Public Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::AlosPalsarFacilityData Class Reference
This class is able to read the SAR leader data set summary record of the leader file. More...
#include <AlosPalsarFacilityData.h>
Inheritance diagram for ossimplugins::AlosPalsarFacilityData:
ossimplugins::AlosPalsarRecord
 AlosPalsarFacilityData ()
 Constructor. More...
virtual ~AlosPalsarFacilityData ()
 Destructor. More...
 AlosPalsarFacilityData (const AlosPalsarFacilityData &rhs)
 Copy constructor. More...
AlosPalsarFacilityDataoperator= (const AlosPalsarFacilityData &rhs)
 Copy operator. More...
AlosPalsarRecordInstanciate ()
 This function is able to create a new instance of the class. More...
AlosPalsarRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Read the class data from a stream. More...
void Write (std::ostream &os)
 Write the class to a stream. More...
std::string get_name_of_facil_rec () const
 name_of_facil_rec More...
std::string get_last_release_qc_date () const
 last_release_qc_date More...
std::string get_last_release_cal_date () const
 last_release_cal_date More...
int get_qa_summary_flag () const
 qa_summary_flag More...
int get_prf_code_change_flag () const
 prf_code_change_flag More...
int get_sampling_win_change_flag () const
 sampling_win_change_flag More...
int get_cal_gain_change_flag () const
 cal_gain_change_flag More...
int get_quirp_qu_flag () const
 quirp_qu_flag More...
int get_inp_data_stat_flag () const
 inp_data_stat_flag More...
int get_dopp_cent_conf_meas_flag () const
 dopp_cent_conf_meas_flag More...
int get_dopp_cent_val_flag () const
 dopp_cent_val_flag More...
int get_dopp_ambig_conf_meas_flag () const
 dopp_ambig_conf_meas_flag More...
int get_outp_data_mean_flag () const
 outp_data_mean_flag More...
int get_OGOB_flag ()
 OGOB_flag. More...
int get_PRF_changes ()
 PRF_changes. More...
int get_sampling_win_changes () const
 sampling_win_changes More...
int get_cal_gain_changes () const
 cal_gain_changes More...
int get_missing_lines () const
 missing_lines More...
int get_rec_gain_changes () const
 rec_gain_changes More...
double get_pulse_width_of_ACF_3db ()
 pulse_width_of_ACF_3db More...
double get_first_side_lobe_lev_of_ACF ()
 first_side_lobe_lev_of_ACF More...
double get_ISLR_of_ACF ()
 ISLR_of_ACF. More...
double get_dopp_cent_conf_meas () const
 dopp_cent_conf_meas More...
double get_dopp_ambig_conf_meas () const
 dopp_ambig_conf_meas More...
double get_inp_data_I_mean ()
 inp_data_I_mean More...
double get_inp_data_Q_mean ()
 inp_data_Q_mean More...
double get_inp_data_I_stddev ()
 inp_data_I_stddev More...
double get_inp_data_Q_stddev ()
 inp_data_Q_stddev More...
double get_cal_sys_gain () const
 cal_sys_gain More...
double get_first_rec_gain_read () const
 first_rec_gain_read More...
double get_dopp_ambig_num () const
 dopp_ambig_num More...
double get_I_channel_bias_correction ()
 I_channel_bias_correction. More...
double get_Q_channel_bias_correction ()
 Q_channel_bias_correction. More...
double get_I_channel_gain_correction ()
 I_channel_gain_correction. More...
double get_Q_channel_gain_correction ()
 Q_channel_gain_correction. More...
double get_Q_channel_I_Q_correction ()
 Q_channel_I_Q_correction. More...
double get_noise_power () const
 noise_power More...
int get_int_cal_utc () const
 int_cal_utc More...
int get_num_valid_cal_pulses () const
 num_valid_cal_pulses More...
int get_num_valid_noise_pulses () const
 num_valid_noise_pulses More...
int get_num_valid_replicas () const
 num_valid_replicas More...
double get_first_replica_sample () const
 first_replica_sample More...
double get_mean_cal_pulse_power () const
 mean_cal_pulse_power More...
double get_mean_noise_power () const
 mean_noise_power More...
double get_range_comp_norm_fact () const
 range_comp_norm_fact More...
double get_replica_power () const
 replica_power More...
double get_first_range_pixel_mid_az_inc () const
 first_range_pixel_mid_az_inc More...
double get_center_range_pix_mid_az_inc () const
 center_range_pix_mid_az_inc More...
double get_last_range_pix_mid_az_inc () const
 last_range_pix_mid_az_inc More...
double get_norm_ref_range_ro () const
 norm_ref_range_ro More...
int get_antenna_elev_flag () const
 antenna_elev_flag More...
double get_abs_cal_const_K ()
 abs_cal_const_K More...
double get_upp_bound_K ()
 upp_bound_K More...
double get_low_bound_K ()
 low_bound_K More...
double get_proc_noise_scale_fact () const
 proc_noise_scale_fact More...
std::string get_K_gen_date ()
 K_gen_date. More...
std::string get_K_vers_num ()
 K_vers_num. More...
int get_num_duplic_input_lines () const
 num_duplic_input_lines More...
double get_estim_bit_error_rate () const
 estim_bit_error_rate More...
double get_out_image_mean () const
 out_image_mean More...
double get_out_image_std_dev () const
 out_image_std_dev More...
double get_out_image_max_value () const
 out_image_max_value More...
std::string get_time_raw_data_first_input () const
 time_raw_data_first_input More...
std::string get_time_asc_node_state_vectors () const
 time_asc_node_state_vectors More...
std::string get_asc_node_pos_X_comp ()
 asc_node_pos_X_comp More...
std::string get_asc_node_pos_Y_comp ()
 asc_node_pos_Y_comp More...
std::string get_asc_node_pos_Z_comp ()
 asc_node_pos_Z_comp More...
std::string get_asc_node_vel_X_comp ()
 asc_node_vel_X_comp More...
std::string get_asc_node_vel_Y_comp ()
 asc_node_vel_Y_comp More...
std::string get_asc_node_vel_Z_comp ()
 asc_node_vel_Z_comp More...
int get_out_pixel_bit_length () const
 out_pixel_bit_length More...
double get_proc_gain_param_1 ()
 proc_gain_param_1 More...
double get_proc_gain_param_2 ()
 proc_gain_param_2 More...
double get_proc_gain_param_3 ()
 proc_gain_param_3 More...
int get_peak_loc_cross_correl_fun () const
 peak_loc_cross_correl_fun More...
double get_3_dB_width_CCF ()
 3_dB_width_CCF More...
double get_first_side_lobe_level () const
 first_side_lobe_level More...
double get_ISLR_CCF_between_last ()
 ISLR_CCF_between_last. More...
int get_peak_loc_CCF_betw_last ()
 peak_loc_CCF_betw_last More...
int get_Roll_Tilt_Mode_flag ()
 Roll_Tilt_Mode_flag. More...
int get_raw_data_correction_flag () const
 raw_data_correction_flag More...
int get_look_detecion_flag () const
 look_detecion_flag More...
int get_doppler_ambiguity_estimat_flag () const
 doppler_ambiguity_estimat_flag More...
int get_azimuth_baseband_convers_flag () const
 azimuth_baseband_convers_flag More...
int get_samples_per_line_used () const
 samples_per_line_used More...
int get_range_lines_skip_factor () const
 range_lines_skip_factor More...
std::string get_time_of_inp_state_vectors () const
 time_of_inp_state_vectors More...
std::string get_inp_state_vect_pos_X_comp ()
 inp_state_vect_pos_X_comp More...
std::string get_inp_state_vect_pos_Y_comp ()
 inp_state_vect_pos_Y_comp More...
std::string get_inp_state_vect_pos_Z_comp ()
 inp_state_vect_pos_Z_comp More...
std::string get_inp_state_vect_vel_Vx_comp ()
 inp_state_vect_vel_Vx_comp More...
std::string get_inp_state_vect_vel_Vy_comp ()
 inp_state_vect_vel_Vy_comp More...
std::string get_inp_state_vect_vel_Vz_comp ()
 inp_state_vect_vel_Vz_comp More...
int get_inp_state_vector_type_flag () const
 inp_state_vector_type_flag More...
double get_win_coeff_for_range_match () const
 win_coeff_for_range_match More...
double get_win_coeff_for_azi_match () const
 win_coeff_for_azi_match More...
int get_update_period_range_match () const
 update_period_range_match More...
double get_look_scalar_gain_1 ()
 look_scalar_gain_1 More...
double get_look_scalar_gain_2 ()
 look_scalar_gain_2 More...
double get_look_scalar_gain_3 ()
 look_scalar_gain_3 More...
double get_look_scalar_gain_4 ()
 look_scalar_gain_4 More...
double get_look_scalar_gain_5 ()
 look_scalar_gain_5 More...
double get_look_scalar_gain_6 ()
 look_scalar_gain_6 More...
double get_look_scalar_gain_7 ()
 look_scalar_gain_7 More...
double get_look_scalar_gain_8 ()
 look_scalar_gain_8 More...
int get_samp_window_start_time_bias () const
 samp_window_start_time_bias More...
double get_doppler_centroid_cubic_coeff () const
 doppler_centroid_cubic_coeff More...
int get_PRF_code_first_range_line ()
 PRF_code_first_range_line. More...
int get_PRF_code_last_range_line ()
 PRF_code_last_range_line. More...
int get_samp_win_start_first () const
 samp_win_start_first More...
int get_samp_win_start_last () const
 samp_win_start_last More...
int get_cal_syst_gain_last_proc () const
 cal_syst_gain_last_proc More...
int get_receiver_gain_last_proc () const
 receiver_gain_last_proc More...
int get_first_processed_range_sample () const
 first_processed_range_sample More...
int get_azimuth_FFT_IFFT_ratio ()
 azimuth_FFT_IFFT_ratio More...
int get_num_azimuth_blocks_proc () const
 num_azimuth_blocks_proc More...
int get_num_input_raw_data_lines () const
 num_input_raw_data_lines More...
int get_initial_doppler_ambiguity_num () const
 initial_doppler_ambiguity_num More...
double get_thresh_no_1_flag ()
 thresh_no_1_flag More...
double get_thresh_no_2_flag ()
 thresh_no_2_flag More...
double get_thresh_no_3_flag ()
 thresh_no_3_flag More...
double get_thresh_no_4_flag ()
 thresh_no_4_flag More...
double get_thresh_no_5_flag ()
 thresh_no_5_flag More...
double get_thresh_no_6_flag ()
 thresh_no_6_flag More...
double get_thresh_no_7_flag ()
 thresh_no_7_flag More...
double get_thresh_no_8_flag ()
 thresh_no_8_flag More...
double get_thresh_no_9_flag ()
 thresh_no_9_flag More...
double get_thresh_no_10_flag ()
 thresh_no_10_flag More...
double get_thresh_no_11_flag ()
 thresh_no_11_flag More...
int get_sat_binary_time_of_first () const
 sat_binary_time_of_first More...
int get_num_valid_pixels_per_range () const
 num_valid_pixels_per_range More...
int get_num_range_samp_discarded () const
 num_range_samp_discarded More...
double get_I_gain_imb_lower_bound ()
 I_gain_imb_lower_bound. More...
double get_I_gain_imb_upper_bound ()
 I_gain_imb_upper_bound. More...
double get_I_Q_quad_depar_lower_bound ()
 I_Q_quad_depar_lower_bound. More...
double get_I_Q_quad_depar_upper_bound ()
 I_Q_quad_depar_upper_bound. More...
double get_3_dB_look_bandwidth ()
 3_dB_look_bandwidth More...
double get_3_dB_look_proc_dopp_bandw ()
 3_dB_look_proc_dopp_bandw More...
int get_range_spread_loss_comp_flag () const
 range_spread_loss_comp_flag More...
bool get_datation_flag () const
 datation_flag More...
int get_max_error_range_line_timing () const
 max_error_range_line_timing More...
int get_form_num_range_line_used () const
 form_num_range_line_used More...
bool get_autom_look_scal_gain_flag () const
 autom_look_scal_gain_flag More...
int get_max_value_look_scalar_gain () const
 max_value_look_scalar_gain More...
int get_replica_norm_method_flag () const
 replica_norm_method_flag More...
double get_coef_ground_range_1 () const
 coef_ground_range_1 More...
double get_coef_ground_range_2 () const
 coef_ground_range_2 More...
double get_coef_ground_range_3 () const
 coef_ground_range_3 More...
double get_coef_ground_range_4 () const
 coef_ground_range_4 More...
double get_coef_ant_elev_1 () const
 coef_ant_elev_1 More...
double get_coef_ant_elev_2 () const
 coef_ant_elev_2 More...
double get_coef_ant_elev_3 () const
 coef_ant_elev_3 More...
double get_coef_ant_elev_4 () const
 coef_ant_elev_4 More...
double get_coef_ant_elev_5 () const
 coef_ant_elev_5 More...
double get_range_time_origin_ant () const
 range_time_origin_ant More...
- Public Member Functions inherited from ossimplugins::AlosPalsarRecord
 AlosPalsarRecord (std::string mnemonic)
virtual ~AlosPalsarRecord ()
 Destructor. More...
 AlosPalsarRecord (const AlosPalsarRecord &rhs)
std::string get_mnemonic ()
std::string _name_of_facil_rec
std::string _last_release_qc_date
std::string _last_release_cal_date
int _qa_summary_flag
int _prf_code_change_flag
int _sampling_win_change_flag
int _cal_gain_change_flag
int _quirp_qu_flag
int _inp_data_stat_flag
int _dopp_cent_conf_meas_flag
int _dopp_cent_val_flag
int _dopp_ambig_conf_meas_flag
int _outp_data_mean_flag
int _OGOB_flag
 OGOB_flag. More...
int _PRF_changes
int _sampling_win_changes
int _cal_gain_changes
int _missing_lines
int _rec_gain_changes
double _pulse_width_of_ACF_3db
double _first_side_lobe_lev_of_ACF
double _ISLR_of_ACF
double _dopp_cent_conf_meas
double _dopp_ambig_conf_meas
double _inp_data_I_mean
double _inp_data_Q_mean
double _inp_data_I_stddev
double _inp_data_Q_stddev
double _cal_sys_gain
double _first_rec_gain_read
double _dopp_ambig_num
double _I_channel_bias_correction
double _Q_channel_bias_correction
double _I_channel_gain_correction
double _Q_channel_gain_correction
double _Q_channel_I_Q_correction
double _noise_power
 noise_power More...
int _int_cal_utc
 int_cal_utc More...
int _num_valid_cal_pulses
int _num_valid_noise_pulses
int _num_valid_replicas
double _first_replica_sample
double _mean_cal_pulse_power
double _mean_noise_power
double _range_comp_norm_fact
double _replica_power
double _first_range_pixel_mid_az_inc
double _center_range_pix_mid_az_inc
double _last_range_pix_mid_az_inc
double _norm_ref_range_ro
int _antenna_elev_flag
double _abs_cal_const_K
double _upp_bound_K
 upp_bound_K More...
double _low_bound_K
 low_bound_K More...
double _proc_noise_scale_fact
std::string _K_gen_date
 K_gen_date. More...
std::string _K_vers_num
 K_vers_num. More...
int _num_duplic_input_lines
double _estim_bit_error_rate
double _out_image_mean
double _out_image_std_dev
double _out_image_max_value
std::string _time_raw_data_first_input
std::string _time_asc_node_state_vectors
std::string _asc_node_pos_X_comp
std::string _asc_node_pos_Y_comp
std::string _asc_node_pos_Z_comp
std::string _asc_node_vel_X_comp
std::string _asc_node_vel_Y_comp
std::string _asc_node_vel_Z_comp
int _out_pixel_bit_length
double _proc_gain_param_1
double _proc_gain_param_2
double _proc_gain_param_3
int _peak_loc_cross_correl_fun
double _3_dB_width_CCF
double _first_side_lobe_level
double _ISLR_CCF_between_last
int _peak_loc_CCF_betw_last
int _Roll_Tilt_Mode_flag
int _raw_data_correction_flag
int _look_detecion_flag
int _doppler_ambiguity_estimat_flag
int _azimuth_baseband_convers_flag
int _samples_per_line_used
int _range_lines_skip_factor
std::string _time_of_inp_state_vectors
std::string _inp_state_vect_pos_X_comp
std::string _inp_state_vect_pos_Y_comp
std::string _inp_state_vect_pos_Z_comp
std::string _inp_state_vect_vel_Vx_comp
std::string _inp_state_vect_vel_Vy_comp
std::string _inp_state_vect_vel_Vz_comp
int _inp_state_vector_type_flag
double _win_coeff_for_range_match
double _win_coeff_for_azi_match
int _update_period_range_match
double _look_scalar_gain_1
double _look_scalar_gain_2
double _look_scalar_gain_3
double _look_scalar_gain_4
double _look_scalar_gain_5
double _look_scalar_gain_6
double _look_scalar_gain_7
double _look_scalar_gain_8
int _samp_window_start_time_bias
double _doppler_centroid_cubic_coeff
int _PRF_code_first_range_line
int _PRF_code_last_range_line
int _samp_win_start_first
int _samp_win_start_last
int _cal_syst_gain_last_proc
int _receiver_gain_last_proc
int _first_processed_range_sample
int _azimuth_FFT_IFFT_ratio
int _num_azimuth_blocks_proc
int _num_input_raw_data_lines
int _initial_doppler_ambiguity_num
double _thresh_no_1_flag
double _thresh_no_2_flag
double _thresh_no_3_flag
double _thresh_no_4_flag
double _thresh_no_5_flag
double _thresh_no_6_flag
double _thresh_no_7_flag
double _thresh_no_8_flag
double _thresh_no_9_flag
double _thresh_no_10_flag
double _thresh_no_11_flag
int _sat_binary_time_of_first
int _num_valid_pixels_per_range
int _num_range_samp_discarded
double _I_gain_imb_lower_bound
double _I_gain_imb_upper_bound
double _I_Q_quad_depar_lower_bound
double _I_Q_quad_depar_upper_bound
double _3_dB_look_bandwidth
double _3_dB_look_proc_dopp_bandw
int _range_spread_loss_comp_flag
bool _datation_flag
int _max_error_range_line_timing
int _form_num_range_line_used
bool _autom_look_scal_gain_flag
int _max_value_look_scalar_gain
int _replica_norm_method_flag
double _coef_ground_range_1
double _coef_ground_range_2
double _coef_ground_range_3
double _coef_ground_range_4
double _coef_ant_elev_1
double _coef_ant_elev_2
double _coef_ant_elev_3
double _coef_ant_elev_4
double _coef_ant_elev_5
double _range_time_origin_ant
- Protected Attributes inherited from ossimplugins::AlosPalsarRecord
std::string _mnemonic
Friends
std::ostream & operator<< (std::ostream &os, const AlosPalsarFacilityData &data)
 This function write the AlosPalsarFacilityData in a stream. More...
std::istream & operator>> (std::istream &is, AlosPalsarFacilityData &data)
 This function read a AlosPalsarFacilityData from a stream. More...
Detailed Description
Definition at line 28 of file AlosPalsarFacilityData.h.
◆ AlosPalsarFacilityData() [1/2]
ossimplugins::AlosPalsarFacilityData::AlosPalsarFacilityData ( )
Constructor.
Definition at line 18 of file AlosPalsarFacilityData.cpp.
Referenced by Clone(), and Instanciate().
18  : AlosPalsarRecord("facility_data_rec")
19  {
20  }
AlosPalsarRecord(std::string mnemonic)
Constructor.
◆ ~AlosPalsarFacilityData()
ossimplugins::AlosPalsarFacilityData::~AlosPalsarFacilityData ( )
virtual
Destructor.
Definition at line 22 of file AlosPalsarFacilityData.cpp.
23  {
24  }
◆ AlosPalsarFacilityData() [2/2]
ossimplugins::AlosPalsarFacilityData::AlosPalsarFacilityData ( const AlosPalsarFacilityData rhs)
Copy constructor.
Definition at line 850 of file AlosPalsarFacilityData.cpp.
850  :
851  AlosPalsarRecord(rhs),
852  _last_release_qc_date(rhs._last_release_qc_date),
853  _last_release_cal_date(rhs._last_release_cal_date),
854  _qa_summary_flag(rhs._qa_summary_flag),
855  _prf_code_change_flag(rhs._prf_code_change_flag),
856  _sampling_win_change_flag(rhs._sampling_win_change_flag),
857  _cal_gain_change_flag(rhs._cal_gain_change_flag),
858  _quirp_qu_flag(rhs._quirp_qu_flag),
859  _inp_data_stat_flag(rhs._inp_data_stat_flag),
860  _dopp_cent_conf_meas_flag(rhs._dopp_cent_conf_meas_flag),
861  _dopp_cent_val_flag(rhs._dopp_cent_val_flag),
862  _dopp_ambig_conf_meas_flag(rhs._dopp_ambig_conf_meas_flag),
863  _outp_data_mean_flag(rhs._outp_data_mean_flag),
864  _OGOB_flag(rhs._OGOB_flag),
865  _PRF_changes(rhs._PRF_changes),
866  _sampling_win_changes(rhs._sampling_win_changes),
867  _cal_gain_changes(rhs._cal_gain_changes),
868  _missing_lines(rhs._missing_lines),
869  _rec_gain_changes(rhs._rec_gain_changes),
870  _pulse_width_of_ACF_3db(rhs._pulse_width_of_ACF_3db),
871  _first_side_lobe_lev_of_ACF(rhs._first_side_lobe_lev_of_ACF),
872  _ISLR_of_ACF(rhs._ISLR_of_ACF),
873  _dopp_cent_conf_meas(rhs._dopp_cent_conf_meas),
874  _dopp_ambig_conf_meas(rhs._dopp_ambig_conf_meas),
875  _inp_data_I_mean(rhs._inp_data_I_mean),
876  _inp_data_Q_mean(rhs._inp_data_Q_mean),
877  _inp_data_I_stddev(rhs._inp_data_I_stddev),
878  _inp_data_Q_stddev(rhs._inp_data_Q_stddev),
879  _cal_sys_gain(rhs._cal_sys_gain),
880  _first_rec_gain_read(rhs._first_rec_gain_read),
881  _dopp_ambig_num(rhs._dopp_ambig_num),
882  _I_channel_bias_correction(rhs._I_channel_bias_correction),
883  _Q_channel_bias_correction(rhs._Q_channel_bias_correction),
884  _I_channel_gain_correction(rhs._I_channel_gain_correction),
885  _Q_channel_gain_correction(rhs._Q_channel_gain_correction),
886  _Q_channel_I_Q_correction(rhs._Q_channel_I_Q_correction),
887  _noise_power(rhs._noise_power),
888  _int_cal_utc(rhs._int_cal_utc),
889  _num_valid_cal_pulses(rhs._num_valid_cal_pulses),
890  _num_valid_noise_pulses(rhs._num_valid_noise_pulses),
891  _num_valid_replicas(rhs._num_valid_replicas),
892  _first_replica_sample(rhs._first_replica_sample),
893  _mean_cal_pulse_power(rhs._mean_cal_pulse_power),
894  _mean_noise_power(rhs._mean_noise_power),
895  _range_comp_norm_fact(rhs._range_comp_norm_fact),
896  _replica_power(rhs._replica_power),
897  _first_range_pixel_mid_az_inc(rhs._first_range_pixel_mid_az_inc),
898  _center_range_pix_mid_az_inc(rhs._center_range_pix_mid_az_inc),
899  _last_range_pix_mid_az_inc(rhs._last_range_pix_mid_az_inc),
900  _norm_ref_range_ro(rhs._norm_ref_range_ro),
901  _antenna_elev_flag(rhs._antenna_elev_flag),
902  _abs_cal_const_K(rhs._abs_cal_const_K),
903  _upp_bound_K(rhs._upp_bound_K),
904  _low_bound_K(rhs._low_bound_K),
905  _proc_noise_scale_fact(rhs._proc_noise_scale_fact),
906  _K_gen_date(rhs._K_gen_date),
907  _K_vers_num(rhs._K_vers_num),
908  _num_duplic_input_lines(rhs._num_duplic_input_lines),
909  _estim_bit_error_rate(rhs._estim_bit_error_rate),
910  _out_image_mean(rhs._out_image_mean),
911  _out_image_std_dev(rhs._out_image_std_dev),
912  _out_image_max_value(rhs._out_image_max_value),
913  _time_raw_data_first_input(rhs._time_raw_data_first_input),
914  _time_asc_node_state_vectors(rhs._time_asc_node_state_vectors),
915  _asc_node_pos_X_comp(rhs._asc_node_pos_X_comp),
916  _asc_node_pos_Y_comp(rhs._asc_node_pos_Y_comp),
917  _asc_node_pos_Z_comp(rhs._asc_node_pos_Z_comp),
918  _asc_node_vel_X_comp(rhs._asc_node_vel_X_comp),
919  _asc_node_vel_Y_comp(rhs._asc_node_vel_Y_comp),
920  _asc_node_vel_Z_comp(rhs._asc_node_vel_Z_comp),
921  _out_pixel_bit_length(rhs._out_pixel_bit_length),
922  _proc_gain_param_1(rhs._proc_gain_param_1),
923  _proc_gain_param_2(rhs._proc_gain_param_2),
924  _proc_gain_param_3(rhs._proc_gain_param_3),
925  _peak_loc_cross_correl_fun(rhs._peak_loc_cross_correl_fun),
926  _3_dB_width_CCF(rhs._3_dB_width_CCF),
927  _first_side_lobe_level(rhs._first_side_lobe_level),
928  _ISLR_CCF_between_last(rhs._ISLR_CCF_between_last),
929  _peak_loc_CCF_betw_last(rhs._peak_loc_CCF_betw_last),
930  _Roll_Tilt_Mode_flag(rhs._Roll_Tilt_Mode_flag),
931  _raw_data_correction_flag(rhs._raw_data_correction_flag),
932  _look_detecion_flag(rhs._look_detecion_flag),
933  _doppler_ambiguity_estimat_flag(rhs._doppler_ambiguity_estimat_flag),
934  _azimuth_baseband_convers_flag(rhs._azimuth_baseband_convers_flag),
935  _samples_per_line_used(rhs._samples_per_line_used),
936  _range_lines_skip_factor(rhs._range_lines_skip_factor),
937  _time_of_inp_state_vectors(rhs._time_of_inp_state_vectors),
938  _inp_state_vect_pos_X_comp(rhs._inp_state_vect_pos_X_comp),
939  _inp_state_vect_pos_Y_comp(rhs._inp_state_vect_pos_Y_comp),
940  _inp_state_vect_pos_Z_comp(rhs._inp_state_vect_pos_Z_comp),
941  _inp_state_vect_vel_Vx_comp(rhs._inp_state_vect_vel_Vx_comp),
942  _inp_state_vect_vel_Vy_comp(rhs._inp_state_vect_vel_Vy_comp),
943  _inp_state_vect_vel_Vz_comp(rhs._inp_state_vect_vel_Vz_comp),
944  _inp_state_vector_type_flag(rhs._inp_state_vector_type_flag),
945  _win_coeff_for_range_match(rhs._win_coeff_for_range_match),
946  _win_coeff_for_azi_match(rhs._win_coeff_for_azi_match),
947  _update_period_range_match(rhs._update_period_range_match),
948  _look_scalar_gain_1(rhs._look_scalar_gain_1),
949  _look_scalar_gain_2(rhs._look_scalar_gain_2),
950  _look_scalar_gain_3(rhs._look_scalar_gain_3),
951  _look_scalar_gain_4(rhs._look_scalar_gain_4),
952  _look_scalar_gain_5(rhs._look_scalar_gain_5),
953  _look_scalar_gain_6(rhs._look_scalar_gain_6),
954  _look_scalar_gain_7(rhs._look_scalar_gain_7),
955  _look_scalar_gain_8(rhs._look_scalar_gain_8),
956  _samp_window_start_time_bias(rhs._samp_window_start_time_bias),
957  _doppler_centroid_cubic_coeff(rhs._doppler_centroid_cubic_coeff),
958  _PRF_code_first_range_line(rhs._PRF_code_first_range_line),
959  _PRF_code_last_range_line(rhs._PRF_code_last_range_line),
960  _samp_win_start_first(rhs._samp_win_start_first),
961  _samp_win_start_last(rhs._samp_win_start_last),
962  _cal_syst_gain_last_proc(rhs._cal_syst_gain_last_proc),
963  _receiver_gain_last_proc(rhs._receiver_gain_last_proc),
964  _first_processed_range_sample(rhs._first_processed_range_sample),
965  _azimuth_FFT_IFFT_ratio(rhs._azimuth_FFT_IFFT_ratio),
966  _num_azimuth_blocks_proc(rhs._num_azimuth_blocks_proc),
967  _num_input_raw_data_lines(rhs._num_input_raw_data_lines),
968  _initial_doppler_ambiguity_num(rhs._initial_doppler_ambiguity_num),
969  _thresh_no_1_flag(rhs._thresh_no_1_flag),
970  _thresh_no_2_flag(rhs._thresh_no_2_flag),
971  _thresh_no_3_flag(rhs._thresh_no_3_flag),
972  _thresh_no_4_flag(rhs._thresh_no_4_flag),
973  _thresh_no_5_flag(rhs._thresh_no_5_flag),
974  _thresh_no_6_flag(rhs._thresh_no_6_flag),
975  _thresh_no_7_flag(rhs._thresh_no_7_flag),
976  _thresh_no_8_flag(rhs._thresh_no_8_flag),
977  _thresh_no_9_flag(rhs._thresh_no_9_flag),
978  _thresh_no_10_flag(rhs._thresh_no_10_flag),
979  _thresh_no_11_flag(rhs._thresh_no_11_flag),
980  _sat_binary_time_of_first(rhs._sat_binary_time_of_first),
981  _num_valid_pixels_per_range(rhs._num_valid_pixels_per_range),
982  _num_range_samp_discarded(rhs._num_range_samp_discarded),
983  _I_gain_imb_lower_bound(rhs._I_gain_imb_lower_bound),
984  _I_gain_imb_upper_bound(rhs._I_gain_imb_upper_bound),
985  _I_Q_quad_depar_lower_bound(rhs._I_Q_quad_depar_lower_bound),
986  _I_Q_quad_depar_upper_bound(rhs._I_Q_quad_depar_upper_bound),
987  _3_dB_look_bandwidth(rhs._3_dB_look_bandwidth),
988  _3_dB_look_proc_dopp_bandw(rhs._3_dB_look_proc_dopp_bandw),
989  _range_spread_loss_comp_flag(rhs._range_spread_loss_comp_flag),
990  _datation_flag(rhs._datation_flag),
991  _max_error_range_line_timing(rhs._max_error_range_line_timing),
992  _form_num_range_line_used(rhs._form_num_range_line_used),
993  _autom_look_scal_gain_flag(rhs._autom_look_scal_gain_flag),
994  _max_value_look_scalar_gain(rhs._max_value_look_scalar_gain),
995  _replica_norm_method_flag(rhs._replica_norm_method_flag),
996  _coef_ground_range_1(rhs._coef_ground_range_1),
997  _coef_ground_range_2(rhs._coef_ground_range_2),
998  _coef_ground_range_3(rhs._coef_ground_range_3),
999  _coef_ground_range_4(rhs._coef_ground_range_4),
1000  _coef_ant_elev_1(rhs._coef_ant_elev_1),
1001  _coef_ant_elev_2(rhs._coef_ant_elev_2),
1002  _coef_ant_elev_3(rhs._coef_ant_elev_3),
1003  _coef_ant_elev_4(rhs._coef_ant_elev_4),
1004  _coef_ant_elev_5(rhs._coef_ant_elev_5),
1005  _range_time_origin_ant(rhs._range_time_origin_ant)
1006  {}
coef_ground_range_4
dopp_cent_conf_meas
asc_node_vel_X_comp
asc_node_pos_X_comp
3_dB_look_bandwidth
coef_ground_range_3
coef_ground_range_2
Constructor.
coef_ground_range_1
asc_node_pos_Y_comp
out_image_max_value
asc_node_vel_Z_comp
asc_node_vel_Y_comp
asc_node_pos_Z_comp
first_rec_gain_read
Member Function Documentation
◆ Clone()
AlosPalsarRecord* ossimplugins::AlosPalsarFacilityData::Clone ( )
inlinevirtual
Implements ossimplugins::AlosPalsarRecord.
Definition at line 72 of file AlosPalsarFacilityData.h.
References AlosPalsarFacilityData().
73  {
74  return new AlosPalsarFacilityData(*this);
75  };
◆ get_3_dB_look_bandwidth()
double ossimplugins::AlosPalsarFacilityData::get_3_dB_look_bandwidth ( )
inline
3_dB_look_bandwidth
Definition at line 1049 of file AlosPalsarFacilityData.h.
References _3_dB_look_bandwidth.
1050  {
1051  return _3_dB_look_bandwidth;
1052  };
3_dB_look_bandwidth
◆ get_3_dB_look_proc_dopp_bandw()
double ossimplugins::AlosPalsarFacilityData::get_3_dB_look_proc_dopp_bandw ( )
inline
Definition at line 1056 of file AlosPalsarFacilityData.h.
References _3_dB_look_proc_dopp_bandw.
1057  {
1059  };
◆ get_3_dB_width_CCF()
double ossimplugins::AlosPalsarFacilityData::get_3_dB_width_CCF ( )
inline
3_dB_width_CCF
Definition at line 622 of file AlosPalsarFacilityData.h.
References _3_dB_width_CCF.
623  {
624  return _3_dB_width_CCF;
625  };
◆ get_abs_cal_const_K()
double ossimplugins::AlosPalsarFacilityData::get_abs_cal_const_K ( )
inline
abs_cal_const_K
Definition at line 454 of file AlosPalsarFacilityData.h.
References _abs_cal_const_K.
455  {
456  return _abs_cal_const_K;
457  };
◆ get_antenna_elev_flag()
int ossimplugins::AlosPalsarFacilityData::get_antenna_elev_flag ( ) const
inline
antenna_elev_flag
Definition at line 447 of file AlosPalsarFacilityData.h.
References _antenna_elev_flag.
448  {
449  return _antenna_elev_flag;
450  };
◆ get_asc_node_pos_X_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_asc_node_pos_X_comp ( )
inline
asc_node_pos_X_comp
Definition at line 545 of file AlosPalsarFacilityData.h.
References _asc_node_pos_X_comp.
546  {
547  return _asc_node_pos_X_comp;
548  };
asc_node_pos_X_comp
◆ get_asc_node_pos_Y_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_asc_node_pos_Y_comp ( )
inline
asc_node_pos_Y_comp
Definition at line 552 of file AlosPalsarFacilityData.h.
References _asc_node_pos_Y_comp.
553  {
554  return _asc_node_pos_Y_comp;
555  };
asc_node_pos_Y_comp
◆ get_asc_node_pos_Z_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_asc_node_pos_Z_comp ( )
inline
asc_node_pos_Z_comp
Definition at line 559 of file AlosPalsarFacilityData.h.
References _asc_node_pos_Z_comp.
560  {
561  return _asc_node_pos_Z_comp;
562  };
asc_node_pos_Z_comp
◆ get_asc_node_vel_X_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_asc_node_vel_X_comp ( )
inline
asc_node_vel_X_comp
Definition at line 566 of file AlosPalsarFacilityData.h.
References _asc_node_vel_X_comp.
567  {
568  return _asc_node_vel_X_comp;
569  };
asc_node_vel_X_comp
◆ get_asc_node_vel_Y_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_asc_node_vel_Y_comp ( )
inline
asc_node_vel_Y_comp
Definition at line 573 of file AlosPalsarFacilityData.h.
References _asc_node_vel_Y_comp.
574  {
575  return _asc_node_vel_Y_comp;
576  };
asc_node_vel_Y_comp
◆ get_asc_node_vel_Z_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_asc_node_vel_Z_comp ( )
inline
asc_node_vel_Z_comp
Definition at line 580 of file AlosPalsarFacilityData.h.
References _asc_node_vel_Z_comp.
581  {
582  return _asc_node_vel_Z_comp;
583  };
asc_node_vel_Z_comp
◆ get_autom_look_scal_gain_flag()
bool ossimplugins::AlosPalsarFacilityData::get_autom_look_scal_gain_flag ( ) const
inline
Definition at line 1091 of file AlosPalsarFacilityData.h.
References _autom_look_scal_gain_flag.
1092  {
1094  };
◆ get_azimuth_baseband_convers_flag()
int ossimplugins::AlosPalsarFacilityData::get_azimuth_baseband_convers_flag ( ) const
inline
Definition at line 678 of file AlosPalsarFacilityData.h.
References _azimuth_baseband_convers_flag.
679  {
681  };
◆ get_azimuth_FFT_IFFT_ratio()
int ossimplugins::AlosPalsarFacilityData::get_azimuth_FFT_IFFT_ratio ( )
inline
Definition at line 895 of file AlosPalsarFacilityData.h.
References _azimuth_FFT_IFFT_ratio.
896  {
898  };
◆ get_cal_gain_change_flag()
int ossimplugins::AlosPalsarFacilityData::get_cal_gain_change_flag ( ) const
inline
Definition at line 139 of file AlosPalsarFacilityData.h.
References _cal_gain_change_flag.
140  {
141  return _cal_gain_change_flag;
142  };
◆ get_cal_gain_changes()
int ossimplugins::AlosPalsarFacilityData::get_cal_gain_changes ( ) const
inline
cal_gain_changes
Definition at line 209 of file AlosPalsarFacilityData.h.
References _cal_gain_changes.
210  {
211  return _cal_gain_changes;
212  };
◆ get_cal_sys_gain()
double ossimplugins::AlosPalsarFacilityData::get_cal_sys_gain ( ) const
inline
cal_sys_gain
Definition at line 293 of file AlosPalsarFacilityData.h.
References _cal_sys_gain.
294  {
295  return _cal_sys_gain;
296  };
◆ get_cal_syst_gain_last_proc()
int ossimplugins::AlosPalsarFacilityData::get_cal_syst_gain_last_proc ( ) const
inline
Definition at line 874 of file AlosPalsarFacilityData.h.
References _cal_syst_gain_last_proc.
875  {
877  };
◆ get_center_range_pix_mid_az_inc()
double ossimplugins::AlosPalsarFacilityData::get_center_range_pix_mid_az_inc ( ) const
inline
Definition at line 426 of file AlosPalsarFacilityData.h.
References _center_range_pix_mid_az_inc.
427  {
429  };
◆ get_coef_ant_elev_1()
double ossimplugins::AlosPalsarFacilityData::get_coef_ant_elev_1 ( ) const
inline
coef_ant_elev_1
Definition at line 1140 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_1.
1141  {
1142  return _coef_ant_elev_1;
1143  };
◆ get_coef_ant_elev_2()
double ossimplugins::AlosPalsarFacilityData::get_coef_ant_elev_2 ( ) const
inline
coef_ant_elev_2
Definition at line 1147 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_2.
1148  {
1149  return _coef_ant_elev_2;
1150  };
◆ get_coef_ant_elev_3()
double ossimplugins::AlosPalsarFacilityData::get_coef_ant_elev_3 ( ) const
inline
coef_ant_elev_3
Definition at line 1154 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_3.
1155  {
1156  return _coef_ant_elev_3;
1157  };
◆ get_coef_ant_elev_4()
double ossimplugins::AlosPalsarFacilityData::get_coef_ant_elev_4 ( ) const
inline
coef_ant_elev_4
Definition at line 1161 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_4.
1162  {
1163  return _coef_ant_elev_4;
1164  };
◆ get_coef_ant_elev_5()
double ossimplugins::AlosPalsarFacilityData::get_coef_ant_elev_5 ( ) const
inline
coef_ant_elev_5
Definition at line 1168 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_5.
1169  {
1170  return _coef_ant_elev_5;
1171  };
◆ get_coef_ground_range_1()
double ossimplugins::AlosPalsarFacilityData::get_coef_ground_range_1 ( ) const
inline
coef_ground_range_1
Definition at line 1112 of file AlosPalsarFacilityData.h.
References _coef_ground_range_1.
1113  {
1114  return _coef_ground_range_1;
1115  };
coef_ground_range_1
◆ get_coef_ground_range_2()
double ossimplugins::AlosPalsarFacilityData::get_coef_ground_range_2 ( ) const
inline
coef_ground_range_2
Definition at line 1119 of file AlosPalsarFacilityData.h.
References _coef_ground_range_2.
1120  {
1121  return _coef_ground_range_2;
1122  };
coef_ground_range_2
◆ get_coef_ground_range_3()
double ossimplugins::AlosPalsarFacilityData::get_coef_ground_range_3 ( ) const
inline
coef_ground_range_3
Definition at line 1126 of file AlosPalsarFacilityData.h.
References _coef_ground_range_3.
1127  {
1128  return _coef_ground_range_3;
1129  };
coef_ground_range_3
◆ get_coef_ground_range_4()
double ossimplugins::AlosPalsarFacilityData::get_coef_ground_range_4 ( ) const
inline
coef_ground_range_4
Definition at line 1133 of file AlosPalsarFacilityData.h.
References _coef_ground_range_4.
1134  {
1135  return _coef_ground_range_4;
1136  };
coef_ground_range_4
◆ get_datation_flag()
bool ossimplugins::AlosPalsarFacilityData::get_datation_flag ( ) const
inline
datation_flag
Definition at line 1070 of file AlosPalsarFacilityData.h.
References _datation_flag.
1071  {
1072  return _datation_flag;
1073  };
◆ get_dopp_ambig_conf_meas()
double ossimplugins::AlosPalsarFacilityData::get_dopp_ambig_conf_meas ( ) const
inline
Definition at line 258 of file AlosPalsarFacilityData.h.
References _dopp_ambig_conf_meas.
259  {
260  return _dopp_ambig_conf_meas;
261  };
◆ get_dopp_ambig_conf_meas_flag()
int ossimplugins::AlosPalsarFacilityData::get_dopp_ambig_conf_meas_flag ( ) const
inline
Definition at line 174 of file AlosPalsarFacilityData.h.
References _dopp_ambig_conf_meas_flag.
175  {
177  };
◆ get_dopp_ambig_num()
double ossimplugins::AlosPalsarFacilityData::get_dopp_ambig_num ( ) const
inline
dopp_ambig_num
Definition at line 307 of file AlosPalsarFacilityData.h.
References _dopp_ambig_num.
308  {
309  return _dopp_ambig_num;
310  };
◆ get_dopp_cent_conf_meas()
double ossimplugins::AlosPalsarFacilityData::get_dopp_cent_conf_meas ( ) const
inline
dopp_cent_conf_meas
Definition at line 251 of file AlosPalsarFacilityData.h.
References _dopp_cent_conf_meas.
252  {
253  return _dopp_cent_conf_meas;
254  };
dopp_cent_conf_meas
◆ get_dopp_cent_conf_meas_flag()
int ossimplugins::AlosPalsarFacilityData::get_dopp_cent_conf_meas_flag ( ) const
inline
Definition at line 160 of file AlosPalsarFacilityData.h.
References _dopp_cent_conf_meas_flag.
161  {
163  };
◆ get_dopp_cent_val_flag()
int ossimplugins::AlosPalsarFacilityData::get_dopp_cent_val_flag ( ) const
inline
dopp_cent_val_flag
Definition at line 167 of file AlosPalsarFacilityData.h.
References _dopp_cent_val_flag.
168  {
169  return _dopp_cent_val_flag;
170  };
◆ get_doppler_ambiguity_estimat_flag()
int ossimplugins::AlosPalsarFacilityData::get_doppler_ambiguity_estimat_flag ( ) const
inline
Definition at line 671 of file AlosPalsarFacilityData.h.
References _doppler_ambiguity_estimat_flag.
672  {
674  };
◆ get_doppler_centroid_cubic_coeff()
double ossimplugins::AlosPalsarFacilityData::get_doppler_centroid_cubic_coeff ( ) const
inline
Definition at line 839 of file AlosPalsarFacilityData.h.
References _doppler_centroid_cubic_coeff.
840  {
842  };
◆ get_estim_bit_error_rate()
double ossimplugins::AlosPalsarFacilityData::get_estim_bit_error_rate ( ) const
inline
Definition at line 503 of file AlosPalsarFacilityData.h.
References _estim_bit_error_rate.
504  {
505  return _estim_bit_error_rate;
506  };
◆ get_first_processed_range_sample()
int ossimplugins::AlosPalsarFacilityData::get_first_processed_range_sample ( ) const
inline
Definition at line 888 of file AlosPalsarFacilityData.h.
References _first_processed_range_sample.
889  {
891  };
◆ get_first_range_pixel_mid_az_inc()
double ossimplugins::AlosPalsarFacilityData::get_first_range_pixel_mid_az_inc ( ) const
inline
Definition at line 419 of file AlosPalsarFacilityData.h.
References _first_range_pixel_mid_az_inc.
420  {
422  };
◆ get_first_rec_gain_read()
double ossimplugins::AlosPalsarFacilityData::get_first_rec_gain_read ( ) const
inline
first_rec_gain_read
Definition at line 300 of file AlosPalsarFacilityData.h.
References _first_rec_gain_read.
301  {
302  return _first_rec_gain_read;
303  };
first_rec_gain_read
◆ get_first_replica_sample()
double ossimplugins::AlosPalsarFacilityData::get_first_replica_sample ( ) const
inline
Definition at line 384 of file AlosPalsarFacilityData.h.
References _first_replica_sample.
385  {
386  return _first_replica_sample;
387  };
◆ get_first_side_lobe_lev_of_ACF()
double ossimplugins::AlosPalsarFacilityData::get_first_side_lobe_lev_of_ACF ( )
inline
Definition at line 237 of file AlosPalsarFacilityData.h.
References _first_side_lobe_lev_of_ACF.
238  {
240  };
◆ get_first_side_lobe_level()
double ossimplugins::AlosPalsarFacilityData::get_first_side_lobe_level ( ) const
inline
Definition at line 629 of file AlosPalsarFacilityData.h.
References _first_side_lobe_level.
630  {
631  return _first_side_lobe_level;
632  };
◆ get_form_num_range_line_used()
int ossimplugins::AlosPalsarFacilityData::get_form_num_range_line_used ( ) const
inline
Definition at line 1084 of file AlosPalsarFacilityData.h.
References _form_num_range_line_used.
1085  {
1087  };
◆ get_I_channel_bias_correction()
double ossimplugins::AlosPalsarFacilityData::get_I_channel_bias_correction ( )
inline
Definition at line 314 of file AlosPalsarFacilityData.h.
References _I_channel_bias_correction.
315  {
317  };
◆ get_I_channel_gain_correction()
double ossimplugins::AlosPalsarFacilityData::get_I_channel_gain_correction ( )
inline
Definition at line 328 of file AlosPalsarFacilityData.h.
References _I_channel_gain_correction.
329  {
331  };
◆ get_I_gain_imb_lower_bound()
double ossimplugins::AlosPalsarFacilityData::get_I_gain_imb_lower_bound ( )
inline
Definition at line 1021 of file AlosPalsarFacilityData.h.
References _I_gain_imb_lower_bound.
1022  {
1023  return _I_gain_imb_lower_bound;
1024  };
◆ get_I_gain_imb_upper_bound()
double ossimplugins::AlosPalsarFacilityData::get_I_gain_imb_upper_bound ( )
inline
Definition at line 1028 of file AlosPalsarFacilityData.h.
References _I_gain_imb_upper_bound.
1029  {
1030  return _I_gain_imb_upper_bound;
1031  };
◆ get_I_Q_quad_depar_lower_bound()
double ossimplugins::AlosPalsarFacilityData::get_I_Q_quad_depar_lower_bound ( )
inline
Definition at line 1035 of file AlosPalsarFacilityData.h.
References _I_Q_quad_depar_lower_bound.
1036  {
1038  };
◆ get_I_Q_quad_depar_upper_bound()
double ossimplugins::AlosPalsarFacilityData::get_I_Q_quad_depar_upper_bound ( )
inline
Definition at line 1042 of file AlosPalsarFacilityData.h.
References _I_Q_quad_depar_upper_bound.
1043  {
1045  };
◆ get_initial_doppler_ambiguity_num()
int ossimplugins::AlosPalsarFacilityData::get_initial_doppler_ambiguity_num ( ) const
inline
Definition at line 916 of file AlosPalsarFacilityData.h.
References _initial_doppler_ambiguity_num.
917  {
919  };
◆ get_inp_data_I_mean()
double ossimplugins::AlosPalsarFacilityData::get_inp_data_I_mean ( )
inline
inp_data_I_mean
Definition at line 265 of file AlosPalsarFacilityData.h.
References _inp_data_I_mean.
266  {
267  return _inp_data_I_mean;
268  };
◆ get_inp_data_I_stddev()
double ossimplugins::AlosPalsarFacilityData::get_inp_data_I_stddev ( )
inline
inp_data_I_stddev
Definition at line 279 of file AlosPalsarFacilityData.h.
References _inp_data_I_stddev.
280  {
281  return _inp_data_I_stddev;
282  };
◆ get_inp_data_Q_mean()
double ossimplugins::AlosPalsarFacilityData::get_inp_data_Q_mean ( )
inline
inp_data_Q_mean
Definition at line 272 of file AlosPalsarFacilityData.h.
References _inp_data_Q_mean.
273  {
274  return _inp_data_Q_mean;
275  };
◆ get_inp_data_Q_stddev()
double ossimplugins::AlosPalsarFacilityData::get_inp_data_Q_stddev ( )
inline
inp_data_Q_stddev
Definition at line 286 of file AlosPalsarFacilityData.h.
References _inp_data_Q_stddev.
287  {
288  return _inp_data_Q_stddev;
289  };
◆ get_inp_data_stat_flag()
int ossimplugins::AlosPalsarFacilityData::get_inp_data_stat_flag ( ) const
inline
inp_data_stat_flag
Definition at line 153 of file AlosPalsarFacilityData.h.
References _inp_data_stat_flag.
154  {
155  return _inp_data_stat_flag;
156  };
◆ get_inp_state_vect_pos_X_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_inp_state_vect_pos_X_comp ( )
inline
Definition at line 706 of file AlosPalsarFacilityData.h.
References _inp_state_vect_pos_X_comp.
707  {
709  };
◆ get_inp_state_vect_pos_Y_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_inp_state_vect_pos_Y_comp ( )
inline
Definition at line 713 of file AlosPalsarFacilityData.h.
References _inp_state_vect_pos_Y_comp.
714  {
716  };
◆ get_inp_state_vect_pos_Z_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_inp_state_vect_pos_Z_comp ( )
inline
Definition at line 720 of file AlosPalsarFacilityData.h.
References _inp_state_vect_pos_Z_comp.
721  {
723  };
◆ get_inp_state_vect_vel_Vx_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_inp_state_vect_vel_Vx_comp ( )
inline
Definition at line 727 of file AlosPalsarFacilityData.h.
References _inp_state_vect_vel_Vx_comp.
728  {
730  };
◆ get_inp_state_vect_vel_Vy_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_inp_state_vect_vel_Vy_comp ( )
inline
Definition at line 734 of file AlosPalsarFacilityData.h.
References _inp_state_vect_vel_Vy_comp.
735  {
737  };
◆ get_inp_state_vect_vel_Vz_comp()
std::string ossimplugins::AlosPalsarFacilityData::get_inp_state_vect_vel_Vz_comp ( )
inline
Definition at line 741 of file AlosPalsarFacilityData.h.
References _inp_state_vect_vel_Vz_comp.
742  {
744  };
◆ get_inp_state_vector_type_flag()
int ossimplugins::AlosPalsarFacilityData::get_inp_state_vector_type_flag ( ) const
inline
Definition at line 748 of file AlosPalsarFacilityData.h.
References _inp_state_vector_type_flag.
749  {
751  };
◆ get_int_cal_utc()
int ossimplugins::AlosPalsarFacilityData::get_int_cal_utc ( ) const
inline
int_cal_utc
Definition at line 356 of file AlosPalsarFacilityData.h.
References _int_cal_utc.
357  {
358  return _int_cal_utc;
359  };
◆ get_ISLR_CCF_between_last()
double ossimplugins::AlosPalsarFacilityData::get_ISLR_CCF_between_last ( )
inline
Definition at line 636 of file AlosPalsarFacilityData.h.
References _ISLR_CCF_between_last.
637  {
638  return _ISLR_CCF_between_last;
639  };
◆ get_ISLR_of_ACF()
double ossimplugins::AlosPalsarFacilityData::get_ISLR_of_ACF ( )
inline
ISLR_of_ACF.
Definition at line 244 of file AlosPalsarFacilityData.h.
References _ISLR_of_ACF.
245  {
246  return _ISLR_of_ACF;
247  };
◆ get_K_gen_date()
std::string ossimplugins::AlosPalsarFacilityData::get_K_gen_date ( )
inline
K_gen_date.
Definition at line 482 of file AlosPalsarFacilityData.h.
References _K_gen_date.
483  {
484  return _K_gen_date;
485  };
◆ get_K_vers_num()
std::string ossimplugins::AlosPalsarFacilityData::get_K_vers_num ( )
inline
K_vers_num.
Definition at line 489 of file AlosPalsarFacilityData.h.
References _K_vers_num.
490  {
491  return _K_vers_num;
492  };
◆ get_last_range_pix_mid_az_inc()
double ossimplugins::AlosPalsarFacilityData::get_last_range_pix_mid_az_inc ( ) const
inline
Definition at line 433 of file AlosPalsarFacilityData.h.
References _last_range_pix_mid_az_inc.
434  {
436  };
◆ get_last_release_cal_date()
std::string ossimplugins::AlosPalsarFacilityData::get_last_release_cal_date ( ) const
inline
Definition at line 111 of file AlosPalsarFacilityData.h.
References _last_release_cal_date.
112  {
113  return _last_release_cal_date;
114  };
◆ get_last_release_qc_date()
std::string ossimplugins::AlosPalsarFacilityData::get_last_release_qc_date ( ) const
inline
Definition at line 104 of file AlosPalsarFacilityData.h.
References _last_release_qc_date.
105  {
106  return _last_release_qc_date;
107  };
◆ get_look_detecion_flag()
int ossimplugins::AlosPalsarFacilityData::get_look_detecion_flag ( ) const
inline
look_detecion_flag
Definition at line 664 of file AlosPalsarFacilityData.h.
References _look_detecion_flag.
665  {
666  return _look_detecion_flag;
667  };
◆ get_look_scalar_gain_1()
double ossimplugins::AlosPalsarFacilityData::get_look_scalar_gain_1 ( )
inline
look_scalar_gain_1
Definition at line 776 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_1.
777  {
778  return _look_scalar_gain_1;
779  };
◆ get_look_scalar_gain_2()
double ossimplugins::AlosPalsarFacilityData::get_look_scalar_gain_2 ( )
inline
look_scalar_gain_2
Definition at line 783 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_2.
784  {
785  return _look_scalar_gain_2;
786  };
◆ get_look_scalar_gain_3()
double ossimplugins::AlosPalsarFacilityData::get_look_scalar_gain_3 ( )
inline
look_scalar_gain_3
Definition at line 790 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_3.
791  {
792  return _look_scalar_gain_3;
793  };
◆ get_look_scalar_gain_4()
double ossimplugins::AlosPalsarFacilityData::get_look_scalar_gain_4 ( )
inline
look_scalar_gain_4
Definition at line 797 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_4.
798  {
799  return _look_scalar_gain_4;
800  };
◆ get_look_scalar_gain_5()
double ossimplugins::AlosPalsarFacilityData::get_look_scalar_gain_5 ( )
inline
look_scalar_gain_5
Definition at line 804 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_5.
805  {
806  return _look_scalar_gain_5;
807  };
◆ get_look_scalar_gain_6()
double ossimplugins::AlosPalsarFacilityData::get_look_scalar_gain_6 ( )
inline
look_scalar_gain_6
Definition at line 811 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_6.
812  {
813  return _look_scalar_gain_6;
814  };
◆ get_look_scalar_gain_7()
double ossimplugins::AlosPalsarFacilityData::get_look_scalar_gain_7 ( )
inline
look_scalar_gain_7
Definition at line 818 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_7.
819  {
820  return _look_scalar_gain_7;
821  };
◆ get_look_scalar_gain_8()
double ossimplugins::AlosPalsarFacilityData::get_look_scalar_gain_8 ( )
inline
look_scalar_gain_8
Definition at line 825 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_8.
826  {
827  return _look_scalar_gain_8;
828  };
◆ get_low_bound_K()
double ossimplugins::AlosPalsarFacilityData::get_low_bound_K ( )
inline
low_bound_K
Definition at line 468 of file AlosPalsarFacilityData.h.
References _low_bound_K.
469  {
470  return _low_bound_K;
471  };
◆ get_max_error_range_line_timing()
int ossimplugins::AlosPalsarFacilityData::get_max_error_range_line_timing ( ) const
inline
Definition at line 1077 of file AlosPalsarFacilityData.h.
References _max_error_range_line_timing.
1078  {
1080  };
◆ get_max_value_look_scalar_gain()
int ossimplugins::AlosPalsarFacilityData::get_max_value_look_scalar_gain ( ) const
inline
Definition at line 1098 of file AlosPalsarFacilityData.h.
References _max_value_look_scalar_gain.
1099  {
1101  };
◆ get_mean_cal_pulse_power()
double ossimplugins::AlosPalsarFacilityData::get_mean_cal_pulse_power ( ) const
inline
Definition at line 391 of file AlosPalsarFacilityData.h.
References _mean_cal_pulse_power.
392  {
393  return _mean_cal_pulse_power;
394  };
◆ get_mean_noise_power()
double ossimplugins::AlosPalsarFacilityData::get_mean_noise_power ( ) const
inline
mean_noise_power
Definition at line 398 of file AlosPalsarFacilityData.h.
References _mean_noise_power.
399  {
400  return _mean_noise_power;
401  };
◆ get_missing_lines()
int ossimplugins::AlosPalsarFacilityData::get_missing_lines ( ) const
inline
missing_lines
Definition at line 216 of file AlosPalsarFacilityData.h.
References _missing_lines.
217  {
218  return _missing_lines;
219  };
◆ get_name_of_facil_rec()
std::string ossimplugins::AlosPalsarFacilityData::get_name_of_facil_rec ( ) const
inline
name_of_facil_rec
Definition at line 96 of file AlosPalsarFacilityData.h.
References _name_of_facil_rec.
97  {
98  return _name_of_facil_rec;
99  };
◆ get_noise_power()
double ossimplugins::AlosPalsarFacilityData::get_noise_power ( ) const
inline
noise_power
Definition at line 349 of file AlosPalsarFacilityData.h.
References _noise_power.
350  {
351  return _noise_power;
352  };
◆ get_norm_ref_range_ro()
double ossimplugins::AlosPalsarFacilityData::get_norm_ref_range_ro ( ) const
inline
norm_ref_range_ro
Definition at line 440 of file AlosPalsarFacilityData.h.
References _norm_ref_range_ro.
441  {
442  return _norm_ref_range_ro;
443  };
◆ get_num_azimuth_blocks_proc()
int ossimplugins::AlosPalsarFacilityData::get_num_azimuth_blocks_proc ( ) const
inline
Definition at line 902 of file AlosPalsarFacilityData.h.
References _num_azimuth_blocks_proc.
903  {
905  };
◆ get_num_duplic_input_lines()
int ossimplugins::AlosPalsarFacilityData::get_num_duplic_input_lines ( ) const
inline
Definition at line 496 of file AlosPalsarFacilityData.h.
References _num_duplic_input_lines.
497  {
499  };
◆ get_num_input_raw_data_lines()
int ossimplugins::AlosPalsarFacilityData::get_num_input_raw_data_lines ( ) const
inline
Definition at line 909 of file AlosPalsarFacilityData.h.
References _num_input_raw_data_lines.
910  {
912  };
◆ get_num_range_samp_discarded()
int ossimplugins::AlosPalsarFacilityData::get_num_range_samp_discarded ( ) const
inline
Definition at line 1014 of file AlosPalsarFacilityData.h.
References _num_range_samp_discarded.
1015  {
1017  };
◆ get_num_valid_cal_pulses()
int ossimplugins::AlosPalsarFacilityData::get_num_valid_cal_pulses ( ) const
inline
Definition at line 363 of file AlosPalsarFacilityData.h.
References _num_valid_cal_pulses.
364  {
365  return _num_valid_cal_pulses;
366  };
◆ get_num_valid_noise_pulses()
int ossimplugins::AlosPalsarFacilityData::get_num_valid_noise_pulses ( ) const
inline
Definition at line 370 of file AlosPalsarFacilityData.h.
References _num_valid_noise_pulses.
371  {
373  };
◆ get_num_valid_pixels_per_range()
int ossimplugins::AlosPalsarFacilityData::get_num_valid_pixels_per_range ( ) const
inline
Definition at line 1007 of file AlosPalsarFacilityData.h.
References _num_valid_pixels_per_range.
1008  {
1010  };
◆ get_num_valid_replicas()
int ossimplugins::AlosPalsarFacilityData::get_num_valid_replicas ( ) const
inline
num_valid_replicas
Definition at line 377 of file AlosPalsarFacilityData.h.
References _num_valid_replicas.
378  {
379  return _num_valid_replicas;
380  };
◆ get_OGOB_flag()
int ossimplugins::AlosPalsarFacilityData::get_OGOB_flag ( )
inline
OGOB_flag.
Definition at line 188 of file AlosPalsarFacilityData.h.
References _OGOB_flag.
189  {
190  return _OGOB_flag;
191  };
◆ get_out_image_max_value()
double ossimplugins::AlosPalsarFacilityData::get_out_image_max_value ( ) const
inline
out_image_max_value
Definition at line 524 of file AlosPalsarFacilityData.h.
References _out_image_max_value.
525  {
526  return _out_image_max_value;
527  };
out_image_max_value
◆ get_out_image_mean()
double ossimplugins::AlosPalsarFacilityData::get_out_image_mean ( ) const
inline
out_image_mean
Definition at line 510 of file AlosPalsarFacilityData.h.
References _out_image_mean.
511  {
512  return _out_image_mean;
513  };
◆ get_out_image_std_dev()
double ossimplugins::AlosPalsarFacilityData::get_out_image_std_dev ( ) const
inline
out_image_std_dev
Definition at line 517 of file AlosPalsarFacilityData.h.
References _out_image_std_dev.
518  {
519  return _out_image_std_dev;
520  };
◆ get_out_pixel_bit_length()
int ossimplugins::AlosPalsarFacilityData::get_out_pixel_bit_length ( ) const
inline
Definition at line 587 of file AlosPalsarFacilityData.h.
References _out_pixel_bit_length.
588  {
589  return _out_pixel_bit_length;
590  };
◆ get_outp_data_mean_flag()
int ossimplugins::AlosPalsarFacilityData::get_outp_data_mean_flag ( ) const
inline
outp_data_mean_flag
Definition at line 181 of file AlosPalsarFacilityData.h.
References _outp_data_mean_flag.
182  {
183  return _outp_data_mean_flag;
184  };
◆ get_peak_loc_CCF_betw_last()
int ossimplugins::AlosPalsarFacilityData::get_peak_loc_CCF_betw_last ( )
inline
Definition at line 643 of file AlosPalsarFacilityData.h.
References _peak_loc_CCF_betw_last.
644  {
646  };
◆ get_peak_loc_cross_correl_fun()
int ossimplugins::AlosPalsarFacilityData::get_peak_loc_cross_correl_fun ( ) const
inline
Definition at line 615 of file AlosPalsarFacilityData.h.
References _peak_loc_cross_correl_fun.
616  {
618  };
◆ get_PRF_changes()
int ossimplugins::AlosPalsarFacilityData::get_PRF_changes ( )
inline
PRF_changes.
Definition at line 195 of file AlosPalsarFacilityData.h.
References _PRF_changes.
196  {
197  return _PRF_changes;
198  };
◆ get_prf_code_change_flag()
int ossimplugins::AlosPalsarFacilityData::get_prf_code_change_flag ( ) const
inline
Definition at line 125 of file AlosPalsarFacilityData.h.
References _prf_code_change_flag.
126  {
127  return _prf_code_change_flag;
128  };
◆ get_PRF_code_first_range_line()
int ossimplugins::AlosPalsarFacilityData::get_PRF_code_first_range_line ( )
inline
Definition at line 846 of file AlosPalsarFacilityData.h.
References _PRF_code_first_range_line.
847  {
849  };
◆ get_PRF_code_last_range_line()
int ossimplugins::AlosPalsarFacilityData::get_PRF_code_last_range_line ( )
inline
Definition at line 853 of file AlosPalsarFacilityData.h.
References _PRF_code_last_range_line.
854  {
856  };
◆ get_proc_gain_param_1()
double ossimplugins::AlosPalsarFacilityData::get_proc_gain_param_1 ( )
inline
proc_gain_param_1
Definition at line 594 of file AlosPalsarFacilityData.h.
References _proc_gain_param_1.
595  {
596  return _proc_gain_param_1;
597  };
◆ get_proc_gain_param_2()
double ossimplugins::AlosPalsarFacilityData::get_proc_gain_param_2 ( )
inline
proc_gain_param_2
Definition at line 601 of file AlosPalsarFacilityData.h.
References _proc_gain_param_2.
602  {
603  return _proc_gain_param_2;
604  };
◆ get_proc_gain_param_3()
double ossimplugins::AlosPalsarFacilityData::get_proc_gain_param_3 ( )
inline
proc_gain_param_3
Definition at line 608 of file AlosPalsarFacilityData.h.
References _proc_gain_param_3.
609  {
610  return _proc_gain_param_3;
611  };
◆ get_proc_noise_scale_fact()
double ossimplugins::AlosPalsarFacilityData::get_proc_noise_scale_fact ( ) const
inline
Definition at line 475 of file AlosPalsarFacilityData.h.
References _proc_noise_scale_fact.
476  {
477  return _proc_noise_scale_fact;
478  };
◆ get_pulse_width_of_ACF_3db()
double ossimplugins::AlosPalsarFacilityData::get_pulse_width_of_ACF_3db ( )
inline
Definition at line 230 of file AlosPalsarFacilityData.h.
References _pulse_width_of_ACF_3db.
231  {
233  };
◆ get_Q_channel_bias_correction()
double ossimplugins::AlosPalsarFacilityData::get_Q_channel_bias_correction ( )
inline
Definition at line 321 of file AlosPalsarFacilityData.h.
References _Q_channel_bias_correction.
322  {
324  };
◆ get_Q_channel_gain_correction()
double ossimplugins::AlosPalsarFacilityData::get_Q_channel_gain_correction ( )
inline
Definition at line 335 of file AlosPalsarFacilityData.h.
References _Q_channel_gain_correction.
336  {
338  };
◆ get_Q_channel_I_Q_correction()
double ossimplugins::AlosPalsarFacilityData::get_Q_channel_I_Q_correction ( )
inline
Definition at line 342 of file AlosPalsarFacilityData.h.
References _Q_channel_I_Q_correction.
343  {
345  };
◆ get_qa_summary_flag()
int ossimplugins::AlosPalsarFacilityData::get_qa_summary_flag ( ) const
inline
qa_summary_flag
Definition at line 118 of file AlosPalsarFacilityData.h.
References _qa_summary_flag.
119  {
120  return _qa_summary_flag;
121  };
◆ get_quirp_qu_flag()
int ossimplugins::AlosPalsarFacilityData::get_quirp_qu_flag ( ) const
inline
quirp_qu_flag
Definition at line 146 of file AlosPalsarFacilityData.h.
References _quirp_qu_flag.
147  {
148  return _quirp_qu_flag;
149  };
◆ get_range_comp_norm_fact()
double ossimplugins::AlosPalsarFacilityData::get_range_comp_norm_fact ( ) const
inline
Definition at line 405 of file AlosPalsarFacilityData.h.
References _range_comp_norm_fact.
406  {
407  return _range_comp_norm_fact;
408  };
◆ get_range_lines_skip_factor()
int ossimplugins::AlosPalsarFacilityData::get_range_lines_skip_factor ( ) const
inline
Definition at line 692 of file AlosPalsarFacilityData.h.
References _range_lines_skip_factor.
693  {
695  };
◆ get_range_spread_loss_comp_flag()
int ossimplugins::AlosPalsarFacilityData::get_range_spread_loss_comp_flag ( ) const
inline
Definition at line 1063 of file AlosPalsarFacilityData.h.
References _range_spread_loss_comp_flag.
1064  {
1066  };
◆ get_range_time_origin_ant()
double ossimplugins::AlosPalsarFacilityData::get_range_time_origin_ant ( ) const
inline
Definition at line 1175 of file AlosPalsarFacilityData.h.
References _range_time_origin_ant.
1176  {
1177  return _range_time_origin_ant;
1178  };
◆ get_raw_data_correction_flag()
int ossimplugins::AlosPalsarFacilityData::get_raw_data_correction_flag ( ) const
inline
Definition at line 657 of file AlosPalsarFacilityData.h.
References _raw_data_correction_flag.
658  {
660  };
◆ get_rec_gain_changes()
int ossimplugins::AlosPalsarFacilityData::get_rec_gain_changes ( ) const
inline
rec_gain_changes
Definition at line 223 of file AlosPalsarFacilityData.h.
References _rec_gain_changes.
224  {
225  return _rec_gain_changes;
226  };
◆ get_receiver_gain_last_proc()
int ossimplugins::AlosPalsarFacilityData::get_receiver_gain_last_proc ( ) const
inline
Definition at line 881 of file AlosPalsarFacilityData.h.
References _receiver_gain_last_proc.
882  {
884  };
◆ get_replica_norm_method_flag()
int ossimplugins::AlosPalsarFacilityData::get_replica_norm_method_flag ( ) const
inline
Definition at line 1105 of file AlosPalsarFacilityData.h.
References _replica_norm_method_flag.
1106  {
1108  };
◆ get_replica_power()
double ossimplugins::AlosPalsarFacilityData::get_replica_power ( ) const
inline
replica_power
Definition at line 412 of file AlosPalsarFacilityData.h.
References _replica_power.
413  {
414  return _replica_power;
415  };
◆ get_Roll_Tilt_Mode_flag()
int ossimplugins::AlosPalsarFacilityData::get_Roll_Tilt_Mode_flag ( )
inline
Definition at line 650 of file AlosPalsarFacilityData.h.
References _Roll_Tilt_Mode_flag.
651  {
652  return _Roll_Tilt_Mode_flag;
653  };
◆ get_samp_win_start_first()
int ossimplugins::AlosPalsarFacilityData::get_samp_win_start_first ( ) const
inline
Definition at line 860 of file AlosPalsarFacilityData.h.
References _samp_win_start_first.
861  {
862  return _samp_win_start_first;
863  };
◆ get_samp_win_start_last()
int ossimplugins::AlosPalsarFacilityData::get_samp_win_start_last ( ) const
inline
samp_win_start_last
Definition at line 867 of file AlosPalsarFacilityData.h.
References _samp_win_start_last.
868  {
869  return _samp_win_start_last;
870  };
◆ get_samp_window_start_time_bias()
int ossimplugins::AlosPalsarFacilityData::get_samp_window_start_time_bias ( ) const
inline
Definition at line 832 of file AlosPalsarFacilityData.h.
References _samp_window_start_time_bias.
833  {
835  };
◆ get_samples_per_line_used()
int ossimplugins::AlosPalsarFacilityData::get_samples_per_line_used ( ) const
inline
Definition at line 685 of file AlosPalsarFacilityData.h.
References _samples_per_line_used.
686  {
687  return _samples_per_line_used;
688  };
◆ get_sampling_win_change_flag()
int ossimplugins::AlosPalsarFacilityData::get_sampling_win_change_flag ( ) const
inline
Definition at line 132 of file AlosPalsarFacilityData.h.
References _sampling_win_change_flag.
133  {
135  };
◆ get_sampling_win_changes()
int ossimplugins::AlosPalsarFacilityData::get_sampling_win_changes ( ) const
inline
Definition at line 202 of file AlosPalsarFacilityData.h.
References _sampling_win_changes.
203  {
204  return _sampling_win_changes;
205  };
◆ get_sat_binary_time_of_first()
int ossimplugins::AlosPalsarFacilityData::get_sat_binary_time_of_first ( ) const
inline
Definition at line 1000 of file AlosPalsarFacilityData.h.
References _sat_binary_time_of_first.
1001  {
1003  };
◆ get_thresh_no_10_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_10_flag ( )
inline
thresh_no_10_flag
Definition at line 986 of file AlosPalsarFacilityData.h.
References _thresh_no_10_flag.
987  {
988  return _thresh_no_10_flag;
989  };
◆ get_thresh_no_11_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_11_flag ( )
inline
thresh_no_11_flag
Definition at line 993 of file AlosPalsarFacilityData.h.
References _thresh_no_11_flag.
994  {
995  return _thresh_no_11_flag;
996  };
◆ get_thresh_no_1_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_1_flag ( )
inline
thresh_no_1_flag
Definition at line 923 of file AlosPalsarFacilityData.h.
References _thresh_no_1_flag.
924  {
925  return _thresh_no_1_flag;
926  };
◆ get_thresh_no_2_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_2_flag ( )
inline
thresh_no_2_flag
Definition at line 930 of file AlosPalsarFacilityData.h.
References _thresh_no_2_flag.
931  {
932  return _thresh_no_2_flag;
933  };
◆ get_thresh_no_3_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_3_flag ( )
inline
thresh_no_3_flag
Definition at line 937 of file AlosPalsarFacilityData.h.
References _thresh_no_3_flag.
938  {
939  return _thresh_no_3_flag;
940  };
◆ get_thresh_no_4_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_4_flag ( )
inline
thresh_no_4_flag
Definition at line 944 of file AlosPalsarFacilityData.h.
References _thresh_no_4_flag.
945  {
946  return _thresh_no_4_flag;
947  };
◆ get_thresh_no_5_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_5_flag ( )
inline
thresh_no_5_flag
Definition at line 951 of file AlosPalsarFacilityData.h.
References _thresh_no_5_flag.
952  {
953  return _thresh_no_5_flag;
954  };
◆ get_thresh_no_6_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_6_flag ( )
inline
thresh_no_6_flag
Definition at line 958 of file AlosPalsarFacilityData.h.
References _thresh_no_6_flag.
959  {
960  return _thresh_no_6_flag;
961  };
◆ get_thresh_no_7_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_7_flag ( )
inline
thresh_no_7_flag
Definition at line 965 of file AlosPalsarFacilityData.h.
References _thresh_no_7_flag.
966  {
967  return _thresh_no_7_flag;
968  };
◆ get_thresh_no_8_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_8_flag ( )
inline
thresh_no_8_flag
Definition at line 972 of file AlosPalsarFacilityData.h.
References _thresh_no_8_flag.
973  {
974  return _thresh_no_8_flag;
975  };
◆ get_thresh_no_9_flag()
double ossimplugins::AlosPalsarFacilityData::get_thresh_no_9_flag ( )
inline
thresh_no_9_flag
Definition at line 979 of file AlosPalsarFacilityData.h.
References _thresh_no_9_flag.
980  {
981  return _thresh_no_9_flag;
982  };
◆ get_time_asc_node_state_vectors()
std::string ossimplugins::AlosPalsarFacilityData::get_time_asc_node_state_vectors ( ) const
inline
Definition at line 538 of file AlosPalsarFacilityData.h.
References _time_asc_node_state_vectors.
539  {
541  };
◆ get_time_of_inp_state_vectors()
std::string ossimplugins::AlosPalsarFacilityData::get_time_of_inp_state_vectors ( ) const
inline
Definition at line 699 of file AlosPalsarFacilityData.h.
References _time_of_inp_state_vectors.
700  {
702  };
◆ get_time_raw_data_first_input()
std::string ossimplugins::AlosPalsarFacilityData::get_time_raw_data_first_input ( ) const
inline
Definition at line 531 of file AlosPalsarFacilityData.h.
References _time_raw_data_first_input.
532  {
534  };
◆ get_update_period_range_match()
int ossimplugins::AlosPalsarFacilityData::get_update_period_range_match ( ) const
inline
Definition at line 769 of file AlosPalsarFacilityData.h.
References _update_period_range_match.
770  {
772  };
◆ get_upp_bound_K()
double ossimplugins::AlosPalsarFacilityData::get_upp_bound_K ( )
inline
upp_bound_K
Definition at line 461 of file AlosPalsarFacilityData.h.
References _upp_bound_K.
462  {
463  return _upp_bound_K;
464  };
◆ get_win_coeff_for_azi_match()
double ossimplugins::AlosPalsarFacilityData::get_win_coeff_for_azi_match ( ) const
inline
Definition at line 762 of file AlosPalsarFacilityData.h.
References _win_coeff_for_azi_match.
763  {
765  };
◆ get_win_coeff_for_range_match()
double ossimplugins::AlosPalsarFacilityData::get_win_coeff_for_range_match ( ) const
inline
Definition at line 755 of file AlosPalsarFacilityData.h.
References _win_coeff_for_range_match.
756  {
758  };
◆ Instanciate()
AlosPalsarRecord* ossimplugins::AlosPalsarFacilityData::Instanciate ( )
inlinevirtual
This function is able to create a new instance of the class.
Definition at line 64 of file AlosPalsarFacilityData.h.
65  {
66  return new AlosPalsarFacilityData();
67  };
◆ operator=()
AlosPalsarFacilityData & ossimplugins::AlosPalsarFacilityData::operator= ( const AlosPalsarFacilityData rhs)
Copy operator.
Definition at line 1008 of file AlosPalsarFacilityData.cpp.
References _3_dB_look_bandwidth, _3_dB_look_proc_dopp_bandw, _3_dB_width_CCF, _abs_cal_const_K, _antenna_elev_flag, _asc_node_pos_X_comp, _asc_node_pos_Y_comp, _asc_node_pos_Z_comp, _asc_node_vel_X_comp, _asc_node_vel_Y_comp, _asc_node_vel_Z_comp, _autom_look_scal_gain_flag, _azimuth_baseband_convers_flag, _azimuth_FFT_IFFT_ratio, _cal_gain_change_flag, _cal_gain_changes, _cal_sys_gain, _cal_syst_gain_last_proc, _center_range_pix_mid_az_inc, _coef_ant_elev_1, _coef_ant_elev_2, _coef_ant_elev_3, _coef_ant_elev_4, _coef_ant_elev_5, _coef_ground_range_1, _coef_ground_range_2, _coef_ground_range_3, _coef_ground_range_4, _datation_flag, _dopp_ambig_conf_meas, _dopp_ambig_conf_meas_flag, _dopp_ambig_num, _dopp_cent_conf_meas, _dopp_cent_conf_meas_flag, _dopp_cent_val_flag, _doppler_ambiguity_estimat_flag, _doppler_centroid_cubic_coeff, _estim_bit_error_rate, _first_processed_range_sample, _first_range_pixel_mid_az_inc, _first_rec_gain_read, _first_replica_sample, _first_side_lobe_lev_of_ACF, _first_side_lobe_level, _form_num_range_line_used, _I_channel_bias_correction, _I_channel_gain_correction, _I_gain_imb_lower_bound, _I_gain_imb_upper_bound, _I_Q_quad_depar_lower_bound, _I_Q_quad_depar_upper_bound, _initial_doppler_ambiguity_num, _inp_data_I_mean, _inp_data_I_stddev, _inp_data_Q_mean, _inp_data_Q_stddev, _inp_data_stat_flag, _inp_state_vect_pos_X_comp, _inp_state_vect_pos_Y_comp, _inp_state_vect_pos_Z_comp, _inp_state_vect_vel_Vx_comp, _inp_state_vect_vel_Vy_comp, _inp_state_vect_vel_Vz_comp, _inp_state_vector_type_flag, _int_cal_utc, _ISLR_CCF_between_last, _ISLR_of_ACF, _K_gen_date, _K_vers_num, _last_range_pix_mid_az_inc, _last_release_cal_date, _last_release_qc_date, _look_detecion_flag, _look_scalar_gain_1, _look_scalar_gain_2, _look_scalar_gain_3, _look_scalar_gain_4, _look_scalar_gain_5, _look_scalar_gain_6, _look_scalar_gain_7, _look_scalar_gain_8, _low_bound_K, _max_error_range_line_timing, _max_value_look_scalar_gain, _mean_cal_pulse_power, _mean_noise_power, _missing_lines, _noise_power, _norm_ref_range_ro, _num_azimuth_blocks_proc, _num_duplic_input_lines, _num_input_raw_data_lines, _num_range_samp_discarded, _num_valid_cal_pulses, _num_valid_noise_pulses, _num_valid_pixels_per_range, _num_valid_replicas, _OGOB_flag, _out_image_max_value, _out_image_mean, _out_image_std_dev, _out_pixel_bit_length, _outp_data_mean_flag, _peak_loc_CCF_betw_last, _peak_loc_cross_correl_fun, _PRF_changes, _prf_code_change_flag, _PRF_code_first_range_line, _PRF_code_last_range_line, _proc_gain_param_1, _proc_gain_param_2, _proc_gain_param_3, _proc_noise_scale_fact, _pulse_width_of_ACF_3db, _Q_channel_bias_correction, _Q_channel_gain_correction, _Q_channel_I_Q_correction, _qa_summary_flag, _quirp_qu_flag, _range_comp_norm_fact, _range_lines_skip_factor, _range_spread_loss_comp_flag, _range_time_origin_ant, _raw_data_correction_flag, _rec_gain_changes, _receiver_gain_last_proc, _replica_norm_method_flag, _replica_power, _Roll_Tilt_Mode_flag, _samp_win_start_first, _samp_win_start_last, _samp_window_start_time_bias, _samples_per_line_used, _sampling_win_change_flag, _sampling_win_changes, _sat_binary_time_of_first, _thresh_no_10_flag, _thresh_no_11_flag, _thresh_no_1_flag, _thresh_no_2_flag, _thresh_no_3_flag, _thresh_no_4_flag, _thresh_no_5_flag, _thresh_no_6_flag, _thresh_no_7_flag, _thresh_no_8_flag, _thresh_no_9_flag, _time_asc_node_state_vectors, _time_of_inp_state_vectors, _time_raw_data_first_input, _update_period_range_match, _upp_bound_K, _win_coeff_for_azi_match, and _win_coeff_for_range_match.
1009  {
1010  _last_release_qc_date = rhs._last_release_qc_date;
1011  _last_release_cal_date = rhs._last_release_cal_date;
1012  _qa_summary_flag = rhs._qa_summary_flag;
1013  _prf_code_change_flag = rhs._prf_code_change_flag;
1014  _sampling_win_change_flag = rhs._sampling_win_change_flag;
1015  _cal_gain_change_flag = rhs._cal_gain_change_flag;
1016  _quirp_qu_flag = rhs._quirp_qu_flag;
1017  _inp_data_stat_flag = rhs._inp_data_stat_flag;
1018  _dopp_cent_conf_meas_flag = rhs._dopp_cent_conf_meas_flag;
1019  _dopp_cent_val_flag = rhs._dopp_cent_val_flag;
1020  _dopp_ambig_conf_meas_flag = rhs._dopp_ambig_conf_meas_flag;
1021  _outp_data_mean_flag = rhs._outp_data_mean_flag;
1022  _OGOB_flag = rhs._OGOB_flag;
1023  _PRF_changes = rhs._PRF_changes;
1024  _sampling_win_changes = rhs._sampling_win_changes;
1025  _cal_gain_changes = rhs._cal_gain_changes;
1026  _missing_lines = rhs._missing_lines;
1027  _rec_gain_changes = rhs._rec_gain_changes;
1028  _pulse_width_of_ACF_3db = rhs._pulse_width_of_ACF_3db;
1029  _first_side_lobe_lev_of_ACF = rhs._first_side_lobe_lev_of_ACF;
1030  _ISLR_of_ACF = rhs._ISLR_of_ACF;
1031  _dopp_cent_conf_meas = rhs._dopp_cent_conf_meas;
1032  _dopp_ambig_conf_meas = rhs._dopp_ambig_conf_meas;
1033  _inp_data_I_mean = rhs._inp_data_I_mean;
1034  _inp_data_Q_mean = rhs._inp_data_Q_mean;
1035  _inp_data_I_stddev = rhs._inp_data_I_stddev;
1036  _inp_data_Q_stddev = rhs._inp_data_Q_stddev;
1037  _cal_sys_gain = rhs._cal_sys_gain;
1038  _first_rec_gain_read = rhs._first_rec_gain_read;
1039  _dopp_ambig_num = rhs._dopp_ambig_num;
1040  _I_channel_bias_correction = rhs._I_channel_bias_correction;
1041  _Q_channel_bias_correction = rhs._Q_channel_bias_correction;
1042  _I_channel_gain_correction = rhs._I_channel_gain_correction;
1043  _Q_channel_gain_correction = rhs._Q_channel_gain_correction;
1044  _Q_channel_I_Q_correction = rhs._Q_channel_I_Q_correction;
1045  _noise_power = rhs._noise_power;
1046  _int_cal_utc = rhs._int_cal_utc;
1047  _num_valid_cal_pulses = rhs._num_valid_cal_pulses;
1048  _num_valid_noise_pulses = rhs._num_valid_noise_pulses;
1049  _num_valid_replicas = rhs._num_valid_replicas;
1050  _first_replica_sample = rhs._first_replica_sample;
1051  _mean_cal_pulse_power = rhs._mean_cal_pulse_power;
1052  _mean_noise_power = rhs._mean_noise_power;
1053  _range_comp_norm_fact = rhs._range_comp_norm_fact;
1054  _replica_power = rhs._replica_power;
1055  _first_range_pixel_mid_az_inc = rhs._first_range_pixel_mid_az_inc;
1056  _center_range_pix_mid_az_inc = rhs._center_range_pix_mid_az_inc;
1057  _last_range_pix_mid_az_inc = rhs._last_range_pix_mid_az_inc;
1058  _norm_ref_range_ro = rhs._norm_ref_range_ro;
1059  _antenna_elev_flag = rhs._antenna_elev_flag;
1060  _abs_cal_const_K = rhs._abs_cal_const_K;
1061  _upp_bound_K = rhs._upp_bound_K;
1062  _low_bound_K = rhs._low_bound_K;
1063  _proc_noise_scale_fact = rhs._proc_noise_scale_fact;
1064  _K_gen_date = rhs._K_gen_date;
1065  _K_vers_num = rhs._K_vers_num;
1066  _num_duplic_input_lines = rhs._num_duplic_input_lines;
1067  _estim_bit_error_rate = rhs._estim_bit_error_rate;
1068  _out_image_mean = rhs._out_image_mean;
1069  _out_image_std_dev = rhs._out_image_std_dev;
1070  _out_image_max_value = rhs._out_image_max_value;
1071  _time_raw_data_first_input = rhs._time_raw_data_first_input;
1072  _time_asc_node_state_vectors = rhs._time_asc_node_state_vectors;
1073  _asc_node_pos_X_comp = rhs._asc_node_pos_X_comp;
1074  _asc_node_pos_Y_comp = rhs._asc_node_pos_Y_comp;
1075  _asc_node_pos_Z_comp = rhs._asc_node_pos_Z_comp;
1076  _asc_node_vel_X_comp = rhs._asc_node_vel_X_comp;
1077  _asc_node_vel_Y_comp = rhs._asc_node_vel_Y_comp;
1078  _asc_node_vel_Z_comp = rhs._asc_node_vel_Z_comp;
1079  _out_pixel_bit_length = rhs._out_pixel_bit_length;
1080  _proc_gain_param_1 = rhs._proc_gain_param_1;
1081  _proc_gain_param_2 = rhs._proc_gain_param_2;
1082  _proc_gain_param_3 = rhs._proc_gain_param_3;
1083  _peak_loc_cross_correl_fun = rhs._peak_loc_cross_correl_fun;
1084  _3_dB_width_CCF = rhs._3_dB_width_CCF;
1085  _first_side_lobe_level = rhs._first_side_lobe_level;
1086  _ISLR_CCF_between_last = rhs._ISLR_CCF_between_last;
1087  _peak_loc_CCF_betw_last = rhs._peak_loc_CCF_betw_last;
1088  _Roll_Tilt_Mode_flag = rhs._Roll_Tilt_Mode_flag;
1089  _raw_data_correction_flag = rhs._raw_data_correction_flag;
1090  _look_detecion_flag = rhs._look_detecion_flag;
1091  _doppler_ambiguity_estimat_flag = rhs._doppler_ambiguity_estimat_flag;
1092  _azimuth_baseband_convers_flag = rhs._azimuth_baseband_convers_flag;
1093  _samples_per_line_used = rhs._samples_per_line_used;
1094  _range_lines_skip_factor = rhs._range_lines_skip_factor;
1095  _time_of_inp_state_vectors = rhs._time_of_inp_state_vectors;
1096  _inp_state_vect_pos_X_comp = rhs._inp_state_vect_pos_X_comp;
1097  _inp_state_vect_pos_Y_comp = rhs._inp_state_vect_pos_Y_comp;
1098  _inp_state_vect_pos_Z_comp = rhs._inp_state_vect_pos_Z_comp;
1099  _inp_state_vect_vel_Vx_comp = rhs._inp_state_vect_vel_Vx_comp;
1100  _inp_state_vect_vel_Vy_comp = rhs._inp_state_vect_vel_Vy_comp;
1101  _inp_state_vect_vel_Vz_comp = rhs._inp_state_vect_vel_Vz_comp;
1102  _inp_state_vector_type_flag = rhs._inp_state_vector_type_flag;
1103  _win_coeff_for_range_match = rhs._win_coeff_for_range_match;
1104  _win_coeff_for_azi_match = rhs._win_coeff_for_azi_match;
1105  _update_period_range_match = rhs._update_period_range_match;
1106  _look_scalar_gain_1 = rhs._look_scalar_gain_1;
1107  _look_scalar_gain_2 = rhs._look_scalar_gain_2;
1108  _look_scalar_gain_3 = rhs._look_scalar_gain_3;
1109  _look_scalar_gain_4 = rhs._look_scalar_gain_4;
1110  _look_scalar_gain_5 = rhs._look_scalar_gain_5;
1111  _look_scalar_gain_6 = rhs._look_scalar_gain_6;
1112  _look_scalar_gain_7 = rhs._look_scalar_gain_7;
1113  _look_scalar_gain_8 = rhs._look_scalar_gain_8;
1114  _samp_window_start_time_bias = rhs._samp_window_start_time_bias;
1115  _doppler_centroid_cubic_coeff = rhs._doppler_centroid_cubic_coeff;
1116  _PRF_code_first_range_line = rhs._PRF_code_first_range_line;
1117  _PRF_code_last_range_line = rhs._PRF_code_last_range_line;
1118  _samp_win_start_first = rhs._samp_win_start_first;
1119  _samp_win_start_last = rhs._samp_win_start_last;
1120  _cal_syst_gain_last_proc = rhs._cal_syst_gain_last_proc;
1121  _receiver_gain_last_proc = rhs._receiver_gain_last_proc;
1122  _first_processed_range_sample = rhs._first_processed_range_sample;
1123  _azimuth_FFT_IFFT_ratio = rhs._azimuth_FFT_IFFT_ratio;
1124  _num_azimuth_blocks_proc = rhs._num_azimuth_blocks_proc;
1125  _num_input_raw_data_lines = rhs._num_input_raw_data_lines;
1126  _initial_doppler_ambiguity_num = rhs._initial_doppler_ambiguity_num;
1127  _thresh_no_1_flag = rhs._thresh_no_1_flag;
1128  _thresh_no_2_flag = rhs._thresh_no_2_flag;
1129  _thresh_no_3_flag = rhs._thresh_no_3_flag;
1130  _thresh_no_4_flag = rhs._thresh_no_4_flag;
1131  _thresh_no_5_flag = rhs._thresh_no_5_flag;
1132  _thresh_no_6_flag = rhs._thresh_no_6_flag;
1133  _thresh_no_7_flag = rhs._thresh_no_7_flag;
1134  _thresh_no_8_flag = rhs._thresh_no_8_flag;
1135  _thresh_no_9_flag = rhs._thresh_no_9_flag;
1136  _thresh_no_10_flag = rhs._thresh_no_10_flag;
1137  _thresh_no_11_flag = rhs._thresh_no_11_flag;
1138  _sat_binary_time_of_first = rhs._sat_binary_time_of_first;
1139  _num_valid_pixels_per_range = rhs._num_valid_pixels_per_range;
1140  _num_range_samp_discarded = rhs._num_range_samp_discarded;
1141  _I_gain_imb_lower_bound = rhs._I_gain_imb_lower_bound;
1142  _I_gain_imb_upper_bound = rhs._I_gain_imb_upper_bound;
1143  _I_Q_quad_depar_lower_bound = rhs._I_Q_quad_depar_lower_bound;
1144  _I_Q_quad_depar_upper_bound = rhs._I_Q_quad_depar_upper_bound;
1145  _3_dB_look_bandwidth = rhs._3_dB_look_bandwidth;
1146  _3_dB_look_proc_dopp_bandw = rhs._3_dB_look_proc_dopp_bandw;
1147  _range_spread_loss_comp_flag = rhs._range_spread_loss_comp_flag;
1148  _datation_flag = rhs._datation_flag;
1149  _max_error_range_line_timing = rhs._max_error_range_line_timing;
1150  _form_num_range_line_used = rhs._form_num_range_line_used;
1151  _autom_look_scal_gain_flag = rhs._autom_look_scal_gain_flag;
1152  _max_value_look_scalar_gain = rhs._max_value_look_scalar_gain;
1153  _replica_norm_method_flag = rhs._replica_norm_method_flag;
1154  _coef_ground_range_1 = rhs._coef_ground_range_1;
1155  _coef_ground_range_2 = rhs._coef_ground_range_2;
1156  _coef_ground_range_3 = rhs._coef_ground_range_3;
1157  _coef_ground_range_4 = rhs._coef_ground_range_4;
1158  _coef_ant_elev_1 = rhs._coef_ant_elev_1;
1159  _coef_ant_elev_2 = rhs._coef_ant_elev_2;
1160  _coef_ant_elev_3 = rhs._coef_ant_elev_3;
1161  _coef_ant_elev_4 = rhs._coef_ant_elev_4;
1162  _coef_ant_elev_5 = rhs._coef_ant_elev_5;
1163  _range_time_origin_ant = rhs._range_time_origin_ant;
1164
1165  return *this;
1166  }
int _dopp_cent_conf_meas_flag
int _samples_per_line_used
double _range_time_origin_ant
double _win_coeff_for_azi_match
int _PRF_code_first_range_line
int _max_value_look_scalar_gain
double _Q_channel_I_Q_correction
double _coef_ground_range_4
coef_ground_range_4
double _dopp_cent_conf_meas
dopp_cent_conf_meas
int _receiver_gain_last_proc
int _num_duplic_input_lines
std::string _inp_state_vect_pos_Z_comp
std::string _inp_state_vect_vel_Vz_comp
double _estim_bit_error_rate
int _raw_data_correction_flag
int _sat_binary_time_of_first
double _3_dB_look_proc_dopp_bandw
int _num_range_samp_discarded
int _sampling_win_change_flag
std::string _time_asc_node_state_vectors
double _I_channel_bias_correction
int _doppler_ambiguity_estimat_flag
int _num_valid_noise_pulses
std::string _asc_node_vel_X_comp
asc_node_vel_X_comp
int _num_azimuth_blocks_proc
int _update_period_range_match
std::string _asc_node_pos_X_comp
asc_node_pos_X_comp
std::string _time_raw_data_first_input
double _3_dB_look_bandwidth
3_dB_look_bandwidth
std::string _last_release_cal_date
double _coef_ground_range_3
coef_ground_range_3
int _num_valid_pixels_per_range
double _coef_ground_range_2
coef_ground_range_2
int _range_lines_skip_factor
std::string _inp_state_vect_vel_Vx_comp
double _I_gain_imb_upper_bound
double _first_replica_sample
int _peak_loc_CCF_betw_last
double _first_side_lobe_level
double _I_Q_quad_depar_lower_bound
int _replica_norm_method_flag
int _dopp_ambig_conf_meas_flag
double _center_range_pix_mid_az_inc
int _initial_doppler_ambiguity_num
double _proc_noise_scale_fact
int _peak_loc_cross_correl_fun
std::string _time_of_inp_state_vectors
int _inp_state_vector_type_flag
double _I_channel_gain_correction
int _samp_window_start_time_bias
double _ISLR_CCF_between_last
double _I_gain_imb_lower_bound
double _first_side_lobe_lev_of_ACF
int _range_spread_loss_comp_flag
int _num_input_raw_data_lines
double _doppler_centroid_cubic_coeff
double _first_range_pixel_mid_az_inc
double _win_coeff_for_range_match
double _coef_ground_range_1
coef_ground_range_1
int _max_error_range_line_timing
int _azimuth_FFT_IFFT_ratio
std::string _asc_node_pos_Y_comp
asc_node_pos_Y_comp
bool _autom_look_scal_gain_flag
double _Q_channel_bias_correction
double _out_image_max_value
out_image_max_value
std::string _asc_node_vel_Z_comp
asc_node_vel_Z_comp
double _Q_channel_gain_correction
std::string _asc_node_vel_Y_comp
asc_node_vel_Y_comp
int _cal_syst_gain_last_proc
double _dopp_ambig_conf_meas
int _first_processed_range_sample
int _PRF_code_last_range_line
double _I_Q_quad_depar_upper_bound
std::string _inp_state_vect_vel_Vy_comp
double _range_comp_norm_fact
std::string _asc_node_pos_Z_comp
asc_node_pos_Z_comp
double _first_rec_gain_read
first_rec_gain_read
std::string _last_release_qc_date
std::string _inp_state_vect_pos_Y_comp
double _last_range_pix_mid_az_inc
int _form_num_range_line_used
int _azimuth_baseband_convers_flag
std::string _inp_state_vect_pos_X_comp
double _mean_cal_pulse_power
double _pulse_width_of_ACF_3db
◆ Read()
void ossimplugins::AlosPalsarFacilityData::Read ( std::istream &  is)
inlinevirtual
Read the class data from a stream.
Definition at line 80 of file AlosPalsarFacilityData.h.
81  {
82  is >> *this;
83  };
◆ Write()
void ossimplugins::AlosPalsarFacilityData::Write ( std::ostream &  os)
inlinevirtual
Write the class to a stream.
Definition at line 88 of file AlosPalsarFacilityData.h.
89  {
90  os << *this;
91  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const AlosPalsarFacilityData data
friend
This function write the AlosPalsarFacilityData in a stream.
Definition at line 26 of file AlosPalsarFacilityData.cpp.
27  {
28  os << "last_release_qc_date:" << data._last_release_qc_date.c_str() << std::endl;
29
30  os << "last_release_cal_date:" << data._last_release_cal_date.c_str() << std::endl;
31
32  os << "qa_summary_flag:" << data._qa_summary_flag << std::endl;
33
34  os << "prf_code_change_flag:" << data._prf_code_change_flag << std::endl;
35
36  os << "sampling_win_change_flag:" << data._sampling_win_change_flag << std::endl;
37
38  os << "cal_gain_change_flag:" << data._cal_gain_change_flag << std::endl;
39
40  os << "quirp_qu_flag:" << data._quirp_qu_flag << std::endl;
41
42  os << "inp_data_stat_flag:" << data._inp_data_stat_flag << std::endl;
43
44  os << "dopp_cent_conf_meas_flag:" << data._dopp_cent_conf_meas_flag << std::endl;
45
46  os << "dopp_cent_val_flag:" << data._dopp_cent_val_flag << std::endl;
47
48  os << "dopp_ambig_conf_meas_flag:" << data._dopp_ambig_conf_meas_flag << std::endl;
49
50  os << "outp_data_mean_flag:" << data._outp_data_mean_flag << std::endl;
51
52  os << "OGOB_flag:" << data._OGOB_flag << std::endl;
53
54  os << "PRF_changes:" << data._PRF_changes << std::endl;
55
56  os << "sampling_win_changes:" << data._sampling_win_changes << std::endl;
57
58  os << "cal_gain_changes:" << data._cal_gain_changes << std::endl;
59
60  os << "missing_lines:" << data._missing_lines << std::endl;
61
62  os << "rec_gain_changes:" << data._rec_gain_changes << std::endl;
63
64  os << "pulse_width_of_ACF_3db:" << data._pulse_width_of_ACF_3db << std::endl;
65
66  os << "first_side_lobe_lev_of_ACF:" << data._first_side_lobe_lev_of_ACF << std::endl;
67
68  os << "ISLR_of_ACF:" << data._ISLR_of_ACF << std::endl;
69
70  os << "dopp_cent_conf_meas:" << data._dopp_cent_conf_meas << std::endl;
71
72  os << "dopp_ambig_conf_meas:" << data._dopp_ambig_conf_meas << std::endl;
73
74  os << "inp_data_I_mean:" << data._inp_data_I_mean << std::endl;
75
76  os << "inp_data_Q_mean:" << data._inp_data_Q_mean << std::endl;
77
78  os << "inp_data_I_stddev:" << data._inp_data_I_stddev << std::endl;
79
80  os << "inp_data_Q_stddev:" << data._inp_data_Q_stddev << std::endl;
81
82  os << "cal_sys_gain:" << data._cal_sys_gain << std::endl;
83
84  os << "first_rec_gain_read:" << data._first_rec_gain_read << std::endl;
85
86  os << "dopp_ambig_num:" << data._dopp_ambig_num << std::endl;
87
88  os << "I_channel_bias_correction:" << data._I_channel_bias_correction << std::endl;
89
90  os << "Q_channel_bias_correction:" << data._Q_channel_bias_correction << std::endl;
91
92  os << "I_channel_gain_correction:" << data._I_channel_gain_correction << std::endl;
93
94  os << "Q_channel_gain_correction:" << data._Q_channel_gain_correction << std::endl;
95
96  os << "Q_channel_I_Q_correction:" << data._Q_channel_I_Q_correction << std::endl;
97
98  os << "noise_power:" << data._noise_power << std::endl;
99
100  os << "int_cal_utc:" << data._int_cal_utc << std::endl;
101
102  os << "num_valid_cal_pulses:" << data._num_valid_cal_pulses << std::endl;
103
104  os << "num_valid_noise_pulses:" << data._num_valid_noise_pulses << std::endl;
105
106  os << "num_valid_replicas:" << data._num_valid_replicas << std::endl;
107
108  os << "first_replica_sample:" << data._first_replica_sample << std::endl;
109
110  os << "mean_cal_pulse_power:" << data._mean_cal_pulse_power << std::endl;
111
112  os << "mean_noise_power:" << data._mean_noise_power << std::endl;
113
114  os << "range_comp_norm_fact:" << data._range_comp_norm_fact << std::endl;
115
116  os << "replica_power:" << data._replica_power << std::endl;
117
118  os << "first_range_pixel_mid_az_inc:" << data._first_range_pixel_mid_az_inc << std::endl;
119
120  os << "center_range_pix_mid_az_inc:" << data._center_range_pix_mid_az_inc << std::endl;
121
122  os << "last_range_pix_mid_az_inc:" << data._last_range_pix_mid_az_inc << std::endl;
123
124  os << "norm_ref_range_ro:" << data._norm_ref_range_ro << std::endl;
125
126  os << "antenna_elev_flag:" << data._antenna_elev_flag << std::endl;
127
128  os << "abs_cal_const_K:" << data._abs_cal_const_K << std::endl;
129
130  os << "upp_bound_K:" << data._upp_bound_K << std::endl;
131
132  os << "low_bound_K:" << data._low_bound_K << std::endl;
133
134  os << "proc_noise_scale_fact:" << data._proc_noise_scale_fact << std::endl;
135
136  os << "K_gen_date:" << data._K_gen_date.c_str() << std::endl;
137
138  os << "K_vers_num:" << data._K_vers_num.c_str() << std::endl;
139
140  os << "num_duplic_input_lines:" << data._num_duplic_input_lines << std::endl;
141
142  os << "estim_bit_error_rate:" << data._estim_bit_error_rate << std::endl;
143
144  os << "out_image_mean:" << data._out_image_mean << std::endl;
145
146  os << "out_image_std_dev:" << data._out_image_std_dev << std::endl;
147
148  os << "out_image_max_value:" << data._out_image_max_value << std::endl;
149
150  os << "time_raw_data_first_input:" << data._time_raw_data_first_input.c_str() << std::endl;
151
152  os << "time_asc_node_state_vectors:" << data._time_asc_node_state_vectors.c_str() << std::endl;
153
154  os << "asc_node_pos_X_comp:" << data._asc_node_pos_X_comp.c_str() << std::endl;
155
156  os << "asc_node_pos_Y_comp:" << data._asc_node_pos_Y_comp.c_str() << std::endl;
157
158  os << "asc_node_pos_Z_comp:" << data._asc_node_pos_Z_comp.c_str() << std::endl;
159
160  os << "asc_node_vel_X_comp:" << data._asc_node_vel_X_comp.c_str() << std::endl;
161
162  os << "asc_node_vel_Y_comp:" << data._asc_node_vel_Y_comp.c_str() << std::endl;
163
164  os << "asc_node_vel_Z_comp:" << data._asc_node_vel_Z_comp.c_str() << std::endl;
165
166  os << "out_pixel_bit_length:" << data._out_pixel_bit_length << std::endl;
167
168  os << "proc_gain_param_1:" << data._proc_gain_param_1 << std::endl;
169
170  os << "proc_gain_param_2:" << data._proc_gain_param_2 << std::endl;
171
172  os << "proc_gain_param_3:" << data._proc_gain_param_3 << std::endl;
173
174  os << "peak_loc_cross_correl_fun:" << data._peak_loc_cross_correl_fun << std::endl;
175
176  os << "3_dB_width_CCF:" << data._3_dB_width_CCF << std::endl;
177
178  os << "first_side_lobe_level:" << data._first_side_lobe_level << std::endl;
179
180  os << "ISLR_CCF_between_last:" << data._ISLR_CCF_between_last << std::endl;
181
182  os << "peak_loc_CCF_betw_last:" << data._peak_loc_CCF_betw_last << std::endl;
183
184  os << "Roll_Tilt_Mode_flag:" << data._Roll_Tilt_Mode_flag << std::endl;
185
186  os << "raw_data_correction_flag:" << data._raw_data_correction_flag << std::endl;
187
188  os << "look_detecion_flag:" << data._look_detecion_flag << std::endl;
189
190  os << "doppler_ambiguity_estimat_flag:" << data._doppler_ambiguity_estimat_flag << std::endl;
191
192  os << "azimuth_baseband_convers_flag:" << data._azimuth_baseband_convers_flag << std::endl;
193
194  os << "samples_per_line_used:" << data._samples_per_line_used << std::endl;
195
196  os << "range_lines_skip_factor:" << data._range_lines_skip_factor << std::endl;
197
198  os << "time_of_inp_state_vectors:" << data._time_of_inp_state_vectors.c_str() << std::endl;
199
200  os << "inp_state_vect_pos_X_comp:" << data._inp_state_vect_pos_X_comp.c_str() << std::endl;
201
202  os << "inp_state_vect_pos_Y_comp:" << data._inp_state_vect_pos_Y_comp.c_str() << std::endl;
203
204  os << "inp_state_vect_pos_Z_comp:" << data._inp_state_vect_pos_Z_comp.c_str() << std::endl;
205
206  os << "inp_state_vect_vel_Vx_comp:" << data._inp_state_vect_vel_Vx_comp.c_str() << std::endl;
207
208  os << "inp_state_vect_vel_Vy_comp:" << data._inp_state_vect_vel_Vy_comp.c_str() << std::endl;
209
210  os << "inp_state_vect_vel_Vz_comp:" << data._inp_state_vect_vel_Vz_comp.c_str() << std::endl;
211
212  os << "inp_state_vector_type_flag:" << data._inp_state_vector_type_flag << std::endl;
213
214  os << "win_coeff_for_range_match:" << data._win_coeff_for_range_match << std::endl;
215
216  os << "win_coeff_for_azi_match:" << data._win_coeff_for_azi_match << std::endl;
217
218  os << "update_period_range_match:" << data._update_period_range_match << std::endl;
219
220  os << "look_scalar_gain_1:" << data._look_scalar_gain_1 << std::endl;
221
222  os << "look_scalar_gain_2:" << data._look_scalar_gain_2 << std::endl;
223
224  os << "look_scalar_gain_3:" << data._look_scalar_gain_3 << std::endl;
225
226  os << "look_scalar_gain_4:" << data._look_scalar_gain_4 << std::endl;
227
228  os << "look_scalar_gain_5:" << data._look_scalar_gain_5 << std::endl;
229
230  os << "look_scalar_gain_6:" << data._look_scalar_gain_6 << std::endl;
231
232  os << "look_scalar_gain_7:" << data._look_scalar_gain_7 << std::endl;
233
234  os << "look_scalar_gain_8:" << data._look_scalar_gain_8 << std::endl;
235
236  os << "samp_window_start_time_bias:" << data._samp_window_start_time_bias << std::endl;
237
238  os << "doppler_centroid_cubic_coeff:" << data._doppler_centroid_cubic_coeff << std::endl;
239
240  os << "PRF_code_first_range_line:" << data._PRF_code_first_range_line << std::endl;
241
242  os << "PRF_code_last_range_line:" << data._PRF_code_last_range_line << std::endl;
243
244  os << "samp_win_start_first:" << data._samp_win_start_first << std::endl;
245
246  os << "samp_win_start_last:" << data._samp_win_start_last << std::endl;
247
248  os << "cal_syst_gain_last_proc:" << data._cal_syst_gain_last_proc << std::endl;
249
250  os << "receiver_gain_last_proc:" << data._receiver_gain_last_proc << std::endl;
251
252  os << "first_processed_range_sample:" << data._first_processed_range_sample << std::endl;
253
254  os << "azimuth_FFT_IFFT_ratio:" << data._azimuth_FFT_IFFT_ratio << std::endl;
255
256  os << "num_azimuth_blocks_proc:" << data._num_azimuth_blocks_proc << std::endl;
257
258  os << "num_input_raw_data_lines:" << data._num_input_raw_data_lines << std::endl;
259
260  os << "initial_doppler_ambiguity_num:" << data._initial_doppler_ambiguity_num << std::endl;
261
262  os << "thresh_no_1_flag:" << data._thresh_no_1_flag << std::endl;
263
264  os << "thresh_no_2_flag:" << data._thresh_no_2_flag << std::endl;
265
266  os << "thresh_no_3_flag:" << data._thresh_no_3_flag << std::endl;
267
268  os << "thresh_no_4_flag:" << data._thresh_no_4_flag << std::endl;
269
270  os << "thresh_no_5_flag:" << data._thresh_no_5_flag << std::endl;
271
272  os << "thresh_no_6_flag:" << data._thresh_no_6_flag << std::endl;
273
274  os << "thresh_no_7_flag:" << data._thresh_no_7_flag << std::endl;
275
276  os << "thresh_no_8_flag:" << data._thresh_no_8_flag << std::endl;
277
278  os << "thresh_no_9_flag:" << data._thresh_no_9_flag << std::endl;
279
280  os << "thresh_no_10_flag:" << data._thresh_no_10_flag << std::endl;
281
282  os << "thresh_no_11_flag:" << data._thresh_no_11_flag << std::endl;
283
284  os << "sat_binary_time_of_first:" << data._sat_binary_time_of_first << std::endl;
285
286  os << "num_valid_pixels_per_range:" << data._num_valid_pixels_per_range << std::endl;
287
288  os << "num_range_samp_discarded:" << data._num_range_samp_discarded << std::endl;
289
290  os << "I_gain_imb_lower_bound:" << data._I_gain_imb_lower_bound << std::endl;
291
292  os << "I_gain_imb_upper_bound:" << data._I_gain_imb_upper_bound << std::endl;
293
294  os << "I_Q_quad_depar_lower_bound:" << data._I_Q_quad_depar_lower_bound << std::endl;
295
296  os << "I_Q_quad_depar_upper_bound:" << data._I_Q_quad_depar_upper_bound << std::endl;
297
298  os << "3_dB_look_bandwidth:" << data._3_dB_look_bandwidth << std::endl;
299
300  os << "3_dB_look_proc_dopp_bandw:" << data._3_dB_look_proc_dopp_bandw << std::endl;
301
302  os << "range_spread_loss_comp_flag:" << data._range_spread_loss_comp_flag << std::endl;
303
304  os << "datation_flag:" << data._datation_flag << std::endl;
305
306  os << "max_error_range_line_timing:" << data._max_error_range_line_timing << std::endl;
307
308  os << "form_num_range_line_used:" << data._form_num_range_line_used << std::endl;
309
310  os << "autom_look_scal_gain_flag:" << data._autom_look_scal_gain_flag << std::endl;
311
312  os << "max_value_look_scalar_gain:" << data._max_value_look_scalar_gain << std::endl;
313
314  os << "replica_norm_method_flag:" << data._replica_norm_method_flag << std::endl;
315
316  os << "coef_ground_range_1:" << data._coef_ground_range_1 << std::endl;
317
318  os << "coef_ground_range_2:" << data._coef_ground_range_2 << std::endl;
319
320  os << "coef_ground_range_3:" << data._coef_ground_range_3 << std::endl;
321
322  os << "coef_ground_range_4:" << data._coef_ground_range_4 << std::endl;
323
324  os << "coef_ant_elev_1:" << data._coef_ant_elev_1 << std::endl;
325
326  os << "coef_ant_elev_2:" << data._coef_ant_elev_2 << std::endl;
327
328  os << "coef_ant_elev_3:" << data._coef_ant_elev_3 << std::endl;
329
330  os << "coef_ant_elev_4:" << data._coef_ant_elev_4 << std::endl;
331
332  os << "coef_ant_elev_5:" << data._coef_ant_elev_5 << std::endl;
333
334  os << "range_time_origin_ant:" << data._range_time_origin_ant << std::endl;
335
336  return os;
337
338  }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
This function read a AlosPalsarFacilityData from a stream.
Definition at line 340 of file AlosPalsarFacilityData.cpp.
341  {
342  char buf64[65];
343  buf64[64] = '\0';
344  char buf32[33];
345  buf32[32] = '\0';
346  char buf24[25];
347  buf24[24] = '\0';
348  char buf22[23];
349  buf22[22] = '\0';
350  char buf20[21];
351  buf20[20] = '\0';
352  char buf16[17];
353  buf16[16] = '\0';
354  char buf12[13];
355  buf12[12] = '\0';
356  char buf7[8];
357  buf7[7] = '\0';
358  char buf8[9];
359  buf8[8] = '\0';
360  char buf6[7];
361  buf6[6] = '\0';
362  char buf4[5];
363  buf4[4] = '\0';
364  char buf2[3];
365  buf2[2] = '\0';
366  char buf1[2];
367  buf1[1] = '\0';
368
369  is.read(buf64, 64);
370  data._name_of_facil_rec = buf64;
371
372  is.read(buf6, 6);
373  data._last_release_qc_date = buf6;
374
375  is.read(buf2, 2);
376
377  is.read(buf6, 6);
378  data._last_release_cal_date = buf6;
379
380  is.read(buf4, 4);
381  data._qa_summary_flag = atoi(buf4);
382
383  is.read(buf4, 4);
384  data._prf_code_change_flag = atoi(buf4);
385
386  is.read(buf4, 4);
387  data._sampling_win_change_flag = atoi(buf4);
388
389  is.read(buf4, 4);
390  data._cal_gain_change_flag = atoi(buf4);
391
392  is.read(buf4, 4);
393  data._quirp_qu_flag = atoi(buf4);
394
395  is.read(buf4, 4);
396  data._inp_data_stat_flag = atoi(buf4);
397
398  is.read(buf4, 4);
399  data._dopp_cent_conf_meas_flag = atoi(buf4);
400
401  is.read(buf4, 4);
402  data._dopp_cent_val_flag = atoi(buf4);
403
404  is.read(buf4, 4);
405  data._dopp_ambig_conf_meas_flag = atoi(buf4);
406
407  is.read(buf4, 4);
408  data._outp_data_mean_flag = atoi(buf4);
409
410  is.read(buf4, 4);
411  data._OGOB_flag = atoi(buf4);
412
413  is.read(buf4, 4);
414  data._PRF_changes = atoi(buf4);
415
416  is.read(buf4, 4);
417  data._sampling_win_changes = atoi(buf4);
418
419  is.read(buf4, 4);
420  data._cal_gain_changes = atoi(buf4);
421
422  is.read(buf4, 4);
423  data._missing_lines = atoi(buf4);
424
425  is.read(buf4, 4);
426  data._rec_gain_changes = atoi(buf4);
427
428  is.read(buf16, 16);
429  data._pulse_width_of_ACF_3db = atof(buf16);
430
431  is.read(buf16, 16);
432  data._first_side_lobe_lev_of_ACF = atof(buf16);
433
434  is.read(buf16, 16);
435  data._ISLR_of_ACF = atof(buf16);
436
437  is.read(buf16, 16);
438  data._dopp_cent_conf_meas = atof(buf16);
439
440  is.read(buf16, 16);
441  data._dopp_ambig_conf_meas = atof(buf16);
442
443  is.read(buf16, 16);
444  data._inp_data_I_mean = atof(buf16);
445
446  is.read(buf16, 16);
447  data._inp_data_Q_mean = atof(buf16);
448
449  is.read(buf16, 16);
450  data._inp_data_I_stddev = atof(buf16);
451
452  is.read(buf16, 16);
453  data._inp_data_Q_stddev = atof(buf16);
454
455  is.read(buf16, 16);
456  data._cal_sys_gain = atof(buf16);
457
458  is.read(buf16, 16);
459  data._first_rec_gain_read = atof(buf16);
460
461  is.read(buf16, 16);
462  data._dopp_ambig_num = atof(buf16);
463
464  is.read(buf16, 16);
465
466  is.read(buf16, 16);
467  data._I_channel_bias_correction = atof(buf16);
468
469  is.read(buf16, 16);
470  data._Q_channel_bias_correction = atof(buf16);
471
472  is.read(buf16, 16);
473  data._I_channel_gain_correction = atof(buf16);
474
475  is.read(buf16, 16);
476  data._Q_channel_gain_correction = atof(buf16);
477
478  is.read(buf16, 16);
479  data._Q_channel_I_Q_correction = atof(buf16);
480
481  is.read(buf16, 16);
482
483  is.read(buf16, 16);
484  data._noise_power = atof(buf16);
485
486  is.read(buf16, 16);
487  data._int_cal_utc = atoi(buf16);
488
489  is.read(buf4, 4);
490  data._num_valid_cal_pulses = atoi(buf4);
491
492  is.read(buf4, 4);
493  data._num_valid_noise_pulses = atoi(buf4);
494
495  is.read(buf4, 4);
496  data._num_valid_replicas = atoi(buf4);
497
498  is.read(buf16, 16);
499  data._first_replica_sample = atof(buf16);
500
501  is.read(buf16, 16);
502  data._mean_cal_pulse_power = atof(buf16);
503
504  is.read(buf16, 16);
505  data._mean_noise_power = atof(buf16);
506
507  is.read(buf16, 16);
508  data._range_comp_norm_fact = atof(buf16);
509
510  is.read(buf16, 16);
511  data._replica_power = atof(buf16);
512
513  is.read(buf16, 16);
514  data._first_range_pixel_mid_az_inc = atof(buf16);
515
516  is.read(buf16, 16);
517  data._center_range_pix_mid_az_inc = atof(buf16);
518
519  is.read(buf16, 16);
520  data._last_range_pix_mid_az_inc = atof(buf16);
521
522  is.read(buf16, 16);
523  data._norm_ref_range_ro = atof(buf16);
524
525  is.read(buf12, 12);
526
527  is.read(buf4, 4);
528  data._antenna_elev_flag = atoi(buf4);
529
530  is.read(buf16, 16);
531  data._abs_cal_const_K = atof(buf16);
532
533  is.read(buf16, 16);
534  data._upp_bound_K = atof(buf16);
535
536  is.read(buf16, 16);
537  data._low_bound_K = atof(buf16);
538
539  is.read(buf16, 16);
540  data._proc_noise_scale_fact = atof(buf16);
541
542  is.read(buf6, 6);
543  data._K_gen_date = buf6;
544
545  is.read(buf4, 4);
546  data._K_vers_num = buf4;
547
548  is.read(buf4, 4);
549  data._num_duplic_input_lines = atoi(buf4);
550
551  is.read(buf16, 16);
552  data._estim_bit_error_rate = atof(buf16);
553
554  is.read(buf12, 12);
555
556  is.read(buf16, 16);
557  data._out_image_mean = atof(buf16);
558
559  is.read(buf16, 16);
560  data._out_image_std_dev = atof(buf16);
561
562  is.read(buf16, 16);
563  data._out_image_max_value = atof(buf16);
564
565  is.read(buf24, 24);
566  data._time_raw_data_first_input = buf24;
567
568  is.read(buf24, 24);
569  data._time_asc_node_state_vectors = buf24;
570
571  is.read(buf22, 22);
572  data._asc_node_pos_X_comp = buf22;
573
574  is.read(buf22, 22);
575  data._asc_node_pos_Y_comp = buf22;
576
577  is.read(buf22, 22);
578  data._asc_node_pos_Z_comp = buf22;
579
580  is.read(buf22, 22);
581  data._asc_node_vel_X_comp = buf22;
582
583  is.read(buf22, 22);
584  data._asc_node_vel_Y_comp = buf22;
585
586  is.read(buf22, 22);
587  data._asc_node_vel_Z_comp = buf22;
588
589  is.read(buf4, 4);
590  data._out_pixel_bit_length = atoi(buf4);
591
592  is.read(buf16, 16);
593  data._proc_gain_param_1 = atof(buf16);
594
595  is.read(buf16, 16);
596  data._proc_gain_param_2 = atof(buf16);
597
598  is.read(buf16, 16);
599  data._proc_gain_param_3 = atof(buf16);
600
601  is.read(buf4, 4);
602  data._peak_loc_cross_correl_fun = atoi(buf4);
603
604  is.read(buf16, 16);
605  data._3_dB_width_CCF = atof(buf16);
606
607  is.read(buf16, 16);
608  data._first_side_lobe_level = atof(buf16);
609
610  is.read(buf16, 16);
611  data._ISLR_CCF_between_last = atof(buf16);
612
613  is.read(buf4, 4);
614  data._peak_loc_CCF_betw_last = atoi(buf4);
615
616  is.read(buf4, 4);
617  data._Roll_Tilt_Mode_flag = atoi(buf4);
618
619  is.read(buf4, 4);
620  data._raw_data_correction_flag = atoi(buf4);
621
622  is.read(buf4, 4);
623  data._look_detecion_flag = atoi(buf4);
624
625  is.read(buf4, 4);
626  data._doppler_ambiguity_estimat_flag = atoi(buf4);
627
628  is.read(buf4, 4);
629  data._azimuth_baseband_convers_flag = atoi(buf4);
630
631  is.read(buf4, 4);
632  data._samples_per_line_used = atoi(buf4);
633
634  is.read(buf4, 4);
635  data._range_lines_skip_factor = atoi(buf4);
636
637  is.read(buf24, 24);
638  data._time_of_inp_state_vectors = buf24;
639
640  is.read(buf22, 22);
641  data._inp_state_vect_pos_X_comp = buf22;
642
643  is.read(buf22, 22);
644  data._inp_state_vect_pos_Y_comp = buf22;
645
646  is.read(buf22, 22);
647  data._inp_state_vect_pos_Z_comp = buf22;
648
649  is.read(buf22, 22);
650  data._inp_state_vect_vel_Vx_comp = buf22;
651
652  is.read(buf22, 22);
653  data._inp_state_vect_vel_Vy_comp = buf22;
654
655  is.read(buf22, 22);
656  data._inp_state_vect_vel_Vz_comp = buf22;
657
658  is.read(buf4, 4);
659  data._inp_state_vector_type_flag = atoi(buf4);
660
661  is.read(buf16, 16);
662  data._win_coeff_for_range_match = atof(buf16);
663
664  is.read(buf16, 16);
665  data._win_coeff_for_azi_match = atof(buf16);
666
667  is.read(buf4, 4);
668  data._update_period_range_match = atoi(buf4);
669
670  is.read(buf16, 16);
671  data._look_scalar_gain_1 = atof(buf16);
672
673  is.read(buf16, 16);
674  data._look_scalar_gain_2 = atof(buf16);
675
676  is.read(buf16, 16);
677  data._look_scalar_gain_3 = atof(buf16);
678
679  is.read(buf16, 16);
680  data._look_scalar_gain_4 = atof(buf16);
681
682  is.read(buf16, 16);
683  data._look_scalar_gain_5 = atof(buf16);
684
685  is.read(buf16, 16);
686  data._look_scalar_gain_6 = atof(buf16);
687
688  is.read(buf16, 16);
689  data._look_scalar_gain_7 = atof(buf16);
690
691  is.read(buf16, 16);
692  data._look_scalar_gain_8 = atof(buf16);
693
694  is.read(buf4, 4);
695  data._samp_window_start_time_bias = atoi(buf4);
696
697  is.read(buf22, 22);
698  data._doppler_centroid_cubic_coeff = atof(buf22);
699
700  is.read(buf4, 4);
701  data._PRF_code_first_range_line = atoi(buf4);
702
703  is.read(buf4, 4);
704  data._PRF_code_last_range_line = atoi(buf4);
705
706  is.read(buf4, 4);
707  data._samp_win_start_first = atoi(buf4);
708
709  is.read(buf4, 4);
710  data._samp_win_start_last = atoi(buf4);
711
712  is.read(buf4, 4);
713  data._cal_syst_gain_last_proc = atoi(buf4);
714
715  is.read(buf4, 4);
716  data._receiver_gain_last_proc = atoi(buf4);
717
718  is.read(buf4, 4);
719  data._first_processed_range_sample = atoi(buf4);
720
721  is.read(buf4, 4);
722  data._azimuth_FFT_IFFT_ratio = atoi(buf4);
723
724  is.read(buf4, 4);
725  data._num_azimuth_blocks_proc = atoi(buf4);
726
727  is.read(buf8, 8);
728  data._num_input_raw_data_lines = atol(buf8);
729
730  is.read(buf4, 4);
731  data._initial_doppler_ambiguity_num = atoi(buf4);
732
733  is.read(buf16, 16);
734  data._thresh_no_1_flag = atof(buf16);
735
736  is.read(buf16, 16);
737  data._thresh_no_2_flag = atof(buf16);
738
739  is.read(buf16, 16);
740  data._thresh_no_3_flag = atof(buf16);
741
742  is.read(buf16, 16);
743  data._thresh_no_4_flag = atof(buf16);
744
745  is.read(buf16, 16);
746  data._thresh_no_5_flag = atof(buf16);
747
748  is.read(buf16, 16);
749  data._thresh_no_6_flag = atof(buf16);
750
751  is.read(buf16, 16);
752  data._thresh_no_7_flag = atof(buf16);
753
754  is.read(buf16, 16);
755  data._thresh_no_8_flag = atof(buf16);
756
757  is.read(buf16, 16);
758  data._thresh_no_9_flag = atof(buf16);
759
760  is.read(buf16, 16);
761  data._thresh_no_10_flag = atof(buf16);
762
763  is.read(buf16, 16);
764  data._thresh_no_11_flag = atof(buf16);
765
766  is.read(buf16, 16);
767  data._sat_binary_time_of_first = atol(buf16);
768
769  is.read(buf4, 4);
770  data._num_valid_pixels_per_range = atoi(buf4);
771
772  is.read(buf4, 4);
773  data._num_range_samp_discarded = atoi(buf4);
774
775  is.read(buf16, 16);
776  data._I_gain_imb_lower_bound = atof(buf16);
777
778  is.read(buf16, 16);
779  data._I_gain_imb_upper_bound = atof(buf16);
780
781  is.read(buf16, 16);
782  data._I_Q_quad_depar_lower_bound = atof(buf16);
783
784  is.read(buf16, 16);
785  data._I_Q_quad_depar_upper_bound = atof(buf16);
786
787  is.read(buf16, 16);
788  data._3_dB_look_bandwidth = atof(buf16);
789
790  is.read(buf16, 16);
791  data._3_dB_look_proc_dopp_bandw = atof(buf16);
792
793  is.read(buf4, 4);
794  data._range_spread_loss_comp_flag = atoi(buf4);
795
796  is.read(buf1, 1);
797  data._datation_flag = atoi(buf1) != 0;
798
799  is.read(buf7, 7);
800  data._max_error_range_line_timing = atoi(buf7);
801
802  is.read(buf7, 7);
803  data._form_num_range_line_used = atoi(buf7);
804
805  is.read(buf1, 1);
806  data._autom_look_scal_gain_flag = atoi(buf1) != 0;
807
808  is.read(buf4, 4);
809  data._max_value_look_scalar_gain = atoi(buf4);
810
811  is.read(buf4, 4);
812  data._replica_norm_method_flag = atoi(buf4);
813
814  is.read(buf20, 20);
815  data._coef_ground_range_1 = atof(buf20);
816
817  is.read(buf20, 20);
818  data._coef_ground_range_2 = atof(buf20);
819
820  is.read(buf20, 20);
821  data._coef_ground_range_3 = atof(buf20);
822
823  is.read(buf20, 20);
824  data._coef_ground_range_4 = atof(buf20);
825
826  is.read(buf20, 20);
827  data._coef_ant_elev_1 = atof(buf20);
828
829  is.read(buf20, 20);
830  data._coef_ant_elev_2 = atof(buf20);
831
832  is.read(buf20, 20);
833  data._coef_ant_elev_3 = atof(buf20);
834
835  is.read(buf20, 20);
836  data._coef_ant_elev_4 = atof(buf20);
837
838  is.read(buf20, 20);
839  data._coef_ant_elev_5 = atof(buf20);
840
841  is.read(buf16, 16);
842  data._range_time_origin_ant = atof(buf16);
843
844  char buf10238[10238];
845  is.read(buf10238, 10238);
846  return is;
847  }
Member Data Documentation
◆ _3_dB_look_bandwidth
double ossimplugins::AlosPalsarFacilityData::_3_dB_look_bandwidth
protected
◆ _3_dB_look_proc_dopp_bandw
double ossimplugins::AlosPalsarFacilityData::_3_dB_look_proc_dopp_bandw
protected
Definition at line 1734 of file AlosPalsarFacilityData.h.
Referenced by get_3_dB_look_proc_dopp_bandw(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _3_dB_width_CCF
double ossimplugins::AlosPalsarFacilityData::_3_dB_width_CCF
protected
◆ _abs_cal_const_K
double ossimplugins::AlosPalsarFacilityData::_abs_cal_const_K
protected
◆ _antenna_elev_flag
int ossimplugins::AlosPalsarFacilityData::_antenna_elev_flag
protected
◆ _asc_node_pos_X_comp
std::string ossimplugins::AlosPalsarFacilityData::_asc_node_pos_X_comp
protected
◆ _asc_node_pos_Y_comp
std::string ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Y_comp
protected
◆ _asc_node_pos_Z_comp
std::string ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Z_comp
protected
◆ _asc_node_vel_X_comp
std::string ossimplugins::AlosPalsarFacilityData::_asc_node_vel_X_comp
protected
◆ _asc_node_vel_Y_comp
std::string ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Y_comp
protected
◆ _asc_node_vel_Z_comp
std::string ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Z_comp
protected
◆ _autom_look_scal_gain_flag
bool ossimplugins::AlosPalsarFacilityData::_autom_look_scal_gain_flag
protected
Definition at line 1754 of file AlosPalsarFacilityData.h.
Referenced by get_autom_look_scal_gain_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _azimuth_baseband_convers_flag
int ossimplugins::AlosPalsarFacilityData::_azimuth_baseband_convers_flag
protected
Definition at line 1518 of file AlosPalsarFacilityData.h.
Referenced by get_azimuth_baseband_convers_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _azimuth_FFT_IFFT_ratio
int ossimplugins::AlosPalsarFacilityData::_azimuth_FFT_IFFT_ratio
protected
Definition at line 1642 of file AlosPalsarFacilityData.h.
Referenced by get_azimuth_FFT_IFFT_ratio(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _cal_gain_change_flag
int ossimplugins::AlosPalsarFacilityData::_cal_gain_change_flag
protected
Definition at line 1210 of file AlosPalsarFacilityData.h.
Referenced by get_cal_gain_change_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _cal_gain_changes
int ossimplugins::AlosPalsarFacilityData::_cal_gain_changes
protected
◆ _cal_sys_gain
double ossimplugins::AlosPalsarFacilityData::_cal_sys_gain
protected
◆ _cal_syst_gain_last_proc
int ossimplugins::AlosPalsarFacilityData::_cal_syst_gain_last_proc
protected
Definition at line 1630 of file AlosPalsarFacilityData.h.
Referenced by get_cal_syst_gain_last_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _center_range_pix_mid_az_inc
double ossimplugins::AlosPalsarFacilityData::_center_range_pix_mid_az_inc
protected
Definition at line 1374 of file AlosPalsarFacilityData.h.
Referenced by get_center_range_pix_mid_az_inc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _coef_ant_elev_1
double ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_1
protected
◆ _coef_ant_elev_2
double ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_2
protected
◆ _coef_ant_elev_3
double ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_3
protected
◆ _coef_ant_elev_4
double ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_4
protected
◆ _coef_ant_elev_5
double ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_5
protected
◆ _coef_ground_range_1
double ossimplugins::AlosPalsarFacilityData::_coef_ground_range_1
protected
◆ _coef_ground_range_2
double ossimplugins::AlosPalsarFacilityData::_coef_ground_range_2
protected
◆ _coef_ground_range_3
double ossimplugins::AlosPalsarFacilityData::_coef_ground_range_3
protected
◆ _coef_ground_range_4
double ossimplugins::AlosPalsarFacilityData::_coef_ground_range_4
protected
◆ _datation_flag
bool ossimplugins::AlosPalsarFacilityData::_datation_flag
protected
◆ _dopp_ambig_conf_meas
double ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas
protected
Definition at line 1278 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_ambig_conf_meas(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _dopp_ambig_conf_meas_flag
int ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas_flag
protected
Definition at line 1230 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_ambig_conf_meas_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _dopp_ambig_num
double ossimplugins::AlosPalsarFacilityData::_dopp_ambig_num
protected
◆ _dopp_cent_conf_meas
double ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas
protected
◆ _dopp_cent_conf_meas_flag
int ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas_flag
protected
Definition at line 1222 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_cent_conf_meas_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _dopp_cent_val_flag
int ossimplugins::AlosPalsarFacilityData::_dopp_cent_val_flag
protected
◆ _doppler_ambiguity_estimat_flag
int ossimplugins::AlosPalsarFacilityData::_doppler_ambiguity_estimat_flag
protected
Definition at line 1514 of file AlosPalsarFacilityData.h.
Referenced by get_doppler_ambiguity_estimat_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _doppler_centroid_cubic_coeff
double ossimplugins::AlosPalsarFacilityData::_doppler_centroid_cubic_coeff
protected
Definition at line 1610 of file AlosPalsarFacilityData.h.
Referenced by get_doppler_centroid_cubic_coeff(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _estim_bit_error_rate
double ossimplugins::AlosPalsarFacilityData::_estim_bit_error_rate
protected
Definition at line 1418 of file AlosPalsarFacilityData.h.
Referenced by get_estim_bit_error_rate(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_processed_range_sample
int ossimplugins::AlosPalsarFacilityData::_first_processed_range_sample
protected
Definition at line 1638 of file AlosPalsarFacilityData.h.
Referenced by get_first_processed_range_sample(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_range_pixel_mid_az_inc
double ossimplugins::AlosPalsarFacilityData::_first_range_pixel_mid_az_inc
protected
Definition at line 1370 of file AlosPalsarFacilityData.h.
Referenced by get_first_range_pixel_mid_az_inc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_rec_gain_read
double ossimplugins::AlosPalsarFacilityData::_first_rec_gain_read
protected
◆ _first_replica_sample
double ossimplugins::AlosPalsarFacilityData::_first_replica_sample
protected
Definition at line 1350 of file AlosPalsarFacilityData.h.
Referenced by get_first_replica_sample(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_side_lobe_lev_of_ACF
double ossimplugins::AlosPalsarFacilityData::_first_side_lobe_lev_of_ACF
protected
Definition at line 1266 of file AlosPalsarFacilityData.h.
Referenced by get_first_side_lobe_lev_of_ACF(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_side_lobe_level
double ossimplugins::AlosPalsarFacilityData::_first_side_lobe_level
protected
Definition at line 1490 of file AlosPalsarFacilityData.h.
Referenced by get_first_side_lobe_level(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _form_num_range_line_used
int ossimplugins::AlosPalsarFacilityData::_form_num_range_line_used
protected
Definition at line 1750 of file AlosPalsarFacilityData.h.
Referenced by get_form_num_range_line_used(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _I_channel_bias_correction
double ossimplugins::AlosPalsarFacilityData::_I_channel_bias_correction
protected
I_channel_bias_correction.
Definition at line 1310 of file AlosPalsarFacilityData.h.
Referenced by get_I_channel_bias_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _I_channel_gain_correction
double ossimplugins::AlosPalsarFacilityData::_I_channel_gain_correction
protected
I_channel_gain_correction.
Definition at line 1318 of file AlosPalsarFacilityData.h.
Referenced by get_I_channel_gain_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _I_gain_imb_lower_bound
double ossimplugins::AlosPalsarFacilityData::_I_gain_imb_lower_bound
protected
I_gain_imb_lower_bound.
Definition at line 1714 of file AlosPalsarFacilityData.h.
Referenced by get_I_gain_imb_lower_bound(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _I_gain_imb_upper_bound
double ossimplugins::AlosPalsarFacilityData::_I_gain_imb_upper_bound
protected
I_gain_imb_upper_bound.
Definition at line 1718 of file AlosPalsarFacilityData.h.
Referenced by get_I_gain_imb_upper_bound(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _I_Q_quad_depar_lower_bound
double ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_lower_bound
protected
I_Q_quad_depar_lower_bound.
Definition at line 1722 of file AlosPalsarFacilityData.h.
Referenced by get_I_Q_quad_depar_lower_bound(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _I_Q_quad_depar_upper_bound
double ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_upper_bound
protected
I_Q_quad_depar_upper_bound.
Definition at line 1726 of file AlosPalsarFacilityData.h.
Referenced by get_I_Q_quad_depar_upper_bound(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _initial_doppler_ambiguity_num
int ossimplugins::AlosPalsarFacilityData::_initial_doppler_ambiguity_num
protected
Definition at line 1654 of file AlosPalsarFacilityData.h.
Referenced by get_initial_doppler_ambiguity_num(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _inp_data_I_mean
double ossimplugins::AlosPalsarFacilityData::_inp_data_I_mean
protected
◆ _inp_data_I_stddev
double ossimplugins::AlosPalsarFacilityData::_inp_data_I_stddev
protected
◆ _inp_data_Q_mean
double ossimplugins::AlosPalsarFacilityData::_inp_data_Q_mean
protected
◆ _inp_data_Q_stddev
double ossimplugins::AlosPalsarFacilityData::_inp_data_Q_stddev
protected
◆ _inp_data_stat_flag
int ossimplugins::AlosPalsarFacilityData::_inp_data_stat_flag
protected
◆ _inp_state_vect_pos_X_comp
std::string ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_X_comp
protected
Definition at line 1534 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_pos_X_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _inp_state_vect_pos_Y_comp
std::string ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Y_comp
protected
Definition at line 1538 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_pos_Y_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _inp_state_vect_pos_Z_comp
std::string ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Z_comp
protected
Definition at line 1542 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_pos_Z_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _inp_state_vect_vel_Vx_comp
std::string ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vx_comp
protected
Definition at line 1546 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_vel_Vx_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _inp_state_vect_vel_Vy_comp
std::string ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vy_comp
protected
Definition at line 1550 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_vel_Vy_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _inp_state_vect_vel_Vz_comp
std::string ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vz_comp
protected
Definition at line 1554 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_vel_Vz_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _inp_state_vector_type_flag
int ossimplugins::AlosPalsarFacilityData::_inp_state_vector_type_flag
protected
Definition at line 1558 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vector_type_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _int_cal_utc
int ossimplugins::AlosPalsarFacilityData::_int_cal_utc
protected
◆ _ISLR_CCF_between_last
double ossimplugins::AlosPalsarFacilityData::_ISLR_CCF_between_last
protected
ISLR_CCF_between_last.
Definition at line 1494 of file AlosPalsarFacilityData.h.
Referenced by get_ISLR_CCF_between_last(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _ISLR_of_ACF
double ossimplugins::AlosPalsarFacilityData::_ISLR_of_ACF
protected
◆ _K_gen_date
std::string ossimplugins::AlosPalsarFacilityData::_K_gen_date
protected
◆ _K_vers_num
std::string ossimplugins::AlosPalsarFacilityData::_K_vers_num
protected
◆ _last_range_pix_mid_az_inc
double ossimplugins::AlosPalsarFacilityData::_last_range_pix_mid_az_inc
protected
Definition at line 1378 of file AlosPalsarFacilityData.h.
Referenced by get_last_range_pix_mid_az_inc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _last_release_cal_date
std::string ossimplugins::AlosPalsarFacilityData::_last_release_cal_date
protected
Definition at line 1194 of file AlosPalsarFacilityData.h.
Referenced by get_last_release_cal_date(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _last_release_qc_date
std::string ossimplugins::AlosPalsarFacilityData::_last_release_qc_date
protected
Definition at line 1190 of file AlosPalsarFacilityData.h.
Referenced by get_last_release_qc_date(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _look_detecion_flag
int ossimplugins::AlosPalsarFacilityData::_look_detecion_flag
protected
◆ _look_scalar_gain_1
double ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_1
protected
◆ _look_scalar_gain_2
double ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_2
protected
◆ _look_scalar_gain_3
double ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_3
protected
◆ _look_scalar_gain_4
double ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_4
protected
◆ _look_scalar_gain_5
double ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_5
protected
◆ _look_scalar_gain_6
double ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_6
protected
◆ _look_scalar_gain_7
double ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_7
protected
◆ _look_scalar_gain_8
double ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_8
protected
◆ _low_bound_K
double ossimplugins::AlosPalsarFacilityData::_low_bound_K
protected
◆ _max_error_range_line_timing
int ossimplugins::AlosPalsarFacilityData::_max_error_range_line_timing
protected
Definition at line 1746 of file AlosPalsarFacilityData.h.
Referenced by get_max_error_range_line_timing(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _max_value_look_scalar_gain
int ossimplugins::AlosPalsarFacilityData::_max_value_look_scalar_gain
protected
Definition at line 1758 of file AlosPalsarFacilityData.h.
Referenced by get_max_value_look_scalar_gain(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _mean_cal_pulse_power
double ossimplugins::AlosPalsarFacilityData::_mean_cal_pulse_power
protected
Definition at line 1354 of file AlosPalsarFacilityData.h.
Referenced by get_mean_cal_pulse_power(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _mean_noise_power
double ossimplugins::AlosPalsarFacilityData::_mean_noise_power
protected
◆ _missing_lines
int ossimplugins::AlosPalsarFacilityData::_missing_lines
protected
◆ _name_of_facil_rec
std::string ossimplugins::AlosPalsarFacilityData::_name_of_facil_rec
protected
Definition at line 1178 of file AlosPalsarFacilityData.h.
Referenced by get_name_of_facil_rec(), and ossimplugins::operator>>().
◆ _noise_power
double ossimplugins::AlosPalsarFacilityData::_noise_power
protected
◆ _norm_ref_range_ro
double ossimplugins::AlosPalsarFacilityData::_norm_ref_range_ro
protected
◆ _num_azimuth_blocks_proc
int ossimplugins::AlosPalsarFacilityData::_num_azimuth_blocks_proc
protected
Definition at line 1646 of file AlosPalsarFacilityData.h.
Referenced by get_num_azimuth_blocks_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _num_duplic_input_lines
int ossimplugins::AlosPalsarFacilityData::_num_duplic_input_lines
protected
Definition at line 1414 of file AlosPalsarFacilityData.h.
Referenced by get_num_duplic_input_lines(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _num_input_raw_data_lines
int ossimplugins::AlosPalsarFacilityData::_num_input_raw_data_lines
protected
Definition at line 1650 of file AlosPalsarFacilityData.h.
Referenced by get_num_input_raw_data_lines(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _num_range_samp_discarded
int ossimplugins::AlosPalsarFacilityData::_num_range_samp_discarded
protected
Definition at line 1710 of file AlosPalsarFacilityData.h.
Referenced by get_num_range_samp_discarded(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _num_valid_cal_pulses
int ossimplugins::AlosPalsarFacilityData::_num_valid_cal_pulses
protected
Definition at line 1338 of file AlosPalsarFacilityData.h.
Referenced by get_num_valid_cal_pulses(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _num_valid_noise_pulses
int ossimplugins::AlosPalsarFacilityData::_num_valid_noise_pulses
protected
Definition at line 1342 of file AlosPalsarFacilityData.h.
Referenced by get_num_valid_noise_pulses(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _num_valid_pixels_per_range
int ossimplugins::AlosPalsarFacilityData::_num_valid_pixels_per_range
protected
Definition at line 1706 of file AlosPalsarFacilityData.h.
Referenced by get_num_valid_pixels_per_range(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _num_valid_replicas
int ossimplugins::AlosPalsarFacilityData::_num_valid_replicas
protected
◆ _OGOB_flag
int ossimplugins::AlosPalsarFacilityData::_OGOB_flag
protected
◆ _out_image_max_value
double ossimplugins::AlosPalsarFacilityData::_out_image_max_value
protected
◆ _out_image_mean
double ossimplugins::AlosPalsarFacilityData::_out_image_mean
protected
◆ _out_image_std_dev
double ossimplugins::AlosPalsarFacilityData::_out_image_std_dev
protected
◆ _out_pixel_bit_length
int ossimplugins::AlosPalsarFacilityData::_out_pixel_bit_length
protected
Definition at line 1466 of file AlosPalsarFacilityData.h.
Referenced by get_out_pixel_bit_length(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _outp_data_mean_flag
int ossimplugins::AlosPalsarFacilityData::_outp_data_mean_flag
protected
◆ _peak_loc_CCF_betw_last
int ossimplugins::AlosPalsarFacilityData::_peak_loc_CCF_betw_last
protected
Definition at line 1498 of file AlosPalsarFacilityData.h.
Referenced by get_peak_loc_CCF_betw_last(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _peak_loc_cross_correl_fun
int ossimplugins::AlosPalsarFacilityData::_peak_loc_cross_correl_fun
protected
Definition at line 1482 of file AlosPalsarFacilityData.h.
Referenced by get_peak_loc_cross_correl_fun(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _PRF_changes
int ossimplugins::AlosPalsarFacilityData::_PRF_changes
protected
◆ _prf_code_change_flag
int ossimplugins::AlosPalsarFacilityData::_prf_code_change_flag
protected
Definition at line 1202 of file AlosPalsarFacilityData.h.
Referenced by get_prf_code_change_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _PRF_code_first_range_line
int ossimplugins::AlosPalsarFacilityData::_PRF_code_first_range_line
protected
PRF_code_first_range_line.
Definition at line 1614 of file AlosPalsarFacilityData.h.
Referenced by get_PRF_code_first_range_line(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _PRF_code_last_range_line
int ossimplugins::AlosPalsarFacilityData::_PRF_code_last_range_line
protected
PRF_code_last_range_line.
Definition at line 1618 of file AlosPalsarFacilityData.h.
Referenced by get_PRF_code_last_range_line(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _proc_gain_param_1
double ossimplugins::AlosPalsarFacilityData::_proc_gain_param_1
protected
◆ _proc_gain_param_2
double ossimplugins::AlosPalsarFacilityData::_proc_gain_param_2
protected
◆ _proc_gain_param_3
double ossimplugins::AlosPalsarFacilityData::_proc_gain_param_3
protected
◆ _proc_noise_scale_fact
double ossimplugins::AlosPalsarFacilityData::_proc_noise_scale_fact
protected
Definition at line 1402 of file AlosPalsarFacilityData.h.
Referenced by get_proc_noise_scale_fact(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _pulse_width_of_ACF_3db
double ossimplugins::AlosPalsarFacilityData::_pulse_width_of_ACF_3db
protected
Definition at line 1262 of file AlosPalsarFacilityData.h.
Referenced by get_pulse_width_of_ACF_3db(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _Q_channel_bias_correction
double ossimplugins::AlosPalsarFacilityData::_Q_channel_bias_correction
protected
Q_channel_bias_correction.
Definition at line 1314 of file AlosPalsarFacilityData.h.
Referenced by get_Q_channel_bias_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _Q_channel_gain_correction
double ossimplugins::AlosPalsarFacilityData::_Q_channel_gain_correction
protected
Q_channel_gain_correction.
Definition at line 1322 of file AlosPalsarFacilityData.h.
Referenced by get_Q_channel_gain_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _Q_channel_I_Q_correction
double ossimplugins::AlosPalsarFacilityData::_Q_channel_I_Q_correction
protected
Q_channel_I_Q_correction.
Definition at line 1326 of file AlosPalsarFacilityData.h.
Referenced by get_Q_channel_I_Q_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _qa_summary_flag
int ossimplugins::AlosPalsarFacilityData::_qa_summary_flag
protected
◆ _quirp_qu_flag
int ossimplugins::AlosPalsarFacilityData::_quirp_qu_flag
protected
◆ _range_comp_norm_fact
double ossimplugins::AlosPalsarFacilityData::_range_comp_norm_fact
protected
Definition at line 1362 of file AlosPalsarFacilityData.h.
Referenced by get_range_comp_norm_fact(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _range_lines_skip_factor
int ossimplugins::AlosPalsarFacilityData::_range_lines_skip_factor
protected
Definition at line 1526 of file AlosPalsarFacilityData.h.
Referenced by get_range_lines_skip_factor(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _range_spread_loss_comp_flag
int ossimplugins::AlosPalsarFacilityData::_range_spread_loss_comp_flag
protected
Definition at line 1738 of file AlosPalsarFacilityData.h.
Referenced by get_range_spread_loss_comp_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _range_time_origin_ant
double ossimplugins::AlosPalsarFacilityData::_range_time_origin_ant
protected
Definition at line 1802 of file AlosPalsarFacilityData.h.
Referenced by get_range_time_origin_ant(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _raw_data_correction_flag
int ossimplugins::AlosPalsarFacilityData::_raw_data_correction_flag
protected
Definition at line 1506 of file AlosPalsarFacilityData.h.
Referenced by get_raw_data_correction_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _rec_gain_changes
int ossimplugins::AlosPalsarFacilityData::_rec_gain_changes
protected
◆ _receiver_gain_last_proc
int ossimplugins::AlosPalsarFacilityData::_receiver_gain_last_proc
protected
Definition at line 1634 of file AlosPalsarFacilityData.h.
Referenced by get_receiver_gain_last_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _replica_norm_method_flag
int ossimplugins::AlosPalsarFacilityData::_replica_norm_method_flag
protected
Definition at line 1762 of file AlosPalsarFacilityData.h.
Referenced by get_replica_norm_method_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _replica_power
double ossimplugins::AlosPalsarFacilityData::_replica_power
protected
◆ _Roll_Tilt_Mode_flag
int ossimplugins::AlosPalsarFacilityData::_Roll_Tilt_Mode_flag
protected
Roll_Tilt_Mode_flag.
Definition at line 1502 of file AlosPalsarFacilityData.h.
Referenced by get_Roll_Tilt_Mode_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _samp_win_start_first
int ossimplugins::AlosPalsarFacilityData::_samp_win_start_first
protected
Definition at line 1622 of file AlosPalsarFacilityData.h.
Referenced by get_samp_win_start_first(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _samp_win_start_last
int ossimplugins::AlosPalsarFacilityData::_samp_win_start_last
protected
◆ _samp_window_start_time_bias
int ossimplugins::AlosPalsarFacilityData::_samp_window_start_time_bias
protected
Definition at line 1606 of file AlosPalsarFacilityData.h.
Referenced by get_samp_window_start_time_bias(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _samples_per_line_used
int ossimplugins::AlosPalsarFacilityData::_samples_per_line_used
protected
Definition at line 1522 of file AlosPalsarFacilityData.h.
Referenced by get_samples_per_line_used(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _sampling_win_change_flag
int ossimplugins::AlosPalsarFacilityData::_sampling_win_change_flag
protected
Definition at line 1206 of file AlosPalsarFacilityData.h.
Referenced by get_sampling_win_change_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _sampling_win_changes
int ossimplugins::AlosPalsarFacilityData::_sampling_win_changes
protected
Definition at line 1246 of file AlosPalsarFacilityData.h.
Referenced by get_sampling_win_changes(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _sat_binary_time_of_first
int ossimplugins::AlosPalsarFacilityData::_sat_binary_time_of_first
protected
Definition at line 1702 of file AlosPalsarFacilityData.h.
Referenced by get_sat_binary_time_of_first(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _thresh_no_10_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_10_flag
protected
◆ _thresh_no_11_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_11_flag
protected
◆ _thresh_no_1_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_1_flag
protected
◆ _thresh_no_2_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_2_flag
protected
◆ _thresh_no_3_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_3_flag
protected
◆ _thresh_no_4_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_4_flag
protected
◆ _thresh_no_5_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_5_flag
protected
◆ _thresh_no_6_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_6_flag
protected
◆ _thresh_no_7_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_7_flag
protected
◆ _thresh_no_8_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_8_flag
protected
◆ _thresh_no_9_flag
double ossimplugins::AlosPalsarFacilityData::_thresh_no_9_flag
protected
◆ _time_asc_node_state_vectors
std::string ossimplugins::AlosPalsarFacilityData::_time_asc_node_state_vectors
protected
Definition at line 1438 of file AlosPalsarFacilityData.h.
Referenced by get_time_asc_node_state_vectors(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _time_of_inp_state_vectors
std::string ossimplugins::AlosPalsarFacilityData::_time_of_inp_state_vectors
protected
Definition at line 1530 of file AlosPalsarFacilityData.h.
Referenced by get_time_of_inp_state_vectors(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _time_raw_data_first_input
std::string ossimplugins::AlosPalsarFacilityData::_time_raw_data_first_input
protected
Definition at line 1434 of file AlosPalsarFacilityData.h.
Referenced by get_time_raw_data_first_input(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _update_period_range_match
int ossimplugins::AlosPalsarFacilityData::_update_period_range_match
protected
Definition at line 1570 of file AlosPalsarFacilityData.h.
Referenced by get_update_period_range_match(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _upp_bound_K
double ossimplugins::AlosPalsarFacilityData::_upp_bound_K
protected
◆ _win_coeff_for_azi_match
double ossimplugins::AlosPalsarFacilityData::_win_coeff_for_azi_match
protected
Definition at line 1566 of file AlosPalsarFacilityData.h.
Referenced by get_win_coeff_for_azi_match(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _win_coeff_for_range_match
double ossimplugins::AlosPalsarFacilityData::_win_coeff_for_range_match
protected
Definition at line 1562 of file AlosPalsarFacilityData.h.
Referenced by get_win_coeff_for_range_match(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
