Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimWebRequestFactoryRegistry Class Reference
This will later be changed fro ossimHttpRequest to ossimWebRequest so we have a base class for general schema access such as ftp, sftp,smtp, ... More...
#include <ossimWebRequestFactoryRegistry.h>
Inheritance diagram for ossimWebRequestFactoryRegistry:
ossimWebRequestFactoryBase ossimFactoryListInterface< ossimWebRequestFactoryBase, ossimWebRequest > ossimBaseObjectFactory ossimObjectFactory ossimObject ossimReferenced
virtual ossimWebRequestcreate (const ossimUrl &url)
virtual ossimHttpRequestcreateHttp (const ossimUrl &url)
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossimBaseObjectFactory
 ossimBaseObjectFactory ()
virtual ~ossimBaseObjectFactory ()
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
- Public Member Functions inherited from ossimFactoryListInterface< ossimWebRequestFactoryBase, ossimWebRequest >
 ossimFactoryListInterface ()
void addFactory (ossimWebRequestFactoryBase *factory)
 This is for backward compatability and calls registerFactory for simple adds. More...
bool isFactoryRegistered (ossimWebRequestFactoryBase *factory) const
 Public access method to determine if a factory is already registered to this list. More...
void registerFactory (ossimWebRequestFactoryBase *factory, bool pushToFrontFlag=false)
 Will register a factory to the factory list. More...
void unregisterFactory (ossimWebRequestFactoryBase *factory)
 Will remove the factory from the registry. More...
void unregisterFactory (const ossimString &factoryTypeName)
 Will remove the factory from the registry by name. More...
void unregisterAllFactories ()
 Will remove all factories from the registry. More...
void registerFactoryToFront (ossimWebRequestFactoryBase *factory)
 Inserts the factory to the front of the list. More...
void registerFactoryBefore (ossimWebRequestFactoryBase *factory, ossimWebRequestFactoryBase *beforeThisFactory)
 Will insert the factory before the beforeThisFactory. More...
void getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const
 Will add all object types the factories can allocate. More...
ossimObjectcreateObjectFromRegistry (const ossimString &typeName) const
 This is the base object return for all objects in the system. More...
ossimObjectcreateObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const
ossimWebRequestcreateNativeObjectFromRegistry (const ossimString &typeName) const
 This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More...
ossimWebRequestcreateNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const
static ossimWebRequestFactoryRegistryinstance ()
- Static Public Member Functions inherited from ossimBaseObjectFactory
static ossimBaseObjectFactoryinstance ()
 ossimWebRequestFactoryRegistry ()
virtual ~ossimReferenced ()
- Protected Member Functions inherited from ossimFactoryListInterface< ossimWebRequestFactoryBase, ossimWebRequest >
bool findFactory (ossimWebRequestFactoryBase *factory) const
 Utility to find a factory in the list. More...
static ossimWebRequestFactoryRegistrym_instance = 0
Additional Inherited Members
- Public Types inherited from ossimFactoryListInterface< ossimWebRequestFactoryBase, ossimWebRequest >
typedef std::vector< ossimWebRequestFactoryBase *> FactoryListType
typedef ossimWebRequestFactoryBase FactoryType
typedef ossimWebRequest NativeReturnType
- Protected Attributes inherited from ossimFactoryListInterface< ossimWebRequestFactoryBase, ossimWebRequest >
std::mutex m_factoryListMutex
FactoryListType m_factoryList
Detailed Description
etc and not just restricted to http and https schema definitions.
Definition at line 13 of file ossimWebRequestFactoryRegistry.h.
◆ ossimWebRequestFactoryRegistry()
ossimWebRequestFactoryRegistry::ossimWebRequestFactoryRegistry ( )
protected
Definition at line 6 of file ossimWebRequestFactoryRegistry.cpp.
References m_instance.
Referenced by instance().
7 {
8  m_instance = this;
9 }
static ossimWebRequestFactoryRegistry * m_instance
Member Function Documentation
◆ create()
ossimWebRequest * ossimWebRequestFactoryRegistry::create ( const ossimUrl url)
virtual
Reimplemented from ossimWebRequestFactoryBase.
Definition at line 28 of file ossimWebRequestFactoryRegistry.cpp.
References ossimFactoryListInterface< ossimWebRequestFactoryBase, ossimWebRequest >::m_factoryList.
Referenced by createHttp().
29 {
30  ossim_uint32 idx = 0;
31  ossimWebRequest* result = 0;
32  for(idx = 0; ((idx < m_factoryList.size())&&!result); ++idx)
33  {
34  result = m_factoryList[idx]->create(url);
35  }
36
37  return result;
38 }
unsigned int ossim_uint32
◆ createHttp()
ossimHttpRequest * ossimWebRequestFactoryRegistry::createHttp ( const ossimUrl url)
virtual
Definition at line 40 of file ossimWebRequestFactoryRegistry.cpp.
References create(), ossimRefPtr< T >::get(), ossimRefPtr< T >::release(), and ossimRefPtr< T >::valid().
Referenced by ossimKakaduJpipHandler::allocateSession(), and ossimKakaduJpipHandler::loadClient().
41 {
42  ossimRefPtr<ossimWebRequest> request = create(url);
44  if(request.valid())
45  {
46  result = dynamic_cast<ossimHttpRequest*>(request.get());
47  request = 0;
48  }
49
50  return result.release();
51 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimWebRequest * create(const ossimUrl &url)
T * release()
Definition: ossimRefPtr.h:93
◆ createObject() [1/2]
virtual ossimObject* ossimWebRequestFactoryRegistry::createObject ( const ossimString typeName) const
inlinevirtual
Creates an object given a type name.
Reimplemented from ossimBaseObjectFactory.
Definition at line 26 of file ossimWebRequestFactoryRegistry.h.
References ossimFactoryListInterface< T, NativeType >::createObjectFromRegistry().
27  {
28  return createObjectFromRegistry(typeName);
29  }
ossimObject * createObjectFromRegistry(const ossimString &typeName) const
◆ createObject() [2/2]
ossimObject * ossimWebRequestFactoryRegistry::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Creates and object given a keyword list.
Definition at line 22 of file ossimWebRequestFactoryRegistry.cpp.
References ossimFactoryListInterface< ossimWebRequestFactoryBase, ossimWebRequest >::createObjectFromRegistry().
24 {
25  return createObjectFromRegistry(kwl, prefix);
26 }
◆ getTypeNameList()
virtual void ossimWebRequestFactoryRegistry::getTypeNameList ( std::vector< ossimString > &  typeList) const
inlinevirtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 41 of file ossimWebRequestFactoryRegistry.h.
References ossimFactoryListInterface< T, NativeType >::getAllTypeNamesFromRegistry().
42  {
44  }
void getAllTypeNamesFromRegistry(std::vector< ossimString > &typeList) const
◆ instance()
ossimWebRequestFactoryRegistry * ossimWebRequestFactoryRegistry::instance ( )
static
Member Data Documentation
◆ m_instance
ossimWebRequestFactoryRegistry * ossimWebRequestFactoryRegistry::m_instance = 0
staticprotected
Definition at line 47 of file ossimWebRequestFactoryRegistry.h.
Referenced by instance(), and ossimWebRequestFactoryRegistry().
