Public Member Functions | Static Public Member Functions | List of all members
ossimBaseObjectFactory Class Reference
#include <ossimBaseObjectFactory.h>
Inheritance diagram for ossimBaseObjectFactory:
ossimObjectFactory ossimObject ossimReferenced ossimImageGeometryFactoryBase ossimWebRequestFactoryBase ossimImageGeometryFactory ossimImageGeometryRegistry ossimKakaduJpipImageGeometryFactory ossimWebPluginRequestFactory ossimWebRequestFactoryRegistry
 ossimBaseObjectFactory ()
virtual ~ossimBaseObjectFactory ()
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimBaseObjectFactoryinstance ()
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 14 of file ossimBaseObjectFactory.h.
◆ ossimBaseObjectFactory()
ossimBaseObjectFactory::ossimBaseObjectFactory ( )
Definition at line 18 of file ossimBaseObjectFactory.cpp.
19 {
20
21 }
◆ ~ossimBaseObjectFactory()
virtual ossimBaseObjectFactory::~ossimBaseObjectFactory ( )
inlinevirtual
Definition at line 18 of file ossimBaseObjectFactory.h.
18 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimBaseObjectFactory::createObject ( const ossimString typeName) const
virtual
Creates an object given a type name.
Implements ossimObjectFactory.
Reimplemented in ossimWebRequestFactoryRegistry, and ossimImageGeometryFactoryBase.
Definition at line 30 of file ossimBaseObjectFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createObject().
31 {
33  {
34  return new ossimConnectableContainer;
35  }
36
37  return (ossimObject*)NULL;
38 }
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
◆ createObject() [2/2]
ossimObject * ossimBaseObjectFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Creates and object given a keyword list.
Definition at line 40 of file ossimBaseObjectFactory.cpp.
References ossimString::c_str(), createObject(), ossimKeywordlist::find(), and ossimKeywordNames::TYPE_KW.
42 {
43  const char* type = kwl.find(prefix,
45  ossimString copyPrefix = prefix;
46  if(type)
47  {
48  ossimObject* object = createObject(ossimString(type));
49  if(object)
50  {
51  object->loadState(kwl, copyPrefix.c_str());
52  }
53  return object;
54  }
55  return NULL;
56 }
static const char * TYPE_KW
const char * c_str() const
Definition: ossimString.h:396
virtual ossimObject * createObject(const ossimString &typeName) const
◆ getTypeNameList()
void ossimBaseObjectFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Reimplemented in ossimImageGeometryRegistry, ossimWebRequestFactoryRegistry, ossimImageGeometryFactory, and ossimKakaduJpipImageGeometryFactory.
Definition at line 58 of file ossimBaseObjectFactory.cpp.
59 {
60  typeList.push_back(STATIC_TYPE_NAME(ossimConnectableContainer));
61 }
◆ instance()
ossimBaseObjectFactory * ossimBaseObjectFactory::instance ( )
static
Definition at line 23 of file ossimBaseObjectFactory.cpp.
Referenced by ossimInit::initializeDefaultFactories(), and ossimObjectFactoryRegistry::ossimObjectFactoryRegistry().
24 {
25  static ossimBaseObjectFactory staticInstance;
26
27  return &staticInstance;
28 }
