject::getOutputListIsFixedFlag ( ) const
virtual
Definition at line 2328 of file ossimConnectableObject.cpp.
References theOutputListIsFixedFlag.
Referenced by ossimImageChain::add().
2329 {
2330  return theOutputListIsFixedFlag;
2331 }
◆ getOwner()
const ossimObject * ossimConnectableObject::getOwner ( ) const
Fetches the current owner, most likely a container but not limited to one.
Definition at line 2308 of file ossimConnectableObject.cpp.
References theOwner.
Referenced by ossimConnectableContainer::removeChild().
2309 {
2310  return theOwner;
2311 }
◆ getProperty()
ossimRefPtr< ossimProperty > ossimConnectableObject::getProperty ( const ossimString name) const
virtual
Reimplemented from ossimPropertyInterface.
Reimplemented in ossimImageHandler, ossimCibCadrgTileSource, ossimImageFileWriter, ossimRpfCacheTileSource, ossimImageSource, ossimLasReader, ossimTiffTileSource, ossimGdalTileSource, ossimBumpShadeTileSource, ossimPixelFlipper, ossimPointCloudImageHandler, ossimH5ImageHandler, ossimEquationCombiner, ossimNitfTileSource, ossimHdf5ImageHandler, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimMaskFilter, ossimDtedTileSource, ossimAdrgTileSource, ossimCcfTileSource, ossimMetadataFileWriter, ossimJpegTileSource, ossimWriter, ossimPngReader, ossimBandSelector, ossimWatermarkFilter, ossimPdfWriter, ossimTiffWriter, ossimGpkgReader, ossimImageRenderer, ossimGpkgWriter, ossimRangeDomeTileSource, ossimNBandToIndexFilter, ossimPngWriter, ossimHistogramMatchFilter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimScalarRemapper, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimJpegWriter, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalWriter, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimEnviTileSource, ossimLandsatTileSource, ossimKakaduJpipHandler, ossimNitfWriterBase, ossimSrtmTileSource, ossimCacheTileSource, ossimImageSourceFilter, ossimNitfWriter, ossimSFIMFusion, ossimImageGaussianFilter, ossimFftFilter, ossimImageToPlaneNormalFilter, ossimNitf20Writer, ossimEdgeFilter, ossimSource, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossimDoqqTileSource, ossim3x3ConvolutionFilter, ossimTrimFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 1815 of file ossimConnectableObject.cpp.
References ossimObject::getClassName(), ossimProperty::setReadOnlyFlag(), and theDescription.
Referenced by ossimSource::getProperty(), and ossimMetadataFileWriter::getProperty().
1816 {
1817  if(name == "Description")
1818  {
1819  return new ossimTextProperty(name, theDescription);
1820  }
1821  // "Class name" check for backwards compatibility only.
1822  else if( (name == "class_name") ||
1823  (name == "Class name") )
1824  {
1825  ossimProperty* prop = new ossimTextProperty(name,
1826  getClassName());
1827  prop->setReadOnlyFlag(true);
1828
1829  return prop;
1830  }
1831  return ossimRefPtr<ossimProperty>();
1832 }
virtual void setReadOnlyFlag(bool flag)
◆ getPropertyNames()
void ossimConnectableObject::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Reimplemented in ossimImageHandler, ossimCibCadrgTileSource, ossimImageFileWriter, ossimLasReader, ossimImageSource, ossimGdalTileSource, ossimTiffOverviewBuilder, ossimTiffTileSource, ossimBumpShadeTileSource, ossimH5ImageHandler, ossimPixelFlipper, ossimHdf5ImageHandler, ossimNitfTileSource, ossimEquationCombiner, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimMaskFilter, ossimDtedTileSource, ossimAdrgTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimMetadataFileWriter, ossimGdalOverviewBuilder, ossimWatermarkFilter, ossimWriter, ossimPngReader, ossimPdfWriter, ossimTiffWriter, ossimBandSelector, ossimGpkgReader, ossimKakaduNitfOverviewBuilder, ossimGpkgWriter, ossimImageRenderer, ossimHistogramMatchFilter, ossimNBandToIndexFilter, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimScalarRemapper, ossimJpegWriter, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalWriter, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimEnviTileSource, ossimLandsatTileSource, ossimNitfWriterBase, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimNitfWriter, ossimSrtmTileSource, ossimKakaduJpipHandler, ossimNitf20Writer, ossimCacheTileSource, ossimImageSourceFilter, ossimTrimFilter, ossimSFIMFusion, ossimFftFilter, ossimImageGaussianFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimDoqqTileSource, ossimSource, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 1834 of file ossimConnectableObject.cpp.
Referenced by ossimSource::getPropertyNames(), and ossimMetadataFileWriter::getPropertyNames().
1835 {
1836  propertyNames.push_back("class_name");
1837  propertyNames.push_back("Description");
1838 }
◆ isConnected()
bool ossimConnectableObject::isConnected ( ossimConnectableObjectDirectionType  direction = CONNECTABLE_DIRECTION_INPUT) const
virtual
If any slot is null then false is returned. If a filter requires options testing they need to override this method. The argument can be ored together. If you want both checked then pass CONNECTABLE_DIRECTION_INPUT | CONNECTABLE_DIRECTION_OUTPUT
Definition at line 100 of file ossimConnectableObject.cpp.
References CONNECTABLE_DIRECTION_INPUT, CONNECTABLE_DIRECTION_OUTPUT, getNumberOfInputs(), theInputListIsFixedFlag, theInputObjectList, theOutputListIsFixedFlag, and theOutputObjectList.
Referenced by accept().
101 {
102  if(direction & CONNECTABLE_DIRECTION_INPUT)
103  {
104  if(getNumberOfInputs())
105  {
106  ConnectableObjectList::const_iterator current = theInputObjectList.begin();
107
108  while(current != theInputObjectList.end())
109  {
110  if(! (*current))
111  {
112  return false;
113  }
114
115  ++current;
116  }
117  }
118  else if(!theInputListIsFixedFlag)
119  {
120  return false;
121  }
122  }
123
124  if(direction & CONNECTABLE_DIRECTION_OUTPUT)
125  {
126  if(theOutputObjectList.empty())
127  {
129
130  }
131  ConnectableObjectList::const_iterator current = theOutputObjectList.begin();
132  current = theOutputObjectList.begin();
133  while(current != theOutputObjectList.end())
134  {
135  if(! (*current))
136  {
137  return false;
138  }
139
140  ++current;
141  }
142  }
143
144  return true;
145 }
bool theInputListIsFixedFlag
Indicates whether the theInputObjectList is fixed.
bool theOutputListIsFixedFlag
Indicates whether the theOutputObjectList is fixed.
◆ loadState()
bool ossimConnectableObject::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented in ossimHistogramRemapper, ossimImageHandler, ossimImageFileWriter, ossimCibCadrgTileSource, ossimEquationCombiner, ossimEsriShapeFileFilter, ossimLasReader, ossimKakaduJp2Reader, ossimImageChain, ossimMapCompositionSource, ossimKakaduJ2kReader, ossimPointCloudImageHandler, ossimMrSidReader, ossimGeoPdfReader, ossimImageSource, ossimMG4LidarReader, ossimBumpShadeTileSource, ossimTiffTileSource, ossimElevManager, ossimRpfCacheTileSource, ossimMaskFilter, ossimHdfReader, ossimIndexToRgbLutFilter, ossimConnectableContainer, ossimImageSourceSequencer, ossimPixelFlipper, ossimResampler, ossimHistogramMatchFilter, ossimNitfTileSource, ossimScaleFilter, ossimBandLutFilter, ossimWriter, ossimBandSelector, ossimCcfTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimDtedTileSource, ossimPiecewiseRemapper, ossimOgrVectorTileSource, ossimImageElevationDatabase, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimAtCorrGridRemapper, ossimWatermarkFilter, ossimGdalTileSource, ossimKMeansFilter, ossimPdfWriter, ossimTiffWriter, ossimHdf5ImageHandler, ossimGpkgReader, ossimNitfWriterBase, ossimUsgsDemTileSource, ossimJpegTileSource, ossimTiledElevationDatabase, ossimImageCacheBase, ossimGpkgWriter, ossimBitMaskWriter, ossimGeoPolyCutter, ossimTopographicCorrectionFilter, ossimKmlSuperOverlayReader, ossimRangeDomeTileSource, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimNitfWriter, ossimMetadataFileWriter, ossimElevImageSource, ossimAnnotationSource, ossimBandAverageFilter, ossimBrightnessContrastSource, ossimMeanMedianFilter, ossimTiledImagePatch, ossimMemoryImageSource, ossimNitf20Writer, ossimOutputSource, ossimGridRemapSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimGdalOgrVectorAnnotation, ossimImageRenderer, ossimMultiBandHistogramTileSource, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimScalarRemapper, ossimSubImageTileSource, ossimElevationCellDatabase, ossimHistogramWriter, ossimImageHistogramSource, ossimRLevelFilter, ossimValueAssignImageSourceFilter, ossimGeneralRasterWriter, ossimConvolutionFilter1D, ossimTiledImageHandler, ossimGdalWriter, ossimElevationDatabase, ossimBandClipFilter, ossimKakaduJpipHandler, ossimKakaduNitfWriter, ossimSlopeFilter, ossimKakaduJp2Writer, ossimBandSeparateHandler, ossimJpegWriter, ossimplugins::ossimTerraSarTiffReader, ossimImageWriter, ossimDtedElevationDatabase, ossimGeneralRasterElevationDatabase, ossimGeoAnnotationSource, ossimLocalCorrelationFusion, ossimplugins::ossimRadarSat2TiffReader, ossimEnviTileSource, ossimLandsatTileSource, ossimImageChainMtAdaptor, ossimHsiRemapper, ossimSFIMFusion, ossimDilationFilter, ossimCastTileSourceFilter, ossimVectorRenderer, ossimTableRemapper, ossimSrtmElevationDatabase, ossimFftFilter, ossimImageGaussianFilter, ossimLinearStretchRemapper, ossimSource, ossimCacheTileSource, ossimEdgeFilter, ossimMultiThreadSequencer, ossimFgdcFileWriter, ossimImageHandlerMtAdaptor, ossimMaxMosaic, ossimSrtmTileSource, ossimRgbToGreyFilter, ossimElevationMosaic, ossimImageMosaic, ossimPolyCutter, ossimErosionFilter, ossimRectangleCutFilter, ossimHistoMatchRemapper, ossimMapViewController, ossimEnviHeaderFileWriter, ossimWorldFileWriter, ossim3x3ConvolutionFilter, ossimArcInfoGridWriter, ossimConvolutionSource, ossimImageToPlaneNormalFilter, ossimAOD, ossimAtCorrRemapper, ossimERSTileSource, ossimImageSourceFilter, ossimERSFileWriter, ossimGammaRemapper, ossimElevRemapper, ossimImageSharpenFilter, ossimBlendMosaic, ossimBrightnessMatch, ossimImageCombiner, ossimQuickbirdNitfTileSource, ossimHistogramEqualization, ossimHistogramThreshholdFilter, ossimTrimFilter, ossimImageSourceHistogramFilter, ossimLandsatTopoCorrectionFilter, ossimHistogramSource, ossimVpfAnnotationSource, ossimDoqqTileSource, ossimDespeckleFilter, and ossimEastingNorthingCutter.
Definition at line 1840 of file ossimConnectableObject.cpp.
References CONNECTABLE_INPUT_LIST_FIXED_KW, CONNECTABLE_OUTPUT_LIST_FIXED_KW, ossimKeywordNames::DESCRIPTION_KW, ossimKeywordlist::find(), ossimKeywordlist::getNumberOfSubstringKeys(), ossimKeywordNames::ID_KW, ossimObject::loadState(), ossimKeywordNames::NUMBER_INPUTS_KW, ossimKeywordNames::NUMBER_OUTPUTS_KW, setNumberOfInputs(), setNumberOfOutputs(), theDescription, theId, theInputListIsFixedFlag, theInputObjectList, theOutputListIsFixedFlag, theOutputObjectList, ossimString::toBool(), and ossimString::toLong().
Referenced by ossimSource::loadState(), ossimMetadataFileWriter::loadState(), and ossimConnectableContainer::loadState().
1842 {
1843  const char* lookup = kwl.find(prefix,
1845
1846  // disconnect(this);
1847
1848  if(lookup)
1849  {
1850  theId = ossimId(ossimString(lookup).toLong());
1851  }
1852
1853  lookup = kwl.find(prefix, CONNECTABLE_INPUT_LIST_FIXED_KW);
1854  if(lookup)
1855  {
1857  }
1858
1859  lookup = kwl.find(prefix, CONNECTABLE_OUTPUT_LIST_FIXED_KW);
1860  if(lookup)
1861  {
1863  }
1864
1865  ossim_int32 numberInputs = 0;
1866  ossim_int32 numberOutputs = 0;
1867
1868  ossimString regExpression;
1869  lookup = kwl.find(prefix, ossimKeywordNames::NUMBER_INPUTS_KW);
1870  if(lookup)
1871  {
1872  numberInputs = ossimString(lookup).toLong();
1873  }
1874  else if(!theInputListIsFixedFlag)
1875  {
1876  regExpression = ossimString("^(") + ossimString(prefix) + "input_connection[0-9]+)";
1877  numberInputs = kwl.getNumberOfSubstringKeys(regExpression);
1878  }
1879  else
1880  {
1881  // if we are fixed then the list should already be set
1882  numberInputs = (ossim_int32) theInputObjectList.size();
1883  }
1884
1885
1886  lookup = kwl.find(prefix, ossimKeywordNames::NUMBER_OUTPUTS_KW);
1887  if(lookup)
1888  {
1889  numberOutputs = ossimString(lookup).toLong();
1890  }
1891  else if(!theOutputListIsFixedFlag)
1892  {
1893  regExpression = ossimString("^(") + ossimString(prefix) + "output_connection[0-9]+)";
1894  numberOutputs = kwl.getNumberOfSubstringKeys(regExpression);
1895  }
1896  else
1897  {
1898  // if we are fixed then the list should already be set
1899  numberOutputs = (ossim_int32) theOutputObjectList.size();
1900  }
1901
1902  lookup = kwl.find(prefix, ossimKeywordNames::DESCRIPTION_KW);
1903  if (lookup)
1904  {
1905  theDescription = lookup;
1906  }
1907
1908  setNumberOfInputs(numberInputs);
1909  setNumberOfOutputs(numberOutputs);
1910
1911  return ossimObject::loadState(kwl, prefix);
1912 }
virtual void setNumberOfInputs(ossim_int32 numberOfInputs)
Will set the number of inputs.
ossim_uint32 getNumberOfSubstringKeys(const ossimString &regularExpression) const
const char * CONNECTABLE_INPUT_LIST_FIXED_KW
static const char * NUMBER_INPUTS_KW
bool toBool() const
String to numeric methods.
const char * CONNECTABLE_OUTPUT_LIST_FIXED_KW
long toLong() const
toLong&#39;s deprecated, please use the toInts...
ConnectableObjectList theInputObjectList
Holds a list of input objects.
static const char * DESCRIPTION_KW
static const char * ID_KW
ConnectableObjectList theOutputObjectList
Holds a list of output objects.
static const char * NUMBER_OUTPUTS_KW
int ossim_int32
virtual void setNumberOfOutputs(ossim_int32 numberOfInputs)
Will set the number of outputs.
◆ moveInputDown()
bool ossimConnectableObject::moveInputDown ( const ossimId id)
Moves the input connection matching id down one in the connection list.
Parameters
idThe id to move.
Returns
true if action was performed, false if not.
Definition at line 2097 of file ossimConnectableObject.cpp.
References findInputIndex(), ossimListenerManager::fireEvent(), OSSIM_EVENT_CONNECTION_CONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, theInputListIsFixedFlag, and theInputObjectList.
2098 {
2099  bool result = false;
2100
2101  if (theInputListIsFixedFlag == false)
2102  {
2103  if ( theInputObjectList.size() )
2104  {
2105  ossim_int32 indexOfId = findInputIndex(id);
2106
2107  if ( indexOfId <
2108  static_cast<ossim_int32>(theInputObjectList.size()-1) )
2109  {
2110  ConnectableObjectList oldInputs =
2112
2113  // Swap with index below.
2114  ossimRefPtr<ossimConnectableObject> tmpObj = theInputObjectList[indexOfId].get();
2115  theInputObjectList[indexOfId] = theInputObjectList[indexOfId+1].get();
2116  theInputObjectList[indexOfId+1] = tmpObj;
2117  result = true;
2118
2119  ConnectableObjectList newInputs =
2121
2122  ossimConnectionEvent event(this,
2124  newInputs,
2125  oldInputs,
2127  fireEvent(event);
2128  }
2129  }
2130  }
2131
2132  return result;
2133 }
virtual void fireEvent(ossimEvent &event)
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
#define OSSIM_EVENT_CONNECTION_CONNECT_ID
Definition: ossimEventIds.h:22
int ossim_int32
◆ moveInputToBottom()
bool ossimConnectableObject::moveInputToBottom ( const ossimId id)
Moves the input connection matching id to the bottom of the connection list.
Parameters
idThe id to move.
Returns
Definition at line 2183 of file ossimConnectableObject.cpp.
References ossimListenerManager::fireEvent(), ossimRefPtr< T >::get(), OSSIM_EVENT_CONNECTION_CONNECT_ID, ossimConnectionEvent::OSSIM_INPUT_DIRECTION, theInputListIsFixedFlag, and theInputObjectList.
2184 {
2185  bool result = false;
2186
2187  if (theInputListIsFixedFlag == false)
2188  {
2189  if ( theInputObjectList.size() )
2190  {
2191  ConnectableObjectList::iterator bottom =
2192  theInputObjectList.end()-1;
2193
2194  // if not bottom already
2195  if ( (*bottom)->getId() != id )
2196  {
2197  ConnectableObjectList::iterator i =
2198  theInputObjectList.begin();
2199
2200  while (i != bottom)
2201  {
2202  if ( (*i)->getId() == id )
2203  {
2204  break;
2205  }
2206  ++i;
2207  }
2208
2209  if (i != bottom)
2210  {
2211  ConnectableObjectList oldInputs =
2213
2215  theInputObjectList.erase(i);
2216  theInputObjectList.push_back(obj);
2217  result = true;
2218
2219  ConnectableObjectList newInputs =
2221
2222  ossimConnectionEvent event(
2223  this,
2225  newInputs,
2226  oldInputs,
2228  fireEvent(event);
2229  }
2230  }
2231  }
2232  }
2233
2234  return result;
2235 }
◆ moveInputToTop()
bool ossimConnectableObject::moveInputToTop ( const ossimId id)
Moves the input connection matching id to the top of the connection list.
Parameters
idThe id to move.
Returns
Definition at line 2135 of file ossimConnectableObject.cpp.
2136 {
2137  bool result = false;
2138
2139  if (theInputListIsFixedFlag == false)
2140  {
2141  if ( theInputObjectList.size() )
2142  {
2143  ConnectableObjectList::iterator i =
2144  theInputObjectList.begin();
2145
2146  while (i != theInputObjectList.end())
2147  {
2148  if ( (*i)->getId() == id )
2149  {
2150  break;
2151  }
2152  ++i;
2153  }
2154
2155  if ( (i != theInputObjectList.begin()) &&
2156  (i != theInputObjectList.end()) )
2157  {
2158  ConnectableObjectList oldInputs =
2160
2162  theInputObjectList.erase(i);
2163  theInputObjectList.insert(theInputObjectList.begin(), obj.get());
2164  result = true;
2165
2166  ConnectableObjectList newInputs =
2168
2169  ossimConnectionEvent event(
2170  this,
2172  newInputs,
2173  oldInputs,
2175  fireEvent(event);
2176  }
2177  }
2178  }
2179
2180  return result;
2181 }
◆ moveInputUp()
bool ossimConnectableObject::moveInputUp ( const ossimId id)
Moves the input connection matching id up one in the connection list.
Parameters
idThe id to move.
Returns
Definition at line 2060 of file ossimConnectableObject.cpp.
2061 {
2062  bool result = false;
2063
2064  if (theInputListIsFixedFlag == false)
2065  {
2066  if ( theInputObjectList.size() )
2067  {
2068  ossim_int32 indexOfId = findInputIndex(id);
2069
2070  if (indexOfId > 0)
2071  {
2072  ConnectableObjectList oldInputs =
2074
2075  // Swap with index above.
2076  ossimRefPtr<ossimConnectableObject> tmpObj = theInputObjectList[indexOfId].get();
2077  theInputObjectList[indexOfId] = theInputObjectList[indexOfId-1].get();
2078  theInputObjectList[indexOfId-1] = tmpObj;
2079  result = true;
2080
2081  ConnectableObjectList newInputs =
2083
2084  ossimConnectionEvent event(this,
2086  newInputs,
2087  oldInputs,
2089  fireEvent(event);
2090  }
2091  }
2092  }
2093
2094  return result;
2095 }
int ossim_int32
◆ OSSIM_DEPRECATE_METHOD() [1/6]
ossimConnectableObject::OSSIM_DEPRECATE_METHOD ( virtual ossimConnectableObject findConnectableObjectconst ossimId &id)
These methods are now deprecated. You can achieve the same thing by using the new visitor design pattern. If this does not achieve exactly what you want then you can derive new rules by overriding the virtual visit method in ossimVisitor
   ossimIdVisitor visitor(id, false, ossimVisitor::VISIT_CHILDREN |
   ossimVisitor::VISIT_INPUTS);
   connectableObject->accept(visitor);
   ossimRefPtr<ossimConnectableObject> object = visitor.getObject();
◆ OSSIM_DEPRECATE_METHOD() [2/6]
ossimConnectableObject::OSSIM_DEPRECATE_METHOD ( virtual ossimConnectableObject findObjectOfTypeRTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)
   ossimTypeIdVisitor visitor(typeId, true, ossimVisitor::VISIT_CHILDREN |
◆ OSSIM_DEPRECATE_METHOD() [3/6]
ossimConnectableObject::OSSIM_DEPRECATE_METHOD ( virtual ossimConnectableObject findObjectOfTypeconst ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)
   ossimTypeNameVisitor visitor(typeName, true,
   ossimVisitor::VISIT_CHILDREN | ossimVisitor::VISIT_INPUTS);
◆ OSSIM_DEPRECATE_METHOD() [4/6]
ossimConnectableObject::OSSIM_DEPRECATE_METHOD ( virtual ossimConnectableObject findInputObjectOfTypeconst ossimString &className)
◆ OSSIM_DEPRECATE_METHOD() [5/6]
ossimConnectableObject::OSSIM_DEPRECATE_METHOD ( virtual void   findAllObjectsOfTypeConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)
   ossimTypeNameVisitor visitor("<put type name here>",
   false, ossimVisitor::VISIT_CHILDREN);
   ossimCollectionVisitor::List& collection = visitor.getObjects();
◆ OSSIM_DEPRECATE_METHOD() [6/6]
ossimConnectableObject::OSSIM_DEPRECATE_METHOD ( virtual void   findAllObjectsOfTypeConnectableObjectList &result, const ossimString &className, bool recurse=true)
   ossimTypeNameVisitor visitor("<put type name here>", false,
◆ propagateEventToInputs()
void ossimConnectableObject::propagateEventToInputs ( ossimEvent event)
virtual
Reimplemented in ossimImageChain.
Definition at line 1786 of file ossimConnectableObject.cpp.
References ossimListenerManager::fireEvent(), getInput(), getNumberOfInputs(), and propagateEventToInputs().
Referenced by propagateEventToInputs().
1787 {
1788  ossim_uint32 i;
1789
1790  for(i = 0; i <getNumberOfInputs(); ++i)
1791  {
1792  ossimConnectableObject* obj = getInput(i);
1793  if(obj)
1794  {
1795  obj->fireEvent(event);
1796  obj->propagateEventToInputs(event);
1797  }
1798  }
1799 }
unsigned int ossim_uint32
virtual void propagateEventToInputs(ossimEvent &event)
◆ propagateEventToOutputs()
void ossimConnectableObject::propagateEventToOutputs ( ossimEvent event)
virtual
Definition at line 1770 of file ossimConnectableObject.cpp.
References ossimListenerManager::fireEvent(), getNumberOfOutputs(), getOutput(), propagateEventToOutputs(), and ossimEvent::PROPAGATION_OUTPUT.
Referenced by propagateEventToOutputs(), ossimChipProcTool::propagateGeometryToChains(), and ossimConnectableContainerChildListener::propagatePropertyEvent().
1771 {
1772  ossim_uint32 i;
1773
1774  for(i = 0; i <getNumberOfOutputs(); ++i)
1775  {
1777  if(obj)
1778  {
1779  event.setPropagationType(ossimEvent::PROPAGATION_OUTPUT);
1780  obj->fireEvent(event);
1781  obj->propagateEventToOutputs(event);
1782  }
1783  }
1784 }
virtual void propagateEventToOutputs(ossimEvent &event)
virtual ossim_uint32 getNumberOfOutputs() const
Return the number of output objects.
ossimConnectableObject * getOutput(ossim_uint32 index=0)
◆ saveState()
bool ossimConnectableObject::saveState ( ossimKeywordlist kwl,
) const
virtual
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Reimplemented in ossimHistogramRemapper, ossimImageHandler, ossimImageFileWriter, ossimGeoPdfReader, ossimEsriShapeFileFilter, ossimEquationCombiner, ossimLasReader, ossimImageChain, ossimMapCompositionSource, ossimCibCadrgTileSource, ossimPointCloudImageHandler, ossimBumpShadeTileSource, ossimImageSource, ossimMaskFilter, ossimTiffTileSource, ossimElevManager, ossimHistogramMatchFilter, ossimConnectableContainer, ossimIndexToRgbLutFilter, ossimPixelFlipper, ossimRpfCacheTileSource, ossimBandLutFilter, ossimResampler, ossimNitfTileSource, ossimScaleFilter, ossimWriter, ossimImageElevationDatabase, ossimAtCorrGridRemapper, ossimBandSelector, ossimCcfTileSource, ossimKMeansFilter, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimDtedTileSource, ossimOgrVectorTileSource, ossimPiecewiseRemapper, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimGdalTileSource, ossimTiledElevationDatabase, ossimPdfWriter, ossimTopographicCorrectionFilter, ossimHdf5ImageHandler, ossimTiffWriter, ossimGpkgReader, ossimRangeDomeTileSource, ossimBrightnessContrastSource, ossimJpegTileSource, ossimTiledImagePatch, ossimGpkgWriter, ossimGeoPolyCutter, ossimUsgsDemTileSource, ossimWatermarkFilter, ossimKmlSuperOverlayReader, ossimBandAverageFilter, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimGridRemapSource, ossimNitfWriterBase, ossimElevImageSource, ossimNitfWriter, ossimAnnotationSource, ossimMeanMedianFilter, ossimMemoryImageSource, ossimMultiBandHistogramTileSource, ossimOutputSource, ossimSubImageTileSource, ossimRgbToIndexFilter, ossimGdalOgrVectorAnnotation, ossimNBandToIndexFilter, ossimRLevelFilter, ossimElevationCellDatabase, ossimImageHistogramSource, ossimImageCacheBase, ossimNitf20Writer, ossimImageRenderer, ossimBandClipFilter, ossimPngWriter, ossimElevationDatabase, ossimConvolutionFilter1D, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimHistogramWriter, ossimScalarRemapper, ossimKakaduJpipHandler, ossimTiledImageHandler, ossimValueAssignImageSourceFilter, ossimGeneralRasterWriter, ossimGdalWriter, ossimDtedElevationDatabase, ossimGeneralRasterElevationDatabase, ossimImageChainMtAdaptor, ossimBandSeparateHandler, ossimKakaduNitfWriter, ossimImageWriter, ossimSlopeFilter, ossimKakaduJp2Writer, ossimJpegWriter, ossimLocalCorrelationFusion, ossimFftFilter, ossimplugins::ossimTerraSarTiffReader, ossimSrtmElevationDatabase, ossimImageGaussianFilter, ossimSFIMFusion, ossimCacheTileSource, ossimGeoAnnotationSource, ossimplugins::ossimRadarSat2TiffReader, ossimLinearStretchRemapper, ossimDilationFilter, ossimEdgeFilter, ossimHsiRemapper, ossimSource, ossimEnviTileSource, ossimCastTileSourceFilter, ossimVectorRenderer, ossimTableRemapper, ossimImageHandlerMtAdaptor, ossim3x3ConvolutionFilter, ossimImageSourceFilter, ossimImageToPlaneNormalFilter, ossimRectangleCutFilter, ossimMaxMosaic, ossimImageSharpenFilter, ossimRgbToGreyFilter, ossimMapViewController, ossimElevationMosaic, ossimErosionFilter, ossimImageMosaic, ossimPolyCutter, ossimSrtmTileSource, ossimBrightnessMatch, ossimElevRemapper, ossimImageCombiner, ossimHistogramEqualization, ossimArcInfoGridWriter, ossimConvolutionSource, ossimHistogramThreshholdFilter, ossimImageSourceHistogramFilter, ossimTrimFilter, ossimLandsatTopoCorrectionFilter, ossimBlendMosaic, ossimQuickbirdNitfTileSource, ossimHistogramSource, ossimVpfAnnotationSource, ossimDespeckleFilter, and ossimEastingNorthingCutter.
Definition at line 1914 of file ossimConnectableObject.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), CONNECTABLE_INPUT_LIST_FIXED_KW, CONNECTABLE_OUTPUT_LIST_FIXED_KW, ossimKeywordNames::DESCRIPTION_KW, ossimId::getId(), ossimKeywordNames::ID_KW, ossimKeywordNames::NUMBER_INPUTS_KW, ossimKeywordNames::NUMBER_OUTPUTS_KW, ossimObject::saveState(), theDescription, theId, theInputListIsFixedFlag, theInputObjectList, theOutputListIsFixedFlag, theOutputObjectList, and ossimString::toString().
Referenced by ossimIgenGenerator::generateChainForMultiInput(), ossimIgenGenerator::generateInputKwl(), ossimIgenGenerator::generateOutputKwl(), ossimSource::saveState(), ossimConnectableContainer::saveState(), and saveStateOfAllInputs().
1916 {
1917  ossimObject::saveState(kwl, prefix);
1918
1919  kwl.add(prefix,
1921  theId.getId(),
1922  true);
1923
1924  kwl.add(prefix,
1927  true);
1928
1929  kwl.add(prefix,
1932  true);
1933
1934  kwl.add(prefix,
1937  true);
1938
1939  kwl.add(prefix,
1941  static_cast<ossim_uint32>(theInputObjectList.size()),
1942  true);
1943
1944  kwl.add(prefix,
1946  static_cast<ossim_uint32>(theOutputObjectList.size()),
1947  true);
1948
1949  ossim_int32 i = 0;
1950  for(i = 1; i <= (ossim_int32)theInputObjectList.size(); ++i)
1951  {
1952  ossimString value = "input_connection" + ossimString::toString(i);
1953
1954  ossim_int32 id;
1955
1956  if(theInputObjectList[i-1].valid())
1957  {
1958  id = theInputObjectList[i-1]->getId().getId();
1959  }
1960  else
1961  {
1962  id = -1;
1963  }
1964  kwl.add(prefix,
1965  value.c_str(),
1966  id,
1967  true);
1968  }
1969
1970  for(i = 1; i <= (ossim_int32)theOutputObjectList.size(); ++i)
1971  {
1972  ossimString value = "output_connection" + ossimString::toString(i);
1973
1974  ossim_int32 id;
1975
1976  if(theOutputObjectList[i-1].valid())
1977  {
1978  id = theOutputObjectList[i-1]->getId().getId();
1979  }
1980  else
1981  {
1982  id = -1;
1983  }
1984  kwl.add(prefix,
1985  value.c_str(),
1986  id,
1987  true);
1988  }
1989
1990  return true;
1991 }
Definition: ossimObject.cpp:95
Numeric to string methods.
ossim_int64 getId() const
Definition: ossimId.h:29
const char * c_str() const
Definition: ossimString.h:396
int ossim_int32
◆ saveStateOfAllInputs()
ossim_uint32 ossimConnectableObject::saveStateOfAllInputs ( ossimKeywordlist kwl,
bool  saveThisStateFlag = true,
ossim_uint32  objectIndex = 1,
) const
virtual
Save the state of all inputs to a keyword list.
This will do a recursive call through all inputs and save their state to a keyword list.
Parameters
kwlKeyword list to save state to.
saveThisStateFlagIf the true the state of this object will be saved as well as all inputs. Default = true.
objectIndexIndex to be used for prefix. So if objectIndex = 1, the first object will have a prefix of: "object1." Default = 1.
prefixPrefix to tack onto keyword. If prefix = "myChain." and objectIndex = 1, then the first keyword would be "myChain.object1.some_keyword".
Returns
Returns the next object index. This is the last index used plus one. Used internally to keep track of index to use for prefix.
Definition at line 1993 of file ossimConnectableObject.cpp.
References ossimString::c_str(), getInput(), getNumberOfInputs(), saveState(), saveStateOfAllInputs(), and ossimString::toString().
Referenced by saveStateOfAllInputs().
1997 {
1998  ossim_uint32 index = objectIndex;
1999
2000  const ossim_uint32 NUMBER_OF_INPUTS = getNumberOfInputs();
2001  if (NUMBER_OF_INPUTS)
2002  {
2003  // Save all the inputs.
2004  for(ossim_uint32 i = 0; i < NUMBER_OF_INPUTS; ++i)
2005  {
2006  const ossimConnectableObject* input = getInput(i);
2007  if(input)
2008  index = input->saveStateOfAllInputs(kwl, true, index, prefix);
2009  }
2010  }
2011
2012  if (saveThisStateFlag)
2013  {
2014  ossimString myPrefix;
2015  if (prefix)
2016  myPrefix = prefix;
2017
2018  myPrefix += "object" + ossimString::toString(index) + ".";
2019
2020  // Save the state of this object.
2021  saveState(kwl, myPrefix.c_str());
2022  ++index;
2023  }
2024
2025  return index;
2026 }
virtual ossim_uint32 saveStateOfAllInputs(ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const
◆ setDescription()
void ossimConnectableObject::setDescription ( const ossimString description)
virtual
◆ setId()
void ossimConnectableObject::setId ( const ossimId id)
All connectable objects will have id's.
This allows us to set the id of this object.
Definition at line 2298 of file ossimConnectableObject.cpp.
References theId.
Referenced by ossimConnectableContainer::makeUniqueIds(), and ossimImageChain::makeUniqueIds().
2299 {
2300  theId = id;
2301 }
◆ setNumberOfInputs()
void ossimConnectableObject::setNumberOfInputs ( ossim_int32  numberOfInputs)
virtual
This will expand the list if the number of inputs is larger than the current number of inputs. Will shrink the list if the current number of inputs is larger than the passed in inputs.
Definition at line 1509 of file ossimConnectableObject.cpp.
References disconnectMyInputs(), and theInputObjectList.
Referenced by ossimImageChain::addLast(), ossimHistogramWriter::loadState(), ossimImageHistogramSource::loadState(), ossimMaskFilter::loadState(), loadState(), ossimConnectableObject(), ossimHistogramRemapper::ossimHistogramRemapper(), and ossimImageSourceHistogramFilter::ossimImageSourceHistogramFilter().
1510 {
1511  if((ossim_int32)theInputObjectList.size() == numberOfInputs)
1512  {
1513  return;
1514  }
1515  ossim_int32 i = 0;
1516  if(numberOfInputs < (ossim_int32)theInputObjectList.size())
1517  {
1519  theInputObjectList.begin()+numberOfInputs);
1520  ConnectableObjectList disconnectList;
1521
1522  for(i = numberOfInputs;
1523  i < (ossim_int32)theInputObjectList.size();
1524  ++i)
1525  {
1526  if(theInputObjectList[i].valid())
1527  {
1528  disconnectList.push_back(theInputObjectList[i]);
1529  }
1530  }
1531  disconnectMyInputs(disconnectList);
1532
1533  theInputObjectList.clear();
1534  theInputObjectList = v;
1535  }
1536  else
1537  {
1538  for(i = (ossim_int32)theInputObjectList.size();
1539  i < numberOfInputs;
1540  ++i)
1541  {
1542  theInputObjectList.push_back(0);
1543  }
1544  }
1545 }
virtual void disconnectMyInputs(ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true)
int ossim_int32
◆ setNumberOfOutputs()
void ossimConnectableObject::setNumberOfOutputs ( ossim_int32  numberOfInputs)
virtual
This will expand the list if the number of outputs is larger than the current number of outputs. Will shrink the list if the current number of outputs is larger than the passed in outputs.
Definition at line 1547 of file ossimConnectableObject.cpp.
References disconnectMyOutputs(), and theOutputObjectList.
Referenced by loadState(), and ossimConnectableObject().
1548 {
1549  if((ossim_int32)theOutputObjectList.size() == numberOfOutputs)
1550  {
1551  return;
1552  }
1553  ossim_int32 i = 0;
1554  if(numberOfOutputs < (ossim_int32)theOutputObjectList.size())
1555  {
1557  theOutputObjectList.begin()+numberOfOutputs);
1558  ConnectableObjectList disconnectList;
1559  for(i = numberOfOutputs;
1560  i < (ossim_int32)theOutputObjectList.size();
1561  ++i)
1562  {
1563  if(theOutputObjectList[i].valid())
1564  {
1565  disconnectList.push_back(theOutputObjectList[i]);
1566  }
1567  }
1568  disconnectMyOutputs(disconnectList);
1569
1570  theOutputObjectList.clear();
1571  theOutputObjectList = v;
1572  }
1573  else
1574  {
1575  for(i = (ossim_int32)theOutputObjectList.size();
1576  i < numberOfOutputs;
1577  ++i)
1578  {
1579  theOutputObjectList.push_back(0);
1580  }
1581  }
1582 }
int ossim_int32
virtual void disconnectMyOutputs(ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true)
◆ setProperty() [1/2]
void ossimConnectableObject::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Reimplemented in ossimImageHandler, ossimImageFileWriter, ossimImageSource, ossimLasReader, ossimTiffTileSource, ossimBumpShadeTileSource, ossimTiffOverviewBuilder, ossimGdalTileSource, ossimPixelFlipper, ossimPointCloudImageHandler, ossimNitfTileSource, ossimH5ImageHandler, ossimEquationCombiner, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimMaskFilter, ossimMetadataFileWriter, ossimGdalOverviewBuilder, ossimWatermarkFilter, ossimWriter, ossimBandSelector, ossimPngReader, ossimImageRenderer, ossimPdfWriter, ossimKakaduNitfOverviewBuilder, ossimGpkgReader, ossimTiffWriter, ossimGpkgWriter, ossimRangeDomeTileSource, ossimNBandToIndexFilter, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimScalarRemapper, ossimHistogramMatchFilter, ossimPolyCutter, ossimBrightnessContrastSource, ossimKakaduNitfWriter, ossimGdalWriter, ossimGdalOgrVectorAnnotation, ossimKakaduJp2Writer, ossimJpegWriter, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimKakaduJpipHandler, ossimCacheTileSource, ossimImageSourceFilter, ossimNitfWriter, ossimNitfWriterBase, ossimFftFilter, ossimSFIMFusion, ossimImageGaussianFilter, ossimImageToPlaneNormalFilter, ossimNitf20Writer, ossimEdgeFilter, ossimTrimFilter, ossimSource, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 1801 of file ossimConnectableObject.cpp.
References ossimProperty::getName(), theDescription, and ossimRefPtr< T >::valid().
Referenced by ossimSource::setProperty(), and ossimMetadataFileWriter::setProperty().
1802 {
1803  if(!property.valid()) return;
1804  if(property->getName() == "Description")
1805  {
1806  property->valueToString(theDescription);
1807  }
1808 }
bool valid() const
const ossimString & getName() const
◆ setProperty() [2/2]
void ossimConnectableObject::setProperty ( const ossimString name,
const ossimString value
virtual
Definition at line 1810 of file ossimConnectableObject.cpp.
References ossimPropertyInterface::setProperty().
1811 {
1813 }
virtual void setProperty(const ossimString &name, const ossimString &value)
Member Data Documentation
◆ theDescription
ossimString ossimConnectableObject::theDescription
protected
◆ theId
ossimId ossimConnectableObject::theId
protected
◆ theInputListIsFixedFlag
bool ossimConnectableObject::theInputListIsFixedFlag
protected
◆ theInputObjectList
ConnectableObjectList ossimConnectableObject::theInputObjectList
protected
◆ theOutputListIsFixedFlag
bool ossimConnectableObject::theOutputListIsFixedFlag
protected
◆ theOutputObjectList
ConnectableObjectList ossimConnectableObject::theOutputObjectList
protected
◆ theOwner
ossimObject* ossimConnectableObject::theOwner
protected
