Classes | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossim::S3StreamBuffer Class Reference
#include <ossimS3StreamBuffer.h>
Inheritance diagram for ossim::S3StreamBuffer:
Classes
class  blockInfo
 S3StreamBuffer (ossim_int64 blockSize=ossim::S3StreamDefaults::m_readBlocksize)
S3StreamBufferopen (const char *connectionString, const ossimKeywordlist &options, std::ios_base::openmode mode)
S3StreamBufferopen (const std::string &connectionString, const ossimKeywordlist &options, std::ios_base::openmode mode)
bool is_open () const
virtual ~S3StreamBuffer ()
ossim_uint64 getFileSize () const
ossim_uint64 getBlockSize () const
virtual pos_type seekoff (off_type offset, std::ios_base::seekdir dir, std::ios_base::openmode __mode=std::ios_base::in|std::ios_base::out)
virtual pos_type seekpos (pos_type pos, std::ios_base::openmode mode=std::ios_base::in|std::ios_base::out)
virtual std::streamsize xsgetn (char_type *s, std::streamsize n)
virtual int underflow ()
void clearAll ()
ossim_int64 getBlockIndex (ossim_int64 byteOffset) const
ossim_int64 getBlockOffset (ossim_int64 byteOffset) const
bool getBlockRangeInBytes (ossim_int64 blockIndex, ossim_int64 &startRange, ossim_int64 &endRange) const
bool loadBlock (ossim_int64 absolutePosition)
ossim_int64 getAbsoluteByteOffset () const
bool withinWindow () const
std::shared_ptr< Aws::S3::S3Client > m_client
std::string m_bucket
std::string m_key
std::vector< char > m_buffer
ossim_int64 m_bufferActualDataSize
ossim_int64 m_currentBlockPosition
char * m_bufferPtr
ossim_int64 m_fileSize
bool m_opened
blockInfo m_blockInfo
Detailed Description
Definition at line 35 of file ossimS3StreamBuffer.h.
◆ S3StreamBuffer()
ossim::S3StreamBuffer::S3StreamBuffer ( ossim_int64  blockSize = ossim::S3StreamDefaults::m_readBlocksize)
Definition at line 50 of file ossimS3StreamBuffer.cpp.
References ossim::AwsStreamFactory::getSharedS3Client(), ossim::AwsStreamFactory::instance(), ossimPreferences::instance(), m_bufferPtr, and m_client.
51  :
52  m_bucket(""),
53  m_key(""),
54  m_buffer(blockSize),
57  m_bufferPtr(0),
58  m_fileSize(0),
59  m_opened(false)
60  //m_mode(0)
61 {
62  Aws::Client::ClientConfiguration config;
63
64  // Look for AWS S3 regionn override:
65  std::string region = ossimPreferences::instance()->
66  preferencesKWL().findKey(std::string("ossim.plugins.aws.s3.region"));
67  if ( region.size() )
68  {
69  config.region = region.c_str();
70  }
72  // m_client = new Aws::S3::S3Client( config );
73
74 // std::cout << "CONSTRUCTED!!!!!" << std::endl;
75 // setp(0);
77 }
static ossimPreferences * instance()
std::shared_ptr< Aws::S3::S3Client > getSharedS3Client() const
static AwsStreamFactory * instance()
◆ ~S3StreamBuffer()
ossim::S3StreamBuffer::~S3StreamBuffer ( )
virtual
Definition at line 79 of file ossimS3StreamBuffer.cpp.
80 {
81 }
Member Function Documentation
◆ clearAll()
void ossim::S3StreamBuffer::clearAll ( )
protected
Definition at line 268 of file ossimS3StreamBuffer.cpp.
269 {
270  m_bucket = "";
271  m_key = "";
272  m_fileSize = 0;
273  m_opened = false;
275  m_blockInfo.setBytes(0,0,0);
276 }
void setBytes(ossim_int64 startByte, ossim_int64 currentByte, ossim_int64 endByte)
◆ getAbsoluteByteOffset()
ossim_int64 ossim::S3StreamBuffer::getAbsoluteByteOffset ( ) const
protected
Definition at line 541 of file ossimS3StreamBuffer.cpp.
542 {
543  ossim_int64 result = -1;
544
545  if(m_currentBlockPosition >= 0)
546  {
547  result = m_blockInfo.getCurrentByte();
548  //result = m_currentBlockPosition;
549  // if(gptr()&&eback())
550  // {
551  // result += (gptr()-eback());
552  // }
553  }
554
555  // std::cout << "RESULT getAbsoluteByteOffset======== " << result << "\n";
556  return result;
557 }
const ossim_int64 & getCurrentByte() const
long long ossim_int64
◆ getBlockIndex()
ossim_int64 ossim::S3StreamBuffer::getBlockIndex ( ossim_int64  byteOffset) const
protected
Definition at line 83 of file ossimS3StreamBuffer.cpp.
84 {
85  ossim_int64 blockNumber = -1;
86
87  if(byteOffset < (ossim_int64)m_fileSize)
88  {
89  if(m_buffer.size()>0)
90  {
91  blockNumber = byteOffset/m_buffer.size();
92  }
93  }
94
95  return blockNumber;
96 }
◆ getBlockOffset()
ossim_int64 ossim::S3StreamBuffer::getBlockOffset ( ossim_int64  byteOffset) const
protected
Definition at line 98 of file ossimS3StreamBuffer.cpp.
99 {
100  ossim_int64 blockOffset = -1;
101
102  if(m_buffer.size()>0)
103  {
104  blockOffset = byteOffset%m_buffer.size();
105  }
106
107  return blockOffset;
108 }
◆ getBlockRangeInBytes()
bool ossim::S3StreamBuffer::getBlockRangeInBytes ( ossim_int64  blockIndex,
ossim_int64 startRange,
ossim_int64 endRange
) const
protected
Definition at line 110 of file ossimS3StreamBuffer.cpp.
113 {
114  bool result = false;
115
116  if(blockIndex >= 0)
117  {
118  startRange = blockIndex*m_buffer.size();
119  endRange = startRange + m_buffer.size()-1;
120
121  result = true;
122  }
123
124  return result;
125 }
◆ getBlockSize()
ossim_uint64 ossim::S3StreamBuffer::getBlockSize ( ) const
Returns
Size of block buffer in bytes.
Definition at line 570 of file ossimS3StreamBuffer.cpp.
Referenced by ossim::S3IStream::getBlockSize().
571 {
572  return m_buffer.size();
573 }
◆ getFileSize()
ossim_uint64 ossim::S3StreamBuffer::getFileSize ( ) const
Returns
Size of file in bytes.
Definition at line 565 of file ossimS3StreamBuffer.cpp.
Referenced by ossim::S3IStream::getFileSize().
566 {
567  return static_cast<ossim_uint32>(m_fileSize);
568 }
unsigned int ossim_uint32
◆ is_open()
bool ossim::S3StreamBuffer::is_open ( ) const
inline
Definition at line 78 of file ossimS3StreamBuffer.h.
References m_opened.
79  {
80  return m_opened;
81  }
◆ loadBlock()
bool ossim::S3StreamBuffer::loadBlock ( ossim_int64  absolutePosition)
protected
Definition at line 127 of file ossimS3StreamBuffer.cpp.
128 {
129  if(traceDebug())
130  {
132  << "ossim::S3StreamBuffer::loadBlock DEBUG: entered with absolute position: " << absolutePosition << "\n";
133
134  }
135  bool result = false;
136  m_bufferPtr = 0;
137  GetObjectRequest getObjectRequest;
138  std::stringstream stringStream;
139  ossim_int64 startRange, endRange;
140  ossim_int64 blockIndex = getBlockIndex(absolutePosition);
141  if((absolutePosition < 0) || (absolutePosition > (ossim_int64)m_fileSize)) return false;
142  //std::cout << "CURRENT BYTE LOCATION = " << absoluteLocation << std::endl;
143  if(getBlockRangeInBytes(blockIndex, startRange, endRange))
144  {
145  stringStream << "bytes=" << startRange << "-" << endRange;
146  getObjectRequest.WithBucket(m_bucket.c_str())
147  .WithKey(m_key.c_str()).WithRange(stringStream.str().c_str());
148  auto getObjectOutcome = m_client->GetObject(getObjectRequest);
149
150  if(getObjectOutcome.IsSuccess())
151  {
152 // std::cout << "GOOD CALL!!!!!!!!!!!!\n";
153  Aws::IOStream& bodyStream = getObjectOutcome.GetResult().GetBody();
154  ossim_int64 bufSize = getObjectOutcome.GetResult().GetContentLength();
155 // std::cout << "SIZE OF RESULT ======== " << bufSize << std::endl;
156  m_bufferActualDataSize = bufSize;
157  bodyStream.read(&m_buffer.front(), bufSize);
158  m_bufferPtr = &m_buffer.front();
159
160  ossim_int64 delta = absolutePosition-startRange;
162  m_blockInfo.setBytes(startRange,startRange+delta,startRange+m_bufferActualDataSize);
163  // std::cout << "LOADING BLOCK: " << m_blockInfo.getStartByte() << ", " << m_blockInfo.getCurrentByte() << ", " << m_blockInfo.getEndByte() << "\n";
164  m_currentBlockPosition = startRange;
165  result = true;
166  //std::cout << "Successfully retrieved object from s3 with value: " << std::endl;
167  //std::cout << getObjectOutcome.GetResult().GetBody().rdbuf() << std::endl << std::endl;;
168  }
169  else
170  {
172  }
173  }
174  if(traceDebug())
175  {
177  << "ossim::S3StreamBuffer::loadBlock DEBUG: leaving with absolutePosition " << absolutePosition << "\n";
178
179  }
180
181  return result;
182 }
bool getBlockRangeInBytes(ossim_int64 blockIndex, ossim_int64 &startRange, ossim_int64 &endRange) const
ossim_int64 getBlockIndex(ossim_int64 byteOffset) const
std::basic_stringstream< char > stringstream
Class for char mixed input and output memory streams.
Definition: ossimIosFwd.h:38
◆ open() [1/2]
ossim::S3StreamBuffer * ossim::S3StreamBuffer::open ( const char *  connectionString,
const ossimKeywordlist options,
Definition at line 184 of file ossimS3StreamBuffer.cpp.
Referenced by ossim::S3IStream::open().
187 {
188  std::string temp(connectionString);
189  return open(temp, options, m);
190 }
S3StreamBuffer * open(const char *connectionString, const ossimKeywordlist &options, std::ios_base::openmode mode)
◆ open() [2/2]
ossim::S3StreamBuffer * ossim::S3StreamBuffer::open ( const std::string &  connectionString,
Definition at line 192 of file ossimS3StreamBuffer.cpp.
195 {
196  if(traceDebug())
197  {
199  << "ossim::S3StreamBuffer::open DEBUG: entered..... with connection " << connectionString << std::endl;
200  }
201  // bool result = false;
202  ossimUrl url(connectionString);
203  clearAll();
204  // m_mode = mode;
206
207  // AWS server is case insensitive:
208  if( (url.getProtocol() == "s3") || (url.getProtocol() == "S3") )
209  {
210  ossim_int64 filesize;
211  m_bucket = url.getIp().c_str();
212  m_key = url.getPath().c_str();
213  if(ossim::S3HeaderCache::instance()->getCachedFilesize(connectionString, filesize))
214  {
215  m_fileSize = filesize;
216  if(m_fileSize >= 0)
217  {
218  m_opened = true;
220  }
221  }
222  else
223  {
224  if(!m_bucket.empty() && !m_key.empty())
225  {
226  HeadObjectRequest headObjectRequest;
227  headObjectRequest.WithBucket(m_bucket.c_str())
228  .WithKey(m_key.c_str());
229  auto headObject = m_client->HeadObject(headObjectRequest);
230  if(headObject.IsSuccess())
231  {
232  m_fileSize = headObject.GetResult().GetContentLength();
233  m_opened = true;
235  ossim::S3HeaderCache::Node_t nodePtr = std::make_shared<ossim::S3HeaderCacheNode>(m_fileSize);
236  ossim::S3HeaderCache::instance()->addHeader(connectionString, nodePtr);
237  }
238  else
239  {
240  m_opened = false;
241  m_fileSize = -1;
243  ossim::S3HeaderCache::Node_t nodePtr = std::make_shared<ossim::S3HeaderCacheNode>(m_fileSize);
244  ossim::S3HeaderCache::instance()->addHeader(connectionString, nodePtr);
245  }
246  }
247  }
248  }
250
251  if(traceDebug())
252  {
253  ossim_float64 delta = ossimTimer::instance()->delta_s(startTimer, endTimer);
254
256  << "ossim::S3StreamBuffer::open DEBUG: Took " << delta << " seconds to open" << std::endl;
258  << "ossim::S3StreamBuffer::open DEBUG: leaving....." << std::endl;
259
260  }
261  if(m_opened) return this;
262
263  return 0;
264 }
std::shared_ptr< S3HeaderCacheNode > Node_t
Definition: S3HeaderCache.h:30
unsigned long long Timer_t
Definition: ossimTimer.h:16
double ossim_float64
static ossimTimer * instance()
Definition: ossimTimer.cpp:19
static std::shared_ptr< S3HeaderCache > instance()
Timer_t tick() const
Get the timers tick value.
Definition: ossimTimer.cpp:95
double delta_s(Timer_t t1, Timer_t t2) const
Get the time in seconds between timer ticks t1 and t2.
Definition: ossimTimer.h:45
◆ seekoff()
ossim::S3StreamBuffer::pos_type ossim::S3StreamBuffer::seekoff ( off_type  offset,
std::ios_base::openmode  __mode = std::ios_base::in | std::ios_base::out
protectedvirtual
Definition at line 309 of file ossimS3StreamBuffer.cpp.
312 {
313  // std::cout <<"ossim::S3StreamBuffer::seekoff type size === " << sizeof(off_type) << std::endl;
314  // std::cout <<"ossim::S3StreamBuffer::seekoff offset ====== " << offset << std::endl;
315  // std::cout << "ossim::S3StreamBuffer::seekoff\n";
316  pos_type result = pos_type(off_type(-1));
317  // bool withinBlock = true;
318  if((mode & std::ios_base::in)&&
319  (mode & std::ios_base::out))
320  {
321  return result;
322  }
323  switch(dir)
324  {
325  case std::ios_base::beg:
326  {
327  ossim_int64 absolutePosition = getAbsoluteByteOffset();
328  // really would like to figure out a better way but for now
329  // we have to have one valid block read in to properly adjust
330  // gptr() with gbump
331  //
332  // if(!gptr())
333  // {
334  // if(!loadBlock(offset))
335  // {
336  // return result;
337  // }
338  // }
339  if((offset <= (ossim_int64)m_fileSize)&&
340  (offset >=0))
341  {
342  result = pos_type(offset);
343  }
344  // if(!gptr())
345  // {
346  // if(!loadBlock(result))
347  // {
348  // return EOF;
349  // }
350  // }
351  //else
352  if(mode & std::ios_base::in)
353  {
354  absolutePosition = getAbsoluteByteOffset();
355  ossim_int64 delta = offset - absolutePosition;
356  setg(eback(), gptr()+delta, egptr());
357  m_blockInfo.setCurrentByte(offset);
358  }
359  // std::cout << "ossim::S3StreamBuffer::seekoff beg RESULT??????????????????? " << result << std::endl;
360  break;
361  }
362  case std::ios_base::cur:
363  {
364  // if(!gptr())
365  // {
366  // // std::cout << "LOADING BLOCK!!!!!!!!!!!!!!\n" << std::endl;
367  // if(!loadBlock(0))
368  // {
369  // return result;
370  // }
371  // }
372  // result = getAbsoluteByteOffset();
373  // std::cout << "INITIAL ABSOLUTE BYTE OFFSET ==== " << result << "\n";
374  if(!offset)
375  {
376  result = getAbsoluteByteOffset();
377  }
378  else
379  {
380  result += offset;
381  setg(eback(), gptr()+offset, egptr());
383  }
384
385  break;
386  }
387  case std::ios_base::end:
388  {
389  ossim_int64 absolutePosition = m_fileSize + offset;
390  // if(!gptr())
391  // {
392  // if(!loadBlock(absolutePosition))
393  // {
394  // return result;
395  // }
396  // }
397  ossim_int64 currentAbsolutePosition = getAbsoluteByteOffset();
398  ossim_int64 delta = absolutePosition-currentAbsolutePosition;
399
400 // std::cout << "CURRENT ABSOLUTE POSITION === " << currentAbsolutePosition << std::endl;
401 // std::cout << "CURRENT ABSOLUTE delta POSITION === " << delta << std::endl;
402  if(mode & std::ios_base::in )
403  {
404  setg(eback(), gptr()+delta, egptr());
405  m_blockInfo.setCurrentByte(absolutePosition);
406  result = absolutePosition;
407  }
408  // std::cout << "ossim::S3StreamBuffer::seekoff end RESULT??????????????????? " << result << std::endl;
409  break;
410  }
411  default:
412  {
413  break;
414  }
415  }
416
417  return result;
418 }
void setCurrentByte(ossim_int64 currentByte)
ossim_int64 getAbsoluteByteOffset() const
◆ seekpos()
ossim::S3StreamBuffer::pos_type ossim::S3StreamBuffer::seekpos ( pos_type  pos,
std::ios_base::openmode  mode = std::ios_base::in | std::ios_base::out
protectedvirtual
Definition at line 420 of file ossimS3StreamBuffer.cpp.
421 {
422  // std::cout << "ossim::S3StreamBuffer::seekpos: " << pos << std::endl;
423  pos_type result = pos_type(off_type(-1));
424  ossim_int64 tempPos = static_cast<ossim_int64>(pos);
425  // Currently we must initialize to a block
426  // if(!gptr())
427  // {
428  // if(!loadBlock(tempPos))
429  // {
430  // return result;
431  // }
432  // }
433  ossim_int64 absoluteLocation = getAbsoluteByteOffset();
434  if(mode & std::ios_base::in)
435  {
436  if((pos >= 0)&&(pos < (ossim_int64)m_fileSize))
437  {
438  m_blockInfo.setCurrentByte(tempPos);
439  ossim_int64 delta = tempPos-absoluteLocation;
440  if(delta)
441  {
442  setg(eback(), gptr()+delta, egptr());
443  }
444  result = pos;
445  }
446  }
447  return result;
448 }
◆ underflow()
int ossim::S3StreamBuffer::underflow ( )
protectedvirtual
Definition at line 279 of file ossimS3StreamBuffer.cpp.
280 {
281  if(!is_open())
282  {
283  return EOF;
284  }
285  else if( !m_blockInfo.withinWindow() )
286  {
287  ossim_int64 absolutePosition = getAbsoluteByteOffset();
288  if(absolutePosition < 0)
289  {
290  return EOF;
291  }
292
293  if(!loadBlock(absolutePosition))
294  {
295  return EOF;
296  }
297  }
298
299  // std::cout << "GPTR CHARACTER ========== "
300  // << (int)static_cast<ossim_uint8>(*gptr()) << std::endl;
301
302  //---
303  // Double cast to get non-negative values so as to not send an inadvertent
304  // EOF(-1) to caller.
305  //---
306  return (int)static_cast<ossim_uint8>(*gptr());
307 }
bool loadBlock(ossim_int64 absolutePosition)
unsigned char ossim_uint8
◆ withinWindow()
bool ossim::S3StreamBuffer::withinWindow ( ) const
protected
Definition at line 559 of file ossimS3StreamBuffer.cpp.
560 {
561  if(!gptr()) return false;
562  return ((gptr()>=eback()) && (gptr()<egptr()));
563 }
◆ xsgetn()
std::streamsize ossim::S3StreamBuffer::xsgetn ( char_type *  s,
std::streamsize  n
protectedvirtual
Definition at line 450 of file ossimS3StreamBuffer.cpp.
References n.
451 {
452  // std::cout << "ossim::S3StreamBuffer::xsgetn" << std::endl;
453
454  if(!is_open()) return EOF;
455  // unsigned long int bytesLeftToRead = egptr()-gptr();
456  // initialize if we need to to load the block at current position
457 // if((!withinWindow())&&is_open())
458  if((!m_blockInfo.withinWindow())&&is_open())
459  {
460  // if(!gptr())
461  // {
462  // if(!loadBlock(0))
463  // {
464  // return EOF;
465  // }
466  // }
467  // else if(!loadBlock(getAbsoluteByteOffset()))
468  // {
469  // return EOF;
470  // }
472  {
473  return EOF;
474  }
475  }
476  ossim_int64 bytesNeedToRead = n;
477  // ossim_int64 bytesToRead = 0;
478  ossim_int64 bytesRead = 0;
479  ossim_int64 currentAbsolutePosition = m_blockInfo.getCurrentByte();//getAbsoluteByteOffset();
480  // ossim_int64 startOffset, endOffset;
481  if(currentAbsolutePosition >= (ossim_int64)m_fileSize)
482  {
483  return EOF;
484  }
485  else if((currentAbsolutePosition + bytesNeedToRead)>(ossim_int64)m_fileSize)
486  {
487  bytesNeedToRead = (m_fileSize - currentAbsolutePosition);
488  }
489
490  while(bytesNeedToRead > 0)
491  {
492  currentAbsolutePosition = m_blockInfo.getCurrentByte();//getAbsoluteByteOffset();
493  //if(!withinWindow())
495  {
497  {
498  return bytesRead;
499  }
500  currentAbsolutePosition = m_blockInfo.getCurrentByte();
501  }
502
503  // get each bloc
504  if(currentAbsolutePosition>=0)
505  {
506  //getBlockRangeInBytes(getBlockIndex(m_currentBlockPosition), startOffset, endOffset);
507
508  ossim_int64 delta = (m_blockInfo.getEndByte()-m_blockInfo.getCurrentByte());//(endOffset - m_currentBlockPosition)+1;
509
510  if(delta <= bytesNeedToRead)
511  {
512
513  std::memcpy(s+bytesRead, gptr(), delta);
514  //m_currentBlockPosition += delta;
515  //setg(eback(), egptr(), egptr());
516  bytesRead+=delta;
517  bytesNeedToRead-=delta;
518  //gbump(delta);
519  setg(eback(), gptr()+delta, egptr());
521  }
522  else
523  {
524  std::memcpy(s+bytesRead, gptr(), bytesNeedToRead);
525  setg(eback(), gptr()+bytesNeedToRead, egptr());
527  //gbump(bytesNeedToRead);
528 // std::cout << "gbump 2 DELTA ========= " << bytesNeedToRead << std::endl;
529  bytesRead+=bytesNeedToRead;
530  bytesNeedToRead=0;
531  }
532  }
533  else
534  {
535  break;
536  }
537  }
538  return std::streamsize(bytesRead);
539 }
const ossim_int64 & getEndByte() const
os2<< "> n<< " > nendobj n
Member Data Documentation
◆ m_blockInfo
blockInfo ossim::S3StreamBuffer::m_blockInfo
protected
Definition at line 128 of file ossimS3StreamBuffer.h.
◆ m_bucket
std::string ossim::S3StreamBuffer::m_bucket
protected
Definition at line 120 of file ossimS3StreamBuffer.h.
◆ m_buffer
std::vector<char> ossim::S3StreamBuffer::m_buffer
protected
Definition at line 122 of file ossimS3StreamBuffer.h.
◆ m_bufferActualDataSize
ossim_int64 ossim::S3StreamBuffer::m_bufferActualDataSize
protected
Definition at line 123 of file ossimS3StreamBuffer.h.
◆ m_bufferPtr
char* ossim::S3StreamBuffer::m_bufferPtr
protected
Definition at line 125 of file ossimS3StreamBuffer.h.
Referenced by S3StreamBuffer().
◆ m_client
std::shared_ptr<Aws::S3::S3Client> ossim::S3StreamBuffer::m_client
mutableprotected
Definition at line 119 of file ossimS3StreamBuffer.h.
◆ m_currentBlockPosition
ossim_int64 ossim::S3StreamBuffer::m_currentBlockPosition
protected
Definition at line 124 of file ossimS3StreamBuffer.h.
◆ m_fileSize
ossim_int64 ossim::S3StreamBuffer::m_fileSize
protected
Definition at line 126 of file ossimS3StreamBuffer.h.
◆ m_key
std::string ossim::S3StreamBuffer::m_key
protected
Definition at line 121 of file ossimS3StreamBuffer.h.
◆ m_opened
bool ossim::S3StreamBuffer::m_opened
protected
Definition at line 127 of file ossimS3StreamBuffer.h.
Referenced by is_open().
