Class for representing a single tiepoint on two or more images. More...
#include <TiePoint.h>
Public Types | |
enum | Type { UNASSIGNED, MANUAL, AUTO, GCP } |
TiePoint () | |
TiePoint (const TiePoint ©) | |
TiePoint (const Json::Value &tp_json_node) | |
Creates new tiepoint from JSON object formatted as: { "id": <unsigned int>="">, // may be ignored if not valid "type": "M"|"A"|"G" For “manual”, “auto”, or “GCP-associated” "imagePoints: [ { "imageId": <string>, "x": <double>, "y": <double>, "covariance": [ cxx, cyy, cxy ], "gcpId": <string> Only if associated with a GCP } ] }. More... | |
virtual | ~TiePoint () |
unsigned int | getImageCount () const |
const std::string & | getTiePointId () const |
void | setTiePointId (const std::string &id) |
void | getImagePoint (unsigned int index, std::string &imageId, ossimDpt &imagePoint, NEWMAT::SymmetricMatrix &cov) const |
Fetches the image point coordinates along with image ID and GCP ID if available. More... | |
void | setImagePoint (std::shared_ptr< Image > image, const ossimDpt &imagePoint, const NEWMAT::SymmetricMatrix &cov) |
Sets image point value and associated measurement covariance for specified image ID. More... | |
Type | getType () const |
void | setType (Type t) |
const std::string & | getGcpId () const |
void | setGcpId (const std::string &id) |
virtual void | loadJSON (const Json::Value &json) |
virtual void | saveJSON (Json::Value &json) const |
virtual std::ostream & | print (std::ostream &out) const |
JsonInterface () | |
virtual | ~JsonInterface () |
Protected Attributes | |
Type | m_type |
std::string | m_tiePointId |
std::vector< std::shared_ptr< Image > > | m_images |
std::vector< ossimDpt > | m_imagePoints |
std::vector< NEWMAT::SymmetricMatrix > | m_covariances |
double | m_gsd |
std::string | m_gcpId |
Static Protected Attributes | |
static int | s_runningId = 1 |
Friends | |
std::ostream & | operator<< (std::ostream &out, const TiePoint &tp) |
It also represents image-points associated with a ground control point.
Definition at line 28 of file TiePoint.h.
Enumerator | |
UNASSIGNED | |
MANUAL | |
AUTO | |
GCP |
Definition at line 32 of file TiePoint.h.
ossim::TiePoint::TiePoint | ( | ) |
Definition at line 18 of file TiePoint.cpp.
ossim::TiePoint::TiePoint | ( | const TiePoint & | copy | ) |
Definition at line 25 of file TiePoint.cpp.
References m_covariances, m_imagePoints, and m_images.
ossim::TiePoint::TiePoint | ( | const Json::Value & | tp_json_node | ) |
Definition at line 40 of file TiePoint.cpp.
References loadJSON().
Definition at line 47 of file TiePoint.cpp.
inline |
inline |
void ossim::TiePoint::getImagePoint | ( | unsigned int | index, |
std::string & | imageId, | ||
ossimDpt & | imagePoint, | ||
NEWMAT::SymmetricMatrix & | cov | ||
) | const |
index | Inout index into the list of images containing this tiepoint |
imageId | Output image ID for the ccorresponding image point |
imagePoint | image coordinates |
cov | image point measurement covariance in (x, y) coordinates |
Definition at line 70 of file TiePoint.cpp.
References m_covariances, m_imagePoints, m_images, and ossimDpt::makeNan().
inline |
inline |
Implements ossim::JsonInterface.
Definition at line 126 of file TiePoint.cpp.
References AUTO, GCP, m_covariances, m_gcpId, m_imagePoints, m_images, m_type, MANUAL, and setTiePointId().
Referenced by TiePoint().
Reimplemented in ATP::AutoTiePoint.
Definition at line 239 of file TiePoint.cpp.
References saveJSON().
Definition at line 195 of file TiePoint.cpp.
References AUTO, GCP, m_covariances, m_imagePoints, m_images, m_tiePointId, m_type, and MANUAL.
Referenced by print().
void ossim::TiePoint::setGcpId | ( | const std::string & | id | ) |
Definition at line 120 of file TiePoint.cpp.
References GCP, m_gcpId, and m_type.
void ossim::TiePoint::setImagePoint | ( | std::shared_ptr< Image > | image, |
const ossimDpt & | imagePoint, | ||
const NEWMAT::SymmetricMatrix & | cov | ||
If the image ID is not found, it will be added as new observation.
Definition at line 88 of file TiePoint.cpp.
void ossim::TiePoint::setTiePointId | ( | const std::string & | id | ) |
Definition at line 54 of file TiePoint.cpp.
References m_tiePointId, and s_runningId.
Referenced by loadJSON().
inline |
friend |
Definition at line 108 of file TiePoint.h.
protected |
Definition at line 117 of file TiePoint.h.
Referenced by getImagePoint(), loadJSON(), saveJSON(), setImagePoint(), TiePoint(), and ~TiePoint().
protected |
Definition at line 119 of file TiePoint.h.
Referenced by getGcpId(), loadJSON(), and setGcpId().
protected |
Definition at line 118 of file TiePoint.h.
protected |
Definition at line 116 of file TiePoint.h.
Referenced by ATP::AutoTiePoint::addImageMatch(), ATP::AutoTiePoint::getCmpImagePoint(), getImagePoint(), ATP::AutoTiePoint::getRefImagePoint(), loadJSON(), ATP::AutoTiePoint::print(), ATP::AutoTiePoint::recomputeResidual(), saveJSON(), setImagePoint(), ATP::AutoTiePoint::setRefImagePt(), ATP::AutoTiePoint::setRefViewPt(), TiePoint(), and ~TiePoint().
protected |
Definition at line 115 of file TiePoint.h.
Referenced by getImageCount(), getImagePoint(), loadJSON(), saveJSON(), setImagePoint(), TiePoint(), and ~TiePoint().
protected |
Definition at line 114 of file TiePoint.h.
Referenced by getTiePointId(), ATP::AutoTiePoint::print(), saveJSON(), and setTiePointId().
protected |
Definition at line 113 of file TiePoint.h.
Referenced by getType(), loadJSON(), saveJSON(), setGcpId(), and setType().
staticprotected |
Definition at line 120 of file TiePoint.h.
Referenced by setTiePointId().
