Namespaces | Classes | Typedefs | Functions | Variables
ossimplugins Namespace Reference
Namespaces
 ossim
Classes
class  AlosPalsarData
 This class is able to read the Leader file of the AlosPalsar file structure. More...
class  AlosPalsarDataFileDescriptor
 This class is able to read the SAR leader file descriptor record of the leader file. More...
class  AlosPalsarDataSetSummary
 This class is able to read the SAR leader data set summary record of the leader file. More...
class  AlosPalsarFacilityData
class  AlosPalsarFileDescriptor
class  AlosPalsarLeader
class  AlosPalsarLeaderFactory
 This class is a facory able to construct Record base classes. More...
class  AlosPalsarMapProjectionData
class  AlosPalsarPlatformPositionData
 This class is able to read a Platform position data record. More...
class  AlosPalsarPositionVectorRecord
 This class is able to read a position vector record. More...
class  AlosPalsarRadiometricData
 This class is able to read a radiometric data record. More...
class  AlosPalsarRecord
 This class is the base class of all the record classes. More...
class  AlosPalsarRecordFactory
 This class is a facory able to construct Record base classes given the id of the record wanted. More...
class  AlosPalsarRecordHeader
 This class is able to read a record header. More...
class  AlosPalsarSignalData
 This class is able to read the header of the Signal Data Records of the image file. More...
class  AntennaElevationPatterns
 This class is able to read the ASAR AntennaElevationPatterns record. More...
class  AttitudeData
 This class is able to read a Attitude data record. More...
class  BeamInformationRecord
 This class is able to read a Beam information record. More...
class  BeamPixelCountRecord
 This class is able to read a Beam pixel count record. More...
class  ChirpParameters
 This class is able to read the ASAR ChirpParameters record. More...
class  CivilDateTime
 This class represents a date and time in the civil format. More...
class  CompensationDataRecord
 This class is able to read a Compensation data record. More...
class  Coordinate
 This class represents a coordinate. More...
class  Data
 This class is able to read the data file of the RadarSat file structure. More...
class  DataFactory
 This class is a factory able to construct Record base classes. More...
class  DataHistogramProcessedData
 This class is able to read a data histogram record - Processed data. More...
class  DataHistogramRecord
 This class is able to read a data histogram record. More...
class  DataHistogramSignalData
 This class is able to read a data histogram record - Signal data. More...
class  DataPointDataRecord
 This class is able to read a Data point data record. More...
class  DataQuality
 This class is able to read a data quality record. More...
class  DataSetSummary
class  DopplerCentroidEstimateRecord
 This class is able to read a Doppler centroid estimates record. More...
class  DopplerCentroidParameters
 This class is able to read the ASAR DopplerCentroidParameters record. More...
class  dsd
 This class is able to read the ASAR dsd record. More...
class  EnvisatAsarData
 This class is able to read the Envisat file structure. More...
class  EnvisatAsarDataFactory
class  EnvisatAsarRecord
 This class is the base class of all the Envisat ASAR record classes. More...
class  EnvisatAsarRecordFactory
 This class is a factory able to construct Record base classes given the id of the record wanted. More...
class  Ephemeris
 This class represents an ephemeris. More...
class  Equation
 This class manages and solves an equation of the fourth degree. More...
class  ErsSarDataSetSummary
class  ErsSarFacilityData
class  ErsSarFileDescriptor
class  ErsSarLeader
 This class is able to read the Leader file of the ErsSar file structure. More...
class  ErsSarLeaderFactory
class  ErsSarMapProjectionData
class  ErsSarPlatformPositionData
class  ErsSarPositionVectorRecord
class  ErsSarRecord
class  ErsSarRecordFactory
class  ErsSarRecordHeader
class  FileDescriptor
class  FilePointerRecord
class  GalileanEphemeris
 This class represents an ephemeris in Galilean coordinates system. More...
class  GeodesicCoordinate
 This class represents a coordinate in a geodesic reference. More...
class  GeographicEphemeris
 This class represent an ephemeris in Geographic coordinates system. More...
class  GeolocationGrid
 This class is able to read the ASAR GeolocationGrid record. More...
class  GMSTDateTime
 This class represents a date. More...
class  HermiteInterpolator
 Abstract interpolator. More...
class  ImageNoise
 This class represents an ImageNoise. More...
class  ImageOptionsFileDescriptor
 This class is able to read an Image options file descriptor record. More...
class  IncidenceAngles
 This class represents Incidence Angles. More...
class  InfoIncidenceAngle
 This class represents an InfoIncidenceAngle. More...
class  InfoSceneCoord
 This class represents an InfoSceneCoord. More...
class  JSDDateTime
class  JulianDate
 This class represents a date in the julian referential. More...
class  Leader
 This class is able to read the leader file of the RadarSat file structure. More...
class  LeaderFactory
class  MainProcessingParameters
 This class is able to read the ASAR MainProcessingParameters record. More...
class  MisregistrationRecord
 This class is able to read a misregistration record. More...
class  MJDDateTime
 This class represents an MJD date (Modified Julian date) More...
class  mph
 This class is able to read the ASAR mph record of the leader file. More...
class  Noise
 This class represents an Noise. More...
class  ossimAlosPalsarModel
 This class is able to direct localisation and indirect localisation using the AlosPalsar sensor model. More...
class  ossimCosmoSkymedModel
 This class allows for direct localisation and indirect localisation using the CosmoSkymed sensor model. More...
class  ossimEnvisatAsarModel
 This class is able to direct localisation and indirect localisation using the EnvisatAsar sensor model. More...
class  ossimErsSarModel
 This class is able to direct localisation and indirect localisation using the ErsSar sensor model. More...
class  ossimFormosatModel
class  ossimGeometricSarSensorModel
 This class allows for direct localisation and indirect localisation using the geometric model of SAR sensors. More...
class  ossimPleiadesDimapSupportData
class  ossimPleiadesModel
class  ossimPluginProjectionFactory
class  ossimPluginReaderFactory
 Image handler factory for ossim plugins plugin. More...
class  ossimRadarSat2Model
 This class allows for direct localisation and indirect localisation using the RadarSat2 sensor model. More...
class  ossimRadarSat2ProductDoc
 Class to encapsulate parsing RadarSat2 product.xml file. More...
class  ossimRadarSat2RPCModel
class  ossimRadarSat2TiffReader
class  ossimRadarSatModel
 This class is able to direct localisation and indirect localisation using the RadarSat sensor model. More...
class  ossimSpot6DimapSupportData
class  ossimSpot6Model
class  ossimTerraSarModel
 This class allows for direct localisation and indirect localisation using the TerraSar sensor model. More...
class  ossimTerraSarProductDoc
 Class to encapsulate parsing TerraSAR product xml file. More...
class  ossimTerraSarTiffReader
class  ossimTileMapModel
class  PlatformPosition
 This class handles the platform position. More...
class  PlatformPositionData
class  PositionVectorRecord
class  ProcessedDataRecord
 This class is able to read an Processed Data Record. More...
class  ProcessingParameters
 This class is able to read a Detailed processing parameters record. More...
class  RadarSat2NoiseLevel
class  RadarSatRecord
class  RadarSatRecordFactory
 This class is a factory able to construct Record base classes given the id of the wanted record. More...
class  RadarSatRecordHeader
class  RadiometricCompensationData
 This class is able to read a Radiometric Compensation data record. More...
class  RadiometricData
class  RadiometryUncertaintyRecord
 This class is able to read a radiometry uncertainty record. More...
class  RectangularCoordinate
 This class represents a coordinate in a rectangular reference. More...
class  RefPoint
 This class handles the referential point. More...
class  SarSensor
 This class provides basic location services for SAR sensors. More...
class  SceneCoord
 This class represents Scence coordinate. More...
class  Sensor
 This class provides basic location services. More...
class  SensorParams
 This class handles the sensor parameters. More...
class  sph
 This class is able to read the SAR sph record of the ASAR file. More...
class  SQ_ADSR
 This class is able to read the ASAR SQ_ADSR record. More...
class  SRGRCoefficientSetRecord
 This class is able to read a SRGR coefficients set record. More...
class  SRGRConversionParameters
 This class is able to read the ASAR SRGRConversionParameters record. More...
class  TemperatureSettingsRecord
 This class is able to read a Temperature Settings record. More...
class  TextRecord
 This class is able to read the Text record of the volume directory file. More...
class  Trailer
 This class is able to read the trailer file of the RadarSat file structure. More...
class  TrailerFactory
class  VolumeDescriptorRecord
class  VolumeDir
 This class is able to read the volume directory file of the RadarSat file structure. More...
class  VolumeDirFactory
Typedefs
typedef DataHistogramSignalData DataHistogramProcessedData8
typedef FilePointerRecord SARLeaderFilePointerRecord
typedef FilePointerRecord ImageOptionsFilePointerRecord
typedef FilePointerRecord SARTrailerFilePointerRecord
Functions
std::ostream & operator<< (std::ostream &os, const AlosPalsarData &data)
std::istream & operator>> (std::istream &is, AlosPalsarData &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarDataFileDescriptor &data)
std::istream & operator>> (std::istream &is, AlosPalsarDataFileDescriptor &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarDataSetSummary &data)
std::istream & operator>> (std::istream &is, AlosPalsarDataSetSummary &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarFacilityData &data)
std::istream & operator>> (std::istream &is, AlosPalsarFacilityData &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarFileDescriptor &data)
std::istream & operator>> (std::istream &is, AlosPalsarFileDescriptor &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarLeader &data)
std::istream & operator>> (std::istream &is, AlosPalsarLeader &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarMapProjectionData &data)
std::istream & operator>> (std::istream &is, AlosPalsarMapProjectionData &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarPlatformPositionData &data)
std::istream & operator>> (std::istream &is, AlosPalsarPlatformPositionData &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarPositionVectorRecord &data)
std::istream & operator>> (std::istream &is, AlosPalsarPositionVectorRecord &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarRadiometricData &data)
std::istream & operator>> (std::istream &is, AlosPalsarRadiometricData &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarRecordHeader &data)
std::istream & operator>> (std::istream &is, AlosPalsarRecordHeader &data)
std::ostream & operator<< (std::ostream &os, const AlosPalsarSignalData &data)
std::istream & operator>> (std::istream &is, AlosPalsarSignalData &data)
std::ostream & operator<< (std::ostream &os, const AntennaElevationPatterns &data)
std::istream & operator>> (std::istream &is, AntennaElevationPatterns &data)
std::ostream & operator<< (std::ostream &os, const ChirpParameters &data)
std::istream & operator>> (std::istream &is, ChirpParameters &data)
std::ostream & operator<< (std::ostream &os, const DopplerCentroidParameters &data)
std::istream & operator>> (std::istream &is, DopplerCentroidParameters &data)
std::ostream & operator<< (std::ostream &os, const dsd &data)
std::istream & operator>> (std::istream &is, dsd &data)
std::ostream & operator<< (std::ostream &os, const EnvisatAsarData &data)
std::istream & operator>> (std::istream &is, EnvisatAsarData &data)
std::ostream & operator<< (std::ostream &os, const GeolocationGrid &data)
std::istream & operator>> (std::istream &is, GeolocationGrid &data)
std::ostream & operator<< (std::ostream &os, const MainProcessingParameters &data)
std::istream & operator>> (std::istream &is, MainProcessingParameters &data)
std::ostream & operator<< (std::ostream &os, const mph &data)
std::istream & operator>> (std::istream &is, mph &data)
std::ostream & operator<< (std::ostream &os, const sph &data)
std::istream & operator>> (std::istream &is, sph &data)
std::ostream & operator<< (std::ostream &os, const SQ_ADSR &data)
std::istream & operator>> (std::istream &is, SQ_ADSR &data)
std::ostream & operator<< (std::ostream &os, const SRGRConversionParameters &data)
std::istream & operator>> (std::istream &is, SRGRConversionParameters &data)
std::ostream & operator<< (std::ostream &os, const ErsSarDataSetSummary &data)
std::istream & operator>> (std::istream &is, ErsSarDataSetSummary &data)
std::ostream & operator<< (std::ostream &os, const ErsSarFacilityData &data)
std::istream & operator>> (std::istream &is, ErsSarFacilityData &data)
std::ostream & operator<< (std::ostream &os, const ErsSarFileDescriptor &data)
std::istream & operator>> (std::istream &is, ErsSarFileDescriptor &data)
std::ostream & operator<< (std::ostream &os, const ErsSarLeader &data)
std::istream & operator>> (std::istream &is, ErsSarLeader &data)
std::ostream & operator<< (std::ostream &os, const ErsSarMapProjectionData &data)
std::istream & operator>> (std::istream &is, ErsSarMapProjectionData &data)
std::ostream & operator<< (std::ostream &os, const ErsSarPlatformPositionData &data)
std::istream & operator>> (std::istream &is, ErsSarPlatformPositionData &data)
std::ostream & operator<< (std::ostream &os, const ErsSarPositionVectorRecord &data)
std::istream & operator>> (std::istream &is, ErsSarPositionVectorRecord &data)
std::ostream & operator<< (std::ostream &os, const ErsSarRecordHeader &data)
std::istream & operator>> (std::istream &is, ErsSarRecordHeader &data)
 RTTI_DEF1 (ossimAlosPalsarModel, "ossimAlosPalsarModel", ossimGeometricSarSensorModel)
 RTTI_DEF1 (ossimCosmoSkymedModel, "ossimCosmoSkymedModel", ossimGeometricSarSensorModel)
 RTTI_DEF1 (ossimEnvisatAsarModel, "ossimEnvisatAsarModel", ossimGeometricSarSensorModel)
 RTTI_DEF1 (ossimErsSarModel, "ossimErsSarModel", ossimGeometricSarSensorModel)
 RTTI_DEF1 (ossimFormosatModel, "ossimFormosatModel", ossimSensorModel)
 RTTI_DEF1 (ossimGeometricSarSensorModel, "ossimGeometricSarSensorModel", ossimSensorModel)
 RTTI_DEF1 (ossimPleiadesModel, "ossimPleiadesModel", ossimRpcModel)
const char * getCnesDescription ()
int getCnesNumberOfClassNames ()
const char * getCnesClassName (int idx)
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize (ossimSharedObjectInfo **info)
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ()
 RTTI_DEF1 (ossimPluginReaderFactory, "ossimPluginReaderFactory", ossimImageHandlerFactoryBase)
 RTTI_DEF1 (ossimRadarSat2Model, "ossimRadarSat2Model", ossimGeometricSarSensorModel)
 RTTI_DEF1 (ossimRadarSat2RPCModel, "ossimRadarSat2RPCModel", ossimRpcModel)
 RTTI_DEF1 (ossimRadarSatModel, "ossimRadarSatModel", ossimGeometricSarSensorModel)
 RTTI_DEF1 (ossimSpot6Model, "ossimSpot6Model", ossimRpcModel)
 RTTI_DEF1 (ossimTerraSarModel, "ossimTerraSarModel", ossimGeometricSarSensorModel)
 RTTI_DEF1 (ossimTileMapModel, "ossimTileMapModel", ossimSensorModel)
long inint (double x)
double fnint (double x)
std::ostream & operator<< (std::ostream &out, const CivilDateTime &obj)
std::ostream & operator<< (std::ostream &os, const AttitudeData &data)
std::istream & operator>> (std::istream &is, AttitudeData &data)
std::ostream & operator<< (std::ostream &os, const BeamInformationRecord &data)
std::istream & operator>> (std::istream &is, BeamInformationRecord &data)
std::ostream & operator<< (std::ostream &os, const BeamPixelCountRecord &data)
std::istream & operator>> (std::istream &is, BeamPixelCountRecord &data)
std::ostream & operator<< (std::ostream &os, const CompensationDataRecord &data)
std::istream & operator>> (std::istream &is, CompensationDataRecord &data)
std::ostream & operator<< (std::ostream &os, const DataHistogramRecord &data)
std::istream & operator>> (std::istream &is, DataHistogramRecord &data)
std::ostream & operator<< (std::ostream &os, const DataHistogramSignalData &data)
std::istream & operator>> (std::istream &is, DataHistogramSignalData &data)
std::ostream & operator<< (std::ostream &os, const DataPointDataRecord &data)
std::istream & operator>> (std::istream &is, DataPointDataRecord &data)
std::ostream & operator<< (std::ostream &os, const DataQuality &data)
std::istream & operator>> (std::istream &is, DataQuality &data)
std::ostream & operator<< (std::ostream &os, const DataSetSummary &data)
std::istream & operator>> (std::istream &is, DataSetSummary &data)
std::ostream & operator<< (std::ostream &os, const DopplerCentroidEstimateRecord &data)
std::istream & operator>> (std::istream &is, DopplerCentroidEstimateRecord &data)
std::ostream & operator<< (std::ostream &os, const FileDescriptor &data)
std::istream & operator>> (std::istream &is, FileDescriptor &data)
std::ostream & operator<< (std::ostream &os, const MisregistrationRecord &data)
std::istream & operator>> (std::istream &is, MisregistrationRecord &data)
std::ostream & operator<< (std::ostream &os, const ProcessingParameters &data)
std::istream & operator>> (std::istream &is, ProcessingParameters &data)
std::ostream & operator<< (std::ostream &os, const RadiometricCompensationData &data)
std::istream & operator>> (std::istream &is, RadiometricCompensationData &data)
std::ostream & operator<< (std::ostream &os, const RadiometricData &data)
std::istream & operator>> (std::istream &is, RadiometricData &data)
std::ostream & operator<< (std::ostream &os, const RadiometryUncertaintyRecord &data)
std::istream & operator>> (std::istream &is, RadiometryUncertaintyRecord &data)
std::ostream & operator<< (std::ostream &os, const SRGRCoefficientSetRecord &data)
std::istream & operator>> (std::istream &is, SRGRCoefficientSetRecord &data)
std::ostream & operator<< (std::ostream &os, const TemperatureSettingsRecord &data)
std::istream & operator>> (std::istream &is, TemperatureSettingsRecord &data)
std::ostream & operator<< (std::ostream &os, const Data &data)
std::istream & operator>> (std::istream &is, Data &data)
std::ostream & operator<< (std::ostream &os, const ImageOptionsFileDescriptor &data)
std::istream & operator>> (std::istream &is, ImageOptionsFileDescriptor &data)
std::ostream & operator<< (std::ostream &os, const ProcessedDataRecord &data)
void SwitchEndian (int &value)
std::istream & operator>> (std::istream &is, ProcessedDataRecord &data)
std::ostream & operator<< (std::ostream &os, const DataHistogramProcessedData &data)
std::istream & operator>> (std::istream &is, DataHistogramProcessedData &data)
std::ostream & operator<< (std::ostream &os, const Leader &data)
std::istream & operator>> (std::istream &is, Leader &data)
std::ostream & operator<< (std::ostream &os, const PlatformPositionData &data)
std::istream & operator>> (std::istream &is, PlatformPositionData &data)
std::ostream & operator<< (std::ostream &os, const PositionVectorRecord &data)
std::istream & operator>> (std::istream &is, PositionVectorRecord &data)
std::ostream & operator<< (std::ostream &os, const RadarSatRecordHeader &data)
std::istream & operator>> (std::istream &is, RadarSatRecordHeader &data)
std::ostream & operator<< (std::ostream &os, const Trailer &data)
std::istream & operator>> (std::istream &is, Trailer &data)
std::ostream & operator<< (std::ostream &os, const FilePointerRecord &data)
std::istream & operator>> (std::istream &is, FilePointerRecord &data)
std::ostream & operator<< (std::ostream &os, const TextRecord &data)
std::istream & operator>> (std::istream &is, TextRecord &data)
std::ostream & operator<< (std::ostream &os, const VolumeDescriptorRecord &data)
std::istream & operator>> (std::istream &is, VolumeDescriptorRecord &data)
std::ostream & operator<< (std::ostream &os, const VolumeDir &data)
std::istream & operator>> (std::istream &is, VolumeDir &data)
Variables
std::string _ds_name
std::string _ds_type
std::string _filename
double _ds_offset
double _ds_size
int _num_dsr
int _dsr_size
ossimSharedObjectInfo cnesInfo
ossimString cnesDescription
std::vector< ossimStringcnesObjList
Typedef Documentation
◆ DataHistogramProcessedData8
Definition at line 158 of file DataHistogramSignalData.h.
◆ ImageOptionsFilePointerRecord
Definition at line 302 of file FilePointerRecord.h.
◆ SARLeaderFilePointerRecord
Definition at line 301 of file FilePointerRecord.h.
◆ SARTrailerFilePointerRecord
Definition at line 303 of file FilePointerRecord.h.
Function Documentation
◆ fnint()
double ossimplugins::fnint ( double  x)
Definition at line 35 of file Arithmetic.h.
References x.
Referenced by ossimplugins::JSDDateTime::NormDate().
36  {
37  return (x >= 0.0) ? (double)((long)(x + 0.5)) : (double)((long)(x - 0.5));
38  }
ossim_uint32 x
◆ getCnesClassName()
const char* ossimplugins::getCnesClassName ( int  idx)
Definition at line 51 of file ossimPluginInit.cpp.
References cnesObjList.
Referenced by ossimSharedLibraryInitialize().
52  {
53  if(idx < (int)cnesObjList.size())
54  {
55  return cnesObjList[idx].c_str();
56  }
57  return (const char*)0;
58  }
std::vector< ossimString > cnesObjList
◆ getCnesDescription()
const char* ossimplugins::getCnesDescription ( )
Definition at line 43 of file ossimPluginInit.cpp.
References ossimString::c_str(), and cnesDescription.
44  {
45  return cnesDescription.c_str();
46  }
const char * c_str() const
Definition: ossimString.h:396
◆ getCnesNumberOfClassNames()
int ossimplugins::getCnesNumberOfClassNames ( )
Definition at line 47 of file ossimPluginInit.cpp.
48  {
49  return (int)cnesObjList.size();
50  }
◆ inint()
long ossimplugins::inint ( double  x)
Definition at line 26 of file Arithmetic.h.
References x.
27  {
28  return (x >= 0.0) ? (long)(x + 0.5) : (long)(x-0.5) ;
29  }
ossim_uint32 x
◆ operator<<() [1/63]
std::ostream& ossimplugins::operator<< ( std::ostream &  os,
const DataHistogramProcessedData data
Definition at line 24 of file DataHistogramProcessedData.cpp.
References ossimplugins::DataHistogramProcessedData::_histogram1, ossimplugins::DataHistogramProcessedData::_histogram2, ossimplugins::DataHistogramProcessedData::_ltab, ossimplugins::DataHistogramProcessedData::_ntab, ossimplugins::DataHistogramProcessedData::_rec_seq, and ossimplugins::DataHistogramProcessedData::_sar_chn.
25 {
26  os<<"rec_seq:"<<data._rec_seq<<std::endl;
27
28  os<<"sar_chn:"<<data._sar_chn<<std::endl;
29
30  os<<"ntab:"<<data._ntab<<std::endl;
31
32  os<<"ltab:"<<data._ltab<<std::endl;
33
34  os<<data._histogram1<<std::endl;
35
36  os<<data._histogram2<<std::endl;
37
38  return os;
39 }
◆ operator<<() [2/63]
const PlatformPositionData data
Definition at line 24 of file PlatformPositionData.cpp.
References ossimplugins::PlatformPositionData::_alt_poserr, ossimplugins::PlatformPositionData::_alt_velerr, ossimplugins::PlatformPositionData::_crt_poserr, ossimplugins::PlatformPositionData::_crt_velerr, ossimplugins::PlatformPositionData::_data_int, ossimplugins::PlatformPositionData::_day, ossimplugins::PlatformPositionData::_gmt_day, ossimplugins::PlatformPositionData::_gmt_sec, ossimplugins::PlatformPositionData::_hr_angle, ossimplugins::PlatformPositionData::_month, ossimplugins::PlatformPositionData::_ndata, ossimplugins::PlatformPositionData::_orbit_ele, ossimplugins::PlatformPositionData::_orbit_ele_desg, ossimplugins::PlatformPositionData::_pos_vect, ossimplugins::PlatformPositionData::_rad_poserr, ossimplugins::PlatformPositionData::_rad_velerr, ossimplugins::PlatformPositionData::_ref_coord, and ossimplugins::PlatformPositionData::_year.
25 {
26  os<<"orbit_ele_desg:"<<data._orbit_ele_desg.c_str()<<std::endl;
27
28  for(int i=0;i<6;i++)
29  {
30  os<<"orbit_ele["<<i<<"]:"<<data._orbit_ele[i]<<std::endl;
31  }
32
33  os<<"ndata:"<<data._ndata<<std::endl;
34
35  os<<"year:"<<data._year<<std::endl;
36
37  os<<"month:"<<data._month<<std::endl;
38
39  os<<"day:"<<data._day<<std::endl;
40
41  os<<"gmt_day:"<<data._gmt_day<<std::endl;
42
43  os<<"gmt_sec:"<<data._gmt_sec<<std::endl;
44
45  os<<"data_int:"<<data._data_int<<std::endl;
46
47  os<<"ref_coord:"<<data._ref_coord.c_str()<<std::endl;
48
49  os<<"hr_angle:"<<data._hr_angle<<std::endl;
50
51  os<<"alt_poserr:"<<data._alt_poserr<<std::endl;
52
53  os<<"crt_poserr:"<<data._crt_poserr<<std::endl;
54
55  os<<"rad_poserr:"<<data._rad_poserr<<std::endl;
56
57  os<<"alt_velerr:"<<data._alt_velerr<<std::endl;
58
59  os<<"crt_velerr:"<<data._crt_velerr<<std::endl;
60
61  os<<"rad_velerr:"<<data._rad_velerr<<std::endl;
62
63  for (int i=0;i<64;i++)
64  {
65  os<<"pos_vect["<<i<<"]:"<<data._pos_vect[i]<<std::endl;
66  }
67
68  return os;
69 }
◆ operator<<() [3/63]
const PositionVectorRecord data
Definition at line 24 of file PositionVectorRecord.cpp.
References ossimplugins::PositionVectorRecord::_pos, and ossimplugins::PositionVectorRecord::_vel.
25 {
26  for (int i=0;i<3;i++)
27  {
28  os<<"pos["<<i<<"]:"<<data._pos[i]<<std::endl;
29  }
30
31  for (int i=0;i<3;i++)
32  {
33  os<<"vel["<<i<<"]:"<<data._vel[i]<<std::endl;
34  }
35  return os;
36 }
◆ operator<<() [4/63]
const RadarSatRecordHeader data
Definition at line 24 of file RadarSatRecordHeader.cpp.
References ossimplugins::RadarSatRecordHeader::_length, ossimplugins::RadarSatRecordHeader::_rec_seq, ossimplugins::RadarSatRecordHeader::_rec_sub1, ossimplugins::RadarSatRecordHeader::_rec_sub2, ossimplugins::RadarSatRecordHeader::_rec_sub3, and ossimplugins::RadarSatRecordHeader::_rec_type.
25 {
26  os<<"record_sequence_number:"<<data._rec_seq<<std::endl;
27  os<<"first_record_sub-type:"<<(int)data._rec_sub1<<std::endl;
28  os<<"record_type_code:"<<(int)data._rec_type<<std::endl;
29  os<<"second_record_sub-type:"<<(int)data._rec_sub2<<std::endl;
30  os<<"third_record_sub-type:"<<(int)data._rec_sub3<<std::endl;
31  os<<"length:"<<data._length<<std::endl;
32  return os;
33 }
◆ operator<<() [5/63]
const FilePointerRecord data
Definition at line 24 of file FilePointerRecord.cpp.
References ossimplugins::FilePointerRecord::_ascii_flag, ossimplugins::FilePointerRecord::_data_code, ossimplugins::FilePointerRecord::_data_type, ossimplugins::FilePointerRecord::_file_class, ossimplugins::FilePointerRecord::_file_code, ossimplugins::FilePointerRecord::_file_name, ossimplugins::FilePointerRecord::_file_num, ossimplugins::FilePointerRecord::_first_len, ossimplugins::FilePointerRecord::_first_phyvol, ossimplugins::FilePointerRecord::_first_rec, ossimplugins::FilePointerRecord::_last_phyvol, ossimplugins::FilePointerRecord::_last_rec, ossimplugins::FilePointerRecord::_len_code, ossimplugins::FilePointerRecord::_len_type, ossimplugins::FilePointerRecord::_max_len, and ossimplugins::FilePointerRecord::_nrec.
25 {
26  os<<"ascii_flag:"<<data._ascii_flag.c_str()<<std::endl;
27  os<<"file_num:"<<data._file_num<<std::endl;
28  os<<"file_name:"<<data._file_name.c_str()<<std::endl;
29  os<<"file_class:"<<data._file_class.c_str()<<std::endl;
30  os<<"file_code:"<<data._file_code.c_str()<<std::endl;
31  os<<"data_type:"<<data._data_type.c_str()<<std::endl;
32  os<<"data_code:"<<data._data_code.c_str()<<std::endl;
33  os<<"nrec:"<<data._nrec<<std::endl;
34  os<<"first_len:"<<data._first_len<<std::endl;
35  os<<"max_len:"<<data._max_len<<std::endl;
36  os<<"len_type:"<<data._len_type.c_str()<<std::endl;
37  os<<"len_code:"<<data._len_code.c_str()<<std::endl;
38  os<<"first_phyvol:"<<data._first_phyvol<<std::endl;
39  os<<"last_phyvol:"<<data._last_phyvol<<std::endl;
40  os<<"first_rec:"<<data._first_rec<<std::endl;
41  os<<"last_rec:"<<data._last_rec<<std::endl;
42  return os;
43 }
◆ operator<<() [6/63]
const dsd data
Definition at line 24 of file dsd.cpp.
References ossimplugins::dsd::_ds_name, ossimplugins::dsd::_ds_offset, ossimplugins::dsd::_ds_size, ossimplugins::dsd::_ds_type, ossimplugins::dsd::_dsr_size, ossimplugins::dsd::_filename, and ossimplugins::dsd::_num_dsr.
25  {
26  os<<"ds_name:"<<data._ds_name.c_str()<<std::endl;
27  os<<"ds_type:"<<data._ds_type.c_str()<<std::endl;
28  os<<"filename:"<<data._filename.c_str()<<std::endl;
29  os<<"ds_offset:"<<data._ds_offset<<std::endl;
30  os<<"ds_size:"<<data._ds_size<<std::endl;
31  os<<"num_dsr:"<<data._num_dsr<<std::endl;
32  os<<"dsr_size:"<<data._dsr_size<<std::endl;
33
34  return os;
35  }
◆ operator<<() [7/63]
const mph data
Definition at line 24 of file mph.cpp.
References ossimplugins::mph::_abs_orbit, ossimplugins::mph::_absolute_orbit_title, ossimplugins::mph::_acq_stat_id_title, ossimplugins::mph::_acq_station, ossimplugins::mph::_clock_step, ossimplugins::mph::_clock_step_title, ossimplugins::mph::_clock_step_units, ossimplugins::mph::_cycle, ossimplugins::mph::_cycle_title, ossimplugins::mph::_delta_ut1, ossimplugins::mph::_delta_ut1_title, ossimplugins::mph::_delta_ut1_units, ossimplugins::mph::_dsd_size, ossimplugins::mph::_leap_err, ossimplugins::mph::_leap_err_title, ossimplugins::mph::_leap_sign, ossimplugins::mph::_leap_sign_title, ossimplugins::mph::_leap_utc, ossimplugins::mph::_leap_utc_title, ossimplugins::mph::_num_data_sets, ossimplugins::mph::_num_dsd, ossimplugins::mph::_number_of_ds_att_title, ossimplugins::mph::_number_of_dsd_title, ossimplugins::mph::_phase, ossimplugins::mph::_phase_title, ossimplugins::mph::_proc_center, ossimplugins::mph::_proc_center_title, ossimplugins::mph::_proc_stage, ossimplugins::mph::_proc_stage_title, ossimplugins::mph::_proc_time, ossimplugins::mph::_proc_time_title, ossimplugins::mph::_product, ossimplugins::mph::_product_err, ossimplugins::mph::_product_err_title, ossimplugins::mph::_product_name, ossimplugins::mph::_ref_doc, ossimplugins::mph::_ref_doc_title, ossimplugins::mph::_rel_orbit, ossimplugins::mph::_relative_orbit_title, ossimplugins::mph::_sat_binary_time, ossimplugins::mph::_sat_binary_time_title, ossimplugins::mph::_sensing_start, ossimplugins::mph::_sensing_start_title, ossimplugins::mph::_sensing_stop, ossimplugins::mph::_sensing_stop_title, ossimplugins::mph::_size_of_dsd_title, ossimplugins::mph::_size_of_dsd_units, ossimplugins::mph::_soft_version, ossimplugins::mph::_soft_version_title, ossimplugins::mph::_spare_4, ossimplugins::mph::_sph_size, ossimplugins::mph::_sph_size_title, ossimplugins::mph::_sph_size_units, ossimplugins::mph::_state_vector_time, ossimplugins::mph::_state_vector_time_title, ossimplugins::mph::_tot_size, ossimplugins::mph::_total_size_title, ossimplugins::mph::_total_size_units, ossimplugins::mph::_utc_sbt_time, ossimplugins::mph::_utc_sbt_time_title, ossimplugins::mph::_vector_source, ossimplugins::mph::_vector_source_title, ossimplugins::mph::_x_position, ossimplugins::mph::_x_position_title, ossimplugins::mph::_x_position_units, ossimplugins::mph::_x_velocity, ossimplugins::mph::_x_velocity_title, ossimplugins::mph::_x_velocity_units, ossimplugins::mph::_y_position, ossimplugins::mph::_y_position_title, ossimplugins::mph::_y_position_units, ossimplugins::mph::_y_velocity, ossimplugins::mph::_y_velocity_title, ossimplugins::mph::_y_velocity_units, ossimplugins::mph::_z_position, ossimplugins::mph::_z_position_title, ossimplugins::mph::_z_position_units, ossimplugins::mph::_z_velocity, ossimplugins::mph::_z_velocity_title, and ossimplugins::mph::_z_velocity_units.
25  {
26  os<<"product_name:"<<data._product_name.c_str()<<std::endl;
27
28  os<<"product:"<<data._product.c_str()<<std::endl;
29
30  os<<"proc_stage_title:"<<data._proc_stage_title.c_str()<<std::endl;
31
32  os<<"proc_stage:"<<data._proc_stage.c_str()<<std::endl;
33
34  os<<"ref_doc_title:"<<data._ref_doc_title.c_str()<<std::endl;
35
36  os<<"ref_doc:"<<data._ref_doc.c_str()<<std::endl;
37
38  os<<"acq_stat_id_title:"<<data._acq_stat_id_title.c_str()<<std::endl;
39
40  os<<"acq_station:"<<data._acq_station.c_str()<<std::endl;
41
42  os<<"proc_center_title:"<<data._proc_center_title.c_str()<<std::endl;
43
44  os<<"proc_center:"<<data._proc_center.c_str()<<std::endl;
45
46  os<<"proc_time_title:"<<data._proc_time_title.c_str()<<std::endl;
47
48  os<<"proc_time:"<<data._proc_time.c_str()<<std::endl;
49
50  os<<"soft_version_title:"<<data._soft_version_title.c_str()<<std::endl;
51
52  os<<"soft_version:"<<data._soft_version.c_str()<<std::endl;
53
54  os<<"sensing_start_title:"<<data._sensing_start_title.c_str()<<std::endl;
55
56  os<<"sensing_start:"<<data._sensing_start.c_str()<<std::endl;
57
58  os<<"sensing_stop_title:"<<data._sensing_stop_title.c_str()<<std::endl;
59
60  os<<"sensing_stop:"<<data._sensing_stop.c_str()<<std::endl;
61
62  os<<"phase_title:"<<data._phase_title.c_str()<<std::endl;
63
64  os<<"phase:"<<data._phase.c_str()<<std::endl;
65
66  os<<"cycle_title:"<<data._cycle_title.c_str()<<std::endl;
67
68  os<<"cycle:"<<data._cycle.c_str()<<std::endl;
69
70  os<<"relative_orbit_title:"<<data._relative_orbit_title.c_str()<<std::endl;
71
72  os<<"rel_orbit:"<<data._rel_orbit.c_str()<<std::endl;
73
74  os<<"absolute_orbit_title:"<<data._absolute_orbit_title.c_str()<<std::endl;
75
76  os<<"abs_orbit:"<<data._abs_orbit.c_str()<<std::endl;
77
78  os<<"state_vector_time_title:"<<data._state_vector_time_title.c_str()<<std::endl;
79
80  os<<"state_vector_time:"<<data._state_vector_time.c_str()<<std::endl;
81
82  os<<"delta_ut1_title:"<<data._delta_ut1_title.c_str()<<std::endl;
83
84  os<<"delta_ut1:"<<data._delta_ut1.c_str()<<std::endl;
85
86  os<<"delta_ut1_units:"<<data._delta_ut1_units.c_str()<<std::endl;
87
88  os<<"x_position_title:"<<data._x_position_title.c_str()<<std::endl;
89
90  os<<"x_position:"<<data._x_position.c_str()<<std::endl;
91
92  os<<"x_position_units:"<<data._x_position_units.c_str()<<std::endl;
93
94  os<<"y_position_title:"<<data._y_position_title.c_str()<<std::endl;
95
96  os<<"y_position:"<<data._y_position.c_str()<<std::endl;
97
98  os<<"y_position_units:"<<data._y_position_units.c_str()<<std::endl;
99
100  os<<"z_position_title:"<<data._z_position_title.c_str()<<std::endl;
101
102  os<<"z_position:"<<data._z_position.c_str()<<std::endl;
103
104  os<<"z_position_units:"<<data._z_position_units.c_str()<<std::endl;
105
106  os<<"x_velocity_title:"<<data._x_velocity_title.c_str()<<std::endl;
107
108  os<<"x_velocity:"<<data._x_velocity.c_str()<<std::endl;
109
110  os<<"x_velocity_units:"<<data._x_velocity_units.c_str()<<std::endl;
111
112  os<<"y_velocity_title:"<<data._y_velocity_title.c_str()<<std::endl;
113
114  os<<"y_velocity:"<<data._y_velocity.c_str()<<std::endl;
115
116  os<<"y_velocity_units:"<<data._y_velocity_units.c_str()<<std::endl;
117
118  os<<"z_velocity_title:"<<data._z_velocity_title.c_str()<<std::endl;
119
120  os<<"z_velocity:"<<data._z_velocity.c_str()<<std::endl;
121
122  os<<"z_velocity_units:"<<data._z_velocity_units.c_str()<<std::endl;
123
124  os<<"vector_source_title:"<<data._vector_source_title.c_str()<<std::endl;
125
126  os<<"vector_source:"<<data._vector_source.c_str()<<std::endl;
127
128  os<<"spare_4:"<<data._spare_4.c_str()<<std::endl;
129
130  os<<"utc_sbt_time_title:"<<data._utc_sbt_time_title.c_str()<<std::endl;
131
132  os<<"utc_sbt_time:"<<data._utc_sbt_time.c_str()<<std::endl;
133
134  os<<"sat_binary_time_title:"<<data._sat_binary_time_title.c_str()<<std::endl;
135
136  os<<"sat_binary_time:"<<data._sat_binary_time.c_str()<<std::endl;
137
138  os<<"clock_step_title:"<<data._clock_step_title.c_str()<<std::endl;
139
140  os<<"clock_step:"<<data._clock_step.c_str()<<std::endl;
141
142  os<<"clock_step_units:"<<data._clock_step_units.c_str()<<std::endl;
143
144  os<<"leap_utc_title:"<<data._leap_utc_title.c_str()<<std::endl;
145
146  os<<"leap_utc:"<<data._leap_utc.c_str()<<std::endl;
147
148  os<<"leap_sign_title:"<<data._leap_sign_title.c_str()<<std::endl;
149
150  os<<"leap_sign:"<<data._leap_sign.c_str()<<std::endl;
151
152  os<<"leap_err_title:"<<data._leap_err_title.c_str()<<std::endl;
153
154  os<<"leap_err:"<<data._leap_err.c_str()<<std::endl;
155
156  os<<"product_err_title:"<<data._product_err_title.c_str()<<std::endl;
157
158  os<<"product_err:"<<data._product_err.c_str()<<std::endl;
159
160  os<<"total_size_title:"<<data._total_size_title.c_str()<<std::endl;
161
162  os<<"tot_size:"<<data._tot_size.c_str()<<std::endl;
163
164  os<<"total_size_units:"<<data._total_size_units.c_str()<<std::endl;
165
166  os<<"sph_size_title:"<<data._sph_size_title.c_str()<<std::endl;
167
168  os<<"sph_size:"<<data._sph_size.c_str()<<std::endl;
169
170  os<<"sph_size_units:"<<data._sph_size_units.c_str()<<std::endl;
171
172  os<<"number_of_dsd_title:"<<data._number_of_dsd_title.c_str()<<std::endl;
173
174  os<<"num_dsd:"<<data._num_dsd<<std::endl;
175
176  os<<"size_of_dsd_title:"<<data._size_of_dsd_title.c_str()<<std::endl;
177
178  os<<"dsd_size:"<<data._dsd_size<<std::endl;
179
180  os<<"size_of_dsd_units:"<<data._size_of_dsd_units.c_str()<<std::endl;
181
182  os<<"number_of_ds_att_title:"<<data._number_of_ds_att_title.c_str()<<std::endl;
183
184  os<<"num_data_sets:"<<data._num_data_sets<<std::endl;
185
186  return os;
187
188  }
◆ operator<<() [8/63]
const TextRecord data
Definition at line 24 of file TextRecord.cpp.
References ossimplugins::TextRecord::_ascii_flag, ossimplugins::TextRecord::_cont_flag, ossimplugins::TextRecord::_copyright_info, ossimplugins::TextRecord::_phyvol_id, ossimplugins::TextRecord::_product_create, ossimplugins::TextRecord::_product_type, ossimplugins::TextRecord::_scene_id, and ossimplugins::TextRecord::_scene_loc.
25 {
27  os<<"cont_flag:"<<data._cont_flag.c_str()<<std::endl;
28  os<<"product_type:"<<data._product_type.c_str()<<std::endl;
29  os<<"product_create:"<<data._product_create.c_str()<<std::endl;
30  os<<"phyvol_id:"<<data._phyvol_id.c_str()<<std::endl;
31  os<<"scene_id:"<<data._scene_id.c_str()<<std::endl;
32  os<<"scene_loc:"<<data._scene_loc.c_str()<<std::endl;
33  os<<"copyright_info:"<<data._copyright_info.c_str()<<std::endl;
34  return os;
35 }
◆ operator<<() [9/63]
const VolumeDescriptorRecord data
Definition at line 24 of file VolumeDescriptorRecord.cpp.
References ossimplugins::VolumeDescriptorRecord::_ascii_flag, ossimplugins::VolumeDescriptorRecord::_curr_phyvol, ossimplugins::VolumeDescriptorRecord::_first_file, ossimplugins::VolumeDescriptorRecord::_first_phyvol, ossimplugins::VolumeDescriptorRecord::_format_doc, ossimplugins::VolumeDescriptorRecord::_format_rev, ossimplugins::VolumeDescriptorRecord::_format_ver, ossimplugins::VolumeDescriptorRecord::_last_phyvol, ossimplugins::VolumeDescriptorRecord::_logvol_agency, ossimplugins::VolumeDescriptorRecord::_logvol_country, ossimplugins::VolumeDescriptorRecord::_logvol_date, ossimplugins::VolumeDescriptorRecord::_logvol_facility, ossimplugins::VolumeDescriptorRecord::_logvol_id, ossimplugins::VolumeDescriptorRecord::_logvol_time, ossimplugins::VolumeDescriptorRecord::_n_filepoint, ossimplugins::VolumeDescriptorRecord::_n_voldir, ossimplugins::VolumeDescriptorRecord::_phyvol_cnt, ossimplugins::VolumeDescriptorRecord::_phyvol_id, ossimplugins::VolumeDescriptorRecord::_phyvol_log, ossimplugins::VolumeDescriptorRecord::_product_id, ossimplugins::VolumeDescriptorRecord::_software_id, ossimplugins::VolumeDescriptorRecord::_volset_id, and ossimplugins::VolumeDescriptorRecord::_volset_log.
25 {
27  os<<"format_doc:"<<data._format_doc.c_str()<<std::endl;
28  os<<"format_ver:"<<data._format_ver.c_str()<<std::endl;
29  os<<"format_rev:"<<data._format_rev.c_str()<<std::endl;
30  os<<"software_id:"<<data._software_id.c_str()<<std::endl;
31  os<<"phyvol_id:"<<data._phyvol_id.c_str()<<std::endl;
32  os<<"logvol_id:"<<data._logvol_id.c_str()<<std::endl;
33  os<<"volset_id:"<<data._volset_id.c_str()<<std::endl;
34  os<<"phyvol_cnt:"<<data._phyvol_cnt<<std::endl;
35  os<<"first_phyvol:"<<data._first_phyvol<<std::endl;
36  os<<"last_phyvol:"<<data._last_phyvol<<std::endl;
37  os<<"curr_phyvol:"<<data._curr_phyvol<<std::endl;
38  os<<"first_file:"<<data._first_file<<std::endl;
39  os<<"volset_log:"<<data._volset_log<<std::endl;
40  os<<"phyvol_log:"<<data._phyvol_log<<std::endl;
41  os<<"logvol_date:"<<data._logvol_date.c_str()<<std::endl;
42  os<<"logvol_time:"<<data._logvol_time.c_str()<<std::endl;
43  os<<"logvol_country:"<<data._logvol_country.c_str()<<std::endl;
44  os<<"logvol_agency:"<<data._logvol_agency.c_str()<<std::endl;
45  os<<"logvol_facility:"<<data._logvol_facility.c_str()<<std::endl;
46  os<<"n_filepoint:"<<data._n_filepoint<<std::endl;
47  os<<"n_voldir:"<<data._n_voldir<<std::endl;
48  os<<"product_id:"<<data._product_id.c_str()<<std::endl;
49
50
51  return os;
52 }
◆ operator<<() [10/63]
const SRGRConversionParameters data
Definition at line 24 of file SRGRConversionParameters.cpp.
References ossimplugins::SRGRConversionParameters::_attach_flag, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_day, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_microsec, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_sec, ossimplugins::SRGRConversionParameters::_ground_range_origin, ossimplugins::SRGRConversionParameters::_slant_range_time, and ossimplugins::SRGRConversionParameters::_srgr_coef.
25  {
26  os<<"first_zero_doppler_time_day:"<<data._first_zero_doppler_time_day<<std::endl;
27
28  os<<"first_zero_doppler_time_sec:"<<data._first_zero_doppler_time_sec<<std::endl;
29
30  os<<"first_zero_doppler_time_microsec:"<<data._first_zero_doppler_time_microsec<<std::endl;
31
32  os<<"attach_flag:"<<data._attach_flag<<std::endl;
33
34  os<<"_slant_range_time:"<<data._slant_range_time<<std::endl;
35
36  os<<"_ground_range_origin:"<<data._ground_range_origin<<std::endl;
37
38  for (int i = 0; i<5; i++) {
39  os<<"_srgr_coef[i]:"<<data._srgr_coef[i]<<std::endl;
40  }
41
42  return os;
43
44  }
◆ operator<<() [11/63]
const BeamInformationRecord data
Definition at line 24 of file BeamInformationRecord.cpp.
References ossimplugins::BeamInformationRecord::_beam_look_ang, ossimplugins::BeamInformationRecord::_beam_look_src, ossimplugins::BeamInformationRecord::_beam_type, and ossimplugins::BeamInformationRecord::_prf.
25 {
26  os<<"beam_type:"<<data._beam_type.c_str()<<std::endl;
27
28  os<<"beam_look_src:"<<data._beam_look_src.c_str()<<std::endl;
29
30  os<<"beam_look_ang:"<<data._beam_look_ang<<std::endl;
31
32  os<<"prf:"<<data._prf<<std::endl;
33
34  return os;
35 }
◆ operator<<() [12/63]
const BeamPixelCountRecord data
Definition at line 24 of file BeamPixelCountRecord.cpp.
References ossimplugins::BeamPixelCountRecord::_n_pix, and ossimplugins::BeamPixelCountRecord::_pix_update.
25 {
26  os<<"pix_update:"<<data._pix_update.c_str()<<std::endl;
27
28  for (int i=0;i<4;i++)
29  {
30  os<<"crt_m["<<i<<":"<<data._n_pix[i]<<std::endl;
31  }
32  return os;
33 }
◆ operator<<() [13/63]
const CompensationDataRecord data
Definition at line 24 of file CompensationDataRecord.cpp.
References ossimplugins::CompensationDataRecord::_beam_tab, ossimplugins::CompensationDataRecord::_beam_tab_inc, ossimplugins::CompensationDataRecord::_beam_tab_size, ossimplugins::CompensationDataRecord::_beam_type, ossimplugins::CompensationDataRecord::_comp_descr, ossimplugins::CompensationDataRecord::_comp_desig, ossimplugins::CompensationDataRecord::_comp_seq_no, ossimplugins::CompensationDataRecord::_look_angle, and ossimplugins::CompensationDataRecord::_n_comp_rec.
25 {
26  os<<"comp_desig:"<<data._comp_desig.c_str()<<std::endl;
27
28  os<<"comp_descr:"<<data._comp_descr.c_str()<<std::endl;
29
30  os<<"n_comp_rec:"<<data._n_comp_rec<<std::endl;
31
32  os<<"comp_seq_no:"<<data._comp_seq_no<<std::endl;
33
34  os<<"beam_tab_size:"<<data._beam_tab_size<<std::endl;
35
36  for (int i=0;i<256;i++)
37  {
38  os<<"beam_tab["<<i<<"]:"<<data._beam_tab[i]<<std::endl;
39  }
40
41  os<<"beam_type:"<<data._beam_type.c_str()<<std::endl;
42
43  os<<"look_angle:"<<data._look_angle<<std::endl;
44
45  os<<"beam_tab_inc:"<<data._beam_tab_inc<<std::endl;
46  return os;
47 }
◆ operator<<() [14/63]
const DataPointDataRecord data
Definition at line 24 of file DataPointDataRecord.cpp.
References ossimplugins::DataPointDataRecord::_gmt_day, ossimplugins::DataPointDataRecord::_gmt_sec, ossimplugins::DataPointDataRecord::_pitch, ossimplugins::DataPointDataRecord::_pitch_flag, ossimplugins::DataPointDataRecord::_pitch_rate, ossimplugins::DataPointDataRecord::_pitch_rate_flag, ossimplugins::DataPointDataRecord::_roll, ossimplugins::DataPointDataRecord::_roll_flag, ossimplugins::DataPointDataRecord::_roll_rate, ossimplugins::DataPointDataRecord::_roll_rate_flag, ossimplugins::DataPointDataRecord::_yaw, ossimplugins::DataPointDataRecord::_yaw_flag, ossimplugins::DataPointDataRecord::_yaw_rate, and ossimplugins::DataPointDataRecord::_yaw_rate_flag.
25 {
26  os<<"gmt_day:"<<data._gmt_day<<std::endl;
27  os<<"gmt_sec:"<<data._gmt_sec<<std::endl;
28  os<<"pitch_flag:"<<data._pitch_flag<<std::endl;
29  os<<"roll_flag:"<<data._roll_flag<<std::endl;
30  os<<"yaw_flag:"<<data._yaw_flag<<std::endl;
31  os<<"pitch:"<<data._pitch<<std::endl;
32  os<<"roll:"<<data._roll<<std::endl;
33  os<<"yaw:"<<data._yaw<<std::endl;
34  os<<"pitch_rate_flag:"<<data._pitch_rate_flag<<std::endl;
35  os<<"roll_rate_flag:"<<data._roll_rate_flag<<std::endl;
36  os<<"yaw_rate_flag:"<<data._yaw_rate_flag<<std::endl;
37  os<<"pitch_rate:"<<data._pitch_rate<<std::endl;
38  os<<"roll_rate:"<<data._roll_rate<<std::endl;
39  os<<"yaw_rate:"<<data._yaw_rate<<std::endl;
40  return os;
41 }
◆ operator<<() [15/63]
const DataQuality data
Definition at line 24 of file DataQuality.cpp.
References ossimplugins::DataQuality::_alt_locerr, ossimplugins::DataQuality::_alt_scale, ossimplugins::DataQuality::_azi_ambig, ossimplugins::DataQuality::_azi_res, ossimplugins::DataQuality::_ber, ossimplugins::DataQuality::_cali_date, ossimplugins::DataQuality::_crt_locerr, ossimplugins::DataQuality::_crt_scale, ossimplugins::DataQuality::_dis_skew, ossimplugins::DataQuality::_dyn_rng, ossimplugins::DataQuality::_enl, ossimplugins::DataQuality::_islr, ossimplugins::DataQuality::_misreg, ossimplugins::DataQuality::_nchn, ossimplugins::DataQuality::_nesz, ossimplugins::DataQuality::_ori_err, ossimplugins::DataQuality::_pslr, ossimplugins::DataQuality::_rad_res, ossimplugins::DataQuality::_rad_unc, ossimplugins::DataQuality::_rad_unc_db, ossimplugins::DataQuality::_rad_unc_deg, ossimplugins::DataQuality::_rec_seq, ossimplugins::DataQuality::_rng_ambig, ossimplugins::DataQuality::_rng_res, ossimplugins::DataQuality::_sar_chn, ossimplugins::DataQuality::_snr, and ossimplugins::DataQuality::_tb_update.
25 {
26
27  os<<"rec_seq:"<<data._rec_seq<<std::endl;
28
29  os<<"sar_chn:"<<data._sar_chn.c_str()<<std::endl;
30
31  os<<"cali_date:"<<data._cali_date.c_str()<<std::endl;
32
33  os<<"nchn:"<<data._nchn<<std::endl;
34
35  os<<"islr:"<<data._islr<<std::endl;
36
37  os<<"pslr:"<<data._pslr<<std::endl;
38
39  os<<"azi_ambig:"<<data._azi_ambig<<std::endl;
40
41  os<<"rng_ambig:"<<data._rng_ambig<<std::endl;
42
43  os<<"snr:"<<data._snr<<std::endl;
44
45  os<<"ber:"<<data._ber<<std::endl;
46
47  os<<"rng_res:"<<data._rng_res<<std::endl;
48
49  os<<"azi_res:"<<data._azi_res<<std::endl;
50
51  os<<"rad_res:"<<data._rad_res<<std::endl;
52
53  os<<"dyn_rng:"<<data._dyn_rng<<std::endl;
54
55  os<<"rad_unc_db:"<<data._rad_unc_db<<std::endl;
56
57  os<<"rad_unc_deg:"<<data._rad_unc_deg<<std::endl;
58
59  for (int i=0;i<16;i++)
60  {
61  os<<"rad_unc:"<<data._rad_unc[i]<<std::endl;
62  }
63
64  os<<"alt_locerr:"<<data._alt_locerr<<std::endl;
65
66  os<<"crt_locerr:"<<data._crt_locerr<<std::endl;
67
68  os<<"alt_scale:"<<data._alt_scale<<std::endl;
69
70  os<<"crt_scale:"<<data._crt_scale<<std::endl;
71
72  os<<"dis_skew:"<<data._dis_skew<<std::endl;
73
74  os<<"ori_err:"<<data._ori_err<<std::endl;
75
76  for (int i=0;i<16;i++)
77  {
78  os<<"misreg:"<<data._misreg[i]<<std::endl;
79  }
80
81  os<<"nesz:"<<data._nesz<<std::endl;
82
83  os<<"enl:"<<data._enl<<std::endl;
84
85  os<<"tb_update:"<<data._tb_update.c_str()<<std::endl;
86
87
88  return os;
89 }
◆ operator<<() [16/63]
const DataSetSummary data
Definition at line 24 of file DataSetSummary.cpp.
References ossimplugins::DataSetSummary::_algor_id, ossimplugins::DataSetSummary::_alt_dopcen, ossimplugins::DataSetSummary::_alt_rate, ossimplugins::DataSetSummary::_ampl_coef, ossimplugins::DataSetSummary::_asc_des, ossimplugins::DataSetSummary::_auto_focus, ossimplugins::DataSetSummary::_azi_res, ossimplugins::DataSetSummary::_azi_weight, ossimplugins::DataSetSummary::_azim_beam, ossimplugins::DataSetSummary::_baseband_f, ossimplugins::DataSetSummary::_bnd_azi, ossimplugins::DataSetSummary::_bnd_azilok, ossimplugins::DataSetSummary::_bnd_rng, ossimplugins::DataSetSummary::_bnd_rnglok, ossimplugins::DataSetSummary::_chirp_ext_ind, ossimplugins::DataSetSummary::_chn_bits, ossimplugins::DataSetSummary::_clock_ang, ossimplugins::DataSetSummary::_clutter_lock, ossimplugins::DataSetSummary::_crt_dopcen, ossimplugins::DataSetSummary::_crt_rate, ossimplugins::DataSetSummary::_data_inpsrc, ossimplugins::DataSetSummary::_earth_mass, ossimplugins::DataSetSummary::_echo_track, ossimplugins::DataSetSummary::_ele_sight, ossimplugins::DataSetSummary::_elev_beam, ossimplugins::DataSetSummary::_ellip_des, ossimplugins::DataSetSummary::_ellip_j, ossimplugins::DataSetSummary::_ellip_maj, ossimplugins::DataSetSummary::_ellip_min, ossimplugins::DataSetSummary::_fa, ossimplugins::DataSetSummary::_fac_code, ossimplugins::DataSetSummary::_fac_id, ossimplugins::DataSetSummary::_fr, ossimplugins::DataSetSummary::_gn_cross, ossimplugins::DataSetSummary::_gn_polar, ossimplugins::DataSetSummary::_grav_const, ossimplugins::DataSetSummary::_i_bias, ossimplugins::DataSetSummary::_incident_ang, ossimplugins::DataSetSummary::_inp_sctim, ossimplugins::DataSetSummary::_iq_ratio, ossimplugins::DataSetSummary::_lev_code, ossimplugins::DataSetSummary::_line_cont, ossimplugins::DataSetSummary::_line_spacing, ossimplugins::DataSetSummary::_mech_sight, ossimplugins::DataSetSummary::_mission_id, ossimplugins::DataSetSummary::_motion_comp, ossimplugins::DataSetSummary::_n_azilok, ossimplugins::DataSetSummary::_n_rnglok, ossimplugins::DataSetSummary::_nchn, ossimplugins::DataSetSummary::_orbit_num, ossimplugins::DataSetSummary::_phas_coef, ossimplugins::DataSetSummary::_pix_spacing, ossimplugins::DataSetSummary::_plat_head, ossimplugins::DataSetSummary::_plat_lat, ossimplugins::DataSetSummary::_plat_long, ossimplugins::DataSetSummary::_pro_head, ossimplugins::DataSetSummary::_pro_lat, ossimplugins::DataSetSummary::_pro_long, ossimplugins::DataSetSummary::_prod_type, ossimplugins::DataSetSummary::_pulse_code, ossimplugins::DataSetSummary::_q_bias, ossimplugins::DataSetSummary::_quant_desc, ossimplugins::DataSetSummary::_radi_stretch, ossimplugins::DataSetSummary::_rng_gate, ossimplugins::DataSetSummary::_rng_length, ossimplugins::DataSetSummary::_rng_res, ossimplugins::DataSetSummary::_rng_weight, ossimplugins::DataSetSummary::_rngcmp_desg, ossimplugins::DataSetSummary::_rngcmp_f, ossimplugins::DataSetSummary::_sar_chn, ossimplugins::DataSetSummary::_sat_bintim, ossimplugins::DataSetSummary::_sat_clkinc, ossimplugins::DataSetSummary::_sat_clktim, ossimplugins::DataSetSummary::_sc_lin, ossimplugins::DataSetSummary::_sc_pix, ossimplugins::DataSetSummary::_scene_des, ossimplugins::DataSetSummary::_scene_id, ossimplugins::DataSetSummary::_scene_len, ossimplugins::DataSetSummary::_scene_wid, ossimplugins::DataSetSummary::_sensor_id, ossimplugins::DataSetSummary::_seq_num, ossimplugins::DataSetSummary::_sys_id, ossimplugins::DataSetSummary::_terrain_h, ossimplugins::DataSetSummary::_time_dir_lin, ossimplugins::DataSetSummary::_time_dir_pix, ossimplugins::DataSetSummary::_ver_id, and ossimplugins::DataSetSummary::_wave_length.
25 {
26  os<<"seq_num:"<<data._seq_num<<std::endl;
27
29
30  os<<"scene_id:"<<data._scene_id.c_str()<<std::endl;
31
32  os<<"scene_des:"<<data._scene_des.c_str()<<std::endl;
33
34  os<<"inp_sctim:"<<data._inp_sctim.c_str()<<std::endl;
35
36  os<<"asc_des:"<<data._asc_des.c_str()<<std::endl;
37
38  os<<"pro_lat:"<<data._pro_lat<<std::endl;
39
40  os<<"pro_long:"<<data._pro_long<<std::endl;
41
42  os<<"pro_head:"<<data._pro_head<<std::endl;
43
44  os<<"ellip_des:"<<data._ellip_des.c_str()<<std::endl;
45
46  os<<"ellip_maj:"<<data._ellip_maj<<std::endl;
47
48  os<<"ellip_min:"<<data._ellip_min<<std::endl;
49  os<<"earth_mass:"<<data._earth_mass<<std::endl;
50  os<<"grav_const:"<<data._grav_const<<std::endl;
51  os<<"ellip_j[0]:"<<data._ellip_j[0]<<std::endl;
52  os<<"ellip_j[1]:"<<data._ellip_j[1]<<std::endl;
53  os<<"ellip_j[2]:"<<data._ellip_j[2]<<std::endl;
54  os<<"terrain_h:"<<data._terrain_h<<std::endl;
55  os<<"sc_lin:"<<data._sc_lin<<std::endl;
56  os<<"sc_pix:"<<data._sc_pix<<std::endl;
57  os<<"scene_len:"<<data._scene_len<<std::endl;
58  os<<"scene_wid:"<<data._scene_wid<<std::endl;
59  os<<"nchn:"<<data._nchn<<std::endl;
60  os<<"mission_id:"<<data._mission_id.c_str()<<std::endl;
61  os<<"sensor_id:"<<data._sensor_id.c_str()<<std::endl;
62  os<<"orbit_num:"<<data._orbit_num.c_str()<<std::endl;
63
64  os<<"plat_lat:"<<data._plat_lat<<std::endl;
65
66  os<<"plat_long:"<<data._plat_long<<std::endl;
67
68  os<<"plat_head:"<<data._plat_head<<std::endl;
69
70  os<<"clock_ang:"<<data._clock_ang<<std::endl;
71
72  os<<"incident_ang:"<<data._incident_ang<<std::endl;
73
74
75  os<<"wave_length:"<<data._wave_length<<std::endl;
76
77  os<<"motion_comp:"<<data._motion_comp.c_str()<<std::endl;
78
79  os<<"pulse_code:"<<data._pulse_code.c_str()<<std::endl;
80
81  for (int i=0;i<5;i++)
82  {
83  os<<"ampl_coef["<<i<<"]:"<<data._ampl_coef[i]<<std::endl;
84  }
85
86  for (int i=0;i<5;i++)
87  {
88  os<<"phas_coef["<<i<<"]:"<<data._phas_coef[i]<<std::endl;
89  }
90
91  os<<"chirp_ext_ind:"<<data._chirp_ext_ind<<std::endl;
92
93  os<<"fr:"<<data._fr<<std::endl;
94
95  os<<"rng_gate:"<<data._rng_gate<<std::endl;
96
97  os<<"rng_length:"<<data._rng_length<<std::endl;
98
99  os<<"baseband_f:"<<data._baseband_f.c_str()<<std::endl;
100
101  os<<"rngcmp_f:"<<data._rngcmp_f.c_str()<<std::endl;
102
103  os<<"gn_polar:"<<data._gn_polar <<std::endl;
104
105  os<<"gn_cross:"<<data._gn_cross <<std::endl;
106
107  os<<"chn_bits:"<<data._chn_bits<<std::endl;
108
109  os<<"quant_desc:"<<data._quant_desc.c_str()<<std::endl;
110
111  os<<"i_bias:"<<data._i_bias<<std::endl;
112
113  os<<"q_bias:"<<data._q_bias<<std::endl;
114
115  os<<"iq_ratio:"<<data._iq_ratio<<std::endl;
116
117  os<<"ele_sight:"<<data._ele_sight<<std::endl;
118
119  os<<"mech_sight:"<<data._mech_sight<<std::endl;
120
121  os<<"echo_track:"<<data._echo_track.c_str()<<std::endl;
122
123  os<<"fa:"<<data._fa<<std::endl;
124
125  os<<"elev_beam:"<<data._elev_beam<<std::endl;
126
127  os<<"azim_beam:"<<data._azim_beam<<std::endl;
128
129  os<<"sat_bintim:"<<data._sat_bintim<<std::endl;
130
131  os<<"sat_clktim:"<<data._sat_clktim<<std::endl;
132
133  os<<"sat_clkinc:"<<data._sat_clkinc<<std::endl;
134
135  os<<"fac_id:"<<data._fac_id.c_str()<<std::endl;
136
137  os<<"sys_id:"<<data._sys_id.c_str()<<std::endl;
138
139  os<<"ver_id:"<<data._ver_id.c_str()<<std::endl;
140
141  os<<"fac_code:"<<data._fac_code.c_str()<<std::endl;
142
143  os<<"lev_code:"<<data._lev_code.c_str()<<std::endl;
144
145  os<<"prod_type:"<<data._prod_type.c_str()<<std::endl;
146
147  os<<"algor_id:"<<data._algor_id.c_str()<<std::endl;
148
149  os<<"n_azilok:"<<data._n_azilok<<std::endl;
150
151  os<<"n_rnglok:"<<data._n_rnglok<<std::endl;
152
153  os<<"bnd_azilok:"<<data._bnd_azilok<<std::endl;
154
155  os<<"bnd_rnglok:"<<data._bnd_rnglok<<std::endl;
156
157  os<<"bnd_azi:"<<data._bnd_azi<<std::endl;
158
159  os<<"bnd_rng:"<<data._bnd_rng<<std::endl;
160
161  os<<"azi_weight:"<<data._azi_weight.c_str()<<std::endl;
162
163  os<<"rng_weight:"<<data._rng_weight.c_str()<<std::endl;
164
165  os<<"data_inpsrc:"<<data._data_inpsrc.c_str()<<std::endl;
166
167  os<<"rng_res:"<<data._rng_res<<std::endl;
168
169  os<<"azi_res:"<<data._azi_res<<std::endl;
170
171  os<<"radi_stretch[0]:"<<data._radi_stretch[0]<<std::endl;
172  os<<"radi_stretch[1]:"<<data._radi_stretch[1]<<std::endl;
173
174  os<<"alt_dopcen[0]:"<<data._alt_dopcen[0]<<std::endl;
175  os<<"alt_dopcen[1]:"<<data._alt_dopcen[1]<<std::endl;
176  os<<"alt_dopcen[2]:"<<data._alt_dopcen[2]<<std::endl;
177
178  os<<"crt_dopcen[0]:"<<data._crt_dopcen[0]<<std::endl;
179  os<<"crt_dopcen[1]:"<<data._crt_dopcen[1]<<std::endl;
180  os<<"crt_dopcen[2]:"<<data._crt_dopcen[2]<<std::endl;
181
182  os<<"time_dir_pix:"<<data._time_dir_pix.c_str()<<std::endl;
183
184  os<<"time_dir_lin:"<<data._time_dir_lin.c_str()<<std::endl;
185
186  os<<"alt_rate[0]:"<<data._alt_rate[0]<<std::endl;
187  os<<"alt_rate[1]:"<<data._alt_rate[1]<<std::endl;
188  os<<"alt_rate[2]:"<<data._alt_rate[2]<<std::endl;
189
190  os<<"crt_rate[0]:"<<data._crt_rate[0]<<std::endl;
191  os<<"crt_rate[1]:"<<data._crt_rate[1]<<std::endl;
192  os<<"crt_rate[2]:"<<data._crt_rate[2]<<std::endl;
193
194  os<<"clutter_lock:"<<data._line_cont.c_str()<<std::endl;
195
196  os<<"clutter_lock:"<<data._clutter_lock.c_str()<<std::endl;
197
198  os<<"auto_focus:"<<data._auto_focus.c_str()<<std::endl;
199
200  os<<"line_spacing:"<<data._line_spacing<<std::endl;
201
202  os<<"pix_spacing:"<<data._pix_spacing<<std::endl;
203
204  os<<"rngcmp_desg:"<<data._rngcmp_desg.c_str()<<std::endl;
205
206  return os;
207
208 }
◆ operator<<() [17/63]
const DopplerCentroidEstimateRecord data
Definition at line 24 of file DopplerCentroidEstimateRecord.cpp.
References ossimplugins::DopplerCentroidEstimateRecord::_dopcen_coef, ossimplugins::DopplerCentroidEstimateRecord::_dopcen_conf, and ossimplugins::DopplerCentroidEstimateRecord::_dopcen_ref_tim.
25 {
26  os<<"dopcen_conf:"<<data._dopcen_conf<<std::endl;
27  os<<"dopcen_ref_tim:"<<data._dopcen_ref_tim<<std::endl;
29  {
30  os<<"dopcen_coef["<<i<<"]:"<<data._dopcen_coef[i]<<std::endl;
31  }
32
33  return os;
34 }
◆ operator<<() [18/63]
const FileDescriptor data
Definition at line 24 of file FileDescriptor.cpp.
References ossimplugins::FileDescriptor::_ascii_flag, ossimplugins::FileDescriptor::_code_len, ossimplugins::FileDescriptor::_code_loc, ossimplugins::FileDescriptor::_design_rev, ossimplugins::FileDescriptor::_file_name, ossimplugins::FileDescriptor::_file_num, ossimplugins::FileDescriptor::_format_doc, ossimplugins::FileDescriptor::_format_ver, ossimplugins::FileDescriptor::_l_anno_data, ossimplugins::FileDescriptor::_l_att_data, ossimplugins::FileDescriptor::_l_cal, ossimplugins::FileDescriptor::_l_data_his, ossimplugins::FileDescriptor::_l_dataset, ossimplugins::FileDescriptor::_l_dem_desc, ossimplugins::FileDescriptor::_l_det_proc, ossimplugins::FileDescriptor::_l_fac_data, ossimplugins::FileDescriptor::_l_gcp, ossimplugins::FileDescriptor::_l_map_proj, ossimplugins::FileDescriptor::_l_plat_pos, ossimplugins::FileDescriptor::_l_qual_sum, ossimplugins::FileDescriptor::_l_radar_par, ossimplugins::FileDescriptor::_l_radi_comp, ossimplugins::FileDescriptor::_l_radi_data, ossimplugins::FileDescriptor::_l_rang_spec, ossimplugins::FileDescriptor::_n_anno_data, ossimplugins::FileDescriptor::_n_att_data, ossimplugins::FileDescriptor::_n_cal, ossimplugins::FileDescriptor::_n_data_his, ossimplugins::FileDescriptor::_n_dataset, ossimplugins::FileDescriptor::_n_dem_desc, ossimplugins::FileDescriptor::_n_det_proc, ossimplugins::FileDescriptor::_n_fac_data, ossimplugins::FileDescriptor::_n_gcp, ossimplugins::FileDescriptor::_n_map_proj, ossimplugins::FileDescriptor::_n_plat_pos, ossimplugins::FileDescriptor::_n_qual_sum, ossimplugins::FileDescriptor::_n_radar_par, ossimplugins::FileDescriptor::_n_radi_comp, ossimplugins::FileDescriptor::_n_radi_data, ossimplugins::FileDescriptor::_n_rang_spec, ossimplugins::FileDescriptor::_rec_code, ossimplugins::FileDescriptor::_rec_len, ossimplugins::FileDescriptor::_rec_seq, ossimplugins::FileDescriptor::_rlen_len, ossimplugins::FileDescriptor::_rlen_loc, ossimplugins::FileDescriptor::_seq_len, ossimplugins::FileDescriptor::_seq_loc, and ossimplugins::FileDescriptor::_software_id.
25 {
29  os<<"design_rev:"<<data._design_rev.c_str()<<std::endl;
31  os<<"file_num:"<<data._file_num<<std::endl;
32  os<<"file_name:"<<data._file_name.c_str()<<std::endl;
33  os<<"rec_seq:"<<data._rec_seq.c_str()<<std::endl;
34  os<<"seq_loc:"<<data._seq_loc<<std::endl;
35  os<<"seq_len:"<<data._seq_len<<std::endl;
36  os<<"rec_code:"<<data._rec_code.c_str()<<std::endl;
37  os<<"code_loc:"<<data._code_loc<<std::endl;
38  os<<"code_len:"<<data._code_len<<std::endl;
39  os<<"rec_len:"<<data._rec_len.c_str()<<std::endl;
40  os<<"rlen_loc:"<<data._rlen_loc<<std::endl;
41  os<<"rlen_len:"<<data._rlen_len<<std::endl;
42  os<<"n_dataset:"<<data._n_dataset<<std::endl;
43  os<<"l_dataset:"<<data._l_dataset<<std::endl;
44  os<<"n_map_proj:"<<data._n_map_proj<<std::endl;
45  os<<"l_map_proj:"<<data._l_map_proj<<std::endl;
46  os<<"n_plat_pos:"<<data._n_plat_pos<<std::endl;
47  os<<"l_plat_pos:"<<data._l_plat_pos<<std::endl;
48  os<<"n_att_data:"<<data._n_att_data<<std::endl;
49  os<<"l_att_data:"<<data._l_att_data<<std::endl;
50  os<<"n_radi_data:"<<data._n_radi_data<<std::endl;
51  os<<"l_radi_data:"<<data._l_radi_data<<std::endl;
52  os<<"n_radi_comp:"<<data._n_radi_comp<<std::endl;
53  os<<"l_radi_comp:"<<data._l_radi_comp<<std::endl;
54  os<<"n_qual_sum:"<<data._n_qual_sum<<std::endl;
55  os<<"l_qual_sum:"<<data._l_qual_sum<<std::endl;
56  os<<"n_data_his:"<<data._n_data_his<<std::endl;
57  os<<"l_data_his:"<<data._l_data_his<<std::endl;
58  os<<"n_rang_spec:"<<data._n_rang_spec<<std::endl;
59  os<<"l_rang_spec:"<<data._l_rang_spec<<std::endl;
60  os<<"n_dem_desc:"<<data._n_dem_desc<<std::endl;
61  os<<"l_dem_desc:"<<data._l_dem_desc<<std::endl;
62  os<<"n_radar_par:"<<data._n_radar_par<<std::endl;
63  os<<"l_radar_par:"<<data._l_radar_par<<std::endl;
64  os<<"n_anno_data:"<<data._n_anno_data<<std::endl;
65  os<<"l_anno_data:"<<data._l_anno_data<<std::endl;
66  os<<"n_det_proc:"<<data._n_det_proc<<std::endl;
67  os<<"l_det_proc:"<<data._l_det_proc<<std::endl;
68  os<<"n_cal:"<<data._n_cal<<std::endl;
69  os<<"l_cal:"<<data._l_cal<<std::endl;
70  os<<"n_gcp:"<<data._n_gcp<<std::endl;
71  os<<"l_gcp:"<<data._l_gcp<<std::endl;
72  os<<"n_fac_data:"<<data._n_fac_data<<std::endl;
73  os<<"l_fac_data:"<<data._l_fac_data<<std::endl;
74  return os;
75 }
◆ operator<<() [19/63]
const MisregistrationRecord data
Definition at line 24 of file MisregistrationRecord.cpp.
References ossimplugins::MisregistrationRecord::_alt_m, and ossimplugins::MisregistrationRecord::_crt_m.
25 {
26  os<<"alt_m:"<<data._alt_m<<std::endl;
27  os<<"crt_m:"<<data._crt_m<<std::endl;
28  return os;
29 }
◆ operator<<() [20/63]
const ProcessingParameters data
Definition at line 24 of file ProcessingParameters.cpp.
References ossimplugins::ProcessingParameters::_act_ing_start, ossimplugins::ProcessingParameters::_act_ing_stop, ossimplugins::ProcessingParameters::_adc_samp_rate, ossimplugins::ProcessingParameters::_angle_first, ossimplugins::ProcessingParameters::_angle_last, ossimplugins::ProcessingParameters::_appl_type, ossimplugins::ProcessingParameters::_apply_dtm, ossimplugins::ProcessingParameters::_beam_edge_conf, ossimplugins::ProcessingParameters::_beam_edge_rqd, ossimplugins::ProcessingParameters::_beam_info, ossimplugins::ProcessingParameters::_bit_err_rate, ossimplugins::ProcessingParameters::_centre_lat, ossimplugins::ProcessingParameters::_centre_long, ossimplugins::ProcessingParameters::_complete_msg, ossimplugins::ProcessingParameters::_date_incons, ossimplugins::ProcessingParameters::_delay_changes, ossimplugins::ProcessingParameters::_density_in, ossimplugins::ProcessingParameters::_density_out, ossimplugins::ProcessingParameters::_dop_amb_err, ossimplugins::ProcessingParameters::_dopamb_conf, ossimplugins::ProcessingParameters::_dopcen_est, ossimplugins::ProcessingParameters::_dopcen_inc, ossimplugins::ProcessingParameters::_eph_orb_data, ossimplugins::ProcessingParameters::_err_amp_coef, ossimplugins::ProcessingParameters::_err_phas_coef, ossimplugins::ProcessingParameters::_exp_ing_start, ossimplugins::ProcessingParameters::_exp_ing_stop, ossimplugins::ProcessingParameters::_fm_crc_err, ossimplugins::ProcessingParameters::_gics_reqd, ossimplugins::ProcessingParameters::_gn_corctn_fctr, ossimplugins::ProcessingParameters::_img_cumu_dist, ossimplugins::ProcessingParameters::_img_hist_mean, ossimplugins::ProcessingParameters::_inp_media, ossimplugins::ProcessingParameters::_large_gap, ossimplugins::ProcessingParameters::_map_system, ossimplugins::ProcessingParameters::_media_id, ossimplugins::ProcessingParameters::_miss_ln, ossimplugins::ProcessingParameters::_mn_sig_lev, ossimplugins::ProcessingParameters::_n_beams, ossimplugins::ProcessingParameters::_n_dopcen, ossimplugins::ProcessingParameters::_n_image_pix, ossimplugins::ProcessingParameters::_n_pix_updates, ossimplugins::ProcessingParameters::_n_srgr, ossimplugins::ProcessingParameters::_n_tape_id, ossimplugins::ProcessingParameters::_n_temp_set, ossimplugins::ProcessingParameters::_num_state_vectors, ossimplugins::ProcessingParameters::_orb_data_src, ossimplugins::ProcessingParameters::_pix_count, ossimplugins::ProcessingParameters::_pix_overlap, ossimplugins::ProcessingParameters::_pixel_spacing, ossimplugins::ProcessingParameters::_post_img_gn, ossimplugins::ProcessingParameters::_prc_satur_pix, ossimplugins::ProcessingParameters::_prc_zero_pix, ossimplugins::ProcessingParameters::_pre_img_gn, ossimplugins::ProcessingParameters::_prf_changes, ossimplugins::ProcessingParameters::_proc_start, ossimplugins::ProcessingParameters::_proc_stop, ossimplugins::ProcessingParameters::_prod_type, ossimplugins::ProcessingParameters::_pulse_bandw, ossimplugins::ProcessingParameters::_pulse_cnt_1, ossimplugins::ProcessingParameters::_pulse_cnt_2, ossimplugins::ProcessingParameters::_pwin_end, ossimplugins::ProcessingParameters::_pwin_start, ossimplugins::ProcessingParameters::_rec_seq, ossimplugins::ProcessingParameters::_recd_type, ossimplugins::ProcessingParameters::_rej_bf_start, ossimplugins::ProcessingParameters::_rej_few_fram, ossimplugins::ProcessingParameters::_rej_ln, ossimplugins::ProcessingParameters::_rej_many_fram, ossimplugins::ProcessingParameters::_rej_mchn_err, ossimplugins::ProcessingParameters::_rej_rec_type, ossimplugins::ProcessingParameters::_rej_vchn_err, ossimplugins::ProcessingParameters::_rep_agc_attn, ossimplugins::ProcessingParameters::_rep_energy_gn, ossimplugins::ProcessingParameters::_rng_amp_coef, ossimplugins::ProcessingParameters::_rng_phas_coef, ossimplugins::ProcessingParameters::_rng_ref_src, ossimplugins::ProcessingParameters::_satellite_id, ossimplugins::ProcessingParameters::_scene_id, ossimplugins::ProcessingParameters::_scr_data_ind, ossimplugins::ProcessingParameters::_sens_config, ossimplugins::ProcessingParameters::_sens_orient, ossimplugins::ProcessingParameters::_skipd_frams, ossimplugins::ProcessingParameters::_slow_time_coef, ossimplugins::ProcessingParameters::_span_x, ossimplugins::ProcessingParameters::_span_y, ossimplugins::ProcessingParameters::_srgr_coefset, ossimplugins::ProcessingParameters::_state_time, ossimplugins::ProcessingParameters::_state_time_inc, ossimplugins::ProcessingParameters::_sych_marker, ossimplugins::ProcessingParameters::_tape_id, ossimplugins::ProcessingParameters::_temp, ossimplugins::ProcessingParameters::_temp_set_inc, ossimplugins::ProcessingParameters::_user_id, ossimplugins::ProcessingParameters::_wo_date, and ossimplugins::ProcessingParameters::_wo_number.
25  {
27
28  os<<"inp_media:"<<data._inp_media.c_str()<<std::endl;
29
30  os<<"n_tape_id:"<<data._n_tape_id<<std::endl;
31
32  for (int i=0;i<10;i++)
33  {
34  os<<"tape_id["<<i<<"]:"<<data._tape_id[i].c_str()<<std::endl;
35  }
36
37  os<<"exp_ing_start:"<<data._exp_ing_start.c_str()<<std::endl;
38
39  os<<"exp_ing_stop:"<<data._exp_ing_stop.c_str()<<std::endl;
40
41  os<<"act_ing_start:"<<data._act_ing_start.c_str()<<std::endl;
42
43  os<<"act_ing_stop:"<<data._act_ing_stop.c_str()<<std::endl;
44
45  os<<"proc_start:"<<data._proc_start.c_str()<<std::endl;
46
47  os<<"proc_stop:"<<data._proc_stop.c_str()<<std::endl;
48
49  for (int i=0;i<10;i++)
50  {
51  os<<"mn_sig_lev["<<i<<"]:"<<data._mn_sig_lev[i]<<std::endl;
52  }
53
54  os<<"scr_data_ind:"<<data._scr_data_ind<<std::endl;
55
56  os<<"miss_ln:"<<data._miss_ln<<std::endl;
57
58  os<<"rej_ln:"<<data._rej_ln<<std::endl;
59
60  os<<"large_gap:"<<data._large_gap<<std::endl;
61
62  os<<"bit_err_rate:"<<data._bit_err_rate<<std::endl;
63
64  os<<"fm_crc_err:"<<data._fm_crc_err<<std::endl;
65
66  os<<"date_incons:"<<data._date_incons<<std::endl;
67
68  os<<"prf_changes:"<<data._prf_changes<<std::endl;
69
70  os<<"delay_changes:"<<data._delay_changes<<std::endl;
71
72  os<<"skipd_frams:"<<data._skipd_frams<<std::endl;
73
74  os<<"rej_bf_start:"<<data._rej_bf_start<<std::endl;
75
76  os<<"rej_few_fram:"<<data._rej_few_fram<<std::endl;
77
78  os<<"rej_many_fram:"<<data._rej_many_fram<<std::endl;
79
80  os<<"rej_mchn_err:"<<data._rej_mchn_err<<std::endl;
81
82  os<<"rej_vchn_err:"<<data._rej_vchn_err<<std::endl;
83
84  os<<"rej_rec_type:"<<data._rej_rec_type<<std::endl;
85
86  os<<"sens_config:"<<data._sens_config.c_str()<<std::endl;
87
88  os<<"sens_orient:"<<data._sens_orient.c_str()<<std::endl;
89
90  os<<"sych_marker:"<<data._sych_marker.c_str()<<std::endl;
91
92  os<<"rng_ref_src:"<<data._rng_ref_src.c_str()<<std::endl;
93
94  for (int i=0;i<4;i++)
95  {
96  os<<"rng_amp_coef["<<i<<"]:"<<data._rng_amp_coef[i]<<std::endl;
97  }
98
99  for (int i=0;i<4;i++)
100  {
101  os<<"rng_phas_coef["<<i<<"]:"<<data._rng_phas_coef[i]<<std::endl;
102  }
103
104  for (int i=0;i<4;i++)
105  {
106  os<<"err_amp_coef["<<i<<"]:"<<data._err_amp_coef[i]<<std::endl;
107  }
108
109  for (int i=0;i<4;i++)
110  {
111  os<<"err_phas_coef["<<i<<"]:"<<data._err_phas_coef[i]<<std::endl;
112  }
113
114  os<<"pulse_bandw:"<<data._pulse_bandw<<std::endl;
115
116
117  os<<"adc_samp_rate:"<<data._adc_samp_rate.c_str()<<std::endl;
118
119  os<<"rep_agc_attn:"<<data._rep_agc_attn<<std::endl;
120
121  os<<"gn_corctn_fctr:"<<data._gn_corctn_fctr<<std::endl;
122
123  os<<"rep_energy_gn:"<<data._rep_energy_gn<<std::endl;
124
125  os<<"orb_data_src:"<<data._orb_data_src.c_str()<<std::endl;
126
127  os<<"pulse_cnt_1:"<<data._pulse_cnt_1<<std::endl;
128
129  os<<"pulse_cnt_2:"<<data._pulse_cnt_2<<std::endl;
130
131  os<<"beam_edge_rqd:"<<data._beam_edge_rqd.c_str()<<std::endl;
132
133  os<<"beam_edge_conf:"<<data._beam_edge_conf<<std::endl;
134
135  os<<"pix_overlap:"<<data._pix_overlap<<std::endl;
136
137  os<<"n_beams:"<<data._n_beams<<std::endl;
138
139  for (int i=0;i<4;i++)
140  {
141  os<<"beam_info["<<i<<"]:"<<data._beam_info[i]<<std::endl;
142  }
143
144  os<<"n_pix_updates:"<<data._n_pix_updates<<std::endl;
145
146  for (int i=0;i<4;i++)
147  {
148  os<<"pix_count["<<i<<"]:"<<data._pix_count[i]<<std::endl;
149  }
150
151  os<<"pwin_start:"<<data._pwin_start<<std::endl;
152
153  os<<"pwin_end:"<<data._pwin_end<<std::endl;
154
155  os<<"recd_type:"<<data._recd_type.c_str()<<std::endl;
156
157  os<<"temp_set_inc:"<<data._temp_set_inc<<std::endl;
158
159  os<<"n_temp_set:"<<data._n_temp_set<<std::endl;
160
161  for (int i=0;i<20;i++)
162  {
163  os<<"temp["<<i<<"]:"<<data._temp[i]<<std::endl;
164  }
165
166  os<<"n_image_pix:"<<data._n_image_pix<<std::endl;
167
168  os<<"prc_zero_pix:"<<data._prc_zero_pix<<std::endl;
169
170  os<<"prc_satur_pix:"<<data._prc_satur_pix<<std::endl;
171
172  os<<"img_hist_mean:"<<data._img_hist_mean<<std::endl;
173
174  for (int i=0;i<3;i++)
175  {
176  os<<"img_cumu_dist["<<i<<"]:"<<data._img_cumu_dist[i]<<std::endl;
177  }
178
179  os<<"pre_img_gn:"<<data._pre_img_gn<<std::endl;
180
181  os<<"post_img_gn:"<<data._post_img_gn<<std::endl;
182
183  os<<"dopcen_inc:"<<data._dopcen_inc<<std::endl;
184
185  os<<"n_dopcen:"<<data._n_dopcen<<std::endl;
186
187  for (int i=0;i<20;i++)
188  {
189  os<<"dopcen_est["<<i<<"]:"<<data._dopcen_est[i]<<std::endl;
190  }
191
192  os<<"dop_amb_err:"<<data._dop_amb_err<<std::endl;
193
194  os<<"dopamb_conf:"<<data._dopamb_conf<<std::endl;
195
196  for (int i=0;i<7;i++)
197  {
198  os<<"eph_orb_data["<<i<<"]:"<<data._eph_orb_data[i]<<std::endl;
199  }
200
201  os<<"appl_type:"<<data._appl_type.c_str()<<std::endl;
202
203  for (int i=0;i<5;i++)
204  {
205  os<<"slow_time_coef["<<i<<"]:"<<data._slow_time_coef[i]<<std::endl;
206  }
207
208  os<<"n_srgr:"<<data._n_srgr<<std::endl;
209
210  for (int i=0;i<20;i++)
211  {
212  os<<"srgr_coefset["<<i<<"]:"<<data._srgr_coefset[i]<<std::endl;
213  }
214
215  os<<"pixel_spacing:"<<data._pixel_spacing<<std::endl;
216
217  os<<"gics_reqd:"<<data._gics_reqd.c_str()<<std::endl;
218
219  os<<"wo_number:"<<data._wo_number.c_str()<<std::endl;
220
221  os<<"wo_date:"<<data._wo_date.c_str()<<std::endl;
222
223  os<<"satellite_id:"<<data._satellite_id.c_str()<<std::endl;
224
225  os<<"user_id:"<<data._user_id.c_str()<<std::endl;
226
227  os<<"complete_msg:"<<data._complete_msg.c_str()<<std::endl;
228
229  os<<"scene_id:"<<data._scene_id.c_str()<<std::endl;
230
231  os<<"density_in:"<<data._density_in.c_str()<<std::endl;
232
233  os<<"media_id:"<<data._media_id.c_str()<<std::endl;
234
235  os<<"angle_first:"<<data._angle_first<<std::endl;
236
237  os<<"angle_last:"<<data._angle_last<<std::endl;
238
239  os<<"prod_type:"<<data._prod_type.c_str()<<std::endl;
240
241  os<<"map_system:"<<data._map_system.c_str()<<std::endl;
242
243  os<<"centre_lat:"<<data._centre_lat<<std::endl;
244
245  os<<"centre_long:"<<data._centre_long<<std::endl;
246
247  os<<"span_x:"<<data._span_x<<std::endl;
248
249  os<<"span_y:"<<data._span_y<<std::endl;
250
251  os<<"apply_dtm:"<<data._apply_dtm.c_str()<<std::endl;
252
253  os<<"density_out:"<<data._density_out.c_str()<<std::endl;
254
255  os<<"state_time:"<<data._state_time.c_str()<<std::endl;
256
257  os<<"num_state_vectors:"<<data._num_state_vectors<<std::endl;
258
259  os<<"state_time_inc:"<<data._state_time_inc<<std::endl;
260
261  return os;
262  }
◆ operator<<() [21/63]
const RadiometricCompensationData data
Definition at line 24 of file RadiometricCompensationData.cpp.
References ossimplugins::RadiometricCompensationData::_chan_ind, ossimplugins::RadiometricCompensationData::_dset, ossimplugins::RadiometricCompensationData::_dset_size, ossimplugins::RadiometricCompensationData::_n_dset, and ossimplugins::RadiometricCompensationData::_seq_num.
25  {
27
28  os<<"chan_ind:"<<data._chan_ind<<std::endl;
29
30  os<<"n_dset:"<<data._n_dset<<std::endl;
31
32  os<<"dset_size:"<<data._dset_size<<std::endl;
33
34  for (int i=0;i<4;i++)
35  {
36  os<<"dset["<<i<<"]:"<<data._dset[i]<<std::endl;
37  }
38  return os;
39  }
◆ operator<<() [22/63]
const RadiometryUncertaintyRecord data
Definition at line 24 of file RadiometryUncertaintyRecord.cpp.
References ossimplugins::RadiometryUncertaintyRecord::_db, and ossimplugins::RadiometryUncertaintyRecord::_deg.
25 {
26  os<<"db:"<<data._db<<std::endl;
27  os<<"deg:"<<data._deg<<std::endl;
28  return os;
29 }
◆ operator<<() [23/63]
const SRGRCoefficientSetRecord data
Definition at line 24 of file SRGRCoefficientSetRecord.cpp.
References ossimplugins::SRGRCoefficientSetRecord::_srgr_coef, and ossimplugins::SRGRCoefficientSetRecord::_srgr_update.
25 {
26  os<<"srgr_update:"<<data._srgr_update.c_str()<<std::endl;
27  for (int i=0;i<6;i++)
28  {
29  os<<"srgr_coef["<<i<<"]:"<<data._srgr_coef[i]<<std::endl;
30  }
31
32  return os;
33 }
◆ operator<<() [24/63]
const TemperatureSettingsRecord data
Definition at line 24 of file TemperatureSettingsRecord.cpp.
References ossimplugins::TemperatureSettingsRecord::_temp_set.
25 {
26  for (int i=0;i<4;i++)
27  {
28  os<<"temp_set["<<i<<"]:"<<data._temp_set[i]<<std::endl;
29  }
30
31  return os;
32 }
◆ operator<<() [25/63]
const ProcessedDataRecord data
Definition at line 25 of file ProcessedDataRecord.cpp.
References ossimplugins::ProcessedDataRecord::_acq_day, ossimplugins::ProcessedDataRecord::_acq_msec, ossimplugins::ProcessedDataRecord::_acq_year, ossimplugins::ProcessedDataRecord::_east_first, ossimplugins::ProcessedDataRecord::_east_last, ossimplugins::ProcessedDataRecord::_fdc_first, ossimplugins::ProcessedDataRecord::_fdc_last, ossimplugins::ProcessedDataRecord::_fdc_mid, ossimplugins::ProcessedDataRecord::_geo_updf, ossimplugins::ProcessedDataRecord::_heading, ossimplugins::ProcessedDataRecord::_ka_first, ossimplugins::ProcessedDataRecord::_ka_last, ossimplugins::ProcessedDataRecord::_ka_mid, ossimplugins::ProcessedDataRecord::_lat_first, ossimplugins::ProcessedDataRecord::_lat_last, ossimplugins::ProcessedDataRecord::_lat_mid, ossimplugins::ProcessedDataRecord::_line_num, ossimplugins::ProcessedDataRecord::_lon_first, ossimplugins::ProcessedDataRecord::_lon_last, ossimplugins::ProcessedDataRecord::_lon_mid, ossimplugins::ProcessedDataRecord::_n_data_pixel, ossimplugins::ProcessedDataRecord::_n_left_pixel, ossimplugins::ProcessedDataRecord::_n_right_pixel, ossimplugins::ProcessedDataRecord::_nadir_ang, ossimplugins::ProcessedDataRecord::_north_first, ossimplugins::ProcessedDataRecord::_north_last, ossimplugins::ProcessedDataRecord::_prf, ossimplugins::ProcessedDataRecord::_rec_num, ossimplugins::ProcessedDataRecord::_recv_polar, ossimplugins::ProcessedDataRecord::_sar_chan_code, ossimplugins::ProcessedDataRecord::_sar_chan_ind, ossimplugins::ProcessedDataRecord::_sensor_updf, ossimplugins::ProcessedDataRecord::_squint_ang, ossimplugins::ProcessedDataRecord::_sr_first, ossimplugins::ProcessedDataRecord::_sr_last, and ossimplugins::ProcessedDataRecord::_tran_polar.
26  {
27  os<<"line_num:"<<data._line_num<<std::endl;
28  os<<"rec_num:"<<data._rec_num<<std::endl;
29  os<<"n_left_pixel:"<<data._n_left_pixel<<std::endl;
30  os<<"n_data_pixel:"<<data._n_data_pixel<<std::endl;
31  os<<"n_right_pixel:"<<data._n_right_pixel<<std::endl;
32  os<<"sensor_updf:"<<data._sensor_updf<<std::endl;
33  os<<"acq_year:"<<data._acq_year<<std::endl;
34  os<<"acq_day:"<<data._acq_day<<std::endl;
35  os<<"acq_msec:"<<data._acq_msec<<std::endl;
36  os<<"sar_chan_ind:"<<data._sar_chan_ind<<std::endl;
37  os<<"sar_chan_code:"<<data._sar_chan_code<<std::endl;
38  os<<"tran_polar:"<<data._tran_polar<<std::endl;
39  os<<"recv_polar:"<<data._recv_polar<<std::endl;
40  os<<"prf:"<<data._prf<<std::endl;
41  os<<"sr_first:"<<data._sr_first<<std::endl;
42  os<<"sr_last:"<<data._sr_last<<std::endl;
43  os<<"fdc_first:"<<data._fdc_first<<std::endl;
44  os<<"fdc_mid:"<<data._fdc_mid<<std::endl;
45  os<<"fdc_last:"<<data._fdc_last<<std::endl;
46  os<<"ka_first:"<<data._ka_first<<std::endl;
47  os<<"ka_mid:"<<data._ka_mid<<std::endl;
48  os<<"ka_last:"<<data._ka_last<<std::endl;
49  os<<"nadir_ang:"<<data._nadir_ang<<std::endl;
50  os<<"squint_ang:"<<data._squint_ang<<std::endl;
51  os<<"geo_updf:"<<data._geo_updf<<std::endl;
52  os<<"lat_first:"<<data._lat_first<<std::endl;
53  os<<"lat_mid:"<<data._lat_mid<<std::endl;
54  os<<"lat_last:"<<data._lat_last<<std::endl;
55  os<<"lon_first:"<<data._lon_first<<std::endl;
56  os<<"lon_mid:"<<data._lon_mid<<std::endl;
57  os<<"lon_last:"<<data._lon_last<<std::endl;
58  os<<"north_first:"<<data._north_first<<std::endl;
59  os<<"north_last:"<<data._north_last<<std::endl;
60  os<<"east_first:"<<data._east_first<<std::endl;
61  os<<"east_last:"<<data._east_last<<std::endl;
62  os<<"heading:"<<data._heading<<std::endl;
63
64  return os;
65  }
◆ operator<<() [26/63]
const MainProcessingParameters data
Definition at line 25 of file MainProcessingParameters.cpp.
References ossimplugins::MainProcessingParameters::_ant_elev_coor_flag, ossimplugins::MainProcessingParameters::_ant_scal_flag, ossimplugins::MainProcessingParameters::_attach_flag, ossimplugins::MainProcessingParameters::_avg_scene_height_ellpsoid, ossimplugins::MainProcessingParameters::_ax_fm_origin, ossimplugins::MainProcessingParameters::_az_fm_rate, ossimplugins::MainProcessingParameters::_azimut_spacing, ossimplugins::MainProcessingParameters::_bandwidth, ossimplugins::MainProcessingParameters::_beam_overlap, ossimplugins::MainProcessingParameters::_calibration_factors, ossimplugins::MainProcessingParameters::_chirp_extract_flag, ossimplugins::MainProcessingParameters::_data_analysis_flag, ossimplugins::MainProcessingParameters::_data_type, ossimplugins::MainProcessingParameters::_detected_flag, ossimplugins::MainProcessingParameters::_dop_amb_coef, ossimplugins::MainProcessingParameters::_dop_amb_flag, ossimplugins::MainProcessingParameters::_dop_cen_flag, ossimplugins::MainProcessingParameters::_echo_comp, ossimplugins::MainProcessingParameters::_echo_comp_ratio, ossimplugins::MainProcessingParameters::_errors_counters, ossimplugins::MainProcessingParameters::_filter_az, ossimplugins::MainProcessingParameters::_filter_coef_az, ossimplugins::MainProcessingParameters::_filter_coef_range, ossimplugins::MainProcessingParameters::_filter_range, ossimplugins::MainProcessingParameters::_first_proc_range_samp, ossimplugins::MainProcessingParameters::_first_zero_doppler_time, ossimplugins::MainProcessingParameters::_gm_rng_comp_inv_filter_flag, ossimplugins::MainProcessingParameters::_image_parameters1, ossimplugins::MainProcessingParameters::_image_parameters2, ossimplugins::MainProcessingParameters::_init_cal_comp, ossimplugins::MainProcessingParameters::_init_cal_ratio, ossimplugins::MainProcessingParameters::_last_zero_doppler_time, ossimplugins::MainProcessingParameters::_line_time_interval, ossimplugins::MainProcessingParameters::_lines_per_burst, ossimplugins::MainProcessingParameters::_look_bw_az, ossimplugins::MainProcessingParameters::_look_sum_flag, ossimplugins::MainProcessingParameters::_noise_comp, ossimplugins::MainProcessingParameters::_noise_comp_ratio, ossimplugins::MainProcessingParameters::_noise_estimation, ossimplugins::MainProcessingParameters::_nominal_chirp, ossimplugins::MainProcessingParameters::_num_lines_proc, ossimplugins::MainProcessingParameters::_num_look_az, ossimplugins::MainProcessingParameters::_num_looks_range, ossimplugins::MainProcessingParameters::_num_output_lines, ossimplugins::MainProcessingParameters::_num_range_lines_per_burst, ossimplugins::MainProcessingParameters::_num_samples_per_line, ossimplugins::MainProcessingParameters::_output_statistics, ossimplugins::MainProcessingParameters::_parameter_code, ossimplugins::MainProcessingParameters::_per_cal_comp, ossimplugins::MainProcessingParameters::_per_cal_ratio, ossimplugins::MainProcessingParameters::_prf_values, ossimplugins::MainProcessingParameters::_radar_freq, ossimplugins::MainProcessingParameters::_range_ref, ossimplugins::MainProcessingParameters::_range_samp_rate, ossimplugins::MainProcessingParameters::_range_spacing, ossimplugins::MainProcessingParameters::_range_spread_comp_flag, ossimplugins::MainProcessingParameters::_raw_data_analysis, ossimplugins::MainProcessingParameters::_rms_equal_flag, ossimplugins::MainProcessingParameters::_srgr_flag, ossimplugins::MainProcessingParameters::_start_time_mds1, ossimplugins::MainProcessingParameters::_start_time_mds2, ossimplugins::MainProcessingParameters::_state_vector_time_1_day, ossimplugins::MainProcessingParameters::_state_vector_time_1_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_1_sec, ossimplugins::MainProcessingParameters::_state_vector_time_2_day, ossimplugins::MainProcessingParameters::_state_vector_time_2_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_2_sec, ossimplugins::MainProcessingParameters::_state_vector_time_3_day, ossimplugins::MainProcessingParameters::_state_vector_time_3_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_3_sec, ossimplugins::MainProcessingParameters::_state_vector_time_4_day, ossimplugins::MainProcessingParameters::_state_vector_time_4_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_4_sec, ossimplugins::MainProcessingParameters::_state_vector_time_5_day, ossimplugins::MainProcessingParameters::_state_vector_time_5_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_5_sec, ossimplugins::MainProcessingParameters::_swath_num, ossimplugins::MainProcessingParameters::_time_diff, ossimplugins::MainProcessingParameters::_time_diff_zero_doppler, ossimplugins::MainProcessingParameters::_time_first_SS1_echo, ossimplugins::MainProcessingParameters::_to_bw_az, ossimplugins::MainProcessingParameters::_vga_com_cal_flag, ossimplugins::MainProcessingParameters::_vga_com_echo_flag, ossimplugins::MainProcessingParameters::_vga_com_nom_time_flag, ossimplugins::MainProcessingParameters::_work_order_id, ossimplugins::MainProcessingParameters::_x_pos_1, ossimplugins::MainProcessingParameters::_x_pos_2, ossimplugins::MainProcessingParameters::_x_pos_3, ossimplugins::MainProcessingParameters::_x_pos_4, ossimplugins::MainProcessingParameters::_x_pos_5, ossimplugins::MainProcessingParameters::_x_vel_1, ossimplugins::MainProcessingParameters::_x_vel_2, ossimplugins::MainProcessingParameters::_x_vel_3, ossimplugins::MainProcessingParameters::_x_vel_4, ossimplugins::MainProcessingParameters::_x_vel_5, ossimplugins::MainProcessingParameters::_y_pos_1, ossimplugins::MainProcessingParameters::_y_pos_2, ossimplugins::MainProcessingParameters::_y_pos_3, ossimplugins::MainProcessingParameters::_y_pos_4, ossimplugins::MainProcessingParameters::_y_pos_5, ossimplugins::MainProcessingParameters::_y_vel_1, ossimplugins::MainProcessingParameters::_y_vel_2, ossimplugins::MainProcessingParameters::_y_vel_3, ossimplugins::MainProcessingParameters::_y_vel_4, ossimplugins::MainProcessingParameters::_y_vel_5, ossimplugins::MainProcessingParameters::_z_pos_1, ossimplugins::MainProcessingParameters::_z_pos_2, ossimplugins::MainProcessingParameters::_z_pos_3, ossimplugins::MainProcessingParameters::_z_pos_4, ossimplugins::MainProcessingParameters::_z_pos_5, ossimplugins::MainProcessingParameters::_z_vel_1, ossimplugins::MainProcessingParameters::_z_vel_2, ossimplugins::MainProcessingParameters::_z_vel_3, ossimplugins::MainProcessingParameters::_z_vel_4, and ossimplugins::MainProcessingParameters::_z_vel_5.
26  {
27  os<<"first_zero_doppler_time:"<<data._first_zero_doppler_time.c_str()<<std::endl;
28
29  os<<"attach_flag:"<<data._attach_flag<<std::endl;
30
31  os<<"last_zero_doppler_time:"<<data._last_zero_doppler_time.c_str()<<std::endl;
32
33  os<<"work_order_id:"<<data._work_order_id.c_str()<<std::endl;
34
35  os<<"time_diff:"<<data._time_diff<<std::endl;
36
37  os<<"swath_num:"<<data._swath_num.c_str()<<std::endl;
38
39  os<<"range_spacing:"<<data._range_spacing<<std::endl;
40
41  os<<"azimut_spacing:"<<data._azimut_spacing<<std::endl;
42
43  os<<"line_time_interval:"<<data._line_time_interval<<std::endl;
44
45  os<<"num_output_lines:"<<data._num_output_lines<<std::endl;
46
47  os<<"num_samples_per_line:"<<data._num_samples_per_line<<std::endl;
48
49  os<<"data_type:"<<data._data_type.c_str()<<std::endl;
50
51  os<<"num_range_lines_per_burst:"<<data._num_range_lines_per_burst<<std::endl;
52
53  os<<"time_diff_zero_doppler:"<<data._time_diff_zero_doppler<<std::endl;
54
55  os<<"data_analysis_flag:"<<data._data_analysis_flag<<std::endl;
56
57  os<<"ant_elev_coor_flag:"<<data._ant_elev_coor_flag<<std::endl;
58
59  os<<"chirp_extract_flag:"<<data._chirp_extract_flag<<std::endl;
60
61  os<<"srgr_flag:"<<data._srgr_flag<<std::endl;
62
63  os<<"dop_cen_flag:"<<data._dop_cen_flag<<std::endl;
64
65  os<<"dop_amb_flag:"<<data._dop_amb_flag<<std::endl;
66
67  os<<"range_spread_comp_flag:"<<data._range_spread_comp_flag<<std::endl;
68
69  os<<"detected_flag:"<<data._detected_flag<<std::endl;
70
71  os<<"look_sum_flag:"<<data._look_sum_flag<<std::endl;
72
73  os<<"rms_equal_flag:"<<data._rms_equal_flag<<std::endl;
74
75  os<<"ant_scal_flag:"<<data._ant_scal_flag<<std::endl;
76
77  os<<"vga_com_echo_flag:"<<data._vga_com_echo_flag<<std::endl;
78
79  os<<"vga_com_cal_flag:"<<data._vga_com_cal_flag<<std::endl;
80
81  os<<"vga_com_nom_time_flag:"<<data._vga_com_nom_time_flag<<std::endl;
82
83  os<<"gm_rng_comp_inv_filter_flag:"<<data._gm_rng_comp_inv_filter_flag<<std::endl;
84
85  os<<"raw_data_analysis:"<<data._raw_data_analysis.c_str()<<std::endl;
86
87  os<<"start_time_mds1:"<<data._start_time_mds1.c_str()<<std::endl;
88
89  os<<"start_time_mds2:"<<data._start_time_mds2.c_str()<<std::endl;
90
91  os<<"parameter_code:"<<data._parameter_code.c_str()<<std::endl;
92
93  os<<"errors_counters:"<<data._errors_counters.c_str()<<std::endl;
94
95  os<<"image_parameters 1:"<<data._image_parameters1.c_str()<<std::endl;
96
97  os<<"prf_values[0]:"<<data._prf_values[0]<<std::endl;
98
99  os<<"image_parameters 1:"<<data._image_parameters2.c_str()<<std::endl;
100
101  os<<"first_proc_range_samp:"<<data._first_proc_range_samp<<std::endl;
102
103  os<<"range_ref:"<<data._range_ref<<std::endl;
104
105  os<<"range_samp_rate:"<<data._range_samp_rate<<std::endl;
106
107  os<<"radar_freq:"<<data._radar_freq<<std::endl;
108
109  os<<"num_looks_range:"<<data._num_looks_range<<std::endl;
110
111  os<<"filter_range:"<<data._filter_range.c_str()<<std::endl;
112
113  os<<"filter_coef_range:"<<data._filter_coef_range<<std::endl;
114
115  os<<"bandwidth:"<<data._bandwidth.c_str()<<std::endl;
116
117  os<<"nominal_chirp:"<<data._nominal_chirp.c_str()<<std::endl;
118
119  os<<"num_lines_proc:"<<data._num_lines_proc<<std::endl;
120
121  os<<"num_look_az:"<<data._num_look_az<<std::endl;
122
123  os<<"look_bw_az:"<<data._look_bw_az<<std::endl;
124
125  os<<"to_bw_az:"<<data._to_bw_az<<std::endl;
126
127  os<<"filter_az:"<<data._filter_az.c_str()<<std::endl;
128
129  os<<"filter_coef_az:"<<data._filter_coef_az<<std::endl;
130
131  os<<"az_fm_rate[0]:"<<data._az_fm_rate[0]<<std::endl;
132  os<<"az_fm_rate[1]:"<<data._az_fm_rate[1]<<std::endl;
133  os<<"az_fm_rate[2]:"<<data._az_fm_rate[2]<<std::endl;
134
135  os<<"ax_fm_origin:"<<data._ax_fm_origin<<std::endl;
136
137  os<<"dop_amb_coef:"<<data._dop_amb_coef<<std::endl;
138
139  os<<"calibration_factors:"<<data._calibration_factors.c_str()<<std::endl;
140
141  os<<"noise_estimation:"<<data._noise_estimation.c_str()<<std::endl;
142
143  os<<"output_statistics:"<<data._output_statistics.c_str()<<std::endl;
144
145  os<<"avg_scene_height_ellpsoid:"<<data._avg_scene_height_ellpsoid<<std::endl;
146
147  os<<"echo_comp:"<<data._echo_comp.c_str()<<std::endl;
148
149  os<<"echo_comp_ratio:"<<data._echo_comp_ratio.c_str()<<std::endl;
150
151  os<<"init_cal_comp:"<<data._init_cal_comp.c_str()<<std::endl;
152
153  os<<"init_cal_ratio:"<<data._init_cal_ratio.c_str()<<std::endl;
154
155  os<<"per_cal_comp:"<<data._per_cal_comp.c_str()<<std::endl;
156
157  os<<"per_cal_ratio:"<<data._per_cal_ratio.c_str()<<std::endl;
158
159  os<<"noise_comp:"<<data._noise_comp.c_str()<<std::endl;
160
161  os<<"noise_comp_ratio:"<<data._noise_comp_ratio.c_str()<<std::endl;
162
163  os<<"beam_overlap[0]:"<<data._beam_overlap[0]<<std::endl;
164  os<<"beam_overlap[1]:"<<data._beam_overlap[1]<<std::endl;
165  os<<"beam_overlap[2]:"<<data._beam_overlap[2]<<std::endl;
166  os<<"beam_overlap[3]:"<<data._beam_overlap[3]<<std::endl;
167
168  os<<"lines_per_burst[0]:"<<data._lines_per_burst[0]<<std::endl;
169  os<<"lines_per_burst[1]:"<<data._lines_per_burst[1]<<std::endl;
170  os<<"lines_per_burst[2]:"<<data._lines_per_burst[2]<<std::endl;
171  os<<"lines_per_burst[3]:"<<data._lines_per_burst[3]<<std::endl;
172  os<<"lines_per_burst[4]:"<<data._lines_per_burst[4]<<std::endl;
173
174  os<<"time_first_SS1_echo:"<<data._time_first_SS1_echo.c_str()<<std::endl;
175
176  os<<"state_vector_time_1:"<<data._state_vector_time_1_day<<std::endl;
177
178  os<<"state_vector_time_1:"<<data._state_vector_time_1_sec<<std::endl;
179
180  os<<"state_vector_time_1:"<<data._state_vector_time_1_microsec<<std::endl;
181
182  os<<"x_pos_1:"<<data._x_pos_1<<std::endl;
183
184  os<<"y_pos_1:"<<data._y_pos_1<<std::endl;
185
186  os<<"z_pos_1:"<<data._z_pos_1<<std::endl;
187
188  os<<"x_vel_1:"<<data._x_vel_1<<std::endl;
189
190  os<<"y_vel_1:"<<data._y_vel_1<<std::endl;
191
192  os<<"z_vel_1:"<<data._z_vel_1<<std::endl;
193
194  os<<"state_vector_time_2:"<<data._state_vector_time_2_day<<std::endl;
195
196  os<<"state_vector_time_2:"<<data._state_vector_time_2_sec<<std::endl;
197
198  os<<"state_vector_time_2:"<<data._state_vector_time_2_microsec<<std::endl;
199
200  os<<"x_pos_2:"<<data._x_pos_2<<std::endl;
201
202  os<<"y_pos_2:"<<data._y_pos_2<<std::endl;
203
204  os<<"z_pos_2:"<<data._z_pos_2<<std::endl;
205
206  os<<"x_vel_2:"<<data._x_vel_2<<std::endl;
207
208  os<<"y_vel_2:"<<data._y_vel_2<<std::endl;
209
210  os<<"z_vel_2:"<<data._z_vel_2<<std::endl;
211
212  os<<"state_vector_time_3:"<<data._state_vector_time_3_day<<std::endl;
213
214  os<<"state_vector_time_3:"<<data._state_vector_time_3_sec<<std::endl;
215
216  os<<"state_vector_time_3:"<<data._state_vector_time_3_microsec<<std::endl;
217
218  os<<"x_pos_3:"<<data._x_pos_3<<std::endl;
219
220  os<<"y_pos_3:"<<data._y_pos_3<<std::endl;
221
222  os<<"z_pos_3:"<<data._z_pos_3<<std::endl;
223
224  os<<"x_vel_3:"<<data._x_vel_3<<std::endl;
225
226  os<<"y_vel_3:"<<data._y_vel_3<<std::endl;
227
228  os<<"z_vel_3:"<<data._z_vel_3<<std::endl;
229
230  os<<"state_vector_time_4:"<<data._state_vector_time_4_day<<std::endl;
231
232  os<<"state_vector_time_4:"<<data._state_vector_time_4_sec<<std::endl;
233
234  os<<"state_vector_time_4:"<<data._state_vector_time_4_microsec<<std::endl;
235
236  os<<"x_pos_4:"<<data._x_pos_4<<std::endl;
237
238  os<<"y_pos_4:"<<data._y_pos_4<<std::endl;
239
240  os<<"z_pos_4:"<<data._z_pos_4<<std::endl;
241
242  os<<"x_vel_4:"<<data._x_vel_4<<std::endl;
243
244  os<<"y_vel_4:"<<data._y_vel_4<<std::endl;
245
246  os<<"z_vel_4:"<<data._z_vel_4<<std::endl;
247
248  os<<"state_vector_time_5:"<<data._state_vector_time_5_day<<std::endl;
249
250  os<<"state_vector_time_5:"<<data._state_vector_time_5_sec<<std::endl;
251
252  os<<"state_vector_time_5:"<<data._state_vector_time_5_microsec<<std::endl;
253
254  os<<"x_pos_5:"<<data._x_pos_5<<std::endl;
255
256  os<<"y_pos_5:"<<data._y_pos_5<<std::endl;
257
258  os<<"z_pos_5:"<<data._z_pos_5<<std::endl;
259
260  os<<"x_vel_5:"<<data._x_vel_5<<std::endl;
261
262  os<<"y_vel_5:"<<data._y_vel_5<<std::endl;
263
264  os<<"z_vel_5:"<<data._z_vel_5<<std::endl;
265
266  return os;
267
268  }
◆ operator<<() [27/63]
std::ostream& ossimplugins::operator<< ( std::ostream &  os,
const GeolocationGrid data
Definition at line 25 of file GeolocationGrid.cpp.
References ossimplugins::GeolocationGrid::_angles, ossimplugins::GeolocationGrid::_attach_flag, ossimplugins::GeolocationGrid::_first_zero_doppler_time_day, ossimplugins::GeolocationGrid::_first_zero_doppler_time_microsec, ossimplugins::GeolocationGrid::_first_zero_doppler_time_sec, ossimplugins::GeolocationGrid::_last_line_tie_points, ossimplugins::GeolocationGrid::_last_zero_doppler_time, ossimplugins::GeolocationGrid::_lats, ossimplugins::GeolocationGrid::_line_num, ossimplugins::GeolocationGrid::_longs, ossimplugins::GeolocationGrid::_num_lines, ossimplugins::GeolocationGrid::_samp_numbers, ossimplugins::GeolocationGrid::_slant_range_times, and ossimplugins::GeolocationGrid::_sub_sat_track.
26  {
27  os<<"first_zero_doppler_time_day:"<<data._first_zero_doppler_time_day<<std::endl;
28
29  os<<"first_zero_doppler_time_sec:"<<data._first_zero_doppler_time_sec<<std::endl;
30
31  os<<"first_zero_doppler_time_microsec:"<<data._first_zero_doppler_time_microsec<<std::endl;
32
33  os<<"attach_flag:"<<data._attach_flag<<std::endl;
34
35  os<<"line_num:"<<data._line_num<<std::endl;
36
37  os<<"num_lines:"<<data._num_lines<<std::endl;
38
39  os<<"sub_sat_track:"<<data._sub_sat_track<<std::endl;
40
41  for (int i = 0; i<11; i++) {
42  os<<"samp_numbers["<<i<<"]:"<<data._samp_numbers[i]<<std::endl;
43  }
44
45  for (int i = 0; i<11; i++) {
46  os<<"slant_range_times["<<i<<"]:"<<data._slant_range_times[i]<<std::endl;
47  }
48
49  for (int i = 0; i<11; i++) {
50  os<<"angles["<<i<<"]:"<<data._angles[i]<<std::endl;
51  }
52
53  for (int i = 0; i<11; i++) {
54  os<<"lats["<<i<<"]:"<<data._lats[i]<<std::endl;
55  }
56
57  for (int i = 0; i<11; i++) {
58  os<<"longs["<<i<<"]:"<<data._longs[i]<<std::endl;
59  }
60
61  os<<"last_zero_doppler_time:"<<data._last_zero_doppler_time.c_str()<<std::endl;
62
63  os<<"last_line_tie_points:"<<data._last_line_tie_points.c_str()<<std::endl;
64
65  return os;
66
67  }
◆ operator<<() [28/63]
const ErsSarDataSetSummary data
Definition at line 25 of file ErsSarDataSetSummary.cpp.
References ossimplugins::ErsSarDataSetSummary::_algor_id, ossimplugins::ErsSarDataSetSummary::_alt_dopcen, ossimplugins::ErsSarDataSetSummary::_alt_rate, ossimplugins::ErsSarDataSetSummary::_ampl_coef, ossimplugins::ErsSarDataSetSummary::_asc_des, ossimplugins::ErsSarDataSetSummary::_auto_focus, ossimplugins::ErsSarDataSetSummary::_azi_res, ossimplugins::ErsSarDataSetSummary::_azi_weight, ossimplugins::ErsSarDataSetSummary::_baseband_f, ossimplugins::ErsSarDataSetSummary::_bnd_azi, ossimplugins::ErsSarDataSetSummary::_bnd_azilok, ossimplugins::ErsSarDataSetSummary::_bnd_rng, ossimplugins::ErsSarDataSetSummary::_bnd_rnglok, ossimplugins::ErsSarDataSetSummary::_chirp_ext_ind, ossimplugins::ErsSarDataSetSummary::_chn_bits, ossimplugins::ErsSarDataSetSummary::_clock_ang, ossimplugins::ErsSarDataSetSummary::_clutter_lock, ossimplugins::ErsSarDataSetSummary::_crt_dopcen, ossimplugins::ErsSarDataSetSummary::_crt_rate, ossimplugins::ErsSarDataSetSummary::_data_inpsrc, ossimplugins::ErsSarDataSetSummary::_earth_mass, ossimplugins::ErsSarDataSetSummary::_ellip_des, ossimplugins::ErsSarDataSetSummary::_ellip_j, ossimplugins::ErsSarDataSetSummary::_ellip_maj, ossimplugins::ErsSarDataSetSummary::_ellip_min, ossimplugins::ErsSarDataSetSummary::_fa, ossimplugins::ErsSarDataSetSummary::_fac_id, ossimplugins::ErsSarDataSetSummary::_fr, ossimplugins::ErsSarDataSetSummary::_gn_cross, ossimplugins::ErsSarDataSetSummary::_gn_polar, ossimplugins::ErsSarDataSetSummary::_grav_const, ossimplugins::ErsSarDataSetSummary::_i_bias, ossimplugins::ErsSarDataSetSummary::_incident_ang, ossimplugins::ErsSarDataSetSummary::_inp_sctim, ossimplugins::ErsSarDataSetSummary::_iq_ratio, ossimplugins::ErsSarDataSetSummary::_line_cont, ossimplugins::ErsSarDataSetSummary::_line_spacing, ossimplugins::ErsSarDataSetSummary::_mech_sight, ossimplugins::ErsSarDataSetSummary::_mission_id, ossimplugins::ErsSarDataSetSummary::_motion_comp, ossimplugins::ErsSarDataSetSummary::_n_azilok, ossimplugins::ErsSarDataSetSummary::_n_rnglok, ossimplugins::ErsSarDataSetSummary::_nchn, ossimplugins::ErsSarDataSetSummary::_orbit_num, ossimplugins::ErsSarDataSetSummary::_phas_coef, ossimplugins::ErsSarDataSetSummary::_pix_spacing, ossimplugins::ErsSarDataSetSummary::_plat_head, ossimplugins::ErsSarDataSetSummary::_plat_lat, ossimplugins::ErsSarDataSetSummary::_plat_long, ossimplugins::ErsSarDataSetSummary::_pro_head, ossimplugins::ErsSarDataSetSummary::_pro_lat, ossimplugins::ErsSarDataSetSummary::_pro_long, ossimplugins::ErsSarDataSetSummary::_prod_type, ossimplugins::ErsSarDataSetSummary::_pulse_code, ossimplugins::ErsSarDataSetSummary::_q_bias, ossimplugins::ErsSarDataSetSummary::_quant_desc, ossimplugins::ErsSarDataSetSummary::_rng_gate, ossimplugins::ErsSarDataSetSummary::_rng_length, ossimplugins::ErsSarDataSetSummary::_rng_res, ossimplugins::ErsSarDataSetSummary::_rng_weight, ossimplugins::ErsSarDataSetSummary::_rngcmp_desg, ossimplugins::ErsSarDataSetSummary::_rngcmp_f, ossimplugins::ErsSarDataSetSummary::_sar_chn, ossimplugins::ErsSarDataSetSummary::_sat_bintim, ossimplugins::ErsSarDataSetSummary::_sat_clkinc, ossimplugins::ErsSarDataSetSummary::_sat_clktim, ossimplugins::ErsSarDataSetSummary::_sc_lin, ossimplugins::ErsSarDataSetSummary::_sc_pix, ossimplugins::ErsSarDataSetSummary::_scene_des, ossimplugins::ErsSarDataSetSummary::_scene_id, ossimplugins::ErsSarDataSetSummary::_scene_len, ossimplugins::ErsSarDataSetSummary::_scene_wid, ossimplugins::ErsSarDataSetSummary::_sensor_id, ossimplugins::ErsSarDataSetSummary::_seq_num, ossimplugins::ErsSarDataSetSummary::_sys_id, ossimplugins::ErsSarDataSetSummary::_terrain_h, ossimplugins::ErsSarDataSetSummary::_time_dir_lin, ossimplugins::ErsSarDataSetSummary::_time_dir_pix, ossimplugins::ErsSarDataSetSummary::_ver_id, ossimplugins::ErsSarDataSetSummary::_wave_length, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_c_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_f_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_l_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_c_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_f_pixel, and ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_l_pixel.
26 {
27  os << "seq_num:" << data._seq_num << std::endl;
28
29  os << "sar_chn:" << data._sar_chn << std::endl;
30
31  os << "scene_id:" << data._scene_id.c_str() << std::endl;
32
33  os << "scene_des:" << data._scene_des.c_str() << std::endl;
34
35  os << "inp_sctim:" << data._inp_sctim.c_str() << std::endl;
36
37  os << "asc_des:" << data._asc_des.c_str() << std::endl;
38
39  os << "pro_lat:" << data._pro_lat << std::endl;
40
41  os << "pro_long:" << data._pro_long << std::endl;
42
43  os << "pro_head:" << data._pro_head << std::endl;
44
45  os << "ellip_des:" << data._ellip_des.c_str() << std::endl;
46
47  os << "ellip_maj:" << data._ellip_maj << std::endl;
48
49  os << "ellip_min:" << data._ellip_min << std::endl;
50  os << "earth_mass:" << data._earth_mass << std::endl;
51  os << "grav_const:" << data._grav_const << std::endl;
52  os << "ellip_j[0]:" << data._ellip_j[0] << std::endl;
53  os << "ellip_j[1]:" << data._ellip_j[1] << std::endl;
54  os << "ellip_j[2]:" << data._ellip_j[2] << std::endl;
55  os << "terrain_h:" << data._terrain_h << std::endl;
56  os << "sc_lin:" << data._sc_lin << std::endl;
57  os << "sc_pix:" << data._sc_pix << std::endl;
58  os << "scene_len:" << data._scene_len << std::endl;
59  os << "scene_wid:" << data._scene_wid << std::endl;
60  os << "nchn:" << data._nchn << std::endl;
61  os << "mission_id:" << data._mission_id.c_str() << std::endl;
62  os << "sensor_id:" << data._sensor_id.c_str() << std::endl;
63  os << "orbit_num:" << data._orbit_num.c_str() << std::endl;
64
65  os << "plat_lat:" << data._plat_lat << std::endl;
66
67  os << "plat_long:" << data._plat_long << std::endl;
68
69  os << "plat_head:" << data._plat_head << std::endl;
70
71  os << "clock_ang:" << data._clock_ang << std::endl;
72
73  os << "incident_ang:" << data._incident_ang << std::endl;
74
75
76  os << "wave_length:" << data._wave_length << std::endl;
77
78  os << "motion_comp:" << data._motion_comp.c_str() << std::endl;
79
80  os << "pulse_code:" << data._pulse_code.c_str() << std::endl;
81
82  for (int i = 0; i < 5; i++)
83  {
84  os << "ampl_coef[" << i << "]:" << data._ampl_coef[i] << std::endl;
85  }
86
87  for (int i = 0; i < 5; i++)
88  {
89  os << "phas_coef[" << i << "]:" << data._phas_coef[i] << std::endl;
90  }
91
92  os << "chirp_ext_ind:" << data._chirp_ext_ind << std::endl;
93
94  os << "fr:" << data._fr << std::endl;
95
96  os << "rng_gate:" << data._rng_gate << std::endl;
97
98  os << "rng_length:" << data._rng_length << std::endl;
99
100  os << "baseband_f:" << data._baseband_f.c_str() << std::endl;
101
102  os << "rngcmp_f:" << data._rngcmp_f.c_str() << std::endl;
103
104  os << "gn_polar:" << data._gn_polar << std::endl;
105
106  os << "gn_cross:" << data._gn_cross << std::endl;
107
108  os << "chn_bits:" << data._chn_bits << std::endl;
109
110  os << "quant_desc:" << data._quant_desc.c_str() << std::endl;
111
112  os << "i_bias:" << data._i_bias << std::endl;
113
114  os << "q_bias:" << data._q_bias << std::endl;
115
116  os << "iq_ratio:" << data._iq_ratio << std::endl;
117
118  os << "mech_sight:" << data._mech_sight << std::endl;
119
120  os << "fa:" << data._fa << std::endl;
121
122  os << "sat_bintim:" << data._sat_bintim.c_str() << std::endl;
123
124  os << "sat_clktim:" << data._sat_clktim.c_str() << std::endl;
125
126  os << "sat_clkinc:" << data._sat_clkinc.c_str() << std::endl;
127
128  os << "fac_id:" << data._fac_id.c_str() << std::endl;
129
130  os << "sys_id:" << data._sys_id.c_str() << std::endl;
131
132  os << "ver_id:" << data._ver_id.c_str() << std::endl;
133
134  os << "prod_type:" << data._prod_type.c_str() << std::endl;
135
136  os << "algor_id:" << data._algor_id.c_str() << std::endl;
137
138  os << "n_azilok:" << data._n_azilok << std::endl;
139
140  os << "n_rnglok:" << data._n_rnglok << std::endl;
141
142  os << "bnd_azilok:" << data._bnd_azilok << std::endl;
143
144  os << "bnd_rnglok:" << data._bnd_rnglok << std::endl;
145
146  os << "bnd_azi:" << data._bnd_azi << std::endl;
147
148  os << "bnd_rng:" << data._bnd_rng << std::endl;
149
150  os << "azi_weight:" << data._azi_weight.c_str() << std::endl;
151
152  os << "rng_weight:" << data._rng_weight.c_str() << std::endl;
153
154  os << "data_inpsrc:" << data._data_inpsrc.c_str() << std::endl;
155
156  os << "rng_res:" << data._rng_res << std::endl;
157
158  os << "azi_res:" << data._azi_res << std::endl;
159
160  os << "alt_dopcen[0]:" << data._alt_dopcen[0] << std::endl;
161  os << "alt_dopcen[1]:" << data._alt_dopcen[1] << std::endl;
162  os << "alt_dopcen[2]:" << data._alt_dopcen[2] << std::endl;
163
164  os << "crt_dopcen[0]:" << data._crt_dopcen[0] << std::endl;
165  os << "crt_dopcen[1]:" << data._crt_dopcen[1] << std::endl;
166  os << "crt_dopcen[2]:" << data._crt_dopcen[2] << std::endl;
167
168  os << "time_dir_pix:" << data._time_dir_pix.c_str() << std::endl;
169
170  os << "time_dir_lin:" << data._time_dir_lin.c_str() << std::endl;
171
172  os << "alt_rate[0]:" << data._alt_rate[0] << std::endl;
173  os << "alt_rate[1]:" << data._alt_rate[1] << std::endl;
174  os << "alt_rate[2]:" << data._alt_rate[2] << std::endl;
175
176  os << "crt_rate[0]:" << data._crt_rate[0] << std::endl;
177  os << "crt_rate[1]:" << data._crt_rate[1] << std::endl;
178  os << "crt_rate[2]:" << data._crt_rate[2] << std::endl;
179
180  os << "clutter_lock:" << data._line_cont.c_str() << std::endl;
181
182  os << "clutter_lock:" << data._clutter_lock.c_str() << std::endl;
183
184  os << "auto_focus:" << data._auto_focus.c_str() << std::endl;
185
186  os << "line_spacing:" << data._line_spacing << std::endl;
187
188  os << "pix_spacing:" << data._pix_spacing << std::endl;
189
190  os << "rngcmp_desg:" << data._rngcmp_desg.c_str() << std::endl;
191
192  os << "zero_dop_range_time_f_pixel:" << data._zero_dop_range_time_f_pixel << std::endl;
193
194  os << "zero_dop_range_time_c_pixel:" << data._zero_dop_range_time_c_pixel << std::endl;
195
196  os << "zero_dop_range_time_l_pixel:" << data._zero_dop_range_time_l_pixel << std::endl;
197
198  os << "zero_dop_az_time_f_pixel :" << data._zero_dop_az_time_f_pixel.c_str() << std::endl;
199
200  os << " zero_dop_az_time_c_pixel:" << data._zero_dop_az_time_c_pixel.c_str() << std::endl;
201
202  os << " zero_dop_az_time_l_pixel:" << data._zero_dop_az_time_l_pixel.c_str() << std::endl;
203
204  return os;
205
206 }
◆ operator<<() [29/63]
const AntennaElevationPatterns data
Definition at line 25 of file AntennaElevationPatterns.cpp.
References ossimplugins::AntennaElevationPatterns::_attach_flag, ossimplugins::AntennaElevationPatterns::_elevation_pattern, ossimplugins::AntennaElevationPatterns::_swath, and ossimplugins::AntennaElevationPatterns::_zero_doppler_time.
26  {
27  os<<"zero_doppler_time:"<<data._zero_doppler_time.c_str()<<std::endl;
28
30
31  os<<"swath:"<<data._swath.c_str()<<std::endl;
32
33  for (int i = 0; i<33; i++) {
34  os<<"elevation pattern:"<<data._elevation_pattern[i]<<std::endl;
35  }
36
37  return os;
38
39  }
◆ operator<<() [30/63]
const ErsSarFacilityData data
Definition at line 25 of file ErsSarFacilityData.cpp.
References ossimplugins::ErsSarFacilityData::_3_dB_look_bandwidth, ossimplugins::ErsSarFacilityData::_3_dB_look_proc_dopp_bandw, ossimplugins::ErsSarFacilityData::_3_dB_width_CCF, ossimplugins::ErsSarFacilityData::_abs_cal_const_K, ossimplugins::ErsSarFacilityData::_antenna_elev_flag, ossimplugins::ErsSarFacilityData::_asc_node_pos_X_comp, ossimplugins::ErsSarFacilityData::_asc_node_pos_Y_comp, ossimplugins::ErsSarFacilityData::_asc_node_pos_Z_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_X_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_Y_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_Z_comp, ossimplugins::ErsSarFacilityData::_autom_look_scal_gain_flag, ossimplugins::ErsSarFacilityData::_azimuth_baseband_convers_flag, ossimplugins::ErsSarFacilityData::_azimuth_FFT_IFFT_ratio, ossimplugins::ErsSarFacilityData::_cal_gain_change_flag, ossimplugins::ErsSarFacilityData::_cal_gain_changes, ossimplugins::ErsSarFacilityData::_cal_sys_gain, ossimplugins::ErsSarFacilityData::_cal_syst_gain_last_proc, ossimplugins::ErsSarFacilityData::_center_range_pix_mid_az_inc, ossimplugins::ErsSarFacilityData::_coef_ant_elev_1, ossimplugins::ErsSarFacilityData::_coef_ant_elev_2, ossimplugins::ErsSarFacilityData::_coef_ant_elev_3, ossimplugins::ErsSarFacilityData::_coef_ant_elev_4, ossimplugins::ErsSarFacilityData::_coef_ant_elev_5, ossimplugins::ErsSarFacilityData::_coef_ground_range_1, ossimplugins::ErsSarFacilityData::_coef_ground_range_2, ossimplugins::ErsSarFacilityData::_coef_ground_range_3, ossimplugins::ErsSarFacilityData::_coef_ground_range_4, ossimplugins::ErsSarFacilityData::_datation_flag, ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas, ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas_flag, ossimplugins::ErsSarFacilityData::_dopp_ambig_num, ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas, ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas_flag, ossimplugins::ErsSarFacilityData::_dopp_cent_val_flag, ossimplugins::ErsSarFacilityData::_doppler_ambiguity_estimat_flag, ossimplugins::ErsSarFacilityData::_doppler_centroid_cubic_coeff, ossimplugins::ErsSarFacilityData::_estim_bit_error_rate, ossimplugins::ErsSarFacilityData::_first_processed_range_sample, ossimplugins::ErsSarFacilityData::_first_range_pixel_mid_az_inc, ossimplugins::ErsSarFacilityData::_first_rec_gain_read, ossimplugins::ErsSarFacilityData::_first_replica_sample, ossimplugins::ErsSarFacilityData::_first_side_lobe_lev_of_ACF, ossimplugins::ErsSarFacilityData::_first_side_lobe_level, ossimplugins::ErsSarFacilityData::_form_num_range_line_used, ossimplugins::ErsSarFacilityData::_I_channel_bias_correction, ossimplugins::ErsSarFacilityData::_I_channel_gain_correction, ossimplugins::ErsSarFacilityData::_I_gain_imb_lower_bound, ossimplugins::ErsSarFacilityData::_I_gain_imb_upper_bound, ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_lower_bound, ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_upper_bound, ossimplugins::ErsSarFacilityData::_initial_doppler_ambiguity_num, ossimplugins::ErsSarFacilityData::_inp_data_I_mean, ossimplugins::ErsSarFacilityData::_inp_data_I_stddev, ossimplugins::ErsSarFacilityData::_inp_data_Q_mean, ossimplugins::ErsSarFacilityData::_inp_data_Q_stddev, ossimplugins::ErsSarFacilityData::_inp_data_stat_flag, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_X_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Y_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Z_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vx_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vy_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vz_comp, ossimplugins::ErsSarFacilityData::_inp_state_vector_type_flag, ossimplugins::ErsSarFacilityData::_int_cal_utc, ossimplugins::ErsSarFacilityData::_ISLR_CCF_between_last, ossimplugins::ErsSarFacilityData::_ISLR_of_ACF, ossimplugins::ErsSarFacilityData::_K_gen_date, ossimplugins::ErsSarFacilityData::_K_vers_num, ossimplugins::ErsSarFacilityData::_last_range_pix_mid_az_inc, ossimplugins::ErsSarFacilityData::_last_release_cal_date, ossimplugins::ErsSarFacilityData::_last_release_qc_date, ossimplugins::ErsSarFacilityData::_look_detecion_flag, ossimplugins::ErsSarFacilityData::_look_scalar_gain_1, ossimplugins::ErsSarFacilityData::_look_scalar_gain_2, ossimplugins::ErsSarFacilityData::_look_scalar_gain_3, ossimplugins::ErsSarFacilityData::_look_scalar_gain_4, ossimplugins::ErsSarFacilityData::_look_scalar_gain_5, ossimplugins::ErsSarFacilityData::_look_scalar_gain_6, ossimplugins::ErsSarFacilityData::_look_scalar_gain_7, ossimplugins::ErsSarFacilityData::_look_scalar_gain_8, ossimplugins::ErsSarFacilityData::_low_bound_K, ossimplugins::ErsSarFacilityData::_max_error_range_line_timing, ossimplugins::ErsSarFacilityData::_max_value_look_scalar_gain, ossimplugins::ErsSarFacilityData::_mean_cal_pulse_power, ossimplugins::ErsSarFacilityData::_mean_noise_power, ossimplugins::ErsSarFacilityData::_missing_lines, ossimplugins::ErsSarFacilityData::_noise_power, ossimplugins::ErsSarFacilityData::_norm_ref_range_ro, ossimplugins::ErsSarFacilityData::_num_azimuth_blocks_proc, ossimplugins::ErsSarFacilityData::_num_duplic_input_lines, ossimplugins::ErsSarFacilityData::_num_input_raw_data_lines, ossimplugins::ErsSarFacilityData::_num_range_samp_discarded, ossimplugins::ErsSarFacilityData::_num_valid_cal_pulses, ossimplugins::ErsSarFacilityData::_num_valid_noise_pulses, ossimplugins::ErsSarFacilityData::_num_valid_pixels_per_range, ossimplugins::ErsSarFacilityData::_num_valid_replicas, ossimplugins::ErsSarFacilityData::_OGOB_flag, ossimplugins::ErsSarFacilityData::_out_image_max_value, ossimplugins::ErsSarFacilityData::_out_image_mean, ossimplugins::ErsSarFacilityData::_out_image_std_dev, ossimplugins::ErsSarFacilityData::_out_pixel_bit_length, ossimplugins::ErsSarFacilityData::_outp_data_mean_flag, ossimplugins::ErsSarFacilityData::_peak_loc_CCF_betw_last, ossimplugins::ErsSarFacilityData::_peak_loc_cross_correl_fun, ossimplugins::ErsSarFacilityData::_PRF_changes, ossimplugins::ErsSarFacilityData::_prf_code_change_flag, ossimplugins::ErsSarFacilityData::_PRF_code_first_range_line, ossimplugins::ErsSarFacilityData::_PRF_code_last_range_line, ossimplugins::ErsSarFacilityData::_proc_gain_param_1, ossimplugins::ErsSarFacilityData::_proc_gain_param_2, ossimplugins::ErsSarFacilityData::_proc_gain_param_3, ossimplugins::ErsSarFacilityData::_proc_noise_scale_fact, ossimplugins::ErsSarFacilityData::_pulse_width_of_ACF_3db, ossimplugins::ErsSarFacilityData::_Q_channel_bias_correction, ossimplugins::ErsSarFacilityData::_Q_channel_gain_correction, ossimplugins::ErsSarFacilityData::_Q_channel_I_Q_correction, ossimplugins::ErsSarFacilityData::_qa_summary_flag, ossimplugins::ErsSarFacilityData::_quirp_qu_flag, ossimplugins::ErsSarFacilityData::_range_comp_norm_fact, ossimplugins::ErsSarFacilityData::_range_lines_skip_factor, ossimplugins::ErsSarFacilityData::_range_spread_loss_comp_flag, ossimplugins::ErsSarFacilityData::_range_time_origin_ant, ossimplugins::ErsSarFacilityData::_raw_data_correction_flag, ossimplugins::ErsSarFacilityData::_rec_gain_changes, ossimplugins::ErsSarFacilityData::_receiver_gain_last_proc, ossimplugins::ErsSarFacilityData::_replica_norm_method_flag, ossimplugins::ErsSarFacilityData::_replica_power, ossimplugins::ErsSarFacilityData::_Roll_Tilt_Mode_flag, ossimplugins::ErsSarFacilityData::_samp_win_start_first, ossimplugins::ErsSarFacilityData::_samp_win_start_last, ossimplugins::ErsSarFacilityData::_samp_window_start_time_bias, ossimplugins::ErsSarFacilityData::_samples_per_line_used, ossimplugins::ErsSarFacilityData::_sampling_win_change_flag, ossimplugins::ErsSarFacilityData::_sampling_win_changes, ossimplugins::ErsSarFacilityData::_sat_binary_time_of_first, ossimplugins::ErsSarFacilityData::_thresh_no_10_flag, ossimplugins::ErsSarFacilityData::_thresh_no_11_flag, ossimplugins::ErsSarFacilityData::_thresh_no_1_flag, ossimplugins::ErsSarFacilityData::_thresh_no_2_flag, ossimplugins::ErsSarFacilityData::_thresh_no_3_flag, ossimplugins::ErsSarFacilityData::_thresh_no_4_flag, ossimplugins::ErsSarFacilityData::_thresh_no_5_flag, ossimplugins::ErsSarFacilityData::_thresh_no_6_flag, ossimplugins::ErsSarFacilityData::_thresh_no_7_flag, ossimplugins::ErsSarFacilityData::_thresh_no_8_flag, ossimplugins::ErsSarFacilityData::_thresh_no_9_flag, ossimplugins::ErsSarFacilityData::_time_asc_node_state_vectors, ossimplugins::ErsSarFacilityData::_time_of_inp_state_vectors, ossimplugins::ErsSarFacilityData::_time_raw_data_first_input, ossimplugins::ErsSarFacilityData::_update_period_range_match, ossimplugins::ErsSarFacilityData::_upp_bound_K, ossimplugins::ErsSarFacilityData::_win_coeff_for_azi_match, and ossimplugins::ErsSarFacilityData::_win_coeff_for_range_match.
26  {
27  os << "last_release_qc_date:" << data._last_release_qc_date.c_str() << std::endl;
28
29  os << "last_release_cal_date:" << data._last_release_cal_date.c_str() << std::endl;
30
31  os << "qa_summary_flag:" << data._qa_summary_flag << std::endl;
32
33  os << "prf_code_change_flag:" << data._prf_code_change_flag << std::endl;
34
35  os << "sampling_win_change_flag:" << data._sampling_win_change_flag << std::endl;
36
37  os << "cal_gain_change_flag:" << data._cal_gain_change_flag << std::endl;
38
39  os << "quirp_qu_flag:" << data._quirp_qu_flag << std::endl;
40
41  os << "inp_data_stat_flag:" << data._inp_data_stat_flag << std::endl;
42
43  os << "dopp_cent_conf_meas_flag:" << data._dopp_cent_conf_meas_flag << std::endl;
44
45  os << "dopp_cent_val_flag:" << data._dopp_cent_val_flag << std::endl;
46
47  os << "dopp_ambig_conf_meas_flag:" << data._dopp_ambig_conf_meas_flag << std::endl;
48
49  os << "outp_data_mean_flag:" << data._outp_data_mean_flag << std::endl;
50
51  os << "OGOB_flag:" << data._OGOB_flag << std::endl;
52
53  os << "PRF_changes:" << data._PRF_changes << std::endl;
54
55  os << "sampling_win_changes:" << data._sampling_win_changes << std::endl;
56
57  os << "cal_gain_changes:" << data._cal_gain_changes << std::endl;
58
59  os << "missing_lines:" << data._missing_lines << std::endl;
60
61  os << "rec_gain_changes:" << data._rec_gain_changes << std::endl;
62
63  os << "pulse_width_of_ACF_3db:" << data._pulse_width_of_ACF_3db << std::endl;
64
65  os << "first_side_lobe_lev_of_ACF:" << data._first_side_lobe_lev_of_ACF << std::endl;
66
67  os << "ISLR_of_ACF:" << data._ISLR_of_ACF << std::endl;
68
69  os << "dopp_cent_conf_meas:" << data._dopp_cent_conf_meas << std::endl;
70
71  os << "dopp_ambig_conf_meas:" << data._dopp_ambig_conf_meas << std::endl;
72
73  os << "inp_data_I_mean:" << data._inp_data_I_mean << std::endl;
74
75  os << "inp_data_Q_mean:" << data._inp_data_Q_mean << std::endl;
76
77  os << "inp_data_I_stddev:" << data._inp_data_I_stddev << std::endl;
78
79  os << "inp_data_Q_stddev:" << data._inp_data_Q_stddev << std::endl;
80
81  os << "cal_sys_gain:" << data._cal_sys_gain << std::endl;
82
83  os << "first_rec_gain_read:" << data._first_rec_gain_read << std::endl;
84
85  os << "dopp_ambig_num:" << data._dopp_ambig_num << std::endl;
86
87  os << "I_channel_bias_correction:" << data._I_channel_bias_correction << std::endl;
88
89  os << "Q_channel_bias_correction:" << data._Q_channel_bias_correction << std::endl;
90
91  os << "I_channel_gain_correction:" << data._I_channel_gain_correction << std::endl;
92
93  os << "Q_channel_gain_correction:" << data._Q_channel_gain_correction << std::endl;
94
95  os << "Q_channel_I_Q_correction:" << data._Q_channel_I_Q_correction << std::endl;
96
97  os << "noise_power:" << data._noise_power << std::endl;
98
99  os << "int_cal_utc:" << data._int_cal_utc << std::endl;
100
101  os << "num_valid_cal_pulses:" << data._num_valid_cal_pulses << std::endl;
102
103  os << "num_valid_noise_pulses:" << data._num_valid_noise_pulses << std::endl;
104
105  os << "num_valid_replicas:" << data._num_valid_replicas << std::endl;
106
107  os << "first_replica_sample:" << data._first_replica_sample << std::endl;
108
109  os << "mean_cal_pulse_power:" << data._mean_cal_pulse_power << std::endl;
110
111  os << "mean_noise_power:" << data._mean_noise_power << std::endl;
112
113  os << "range_comp_norm_fact:" << data._range_comp_norm_fact << std::endl;
114
115  os << "replica_power:" << data._replica_power << std::endl;
116
117  os << "first_range_pixel_mid_az_inc:" << data._first_range_pixel_mid_az_inc << std::endl;
118
119  os << "center_range_pix_mid_az_inc:" << data._center_range_pix_mid_az_inc << std::endl;
120
121  os << "last_range_pix_mid_az_inc:" << data._last_range_pix_mid_az_inc << std::endl;
122
123  os << "norm_ref_range_ro:" << data._norm_ref_range_ro << std::endl;
124
125  os << "antenna_elev_flag:" << data._antenna_elev_flag << std::endl;
126
127  os << "abs_cal_const_K:" << data._abs_cal_const_K << std::endl;
128
129  os << "upp_bound_K:" << data._upp_bound_K << std::endl;
130
131  os << "low_bound_K:" << data._low_bound_K << std::endl;
132
133  os << "proc_noise_scale_fact:" << data._proc_noise_scale_fact << std::endl;
134
135  os << "K_gen_date:" << data._K_gen_date.c_str() << std::endl;
136
137  os << "K_vers_num:" << data._K_vers_num.c_str() << std::endl;
138
139  os << "num_duplic_input_lines:" << data._num_duplic_input_lines << std::endl;
140
141  os << "estim_bit_error_rate:" << data._estim_bit_error_rate << std::endl;
142
143  os << "out_image_mean:" << data._out_image_mean << std::endl;
144
145  os << "out_image_std_dev:" << data._out_image_std_dev << std::endl;
146
147  os << "out_image_max_value:" << data._out_image_max_value << std::endl;
148
149  os << "time_raw_data_first_input:" << data._time_raw_data_first_input.c_str() << std::endl;
150
151  os << "time_asc_node_state_vectors:" << data._time_asc_node_state_vectors.c_str() << std::endl;
152
153  os << "asc_node_pos_X_comp:" << data._asc_node_pos_X_comp.c_str() << std::endl;
154
155  os << "asc_node_pos_Y_comp:" << data._asc_node_pos_Y_comp.c_str() << std::endl;
156
157  os << "asc_node_pos_Z_comp:" << data._asc_node_pos_Z_comp.c_str() << std::endl;
158
159  os << "asc_node_vel_X_comp:" << data._asc_node_vel_X_comp.c_str() << std::endl;
160
161  os << "asc_node_vel_Y_comp:" << data._asc_node_vel_Y_comp.c_str() << std::endl;
162
163  os << "asc_node_vel_Z_comp:" << data._asc_node_vel_Z_comp.c_str() << std::endl;
164
165  os << "out_pixel_bit_length:" << data._out_pixel_bit_length << std::endl;
166
167  os << "proc_gain_param_1:" << data._proc_gain_param_1 << std::endl;
168
169  os << "proc_gain_param_2:" << data._proc_gain_param_2 << std::endl;
170
171  os << "proc_gain_param_3:" << data._proc_gain_param_3 << std::endl;
172
173  os << "peak_loc_cross_correl_fun:" << data._peak_loc_cross_correl_fun << std::endl;
174
175  os << "3_dB_width_CCF:" << data._3_dB_width_CCF << std::endl;
176
177  os << "first_side_lobe_level:" << data._first_side_lobe_level << std::endl;
178
179  os << "ISLR_CCF_between_last:" << data._ISLR_CCF_between_last << std::endl;
180
181  os << "peak_loc_CCF_betw_last:" << data._peak_loc_CCF_betw_last << std::endl;
182
183  os << "Roll_Tilt_Mode_flag:" << data._Roll_Tilt_Mode_flag << std::endl;
184
185  os << "raw_data_correction_flag:" << data._raw_data_correction_flag << std::endl;
186
187  os << "look_detecion_flag:" << data._look_detecion_flag << std::endl;
188
189  os << "doppler_ambiguity_estimat_flag:" << data._doppler_ambiguity_estimat_flag << std::endl;
190
191  os << "azimuth_baseband_convers_flag:" << data._azimuth_baseband_convers_flag << std::endl;
192
193  os << "samples_per_line_used:" << data._samples_per_line_used << std::endl;
194
195  os << "range_lines_skip_factor:" << data._range_lines_skip_factor << std::endl;
196
197  os << "time_of_inp_state_vectors:" << data._time_of_inp_state_vectors.c_str() << std::endl;
198
199  os << "inp_state_vect_pos_X_comp:" << data._inp_state_vect_pos_X_comp.c_str() << std::endl;
200
201  os << "inp_state_vect_pos_Y_comp:" << data._inp_state_vect_pos_Y_comp.c_str() << std::endl;
202
203  os << "inp_state_vect_pos_Z_comp:" << data._inp_state_vect_pos_Z_comp.c_str() << std::endl;
204
205  os << "inp_state_vect_vel_Vx_comp:" << data._inp_state_vect_vel_Vx_comp.c_str() << std::endl;
206
207  os << "inp_state_vect_vel_Vy_comp:" << data._inp_state_vect_vel_Vy_comp.c_str() << std::endl;
208
209  os << "inp_state_vect_vel_Vz_comp:" << data._inp_state_vect_vel_Vz_comp.c_str() << std::endl;
210
211  os << "inp_state_vector_type_flag:" << data._inp_state_vector_type_flag << std::endl;
212
213  os << "win_coeff_for_range_match:" << data._win_coeff_for_range_match << std::endl;
214
215  os << "win_coeff_for_azi_match:" << data._win_coeff_for_azi_match << std::endl;
216
217  os << "update_period_range_match:" << data._update_period_range_match << std::endl;
218
219  os << "look_scalar_gain_1:" << data._look_scalar_gain_1 << std::endl;
220
221  os << "look_scalar_gain_2:" << data._look_scalar_gain_2 << std::endl;
222
223  os << "look_scalar_gain_3:" << data._look_scalar_gain_3 << std::endl;
224
225  os << "look_scalar_gain_4:" << data._look_scalar_gain_4 << std::endl;
226
227  os << "look_scalar_gain_5:" << data._look_scalar_gain_5 << std::endl;
228
229  os << "look_scalar_gain_6:" << data._look_scalar_gain_6 << std::endl;
230
231  os << "look_scalar_gain_7:" << data._look_scalar_gain_7 << std::endl;
232
233  os << "look_scalar_gain_8:" << data._look_scalar_gain_8 << std::endl;
234
235  os << "samp_window_start_time_bias:" << data._samp_window_start_time_bias << std::endl;
236
237  os << "doppler_centroid_cubic_coeff:" << data._doppler_centroid_cubic_coeff << std::endl;
238
239  os << "PRF_code_first_range_line:" << data._PRF_code_first_range_line << std::endl;
240
241  os << "PRF_code_last_range_line:" << data._PRF_code_last_range_line << std::endl;
242
243  os << "samp_win_start_first:" << data._samp_win_start_first << std::endl;
244
245  os << "samp_win_start_last:" << data._samp_win_start_last << std::endl;
246
247  os << "cal_syst_gain_last_proc:" << data._cal_syst_gain_last_proc << std::endl;
248
249  os << "receiver_gain_last_proc:" << data._receiver_gain_last_proc << std::endl;
250
251  os << "first_processed_range_sample:" << data._first_processed_range_sample << std::endl;
252
253  os << "azimuth_FFT_IFFT_ratio:" << data._azimuth_FFT_IFFT_ratio << std::endl;
254
255  os << "num_azimuth_blocks_proc:" << data._num_azimuth_blocks_proc << std::endl;
256
257  os << "num_input_raw_data_lines:" << data._num_input_raw_data_lines << std::endl;
258
259  os << "initial_doppler_ambiguity_num:" << data._initial_doppler_ambiguity_num << std::endl;
260
261  os << "thresh_no_1_flag:" << data._thresh_no_1_flag << std::endl;
262
263  os << "thresh_no_2_flag:" << data._thresh_no_2_flag << std::endl;
264
265  os << "thresh_no_3_flag:" << data._thresh_no_3_flag << std::endl;
266
267  os << "thresh_no_4_flag:" << data._thresh_no_4_flag << std::endl;
268
269  os << "thresh_no_5_flag:" << data._thresh_no_5_flag << std::endl;
270
271  os << "thresh_no_6_flag:" << data._thresh_no_6_flag << std::endl;
272
273  os << "thresh_no_7_flag:" << data._thresh_no_7_flag << std::endl;
274
275  os << "thresh_no_8_flag:" << data._thresh_no_8_flag << std::endl;
276
277  os << "thresh_no_9_flag:" << data._thresh_no_9_flag << std::endl;
278
279  os << "thresh_no_10_flag:" << data._thresh_no_10_flag << std::endl;
280
281  os << "thresh_no_11_flag:" << data._thresh_no_11_flag << std::endl;
282
283  os << "sat_binary_time_of_first:" << data._sat_binary_time_of_first << std::endl;
284
285  os << "num_valid_pixels_per_range:" << data._num_valid_pixels_per_range << std::endl;
286
287  os << "num_range_samp_discarded:" << data._num_range_samp_discarded << std::endl;
288
289  os << "I_gain_imb_lower_bound:" << data._I_gain_imb_lower_bound << std::endl;
290
291  os << "I_gain_imb_upper_bound:" << data._I_gain_imb_upper_bound << std::endl;
292
293  os << "I_Q_quad_depar_lower_bound:" << data._I_Q_quad_depar_lower_bound << std::endl;
294
295  os << "I_Q_quad_depar_upper_bound:" << data._I_Q_quad_depar_upper_bound << std::endl;
296
297  os << "3_dB_look_bandwidth:" << data._3_dB_look_bandwidth << std::endl;
298
299  os << "3_dB_look_proc_dopp_bandw:" << data._3_dB_look_proc_dopp_bandw << std::endl;
300
301  os << "range_spread_loss_comp_flag:" << data._range_spread_loss_comp_flag << std::endl;
302
303  os << "datation_flag:" << data._datation_flag << std::endl;
304
305  os << "max_error_range_line_timing:" << data._max_error_range_line_timing << std::endl;
306
307  os << "form_num_range_line_used:" << data._form_num_range_line_used << std::endl;
308
309  os << "autom_look_scal_gain_flag:" << data._autom_look_scal_gain_flag << std::endl;
310
311  os << "max_value_look_scalar_gain:" << data._max_value_look_scalar_gain << std::endl;
312
313  os << "replica_norm_method_flag:" << data._replica_norm_method_flag << std::endl;
314
315  os << "coef_ground_range_1:" << data._coef_ground_range_1 << std::endl;
316
317  os << "coef_ground_range_2:" << data._coef_ground_range_2 << std::endl;
318
319  os << "coef_ground_range_3:" << data._coef_ground_range_3 << std::endl;
320
321  os << "coef_ground_range_4:" << data._coef_ground_range_4 << std::endl;
322
323  os << "coef_ant_elev_1:" << data._coef_ant_elev_1 << std::endl;
324
325  os << "coef_ant_elev_2:" << data._coef_ant_elev_2 << std::endl;
326
327  os << "coef_ant_elev_3:" << data._coef_ant_elev_3 << std::endl;
328
329  os << "coef_ant_elev_4:" << data._coef_ant_elev_4 << std::endl;
330
331  os << "coef_ant_elev_5:" << data._coef_ant_elev_5 << std::endl;
332
333  os << "range_time_origin_ant:" << data._range_time_origin_ant << std::endl;
334
335  return os;
336
337  }
◆ operator<<() [31/63]
const DataHistogramSignalData data
Definition at line 25 of file DataHistogramSignalData.cpp.
References ossimplugins::DataHistogramSignalData::_histogram, ossimplugins::DataHistogramSignalData::_ltab, ossimplugins::DataHistogramSignalData::_ntab, ossimplugins::DataHistogramSignalData::_rec_seq, and ossimplugins::DataHistogramSignalData::_sar_chn.
26 {
27
28  os<<"rec_seq:"<<data._rec_seq<<std::endl;
29
30  os<<"sar_chn:"<<data._sar_chn<<std::endl;
31
32  os<<"ntab:"<<data._ntab<<std::endl;
33
34  os<<"ltab:"<<data._ltab<<std::endl;
35
36  os<<data._histogram<<std::endl;
37
38  return os;
39 }
◆ operator<<() [32/63]
const ErsSarMapProjectionData data
Definition at line 25 of file ErsSarMapProjectionData.cpp.
References ossimplugins::ErsSarMapProjectionData::_asc_node_long, ossimplugins::ErsSarMapProjectionData::_first_line_first_pixel_lat, ossimplugins::ErsSarMapProjectionData::_first_line_first_pixel_lon, ossimplugins::ErsSarMapProjectionData::_first_line_last_pixel_lat, ossimplugins::ErsSarMapProjectionData::_first_line_last_pixel_lon, ossimplugins::ErsSarMapProjectionData::_last_line_first_pixel_lat, ossimplugins::ErsSarMapProjectionData::_last_line_first_pixel_lon, ossimplugins::ErsSarMapProjectionData::_last_line_last_pixel_lat, ossimplugins::ErsSarMapProjectionData::_last_line_last_pixel_lon, ossimplugins::ErsSarMapProjectionData::_map_proj_des, ossimplugins::ErsSarMapProjectionData::_name_of_ref_ellipsoid, ossimplugins::ErsSarMapProjectionData::_nom_interline_dist, ossimplugins::ErsSarMapProjectionData::_nom_interpixel_dist, ossimplugins::ErsSarMapProjectionData::_num_lines, ossimplugins::ErsSarMapProjectionData::_num_pix_in_line, ossimplugins::ErsSarMapProjectionData::_orbit_incl, ossimplugins::ErsSarMapProjectionData::_orientation_at_center, ossimplugins::ErsSarMapProjectionData::_platform_heading, ossimplugins::ErsSarMapProjectionData::_semi_maj_axis, and ossimplugins::ErsSarMapProjectionData::_semi_min_axis.
26  {
27  os << "map_proj_des:" << data._map_proj_des.c_str() << std::endl;
28
29  os << "num_pix_in_line:" << data._num_pix_in_line << std::endl;
30
31  os << "num_lines:" << data._num_lines << std::endl;
32
33  os << "nom_interpixel_dist:" << data._nom_interpixel_dist << std::endl;
34
35  os << "nom_interline_dist:" << data._nom_interline_dist << std::endl;
36
37  os << "orientation_at_center:" << data._orientation_at_center << std::endl;
38
39  os << "orbit_incl:" << data._orbit_incl << std::endl;
40
41  os << "asc_node_long:" << data._asc_node_long << std::endl;
42
43  os << "platform_heading:" << data._platform_heading << std::endl;
44
45  os << "name_of_ref_ellipsoid:" << data._name_of_ref_ellipsoid.c_str() << std::endl;
46
47  os << "semi_maj_axis:" << data._semi_maj_axis << std::endl;
48
49  os << "semi_min_axis:" << data._semi_min_axis << std::endl;
50
51  os << "first_line_first_pixel_lat:" << data._first_line_first_pixel_lat << std::endl;
52
53  os << "first_line_first_pixel_lon:" << data._first_line_first_pixel_lon << std::endl;
54
55  os << "first_line_last_pixel_lat:" << data._first_line_last_pixel_lat << std::endl;
56
57  os << "first_line_last_pixel_lon:" << data._first_line_last_pixel_lon << std::endl;
58
59  os << "last_line_last_pixel_lat:" << data._last_line_last_pixel_lat << std::endl;
60
61  os << "last_line_last_pixel_lon:" << data._last_line_last_pixel_lon << std::endl;
62
63  os << "last_line_first_pixel_lat:" << data._last_line_first_pixel_lat << std::endl;
64
65  os << "last_line_first_pixel_lon:" << data._last_line_first_pixel_lon << std::endl;
66
67  return os;
68
69  }
◆ operator<<() [33/63]
const ChirpParameters data
Definition at line 25 of file ChirpParameters.cpp.
References ossimplugins::ChirpParameters::_attach_flag, ossimplugins::ChirpParameters::_cal_pulse_info, ossimplugins::ChirpParameters::_chirp_islr, ossimplugins::ChirpParameters::_chirp_peak_loc, ossimplugins::ChirpParameters::_chirp_quality_flag, ossimplugins::ChirpParameters::_chirp_sidelobe, ossimplugins::ChirpParameters::_chirp_width, ossimplugins::ChirpParameters::_elev_chirp_power, ossimplugins::ChirpParameters::_normalisation_source, ossimplugins::ChirpParameters::_polar, ossimplugins::ChirpParameters::_re_chirp_power, ossimplugins::ChirpParameters::_ref_chirp_power, ossimplugins::ChirpParameters::_swath, and ossimplugins::ChirpParameters::_zero_doppler_time.
26  {
28
30
32
33  os<<"polar:"<<data._polar.c_str()<<std::endl;
34
35  os<<"chirp_width:"<<data._chirp_width<<std::endl;
36
37  os<<"chirp_sidelobe:"<<data._chirp_sidelobe<<std::endl;
38
39  os<<"chirp_islr:"<<data._chirp_islr<<std::endl;
40
41  os<<"chirp_peak_loc:"<<data._chirp_peak_loc<<std::endl;
42
43  os<<"re_chirp_power:"<<data._re_chirp_power<<std::endl;
44
45  os<<"elev_chirp_power:"<<data._elev_chirp_power<<std::endl;
46
47  os<<"chirp_quality_flag:"<<data._chirp_quality_flag<<std::endl;
48
49  os<<"ref_chirp_power:"<<data._ref_chirp_power<<std::endl;
50
51  os<<"normalisation_source:"<<data._normalisation_source.c_str()<<std::endl;
52
53  for (int i = 0 ; i<352; i++) {
54  os<<"cal_pulse_info["<<i<<"]:"<<data._cal_pulse_info[i]<<std::endl;
55  }
56
57  return os;
58
59  }
◆ operator<<() [34/63]
const RadiometricData data
Definition at line 25 of file RadiometricData.cpp.
References ossimplugins::RadiometricData::_calib_const, ossimplugins::RadiometricData::_chan_ind, ossimplugins::RadiometricData::_field_size, ossimplugins::RadiometricData::_lookup_tab, ossimplugins::RadiometricData::_n_data, ossimplugins::RadiometricData::_n_samp, ossimplugins::RadiometricData::_noise_scale, ossimplugins::RadiometricData::_offset, ossimplugins::RadiometricData::_samp_inc, ossimplugins::RadiometricData::_samp_type, ossimplugins::RadiometricData::_seq_num, and ossimplugins::RadiometricData::_table_desig.
26 {
27  os<<"seq_num:"<<data._seq_num<<std::endl;
28
29  os<<"n_data:"<<data._n_data<<std::endl;
30
31  os<<"field_size:"<<data._field_size<<std::endl;
32
33  os<<"chan_ind:"<<data._chan_ind.c_str()<<std::endl;
34
35  os<<"table_desig:"<<data._table_desig.c_str()<<std::endl;
36
37  os<<"n_samp:"<<data._n_samp<<std::endl;
38
39  os<<"samp_type:"<<data._samp_type.c_str()<<std::endl;
40
41  os<<"samp_inc:"<<data._samp_inc<<std::endl;
42
43  for (int i=0;i<512;i++)
44  {
45  os<<"lookup_tab["<<i<<"]:"<<data._lookup_tab[i]<<std::endl;
46  }
47
48  os<<"noise_scale:"<<data._noise_scale<<std::endl;
49
50  os<<"offset:"<<data._offset<<std::endl;
51
52  os<<"calib_const:"<<data._calib_const<<std::endl;
53
54  return os;
55 }
◆ operator<<() [35/63]
const DopplerCentroidParameters data
Definition at line 25 of file DopplerCentroidParameters.cpp.
References ossimplugins::DopplerCentroidParameters::_attach_flag, ossimplugins::DopplerCentroidParameters::_delta_dopp_coeff, ossimplugins::DopplerCentroidParameters::_dop_coef, ossimplugins::DopplerCentroidParameters::_dop_conf, ossimplugins::DopplerCentroidParameters::_dop_conf_below_thresh_flag, ossimplugins::DopplerCentroidParameters::_slant_range_time, and ossimplugins::DopplerCentroidParameters::_zero_doppler_time.
26  {
28
30
31  os<<"slant_range_time:"<<data._slant_range_time<<std::endl;
32
33  os<<"dop_coef[0]:"<<data._dop_coef[0]<<std::endl;
34  os<<"dop_coef[1]:"<<data._dop_coef[1]<<std::endl;
35  os<<"dop_coef[2]:"<<data._dop_coef[2]<<std::endl;
36  os<<"dop_coef[3]:"<<data._dop_coef[3]<<std::endl;
37  os<<"dop_coef[4]:"<<data._dop_coef[4]<<std::endl;
38
39  os<<"dop_conf:"<<data._dop_conf<<std::endl;
40
41  os<<"dop_conf_below_thresh_flag:"<<data._dop_conf_below_thresh_flag<<std::endl;
42
43  os<<"delta_dopp_coeff[0]:"<<data._delta_dopp_coeff[0]<<std::endl;
44  os<<"delta_dopp_coeff[1]:"<<data._delta_dopp_coeff[1]<<std::endl;
45  os<<"delta_dopp_coeff[2]:"<<data._delta_dopp_coeff[2]<<std::endl;
46  os<<"delta_dopp_coeff[3]:"<<data._delta_dopp_coeff[3]<<std::endl;
47  os<<"delta_dopp_coeff[4]:"<<data._delta_dopp_coeff[4]<<std::endl;
48
49  return os;
50
51  }
◆ operator<<() [36/63]
const AttitudeData data
Definition at line 26 of file AttitudeData.cpp.
References ossimplugins::AttitudeData::_att_vect, ossimplugins::AttitudeData::_npoint, ossimplugins::AttitudeData::_pitch_bias, ossimplugins::AttitudeData::_roll_bias, and ossimplugins::AttitudeData::_yaw_bias.
27 {
28  os<<"npoint:"<<data._npoint<<std::endl;
29  for (int i=0;i<20;i++)
30  {
31  os<<"att_vect["<<i<<"]:"<<data._att_vect[i]<<std::endl;
32  }
33  os<<"pitch_bias:"<<data._pitch_bias<<std::endl;
34  os<<"roll_bias:"<<data._roll_bias<<std::endl;
35  os<<"yaw_bias:"<<data._yaw_bias<<std::endl;
36  return os;
37 }
◆ operator<<() [37/63]
const SQ_ADSR data
Definition at line 26 of file SQ_ADSR.cpp.
References ossimplugins::SQ_ADSR::_attach_flag, ossimplugins::SQ_ADSR::_chirp_flag, ossimplugins::SQ_ADSR::_dop_amb_flag, ossimplugins::SQ_ADSR::_dop_cen_flag, ossimplugins::SQ_ADSR::_exp_input_mean, ossimplugins::SQ_ADSR::_exp_input_std_dev, ossimplugins::SQ_ADSR::_exp_output_mean, ossimplugins::SQ_ADSR::_exp_output_std_dev, ossimplugins::SQ_ADSR::_input_gaps_flag, ossimplugins::SQ_ADSR::_input_mean, ossimplugins::SQ_ADSR::_input_mean_flag, ossimplugins::SQ_ADSR::_input_missing_lines_flag, ossimplugins::SQ_ADSR::_input_std_dev, ossimplugins::SQ_ADSR::_input_std_dev_flag, ossimplugins::SQ_ADSR::_invalid_downlink_flag, ossimplugins::SQ_ADSR::_lines_per_gaps, ossimplugins::SQ_ADSR::_missing_data_set_flag, ossimplugins::SQ_ADSR::_num_gaps, ossimplugins::SQ_ADSR::_num_missing_lines, ossimplugins::SQ_ADSR::_output_mean, ossimplugins::SQ_ADSR::_output_mean_flag, ossimplugins::SQ_ADSR::_output_std_dev, ossimplugins::SQ_ADSR::_output_std_dev_flag, ossimplugins::SQ_ADSR::_thres_chirp_broadening, ossimplugins::SQ_ADSR::_thresh_chirp_islr, ossimplugins::SQ_ADSR::_thresh_chirp_sidelobe, ossimplugins::SQ_ADSR::_thresh_dop_amb, ossimplugins::SQ_ADSR::_thresh_dop_cen, ossimplugins::SQ_ADSR::_thresh_input_gaps, ossimplugins::SQ_ADSR::_thresh_input_mean, ossimplugins::SQ_ADSR::_thresh_input_missing_lines, ossimplugins::SQ_ADSR::_thresh_input_std_dev, ossimplugins::SQ_ADSR::_thresh_output_mean, ossimplugins::SQ_ADSR::_thresh_output_std_dev, ossimplugins::SQ_ADSR::_tot_errors, and ossimplugins::SQ_ADSR::_zero_doppler_time.
27  {
28  os<<"zero_doppler_time:"<<data._zero_doppler_time.c_str()<<std::endl;
29
30  os<<"attach_flag:"<<data._attach_flag<<std::endl;
31
32  os<<"input_mean_flag:"<<data._input_mean_flag<<std::endl;
33
34  os<<"input_std_dev_flag:"<<data._input_std_dev_flag<<std::endl;
35
36  os<<"input_gaps_flag:"<<data._input_gaps_flag<<std::endl;
37
38  os<<"input_missing_lines_flag:"<<data._input_missing_lines_flag<<std::endl;
39
40  os<<"dop_cen_flag:"<<data._dop_cen_flag<<std::endl;
41
42  os<<"dop_amb_flag:"<<data._dop_amb_flag<<std::endl;
43
44  os<<"output_mean_flag:"<<data._output_mean_flag<<std::endl;
45
46  os<<"output_std_dev_flag:"<<data._output_std_dev_flag<<std::endl;
47
48  os<<"chirp_flag:"<<data._chirp_flag<<std::endl;
49
50  os<<"missing_data_set_flag:"<<data._missing_data_set_flag<<std::endl;
51
52  os<<"invalid_downlink_flag:"<<data._invalid_downlink_flag<<std::endl;
53
54  os<<"thres_chirp_broadening:"<<data._thres_chirp_broadening<<std::endl;
55
56  os<<"thresh_chirp_sidelobe:"<<data._thresh_chirp_sidelobe<<std::endl;
57
58  os<<"thresh_chirp_islr:"<<data._thresh_chirp_islr<<std::endl;
59
60  os<<"thresh_input_mean:"<<data._thresh_input_mean<<std::endl;
61
62  os<<"exp_input_mean:"<<data._exp_input_mean<<std::endl;
63
64  os<<"thresh_input_std_dev:"<<data._thresh_input_std_dev<<std::endl;
65
66  os<<"exp_input_std_dev:"<<data._exp_input_std_dev<<std::endl;
67
68  os<<"thresh_dop_cen:"<<data._thresh_dop_cen<<std::endl;
69
70  os<<"thresh_dop_amb:"<<data._thresh_dop_amb<<std::endl;
71
72  os<<"thresh_output_mean:"<<data._thresh_output_mean<<std::endl;
73
74  os<<"exp_output_mean:"<<data._exp_output_mean<<std::endl;
75
76  os<<"thresh_output_std_dev:"<<data._thresh_output_std_dev<<std::endl;
77
78  os<<"exp_output_std_dev:"<<data._exp_output_std_dev<<std::endl;
79
80  os<<"thresh_input_missing_lines:"<<data._thresh_input_missing_lines<<std::endl;
81
82  os<<"thresh_input_gaps:"<<data._thresh_input_gaps<<std::endl;
83
84  os<<"lines_per_gaps:"<<data._lines_per_gaps<<std::endl;
85
86  os<<"input_mean[0]:"<<data._input_mean[0]<<std::endl;
87  os<<"input_mean[1]:"<<data._input_mean[1]<<std::endl;
88
89  os<<"input_std_dev[0]:"<<data._input_std_dev[0]<<std::endl;
90  os<<"input_std_dev[1]:"<<data._input_std_dev[1]<<std::endl;
91
92  os<<"num_gaps:"<<data._num_gaps<<std::endl;
93
94  os<<"num_missing_lines:"<<data._num_missing_lines<<std::endl;
95
96  os<<"output_mean[0]:"<<data._output_mean[0]<<std::endl;
97  os<<"output_mean[1]:"<<data._output_mean[1]<<std::endl;
98
99  os<<"output_std_dev[0]:"<<data._output_std_dev[0]<<std::endl;
100  os<<"output_std_dev[1]:"<<data._output_std_dev[1]<<std::endl;
101
102  os<<"tot_errors:"<<data._tot_errors<<std::endl;
103
104  return os;
105
106  }
◆ operator<<() [38/63]
const AlosPalsarDataSetSummary data
from 1767 to 4096 to be added
Definition at line 26 of file AlosPalsarDataSetSummary.cpp.
References ossimplugins::AlosPalsarDataSetSummary::_algor_id, ossimplugins::AlosPalsarDataSetSummary::_alt_dopcen, ossimplugins::AlosPalsarDataSetSummary::_alt_rate, ossimplugins::AlosPalsarDataSetSummary::_ampl_coef, ossimplugins::AlosPalsarDataSetSummary::_asc_des, ossimplugins::AlosPalsarDataSetSummary::_auto_focus, ossimplugins::AlosPalsarDataSetSummary::_azi_res, ossimplugins::AlosPalsarDataSetSummary::_azi_weight, ossimplugins::AlosPalsarDataSetSummary::_baseband_f, ossimplugins::AlosPalsarDataSetSummary::_bnd_azi, ossimplugins::AlosPalsarDataSetSummary::_bnd_azilok, ossimplugins::AlosPalsarDataSetSummary::_bnd_rng, ossimplugins::AlosPalsarDataSetSummary::_bnd_rnglok, ossimplugins::AlosPalsarDataSetSummary::_chirp_ext_ind, ossimplugins::AlosPalsarDataSetSummary::_chn_bits, ossimplugins::AlosPalsarDataSetSummary::_clock_ang, ossimplugins::AlosPalsarDataSetSummary::_clutter_lock, ossimplugins::AlosPalsarDataSetSummary::_crt_dopcen, ossimplugins::AlosPalsarDataSetSummary::_crt_rate, ossimplugins::AlosPalsarDataSetSummary::_data_inpsrc, ossimplugins::AlosPalsarDataSetSummary::_dopcen_range, ossimplugins::AlosPalsarDataSetSummary::_earth_mass, ossimplugins::AlosPalsarDataSetSummary::_ellip_des, ossimplugins::AlosPalsarDataSetSummary::_ellip_j, ossimplugins::AlosPalsarDataSetSummary::_ellip_maj, ossimplugins::AlosPalsarDataSetSummary::_ellip_min, ossimplugins::AlosPalsarDataSetSummary::_fa, ossimplugins::AlosPalsarDataSetSummary::_fac_id, ossimplugins::AlosPalsarDataSetSummary::_fr, ossimplugins::AlosPalsarDataSetSummary::_gn_cross, ossimplugins::AlosPalsarDataSetSummary::_gn_polar, ossimplugins::AlosPalsarDataSetSummary::_grav_const, ossimplugins::AlosPalsarDataSetSummary::_i_bias, ossimplugins::AlosPalsarDataSetSummary::_incident_ang, ossimplugins::AlosPalsarDataSetSummary::_inp_sctim, ossimplugins::AlosPalsarDataSetSummary::_iq_ratio, ossimplugins::AlosPalsarDataSetSummary::_line_cont, ossimplugins::AlosPalsarDataSetSummary::_line_spacing, ossimplugins::AlosPalsarDataSetSummary::_mech_sight, ossimplugins::AlosPalsarDataSetSummary::_mission_id, ossimplugins::AlosPalsarDataSetSummary::_motion_comp, ossimplugins::AlosPalsarDataSetSummary::_n_azilok, ossimplugins::AlosPalsarDataSetSummary::_n_rnglok, ossimplugins::AlosPalsarDataSetSummary::_nchn, ossimplugins::AlosPalsarDataSetSummary::_orbit_num, ossimplugins::AlosPalsarDataSetSummary::_phas_coef, ossimplugins::AlosPalsarDataSetSummary::_pix_spacing, ossimplugins::AlosPalsarDataSetSummary::_plat_head, ossimplugins::AlosPalsarDataSetSummary::_plat_lat, ossimplugins::AlosPalsarDataSetSummary::_plat_long, ossimplugins::AlosPalsarDataSetSummary::_pro_head, ossimplugins::AlosPalsarDataSetSummary::_pro_lat, ossimplugins::AlosPalsarDataSetSummary::_pro_long, ossimplugins::AlosPalsarDataSetSummary::_prod_type, ossimplugins::AlosPalsarDataSetSummary::_pulse_code, ossimplugins::AlosPalsarDataSetSummary::_q_bias, ossimplugins::AlosPalsarDataSetSummary::_quant_desc, ossimplugins::AlosPalsarDataSetSummary::_rng_gate, ossimplugins::AlosPalsarDataSetSummary::_rng_length, ossimplugins::AlosPalsarDataSetSummary::_rng_res, ossimplugins::AlosPalsarDataSetSummary::_rng_weight, ossimplugins::AlosPalsarDataSetSummary::_rngcmp_desg, ossimplugins::AlosPalsarDataSetSummary::_rngcmp_f, ossimplugins::AlosPalsarDataSetSummary::_sar_chn, ossimplugins::AlosPalsarDataSetSummary::_sat_bintim, ossimplugins::AlosPalsarDataSetSummary::_sat_clkinc, ossimplugins::AlosPalsarDataSetSummary::_sat_clktim, ossimplugins::AlosPalsarDataSetSummary::_sc_lin, ossimplugins::AlosPalsarDataSetSummary::_sc_pix, ossimplugins::AlosPalsarDataSetSummary::_scene_des, ossimplugins::AlosPalsarDataSetSummary::_scene_id, ossimplugins::AlosPalsarDataSetSummary::_scene_len, ossimplugins::AlosPalsarDataSetSummary::_scene_wid, ossimplugins::AlosPalsarDataSetSummary::_sensor_id, ossimplugins::AlosPalsarDataSetSummary::_seq_num, ossimplugins::AlosPalsarDataSetSummary::_sys_id, ossimplugins::AlosPalsarDataSetSummary::_terrain_h, ossimplugins::AlosPalsarDataSetSummary::_time_dir_lin, ossimplugins::AlosPalsarDataSetSummary::_time_dir_pix, ossimplugins::AlosPalsarDataSetSummary::_ver_id, and ossimplugins::AlosPalsarDataSetSummary::_wave_length.
27 {
28  os << "seq_num:" << data._seq_num << std::endl;
29
30  os << "sar_chn:" << data._sar_chn << std::endl;
31
32  os << "scene_id:" << data._scene_id.c_str() << std::endl;
33
34  os << "scene_des:" << data._scene_des.c_str() << std::endl;
35
36  os << "inp_sctim:" << data._inp_sctim.c_str() << std::endl;
37
38  os << "asc_des:" << data._asc_des.c_str() << std::endl;
39
40  os << "pro_lat:" << data._pro_lat << std::endl;
41
42  os << "pro_long:" << data._pro_long << std::endl;
43
44  os << "pro_head:" << data._pro_head << std::endl;
45
46  os << "ellip_des:" << data._ellip_des.c_str() << std::endl;
47
48  os << "ellip_maj:" << data._ellip_maj << std::endl;
49
50  os << "ellip_min:" << data._ellip_min << std::endl;
51  os << "earth_mass:" << data._earth_mass << std::endl;
52  os << "grav_const:" << data._grav_const << std::endl;
53  os << "ellip_j[0]:" << data._ellip_j[0] << std::endl;
54  os << "ellip_j[1]:" << data._ellip_j[1] << std::endl;
55  os << "ellip_j[2]:" << data._ellip_j[2] << std::endl;
56  os << "terrain_h:" << data._terrain_h << std::endl;
57  os << "sc_lin:" << data._sc_lin << std::endl;
58  os << "sc_pix:" << data._sc_pix << std::endl;
59  os << "scene_len:" << data._scene_len << std::endl;
60  os << "scene_wid:" << data._scene_wid << std::endl;
61  os << "nchn:" << data._nchn << std::endl;
62  os << "mission_id:" << data._mission_id.c_str() << std::endl;
63  os << "sensor_id:" << data._sensor_id.c_str() << std::endl;
64  os << "orbit_num:" << data._orbit_num.c_str() << std::endl;
65
66  os << "plat_lat:" << data._plat_lat << std::endl;
67
68  os << "plat_long:" << data._plat_long << std::endl;
69
70  os << "plat_head:" << data._plat_head << std::endl;
71
72  os << "clock_ang:" << data._clock_ang << std::endl;
73
74  os << "incident_ang:" << data._incident_ang << std::endl;
75
76
77  os << "wave_length:" << data._wave_length << std::endl;
78
79  os << "motion_comp:" << data._motion_comp.c_str() << std::endl;
80
81  os << "pulse_code:" << data._pulse_code.c_str() << std::endl;
82
83  for (int i = 0; i < 5; i++)
84  {
85  os << "ampl_coef[" << i << "]:" << data._ampl_coef[i] << std::endl;
86  }
87
88  for (int i = 0; i < 5; i++)
89  {
90  os << "phas_coef[" << i << "]:" << data._phas_coef[i] << std::endl;
91  }
92
93  os << "chirp_ext_ind:" << data._chirp_ext_ind << std::endl;
94
95  os << "fr:" << data._fr << std::endl;
96
97  os << "rng_gate:" << data._rng_gate << std::endl;
98
99  os << "rng_length:" << data._rng_length << std::endl;
100
101  os << "baseband_f:" << data._baseband_f.c_str() << std::endl;
102
103  os << "rngcmp_f:" << data._rngcmp_f.c_str() << std::endl;
104
105  os << "gn_polar:" << data._gn_polar << std::endl;
106
107  os << "gn_cross:" << data._gn_cross << std::endl;
108
109  os << "chn_bits:" << data._chn_bits << std::endl;
110
111  os << "quant_desc:" << data._quant_desc.c_str() << std::endl;
112
113  os << "i_bias:" << data._i_bias << std::endl;
114
115  os << "q_bias:" << data._q_bias << std::endl;
116
117  os << "iq_ratio:" << data._iq_ratio << std::endl;
118
119  os << "mech_sight:" << data._mech_sight << std::endl;
120
121  os << "fa:" << data._fa << std::endl;
122
123  os << "sat_bintim:" << data._sat_bintim.c_str() << std::endl;
124
125  os << "sat_clktim:" << data._sat_clktim.c_str() << std::endl;
126
127  os << "sat_clkinc:" << data._sat_clkinc.c_str() << std::endl;
128
129  os << "fac_id:" << data._fac_id.c_str() << std::endl;
130
131  os << "sys_id:" << data._sys_id.c_str() << std::endl;
132
133  os << "ver_id:" << data._ver_id.c_str() << std::endl;
134
135  os << "prod_type:" << data._prod_type.c_str() << std::endl;
136
137  os << "algor_id:" << data._algor_id.c_str() << std::endl;
138
139  os << "n_azilok:" << data._n_azilok << std::endl;
140
141  os << "n_rnglok:" << data._n_rnglok << std::endl;
142
143  os << "bnd_azilok:" << data._bnd_azilok << std::endl;
144
145  os << "bnd_rnglok:" << data._bnd_rnglok << std::endl;
146
147  os << "bnd_azi:" << data._bnd_azi << std::endl;
148
149  os << "bnd_rng:" << data._bnd_rng << std::endl;
150
151  os << "azi_weight:" << data._azi_weight.c_str() << std::endl;
152
153  os << "rng_weight:" << data._rng_weight.c_str() << std::endl;
154
155  os << "data_inpsrc:" << data._data_inpsrc.c_str() << std::endl;
156
157  os << "rng_res:" << data._rng_res << std::endl;
158
159  os << "azi_res:" << data._azi_res << std::endl;
160
161  os << "alt_dopcen[0]:" << data._alt_dopcen[0] << std::endl;
162  os << "alt_dopcen[1]:" << data._alt_dopcen[1] << std::endl;
163  os << "alt_dopcen[2]:" << data._alt_dopcen[2] << std::endl;
164
165  os << "crt_dopcen[0]:" << data._crt_dopcen[0] << std::endl;
166  os << "crt_dopcen[1]:" << data._crt_dopcen[1] << std::endl;
167  os << "crt_dopcen[2]:" << data._crt_dopcen[2] << std::endl;
168
169  os << "time_dir_pix:" << data._time_dir_pix.c_str() << std::endl;
170
171  os << "time_dir_lin:" << data._time_dir_lin.c_str() << std::endl;
172
173  os << "alt_rate[0]:" << data._alt_rate[0] << std::endl;
174  os << "alt_rate[1]:" << data._alt_rate[1] << std::endl;
175  os << "alt_rate[2]:" << data._alt_rate[2] << std::endl;
176
177  os << "crt_rate[0]:" << data._crt_rate[0] << std::endl;
178  os << "crt_rate[1]:" << data._crt_rate[1] << std::endl;
179  os << "crt_rate[2]:" << data._crt_rate[2] << std::endl;
180
181  os << "clutter_lock:" << data._line_cont.c_str() << std::endl;
182
183  os << "clutter_lock:" << data._clutter_lock.c_str() << std::endl;
184
185  os << "auto_focus:" << data._auto_focus.c_str() << std::endl;
186
187  os << "line_spacing:" << data._line_spacing << std::endl;
188
189  os << "pix_spacing:" << data._pix_spacing << std::endl;
190
191  os << "rngcmp_desg:" << data._rngcmp_desg.c_str() << std::endl;
192
193
194  os << "dopcen_range[0]:" << data._dopcen_range[0] << std::endl;
195  os << "dopcen_range[1]:" << data._dopcen_range[1] << std::endl;
200  return os;
201
202 }
◆ operator<<() [39/63]
const AlosPalsarMapProjectionData data
Definition at line 26 of file AlosPalsarMapProjectionData.cpp.
References ossimplugins::AlosPalsarMapProjectionData::_asc_node_long, ossimplugins::AlosPalsarMapProjectionData::_first_line_first_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_first_line_first_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_first_line_last_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_first_line_last_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_last_line_first_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_last_line_first_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_last_line_last_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_last_line_last_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_map_proj_des, ossimplugins::AlosPalsarMapProjectionData::_name_of_ref_ellipsoid, ossimplugins::AlosPalsarMapProjectionData::_nom_interline_dist, ossimplugins::AlosPalsarMapProjectionData::_nom_interpixel_dist, ossimplugins::AlosPalsarMapProjectionData::_num_lines, ossimplugins::AlosPalsarMapProjectionData::_num_pix_in_line, ossimplugins::AlosPalsarMapProjectionData::_orbit_incl, ossimplugins::AlosPalsarMapProjectionData::_orientation_at_center, ossimplugins::AlosPalsarMapProjectionData::_platform_heading, ossimplugins::AlosPalsarMapProjectionData::_semi_maj_axis, and ossimplugins::AlosPalsarMapProjectionData::_semi_min_axis.
27  {
28  os << "map_proj_des:" << data._map_proj_des.c_str() << std::endl;
29
30  os << "num_pix_in_line:" << data._num_pix_in_line << std::endl;
31
32  os << "num_lines:" << data._num_lines << std::endl;
33
34  os << "nom_interpixel_dist:" << data._nom_interpixel_dist << std::endl;
35
36  os << "nom_interline_dist:" << data._nom_interline_dist << std::endl;
37
38  os << "orientation_at_center:" << data._orientation_at_center << std::endl;
39
40  os << "orbit_incl:" << data._orbit_incl << std::endl;
41
42  os << "asc_node_long:" << data._asc_node_long << std::endl;
43
44  os << "platform_heading:" << data._platform_heading << std::endl;
45
46  os << "name_of_ref_ellipsoid:" << data._name_of_ref_ellipsoid.c_str() << std::endl;
47
48  os << "semi_maj_axis:" << data._semi_maj_axis << std::endl;
49
50  os << "semi_min_axis:" << data._semi_min_axis << std::endl;
51
52  os << "first_line_first_pixel_lat:" << data._first_line_first_pixel_lat << std::endl;
53
54  os << "first_line_first_pixel_lon:" << data._first_line_first_pixel_lon << std::endl;
55
56  os << "first_line_last_pixel_lat:" << data._first_line_last_pixel_lat << std::endl;
57
58  os << "first_line_last_pixel_lon:" << data._first_line_last_pixel_lon << std::endl;
59
60  os << "last_line_last_pixel_lat:" << data._last_line_last_pixel_lat << std::endl;
61
62  os << "last_line_last_pixel_lon:" << data._last_line_last_pixel_lon << std::endl;
63
64  os << "last_line_first_pixel_lat:" << data._last_line_first_pixel_lat << std::endl;
65
66  os << "last_line_first_pixel_lon:" << data._last_line_first_pixel_lon << std::endl;
67
68  return os;
69
70  }
◆ operator<<() [40/63]
std::ostream& ossimplugins::operator<< ( std::ostream &  os,
const ErsSarFileDescriptor data
Definition at line 26 of file ErsSarFileDescriptor.cpp.
References ossimplugins::ErsSarFileDescriptor::_ascii_flag, ossimplugins::ErsSarFileDescriptor::_code_len, ossimplugins::ErsSarFileDescriptor::_code_loc, ossimplugins::ErsSarFileDescriptor::_design_rev, ossimplugins::ErsSarFileDescriptor::_file_name, ossimplugins::ErsSarFileDescriptor::_file_num, ossimplugins::ErsSarFileDescriptor::_format_doc, ossimplugins::ErsSarFileDescriptor::_format_ver, ossimplugins::ErsSarFileDescriptor::_l_anno_data, ossimplugins::ErsSarFileDescriptor::_l_att_data, ossimplugins::ErsSarFileDescriptor::_l_cal, ossimplugins::ErsSarFileDescriptor::_l_data_his, ossimplugins::ErsSarFileDescriptor::_l_dataset, ossimplugins::ErsSarFileDescriptor::_l_dem_desc, ossimplugins::ErsSarFileDescriptor::_l_det_proc, ossimplugins::ErsSarFileDescriptor::_l_fac_data, ossimplugins::ErsSarFileDescriptor::_l_gcp, ossimplugins::ErsSarFileDescriptor::_l_map_proj, ossimplugins::ErsSarFileDescriptor::_l_plat_pos, ossimplugins::ErsSarFileDescriptor::_l_qual_sum, ossimplugins::ErsSarFileDescriptor::_l_radar_par, ossimplugins::ErsSarFileDescriptor::_l_radi_comp, ossimplugins::ErsSarFileDescriptor::_l_radi_data, ossimplugins::ErsSarFileDescriptor::_l_rang_spec, ossimplugins::ErsSarFileDescriptor::_n_anno_data, ossimplugins::ErsSarFileDescriptor::_n_att_data, ossimplugins::ErsSarFileDescriptor::_n_cal, ossimplugins::ErsSarFileDescriptor::_n_data_his, ossimplugins::ErsSarFileDescriptor::_n_dataset, ossimplugins::ErsSarFileDescriptor::_n_dem_desc, ossimplugins::ErsSarFileDescriptor::_n_det_proc, ossimplugins::ErsSarFileDescriptor::_n_fac_data, ossimplugins::ErsSarFileDescriptor::_n_gcp, ossimplugins::ErsSarFileDescriptor::_n_map_proj, ossimplugins::ErsSarFileDescriptor::_n_plat_pos, ossimplugins::ErsSarFileDescriptor::_n_qual_sum, ossimplugins::ErsSarFileDescriptor::_n_radar_par, ossimplugins::ErsSarFileDescriptor::_n_radi_comp, ossimplugins::ErsSarFileDescriptor::_n_radi_data, ossimplugins::ErsSarFileDescriptor::_n_rang_spec, ossimplugins::ErsSarFileDescriptor::_rec_code, ossimplugins::ErsSarFileDescriptor::_rec_len, ossimplugins::ErsSarFileDescriptor::_rec_seq, ossimplugins::ErsSarFileDescriptor::_rlen_len, ossimplugins::ErsSarFileDescriptor::_rlen_loc, ossimplugins::ErsSarFileDescriptor::_seq_len, ossimplugins::ErsSarFileDescriptor::_seq_loc, and ossimplugins::ErsSarFileDescriptor::_software_id.
27 {
28  os << "ascii_flag:" << data._ascii_flag.c_str() << std::endl;
29  os << "format_doc:" << data._format_doc.c_str() << std::endl;
30  os << "format_ver:" << data._format_ver.c_str() << std::endl;
31  os << "design_rev:" << data._design_rev.c_str() << std::endl;
32  os << "software_id:" << data._software_id.c_str() << std::endl;
33  os << "file_num:" << data._file_num << std::endl;
34  os << "file_name:" << data._file_name.c_str() << std::endl;
35  os << "rec_seq:" << data._rec_seq.c_str() << std::endl;
36  os << "seq_loc:" << data._seq_loc << std::endl;
37  os << "seq_len:" << data._seq_len << std::endl;
38  os << "rec_code:" << data._rec_code.c_str() << std::endl;
39  os << "code_loc:" << data._code_loc << std::endl;
40  os << "code_len:" << data._code_len << std::endl;
41  os << "rec_len:" << data._rec_len.c_str() << std::endl;
42  os << "rlen_loc:" << data._rlen_loc << std::endl;
43  os << "rlen_len:" << data._rlen_len << std::endl;
44  os << "n_dataset:" << data._n_dataset << std::endl;
45  os << "l_dataset:" << data._l_dataset << std::endl;
46  os << "n_map_proj:" << data._n_map_proj << std::endl;
47  os << "l_map_proj:" << data._l_map_proj << std::endl;
48  os << "n_plat_pos:" << data._n_plat_pos << std::endl;
49  os << "l_plat_pos:" << data._l_plat_pos << std::endl;
50  os << "n_att_data:" << data._n_att_data << std::endl;
51  os << "l_att_data:" << data._l_att_data << std::endl;
52  os << "n_radi_data:" << data._n_radi_data << std::endl;
53  os << "l_radi_data:" << data._l_radi_data << std::endl;
54  os << "n_radi_comp:" << data._n_radi_comp << std::endl;
55  os << "l_radi_comp:" << data._l_radi_comp << std::endl;
56  os << "n_qual_sum:" << data._n_qual_sum << std::endl;
57  os << "l_qual_sum:" << data._l_qual_sum << std::endl;
58  os << "n_data_his:" << data._n_data_his << std::endl;
59  os << "l_data_his:" << data._l_data_his << std::endl;
60  os << "n_rang_spec:" << data._n_rang_spec << std::endl;
61  os << "l_rang_spec:" << data._l_rang_spec << std::endl;
62  os << "n_dem_desc:" << data._n_dem_desc << std::endl;
63  os << "l_dem_desc:" << data._l_dem_desc << std::endl;
64  os << "n_radar_par:" << data._n_radar_par << std::endl;
65  os << "l_radar_par:" << data._l_radar_par << std::endl;
66  os << "n_anno_data:" << data._n_anno_data << std::endl;
67  os << "l_anno_data:" << data._l_anno_data << std::endl;
68  os << "n_det_proc:" << data._n_det_proc << std::endl;
69  os << "l_det_proc:" << data._l_det_proc << std::endl;
70  os << "n_cal:" << data._n_cal << std::endl;
71  os << "l_cal:" << data._l_cal << std::endl;
72  os << "n_gcp:" << data._n_gcp << std::endl;
73  os << "l_gcp:" << data._l_gcp << std::endl;
74  os << "n_fac_data:" << data._n_fac_data << std::endl;
75  os << "l_fac_data:" << data._l_fac_data << std::endl;
76  return os;
77 }
◆ operator<<() [41/63]
const AlosPalsarFacilityData data
Definition at line 26 of file AlosPalsarFacilityData.cpp.
References ossimplugins::AlosPalsarFacilityData::_3_dB_look_bandwidth, ossimplugins::AlosPalsarFacilityData::_3_dB_look_proc_dopp_bandw, ossimplugins::AlosPalsarFacilityData::_3_dB_width_CCF, ossimplugins::AlosPalsarFacilityData::_abs_cal_const_K, ossimplugins::AlosPalsarFacilityData::_antenna_elev_flag, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_X_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Y_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Z_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_X_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Y_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Z_comp, ossimplugins::AlosPalsarFacilityData::_autom_look_scal_gain_flag, ossimplugins::AlosPalsarFacilityData::_azimuth_baseband_convers_flag, ossimplugins::AlosPalsarFacilityData::_azimuth_FFT_IFFT_ratio, ossimplugins::AlosPalsarFacilityData::_cal_gain_change_flag, ossimplugins::AlosPalsarFacilityData::_cal_gain_changes, ossimplugins::AlosPalsarFacilityData::_cal_sys_gain, ossimplugins::AlosPalsarFacilityData::_cal_syst_gain_last_proc, ossimplugins::AlosPalsarFacilityData::_center_range_pix_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_1, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_2, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_3, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_4, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_5, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_1, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_2, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_3, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_4, ossimplugins::AlosPalsarFacilityData::_datation_flag, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas_flag, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_num, ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas, ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas_flag, ossimplugins::AlosPalsarFacilityData::_dopp_cent_val_flag, ossimplugins::AlosPalsarFacilityData::_doppler_ambiguity_estimat_flag, ossimplugins::AlosPalsarFacilityData::_doppler_centroid_cubic_coeff, ossimplugins::AlosPalsarFacilityData::_estim_bit_error_rate, ossimplugins::AlosPalsarFacilityData::_first_processed_range_sample, ossimplugins::AlosPalsarFacilityData::_first_range_pixel_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_first_rec_gain_read, ossimplugins::AlosPalsarFacilityData::_first_replica_sample, ossimplugins::AlosPalsarFacilityData::_first_side_lobe_lev_of_ACF, ossimplugins::AlosPalsarFacilityData::_first_side_lobe_level, ossimplugins::AlosPalsarFacilityData::_form_num_range_line_used, ossimplugins::AlosPalsarFacilityData::_I_channel_bias_correction, ossimplugins::AlosPalsarFacilityData::_I_channel_gain_correction, ossimplugins::AlosPalsarFacilityData::_I_gain_imb_lower_bound, ossimplugins::AlosPalsarFacilityData::_I_gain_imb_upper_bound, ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_lower_bound, ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_upper_bound, ossimplugins::AlosPalsarFacilityData::_initial_doppler_ambiguity_num, ossimplugins::AlosPalsarFacilityData::_inp_data_I_mean, ossimplugins::AlosPalsarFacilityData::_inp_data_I_stddev, ossimplugins::AlosPalsarFacilityData::_inp_data_Q_mean, ossimplugins::AlosPalsarFacilityData::_inp_data_Q_stddev, ossimplugins::AlosPalsarFacilityData::_inp_data_stat_flag, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_X_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Y_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Z_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vx_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vy_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vz_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vector_type_flag, ossimplugins::AlosPalsarFacilityData::_int_cal_utc, ossimplugins::AlosPalsarFacilityData::_ISLR_CCF_between_last, ossimplugins::AlosPalsarFacilityData::_ISLR_of_ACF, ossimplugins::AlosPalsarFacilityData::_K_gen_date, ossimplugins::AlosPalsarFacilityData::_K_vers_num, ossimplugins::AlosPalsarFacilityData::_last_range_pix_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_last_release_cal_date, ossimplugins::AlosPalsarFacilityData::_last_release_qc_date, ossimplugins::AlosPalsarFacilityData::_look_detecion_flag, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_1, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_2, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_3, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_4, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_5, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_6, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_7, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_8, ossimplugins::AlosPalsarFacilityData::_low_bound_K, ossimplugins::AlosPalsarFacilityData::_max_error_range_line_timing, ossimplugins::AlosPalsarFacilityData::_max_value_look_scalar_gain, ossimplugins::AlosPalsarFacilityData::_mean_cal_pulse_power, ossimplugins::AlosPalsarFacilityData::_mean_noise_power, ossimplugins::AlosPalsarFacilityData::_missing_lines, ossimplugins::AlosPalsarFacilityData::_noise_power, ossimplugins::AlosPalsarFacilityData::_norm_ref_range_ro, ossimplugins::AlosPalsarFacilityData::_num_azimuth_blocks_proc, ossimplugins::AlosPalsarFacilityData::_num_duplic_input_lines, ossimplugins::AlosPalsarFacilityData::_num_input_raw_data_lines, ossimplugins::AlosPalsarFacilityData::_num_range_samp_discarded, ossimplugins::AlosPalsarFacilityData::_num_valid_cal_pulses, ossimplugins::AlosPalsarFacilityData::_num_valid_noise_pulses, ossimplugins::AlosPalsarFacilityData::_num_valid_pixels_per_range, ossimplugins::AlosPalsarFacilityData::_num_valid_replicas, ossimplugins::AlosPalsarFacilityData::_OGOB_flag, ossimplugins::AlosPalsarFacilityData::_out_image_max_value, ossimplugins::AlosPalsarFacilityData::_out_image_mean, ossimplugins::AlosPalsarFacilityData::_out_image_std_dev, ossimplugins::AlosPalsarFacilityData::_out_pixel_bit_length, ossimplugins::AlosPalsarFacilityData::_outp_data_mean_flag, ossimplugins::AlosPalsarFacilityData::_peak_loc_CCF_betw_last, ossimplugins::AlosPalsarFacilityData::_peak_loc_cross_correl_fun, ossimplugins::AlosPalsarFacilityData::_PRF_changes, ossimplugins::AlosPalsarFacilityData::_prf_code_change_flag, ossimplugins::AlosPalsarFacilityData::_PRF_code_first_range_line, ossimplugins::AlosPalsarFacilityData::_PRF_code_last_range_line, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_1, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_2, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_3, ossimplugins::AlosPalsarFacilityData::_proc_noise_scale_fact, ossimplugins::AlosPalsarFacilityData::_pulse_width_of_ACF_3db, ossimplugins::AlosPalsarFacilityData::_Q_channel_bias_correction, ossimplugins::AlosPalsarFacilityData::_Q_channel_gain_correction, ossimplugins::AlosPalsarFacilityData::_Q_channel_I_Q_correction, ossimplugins::AlosPalsarFacilityData::_qa_summary_flag, ossimplugins::AlosPalsarFacilityData::_quirp_qu_flag, ossimplugins::AlosPalsarFacilityData::_range_comp_norm_fact, ossimplugins::AlosPalsarFacilityData::_range_lines_skip_factor, ossimplugins::AlosPalsarFacilityData::_range_spread_loss_comp_flag, ossimplugins::AlosPalsarFacilityData::_range_time_origin_ant, ossimplugins::AlosPalsarFacilityData::_raw_data_correction_flag, ossimplugins::AlosPalsarFacilityData::_rec_gain_changes, ossimplugins::AlosPalsarFacilityData::_receiver_gain_last_proc, ossimplugins::AlosPalsarFacilityData::_replica_norm_method_flag, ossimplugins::AlosPalsarFacilityData::_replica_power, ossimplugins::AlosPalsarFacilityData::_Roll_Tilt_Mode_flag, ossimplugins::AlosPalsarFacilityData::_samp_win_start_first, ossimplugins::AlosPalsarFacilityData::_samp_win_start_last, ossimplugins::AlosPalsarFacilityData::_samp_window_start_time_bias, ossimplugins::AlosPalsarFacilityData::_samples_per_line_used, ossimplugins::AlosPalsarFacilityData::_sampling_win_change_flag, ossimplugins::AlosPalsarFacilityData::_sampling_win_changes, ossimplugins::AlosPalsarFacilityData::_sat_binary_time_of_first, ossimplugins::AlosPalsarFacilityData::_thresh_no_10_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_11_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_1_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_2_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_3_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_4_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_5_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_6_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_7_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_8_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_9_flag, ossimplugins::AlosPalsarFacilityData::_time_asc_node_state_vectors, ossimplugins::AlosPalsarFacilityData::_time_of_inp_state_vectors, ossimplugins::AlosPalsarFacilityData::_time_raw_data_first_input, ossimplugins::AlosPalsarFacilityData::_update_period_range_match, ossimplugins::AlosPalsarFacilityData::_upp_bound_K, ossimplugins::AlosPalsarFacilityData::_win_coeff_for_azi_match, and ossimplugins::AlosPalsarFacilityData::_win_coeff_for_range_match.
27  {
28  os << "last_release_qc_date:" << data._last_release_qc_date.c_str() << std::endl;
29
30  os << "last_release_cal_date:" << data._last_release_cal_date.c_str() << std::endl;
31
32  os << "qa_summary_flag:" << data._qa_summary_flag << std::endl;
33
34  os << "prf_code_change_flag:" << data._prf_code_change_flag << std::endl;
35
36  os << "sampling_win_change_flag:" << data._sampling_win_change_flag << std::endl;
37
38  os << "cal_gain_change_flag:" << data._cal_gain_change_flag << std::endl;
39
40  os << "quirp_qu_flag:" << data._quirp_qu_flag << std::endl;
41
42  os << "inp_data_stat_flag:" << data._inp_data_stat_flag << std::endl;
43
44  os << "dopp_cent_conf_meas_flag:" << data._dopp_cent_conf_meas_flag << std::endl;
45
46  os << "dopp_cent_val_flag:" << data._dopp_cent_val_flag << std::endl;
47
48  os << "dopp_ambig_conf_meas_flag:" << data._dopp_ambig_conf_meas_flag << std::endl;
49
50  os << "outp_data_mean_flag:" << data._outp_data_mean_flag << std::endl;
51
52  os << "OGOB_flag:" << data._OGOB_flag << std::endl;
53
54  os << "PRF_changes:" << data._PRF_changes << std::endl;
55
56  os << "sampling_win_changes:" << data._sampling_win_changes << std::endl;
57
58  os << "cal_gain_changes:" << data._cal_gain_changes << std::endl;
59
60  os << "missing_lines:" << data._missing_lines << std::endl;
61
62  os << "rec_gain_changes:" << data._rec_gain_changes << std::endl;
63
64  os << "pulse_width_of_ACF_3db:" << data._pulse_width_of_ACF_3db << std::endl;
65
66  os << "first_side_lobe_lev_of_ACF:" << data._first_side_lobe_lev_of_ACF << std::endl;
67
68  os << "ISLR_of_ACF:" << data._ISLR_of_ACF << std::endl;
69
70  os << "dopp_cent_conf_meas:" << data._dopp_cent_conf_meas << std::endl;
71
72  os << "dopp_ambig_conf_meas:" << data._dopp_ambig_conf_meas << std::endl;
73
74  os << "inp_data_I_mean:" << data._inp_data_I_mean << std::endl;
75
76  os << "inp_data_Q_mean:" << data._inp_data_Q_mean << std::endl;
77
78  os << "inp_data_I_stddev:" << data._inp_data_I_stddev << std::endl;
79
80  os << "inp_data_Q_stddev:" << data._inp_data_Q_stddev << std::endl;
81
82  os << "cal_sys_gain:" << data._cal_sys_gain << std::endl;
83
84  os << "first_rec_gain_read:" << data._first_rec_gain_read << std::endl;
85
86  os << "dopp_ambig_num:" << data._dopp_ambig_num << std::endl;
87
88  os << "I_channel_bias_correction:" << data._I_channel_bias_correction << std::endl;
89
90  os << "Q_channel_bias_correction:" << data._Q_channel_bias_correction << std::endl;
91
92  os << "I_channel_gain_correction:" << data._I_channel_gain_correction << std::endl;
93
94  os << "Q_channel_gain_correction:" << data._Q_channel_gain_correction << std::endl;
95
96  os << "Q_channel_I_Q_correction:" << data._Q_channel_I_Q_correction << std::endl;
97
98  os << "noise_power:" << data._noise_power << std::endl;
99
100  os << "int_cal_utc:" << data._int_cal_utc << std::endl;
101
102  os << "num_valid_cal_pulses:" << data._num_valid_cal_pulses << std::endl;
103
104  os << "num_valid_noise_pulses:" << data._num_valid_noise_pulses << std::endl;
105
106  os << "num_valid_replicas:" << data._num_valid_replicas << std::endl;
107
108  os << "first_replica_sample:" << data._first_replica_sample << std::endl;
109
110  os << "mean_cal_pulse_power:" << data._mean_cal_pulse_power << std::endl;
111
112  os << "mean_noise_power:" << data._mean_noise_power << std::endl;
113
114  os << "range_comp_norm_fact:" << data._range_comp_norm_fact << std::endl;
115
116  os << "replica_power:" << data._replica_power << std::endl;
117
118  os << "first_range_pixel_mid_az_inc:" << data._first_range_pixel_mid_az_inc << std::endl;
119
120  os << "center_range_pix_mid_az_inc:" << data._center_range_pix_mid_az_inc << std::endl;
121
122  os << "last_range_pix_mid_az_inc:" << data._last_range_pix_mid_az_inc << std::endl;
123
124  os << "norm_ref_range_ro:" << data._norm_ref_range_ro << std::endl;
125
126  os << "antenna_elev_flag:" << data._antenna_elev_flag << std::endl;
127
128  os << "abs_cal_const_K:" << data._abs_cal_const_K << std::endl;
129
130  os << "upp_bound_K:" << data._upp_bound_K << std::endl;
131
132  os << "low_bound_K:" << data._low_bound_K << std::endl;
133
134  os << "proc_noise_scale_fact:" << data._proc_noise_scale_fact << std::endl;
135
136  os << "K_gen_date:" << data._K_gen_date.c_str() << std::endl;
137
138  os << "K_vers_num:" << data._K_vers_num.c_str() << std::endl;
139
140  os << "num_duplic_input_lines:" << data._num_duplic_input_lines << std::endl;
141
142  os << "estim_bit_error_rate:" << data._estim_bit_error_rate << std::endl;
143
144  os << "out_image_mean:" << data._out_image_mean << std::endl;
145
146  os << "out_image_std_dev:" << data._out_image_std_dev << std::endl;
147
148  os << "out_image_max_value:" << data._out_image_max_value << std::endl;
149
150  os << "time_raw_data_first_input:" << data._time_raw_data_first_input.c_str() << std::endl;
151
152  os << "time_asc_node_state_vectors:" << data._time_asc_node_state_vectors.c_str() << std::endl;
153
154  os << "asc_node_pos_X_comp:" << data._asc_node_pos_X_comp.c_str() << std::endl;
155
156  os << "asc_node_pos_Y_comp:" << data._asc_node_pos_Y_comp.c_str() << std::endl;
157
158  os << "asc_node_pos_Z_comp:" << data._asc_node_pos_Z_comp.c_str() << std::endl;
159
160  os << "asc_node_vel_X_comp:" << data._asc_node_vel_X_comp.c_str() << std::endl;
161
162  os << "asc_node_vel_Y_comp:" << data._asc_node_vel_Y_comp.c_str() << std::endl;
163
164  os << "asc_node_vel_Z_comp:" << data._asc_node_vel_Z_comp.c_str() << std::endl;
165
166  os << "out_pixel_bit_length:" << data._out_pixel_bit_length << std::endl;
167
168  os << "proc_gain_param_1:" << data._proc_gain_param_1 << std::endl;
169
170  os << "proc_gain_param_2:" << data._proc_gain_param_2 << std::endl;
171
172  os << "proc_gain_param_3:" << data._proc_gain_param_3 << std::endl;
173
174  os << "peak_loc_cross_correl_fun:" << data._peak_loc_cross_correl_fun << std::endl;
175
176  os << "3_dB_width_CCF:" << data._3_dB_width_CCF << std::endl;
177
178  os << "first_side_lobe_level:" << data._first_side_lobe_level << std::endl;
179
180  os << "ISLR_CCF_between_last:" << data._ISLR_CCF_between_last << std::endl;
181
182  os << "peak_loc_CCF_betw_last:" << data._peak_loc_CCF_betw_last << std::endl;
183
184  os << "Roll_Tilt_Mode_flag:" << data._Roll_Tilt_Mode_flag << std::endl;
185
186  os << "raw_data_correction_flag:" << data._raw_data_correction_flag << std::endl;
187
188  os << "look_detecion_flag:" << data._look_detecion_flag << std::endl;
189
190  os << "doppler_ambiguity_estimat_flag:" << data._doppler_ambiguity_estimat_flag << std::endl;
191
192  os << "azimuth_baseband_convers_flag:" << data._azimuth_baseband_convers_flag << std::endl;
193
194  os << "samples_per_line_used:" << data._samples_per_line_used << std::endl;
195
196  os << "range_lines_skip_factor:" << data._range_lines_skip_factor << std::endl;
197
198  os << "time_of_inp_state_vectors:" << data._time_of_inp_state_vectors.c_str() << std::endl;
199
200  os << "inp_state_vect_pos_X_comp:" << data._inp_state_vect_pos_X_comp.c_str() << std::endl;
201
202  os << "inp_state_vect_pos_Y_comp:" << data._inp_state_vect_pos_Y_comp.c_str() << std::endl;
203
204  os << "inp_state_vect_pos_Z_comp:" << data._inp_state_vect_pos_Z_comp.c_str() << std::endl;
205
206  os << "inp_state_vect_vel_Vx_comp:" << data._inp_state_vect_vel_Vx_comp.c_str() << std::endl;
207
208  os << "inp_state_vect_vel_Vy_comp:" << data._inp_state_vect_vel_Vy_comp.c_str() << std::endl;
209
210  os << "inp_state_vect_vel_Vz_comp:" << data._inp_state_vect_vel_Vz_comp.c_str() << std::endl;
211
212  os << "inp_state_vector_type_flag:" << data._inp_state_vector_type_flag << std::endl;
213
214  os << "win_coeff_for_range_match:" << data._win_coeff_for_range_match << std::endl;
215
216  os << "win_coeff_for_azi_match:" << data._win_coeff_for_azi_match << std::endl;
217
218  os << "update_period_range_match:" << data._update_period_range_match << std::endl;
219
220  os << "look_scalar_gain_1:" << data._look_scalar_gain_1 << std::endl;
221
222  os << "look_scalar_gain_2:" << data._look_scalar_gain_2 << std::endl;
223
224  os << "look_scalar_gain_3:" << data._look_scalar_gain_3 << std::endl;
225
226  os << "look_scalar_gain_4:" << data._look_scalar_gain_4 << std::endl;
227
228  os << "look_scalar_gain_5:" << data._look_scalar_gain_5 << std::endl;
229
230  os << "look_scalar_gain_6:" << data._look_scalar_gain_6 << std::endl;
231
232  os << "look_scalar_gain_7:" << data._look_scalar_gain_7 << std::endl;
233
234  os << "look_scalar_gain_8:" << data._look_scalar_gain_8 << std::endl;
235
236  os << "samp_window_start_time_bias:" << data._samp_window_start_time_bias << std::endl;
237
238  os << "doppler_centroid_cubic_coeff:" << data._doppler_centroid_cubic_coeff << std::endl;
239
240  os << "PRF_code_first_range_line:" << data._PRF_code_first_range_line << std::endl;
241
242  os << "PRF_code_last_range_line:" << data._PRF_code_last_range_line << std::endl;
243
244  os << "samp_win_start_first:" << data._samp_win_start_first << std::endl;
245
246  os << "samp_win_start_last:" << data._samp_win_start_last << std::endl;
247
248  os << "cal_syst_gain_last_proc:" << data._cal_syst_gain_last_proc << std::endl;
249
250  os << "receiver_gain_last_proc:" << data._receiver_gain_last_proc << std::endl;
251
252  os << "first_processed_range_sample:" << data._first_processed_range_sample << std::endl;
253
254  os << "azimuth_FFT_IFFT_ratio:" << data._azimuth_FFT_IFFT_ratio << std::endl;
255
256  os << "num_azimuth_blocks_proc:" << data._num_azimuth_blocks_proc << std::endl;
257
258  os << "num_input_raw_data_lines:" << data._num_input_raw_data_lines << std::endl;
259
260  os << "initial_doppler_ambiguity_num:" << data._initial_doppler_ambiguity_num << std::endl;
261
262  os << "thresh_no_1_flag:" << data._thresh_no_1_flag << std::endl;
263
264  os << "thresh_no_2_flag:" << data._thresh_no_2_flag << std::endl;
265
266  os << "thresh_no_3_flag:" << data._thresh_no_3_flag << std::endl;
267
268  os << "thresh_no_4_flag:" << data._thresh_no_4_flag << std::endl;
269
270  os << "thresh_no_5_flag:" << data._thresh_no_5_flag << std::endl;
271
272  os << "thresh_no_6_flag:" << data._thresh_no_6_flag << std::endl;
273
274  os << "thresh_no_7_flag:" << data._thresh_no_7_flag << std::endl;
275
276  os << "thresh_no_8_flag:" << data._thresh_no_8_flag << std::endl;
277
278  os << "thresh_no_9_flag:" << data._thresh_no_9_flag << std::endl;
279
280  os << "thresh_no_10_flag:" << data._thresh_no_10_flag << std::endl;
281
282  os << "thresh_no_11_flag:" << data._thresh_no_11_flag << std::endl;
283
284  os << "sat_binary_time_of_first:" << data._sat_binary_time_of_first << std::endl;
285
286  os << "num_valid_pixels_per_range:" << data._num_valid_pixels_per_range << std::endl;
287
288  os << "num_range_samp_discarded:" << data._num_range_samp_discarded << std::endl;
289
290  os << "I_gain_imb_lower_bound:" << data._I_gain_imb_lower_bound << std::endl;
291
292  os << "I_gain_imb_upper_bound:" << data._I_gain_imb_upper_bound << std::endl;
293
294  os << "I_Q_quad_depar_lower_bound:" << data._I_Q_quad_depar_lower_bound << std::endl;
295
296  os << "I_Q_quad_depar_upper_bound:" << data._I_Q_quad_depar_upper_bound << std::endl;
297
298  os << "3_dB_look_bandwidth:" << data._3_dB_look_bandwidth << std::endl;
299
300  os << "3_dB_look_proc_dopp_bandw:" << data._3_dB_look_proc_dopp_bandw << std::endl;
301
302  os << "range_spread_loss_comp_flag:" << data._range_spread_loss_comp_flag << std::endl;
303
304  os << "datation_flag:" << data._datation_flag << std::endl;
305
306  os << "max_error_range_line_timing:" << data._max_error_range_line_timing << std::endl;
307
308  os << "form_num_range_line_used:" << data._form_num_range_line_used << std::endl;
309
310  os << "autom_look_scal_gain_flag:" << data._autom_look_scal_gain_flag << std::endl;
311
312  os << "max_value_look_scalar_gain:" << data._max_value_look_scalar_gain << std::endl;
313
314  os << "replica_norm_method_flag:" << data._replica_norm_method_flag << std::endl;
315
316  os << "coef_ground_range_1:" << data._coef_ground_range_1 << std::endl;
317
318  os << "coef_ground_range_2:" << data._coef_ground_range_2 << std::endl;
319
320  os << "coef_ground_range_3:" << data._coef_ground_range_3 << std::endl;
321
322  os << "coef_ground_range_4:" << data._coef_ground_range_4 << std::endl;
323
324  os << "coef_ant_elev_1:" << data._coef_ant_elev_1 << std::endl;
325
326  os << "coef_ant_elev_2:" << data._coef_ant_elev_2 << std::endl;
327
328  os << "coef_ant_elev_3:" << data._coef_ant_elev_3 << std::endl;
329
330  os << "coef_ant_elev_4:" << data._coef_ant_elev_4 << std::endl;
331
332  os << "coef_ant_elev_5:" << data._coef_ant_elev_5 << std::endl;
333
334  os << "range_time_origin_ant:" << data._range_time_origin_ant << std::endl;
335
336  return os;
337
338  }
◆ operator<<() [42/63]
const ErsSarPlatformPositionData data
Definition at line 26 of file ErsSarPlatformPositionData.cpp.
References ossimplugins::ErsSarPlatformPositionData::_alt_poserr, ossimplugins::ErsSarPlatformPositionData::_alt_velerr, ossimplugins::ErsSarPlatformPositionData::_crt_poserr, ossimplugins::ErsSarPlatformPositionData::_crt_velerr, ossimplugins::ErsSarPlatformPositionData::_data_int, ossimplugins::ErsSarPlatformPositionData::_day, ossimplugins::ErsSarPlatformPositionData::_gmt_day, ossimplugins::ErsSarPlatformPositionData::_gmt_sec, ossimplugins::ErsSarPlatformPositionData::_hr_angle, ossimplugins::ErsSarPlatformPositionData::_month, ossimplugins::ErsSarPlatformPositionData::_ndata, ossimplugins::ErsSarPlatformPositionData::_orbit_ele, ossimplugins::ErsSarPlatformPositionData::_orbit_ele_desg, ossimplugins::ErsSarPlatformPositionData::_pos_vect, ossimplugins::ErsSarPlatformPositionData::_rad_poserr, ossimplugins::ErsSarPlatformPositionData::_rad_velerr, ossimplugins::ErsSarPlatformPositionData::_ref_coord, and ossimplugins::ErsSarPlatformPositionData::_year.
27 {
28  os << "orbit_ele_desg:" << data._orbit_ele_desg.c_str() << std::endl;
29
30  for (int i = 0; i < 6; i++)
31  {
32  os << "orbit_ele[" << i << "]:" << data._orbit_ele[i] << std::endl;
33  }
34
35  os << "ndata:" << data._ndata << std::endl;
36
37  os << "year:" << data._year << std::endl;
38
39  os << "month:" << data._month << std::endl;
40
41  os << "day:" << data._day << std::endl;
42
43  os << "gmt_day:" << data._gmt_day << std::endl;
44
45  os << "gmt_sec:" << data._gmt_sec << std::endl;
46
47  os << "data_int:" << data._data_int << std::endl;
48
49  os << "ref_coord:" << data._ref_coord.c_str() << std::endl;
50
51  os << "hr_angle:" << data._hr_angle << std::endl;
52
53  os << "alt_poserr:" << data._alt_poserr << std::endl;
54
55  os << "crt_poserr:" << data._crt_poserr << std::endl;
56
57  os << "rad_poserr:" << data._rad_poserr << std::endl;
58
59  os << "alt_velerr:" << data._alt_velerr << std::endl;
60
61  os << "crt_velerr:" << data._crt_velerr << std::endl;
62
63  os << "rad_velerr:" << data._rad_velerr << std::endl;
64
65  for (int i = 0; i < 64; i++)
66  {
67  os << "pos_vect[" << i << "]:" << data._pos_vect[i] << std::endl;
68  }
69
70  return os;
71 }
◆ operator<<() [43/63]
const ErsSarPositionVectorRecord data
Definition at line 26 of file ErsSarPositionVectorRecord.cpp.
References ossimplugins::ErsSarPositionVectorRecord::_pos, and ossimplugins::ErsSarPositionVectorRecord::_vel.
27 {
28  for (int i = 0; i < 3; i++)
29  {
30  os << "pos[" << i << "]:" << data._pos[i] << std::endl;
31  }
32
33  for (int i = 0; i < 3; i++)
34  {
35  os << "vel[" << i << "]:" << data._vel[i] << std::endl;
36  }
37  return os;
38 }
◆ operator<<() [44/63]
const ErsSarRecordHeader data
Definition at line 26 of file ErsSarRecordHeader.cpp.
References ossimplugins::ErsSarRecordHeader::_length, ossimplugins::ErsSarRecordHeader::_rec_seq, ossimplugins::ErsSarRecordHeader::_rec_sub1, ossimplugins::ErsSarRecordHeader::_rec_sub2, ossimplugins::ErsSarRecordHeader::_rec_sub3, and ossimplugins::ErsSarRecordHeader::_rec_type.
27 {
28  os << "record_sequence_number:" << data._rec_seq << std::endl;
29  os << "first_record_sub-type:" << (int)data._rec_sub1 << std::endl;
30  os << "record_type_code:" << (int)data._rec_type << std::endl;
31  os << "second_record_sub-type:" << (int)data._rec_sub2 << std::endl;
32  os << "third_record_sub-type:" << (int)data._rec_sub3 << std::endl;
33  os << "length:" << data._length << std::endl;
34  return os;
35 }
◆ operator<<() [45/63]
const AlosPalsarFileDescriptor data
Definition at line 27 of file AlosPalsarFileDescriptor.cpp.
References ossimplugins::AlosPalsarFileDescriptor::_ascii_flag, ossimplugins::AlosPalsarFileDescriptor::_code_len, ossimplugins::AlosPalsarFileDescriptor::_code_loc, ossimplugins::AlosPalsarFileDescriptor::_continuation_flag, ossimplugins::AlosPalsarFileDescriptor::_design_rev, ossimplugins::AlosPalsarFileDescriptor::_file_name, ossimplugins::AlosPalsarFileDescriptor::_file_num, ossimplugins::AlosPalsarFileDescriptor::_format_doc, ossimplugins::AlosPalsarFileDescriptor::_format_ver, ossimplugins::AlosPalsarFileDescriptor::_l_anno_data, ossimplugins::AlosPalsarFileDescriptor::_l_att_data, ossimplugins::AlosPalsarFileDescriptor::_l_cal, ossimplugins::AlosPalsarFileDescriptor::_l_data_his, ossimplugins::AlosPalsarFileDescriptor::_l_dataset, ossimplugins::AlosPalsarFileDescriptor::_l_dem_desc, ossimplugins::AlosPalsarFileDescriptor::_l_det_proc, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data10, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data11, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data2, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data3, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data4, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data5, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data6, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data7, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data8, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data9, ossimplugins::AlosPalsarFileDescriptor::_l_gcp, ossimplugins::AlosPalsarFileDescriptor::_l_map_proj, ossimplugins::AlosPalsarFileDescriptor::_l_plat_pos, ossimplugins::AlosPalsarFileDescriptor::_l_qual_sum, ossimplugins::AlosPalsarFileDescriptor::_l_radar_par, ossimplugins::AlosPalsarFileDescriptor::_l_radi_comp, ossimplugins::AlosPalsarFileDescriptor::_l_radi_data, ossimplugins::AlosPalsarFileDescriptor::_l_rang_spec, ossimplugins::AlosPalsarFileDescriptor::_n_anno_data, ossimplugins::AlosPalsarFileDescriptor::_n_att_data, ossimplugins::AlosPalsarFileDescriptor::_n_cal, ossimplugins::AlosPalsarFileDescriptor::_n_data_his, ossimplugins::AlosPalsarFileDescriptor::_n_dataset, ossimplugins::AlosPalsarFileDescriptor::_n_dem_desc, ossimplugins::AlosPalsarFileDescriptor::_n_det_proc, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data10, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data11, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data2, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data3, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data4, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data5, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data6, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data7, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data8, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data9, ossimplugins::AlosPalsarFileDescriptor::_n_gcp, ossimplugins::AlosPalsarFileDescriptor::_n_map_proj, ossimplugins::AlosPalsarFileDescriptor::_n_plat_pos, ossimplugins::AlosPalsarFileDescriptor::_n_qual_sum, ossimplugins::AlosPalsarFileDescriptor::_n_radar_par, ossimplugins::AlosPalsarFileDescriptor::_n_radi_comp, ossimplugins::AlosPalsarFileDescriptor::_n_radi_data, ossimplugins::AlosPalsarFileDescriptor::_n_rang_spec, ossimplugins::AlosPalsarFileDescriptor::_rec_code, ossimplugins::AlosPalsarFileDescriptor::_rec_len, ossimplugins::AlosPalsarFileDescriptor::_rec_seq, ossimplugins::AlosPalsarFileDescriptor::_rlen_len, ossimplugins::AlosPalsarFileDescriptor::_rlen_loc, ossimplugins::AlosPalsarFileDescriptor::_seq_len, ossimplugins::AlosPalsarFileDescriptor::_seq_loc, and ossimplugins::AlosPalsarFileDescriptor::_software_id.
28 {
29  os << "ascii_flag:" << data._ascii_flag.c_str() << std::endl;
30  os << "continuation_flag:" << data._continuation_flag.c_str() << std::endl;
31  os << "format_doc:" << data._format_doc.c_str() << std::endl;
32  os << "format_ver:" << data._format_ver.c_str() << std::endl;
33  os << "design_rev:" << data._design_rev.c_str() << std::endl;
34  os << "software_id:" << data._software_id.c_str() << std::endl;
35  os << "file_num:" << data._file_num << std::endl;
36  os << "file_name:" << data._file_name.c_str() << std::endl;
37  os << "rec_seq:" << data._rec_seq.c_str() << std::endl;
38  os << "seq_loc:" << data._seq_loc << std::endl;
39  os << "seq_len:" << data._seq_len << std::endl;
40  os << "rec_code:" << data._rec_code.c_str() << std::endl;
41  os << "code_loc:" << data._code_loc << std::endl;
42  os << "code_len:" << data._code_len << std::endl;
43  os << "rec_len:" << data._rec_len.c_str() << std::endl;
44  os << "rlen_loc:" << data._rlen_loc << std::endl;
45  os << "rlen_len:" << data._rlen_len << std::endl;
46  os << "n_dataset:" << data._n_dataset << std::endl;
47  os << "l_dataset:" << data._l_dataset << std::endl;
48  os << "n_map_proj:" << data._n_map_proj << std::endl;
49  os << "l_map_proj:" << data._l_map_proj << std::endl;
50  os << "n_plat_pos:" << data._n_plat_pos << std::endl;
51  os << "l_plat_pos:" << data._l_plat_pos << std::endl;
52  os << "n_att_data:" << data._n_att_data << std::endl;
53  os << "l_att_data:" << data._l_att_data << std::endl;
54  os << "n_radi_data:" << data._n_radi_data << std::endl;
55  os << "l_radi_data:" << data._l_radi_data << std::endl;
56  os << "n_radi_comp:" << data._n_radi_comp << std::endl;
57  os << "l_radi_comp:" << data._l_radi_comp << std::endl;
58  os << "n_qual_sum:" << data._n_qual_sum << std::endl;
59  os << "l_qual_sum:" << data._l_qual_sum << std::endl;
60  os << "n_data_his:" << data._n_data_his << std::endl;
61  os << "l_data_his:" << data._l_data_his << std::endl;
62  os << "n_rang_spec:" << data._n_rang_spec << std::endl;
63  os << "l_rang_spec:" << data._l_rang_spec << std::endl;
64  os << "n_dem_desc:" << data._n_dem_desc << std::endl;
65  os << "l_dem_desc:" << data._l_dem_desc << std::endl;
66  os << "n_radar_par:" << data._n_radar_par << std::endl;
67  os << "l_radar_par:" << data._l_radar_par << std::endl;
68  os << "n_anno_data:" << data._n_anno_data << std::endl;
69  os << "l_anno_data:" << data._l_anno_data << std::endl;
70  os << "n_det_proc:" << data._n_det_proc << std::endl;
71  os << "l_det_proc:" << data._l_det_proc << std::endl;
72  os << "n_cal:" << data._n_cal << std::endl;
73  os << "l_cal:" << data._l_cal << std::endl;
74  os << "n_gcp:" << data._n_gcp << std::endl;
75  os << "l_gcp:" << data._l_gcp << std::endl;
76  os << "n_fac_data:" << data._n_fac_data << std::endl;
77  os << "l_fac_data:" << data._l_fac_data << std::endl;
78  os << "n_fac_data2:" << data._n_fac_data2 << std::endl;
79  os << "l_fac_data2:" << data._l_fac_data2 << std::endl;
80  os << "n_fac_data3:" << data._n_fac_data3 << std::endl;
81  os << "l_fac_data3:" << data._l_fac_data3 << std::endl;
82  os << "n_fac_data4:" << data._n_fac_data4 << std::endl;
83  os << "l_fac_data4:" << data._l_fac_data4 << std::endl;
84  os << "n_fac_data5:" << data._n_fac_data5 << std::endl;
85  os << "l_fac_data5:" << data._l_fac_data5 << std::endl;
86  os << "n_fac_data6:" << data._n_fac_data6 << std::endl;
87  os << "l_fac_data6:" << data._l_fac_data6 << std::endl;
88  os << "n_fac_data7:" << data._n_fac_data7 << std::endl;
89  os << "l_fac_data7:" << data._l_fac_data7 << std::endl;
90  os << "n_fac_data8:" << data._n_fac_data8 << std::endl;
91  os << "l_fac_data8:" << data._l_fac_data8 << std::endl;
92  os << "n_fac_data9:" << data._n_fac_data9 << std::endl;
93  os << "l_fac_data9:" << data._l_fac_data9 << std::endl;
94  os << "n_fac_data10:" << data._n_fac_data10 << std::endl;
95  os << "l_fac_data10:" << data._l_fac_data10 << std::endl;
96  os << "n_fac_data11:" << data._n_fac_data11 << std::endl;
97  os << "l_fac_data11:" << data._l_fac_data11 << std::endl;
98  return os;
99 }
◆ operator<<() [46/63]
const AlosPalsarRadiometricData data
Definition at line 27 of file AlosPalsarRadiometricData.cpp.
References ossimplugins::AlosPalsarRadiometricData::_calibration_factor.
28 {
29  os << "calibration_factor:" << data._calibration_factor << std::endl;
30
31  return os;
32 }
◆ operator<<() [47/63]
const AlosPalsarPositionVectorRecord data
Definition at line 27 of file AlosPalsarPositionVectorRecord.cpp.
References ossimplugins::AlosPalsarPositionVectorRecord::_pos, and ossimplugins::AlosPalsarPositionVectorRecord::_vel.
28 {
29  for (int i = 0; i < 3; i++)
30  {
31  os << "pos[" << i << "]:" << data._pos[i] << std::endl;
32  }
33
34  for (int i = 0; i < 3; i++)
35  {
36  os << "vel[" << i << "]:" << data._vel[i] << std::endl;
37  }
38  return os;
39 }
◆ operator<<() [48/63]
const AlosPalsarDataFileDescriptor data
Definition at line 27 of file AlosPalsarDataFileDescriptor.cpp.
References ossimplugins::AlosPalsarDataFileDescriptor::_num_lines, and ossimplugins::AlosPalsarDataFileDescriptor::_num_pix_in_line.
28 {
29  os << "_num_lines:" << data._num_lines << std::endl;
30  os << "_num_pix_in_line:" << data._num_pix_in_line << std::endl;
31  return os;
32 }
◆ operator<<() [49/63]
const AlosPalsarRecordHeader data
Definition at line 27 of file AlosPalsarRecordHeader.cpp.
References ossimplugins::AlosPalsarRecordHeader::_length, ossimplugins::AlosPalsarRecordHeader::_rec_seq, ossimplugins::AlosPalsarRecordHeader::_rec_sub1, ossimplugins::AlosPalsarRecordHeader::_rec_sub2, ossimplugins::AlosPalsarRecordHeader::_rec_sub3, and ossimplugins::AlosPalsarRecordHeader::_rec_type.
28 {
29  os << "record_sequence_number:" << data._rec_seq << std::endl;
30  os << "first_record_sub-type:" << (int)data._rec_sub1 << std::endl;
31  os << "record_type_code:" << (int)data._rec_type << std::endl;
32  os << "second_record_sub-type:" << (int)data._rec_sub2 << std::endl;
33  os << "third_record_sub-type:" << (int)data._rec_sub3 << std::endl;
34  os << "length:" << data._length << std::endl;
35  return os;
36 }
◆ operator<<() [50/63]
const AlosPalsarPlatformPositionData data
Definition at line 27 of file AlosPalsarPlatformPositionData.cpp.
References ossimplugins::AlosPalsarPlatformPositionData::_alt_poserr, ossimplugins::AlosPalsarPlatformPositionData::_alt_velerr, ossimplugins::AlosPalsarPlatformPositionData::_crt_poserr, ossimplugins::AlosPalsarPlatformPositionData::_crt_velerr, ossimplugins::AlosPalsarPlatformPositionData::_data_int, ossimplugins::AlosPalsarPlatformPositionData::_day, ossimplugins::AlosPalsarPlatformPositionData::_gmt_day, ossimplugins::AlosPalsarPlatformPositionData::_gmt_sec, ossimplugins::AlosPalsarPlatformPositionData::_hr_angle, ossimplugins::AlosPalsarPlatformPositionData::_month, ossimplugins::AlosPalsarPlatformPositionData::_ndata, ossimplugins::AlosPalsarPlatformPositionData::_orbit_ele, ossimplugins::AlosPalsarPlatformPositionData::_orbit_ele_desg, ossimplugins::AlosPalsarPlatformPositionData::_pos_vect, ossimplugins::AlosPalsarPlatformPositionData::_rad_poserr, ossimplugins::AlosPalsarPlatformPositionData::_rad_velerr, ossimplugins::AlosPalsarPlatformPositionData::_ref_coord, and ossimplugins::AlosPalsarPlatformPositionData::_year.
28 {
29  os << "orbit_ele_desg:" << data._orbit_ele_desg.c_str() << std::endl;
30
31  for (int i = 0; i < 6; i++)
32  {
33  os << "orbit_ele[" << i << "]:" << data._orbit_ele[i] << std::endl;
34  }
35
36  os << "ndata:" << data._ndata << std::endl;
37
38  os << "year:" << data._year << std::endl;
39
40  os << "month:" << data._month << std::endl;
41
42  os << "day:" << data._day << std::endl;
43
44  os << "gmt_day:" << data._gmt_day << std::endl;
45
46  os << "gmt_sec:" << data._gmt_sec << std::endl;
47
48  os << "data_int:" << data._data_int << std::endl;
49
50  os << "ref_coord:" << data._ref_coord.c_str() << std::endl;
51
52  os << "hr_angle:" << data._hr_angle << std::endl;
53
54  os << "alt_poserr:" << data._alt_poserr << std::endl;
55
56  os << "crt_poserr:" << data._crt_poserr << std::endl;
57
58  os << "rad_poserr:" << data._rad_poserr << std::endl;
59
60  os << "alt_velerr:" << data._alt_velerr << std::endl;
61
62  os << "crt_velerr:" << data._crt_velerr << std::endl;
63
64  os << "rad_velerr:" << data._rad_velerr << std::endl;
65
66  for (int i = 0; i < 64; i++)
67  {
68  os << "pos_vect[" << i << "]:" << data._pos_vect[i] << std::endl;
69  }
70
71  return os;
72 }
◆ operator<<() [51/63]
const ImageOptionsFileDescriptor data
Definition at line 28 of file ImageOptionsFileDescriptor.cpp.
References ossimplugins::ImageOptionsFileDescriptor::_ascii_flag, ossimplugins::ImageOptionsFileDescriptor::_bias_loc, ossimplugins::ImageOptionsFileDescriptor::_cali_loc, ossimplugins::ImageOptionsFileDescriptor::_chn_loc, ossimplugins::ImageOptionsFileDescriptor::_code_len, ossimplugins::ImageOptionsFileDescriptor::_code_loc, ossimplugins::ImageOptionsFileDescriptor::_design_rev, ossimplugins::ImageOptionsFileDescriptor::_file_name, ossimplugins::ImageOptionsFileDescriptor::_file_num, ossimplugins::ImageOptionsFileDescriptor::_format_doc, ossimplugins::ImageOptionsFileDescriptor::_format_rev, ossimplugins::ImageOptionsFileDescriptor::_gain_loc, ossimplugins::ImageOptionsFileDescriptor::_intleav, ossimplugins::ImageOptionsFileDescriptor::_justify, ossimplugins::ImageOptionsFileDescriptor::_l_dataset, ossimplugins::ImageOptionsFileDescriptor::_left_fill, ossimplugins::ImageOptionsFileDescriptor::_left_loc, ossimplugins::ImageOptionsFileDescriptor::_lin_loc, ossimplugins::ImageOptionsFileDescriptor::_n_dataset, ossimplugins::ImageOptionsFileDescriptor::_n_prefix, ossimplugins::ImageOptionsFileDescriptor::_n_sar, ossimplugins::ImageOptionsFileDescriptor::_n_suffix, ossimplugins::ImageOptionsFileDescriptor::_nbit, ossimplugins::ImageOptionsFileDescriptor::_nbott, ossimplugins::ImageOptionsFileDescriptor::_nbyte, ossimplugins::ImageOptionsFileDescriptor::_nchn, ossimplugins::ImageOptionsFileDescriptor::_ngrp, ossimplugins::ImageOptionsFileDescriptor::_nleft, ossimplugins::ImageOptionsFileDescriptor::_nlin, ossimplugins::ImageOptionsFileDescriptor::_nrec_chn, ossimplugins::ImageOptionsFileDescriptor::_nrec_lin, ossimplugins::ImageOptionsFileDescriptor::_nright, ossimplugins::ImageOptionsFileDescriptor::_nsamp, ossimplugins::ImageOptionsFileDescriptor::_ntop, ossimplugins::ImageOptionsFileDescriptor::_pad_ind, ossimplugins::ImageOptionsFileDescriptor::_pix_rng, ossimplugins::ImageOptionsFileDescriptor::_qual_loc, ossimplugins::ImageOptionsFileDescriptor::_rec_code, ossimplugins::ImageOptionsFileDescriptor::_rec_len, ossimplugins::ImageOptionsFileDescriptor::_rec_seq, ossimplugins::ImageOptionsFileDescriptor::_right_fill, ossimplugins::ImageOptionsFileDescriptor::_right_loc, ossimplugins::ImageOptionsFileDescriptor::_rlen_len, ossimplugins::ImageOptionsFileDescriptor::_rlen_loc, ossimplugins::ImageOptionsFileDescriptor::_seq_len, ossimplugins::ImageOptionsFileDescriptor::_seq_loc, ossimplugins::ImageOptionsFileDescriptor::_software_id, ossimplugins::ImageOptionsFileDescriptor::_tim_loc, ossimplugins::ImageOptionsFileDescriptor::_type_code, and ossimplugins::ImageOptionsFileDescriptor::_type_id.
29  {
30  os<<"ascii_flag:"<<data._ascii_flag.c_str()<<std::endl;
31
32  os<<"format_doc:"<<data._format_doc.c_str()<<std::endl;
33
34  os<<"format_rev:"<<data._format_rev.c_str()<<std::endl;
35
36  os<<"design_rev:"<<data._design_rev.c_str()<<std::endl;
37
38  os<<"software_id:"<<data._software_id.c_str()<<std::endl;
39
40  os<<"file_num:"<<data._file_num<<std::endl;
41
42  os<<"file_name:"<<data._file_name.c_str()<<std::endl;
43
44  os<<"rec_seq:"<<data._rec_seq.c_str()<<std::endl;
45
46  os<<"seq_loc:"<<data._seq_loc<<std::endl;
47
48  os<<"seq_len:"<<data._seq_len<<std::endl;
49
50  os<<"rec_code:"<<data._rec_code.c_str()<<std::endl;
51
52  os<<"code_loc:"<<data._code_loc<<std::endl;
53
54  os<<"code_len:"<<data._code_len<<std::endl;
55
56  os<<"rec_len:"<<data._rec_len.c_str()<<std::endl;
57
58  os<<"rlen_loc:"<<data._rlen_loc<<std::endl;
59
60  os<<"rlen_len:"<<data._rlen_len<<std::endl;
61
62  os<<"n_dataset:"<<data._n_dataset<<std::endl;
63
64  os<<"l_dataset:"<<data._l_dataset<<std::endl;
65
66  os<<"nbit:"<<data._nbit<<std::endl;
67
68  os<<"nsamp:"<<data._nsamp<<std::endl;
69
70  os<<"nbyte:"<<data._nbyte<<std::endl;
71
72  os<<"justify:"<<data._justify.c_str()<<std::endl;
73
74  os<<"nchn:"<<data._nchn<<std::endl;
75
76  os<<"nlin:"<<data._nlin<<std::endl;
77
78  os<<"nleft:"<<data._nleft<<std::endl;
79
80  os<<"ngrp:"<<data._ngrp<<std::endl;
81
82  os<<"nright:"<<data._nright<<std::endl;
83
84  os<<"ntop:"<<data._ntop<<std::endl;
85
86  os<<"nbott:"<<data._nbott<<std::endl;
87
88  os<<"intleav:"<<data._intleav.c_str()<<std::endl;
89
90  os<<"nrec_lin:"<<data._nrec_lin<<std::endl;
91
92  os<<"nrec_chn:"<<data._nrec_chn<<std::endl;
93
94  os<<"n_prefix:"<<data._n_prefix<<std::endl;
95
96  os<<"n_sar:"<<data._n_sar<<std::endl;
97
98  os<<"n_suffix:"<<data._n_suffix<<std::endl;
99
100  os<<"lin_loc:"<<data._lin_loc.c_str()<<std::endl;
101
102  os<<"chn_loc:"<<data._chn_loc.c_str()<<std::endl;
103
104  os<<"tim_loc:"<<data._tim_loc.c_str()<<std::endl;
105
106  os<<"left_loc:"<<data._left_loc.c_str()<<std::endl;
107
108  os<<"right_loc:"<<data._right_loc.c_str()<<std::endl;
109
110  os<<"pad_ind:"<<data._pad_ind.c_str()<<std::endl;
111
112  os<<"qual_loc:"<<data._qual_loc.c_str()<<std::endl;
113
114  os<<"cali_loc:"<<data._cali_loc.c_str()<<std::endl;
115
116  os<<"gain_loc:"<<data._gain_loc.c_str()<<std::endl;
117
118  os<<"bias_loc:"<<data._bias_loc.c_str()<<std::endl;
119
120  os<<"type_id:"<<data._type_id.c_str()<<std::endl;
121
122  os<<"type_code:"<<data._type_code.c_str()<<std::endl;
123
124  os<<"left_fill:"<<data._left_fill<<std::endl;
125
126  os<<"right_fill:"<<data._right_fill<<std::endl;
127
128  os<<"pix_rng:"<<data._pix_rng<<std::endl;
129
130  return os;
131  }
◆ operator<<() [52/63]
const AlosPalsarSignalData data
Definition at line 29 of file AlosPalsarSignalData.cpp.
References ossimplugins::AlosPalsarSignalData::_pulse_repetition_frequency, and ossimplugins::AlosPalsarSignalData::_slant_range_to_1st_data_sample.
30 {
31  os << "_pulse_repetition_frequency:"
32  << data._pulse_repetition_frequency << std::endl;
33  os << "_slant_range_to_1st_data_sample:"
34  << data._slant_range_to_1st_data_sample << std::endl;
35
36  return os;
37 }
◆ operator<<() [53/63]
const VolumeDir data
Definition at line 34 of file VolumeDir.cpp.
References ossimplugins::VolumeDir::_records.
35 {
36  std::map<int, RadarSatRecord*>::const_iterator it = data._records.begin();
37  while(it != data._records.end())
38  {
39  (*it).second->Write(os);
40  ++it;
41  }
42  return os;
43
44 }
◆ operator<<() [54/63]
const sph data
Definition at line 34 of file sph.cpp.
References ossimplugins::sph::_algo_title, ossimplugins::sph::_algorithm, ossimplugins::sph::_azimut_looks, ossimplugins::sph::_azimut_looks_title, ossimplugins::sph::_azimut_spacing, ossimplugins::sph::_azimut_spacing_title, ossimplugins::sph::_azimut_spacing_unit, ossimplugins::sph::_compression, ossimplugins::sph::_compression_title, ossimplugins::sph::_data_type, ossimplugins::sph::_data_type_title, ossimplugins::sph::_first_far_lat, ossimplugins::sph::_first_far_lat_title, ossimplugins::sph::_first_far_lat_units, ossimplugins::sph::_first_far_long, ossimplugins::sph::_first_far_long_title, ossimplugins::sph::_first_far_long_units, ossimplugins::sph::_first_line_time, ossimplugins::sph::_first_line_time_title, ossimplugins::sph::_first_mid_lat, ossimplugins::sph::_first_mid_lat_title, ossimplugins::sph::_first_mid_lat_units, ossimplugins::sph::_first_mid_long, ossimplugins::sph::_first_mid_long_title, ossimplugins::sph::_first_mid_long_units, ossimplugins::sph::_first_near_lat, ossimplugins::sph::_first_near_lat_title, ossimplugins::sph::_first_near_lat_units, ossimplugins::sph::_first_near_long, ossimplugins::sph::_first_near_long_title, ossimplugins::sph::_first_near_long_units, ossimplugins::sph::_last_far_lat, ossimplugins::sph::_last_far_lat_title, ossimplugins::sph::_last_far_lat_units, ossimplugins::sph::_last_far_long, ossimplugins::sph::_last_far_long_title, ossimplugins::sph::_last_far_long_units, ossimplugins::sph::_last_line_time, ossimplugins::sph::_last_line_time_title, ossimplugins::sph::_last_mid_lat, ossimplugins::sph::_last_mid_lat_title, ossimplugins::sph::_last_mid_lat_units, ossimplugins::sph::_last_mid_long, ossimplugins::sph::_last_mid_long_title, ossimplugins::sph::_last_mid_long_units, ossimplugins::sph::_last_near_lat, ossimplugins::sph::_last_near_lat_title, ossimplugins::sph::_last_near_lat_units, ossimplugins::sph::_last_near_long, ossimplugins::sph::_last_near_long_title, ossimplugins::sph::_last_near_long_units, ossimplugins::sph::_line_length, ossimplugins::sph::_line_length_title, ossimplugins::sph::_line_length_units, ossimplugins::sph::_line_time_interv_units, ossimplugins::sph::_line_time_interval, ossimplugins::sph::_line_time_interval_title, ossimplugins::sph::_mds1_tx_rx_polar, ossimplugins::sph::_mds1_tx_rx_polar_title, ossimplugins::sph::_mds2_tx_rx_polar, ossimplugins::sph::_mds2_tx_rx_polar_title, ossimplugins::sph::_num_slices, ossimplugins::sph::_num_slices_title, ossimplugins::sph::_pass, ossimplugins::sph::_pass_title, ossimplugins::sph::_range_looks, ossimplugins::sph::_range_looks_title, ossimplugins::sph::_range_spacing, ossimplugins::sph::_range_spacing_title, ossimplugins::sph::_range_spacing_unit, ossimplugins::sph::_sample_type, ossimplugins::sph::_sample_type_title, ossimplugins::sph::_slice_pos_title, ossimplugins::sph::_slice_position, ossimplugins::sph::_sph_desc, ossimplugins::sph::_sph_desc_title, ossimplugins::sph::_strip_cont_ind, ossimplugins::sph::_strip_cont_ind_title, ossimplugins::sph::_swath, and ossimplugins::sph::_swath_title.
35  {
36  os<<"sph_desc_title:"<<data._sph_desc_title.c_str()<<std::endl;
37
38  os<<"sph_desc:"<<data._sph_desc.c_str()<<std::endl;
39
40  os<<"strip_cont_ind_title:"<<data._strip_cont_ind_title.c_str()<<std::endl;
41
42  os<<"strip_cont_ind std::string:"<<data._strip_cont_ind.c_str()<<std::endl;
43
44  os<<"slice_pos_title:"<<data._slice_pos_title.c_str()<<std::endl;
45
46  os<<"slice_position:"<<data._slice_position.c_str()<<std::endl;
47
48  os<<"num_slices_title:"<<data._num_slices_title.c_str()<<std::endl;
49
50  os<<"num_slices:"<<data._num_slices.c_str()<<std::endl;
51
52  os<<"first_line_time_title:"<<data._first_line_time_title.c_str()<<std::endl;
53
54  os<<"first_line_time:"<<data._first_line_time.c_str()<<std::endl;
55
56  os<<"last_line_time_title:"<<data._last_line_time_title.c_str()<<std::endl;
57
58  os<<"last_line_time:"<<data._last_line_time.c_str()<<std::endl;
59
60  os<<"first_near_lat_title:"<<data._first_near_lat_title.c_str()<<std::endl;
61
62  os<<"first_near_lat:"<<data._first_near_lat.c_str()<<std::endl;
63
64  os<<"first_near_lat_units:"<<data._first_near_lat_units.c_str()<<std::endl;
65
66  os<<"first_near_long_title:"<<data._first_near_long_title.c_str()<<std::endl;
67
68  os<<"first_near_long:"<<data._first_near_long.c_str()<<std::endl;
69
70  os<<"first_near_long_units:"<<data._first_near_long_units.c_str()<<std::endl;
71
72  os<<"first_mid_lat_title:"<<data._first_mid_lat_title.c_str()<<std::endl;
73
74  os<<"first_mid_lat:"<<data._first_mid_lat.c_str()<<std::endl;
75
76  os<<"first_mid_lat_units:"<<data._first_mid_lat_units.c_str()<<std::endl;
77
78  os<<"first_mid_long_title:"<<data._first_mid_long_title.c_str()<<std::endl;
79
80  os<<"first_mid_long:"<<data._first_mid_long.c_str()<<std::endl;
81
82  os<<"first_mid_long_units:"<<data._first_mid_long_units.c_str()<<std::endl;
83
84  os<<"first_far_lat_title:"<<data._first_far_lat_title.c_str()<<std::endl;
85
86  os<<"first_far_lat:"<<data._first_far_lat.c_str()<<std::endl;
87
88  os<<"first_far_lat_units:"<<data._first_far_lat_units.c_str()<<std::endl;
89
90  os<<"first_far_long_title:"<<data._first_far_long_title.c_str()<<std::endl;
91
92  os<<"first_far_long:"<<data._first_far_long.c_str()<<std::endl;
93
94  os<<"first_far_long_units:"<<data._first_far_long_units.c_str()<<std::endl;
95
96  os<<"last_near_lat_title:"<<data._last_near_lat_title.c_str()<<std::endl;
97
98  os<<"last_near_lat:"<<data._last_near_lat.c_str()<<std::endl;
99
100  os<<"last_near_lat_units:"<<data._last_near_lat_units.c_str()<<std::endl;
101
102  os<<"last_near_long_title:"<<data._last_near_long_title.c_str()<<std::endl;
103
104  os<<"last_near_long:"<<data._last_near_long.c_str()<<std::endl;
105
106  os<<"last_near_long_units:"<<data._last_near_long_units.c_str()<<std::endl;
107
108  os<<"last_mid_lat_title:"<<data._last_mid_lat_title.c_str()<<std::endl;
109
110  os<<"last_mid_lat:"<<data._last_mid_lat.c_str()<<std::endl;
111
112  os<<"last_mid_lat_units:"<<data._last_mid_lat_units.c_str()<<std::endl;
113
114  os<<"last_mid_long_title:"<<data._last_mid_long_title.c_str()<<std::endl;
115
116  os<<"last_mid_long:"<<data._last_mid_long.c_str()<<std::endl;
117
118  os<<"last_mid_long_units:"<<data._last_mid_long_units.c_str()<<std::endl;
119
120  os<<"last_far_lat_title:"<<data._last_far_lat_title.c_str()<<std::endl;
121
122  os<<"last_far_lat:"<<data._last_far_lat.c_str()<<std::endl;
123
124  os<<"last_far_lat_units:"<<data._last_far_lat_units.c_str()<<std::endl;
125
126  os<<"last_far_long_title:"<<data._last_far_long_title.c_str()<<std::endl;
127
128  os<<"last_far_long:"<<data._last_far_long.c_str()<<std::endl;
129
130  os<<"last_far_long_units:"<<data._last_far_long_units.c_str()<<std::endl;
131
132  os<<"swath_title:"<<data._swath_title.c_str()<<std::endl;
133
134  os<<"swath:"<<data._swath.c_str()<<std::endl;
135
136  os<<"pass_title:"<<data._pass_title.c_str()<<std::endl;
137
138  os<<"pass:"<<data._pass.c_str()<<std::endl;
139
140  os<<"sample_type_title:"<<data._sample_type_title.c_str()<<std::endl;
141
142  os<<"sample_type:"<<data._sample_type.c_str()<<std::endl;
143
144  os<<"algo_title:"<<data._algo_title.c_str()<<std::endl;
145
146  os<<"algorithm:"<<data._algorithm.c_str()<<std::endl;
147
148  os<<"mds1_tx_rx_polar_title:"<<data._mds1_tx_rx_polar_title.c_str()<<std::endl;
149
150  os<<"mds1_tx_rx_polar:"<<data._mds1_tx_rx_polar.c_str()<<std::endl;
151
152  os<<"mds2_tx_rx_polar_title:"<<data._mds2_tx_rx_polar_title.c_str()<<std::endl;
153
154  os<<"mds2_tx_rx_polar:"<<data._mds2_tx_rx_polar.c_str()<<std::endl;
155
156  os<<"compression_title:"<<data._compression_title.c_str()<<std::endl;
157
158  os<<"compression:"<<data._compression.c_str()<<std::endl;
159
160  os<<"azimut_looks_title:"<<data._azimut_looks_title.c_str()<<std::endl;
161
162  os<<"azimut_looks:"<<data._azimut_looks.c_str()<<std::endl;
163
164  os<<"range_looks_title:"<<data._range_looks_title.c_str()<<std::endl;
165
166  os<<"range_looks:"<<data._range_looks.c_str()<<std::endl;
167
168  os<<"range_spacing_title:"<<data._range_spacing_title.c_str()<<std::endl;
169
170  os<<"range_spacing:"<<data._range_spacing.c_str()<<std::endl;
171
172  os<<"range_spacing_unit:"<<data._range_spacing_unit.c_str()<<std::endl;
173
174  os<<"azimut_spacing_title:"<<data._azimut_spacing_title.c_str()<<std::endl;
175
176  os<<"azimut_spacing:"<<data._azimut_spacing.c_str()<<std::endl;
177
178  os<<"azimut_spacing_unit:"<<data._azimut_spacing_unit.c_str()<<std::endl;
179
180  os<<"line_time_interval_title:"<<data._line_time_interval_title.c_str()<<std::endl;
181
182  os<<"line_time_interval:"<<data._line_time_interval.c_str()<<std::endl;
183
184  os<<"line_time_interv_units:"<<data._line_time_interv_units.c_str()<<std::endl;
185
186  os<<"line_length_title:"<<data._line_length_title.c_str()<<std::endl;
187
188  os<<"line_length:"<<data._line_length.c_str()<<std::endl;
189
190  os<<"line_length_units:"<<data._line_length_units.c_str()<<std::endl;
191
192  os<<"data_type_title:"<<data._data_type_title.c_str()<<std::endl;
193
194  os<<"data_type:"<<data._data_type.c_str()<<std::endl;
195
196  return os;
197
198  }
◆ operator<<() [55/63]
const EnvisatAsarData data
Definition at line 37 of file EnvisatAsarData.cpp.
References ossimplugins::EnvisatAsarData::_records.
38 {
39  std::list<EnvisatAsarRecord*>::const_iterator it = data._records.begin();
40  while(it != data._records.end())
41  {
42  (*it)->Write(os);
43  ++it;
44  }
45  return os;
46
47 }
◆ operator<<() [56/63]
const Data data
Definition at line 37 of file Data.cpp.
References ossimplugins::Data::_records.
38 {
39  std::map<int, RadarSatRecord*>::const_iterator it = data._records.begin();
41  {
42  (*it).second->Write(os);
43  ++it;
44  }
45  return os;
46
47 }
◆ operator<<() [57/63]
const AlosPalsarData data
Definition at line 42 of file AlosPalsarData.cpp.
References ossimplugins::AlosPalsarData::_records.
43 {
44  std::map<int, AlosPalsarRecord*>::const_iterator it = data._records.begin();
45  while (it != data._records.end())
46  {
47  (*it).second->Write(os);
48  ++it;
49  }
50  return os;
51
52 }
◆ operator<<() [58/63]
const Trailer data
Definition at line 47 of file Trailer.cpp.
References ossimplugins::Trailer::_records.
48 {
49  std::map<int, RadarSatRecord*>::const_iterator it = data._records.begin();
50  while(it != data._records.end())
51  {
52  (*it).second->Write(os);
53  ++it;
54  }
55  return os;
56
57 }
◆ operator<<() [59/63]
const AlosPalsarLeader data
Definition at line 47 of file AlosPalsarLeader.cpp.
References ossimplugins::AlosPalsarLeader::_records.
48 {
49  std::map<int, AlosPalsarRecord*>::const_iterator it = data._records.begin();
50  while (it != data._records.end())
51  {
53  ++it;
54  }
55  return os;
56
57 }
◆ operator<<() [60/63]
std::ostream& ossimplugins::operator<< ( std::ostream &  os,
const ErsSarLeader data
Definition at line 48 of file ErsSarLeader.cpp.
References ossimplugins::ErsSarLeader::theRecords.
49 {
50  std::map<int, ErsSarRecord*>::const_iterator it = data.theRecords.begin();
51  while (it != data.theRecords.end())
52  {
53  (*it).second->Write(os);
54  ++it;
55  }
56  return os;
57
58 }
◆ operator<<() [61/63]
const Leader data
Definition at line 52 of file Leader.cpp.
References ossimplugins::Leader::_records.
53 {
54  std::map<int, RadarSatRecord*>::const_iterator it = data._records.begin();
55  while(it != data._records.end())
56  {
57  (*it).second->Write(os);
58  ++it;
59  }
60  return os;
61
62 }
◆ operator<<() [62/63]
const DataHistogramRecord data
Definition at line 82 of file DataHistogramRecord.cpp.
References ossimplugins::DataHistogramRecord::_hist, ossimplugins::DataHistogramRecord::_hist_desc, ossimplugins::DataHistogramRecord::_max_hist, ossimplugins::DataHistogramRecord::_max_smp, ossimplugins::DataHistogramRecord::_mean_hist, ossimplugins::DataHistogramRecord::_mean_smp, ossimplugins::DataHistogramRecord::_min_hist, ossimplugins::DataHistogramRecord::_min_smp, ossimplugins::DataHistogramRecord::_nbin, ossimplugins::DataHistogramRecord::_ngrp_lin, ossimplugins::DataHistogramRecord::_ngrp_pix, ossimplugins::DataHistogramRecord::_nhist, ossimplugins::DataHistogramRecord::_nrec, ossimplugins::DataHistogramRecord::_ns_lin, ossimplugins::DataHistogramRecord::_ns_pix, ossimplugins::DataHistogramRecord::_nsamp_lin, ossimplugins::DataHistogramRecord::_nsamp_pix, ossimplugins::DataHistogramRecord::_smp_inc, ossimplugins::DataHistogramRecord::_std_hist, ossimplugins::DataHistogramRecord::_std_smp, and ossimplugins::DataHistogramRecord::_tab_seq.
83 {
84  os<<"hist_desc:"<<data._hist_desc.c_str()<<std::endl;
85
86  os<<"nrec:"<<data._nrec<<std::endl;
87
88  os<<"tab_seq:"<<data._tab_seq<<std::endl;
89
90  os<<"nbin:"<<data._nbin<<std::endl;
91
92  os<<"ns_lin:"<<data._ns_lin<<std::endl;
93
94  os<<"ns_pix:"<<data._ns_pix<<std::endl;
95
96  os<<"ngrp_lin:"<<data._ngrp_lin<<std::endl;
97
98  os<<"ngrp_pix:"<<data._ngrp_pix<<std::endl;
99
100  os<<"nsamp_lin:"<<data._nsamp_lin<<std::endl;
101
102  os<<"nsamp_pix:"<<data._nsamp_pix<<std::endl;
103
104  os<<"min_smp:"<<data._min_smp<<std::endl;
105
106  os<<"max_smp:"<<data._max_smp<<std::endl;
107
108  os<<"mean_smp:"<<data._mean_smp<<std::endl;
109
110  os<<"std_smp:"<<data._std_smp<<std::endl;
111
112  os<<"smp_inc:"<<data._smp_inc<<std::endl;
113
114  os<<"min_hist:"<<data._min_hist<<std::endl;
115
116  os<<"max_histd:"<<data._max_hist<<std::endl;
117
118  os<<"mean_hist:"<<data._mean_hist<<std::endl;
119
120  os<<"std_hist:"<<data._std_hist<<std::endl;
121
122  os<<"nhist:"<<data._nhist<<std::endl;
123
124  for(int i=0;i<data._nhist;i++)
125  {
126  os<<"his["<<i<<"]:"<<data._hist[i]<<std::endl;
127  }
128  return os;
129 }
◆ operator<<() [63/63]
std::ostream& ossimplugins::operator<< ( std::ostream &  out,
const CivilDateTime obj
Definition at line 469 of file CivilDateTime.cpp.
References ossimplugins::CivilDateTime::print().
470 {
471  return obj.print(out);
472 }
◆ operator>>() [1/62]
std::istream& ossimplugins::operator>> ( std::istream &  is,
MisregistrationRecord data
Definition at line 31 of file MisregistrationRecord.cpp.
References ossimplugins::MisregistrationRecord::_alt_m, and ossimplugins::MisregistrationRecord::_crt_m.
32 {
33  char buf16[17];
34  buf16[16] = '\0';
35
36  is.read(buf16,16);
37  data._alt_m = atof(buf16);
38
39  is.read(buf16,16);
40  data._crt_m = atof(buf16);
41  return is;
42 }
◆ operator>>() [2/62]
RadiometryUncertaintyRecord data
Definition at line 31 of file RadiometryUncertaintyRecord.cpp.
References ossimplugins::RadiometryUncertaintyRecord::_db, and ossimplugins::RadiometryUncertaintyRecord::_deg.
32 {
33  char buf16[17];
35
37  data._db = atof(buf16);
38
40  data._deg = atof(buf16);
41  return is;
42 }
◆ operator>>() [3/62]
Definition at line 34 of file AlosPalsarRadiometricData.cpp.
35 {
36  char buf[9];
37
38  is.seekg(8, std::ios::cur);
39
40  is.read(buf, 8);
41  buf[8] = '\0';
42  data._calibration_factor = atof(buf);
43
44  is.seekg(9824, std::ios::cur); //skip the rest of the radiometric data record
45  is.seekg(12477692, std::ios::cur); //skip to the 11th facility-related data record
46
47  return is;
48 }
◆ operator>>() [4/62]
Definition at line 34 of file AlosPalsarDataFileDescriptor.cpp.
35 {
36  char buf6[7];
37  buf6[6] = '\0';
38
39  char buf168[169];
40  buf168[168] = '\0';
41
42  char buf94[95];
43  buf94[94] = '\0';
44
45  char buf8[9];
46  buf8[8] = '\0';
47
48  is.read(buf168, 168);
49
50  is.read(buf6, 6);
51  data._num_lines = atoi(buf6);
52
53  is.read(buf94, 94);
54
55  int tmpval;
56  is.read(buf8, 8);
57  tmpval = atoi(buf8);
58  data._num_pix_in_line = tmpval / 8; // Assume data always in 8-byte complex format
59
60  char buf432[433];
61  buf432[432] = '\0';
62
63  is.read(buf432, 432);
64  return is;
65 }
◆ operator>>() [5/62]
TemperatureSettingsRecord data
Definition at line 34 of file TemperatureSettingsRecord.cpp.
References ossimplugins::TemperatureSettingsRecord::_temp_set.
35 {
36  char buf[5];
37  buf[4] = '\0';
38
39  for (int i=0;i<4;i++)
40  {
41  is.read(buf,4);
42  buf[4] = '\0';
43  data._temp_set[i] = atoi(buf);
44  }
45  return is;
46 }
◆ operator>>() [6/62]
RadarSatRecordHeader data
Definition at line 35 of file RadarSatRecordHeader.cpp.
References ossimplugins::RadarSatRecordHeader::_length, ossimplugins::RadarSatRecordHeader::_rec_seq, ossimplugins::RadarSatRecordHeader::_rec_sub1, ossimplugins::RadarSatRecordHeader::_rec_sub2, ossimplugins::RadarSatRecordHeader::_rec_sub3, ossimplugins::RadarSatRecordHeader::_rec_type, and ossimplugins::RadarSatRecordHeader::SwitchEndian().
36 {
37  is.read((char*)&(data._rec_seq),4);
38  data.SwitchEndian(data._rec_seq);
39  is.read((char*)&(data._rec_sub1),1);
40  is.read((char*)&(data._rec_type),1);
41  is.read((char*)&(data._rec_sub2),1);
42  is.read((char*)&(data._rec_sub3),1);
43  is.read((char*)&(data._length),4);
44  data.SwitchEndian(data._length);
45  return is;
46 }
◆ operator>>() [7/62]
BeamPixelCountRecord data
Definition at line 35 of file BeamPixelCountRecord.cpp.
References ossimplugins::BeamPixelCountRecord::_n_pix, and ossimplugins::BeamPixelCountRecord::_pix_update.
36 {
37  char buf[23];
38  buf[22] = '\0';
39
40  is.read(buf,21);
41  data._pix_update = buf;
42
43  for (int i=0;i<4;i++)
44  {
45  is.read(buf,8);
46  buf[8] = '\0';
47  data._n_pix[i] = atoi(buf);
48  }
49  return is;
50 }
◆ operator>>() [8/62]
SRGRCoefficientSetRecord data
Definition at line 35 of file SRGRCoefficientSetRecord.cpp.
References ossimplugins::SRGRCoefficientSetRecord::_srgr_coef, and ossimplugins::SRGRCoefficientSetRecord::_srgr_update.
36 {
37  char buf[22];
38  buf[21] = '\0';
39
40  is.read(buf,21);
41  buf[21] = '\0';
42  data._srgr_update = buf;
43
44  for (int i=0;i<6;i++)
45  {
46  is.read(buf,16);
47  buf[16] = '\0';
48  data._srgr_coef[i] = atof(buf);
49  }
50  return is;
51 }
◆ operator>>() [9/62]
DopplerCentroidEstimateRecord data
Definition at line 36 of file DopplerCentroidEstimateRecord.cpp.
References ossimplugins::DopplerCentroidEstimateRecord::_dopcen_coef, ossimplugins::DopplerCentroidEstimateRecord::_dopcen_conf, and ossimplugins::DopplerCentroidEstimateRecord::_dopcen_ref_tim.
37 {
38  char buf[17];
39  buf[16] = '\0';
40
41  is.read(buf,16);
42  buf[16] = '\0';
43  data._dopcen_conf = atof(buf);
44
45  is.read(buf,16);
46  buf[16] = '\0';
47  data._dopcen_ref_tim = atof(buf);
48
49  for (int i=0;i<4;i++)
50  {
51  is.read(buf,16);
52  buf[16] = '\0';
53  data._dopcen_coef[i] = atof(buf);
54  }
55  return is;
56 }
◆ operator>>() [10/62]
dsd data
Definition at line 37 of file dsd.cpp.
References ossimplugins::dsd::_ds_name, ossimplugins::dsd::_ds_offset, ossimplugins::dsd::_ds_size, ossimplugins::dsd::_ds_type, ossimplugins::dsd::_dsr_size, ossimplugins::dsd::_filename, and ossimplugins::dsd::_num_dsr.
38  {
39  char buf64[65];
40  buf64[64] = '\0';
41  // char buf32[33];
42  // buf32[32] = '\0';
43  char buf28[29];
44  buf28[28] = '\0';
45  char buf27[28];
46  buf27[27] = '\0';
47  // char buf20[21];
48  // buf20[20] = '\0';
49  char buf16[17];
50  buf16[16]='\0';
51  // char buf15[16];
52  // buf15[15] = '\0';
53  // char buf14[15];
54  // buf14[14] = '\0';
55  // char buf13[14];
56  // buf13[13] = '\0';
57  char buf12[13];
58  buf12[12] = '\0';
59  char buf11[12];
60  buf11[11] = '\0';
61  char buf10[11];
62  buf10[10] = '\0';
63  char buf9[10];
64  buf9[9] = '\0';
65  // char buf8[9];
66  // buf8[8] = '\0';
67  // char buf7[8];
68  // buf7[7] = '\0';
69  // char buf6[7];
70  // buf6[6] = '\0';
71  // char buf5[6];
72  // buf5[5] = '\0';
73  // char buf4[5];
74  // buf4[4] = '\0';
75  // char buf3[4];
76  // buf3[3] = '\0';
77  // char buf2[3];
78  // buf2[2] = '\0';
79  char buf1[1];
80
81  is.read(buf9,9);
82
83  is.read(buf28,28);
84  data._ds_name = buf28;
85
86  is.read(buf10,10);
87
88  is.read(buf1,1);
89  data._ds_type = buf1;
90
91  is.read(buf11,11);
92
93  is.read(buf64,62);
94  buf64[62] = '\0';
95  data._filename = buf64;
96
97  is.read(buf12,12);
98
99  is.read(buf27,21);
100  buf27[21] = '\0';
101  data._ds_offset = atof(buf27);
102
103  is.read(buf16,16);
104
105  is.read(buf27,21);
106  buf27[21] = '\0';
107  data._ds_size = atof(buf27);
108
109  is.read(buf16,16);
110
111  is.read(buf11,11);
112  data._num_dsr = atol(buf11);
113
114  is.read(buf10,10);
115
116  is.read(buf11,11);
117  data._dsr_size = atol(buf11);
118
119  is.read(buf64,41);
120
121  return is;
122
123  }
◆ operator>>() [11/62]
TextRecord data
Definition at line 37 of file TextRecord.cpp.
References ossimplugins::TextRecord::_ascii_flag, ossimplugins::TextRecord::_cont_flag, ossimplugins::TextRecord::_copyright_info, ossimplugins::TextRecord::_phyvol_id, ossimplugins::TextRecord::_product_create, ossimplugins::TextRecord::_product_type, ossimplugins::TextRecord::_scene_id, and ossimplugins::TextRecord::_scene_loc.
38 {
39  char buf[349]; // 361-12
40  buf[348] = '\0';
41
42  is.read(buf, 2);
43  buf[2] = '\0';
44  data._ascii_flag = buf;
45
46  is.read(buf, 2);
47  buf[2] = '\0';
48  data._cont_flag = buf;
49
50  is.read(buf, 40);
51  buf[40] = '\0';
52  data._product_type = buf;
53
54  is.read(buf, 60);
55  buf[60] = '\0';
56  data._product_create = buf;
57
58  is.read(buf, 40);
59  buf[40] = '\0';
60  data._phyvol_id = buf;
61
62  is.read(buf, 40);
63  buf[40] = '\0';
64  data._scene_id = buf;
65
66  is.read(buf, 40);
67  buf[40] = '\0';
68  data._scene_loc = buf;
69
70  is.read(buf, 20);
71  buf[20] = '\0';
72  data._copyright_info = buf;
73
74  is.read(buf, 104); // spare1
75
76  return is;
77 }
◆ operator>>() [12/62]
BeamInformationRecord data
Definition at line 37 of file BeamInformationRecord.cpp.
References ossimplugins::BeamInformationRecord::_beam_look_ang, ossimplugins::BeamInformationRecord::_beam_look_src, ossimplugins::BeamInformationRecord::_beam_type, and ossimplugins::BeamInformationRecord::_prf.
38 {
39  char buf[17];
40  buf[16] = '\0';
41
42  is.read(buf,3);
43  buf[3] = '\0';
44  data._beam_type = buf;
45
46  is.read(buf,9);
47  buf[9] = '\0';
48  data._beam_look_src = buf;
49
50  is.read(buf,16);
51  buf[16] = '\0';
52  data._beam_look_ang = atof(buf);
53
54  is.read(buf,16);
55  buf[16] = '\0';
56  data._prf = atof(buf);
57
58  return is;
59 }
◆ operator>>() [13/62]
Definition at line 37 of file ErsSarRecordHeader.cpp.
References ossimplugins::ErsSarRecordHeader::_length, ossimplugins::ErsSarRecordHeader::_rec_seq, ossimplugins::ErsSarRecordHeader::_rec_sub1, ossimplugins::ErsSarRecordHeader::_rec_sub2, ossimplugins::ErsSarRecordHeader::_rec_sub3, ossimplugins::ErsSarRecordHeader::_rec_type, and ossimplugins::ErsSarRecordHeader::SwitchEndian().
38 {
39  is.read((char*)&(data._rec_seq), 4);
40  data.SwitchEndian(data._rec_seq);
41  is.read((char*)&(data._rec_sub1), 1);
42  is.read((char*)&(data._rec_type), 1);
43  is.read((char*)&(data._rec_sub2), 1);
44  is.read((char*)&(data._rec_sub3), 1);
45  is.read((char*)&(data._length), 4);
46  data.SwitchEndian(data._length);
47  return is;
48 }
◆ operator>>() [14/62]
Definition at line 38 of file PositionVectorRecord.cpp.
References ossimplugins::PositionVectorRecord::_pos, and ossimplugins::PositionVectorRecord::_vel.
39 {
40  char buf[23];
41  buf[22] = '\0';
42
43  for (int i=0;i<3;i++)
44  {
45  is.read(buf,22);
46  data._pos[i] = atof(buf);
47  }
48
49  for (int i=0;i<3;i++)
50  {
51  is.read(buf,22);
52  data._vel[i] = atof(buf);
53  }
54  return is;
55 }
◆ operator>>() [15/62]
Definition at line 38 of file AlosPalsarRecordHeader.cpp.
References ossimplugins::AlosPalsarRecordHeader::_length, ossimplugins::AlosPalsarRecordHeader::_rec_seq, ossimplugins::AlosPalsarRecordHeader::_rec_sub1, ossimplugins::AlosPalsarRecordHeader::_rec_sub2, ossimplugins::AlosPalsarRecordHeader::_rec_sub3, ossimplugins::AlosPalsarRecordHeader::_rec_type, and ossimplugins::AlosPalsarRecordHeader::SwitchEndian().
39 {
40  is.read((char*)&(data._rec_seq), 4); // TODO Change dangerous C-style cast to static cast.
41  data.SwitchEndian(data._rec_seq);
42  is.read((char*)&(data._rec_sub1), 1);
43  is.read((char*)&(data._rec_type), 1);
44  is.read((char*)&(data._rec_sub2), 1);
45  is.read((char*)&(data._rec_sub3), 1);
46  is.read((char*)&(data._length), 4);
47  data.SwitchEndian(data._length);
48  return is;
49 }
◆ operator>>() [16/62]
AttitudeData data
Definition at line 39 of file AttitudeData.cpp.
References ossimplugins::AttitudeData::_att_vect, ossimplugins::AttitudeData::_npoint, ossimplugins::AttitudeData::_pitch_bias, ossimplugins::AttitudeData::_roll_bias, and ossimplugins::AttitudeData::_yaw_bias.
40 {
41  char buf[6503];
42  buf[6502] = '\0';
43
44  is.read(buf,4);
45  buf[4] = '\0';
46  data._npoint = atoi(buf);
47
48  for (int i=0;i<20;i++)
49  {
50  is>>data._att_vect[i];
51  }
52  is.read(buf,14);
53  buf[14] = '\0';
54  data._pitch_bias = atof(buf);
55
56  is.read(buf,14);
57  buf[14] = '\0';
58  data._roll_bias = atof(buf);
59
60  is.read(buf,14);
61  buf[14] = '\0';
62  data._yaw_bias = atof(buf);
63
64  is.read(buf,6502);
65
66  return is;
67 }
◆ operator>>() [17/62]
Definition at line 39 of file AlosPalsarSignalData.cpp.
References ossimplugins::AlosPalsarSignalData::_pulse_repetition_frequency, ossimplugins::AlosPalsarSignalData::_slant_range_to_1st_data_sample, ossimEndian::getSystemEndianType(), OSSIM_LITTLE_ENDIAN, and ossimEndian::swap().
40 {
41  ossim_uint16 tmpuint16;
42  ossim_uint32 tmpuint32;
43  ossimEndian oe;
44
45  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
47  {
48  oe.swap(tmpuint32);
49  }
50 // std::cout << "Data line number = " << tmpuint32 << std::endl;
51
52  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
54  {
55  oe.swap(tmpuint32);
56  }
57 // std::cout << "Data record index = " << tmpuint32 << std::endl;
58
59  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
61  {
62  oe.swap(tmpuint32);
63  }
64 // std::cout << "Actual count of left-fill pixels = " << tmpuint32 << std::endl;
65
66  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
68  {
69  oe.swap(tmpuint32);
70  }
71 // std::cout << "Actual count of data pixels = " << tmpuint32 << std::endl;
72
73  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
75  {
76  oe.swap(tmpuint32);
77  }
78 // std::cout << "Actual count of right-fill pixels = " << tmpuint32 << std::endl;
79
80  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
82  {
83  oe.swap(tmpuint32);
84  }
85 // std::cout << "Sensor parameters update flag = " << tmpuint32 << std::endl;
86
87  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
89  {
90  oe.swap(tmpuint32);
91  }
92 // std::cout << "Scene start year = " << tmpuint32 << std::endl;
93
94  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
96  {
97  oe.swap(tmpuint32);
98  }
99 // std::cout << "Scene start day of year = " << tmpuint32 << std::endl;
100
101  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
103  {
104  oe.swap(tmpuint32);
105  }
106 // std::cout << "Sensor acquisition milliseconds of day = " << tmpuint32 << std::endl;
107
108  is.read(reinterpret_cast<char*>(&tmpuint16), 2);
110  {
111  oe.swap(tmpuint16);
112  }
113 // std::cout << "SAR channel indicator = " << tmpuint16 << std::endl;
114
115  is.read(reinterpret_cast<char*>(&tmpuint16), 2);
117  {
118  oe.swap(tmpuint16);
119  }
120 // std::cout << "SAR channel code = " << tmpuint16 << std::endl;
121
122  is.read(reinterpret_cast<char*>(&tmpuint16), 2);
124  {
125  oe.swap(tmpuint16);
126  }
127 // std::cout << "Transmitted polarization = " << tmpuint16 << std::endl;
128
129  is.read(reinterpret_cast<char*>(&tmpuint16), 2);
131  {
132  oe.swap(tmpuint16);
133  }
134 // std::cout << "Received polarization = " << tmpuint16 << std::endl;
135
136  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
138  {
139  oe.swap(tmpuint32);
140  }
141 // std::cout << "PRF (mHz) = " << tmpuint32 << std::endl;
142  data._pulse_repetition_frequency = static_cast<int>(tmpuint32);
143
144  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
146  {
147  oe.swap(tmpuint32);
148  }
149 // std::cout << "Scan ID for SCAN SAR mode = " << tmpuint32 << std::endl;
150
151  is.read(reinterpret_cast<char*>(&tmpuint16), 2);
153  {
154  oe.swap(tmpuint16);
155  }
156 // std::cout << "Onboard range compressed flag = " << tmpuint16 << std::endl;
157
158  is.seekg(50, std::ios_base::cur);
159
160  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
162  {
163  oe.swap(tmpuint32);
164  }
165 // std::cout << "Slant range to 1st data sample (m) = " << tmpuint32 << std::endl;
166  data._slant_range_to_1st_data_sample = static_cast<int>(tmpuint32);
167
168  is.read(reinterpret_cast<char*>(&tmpuint32), 4);
170  {
171  oe.swap(tmpuint32);
172  }
173 // std::cout << "Data record window position = " << tmpuint32 << std::endl;
174
175 // std::cout << std::endl << "File pointer location = " << is.tellg() << std::endl;
176 // std::cout << std::endl;
177
178  return is;
179 }
unsigned short ossim_uint16
unsigned int ossim_uint32
ossimByteOrder getSystemEndianType() const
Definition: ossimEndian.h:78
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
◆ operator>>() [18/62]
Definition at line 40 of file ErsSarPositionVectorRecord.cpp.
41 {
42  char buf[23];
43  buf[22] = '\0';
44
45  for (int i = 0; i < 3; i++)
46  {
47  is.read(buf, 22);
48  data._pos[i] = atof(buf);
49  }
50
51  for (int i = 0; i < 3; i++)
52  {
53  is.read(buf, 22);
54  data._vel[i] = atof(buf);
55  }
56  return is;
57 }
◆ operator>>() [19/62]
Definition at line 41 of file AlosPalsarPositionVectorRecord.cpp.
42 {
43  char buf[23];
44  buf[22] = '\0';
45
46  for (int i = 0; i < 3; i++)
47  {
48  is.read(buf, 22);
49  data._pos[i] = atof(buf);
50  }
51
52  for (int i = 0; i < 3; i++)
53  {
54  is.read(buf, 22);
55  data._vel[i] = atof(buf);
56  }
57  return is;
58 }
◆ operator>>() [20/62]
DataHistogramSignalData data
Definition at line 41 of file DataHistogramSignalData.cpp.
References ossimplugins::DataHistogramSignalData::_histogram, ossimplugins::DataHistogramSignalData::_ltab, ossimplugins::DataHistogramSignalData::_ntab, ossimplugins::DataHistogramSignalData::_rec_seq, and ossimplugins::DataHistogramSignalData::_sar_chn.
42 {
43  char buff[33];
44  buff[32] = '\0';
45
46
47  is.read(buff,4);
48  buff[4] = '\0';
49  data._rec_seq = atoi(buff);
50
51  is.read(buff,4);
52  buff[4] = '\0';
53  data._sar_chn = atoi(buff);
54
55  is.read(buff,8);
56  buff[8] = '\0';
57  data._ntab = atoi(buff);
58
59  is.read(buff,8);
60  buff[8] = '\0';
61  data._ltab = atoi(buff);
62
63  is>>data._histogram;
64
65  char tmp[14589];
66  tmp[14588] = '\0';
67  is.read(tmp, 14588);
68
69  return is;
70 }
◆ operator>>() [21/62]
DataHistogramProcessedData data
Definition at line 41 of file DataHistogramProcessedData.cpp.
References ossimplugins::DataHistogramProcessedData::_histogram1, ossimplugins::DataHistogramProcessedData::_histogram2, ossimplugins::DataHistogramProcessedData::_ltab, ossimplugins::DataHistogramProcessedData::_ntab, ossimplugins::DataHistogramProcessedData::_rec_seq, and ossimplugins::DataHistogramProcessedData::_sar_chn.
42 {
43  char buff[33];
44  buff[32] = '\0';
45
46  is.read(buff,4);
47  buff[4] = '\0';
48  data._rec_seq = atoi(buff);
49
50  is.read(buff,4);
51  buff[4] = '\0';
52  data._sar_chn = atoi(buff);
53
54  is.read(buff,8);
55  buff[8] = '\0';
56  data._ntab = atoi(buff);
57
58  is.read(buff,8);
59  buff[8] = '\0';
60  data._ltab = atoi(buff);
61
62  is>>data._histogram1;
63
64  is>>data._histogram2;
65
66  char tmp[5];
67  tmp[4] = '\0';
68  is.read(tmp, 4);
69  return is;
70 }
◆ operator>>() [22/62]
AntennaElevationPatterns data
Definition at line 41 of file AntennaElevationPatterns.cpp.
References ossimplugins::AntennaElevationPatterns::_attach_flag, ossimplugins::AntennaElevationPatterns::_elevation_pattern, ossimplugins::AntennaElevationPatterns::_swath, ossimplugins::AntennaElevationPatterns::_zero_doppler_time, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
42  {
43  char buf16[17];
44  buf16[16]='\0';
45  char buf12[13];
46  buf12[12] = '\0';
47  char buf3[4];
48  buf3[3] = '\0';
49  // char buf2[3];
50  // buf2[2] = '\0';
51 // char buf1[1]; // avoid not used warning
52
53  is.read(buf12,12);
54  data._zero_doppler_time = buf12;
55
56  is.read((char*)&(data._attach_flag),1);
57
58  is.read(buf3,3);
59  data._swath = buf3;
60
61  for (int i = 0; i<33; i++) {
62  is.read((char*)&(data._elevation_pattern[i]),4);
63  data.SwitchEndian(data._elevation_pattern[i]);
64  }
65
66  is.read(buf16,14);
67
68  return is;
69
70  }
◆ operator>>() [23/62]
RadiometricCompensationData data
Definition at line 41 of file RadiometricCompensationData.cpp.
References ossimplugins::RadiometricCompensationData::_chan_ind, ossimplugins::RadiometricCompensationData::_dset, ossimplugins::RadiometricCompensationData::_dset_size, ossimplugins::RadiometricCompensationData::_n_dset, and ossimplugins::RadiometricCompensationData::_seq_num.
42  {
43  char buf[9];
44  buf[8] = '\0';
45
46  is.read(buf,4);
47  buf[4] = '\0';
48  data._seq_num = atoi(buf);
49
50  is.read(buf,4);
51  buf[4] = '\0';
52  data._chan_ind = atoi(buf);
53
54  is.read(buf,8);
55  buf[8] = '\0';
56  data._n_dset = atoi(buf);
57
58  is.read(buf,8);
59  buf[8] = '\0';
60  data._dset_size = atoi(buf);
61
62  for (int i=0;i<4;i++)
63  {
64  is>> data._dset[i];
65  }
66
67  return is;
68  }
◆ operator>>() [24/62]
DataPointDataRecord data
Definition at line 43 of file DataPointDataRecord.cpp.
References ossimplugins::DataPointDataRecord::_gmt_day, ossimplugins::DataPointDataRecord::_gmt_sec, ossimplugins::DataPointDataRecord::_pitch, ossimplugins::DataPointDataRecord::_pitch_flag, ossimplugins::DataPointDataRecord::_pitch_rate, ossimplugins::DataPointDataRecord::_pitch_rate_flag, ossimplugins::DataPointDataRecord::_roll, ossimplugins::DataPointDataRecord::_roll_flag, ossimplugins::DataPointDataRecord::_roll_rate, ossimplugins::DataPointDataRecord::_roll_rate_flag, ossimplugins::DataPointDataRecord::_yaw, ossimplugins::DataPointDataRecord::_yaw_flag, ossimplugins::DataPointDataRecord::_yaw_rate, and ossimplugins::DataPointDataRecord::_yaw_rate_flag.
44 {
45  char buf[15];
46  buf[14] = '\0';
47
48  is.read(buf,4);
49  buf[4] = '\0';
50  data._gmt_day = atoi(buf);
51
52  is.read(buf,8);
53  buf[8] = '\0';
54  data._gmt_sec = atoi(buf);
55
56  is.read(buf,4);
57  buf[4] = '\0';
58  data._pitch_flag = atoi(buf);
59
60  is.read(buf,4);
61  buf[4] = '\0';
62  data._roll_flag = atoi(buf);
63
64  is.read(buf,4);
65  buf[4] = '\0';
66  data._yaw_flag = atoi(buf);
67
68  is.read(buf,14);
69  buf[14] = '\0';
70  data._pitch = atof(buf);
71
72  is.read(buf,14);
73  buf[14] = '\0';
74  data._roll = atof(buf);
75
76  is.read(buf,14);
77  buf[14] = '\0';
78  data._yaw = atof(buf);
79
80  is.read(buf,4);
81  buf[4] = '\0';
82  data._pitch_rate_flag = atoi(buf);
83
84  is.read(buf,4);
85  buf[4] = '\0';
86  data._roll_rate_flag = atoi(buf);
87
88  is.read(buf,4);
89  buf[4] = '\0';
90  data._yaw_rate_flag = atoi(buf);
91
92  is.read(buf,14);
93  buf[14] = '\0';
94  data._pitch_rate = atof(buf);
95
96  is.read(buf,14);
97  buf[14] = '\0';
98  data._roll_rate = atof(buf);
99
100  is.read(buf,14);
101  buf[14] = '\0';
102  data._yaw_rate = atof(buf);
103
104  return is;
105 }
◆ operator>>() [25/62]
FilePointerRecord data
Definition at line 45 of file FilePointerRecord.cpp.
References ossimplugins::FilePointerRecord::_ascii_flag, ossimplugins::FilePointerRecord::_data_code, ossimplugins::FilePointerRecord::_data_type, ossimplugins::FilePointerRecord::_file_class, ossimplugins::FilePointerRecord::_file_code, ossimplugins::FilePointerRecord::_file_name, ossimplugins::FilePointerRecord::_file_num, ossimplugins::FilePointerRecord::_first_len, ossimplugins::FilePointerRecord::_first_phyvol, ossimplugins::FilePointerRecord::_first_rec, ossimplugins::FilePointerRecord::_last_phyvol, ossimplugins::FilePointerRecord::_last_rec, ossimplugins::FilePointerRecord::_len_code, ossimplugins::FilePointerRecord::_len_type, ossimplugins::FilePointerRecord::_max_len, and ossimplugins::FilePointerRecord::_nrec.
46 {
47  char buf[349]; // 361-12 (size of header)
48  buf[348] = '\0';
49
50  is.read(buf, 2);
51  buf[2] = '\0';
52  data._ascii_flag = buf;
53
54  is.read(buf, 2); // spare1
55
56  is.read(buf, 4);
57  buf[4] = '\0';
58  data._file_num = atoi(buf);
59
60  is.read(buf, 16);
61  buf[16] = '\0';
62  data._file_name = buf;
63
64  is.read(buf, 28);
65  buf[28] = '\0';
66  data._file_class = buf;
67
68  is.read(buf, 4);
69  buf[4] = '\0';
70  data._file_code = buf;
71
72  is.read(buf, 28);
73  buf[28] = '\0';
74  data._data_type = buf;
75
76  is.read(buf, 4);
77  buf[4] = '\0';
78  data._data_code = buf;
79
80  is.read(buf, 8);
81  buf[8] = '\0';
82  data._nrec = atoi(buf);
83
84  is.read(buf, 8);
85  buf[8] = '\0';
86  data._first_len = atoi(buf);
87
88  is.read(buf, 8);
89  buf[8] = '\0';
90  data._max_len = atoi(buf);
91
92  is.read(buf, 12);
93  buf[12] = '\0';
94  data._len_type = buf;
95
96  is.read(buf, 4);
97  buf[4] = '\0';
98  data._len_code = buf;
99
100  is.read(buf, 2);
101  buf[2] = '\0';
102  data._first_phyvol = atoi(buf);
103
104  is.read(buf, 2);
105  buf[2] = '\0';
106  data._last_phyvol = atoi(buf);
107
108  is.read(buf, 8);
109  buf[8] = '\0';
110  data._first_rec = atoi(buf);
111
112  is.read(buf, 8);
113  buf[8] = '\0';
114  data._last_rec = atoi(buf);
115
116  is.read(buf, 100); // spare2
117
118  is.read(buf, 100); // spare3
119  return is;
120 }
◆ operator>>() [26/62]
VolumeDir data
Definition at line 46 of file VolumeDir.cpp.
References ossimplugins::VolumeDir::_records, ossimplugins::VolumeDir::ClearRecords(), ossimplugins::RadarSatRecordFactory::Instanciate(), and ossimplugins::RadarSatRecord::Read().
47 {
48  VolumeDirFactory factory;
49
50  data.ClearRecords();
51
52  RadarSatRecordHeader header;
53  bool eof = false;
54  while(!eof)
55  {
56  is>>header;
57  if(is.eof())
58  {
59  eof = true;
60  }
61  else
62  {
63  RadarSatRecord* record = factory.Instanciate(header.get_rec_seq());
64  if (record != NULL)
65  {
66  record->Read(is);
67  data._records[header.get_rec_seq()] = record;
68  }
69  else
70  {
71  char* buff = new char[header.get_length()-12];
72  is.read(buff, header.get_length()-12);
73  delete[] buff;
74  }
75  }
76  }
77  return is;
78 }
◆ operator>>() [27/62]
SRGRConversionParameters data
Definition at line 46 of file SRGRConversionParameters.cpp.
References ossimplugins::SRGRConversionParameters::_attach_flag, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_day, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_microsec, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_sec, ossimplugins::SRGRConversionParameters::_ground_range_origin, ossimplugins::SRGRConversionParameters::_slant_range_time, ossimplugins::SRGRConversionParameters::_srgr_coef, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
47  {
48  char buf14[15];
49  buf14[14] = '\0';
50  // char buf12[13];
51  // buf12[12] = '\0';
52
53
54  is.read((char*)&(data._first_zero_doppler_time_day),4);
55  data.SwitchEndian(data._first_zero_doppler_time_day);
56
57  is.read((char*)&(data._first_zero_doppler_time_sec),4);
58  data.SwitchEndian(data._first_zero_doppler_time_sec);
59
60  is.read((char*)&(data._first_zero_doppler_time_microsec),4);
61  data.SwitchEndian(data._first_zero_doppler_time_microsec);
62
63  is.read((char*)&(data._attach_flag),1);
64
65  is.read((char*)&(data._slant_range_time),4);
66  data.SwitchEndian(data._slant_range_time);
67
68  is.read((char*)&(data._ground_range_origin),4);
69  data.SwitchEndian(data._ground_range_origin);
70
71  for (int i = 0; i<5; i++) {
72  is.read((char*)&(data._srgr_coef[i]),4);
73  data.SwitchEndian(data._srgr_coef[i]);
74  }
75
76  is.read(buf14,14);
77
78  return is;
79  }
◆ operator>>() [28/62]
Data data
Definition at line 49 of file Data.cpp.
References ossimplugins::Data::_records, ossimplugins::Data::ClearRecords(), ossimplugins::Data::FirstProcessedDataRecordID, ossimplugins::Data::get_ImageOptionsFileDescriptor(), ossimplugins::Data::ImageOptionsFileDescriptorID, ossimplugins::RadarSatRecordFactory::Instanciate(), ossimplugins::Data::LastProcessedDataRecordID, ossimNotify(), ossimNotifyLevel_DEBUG, ossimNotifyLevel_WARN, ossimplugins::RadarSatRecord::Read(), and ossimplugins::ImageOptionsFileDescriptor::set_nlin().
50 {
51  DataFactory factory;
52
53  data.ClearRecords();
54
55  if (sizeof(int)!=4) ossimNotify(ossimNotifyLevel_WARN) << "RadarSat Data WARNING : (int) not coded over 32 bits, metadata might not be byte swapped correctly"<< std::endl ;
56  if (sizeof(float)!=4) ossimNotify(ossimNotifyLevel_WARN) << "RadarSat Data WARNING : (float) not coded over 32 bits, metadata might not be byte swapped correctly"<< std::endl ;
57  if (sizeof(double)!=8) ossimNotify(ossimNotifyLevel_WARN) << "RadarSat Data WARNING : (double) not coded over 64 bits, metadata might not be byte swapped correctly"<< std::endl ;
58
59  RadarSatRecordHeader header;
60  bool eof = false;
61
62  int nbLin = 0 ; // number of image lines
63  int lineLength = 0 ; // size of any ProcessedDataRecord
64
65  is.seekg(0, std::ios::end) ;
66  int lengthOfFile = is.tellg(); // total length of file
67  is.seekg(0, std::ios::beg);
68  while(!eof)
69  {
70  is>>header;
71  if(is.eof())
72  {
73  eof = true;
74  }
75  else
76  {
77  if (header.get_rec_seq() == 1)
78  { // ImageOptionsFileDescriptor
79  RadarSatRecord* record = factory.Instanciate(header.get_rec_seq());
80  if (record != NULL)
81  {
82  record->Read(is);
83  data._records[Data::ImageOptionsFileDescriptorID] = record;
84
85  nbLin = ((ImageOptionsFileDescriptor *) record)->get_nlin() ;
86  if (nbLin == -1)
87  {
88  ossimNotify(ossimNotifyLevel_DEBUG) << "WARNING: nbLin is not read in the file !" << std::endl;
89  }
90  }
91  else
92  {
93  char* buff = new char[header.get_length()-12];
94  is.read(buff, header.get_length()-12);
95  delete[] buff;
96  }
97  }
98  else if ((header.get_rec_seq() == 2))
99  { // First line ProcessedDataRecord
100  lineLength = header.get_length() ;
101  RadarSatRecord* record = factory.Instanciate(2);
102  if (record != NULL)
103  {
104  record->Read(is);
105  data._records[Data::FirstProcessedDataRecordID] = record;
106
107  char* buff = new char[header.get_length()-192];
108  is.read(buff, header.get_length()-192); // Reads the rest of the line
109  delete[] buff;
110  }
111  else
112  {
113  char* buff = new char[header.get_length()-12];
114  is.read(buff, header.get_length()-12);
115  delete[] buff;
116  }
117  }
118  else if ((header.get_rec_seq() == (1+nbLin)))
119  { // Last line ProcessedDataRecord
120  RadarSatRecord* record = factory.Instanciate(2);
121  if (record != NULL)
122  {
123  record->Read(is);
124  data._records[Data::LastProcessedDataRecordID] = record;
125
126  char* buff = new char[header.get_length()-192];
127  is.read(buff, header.get_length()-192); // Reads the rest of the line
128  delete[] buff;
129  }
130  else
131  {
132  char* buff = new char[header.get_length()-12];
133  is.read(buff, header.get_length()-12);
134  delete[] buff;
135  }
136  }
137  else
138  {
139  // all lines between the first and last ones are skipped
140  if (lineLength != 0)
141  {
142  if (nbLin == -1)
143  {
144  // Compute the number of line per dataset from the size of file and current position
145  int nbLines = ( ( lengthOfFile - is.tellg() ) / lineLength ) + 2;
146  ossimNotify(ossimNotifyLevel_DEBUG) << "To move in the dat file we compute the nb of lines = " << nbLines << std::endl;
147
148  // We move in the file to the last line
149  is.seekg((nbLines - 2) * lineLength - 12, std::ios::cur);
150
151  // We save the nbLines computed in data
152  nbLin = nbLines;
153  ImageOptionsFileDescriptor* record = data.get_ImageOptionsFileDescriptor();
154  record->set_nlin(nbLin);
155  data._records[Data::ImageOptionsFileDescriptorID] = record;
156  }
157  else
158  {
159  // We move in the file
160  is.seekg((nbLin - 2) * lineLength - 12, std::ios::cur);
161  }
162  }
163  else
164  {
165  // We move to the end of the file
166  is.seekg(0, std::ios::end) ;
167  }
168  }
169  }
170  }
171  return is;
172 }
◆ operator>>() [29/62]
Definition at line 49 of file EnvisatAsarData.cpp.
References ossimplugins::EnvisatAsarData::_records, ossimplugins::EnvisatAsarData::ClearRecords(), ossimplugins::EnvisatAsarRecordFactory::Instanciate(), and ossimplugins::EnvisatAsarRecord::Read().
50 {
51  EnvisatAsarDataFactory factory;
52
53  if (sizeof(int)!=4) std::cout << "EnvisatAsarData WARNING : (int) not coded over 32 bits, metadata might not be byte swapped correctly"<< std::endl ;
54  if (sizeof(float)!=4) std::cout << "EnvisatAsarData WARNING : (float) not coded over 32 bits, metadata might not be byte swapped correctly"<< std::endl ;
55  if (sizeof(double)!=8) std::cout << "EnvisatAsarData WARNING : (double) not coded over 64 bits, metadata might not be byte swapped correctly"<< std::endl ;
56
57  data.ClearRecords();
58
59  // read the first record (MPH)
60  EnvisatAsarRecord* mph_record = factory.Instanciate("MPH");
61  mph_record->Read(is);
62  data._records.push_back(mph_record);
63
64  // read the second record (sph) and update it with the mph (number of dsd)
65  EnvisatAsarRecord* sph_record = factory.Instanciate("SPH");
66  ((sph*)sph_record)->update_sph_from_mph(*((mph *)mph_record));
67  sph_record->Read(is);
68  data._records.push_back(sph_record);
69
70  std::vector<dsd> dsd_vector = ((sph*)sph_record)->get_dsd_vector();
71
72  // For each dsd, check if present in the file and in the record factory.
73  // If true, instanciate it and add to the EnvisatAsarRecord list.
74  std::vector<dsd>::iterator it = dsd_vector.begin();
75  while(it != dsd_vector.end())
76  {
77  std::string str = (it->get_ds_name());
78
79  if ( (it->get_ds_size()) != 0)
80  {
81  for (int i = 0; i<(it->get_num_dsr()); i++)
82  {
83  EnvisatAsarRecord* record = factory.Instanciate(str);
84  if (record != NULL)
85  {
86  is.seekg((std::streampos)(it->get_ds_offset())+ (std::streampos)(i*(it->get_dsr_size())));
87  record->Read(is);
88  data._records.push_back(record);
89  }
90  }
91  }
92  ++it;
93  }
94
95  return is;
96 }
◆ operator>>() [30/62]
CompensationDataRecord data
Definition at line 49 of file CompensationDataRecord.cpp.
References ossimplugins::CompensationDataRecord::_beam_tab, ossimplugins::CompensationDataRecord::_beam_tab_inc, ossimplugins::CompensationDataRecord::_beam_tab_size, ossimplugins::CompensationDataRecord::_beam_type, ossimplugins::CompensationDataRecord::_comp_descr, ossimplugins::CompensationDataRecord::_comp_desig, ossimplugins::CompensationDataRecord::_comp_seq_no, ossimplugins::CompensationDataRecord::_look_angle, and ossimplugins::CompensationDataRecord::_n_comp_rec.
50 {
51  char buf[33];
52  buf[32] = '\0';
53
54
55  is.read(buf,8);
56  buf[8] = '\0';
57  data._comp_desig = buf;
58
59  is.read(buf,32);
60  buf[32] = '\0';
61  data._comp_descr = buf;
62
63  is.read(buf,4);
64  buf[4] = '\0';
65  data._n_comp_rec = atoi(buf);
66
67  is.read(buf,4);
68  buf[4] = '\0';
69  data._comp_seq_no = atoi(buf);
70
71  is.read(buf,8);
72  buf[8] = '\0';
73  data._beam_tab_size = atoi(buf);
74
75  for (int i=0;i<256;i++)
76  {
77  is.read(buf,16);
78  buf[16] = '\0';
79  data._beam_tab[i] = atof(buf);
80  }
81
82  is.read(buf,16);
83  buf[16] = '\0';
84  data._beam_type = buf;
85
86  is.read(buf,16);
87  buf[16] = '\0';
88  data._look_angle = atof(buf);
89
90  is.read(buf,16);
91  buf[16] = '\0';
92  data._beam_tab_inc = atof(buf);
93
94  return is;
95 }
◆ operator>>() [31/62]
DopplerCentroidParameters data
Definition at line 53 of file DopplerCentroidParameters.cpp.
References ossimplugins::DopplerCentroidParameters::_attach_flag, ossimplugins::DopplerCentroidParameters::_delta_dopp_coeff, ossimplugins::DopplerCentroidParameters::_dop_coef, ossimplugins::DopplerCentroidParameters::_dop_conf, ossimplugins::DopplerCentroidParameters::_dop_conf_below_thresh_flag, ossimplugins::DopplerCentroidParameters::_slant_range_time, ossimplugins::DopplerCentroidParameters::_zero_doppler_time, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
54  {
55  // char buf64[65];
56  // buf64[64] = '\0';
57  // char buf32[33];
58  // buf32[32] = '\0';
59  // char buf27[28];
60  // buf27[27] = '\0';
61  // char buf20[21];
62  // buf20[20] = '\0';
63  // char buf16[17];
64  // buf16[16]='\0';
65  // char buf15[16];
66  // buf15[15] = '\0';
67  // char buf14[15];
68  // buf14[14] = '\0';
69  // char buf13[14];
70  // buf13[13] = '\0';
71  char buf12[13];
72  buf12[12] = '\0';
73  // char buf11[12];
74  // buf11[11] = '\0';
75  // char buf10[11];
76  // buf10[10] = '\0';
77  // char buf9[10];
78  // buf9[9] = '\0';
79  // char buf8[9];
80  // buf8[8] = '\0';
81  // char buf7[8];
82  // buf7[7] = '\0';
83  // char buf6[7];
84  // buf6[6] = '\0';
85  // char buf5[6];
86  // buf5[5] = '\0';
87  // char buf4[5];
88  // buf4[4] = '\0';
89  char buf3[4];
90  buf3[3] = '\0';
91  // char buf2[3];
92  // buf2[2] = '\0';
93 // char buf1[1]; // Not used avoid warning
94
95  is.read(buf12,12);
96  data._zero_doppler_time = buf12;
97
98  is.read((char*)&(data._attach_flag),1);
99
100  is.read((char*)&(data._slant_range_time),4);
101  data.SwitchEndian(data._slant_range_time);
102
103  for (int i = 0; i <5; i++) {
104  is.read((char*)&(data._dop_coef[i]),4);
105  data.SwitchEndian(data._dop_coef[i]);
106  }
107
108  is.read((char*)&(data._dop_conf),4);
109  data.SwitchEndian(data._dop_conf);
110
111  is.read((char*)&(data._dop_conf_below_thresh_flag),1);
112
113  for (int i = 0; i <5; i++) {
114  is.read((char*)&(data._delta_dopp_coeff[i]),2);
115  data.SwitchEndian(data._delta_dopp_coeff[i]);
116  }
117
118  is.read(buf3,3);
119
120  return is;
121
122  }
◆ operator>>() [32/62]
AlosPalsarData data
Definition at line 54 of file AlosPalsarData.cpp.
References ossimplugins::AlosPalsarData::_records, ossimplugins::AlosPalsarData::ClearRecords(), and ossimplugins::AlosPalsarRecord::Read().
55 {
56
58
59  AlosPalsarRecordHeader header;
60
61  is >> header;
62
63  AlosPalsarRecord* record = new AlosPalsarDataFileDescriptor;
65  {
68  }
69  else
70  {
72  is.read(buff, header.get_length() - 12);
73  delete [] buff;
74  }
75
76  std::streampos filePosition;
77
78  filePosition = is.tellg();
79  is >> header;
80
81  record = new AlosPalsarSignalData;
82
83  if (record != NULL)
84  {
85  record->Read(is);
86  data._records[header.get_rec_seq()] = record;
87 // std::cout << "Record sequence number = " << header.get_rec_seq() << std::endl;
88  }
89  is.seekg(filePosition); // Rewind file pointer to start of record
90  // Then, advance pointer to next record
91  is.seekg(static_cast<std::streamoff>(header.get_length()), std::ios::cur);
92
93  return is;
94 }
◆ operator>>() [33/62]
VolumeDescriptorRecord data
Definition at line 54 of file VolumeDescriptorRecord.cpp.
References ossimplugins::VolumeDescriptorRecord::_ascii_flag, ossimplugins::VolumeDescriptorRecord::_curr_phyvol, ossimplugins::VolumeDescriptorRecord::_first_file, ossimplugins::VolumeDescriptorRecord::_first_phyvol, ossimplugins::VolumeDescriptorRecord::_format_doc, ossimplugins::VolumeDescriptorRecord::_format_rev, ossimplugins::VolumeDescriptorRecord::_format_ver, ossimplugins::VolumeDescriptorRecord::_last_phyvol, ossimplugins::VolumeDescriptorRecord::_logvol_agency, ossimplugins::VolumeDescriptorRecord::_logvol_country, ossimplugins::VolumeDescriptorRecord::_logvol_date, ossimplugins::VolumeDescriptorRecord::_logvol_facility, ossimplugins::VolumeDescriptorRecord::_logvol_id, ossimplugins::VolumeDescriptorRecord::_logvol_time, ossimplugins::VolumeDescriptorRecord::_n_filepoint, ossimplugins::VolumeDescriptorRecord::_n_voldir, ossimplugins::VolumeDescriptorRecord::_phyvol_cnt, ossimplugins::VolumeDescriptorRecord::_phyvol_id, ossimplugins::VolumeDescriptorRecord::_phyvol_log, ossimplugins::VolumeDescriptorRecord::_product_id, ossimplugins::VolumeDescriptorRecord::_software_id, ossimplugins::VolumeDescriptorRecord::_volset_id, and ossimplugins::VolumeDescriptorRecord::_volset_log.
55 {
56  char buf[349]; // 361-12
57  buf[348] = '\0';
58
59  is.read(buf,2);
60  buf[2] = '\0';
61  data._ascii_flag = buf;
62
63  is.read(buf,2); // spare1
64
65  is.read(buf,12);
66  buf[12] = '\0';
67  data._format_doc = buf;
68
69  is.read(buf,2);
70  buf[2] = '\0';
71  data._format_ver = buf;
72
73  is.read(buf,2);
74  buf[2] = '\0';
75  data._format_rev = buf;
76
77  is.read(buf,12);
78  buf[12] = '\0';
79  data._software_id = buf;
80
81  is.read(buf,16);
82  buf[16] = '\0';
83  data._phyvol_id = buf;
84
85  is.read(buf,16);
86  buf[16] = '\0';
87  data._logvol_id = buf;
88
89  is.read(buf,16);
90  buf[16] = '\0';
91  data._volset_id = buf;
92
93  is.read(buf,2);
94  buf[2] = '\0';
95  data._phyvol_cnt = atoi(buf);
96
97  is.read(buf,2);
98  buf[2] = '\0';
99  data._first_phyvol = atoi(buf);
100
101  is.read(buf,2);
102  buf[2] = '\0';
103  data._last_phyvol = atoi(buf);
104
105  is.read(buf,2);
106  buf[2] = '\0';
107  data._curr_phyvol = atoi(buf);
108
109  is.read(buf,4);
110  buf[4] = '\0';
111  data._first_file = atoi(buf);
112
113  is.read(buf,4);
114  buf[4] = '\0';
115  data._volset_log = atoi(buf);
116
117  is.read(buf,4);
118  buf[4] = '\0';
119  data._phyvol_log = atoi(buf);
120
121  is.read(buf,8);
122  buf[8] = '\0';
123  data._logvol_date = buf;
124
125  is.read(buf,8);
126  buf[8] = '\0';
127  data._logvol_time = buf;
128
129  is.read(buf,12);
130  buf[12] = '\0';
131  data._logvol_country = buf;
132
133
134  is.read(buf,8);
135  buf[8] = '\0';
136  data._logvol_agency = buf;
137
138  is.read(buf,12);
139  buf[12] = '\0';
140  data._logvol_facility = buf;
141
142  is.read(buf,4);
143  buf[4] = '\0';
144  data._n_filepoint = atoi(buf);
145
146  is.read(buf,4);
147  buf[4] = '\0';
148  data._n_voldir = atoi(buf);
149
150  is.read(buf,92); // spare2
151
152  is.read(buf,8);
153  buf[8] = '\0';
154  data._product_id = buf;
155
156  is.read(buf,92); // spare3
157
158  return is;
159 }
◆ operator>>() [34/62]
RadiometricData data
Definition at line 57 of file RadiometricData.cpp.
References ossimplugins::RadiometricData::_calib_const, ossimplugins::RadiometricData::_chan_ind, ossimplugins::RadiometricData::_field_size, ossimplugins::RadiometricData::_lookup_tab, ossimplugins::RadiometricData::_n_data, ossimplugins::RadiometricData::_n_samp, ossimplugins::RadiometricData::_noise_scale, ossimplugins::RadiometricData::_offset, ossimplugins::RadiometricData::_samp_inc, ossimplugins::RadiometricData::_samp_type, ossimplugins::RadiometricData::_seq_num, and ossimplugins::RadiometricData::_table_desig.
58 {
59  char buf[1513];
60  buf[1512] = '\0';
61
62
63  is.read(buf,4);
64  buf[4] = '\0';
65  data._seq_num = atoi(buf);
66
67  is.read(buf,4);
68  buf[4] = '\0';
69  data._n_data = atoi(buf);
70
71  is.read(buf,8);
72  buf[8] = '\0';
73  data._field_size = atoi(buf);
74
75  is.read(buf,4);
76  buf[4] = '\0';
77  data._chan_ind = buf;
78
79  is.read(buf,4);
80
81  is.read(buf,24);
82  buf[24] = '\0';
83  data._table_desig = buf;
84
85  is.read(buf,8);
86  buf[8] = '\0';
87  data._n_samp = atoi(buf);
88
89  is.read(buf,16);
90  buf[16] = '\0';
91  data._samp_type = buf;
92
93  is.read(buf,4);
94  buf[4] = '\0';
95  data._samp_inc = atoi(buf);
96
97  for (int i=0;i<512;i++)
98  {
99  is.read(buf,16);
100  buf[16] = '\0';
101  data._lookup_tab[i] = atof(buf);
102  }
103
104  is.read(buf,4);
105
106  is.read(buf,16);
107  buf[16] = '\0';
108  data._noise_scale = atof(buf);
109
110  is.read(buf,16);
111
112  is.read(buf,16);
113  buf[16] = '\0';
114  data._offset = atof(buf);
115
116  is.read(buf,16);
117  buf[16] = '\0';
118  data._calib_const = atof(buf);
119
120  is.read(buf,1512);
121
122  return is;
123 }
◆ operator>>() [35/62]
Trailer data
Definition at line 59 of file Trailer.cpp.
References ossimplugins::Trailer::_records, ossimplugins::Trailer::ClearRecords(), ossimplugins::RadarSatRecordFactory::Instanciate(), and ossimplugins::RadarSatRecord::Read().
60 {
61  TrailerFactory factory;
62
63  data.ClearRecords();
64
65  RadarSatRecordHeader header;
66  bool eof = false;
67  while(!eof)
68  {
69  is>>header;
70  if(is.eof())
71  {
72  eof = true;
73  }
74  else
75  {
76  RadarSatRecord* record = factory.Instanciate(header.get_rec_seq());
77  if (record != NULL)
78  {
79  record->Read(is);
80  data._records[header.get_rec_seq()] = record;
81  }
82  else
83  {
84  char* buff = new char[header.get_length()-12];
85  is.read(buff, header.get_length()-12);
86  delete[] buff;
87  }
88  }
89  }
90  return is;
91 }
◆ operator>>() [36/62]
Definition at line 59 of file AlosPalsarLeader.cpp.
References ossimplugins::AlosPalsarLeader::_records, ossimplugins::AlosPalsarLeader::ClearRecords(), ossimplugins::AlosPalsarRecordFactory::Instanciate(), and ossimplugins::AlosPalsarRecord::Read().
60 {
61  AlosPalsarLeaderFactory factory;
62
64
65  AlosPalsarRecordHeader header;
67  while (!eof)
68  {
69  is >> header;
70  if (is.eof())
71  {
72  eof = true;
73  }
74  else
75  {
76  AlosPalsarRecord* record = factory.Instanciate(header.get_rec_seq());
78  {
81  }
82  else
83  {
84  if (header.get_length() > 12)
85  {
86  char* buff = new char[header.get_length()-12];
87  is.read(buff, header.get_length() - 12);
88  delete [] buff;
89  }
90  }
91  }
92  }
93  return is;
94 }
◆ operator>>() [37/62]
ErsSarLeader data
Definition at line 60 of file ErsSarLeader.cpp.
References ossimplugins::ErsSarLeader::ClearRecords(), ossimplugins::ErsSarRecordFactory::Instanciate(), ossimplugins::ErsSarRecord::Read(), and ossimplugins::ErsSarLeader::theRecords.
61 {
62  ErsSarLeaderFactory factory;
63
64  data.ClearRecords();
65
66  ErsSarRecordHeader header;
67  bool eof = false;
68  while (!eof)
69  {
70  is >> header;
71  if (is.eof())
72  {
73  eof = true;
74  }
75  else
76  {
77  ErsSarRecord* record = factory.Instanciate(header.get_rec_seq());
78  if (record != NULL)
79  {
80  record->Read(is);
81  data.theRecords[header.get_rec_seq()] = record;
82  }
83  else
84  {
85  char* buff = new char[header.get_length()-12];
86  is.read(buff, header.get_length() - 12);
87  delete [] buff;
88  }
89  }
90  }
91  return is;
92 }
◆ operator>>() [38/62]
ChirpParameters data
Definition at line 61 of file ChirpParameters.cpp.
References ossimplugins::ChirpParameters::_attach_flag, ossimplugins::ChirpParameters::_cal_pulse_info, ossimplugins::ChirpParameters::_chirp_islr, ossimplugins::ChirpParameters::_chirp_peak_loc, ossimplugins::ChirpParameters::_chirp_quality_flag, ossimplugins::ChirpParameters::_chirp_sidelobe, ossimplugins::ChirpParameters::_chirp_width, ossimplugins::ChirpParameters::_elev_chirp_power, ossimplugins::ChirpParameters::_normalisation_source, ossimplugins::ChirpParameters::_polar, ossimplugins::ChirpParameters::_re_chirp_power, ossimplugins::ChirpParameters::_ref_chirp_power, ossimplugins::ChirpParameters::_swath, ossimplugins::ChirpParameters::_zero_doppler_time, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
62  {
63  // char buf64[65];
64  // buf64[64] = '\0';
65  // char buf32[33];
66  // buf32[32] = '\0';
67  // char buf27[28];
68  // buf27[27] = '\0';
69  // char buf20[21];
70  // buf20[20] = '\0';
71  char buf16[17];
72  buf16[16]='\0';
73  // char buf15[16];
74  // buf15[15] = '\0';
75  // char buf14[15];
76  // buf14[14] = '\0';
77  // char buf13[14];
78  // buf13[13] = '\0';
79  char buf12[13];
80  buf12[12] = '\0';
81  // char buf11[12];
82  // buf11[11] = '\0';
83  // char buf10[11];
84  // buf10[10] = '\0';
85  // char buf9[10];
86  // buf9[9] = '\0';
87  // char buf8[9];
88  // buf8[8] = '\0';
89  char buf7[8];
90  buf7[7] = '\0';
91  // char buf6[7];
92  // buf6[6] = '\0';
93  // char buf5[6];
94  // buf5[5] = '\0';
95  char buf4[5];
96  buf4[4] = '\0';
97  char buf3[4];
98  buf3[3] = '\0';
99  // char buf2[3];
100  // buf2[2] = '\0';
101 // char buf1[1]; // not used avoid warning
102
103  is.read(buf12,12);
104  data._zero_doppler_time = buf12;
105
106  is.read((char*)&(data._attach_flag),1);
107
108  is.read(buf3,3);
109  data._swath = buf3;
110
111  is.read(buf3,3);
112  data._polar = buf3;
113
114  is.read((char*)&(data._chirp_width),4);
115  data.SwitchEndian(data._chirp_width);
116
117  is.read((char*)&(data._chirp_sidelobe),4);
118  data.SwitchEndian(data._chirp_sidelobe);
119
120  is.read((char*)&(data._chirp_islr),4);
121  data.SwitchEndian(data._chirp_islr);
122
123  is.read((char*)&(data._chirp_peak_loc),4);
124  data.SwitchEndian(data._chirp_peak_loc);
125
126  is.read((char*)&(data._re_chirp_power),4);
127  data.SwitchEndian(data._re_chirp_power);
128
129  is.read((char*)&(data._elev_chirp_power),4);
130  data.SwitchEndian(data._elev_chirp_power);
131
132  is.read((char*)&(data._chirp_quality_flag),1);
133  data.SwitchEndian(data._chirp_quality_flag);
134
135  is.read((char*)&(data._ref_chirp_power),4);
136  data.SwitchEndian(data._ref_chirp_power);
137
138  is.read(buf7,7);
139  data._normalisation_source = buf7;
140
141  is.read(buf4,4);
142
143  for (int i = 0; i<352; i++) {
144  is.read((char*)&(data._cal_pulse_info[i]),4);
145  data.SwitchEndian(data._cal_pulse_info[i]);
146  }
147
148  is.read(buf16,16);
149
150  return is;
151
152  }
◆ operator>>() [39/62]
Leader data
Definition at line 64 of file Leader.cpp.
References ossimplugins::Leader::_records, ossimplugins::Leader::ClearRecords(), ossimplugins::RadarSatRecordFactory::Instanciate(), and ossimplugins::RadarSatRecord::Read().
65 {
66  LeaderFactory factory;
67
68  data.ClearRecords();
69
70  RadarSatRecordHeader header;
71  bool eof = false;
72  while(!eof)
73  {
74  is>>header;
75  if(is.eof())
76  {
77  eof = true;
78  }
79  else
80  {
81  RadarSatRecord* record;
82  if ( (header.get_rec_seq() == 2) && (header.get_length() == 8960) )
83  {
84  record = factory.Instanciate(header.get_rec_seq() + 5); // case of SCN, SCW
85  if (record != NULL)
86  {
88  data._records[header.get_rec_seq() + 5] = record;
89  }
90  else
91  {
92  char* buff = new char[header.get_length()-12];
93  is.read(buff, header.get_length()-12);
94  delete[] buff;
95  }
96  }
97  else
98  {
99  record = factory.Instanciate(header.get_rec_seq());
100  if (record != NULL)
101  {
102  record->Read(is);
103  data._records[header.get_rec_seq()] = record;
104  }
105  else
106  {
107  char* buff = new char[header.get_length()-12];
108  is.read(buff, header.get_length()-12);
109  delete[] buff;
110  }
111  }
112  }
113  }
114  return is;
115 }
◆ operator>>() [40/62]
GeolocationGrid data
Definition at line 69 of file GeolocationGrid.cpp.
References ossimplugins::GeolocationGrid::_angles, ossimplugins::GeolocationGrid::_attach_flag, ossimplugins::GeolocationGrid::_first_zero_doppler_time_day, ossimplugins::GeolocationGrid::_first_zero_doppler_time_microsec, ossimplugins::GeolocationGrid::_first_zero_doppler_time_sec, ossimplugins::GeolocationGrid::_last_line_tie_points, ossimplugins::GeolocationGrid::_last_zero_doppler_time, ossimplugins::GeolocationGrid::_lats, ossimplugins::GeolocationGrid::_line_num, ossimplugins::GeolocationGrid::_longs, ossimplugins::GeolocationGrid::_num_lines, ossimplugins::GeolocationGrid::_samp_numbers, ossimplugins::GeolocationGrid::_slant_range_times, ossimplugins::GeolocationGrid::_sub_sat_track, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
70  {
71  char buf220[221];
72  buf220[220] = '\0';
73  char buf32[33];
74  buf32[32] = '\0';
75  // char buf27[28];
76  // buf27[27] = '\0';
77  // char buf20[21];
78  // buf20[20] = '\0';
79  // char buf16[17];
80  // buf16[16]='\0';
81  // char buf15[16];
82  // buf15[15] = '\0';
83  // char buf14[15];
84  // buf14[14] = '\0';
85  // char buf13[14];
86  // buf13[13] = '\0';
87  char buf12[13];
88  buf12[12] = '\0';
89  // char buf11[12];
90  // buf11[11] = '\0';
91  // char buf10[11];
92  // buf10[10] = '\0';
93  // char buf9[10];
94  // buf9[9] = '\0';
95  // char buf8[9];
96  // buf8[8] = '\0';
97  // char buf7[8];
98  // buf7[7] = '\0';
99  // char buf6[7];
100  // buf6[6] = '\0';
101  // char buf5[6];
102  // buf5[5] = '\0';
103  // char buf4[5];
104  // buf4[4] = '\0';
105  // char buf3[4];
106  // buf3[3] = '\0';
107  // char buf2[3];
108  // buf2[2] = '\0';
109 // char buf1[1]; // not used avoid warning
110
111  is.read((char*)&(data._first_zero_doppler_time_day),4);
112  data.SwitchEndian(data._first_zero_doppler_time_day);
113
114  is.read((char*)&(data._first_zero_doppler_time_sec),4);
115  data.SwitchEndian(data._first_zero_doppler_time_sec);
116
117  is.read((char*)&(data._first_zero_doppler_time_microsec),4);
118  data.SwitchEndian(data._first_zero_doppler_time_microsec);
119
120  is.read((char*)&(data._attach_flag),1);
121
122  is.read((char*)&(data._line_num),4);
123  data.SwitchEndian(data._line_num);
124
125  is.read((char*)&(data._num_lines),4);
126  data.SwitchEndian(data._num_lines);
127
128  is.read((char*)&(data._sub_sat_track),4);
129  data.SwitchEndian(data._sub_sat_track);
130
131  for (int i = 0; i<11; i++) {
132  is.read((char*)&(data._samp_numbers[i]),4);
133  data.SwitchEndian(data._samp_numbers[i]);
134  }
135
136  for (int i = 0; i<11; i++) {
137  is.read((char*)&(data._slant_range_times[i]),4);
138  data.SwitchEndian(data._slant_range_times[i]);
139  }
140
141  for (int i = 0; i<11; i++) {
142  is.read((char*)&(data._angles[i]),4);
143  data.SwitchEndian(data._angles[i]);
144  }
145
146  for (int i = 0; i<11; i++) {
147  is.read((char*)&(data._lats[i]),4);
148  data.SwitchEndian(data._lats[i]);
149  }
150
151  for (int i = 0; i<11; i++) {
152  is.read((char*)&(data._longs[i]),4);
153  data.SwitchEndian(data._longs[i]);
154  }
155
156  is.read(buf32,22);
157
158  is.read(buf12,12);
159  data._last_zero_doppler_time = buf12;
160
161  is.read(buf220,220);
162  data._last_line_tie_points = buf220;
163
164  is.read(buf32,22);
165
166  return is;
167
168  }
◆ operator>>() [41/62]
PlatformPositionData data
Definition at line 71 of file PlatformPositionData.cpp.
References ossimplugins::PlatformPositionData::_alt_poserr, ossimplugins::PlatformPositionData::_alt_velerr, ossimplugins::PlatformPositionData::_crt_poserr, ossimplugins::PlatformPositionData::_crt_velerr, ossimplugins::PlatformPositionData::_data_int, ossimplugins::PlatformPositionData::_day, ossimplugins::PlatformPositionData::_gmt_day, ossimplugins::PlatformPositionData::_gmt_sec, ossimplugins::PlatformPositionData::_hr_angle, ossimplugins::PlatformPositionData::_month, ossimplugins::PlatformPositionData::_ndata, ossimplugins::PlatformPositionData::_orbit_ele, ossimplugins::PlatformPositionData::_orbit_ele_desg, ossimplugins::PlatformPositionData::_pos_vect, ossimplugins::PlatformPositionData::_rad_poserr, ossimplugins::PlatformPositionData::_rad_velerr, ossimplugins::PlatformPositionData::_ref_coord, and ossimplugins::PlatformPositionData::_year.
72 {
73  char buf[1207];
74  buf[1206] = '\0';
75
76  is.read(buf,32);
77  buf[32] = '\0';
78  data._orbit_ele_desg = buf;
79
80  for(int i=0;i<6;i++)
81  {
82  is.read(buf,16);
83  buf[16] = '\0';
84  data._orbit_ele[i] = atof(buf);
85  }
86
87  is.read(buf,4);
88  buf[4] = '\0';
89  data._ndata = atoi(buf);
90
91  is.read(buf,4);
92  buf[4] = '\0';
93  data._year = atoi(buf);
94
95  is.read(buf,4);
96  buf[4] = '\0';
97  data._month = atoi(buf);
98
99  is.read(buf,4);
100  buf[4] = '\0';
101  data._day = atoi(buf);
102
103  is.read(buf,4);
104  buf[4] = '\0';
105  data._gmt_day = atoi(buf);
106
107  is.read(buf,22);
108  buf[22] = '\0';
109  data._gmt_sec = atof(buf);
110
111  is.read(buf,22);
112  buf[22] = '\0';
113  data._data_int = atof(buf);
114
115  is.read(buf,64);
116  buf[64] = '\0';
117  data._ref_coord = buf;
118
119  is.read(buf,22);
120  buf[22] = '\0';
121  data._hr_angle = atof(buf);
122
123  is.read(buf,16);
124  buf[16] = '\0';
125  data._alt_poserr = atof(buf);
126
127  is.read(buf,16);
128  buf[16] = '\0';
129  data._crt_poserr = atof(buf);
130
131  is.read(buf,16);
132  buf[16] = '\0';
133  data._rad_poserr = atof(buf);
134
135  is.read(buf,16);
136  buf[16] = '\0';
137  data._alt_velerr = atof(buf);
138
139  is.read(buf,16);
140  buf[16] = '\0';
141  data._crt_velerr = atof(buf);
142
143  is.read(buf,16);
144  buf[16] = '\0';
145  data._rad_velerr = atof(buf);
146
147  for (int i=0;i<64;i++)
148  {
149  is>>data._pos_vect[i];
150  }
151
152  is.read(buf,126);
153
154
155  return is;
156 }
◆ operator>>() [42/62]
ErsSarMapProjectionData data
Definition at line 71 of file ErsSarMapProjectionData.cpp.
References ossimplugins::ErsSarMapProjectionData::_asc_node_long, ossimplugins::ErsSarMapProjectionData::_first_line_first_pixel_lat, ossimplugins::ErsSarMapProjectionData::_first_line_first_pixel_lon, ossimplugins::ErsSarMapProjectionData::_first_line_last_pixel_lat, ossimplugins::ErsSarMapProjectionData::_first_line_last_pixel_lon, ossimplugins::ErsSarMapProjectionData::_last_line_first_pixel_lat, ossimplugins::ErsSarMapProjectionData::_last_line_first_pixel_lon, ossimplugins::ErsSarMapProjectionData::_last_line_last_pixel_lat, ossimplugins::ErsSarMapProjectionData::_last_line_last_pixel_lon, ossimplugins::ErsSarMapProjectionData::_map_proj_des, ossimplugins::ErsSarMapProjectionData::_name_of_ref_ellipsoid, ossimplugins::ErsSarMapProjectionData::_nom_interline_dist, ossimplugins::ErsSarMapProjectionData::_nom_interpixel_dist, ossimplugins::ErsSarMapProjectionData::_num_lines, ossimplugins::ErsSarMapProjectionData::_num_pix_in_line, ossimplugins::ErsSarMapProjectionData::_orbit_incl, ossimplugins::ErsSarMapProjectionData::_orientation_at_center, ossimplugins::ErsSarMapProjectionData::_platform_heading, ossimplugins::ErsSarMapProjectionData::_semi_maj_axis, and ossimplugins::ErsSarMapProjectionData::_semi_min_axis.
72  {
73  char buf16[17];
74  buf16[16] = '\0';
75  char buf32[33];
76  buf32[32] = '\0';
77  // char buf8[9];
78  // buf8[8] = '\0';
79  // char buf4[5];
80  // buf4[4] = '\0';
81
82  is.read(buf16, 16);
83
84  is.read(buf32, 32);
85  data._map_proj_des = buf32;
86
87  is.read(buf16, 16);
88  data._num_pix_in_line = atoi(buf16);
89
90  is.read(buf16, 16);
91  data._num_lines = atoi(buf16);
92
93  is.read(buf16, 16);
94  data._nom_interpixel_dist = atof(buf16);
95
96  is.read(buf16, 16);
97  data._nom_interline_dist = atof(buf16);
98
99  is.read(buf16, 16);
100  data._orientation_at_center = atof(buf16);
101
102  is.read(buf16, 16);
103  data._orbit_incl = atof(buf16);
104
105  is.read(buf16, 16);
106  data._asc_node_long = atof(buf16);
107
108  is.read(buf16, 16);
109
110  is.read(buf16, 16);
111
112  is.read(buf16, 16);
113
114  is.read(buf16, 16);
115  data._platform_heading = atof(buf16);
116
117  is.read(buf32, 32);
118  data._name_of_ref_ellipsoid = buf32;
119
120  is.read(buf16, 16);
121  data._semi_maj_axis = atof(buf16);
122
123  is.read(buf16, 16);
124  data._semi_min_axis = atof(buf16);
125
126  char buf772[772];
127  is.read(buf772, 772);
128
129  is.read(buf16, 16);
130  data._first_line_first_pixel_lat = atof(buf16);
131
132  is.read(buf16, 16);
133  data._first_line_first_pixel_lon = atof(buf16);
134
135  is.read(buf16, 16);
136  data._first_line_last_pixel_lat = atof(buf16);
137
138  is.read(buf16, 16);
139  data._first_line_last_pixel_lon = atof(buf16);
140
141  is.read(buf16, 16);
142  data._last_line_last_pixel_lat = atof(buf16);
143
144  is.read(buf16, 16);
145  data._last_line_last_pixel_lon = atof(buf16);
146
147  is.read(buf16, 16);
148  data._last_line_first_pixel_lat = atof(buf16);
149
150  is.read(buf16, 16);
151  data._last_line_first_pixel_lon = atof(buf16);
152
153  char buf420[420];
154  is.read(buf420, 420);
155
156  return is;
157  }
◆ operator>>() [43/62]
AlosPalsarMapProjectionData data
Definition at line 72 of file AlosPalsarMapProjectionData.cpp.
References ossimplugins::AlosPalsarMapProjectionData::_asc_node_long, ossimplugins::AlosPalsarMapProjectionData::_first_line_first_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_first_line_first_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_first_line_last_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_first_line_last_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_last_line_first_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_last_line_first_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_last_line_last_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_last_line_last_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_map_proj_des, ossimplugins::AlosPalsarMapProjectionData::_name_of_ref_ellipsoid, ossimplugins::AlosPalsarMapProjectionData::_nom_interline_dist, ossimplugins::AlosPalsarMapProjectionData::_nom_interpixel_dist, ossimplugins::AlosPalsarMapProjectionData::_num_lines, ossimplugins::AlosPalsarMapProjectionData::_num_pix_in_line, ossimplugins::AlosPalsarMapProjectionData::_orbit_incl, ossimplugins::AlosPalsarMapProjectionData::_orientation_at_center, ossimplugins::AlosPalsarMapProjectionData::_platform_heading, ossimplugins::AlosPalsarMapProjectionData::_semi_maj_axis, and ossimplugins::AlosPalsarMapProjectionData::_semi_min_axis.
73  {
74  char buf16[17];
75  buf16[16] = '\0';
76  char buf32[33];
77  buf32[32] = '\0';
78  // char buf8[9];
79  // buf8[8] = '\0';
80  // char buf4[5];
81  // buf4[4] = '\0';
82
83  is.read(buf16, 16);
84
85  is.read(buf32, 32);
86  data._map_proj_des = buf32;
87
88  is.read(buf16, 16);
89  data._num_pix_in_line = atoi(buf16);
90
91  is.read(buf16, 16);
92  data._num_lines = atoi(buf16);
93
94  is.read(buf16, 16);
95  data._nom_interpixel_dist = atof(buf16);
96
97  is.read(buf16, 16);
98  data._nom_interline_dist = atof(buf16);
99
100  is.read(buf16, 16);
101  data._orientation_at_center = atof(buf16);
102
103  is.read(buf16, 16);
104  data._orbit_incl = atof(buf16);
105
106  is.read(buf16, 16);
107  data._asc_node_long = atof(buf16);
108
109  is.read(buf16, 16);
110
111  is.read(buf16, 16);
112
113  is.read(buf16, 16);
114
115  is.read(buf16, 16);
116  data._platform_heading = atof(buf16);
117
118  is.read(buf32, 32);
119  data._name_of_ref_ellipsoid = buf32;
120
121  is.read(buf16, 16);
122  data._semi_maj_axis = atof(buf16);
123
124  is.read(buf16, 16);
125  data._semi_min_axis = atof(buf16);
126
127  char buf772[772];
128  is.read(buf772, 772);
129
130  is.read(buf16, 16);
131  data._first_line_first_pixel_lat = atof(buf16);
132
133  is.read(buf16, 16);
134  data._first_line_first_pixel_lon = atof(buf16);
135
136  is.read(buf16, 16);
137  data._first_line_last_pixel_lat = atof(buf16);
138
139  is.read(buf16, 16);
140  data._first_line_last_pixel_lon = atof(buf16);
141
142  is.read(buf16, 16);
143  data._last_line_last_pixel_lat = atof(buf16);
144
145  is.read(buf16, 16);
146  data._last_line_last_pixel_lon = atof(buf16);
147
148  is.read(buf16, 16);
149  data._last_line_first_pixel_lat = atof(buf16);
150
151  is.read(buf16, 16);
152  data._last_line_first_pixel_lon = atof(buf16);
153
154  char buf420[420];
155  is.read(buf420, 420);
156
157  return is;
158  }
◆ operator>>() [44/62]
ErsSarPlatformPositionData data
Definition at line 73 of file ErsSarPlatformPositionData.cpp.
References ossimplugins::ErsSarPlatformPositionData::_alt_poserr, ossimplugins::ErsSarPlatformPositionData::_alt_velerr, ossimplugins::ErsSarPlatformPositionData::_crt_poserr, ossimplugins::ErsSarPlatformPositionData::_crt_velerr, ossimplugins::ErsSarPlatformPositionData::_data_int, ossimplugins::ErsSarPlatformPositionData::_day, ossimplugins::ErsSarPlatformPositionData::_gmt_day, ossimplugins::ErsSarPlatformPositionData::_gmt_sec, ossimplugins::ErsSarPlatformPositionData::_hr_angle, ossimplugins::ErsSarPlatformPositionData::_month, ossimplugins::ErsSarPlatformPositionData::_ndata, ossimplugins::ErsSarPlatformPositionData::_orbit_ele, ossimplugins::ErsSarPlatformPositionData::_orbit_ele_desg, ossimplugins::ErsSarPlatformPositionData::_pos_vect, ossimplugins::ErsSarPlatformPositionData::_rad_poserr, ossimplugins::ErsSarPlatformPositionData::_rad_velerr, ossimplugins::ErsSarPlatformPositionData::_ref_coord, and ossimplugins::ErsSarPlatformPositionData::_year.
74 {
75  char buf[1207];
76  buf[1206] = '\0';
77
78  is.read(buf, 32);
79  buf[32] = '\0';
80  data._orbit_ele_desg = buf;
81
82  for (int i = 0; i < 6; i++)
83  {
84  is.read(buf, 16);
85  buf[16] = '\0';
86  data._orbit_ele[i] = atof(buf);
87  }
88
89  is.read(buf, 4);
90  buf[4] = '\0';
91  data._ndata = atoi(buf);
92
93  is.read(buf, 4);
94  buf[4] = '\0';
95  data._year = atoi(buf);
96
97  is.read(buf, 4);
98  buf[4] = '\0';
99  data._month = atoi(buf);
100
101  is.read(buf, 4);
102  buf[4] = '\0';
103  data._day = atoi(buf);
104
105  is.read(buf, 4);
106  buf[4] = '\0';
107  data._gmt_day = atoi(buf);
108
109  is.read(buf, 22);
110  buf[22] = '\0';
111  data._gmt_sec = atof(buf);
112
113  is.read(buf, 22);
114  buf[22] = '\0';
115  data._data_int = atof(buf);
116
117  is.read(buf, 64);
118  buf[64] = '\0';
119  data._ref_coord = buf;
120
121  is.read(buf, 22);
122  buf[22] = '\0';
123  data._hr_angle = atof(buf);
124
125  is.read(buf, 16);
126  buf[16] = '\0';
127  data._alt_poserr = atof(buf);
128
129  is.read(buf, 16);
130  buf[16] = '\0';
131  data._crt_poserr = atof(buf);
132
133  is.read(buf, 16);
134  buf[16] = '\0';
135  data._rad_poserr = atof(buf);
136
137  is.read(buf, 16);
138  buf[16] = '\0';
139  data._alt_velerr = atof(buf);
140
141  is.read(buf, 16);
142  buf[16] = '\0';
143  data._crt_velerr = atof(buf);
144
145  is.read(buf, 16);
146  buf[16] = '\0';
147  data._rad_velerr = atof(buf);
148
149  for (int i = 0; i < data._ndata; i++)
150  {
151  is >> data._pos_vect[i];
152  }
153
154  return is;
155 }
◆ operator>>() [45/62]
std::istream& ossimplugins::operator>> ( std::istream &  is,
AlosPalsarPlatformPositionData data
Definition at line 74 of file AlosPalsarPlatformPositionData.cpp.
References ossimplugins::AlosPalsarPlatformPositionData::_alt_poserr, ossimplugins::AlosPalsarPlatformPositionData::_alt_velerr, ossimplugins::AlosPalsarPlatformPositionData::_crt_poserr, ossimplugins::AlosPalsarPlatformPositionData::_crt_velerr, ossimplugins::AlosPalsarPlatformPositionData::_data_int, ossimplugins::AlosPalsarPlatformPositionData::_day, ossimplugins::AlosPalsarPlatformPositionData::_gmt_day, ossimplugins::AlosPalsarPlatformPositionData::_gmt_sec, ossimplugins::AlosPalsarPlatformPositionData::_hr_angle, ossimplugins::AlosPalsarPlatformPositionData::_month, ossimplugins::AlosPalsarPlatformPositionData::_ndata, ossimplugins::AlosPalsarPlatformPositionData::_orbit_ele, ossimplugins::AlosPalsarPlatformPositionData::_orbit_ele_desg, ossimplugins::AlosPalsarPlatformPositionData::_pos_vect, ossimplugins::AlosPalsarPlatformPositionData::_rad_poserr, ossimplugins::AlosPalsarPlatformPositionData::_rad_velerr, ossimplugins::AlosPalsarPlatformPositionData::_ref_coord, and ossimplugins::AlosPalsarPlatformPositionData::_year.
75 {
76  char buf[1207];
77  buf[1206] = '\0';
78
79  is.read(buf, 32);
80  buf[32] = '\0';
81  data._orbit_ele_desg = buf;
82
83  for (int i = 0; i < 6; i++)
84  {
85  is.read(buf, 16);
86  buf[16] = '\0';
87  data._orbit_ele[i] = atof(buf);
88  }
89
90  is.read(buf, 4);
91  buf[4] = '\0';
92  data._ndata = atoi(buf);
93
94  is.read(buf, 4);
95  buf[4] = '\0';
96  data._year = atoi(buf);
97
98  is.read(buf, 4);
99  buf[4] = '\0';
100  data._month = atoi(buf);
101
102  is.read(buf, 4);
103  buf[4] = '\0';
104  data._day = atoi(buf);
105
106  is.read(buf, 4);
107  buf[4] = '\0';
108  data._gmt_day = atoi(buf);
109
110  is.read(buf, 22);
111  buf[22] = '\0';
112  data._gmt_sec = atof(buf);
113
114  is.read(buf, 22);
115  buf[22] = '\0';
116  data._data_int = atof(buf);
117
118  is.read(buf, 64);
119  buf[64] = '\0';
120  data._ref_coord = buf;
121
122  is.read(buf, 22);
123  buf[22] = '\0';
124  data._hr_angle = atof(buf);
125
126  is.read(buf, 16);
127  buf[16] = '\0';
128  data._alt_poserr = atof(buf);
129
130  is.read(buf, 16);
131  buf[16] = '\0';
132  data._crt_poserr = atof(buf);
133
134  is.read(buf, 16);
135  buf[16] = '\0';
136  data._rad_poserr = atof(buf);
137
138  is.read(buf, 16);
139  buf[16] = '\0';
140  data._alt_velerr = atof(buf);
141
142  is.read(buf, 16);
143  buf[16] = '\0';
144  data._crt_velerr = atof(buf);
145
146  is.read(buf, 16);
147  buf[16] = '\0';
148  data._rad_velerr = atof(buf);
149
150  for (int i = 0; i < data._ndata; i++)
151  {
152  is >> data._pos_vect[i];
153  }
154
155  is.seekg(598, std::ios::cur); //skip the rest of the platform position data record
156  is.seekg(8192, std::ios::cur); //skip to the radiometric data record
157  //is.seekg(12495744, std::ios::cur); //skip to the 11th facility-related data record
158
159  return is;
160 }
◆ operator>>() [46/62]
FileDescriptor data
Definition at line 77 of file FileDescriptor.cpp.
References ossimplugins::FileDescriptor::_ascii_flag, ossimplugins::FileDescriptor::_code_len, ossimplugins::FileDescriptor::_code_loc, ossimplugins::FileDescriptor::_design_rev, ossimplugins::FileDescriptor::_file_name, ossimplugins::FileDescriptor::_file_num, ossimplugins::FileDescriptor::_format_doc, ossimplugins::FileDescriptor::_format_ver, ossimplugins::FileDescriptor::_l_anno_data, ossimplugins::FileDescriptor::_l_att_data, ossimplugins::FileDescriptor::_l_cal, ossimplugins::FileDescriptor::_l_data_his, ossimplugins::FileDescriptor::_l_dataset, ossimplugins::FileDescriptor::_l_dem_desc, ossimplugins::FileDescriptor::_l_det_proc, ossimplugins::FileDescriptor::_l_fac_data, ossimplugins::FileDescriptor::_l_gcp, ossimplugins::FileDescriptor::_l_map_proj, ossimplugins::FileDescriptor::_l_plat_pos, ossimplugins::FileDescriptor::_l_qual_sum, ossimplugins::FileDescriptor::_l_radar_par, ossimplugins::FileDescriptor::_l_radi_comp, ossimplugins::FileDescriptor::_l_radi_data, ossimplugins::FileDescriptor::_l_rang_spec, ossimplugins::FileDescriptor::_n_anno_data, ossimplugins::FileDescriptor::_n_att_data, ossimplugins::FileDescriptor::_n_cal, ossimplugins::FileDescriptor::_n_data_his, ossimplugins::FileDescriptor::_n_dataset, ossimplugins::FileDescriptor::_n_dem_desc, ossimplugins::FileDescriptor::_n_det_proc, ossimplugins::FileDescriptor::_n_fac_data, ossimplugins::FileDescriptor::_n_gcp, ossimplugins::FileDescriptor::_n_map_proj, ossimplugins::FileDescriptor::_n_plat_pos, ossimplugins::FileDescriptor::_n_qual_sum, ossimplugins::FileDescriptor::_n_radar_par, ossimplugins::FileDescriptor::_n_radi_comp, ossimplugins::FileDescriptor::_n_radi_data, ossimplugins::FileDescriptor::_n_rang_spec, ossimplugins::FileDescriptor::_rec_code, ossimplugins::FileDescriptor::_rec_len, ossimplugins::FileDescriptor::_rec_seq, ossimplugins::FileDescriptor::_rlen_len, ossimplugins::FileDescriptor::_rlen_loc, ossimplugins::FileDescriptor::_seq_len, ossimplugins::FileDescriptor::_seq_loc, and ossimplugins::FileDescriptor::_software_id.
78 {
79  char buf2[3];
80  buf2[2] = '\0';
81  char buf12[13];
82  buf12[12] = '\0';
83  char buf16[17];
84  buf16[16] = '\0';
85  char buf4[5];
86  buf4[4] = '\0';
87  char buf6[7];
88  buf6[6] = '\0';
89  char buf8[9];
90  buf8[8] = '\0';
91  char buf64[65];
92  buf64[64] = '\0';
93
94  char buf60[61];
95  buf60[60] = '\0';
96
97  char buf288[289];
98  buf288[288] = '\0';
99
100  is.read(buf2,2);
101  data._ascii_flag = buf2;
102
103  is.read(buf2,2);
104
105  is.read(buf12,12);
106  data._format_doc = buf12;
107
108  is.read(buf2,2);
109  data._format_ver = buf2;
110
111  is.read(buf2,2);
112  data._design_rev = buf2;
113
114  is.read(buf12,12);
115  data._software_id = buf12;
116
117  is.read(buf4,4);
118  data._file_num = atoi(buf4);
119
120  is.read(buf16,16);
121  data._file_name = buf16;
122
123  is.read(buf4,4);
124  data._rec_seq = buf4;
125
126  is.read(buf8,8);
127  data._seq_loc = atoi(buf8);
128
129  is.read(buf4,4);
130  data._seq_len = atoi(buf4);
131
132  is.read(buf4,4);
133  data._rec_code = buf4;
134
135  is.read(buf8,8);
136  data._code_loc = atoi(buf8);
137
138  is.read(buf4,4);
139  data._code_len = atoi(buf4);
140
142  data._rec_len = buf4;
143
144  is.read(buf8,8);
145  data._rlen_loc = atoi(buf8);
146
147  is.read(buf4,4);
148  data._rlen_len = atoi(buf4);
149
150  is.read(buf4,4);
151
152  is.read(buf64,64);
153
154  is.read(buf6,6);
155  data._n_dataset = atoi(buf6);
156
157  is.read(buf6,6);
158  data._l_dataset = atoi(buf6);
159
160  is.read(buf6,6);
161  data._n_map_proj = atoi(buf6);
162
163  is.read(buf6,6);
164  data._l_map_proj = atoi(buf6);
165
166  is.read(buf6,6);
167  data._n_plat_pos = atoi(buf6);
168  is.read(buf6,6);
169  data._l_plat_pos = atoi(buf6);
170  is.read(buf6,6);
171  data._n_att_data = atoi(buf6);
172  is.read(buf6,6);
173  data._l_att_data = atoi(buf6);
174  is.read(buf6,6);
175  data._n_radi_data = atoi(buf6);
176  is.read(buf6,6);
177  data._l_radi_data = atoi(buf6);
178  is.read(buf6,6);
179  data._n_radi_comp = atoi(buf6);
180  is.read(buf6,6);
181  data._l_radi_comp = atoi(buf6);
182  is.read(buf6,6);
183  data._n_qual_sum = atoi(buf6);
184  is.read(buf6,6);
185  data._l_qual_sum = atoi(buf6);
186  is.read(buf6,6);
187  data._n_data_his = atoi(buf6);
188  is.read(buf6,6);
189  data._l_data_his = atoi(buf6);
190
191
192
193  is.read(buf6,6);
194  data._n_rang_spec = atoi(buf6);
195  is.read(buf6,6);
196  data._l_rang_spec = atoi(buf6);
197  is.read(buf6,6);
198  data._n_dem_desc = atoi(buf6);
199  is.read(buf6,6);
200  data._l_dem_desc = atoi(buf6);
201  is.read(buf6,6);
202  data._n_radar_par = atoi(buf6);
203  is.read(buf6,6);
204  data._l_radar_par = atoi(buf6);
205  is.read(buf6,6);
206  data._n_anno_data = atoi(buf6);
207  is.read(buf6,6);
208  data._l_anno_data = atoi(buf6);
209  is.read(buf6,6);
210  data._n_det_proc = atoi(buf6);
211  is.read(buf6,6);
212  data._l_det_proc = atoi(buf6);
213  is.read(buf6,6);
214  data._n_cal = atoi(buf6);
215  is.read(buf6,6);
216  data._l_cal = atoi(buf6);
217  is.read(buf6,6);
218  data._n_gcp = atoi(buf6);
219  is.read(buf6,6);
220  data._l_gcp = atoi(buf6);
221  is.read(buf60,60);
222  is.read(buf6,6);
223  data._n_fac_data = atoi(buf6);
224  is.read(buf6,6);
225  data._l_fac_data = atoi(buf6);
226  is.read(buf288,288);
227  return is;
228 }
◆ operator>>() [47/62]
ErsSarFileDescriptor data
Definition at line 79 of file ErsSarFileDescriptor.cpp.
References ossimplugins::ErsSarFileDescriptor::_ascii_flag, ossimplugins::ErsSarFileDescriptor::_code_len, ossimplugins::ErsSarFileDescriptor::_code_loc, ossimplugins::ErsSarFileDescriptor::_design_rev, ossimplugins::ErsSarFileDescriptor::_file_name, ossimplugins::ErsSarFileDescriptor::_file_num, ossimplugins::ErsSarFileDescriptor::_format_doc, ossimplugins::ErsSarFileDescriptor::_format_ver, ossimplugins::ErsSarFileDescriptor::_l_anno_data, ossimplugins::ErsSarFileDescriptor::_l_att_data, ossimplugins::ErsSarFileDescriptor::_l_cal, ossimplugins::ErsSarFileDescriptor::_l_data_his, ossimplugins::ErsSarFileDescriptor::_l_dataset, ossimplugins::ErsSarFileDescriptor::_l_dem_desc, ossimplugins::ErsSarFileDescriptor::_l_det_proc, ossimplugins::ErsSarFileDescriptor::_l_fac_data, ossimplugins::ErsSarFileDescriptor::_l_gcp, ossimplugins::ErsSarFileDescriptor::_l_map_proj, ossimplugins::ErsSarFileDescriptor::_l_plat_pos, ossimplugins::ErsSarFileDescriptor::_l_qual_sum, ossimplugins::ErsSarFileDescriptor::_l_radar_par, ossimplugins::ErsSarFileDescriptor::_l_radi_comp, ossimplugins::ErsSarFileDescriptor::_l_radi_data, ossimplugins::ErsSarFileDescriptor::_l_rang_spec, ossimplugins::ErsSarFileDescriptor::_n_anno_data, ossimplugins::ErsSarFileDescriptor::_n_att_data, ossimplugins::ErsSarFileDescriptor::_n_cal, ossimplugins::ErsSarFileDescriptor::_n_data_his, ossimplugins::ErsSarFileDescriptor::_n_dataset, ossimplugins::ErsSarFileDescriptor::_n_dem_desc, ossimplugins::ErsSarFileDescriptor::_n_det_proc, ossimplugins::ErsSarFileDescriptor::_n_fac_data, ossimplugins::ErsSarFileDescriptor::_n_gcp, ossimplugins::ErsSarFileDescriptor::_n_map_proj, ossimplugins::ErsSarFileDescriptor::_n_plat_pos, ossimplugins::ErsSarFileDescriptor::_n_qual_sum, ossimplugins::ErsSarFileDescriptor::_n_radar_par, ossimplugins::ErsSarFileDescriptor::_n_radi_comp, ossimplugins::ErsSarFileDescriptor::_n_radi_data, ossimplugins::ErsSarFileDescriptor::_n_rang_spec, ossimplugins::ErsSarFileDescriptor::_rec_code, ossimplugins::ErsSarFileDescriptor::_rec_len, ossimplugins::ErsSarFileDescriptor::_rec_seq, ossimplugins::ErsSarFileDescriptor::_rlen_len, ossimplugins::ErsSarFileDescriptor::_rlen_loc, ossimplugins::ErsSarFileDescriptor::_seq_len, ossimplugins::ErsSarFileDescriptor::_seq_loc, and ossimplugins::ErsSarFileDescriptor::_software_id.
80 {
81  char buf2[3];
82  buf2[2] = '\0';
83  char buf12[13];
84  buf12[12] = '\0';
85  char buf16[17];
86  buf16[16] = '\0';
87  char buf4[5];
88  buf4[4] = '\0';
89  char buf6[7];
90  buf6[6] = '\0';
91  char buf8[9];
92  buf8[8] = '\0';
93  char buf64[65];
94  buf64[64] = '\0';
95
96  char buf60[61];
97  buf60[60] = '\0';
98
99  char buf288[289];
100  buf288[288] = '\0';
101
102  is.read(buf2, 2);
103  data._ascii_flag = buf2;
104
105  is.read(buf2, 2);
106
107  is.read(buf12, 12);
108  data._format_doc = buf12;
109
110  is.read(buf2, 2);
111  data._format_ver = buf2;
112
113  is.read(buf2, 2);
114  data._design_rev = buf2;
115
116  is.read(buf12, 12);
117  data._software_id = buf12;
118
119  is.read(buf4, 4);
120  data._file_num = atoi(buf4);
121
122  is.read(buf16, 16);
123  data._file_name = buf16;
124
125  is.read(buf4, 4);
126  data._rec_seq = buf4;
127
128  is.read(buf8, 8);
129  data._seq_loc = atoi(buf8);
130
131  is.read(buf4, 4);
132  data._seq_len = atoi(buf4);
133
134  is.read(buf4, 4);
135  data._rec_code = buf4;
136
137  is.read(buf8, 8);
138  data._code_loc = atoi(buf8);
139
140  is.read(buf4, 4);
141  data._code_len = atoi(buf4);
142
143  is.read(buf4, 4);
144  data._rec_len = buf4;
145
146  is.read(buf8, 8);
147  data._rlen_loc = atoi(buf8);
148
149  is.read(buf4, 4);
150  data._rlen_len = atoi(buf4);
151
152  is.read(buf4, 4);
153
154  is.read(buf64, 64);
155
156  is.read(buf6, 6);
157  data._n_dataset = atoi(buf6);
158
159  is.read(buf6, 6);
160  data._l_dataset = atoi(buf6);
161
162  is.read(buf6, 6);
163  data._n_map_proj = atoi(buf6);
164
165  is.read(buf6, 6);
166  data._l_map_proj = atoi(buf6);
167
168  is.read(buf6, 6);
169  data._n_plat_pos = atoi(buf6);
170  is.read(buf6, 6);
171  data._l_plat_pos = atoi(buf6);
172  is.read(buf6, 6);
173  data._n_att_data = atoi(buf6);
174  is.read(buf6, 6);
175  data._l_att_data = atoi(buf6);
176  is.read(buf6, 6);
177  data._n_radi_data = atoi(buf6);
178  is.read(buf6, 6);
179  data._l_radi_data = atoi(buf6);
180  is.read(buf6, 6);
181  data._n_radi_comp = atoi(buf6);
182  is.read(buf6, 6);
183  data._l_radi_comp = atoi(buf6);
184  is.read(buf6, 6);
185  data._n_qual_sum = atoi(buf6);
186  is.read(buf6, 6);
187  data._l_qual_sum = atoi(buf6);
188  is.read(buf6, 6);
189  data._n_data_his = atoi(buf6);
190  is.read(buf6, 6);
191  data._l_data_his = atoi(buf6);
192
193
194
195  is.read(buf6, 6);
196  data._n_rang_spec = atoi(buf6);
197  is.read(buf6, 6);
198  data._l_rang_spec = atoi(buf6);
199  is.read(buf6, 6);
200  data._n_dem_desc = atoi(buf6);
201  is.read(buf6, 6);
202  data._l_dem_desc = atoi(buf6);
203  is.read(buf6, 6);
204  data._n_radar_par = atoi(buf6);
205  is.read(buf6, 6);
206  data._l_radar_par = atoi(buf6);
207  is.read(buf6, 6);
208  data._n_anno_data = atoi(buf6);
209  is.read(buf6, 6);
210  data._l_anno_data = atoi(buf6);
211  is.read(buf6, 6);
212  data._n_det_proc = atoi(buf6);
213  is.read(buf6, 6);
214  data._l_det_proc = atoi(buf6);
215  is.read(buf6, 6);
216  data._n_cal = atoi(buf6);
217  is.read(buf6, 6);
218  data._l_cal = atoi(buf6);
219  is.read(buf6, 6);
220  data._n_gcp = atoi(buf6);
221  is.read(buf6, 6);
222  data._l_gcp = atoi(buf6);
223  is.read(buf60, 60);
224  is.read(buf6, 6);
225  data._n_fac_data = atoi(buf6);
226  is.read(buf6, 6);
227  data._l_fac_data = atoi(buf6);
228  is.read(buf288, 288);
229  return is;
230 }
◆ operator>>() [48/62]
ProcessedDataRecord data
Definition at line 81 of file ProcessedDataRecord.cpp.
References ossimplugins::ProcessedDataRecord::_acq_day, ossimplugins::ProcessedDataRecord::_acq_msec, ossimplugins::ProcessedDataRecord::_acq_year, ossimplugins::ProcessedDataRecord::_east_first, ossimplugins::ProcessedDataRecord::_east_last, ossimplugins::ProcessedDataRecord::_fdc_first, ossimplugins::ProcessedDataRecord::_fdc_last, ossimplugins::ProcessedDataRecord::_fdc_mid, ossimplugins::ProcessedDataRecord::_geo_updf, ossimplugins::ProcessedDataRecord::_heading, ossimplugins::ProcessedDataRecord::_ka_first, ossimplugins::ProcessedDataRecord::_ka_last, ossimplugins::ProcessedDataRecord::_ka_mid, ossimplugins::ProcessedDataRecord::_lat_first, ossimplugins::ProcessedDataRecord::_lat_last, ossimplugins::ProcessedDataRecord::_lat_mid, ossimplugins::ProcessedDataRecord::_line_num, ossimplugins::ProcessedDataRecord::_lon_first, ossimplugins::ProcessedDataRecord::_lon_last, ossimplugins::ProcessedDataRecord::_lon_mid, ossimplugins::ProcessedDataRecord::_n_data_pixel, ossimplugins::ProcessedDataRecord::_n_left_pixel, ossimplugins::ProcessedDataRecord::_n_right_pixel, ossimplugins::ProcessedDataRecord::_nadir_ang, ossimplugins::ProcessedDataRecord::_north_first, ossimplugins::ProcessedDataRecord::_north_last, ossimplugins::ProcessedDataRecord::_prf, ossimplugins::ProcessedDataRecord::_rec_num, ossimplugins::ProcessedDataRecord::_recv_polar, ossimplugins::ProcessedDataRecord::_sar_chan_code, ossimplugins::ProcessedDataRecord::_sar_chan_ind, ossimplugins::ProcessedDataRecord::_sensor_updf, ossimplugins::ProcessedDataRecord::_squint_ang, ossimplugins::ProcessedDataRecord::_sr_first, ossimplugins::ProcessedDataRecord::_sr_last, ossimplugins::ProcessedDataRecord::_sr_mid, ossimplugins::ProcessedDataRecord::_tran_polar, and ossimplugins::ProcessedDataRecord::SwitchEndian().
82  {
83  char buf[193];
84  buf[192] = '\0';
85
86  is.read((char*)&(data._line_num),4);
87  data.SwitchEndian(data._line_num);
88
89  is.read((char*)&(data._rec_num),4);
90  data.SwitchEndian(data._rec_num);
91
92  is.read((char*)&(data._n_left_pixel),4);
93  data.SwitchEndian(data._n_left_pixel);
94
95  is.read((char*)&(data._n_data_pixel),4);
96  data.SwitchEndian(data._n_data_pixel);
97
98  is.read((char*)&(data._n_right_pixel),4);
99  data.SwitchEndian(data._n_right_pixel);
100
101  is.read((char*)&(data._sensor_updf),4);
102  data.SwitchEndian(data._sensor_updf);
103
104  is.read((char*)&(data._acq_year),4);
105  data.SwitchEndian(data._acq_year);
106
107  is.read((char*)&(data._acq_day),4);
108  data.SwitchEndian(data._acq_day);
109
110  is.read((char*)&(data._acq_msec),4);
111  data.SwitchEndian(data._acq_msec);
112
113  is.read((char*)&(data._sar_chan_ind),2);
114  data.SwitchEndian(data._sar_chan_ind);
115
116  is.read((char*)&(data._sar_chan_code),2);
117  data.SwitchEndian(data._sar_chan_code);
118
119  is.read((char*)&(data._tran_polar),2);
120  data.SwitchEndian(data._tran_polar );
121
122  is.read((char*)&(data._recv_polar),2);
123  data.SwitchEndian(data._recv_polar);
124
125  is.read((char*)&(data._prf),4);
126  data.SwitchEndian(data._prf );
127
128  is.read(buf,4);
129
130  is.read((char*)&(data._sr_first),4);
131  data.SwitchEndian(data._sr_first);
132
133  is.read((char*)&(data._sr_mid),4);
134  data.SwitchEndian(data._sr_mid);
135
136  is.read((char*)&(data._sr_last),4);
137  data.SwitchEndian(data._sr_last);
138
139  is.read((char*)&(data._fdc_first),4);
140  data.SwitchEndian(data._fdc_first);
141
142  is.read((char*)&(data._fdc_mid),4);
143  data.SwitchEndian(data._fdc_mid);
144
145  is.read((char*)&(data._fdc_last),4);
146  data.SwitchEndian(data._fdc_last);
147
148  is.read((char*)&(data._ka_first),4);
149  data.SwitchEndian(data._ka_first);
150
151  is.read((char*)&(data._ka_mid),4);
152  data.SwitchEndian(data._ka_mid);
153
154  is.read((char*)&(data._ka_last),4);
155  data.SwitchEndian(data._ka_last);
156
157  is.read((char*)&(data._nadir_ang),4);
158  data.SwitchEndian(data._nadir_ang);
159
160  is.read((char*)&(data._squint_ang),4);
161  data.SwitchEndian(data._squint_ang);
162
163  is.read(buf,4);
164  is.read(buf,16);
165
166  is.read((char*)&(data._geo_updf),4);
167  data.SwitchEndian(data._geo_updf);
168
169  is.read((char*)&(data._lat_first),4);
170  data.SwitchEndian(data._lat_first);
171
172  is.read((char*)&(data._lat_mid),4);
173  data.SwitchEndian(data._lat_mid);
174
175  is.read((char*)&(data._lat_last),4);
176  data.SwitchEndian(data._lat_last);
177
178  is.read((char*)&(data._lon_first),4);
179  data.SwitchEndian(data._lon_first);
180
181  is.read((char*)&(data._lon_mid),4);
182  data.SwitchEndian(data._lon_mid);
183
184  is.read((char*)&(data._lon_last),4);
185  data.SwitchEndian(data._lon_last);
186
187  is.read((char*)&(data._north_first),4);
188  data.SwitchEndian(data._north_first);
189
190  is.read(buf,4);
191
192  is.read((char*)&(data._north_last),4);
193  data.SwitchEndian(data._north_last);
194
195  is.read((char*)&(data._east_first),4);
196  data.SwitchEndian(data._east_first);
197
198  is.read(buf,4);
199
200  is.read((char*)&(data._east_last),4);
201  data.SwitchEndian(data._east_last);
202
203  is.read((char*)&(data._heading),4);
204  data.SwitchEndian(data._heading);
205
206  is.read(buf,8);
207
208  return is;
209  }
◆ operator>>() [49/62]
DataQuality data
Definition at line 91 of file DataQuality.cpp.
References ossimplugins::DataQuality::_alt_locerr, ossimplugins::DataQuality::_alt_scale, ossimplugins::DataQuality::_azi_ambig, ossimplugins::DataQuality::_azi_res, ossimplugins::DataQuality::_ber, ossimplugins::DataQuality::_cali_date, ossimplugins::DataQuality::_crt_locerr, ossimplugins::DataQuality::_crt_scale, ossimplugins::DataQuality::_dis_skew, ossimplugins::DataQuality::_dyn_rng, ossimplugins::DataQuality::_enl, ossimplugins::DataQuality::_islr, ossimplugins::DataQuality::_misreg, ossimplugins::DataQuality::_nchn, ossimplugins::DataQuality::_nesz, ossimplugins::DataQuality::_ori_err, ossimplugins::DataQuality::_pslr, ossimplugins::DataQuality::_rad_res, ossimplugins::DataQuality::_rad_unc, ossimplugins::DataQuality::_rad_unc_db, ossimplugins::DataQuality::_rad_unc_deg, ossimplugins::DataQuality::_rec_seq, ossimplugins::DataQuality::_rng_ambig, ossimplugins::DataQuality::_rng_res, ossimplugins::DataQuality::_sar_chn, ossimplugins::DataQuality::_snr, and ossimplugins::DataQuality::_tb_update.
92 {
93  char buf[2149];
94  buf[2148] = '\0';
95
96
97  is.read(buf,4);
98  buf[4] = '\0';
99  data._rec_seq = atoi(buf);
100
101  is.read(buf,4);
102  buf[4] = '\0';
103  data._sar_chn = buf;
104
105  is.read(buf,6);
106  buf[6] = '\0';
107  data._cali_date = buf;
108
109  is.read(buf,4);
110  buf[4] = '\0';
111  data._nchn = atoi(buf);
112
113  is.read(buf,16);
114  buf[16] = '\0';
115  data._islr = atof(buf);
116
117  is.read(buf,16);
118  buf[16] = '\0';
119  data._pslr = atof(buf);
120
121  is.read(buf,16);
122  buf[16] = '\0';
123  data._azi_ambig = atof(buf);
124
125  is.read(buf,16);
126  buf[16] = '\0';
127  data._rng_ambig = atof(buf);
128
129  is.read(buf,16);
130  buf[16] = '\0';
131  data._snr = atof(buf);
132
133  is.read(buf,16);
134  buf[16] = '\0';
135  data._ber = atof(buf);
136
137  is.read(buf,16);
138  buf[16] = '\0';
139  data._rng_res = atof(buf);
140
141  is.read(buf,16);
142  buf[16] = '\0';
143  data._azi_res = atof(buf);
144
145  is.read(buf,16);
146  buf[16] = '\0';
147  data._rad_res = atof(buf);
148
149  is.read(buf,16);
150  buf[16] = '\0';
151  data._dyn_rng = atof(buf);
152
153  is.read(buf,16);
154  buf[16] = '\0';
155  data._rad_unc_db = atof(buf);
156
157  is.read(buf,16);
158  buf[16] = '\0';
159  data._rad_unc_deg = atof(buf);
160
161  for (int i=0;i<16;i++)
162  {
163  is>>data._rad_unc[i];
164  }
165
166  is.read(buf,16);
167  buf[16] = '\0';
168  data._alt_locerr = atof(buf);
169
170  is.read(buf,16);
171  buf[16] = '\0';
172  data._crt_locerr = atof(buf);
173
174  is.read(buf,16);
175  buf[16] = '\0';
176  data._alt_scale = atof(buf);
177
178  is.read(buf,16);
179  buf[16] = '\0';
180  data._crt_scale = atof(buf);
181
182  is.read(buf,16);
183  buf[16] = '\0';
184  data._dis_skew = atof(buf);
185
186  is.read(buf,16);
187  buf[16] = '\0';
188  data._ori_err = atof(buf);
189
190  for (int i=0;i<16;i++)
191  {
192  is>>data._misreg[i];
193  }
194
195  is.read(buf,16);
196  buf[16] = '\0';
197  data._nesz = atof(buf);
198
199  is.read(buf,16);
200  buf[16] = '\0';
201  data._enl = atof(buf);
202
203  is.read(buf,8);
204  buf[8] = '\0';
205  data._tb_update = buf;
206
207  is.read(buf,238);
208
209
210  return is;
211 }
◆ operator>>() [50/62]
AlosPalsarFileDescriptor data
Definition at line 101 of file AlosPalsarFileDescriptor.cpp.
References ossimplugins::AlosPalsarFileDescriptor::_ascii_flag, ossimplugins::AlosPalsarFileDescriptor::_code_len, ossimplugins::AlosPalsarFileDescriptor::_code_loc, ossimplugins::AlosPalsarFileDescriptor::_continuation_flag, ossimplugins::AlosPalsarFileDescriptor::_design_rev, ossimplugins::AlosPalsarFileDescriptor::_file_name, ossimplugins::AlosPalsarFileDescriptor::_file_num, ossimplugins::AlosPalsarFileDescriptor::_format_doc, ossimplugins::AlosPalsarFileDescriptor::_format_ver, ossimplugins::AlosPalsarFileDescriptor::_l_anno_data, ossimplugins::AlosPalsarFileDescriptor::_l_att_data, ossimplugins::AlosPalsarFileDescriptor::_l_cal, ossimplugins::AlosPalsarFileDescriptor::_l_data_his, ossimplugins::AlosPalsarFileDescriptor::_l_dataset, ossimplugins::AlosPalsarFileDescriptor::_l_dem_desc, ossimplugins::AlosPalsarFileDescriptor::_l_det_proc, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data10, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data11, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data2, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data3, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data4, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data5, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data6, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data7, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data8, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data9, ossimplugins::AlosPalsarFileDescriptor::_l_gcp, ossimplugins::AlosPalsarFileDescriptor::_l_map_proj, ossimplugins::AlosPalsarFileDescriptor::_l_plat_pos, ossimplugins::AlosPalsarFileDescriptor::_l_qual_sum, ossimplugins::AlosPalsarFileDescriptor::_l_radar_par, ossimplugins::AlosPalsarFileDescriptor::_l_radi_comp, ossimplugins::AlosPalsarFileDescriptor::_l_radi_data, ossimplugins::AlosPalsarFileDescriptor::_l_rang_spec, ossimplugins::AlosPalsarFileDescriptor::_n_anno_data, ossimplugins::AlosPalsarFileDescriptor::_n_att_data, ossimplugins::AlosPalsarFileDescriptor::_n_cal, ossimplugins::AlosPalsarFileDescriptor::_n_data_his, ossimplugins::AlosPalsarFileDescriptor::_n_dataset, ossimplugins::AlosPalsarFileDescriptor::_n_dem_desc, ossimplugins::AlosPalsarFileDescriptor::_n_det_proc, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data10, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data11, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data2, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data3, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data4, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data5, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data6, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data7, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data8, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data9, ossimplugins::AlosPalsarFileDescriptor::_n_gcp, ossimplugins::AlosPalsarFileDescriptor::_n_map_proj, ossimplugins::AlosPalsarFileDescriptor::_n_plat_pos, ossimplugins::AlosPalsarFileDescriptor::_n_qual_sum, ossimplugins::AlosPalsarFileDescriptor::_n_radar_par, ossimplugins::AlosPalsarFileDescriptor::_n_radi_comp, ossimplugins::AlosPalsarFileDescriptor::_n_radi_data, ossimplugins::AlosPalsarFileDescriptor::_n_rang_spec, ossimplugins::AlosPalsarFileDescriptor::_rec_code, ossimplugins::AlosPalsarFileDescriptor::_rec_len, ossimplugins::AlosPalsarFileDescriptor::_rec_seq, ossimplugins::AlosPalsarFileDescriptor::_rlen_len, ossimplugins::AlosPalsarFileDescriptor::_rlen_loc, ossimplugins::AlosPalsarFileDescriptor::_seq_len, ossimplugins::AlosPalsarFileDescriptor::_seq_loc, and ossimplugins::AlosPalsarFileDescriptor::_software_id.
102 {
103  char buf2[3];
104  buf2[2] = '\0';
105  char buf12[13];
106  buf12[12] = '\0';
107  char buf16[17];
108  buf16[16] = '\0';
109  char buf4[5];
110  buf4[4] = '\0';
111  char buf6[7];
112  buf6[6] = '\0';
113  char buf8[9];
114  buf8[8] = '\0';
115  char buf64[65];
116  buf64[64] = '\0';
117
118  char buf60[61];
119  buf60[60] = '\0';
120
121  char buf146[147];
122  buf146[146] = '\0';
123
124  is.read(buf2, 2);
125  data._ascii_flag = buf2;
126
127  is.read(buf2, 2);
128  data._continuation_flag = buf2;
129
130  is.read(buf12, 12);
131  data._format_doc = buf12;
132
133  is.read(buf2, 2);
134  data._format_ver = buf2;
135
136  is.read(buf2, 2);
137  data._design_rev = buf2;
138
139  is.read(buf12, 12);
140  data._software_id = buf12;
141
142  is.read(buf4, 4);
143  data._file_num = atoi(buf4);
144
146  data._file_name = buf16;
147
148  is.read(buf4, 4);
149  data._rec_seq = buf4;
150
151  is.read(buf8, 8);
152  data._seq_loc = atoi(buf8);
153
154  is.read(buf4, 4);
155  data._seq_len = atoi(buf4);
156
157  is.read(buf4, 4);
158  data._rec_code = buf4;
159
160  is.read(buf8, 8);
161  data._code_loc = atoi(buf8);
162
163  is.read(buf4, 4);
164  data._code_len = atoi(buf4);
165
166  is.read(buf4, 4);
167  data._rec_len = buf4;
168
169  is.read(buf8, 8);
170  data._rlen_loc = atoi(buf8);
171
172  is.read(buf4, 4);
173  data._rlen_len = atoi(buf4);
174
175  is.read(buf4, 4);
176
177  is.read(buf64, 64);
178
179  is.read(buf6, 6);
180  data._n_dataset = atoi(buf6);
181
183  data._l_dataset = atoi(buf6);
184
185  is.read(buf6, 6);
186  data._n_map_proj = atoi(buf6);
187
189  data._l_map_proj = atoi(buf6);
190
191  is.read(buf6, 6);
192  data._n_plat_pos = atoi(buf6);
193  is.read(buf6, 6);
194  data._l_plat_pos = atoi(buf6);
196  data._n_att_data = atoi(buf6);
198  data._l_att_data = atoi(buf6);
200  data._n_radi_data = atoi(buf6);
202  data._l_radi_data = atoi(buf6);
204  data._n_radi_comp = atoi(buf6);
206  data._l_radi_comp = atoi(buf6);
208  data._n_qual_sum = atoi(buf6);
210  data._l_qual_sum = atoi(buf6);
212  data._n_data_his = atoi(buf6);
214  data._l_data_his = atoi(buf6);
215
216
217
218  is.read(buf6, 6);
219  data._n_rang_spec = atoi(buf6);
220  is.read(buf6, 6);
221  data._l_rang_spec = atoi(buf6);
222  is.read(buf6, 6);
223  data._n_dem_desc = atoi(buf6);
225  data._l_dem_desc = atoi(buf6);
227  data._n_radar_par = atoi(buf6);
228  is.read(buf6, 6);
229  data._l_radar_par = atoi(buf6);
230  is.read(buf6, 6);
231  data._n_anno_data = atoi(buf6);
232  is.read(buf6, 6);
233  data._l_anno_data = atoi(buf6);
234  is.read(buf6, 6);
235  data._n_det_proc = atoi(buf6);
236  is.read(buf6, 6);
237  data._l_det_proc = atoi(buf6);
238  is.read(buf6, 6);
239  data._n_cal = atoi(buf6);
240  is.read(buf6, 6);
241  data._l_cal = atoi(buf6);
242  is.read(buf6, 6);
243  data._n_gcp = atoi(buf6);
244  is.read(buf6, 6);
245  data._l_gcp = atoi(buf6);
246  is.read(buf60, 60);
247  is.read(buf6, 6);
248  data._n_fac_data = atoi(buf6);
249  is.read(buf8, 8);
250  data._l_fac_data = atoi(buf8);
251  is.read(buf6, 6);
252  data._n_fac_data2 = atoi(buf6);
253  is.read(buf8, 8);
254  data._l_fac_data2 = atoi(buf8);
255  is.read(buf6, 6);
256  data._n_fac_data3 = atoi(buf6);
257  is.read(buf8, 8);
258  data._l_fac_data3 = atoi(buf8);
259  is.read(buf6, 6);
260  data._n_fac_data4 = atoi(buf6);
261  is.read(buf8, 8);
262  data._l_fac_data4 = atoi(buf8);
263  is.read(buf6, 6);
264  data._n_fac_data5 = atoi(buf6);
265  is.read(buf8, 8);
266  data._l_fac_data5 = atoi(buf8);
267  is.read(buf6, 6);
268  data._n_fac_data6 = atoi(buf6);
269  is.read(buf8, 8);
270  data._l_fac_data6 = atoi(buf8);
271  is.read(buf6, 6);
272  data._n_fac_data7 = atoi(buf6);
273  is.read(buf8, 8);
274  data._l_fac_data7 = atoi(buf8);
275  is.read(buf6, 6);
276  data._n_fac_data8 = atoi(buf6);
277  is.read(buf8, 8);
278  data._l_fac_data8 = atoi(buf8);
279  is.read(buf6, 6);
280  data._n_fac_data9 = atoi(buf6);
281  is.read(buf8, 8);
282  data._l_fac_data9 = atoi(buf8);
283  is.read(buf6, 6);
284  data._n_fac_data10 = atoi(buf6);
285  is.read(buf8, 8);
286  data._l_fac_data10 = atoi(buf8);
287  is.read(buf6, 6);
288  data._n_fac_data11 = atoi(buf6);
289  is.read(buf8, 8);
290  data._l_fac_data11 = atoi(buf8);
291
292  is.read(buf146, 146);
293  return is;
294 }
◆ operator>>() [51/62]
SQ_ADSR data
Definition at line 108 of file SQ_ADSR.cpp.
References ossimplugins::SQ_ADSR::_attach_flag, ossimplugins::SQ_ADSR::_chirp_flag, ossimplugins::SQ_ADSR::_dop_amb_flag, ossimplugins::SQ_ADSR::_dop_cen_flag, ossimplugins::SQ_ADSR::_exp_input_mean, ossimplugins::SQ_ADSR::_exp_input_std_dev, ossimplugins::SQ_ADSR::_exp_output_mean, ossimplugins::SQ_ADSR::_exp_output_std_dev, ossimplugins::SQ_ADSR::_input_gaps_flag, ossimplugins::SQ_ADSR::_input_mean, ossimplugins::SQ_ADSR::_input_mean_flag, ossimplugins::SQ_ADSR::_input_missing_lines_flag, ossimplugins::SQ_ADSR::_input_std_dev, ossimplugins::SQ_ADSR::_input_std_dev_flag, ossimplugins::SQ_ADSR::_invalid_downlink_flag, ossimplugins::SQ_ADSR::_lines_per_gaps, ossimplugins::SQ_ADSR::_missing_data_set_flag, ossimplugins::SQ_ADSR::_num_gaps, ossimplugins::SQ_ADSR::_num_missing_lines, ossimplugins::SQ_ADSR::_output_mean, ossimplugins::SQ_ADSR::_output_mean_flag, ossimplugins::SQ_ADSR::_output_std_dev, ossimplugins::SQ_ADSR::_output_std_dev_flag, ossimplugins::SQ_ADSR::_thres_chirp_broadening, ossimplugins::SQ_ADSR::_thresh_chirp_islr, ossimplugins::SQ_ADSR::_thresh_chirp_sidelobe, ossimplugins::SQ_ADSR::_thresh_dop_amb, ossimplugins::SQ_ADSR::_thresh_dop_cen, ossimplugins::SQ_ADSR::_thresh_input_gaps, ossimplugins::SQ_ADSR::_thresh_input_mean, ossimplugins::SQ_ADSR::_thresh_input_missing_lines, ossimplugins::SQ_ADSR::_thresh_input_std_dev, ossimplugins::SQ_ADSR::_thresh_output_mean, ossimplugins::SQ_ADSR::_thresh_output_std_dev, ossimplugins::SQ_ADSR::_tot_errors, ossimplugins::SQ_ADSR::_zero_doppler_time, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
109  {
110  // char buf64[65];
111  // buf64[64] = '\0';
112  // char buf32[33];
113  // buf32[32] = '\0';
114  // char buf27[28];
115  // buf27[27] = '\0';
116  // char buf20[21];
117  // buf20[20] = '\0';
118  char buf16[17];
119  buf16[16]='\0';
120  char buf15[16];
121  buf15[15] = '\0';
122  // char buf14[15];
123  // buf14[14] = '\0';
124  // char buf13[14];
125  // buf13[13] = '\0';
126  char buf12[13];
127  buf12[12] = '\0';
128  // char buf11[12];
129  // buf11[11] = '\0';
130  // char buf10[11];
131  // buf10[10] = '\0';
132  // char buf9[10];
133  // buf9[9] = '\0';
134  // char buf8[9];
135  // buf8[8] = '\0';
136  char buf7[8];
137  buf7[7] = '\0';
138  // char buf6[7];
139  // buf6[6] = '\0';
140  // char buf5[6];
141  // buf5[5] = '\0';
142  // char buf4[5];
143  // buf4[4] = '\0';
144  // char buf3[4];
145  // buf3[3] = '\0';
146  // char buf2[3];
147  // buf2[2] = '\0';
148 // char buf1[1]; // not used avoid warning
149
150  is.read(buf12,12);
151  data._zero_doppler_time = buf12;
152
153  is.read((char*)&(data._attach_flag),1);
154
155  is.read((char*)&(data._input_mean_flag),1);
156
157  is.read((char*)&(data._input_std_dev_flag),1);
158
159  is.read((char*)&(data._input_gaps_flag),1);
160
161  is.read((char*)&(data._input_missing_lines_flag),1);
162
163  is.read((char*)&(data._dop_cen_flag),1);
164
165  is.read((char*)&(data._dop_amb_flag),1);
166
167  is.read((char*)&(data._output_mean_flag),1);
168
169  is.read((char*)&(data._output_std_dev_flag),1);
170
171  is.read((char*)&(data._chirp_flag),1);
172
173  is.read((char*)&(data._missing_data_set_flag),1);
174
175  is.read((char*)&(data._invalid_downlink_flag),1);
176
177  is.read(buf7,7);
178
179  is.read((char*)&(data._thres_chirp_broadening),4);
180  data.SwitchEndian(data._thres_chirp_broadening);
181
182  is.read((char*)&(data._thresh_chirp_sidelobe),4);
183  data.SwitchEndian(data._thresh_chirp_sidelobe);
184
185  is.read((char*)&(data._thresh_chirp_islr),4);
186  data.SwitchEndian(data._thresh_chirp_islr);
187
188  is.read((char*)&(data._thresh_input_mean),4);
189  data.SwitchEndian(data._thresh_input_mean);
190
191  is.read((char*)&(data._exp_input_mean),4);
192  data.SwitchEndian(data._exp_input_mean);
193
194  is.read((char*)&(data._thresh_input_std_dev),4);
195  data.SwitchEndian(data._thresh_input_std_dev);
196
197  is.read((char*)&(data._exp_input_std_dev),4);
198  data.SwitchEndian(data._exp_input_std_dev);
199
200  is.read((char*)&(data._thresh_dop_cen),4);
201  data.SwitchEndian(data._thresh_dop_cen);
202
203  is.read((char*)&(data._thresh_dop_amb),4);
204  data.SwitchEndian(data._thresh_dop_amb);
205
206  is.read((char*)&(data._thresh_output_mean),4);
207  data.SwitchEndian(data._thresh_output_mean);
208
209  is.read((char*)&(data._exp_output_mean),4);
210  data.SwitchEndian(data._exp_output_mean);
211
212  is.read((char*)&(data._thresh_output_std_dev),4);
213  data.SwitchEndian(data._thresh_output_std_dev);
214
215  is.read((char*)&(data._exp_output_std_dev),4);
216  data.SwitchEndian(data._exp_output_std_dev);
217
218  is.read((char*)&(data._thresh_input_missing_lines),4);
219  data.SwitchEndian(data._thresh_input_missing_lines);
220
221  is.read((char*)&(data._thresh_input_gaps),4);
222  data.SwitchEndian(data._thresh_input_gaps);
223
224  is.read((char*)&(data._lines_per_gaps),4);
225  data.SwitchEndian(data._lines_per_gaps);
226
227  is.read(buf15,15);
228
229  is.read((char*)&(data._input_mean[0]),4);
230  data.SwitchEndian(data._input_mean[0]);
231
232  is.read((char*)&(data._input_mean[1]),4);
233  data.SwitchEndian(data._input_mean[1]);
234
235  is.read((char*)&(data._input_std_dev[0]),4);
236  data.SwitchEndian(data._input_std_dev[0]);
237  is.read((char*)&(data._input_std_dev[1]),4);
238  data.SwitchEndian(data._input_std_dev[1]);
239
240  is.read((char*)&(data._num_gaps),4);
241  data.SwitchEndian(data._num_gaps);
242
243  is.read((char*)&(data._num_missing_lines),4);
244  data.SwitchEndian(data._num_missing_lines);
245
246  is.read((char*)&(data._output_mean[0]),4);
247  data.SwitchEndian(data._output_mean[0]);
248  is.read((char*)&(data._output_mean[1]),4);
249  data.SwitchEndian(data._output_mean[1]);
250
251  is.read((char*)&(data._output_std_dev[0]),4);
252  data.SwitchEndian(data._output_std_dev[0]);
253
254  is.read((char*)&(data._output_std_dev[1]),4);
255  data.SwitchEndian(data._output_std_dev[1]);
256
257  is.read((char*)&(data._tot_errors),4);
258  data.SwitchEndian(data._tot_errors);
259
260  is.read(buf16,16);
261
262  return is;
263
264  }
◆ operator>>() [52/62]
DataHistogramRecord data
Definition at line 131 of file DataHistogramRecord.cpp.
References ossimplugins::DataHistogramRecord::_hist, ossimplugins::DataHistogramRecord::_hist_desc, ossimplugins::DataHistogramRecord::_max_hist, ossimplugins::DataHistogramRecord::_max_smp, ossimplugins::DataHistogramRecord::_mean_hist, ossimplugins::DataHistogramRecord::_mean_smp, ossimplugins::DataHistogramRecord::_min_hist, ossimplugins::DataHistogramRecord::_min_smp, ossimplugins::DataHistogramRecord::_nbin, ossimplugins::DataHistogramRecord::_ngrp_lin, ossimplugins::DataHistogramRecord::_ngrp_pix, ossimplugins::DataHistogramRecord::_nhist, ossimplugins::DataHistogramRecord::_nrec, ossimplugins::DataHistogramRecord::_ns_lin, ossimplugins::DataHistogramRecord::_ns_pix, ossimplugins::DataHistogramRecord::_nsamp_lin, ossimplugins::DataHistogramRecord::_nsamp_pix, ossimplugins::DataHistogramRecord::_smp_inc, ossimplugins::DataHistogramRecord::_std_hist, ossimplugins::DataHistogramRecord::_std_smp, and ossimplugins::DataHistogramRecord::_tab_seq.
132 {
133  char buff[33];
134  buff[32] = '\0';
135
136  is.read(buff,32);
137  data._hist_desc = buff;
138
139  is.read(buff,4);
140  buff[4] = '\0';
141  data._nrec = atoi(buff);
142
143  is.read(buff,4);
144  buff[4] = '\0';
145  data._tab_seq = atoi(buff);
146
147  is.read(buff,8);
148  buff[8] = '\0';
149  data._nbin = atoi(buff);
150
151  is.read(buff,8);
152  buff[8] = '\0';
153  data._ns_lin = atoi(buff);
154
155  is.read(buff,8);
156  buff[8] = '\0';
157  data._ns_pix = atoi(buff);
158
159  is.read(buff,8);
160  buff[8] = '\0';
161  data._ngrp_lin = atoi(buff);
162
163  is.read(buff,8);
164  buff[8] = '\0';
165  data._ngrp_pix = atoi(buff);
166
167  is.read(buff,8);
168  buff[8] = '\0';
169  data._nsamp_lin = atoi(buff);
170
171  is.read(buff,8);
172  buff[8] = '\0';
173  data._nsamp_pix = atoi(buff);
174
175  is.read(buff,16);
176  buff[16] = '\0';
177  data._min_smp = atof(buff);
178
179  is.read(buff,16);
180  buff[16] = '\0';
181  data._max_smp = atof(buff);
182
183  is.read(buff,16);
184  buff[16] = '\0';
185  data._mean_smp = atof(buff);
186
187  is.read(buff,16);
188  buff[16] = '\0';
189  data._std_smp = atof(buff);
190
191  is.read(buff,16);
192  buff[16] = '\0';
193  data._smp_inc = atof(buff);
194
195  is.read(buff,16);
196  buff[16] = '\0';
197  data._min_hist = atof(buff);
198
199  is.read(buff,16);
200  buff[16] = '\0';
201  data._max_hist = atof(buff);
202
203  is.read(buff,16);
204  buff[16] = '\0';
205  data._mean_hist = atof(buff);
206
207  is.read(buff,16);
208  buff[16] = '\0';
209  data._std_hist = atof(buff);
210
211  is.read(buff,8);
212  buff[8] = '\0';
213  data._nhist = atoi(buff);
214
215  if(data._hist != NULL)
216  {
217  delete[] data._hist;
218  }
219
220  //for (int i=0;i<data._nhist;i++)
221  int nhist ;
222  if (data._nhist == 256)
223  { nhist = 256 ; } // Signal Data
224  else {nhist = 1024 ; } // Processed Data
225
226  data._hist = new int[nhist];
227  for (int i=0;i<nhist;i++)
228  {
229  is.read(buff,8);
230  buff[8] = '\0';
231  data._hist[i] = atoi(buff);
232  }
233
234  return is;
235 }
◆ operator>>() [53/62]
ImageOptionsFileDescriptor data
Definition at line 133 of file ImageOptionsFileDescriptor.cpp.
References ossimplugins::ImageOptionsFileDescriptor::_ascii_flag, ossimplugins::ImageOptionsFileDescriptor::_bias_loc, ossimplugins::ImageOptionsFileDescriptor::_cali_loc, ossimplugins::ImageOptionsFileDescriptor::_chn_loc, ossimplugins::ImageOptionsFileDescriptor::_code_len, ossimplugins::ImageOptionsFileDescriptor::_code_loc, ossimplugins::ImageOptionsFileDescriptor::_design_rev, ossimplugins::ImageOptionsFileDescriptor::_file_name, ossimplugins::ImageOptionsFileDescriptor::_file_num, ossimplugins::ImageOptionsFileDescriptor::_format_doc, ossimplugins::ImageOptionsFileDescriptor::_format_rev, ossimplugins::ImageOptionsFileDescriptor::_gain_loc, ossimplugins::ImageOptionsFileDescriptor::_intleav, ossimplugins::ImageOptionsFileDescriptor::_justify, ossimplugins::ImageOptionsFileDescriptor::_l_dataset, ossimplugins::ImageOptionsFileDescriptor::_left_fill, ossimplugins::ImageOptionsFileDescriptor::_left_loc, ossimplugins::ImageOptionsFileDescriptor::_lin_loc, ossimplugins::ImageOptionsFileDescriptor::_n_dataset, ossimplugins::ImageOptionsFileDescriptor::_n_prefix, ossimplugins::ImageOptionsFileDescriptor::_n_sar, ossimplugins::ImageOptionsFileDescriptor::_n_suffix, ossimplugins::ImageOptionsFileDescriptor::_nbit, ossimplugins::ImageOptionsFileDescriptor::_nbott, ossimplugins::ImageOptionsFileDescriptor::_nbyte, ossimplugins::ImageOptionsFileDescriptor::_nchn, ossimplugins::ImageOptionsFileDescriptor::_ngrp, ossimplugins::ImageOptionsFileDescriptor::_nleft, ossimplugins::ImageOptionsFileDescriptor::_nlin, ossimplugins::ImageOptionsFileDescriptor::_nrec_chn, ossimplugins::ImageOptionsFileDescriptor::_nrec_lin, ossimplugins::ImageOptionsFileDescriptor::_nright, ossimplugins::ImageOptionsFileDescriptor::_nsamp, ossimplugins::ImageOptionsFileDescriptor::_ntop, ossimplugins::ImageOptionsFileDescriptor::_pad_ind, ossimplugins::ImageOptionsFileDescriptor::_pix_rng, ossimplugins::ImageOptionsFileDescriptor::_qual_loc, ossimplugins::ImageOptionsFileDescriptor::_rec_code, ossimplugins::ImageOptionsFileDescriptor::_rec_len, ossimplugins::ImageOptionsFileDescriptor::_rec_seq, ossimplugins::ImageOptionsFileDescriptor::_right_fill, ossimplugins::ImageOptionsFileDescriptor::_right_loc, ossimplugins::ImageOptionsFileDescriptor::_rlen_len, ossimplugins::ImageOptionsFileDescriptor::_rlen_loc, ossimplugins::ImageOptionsFileDescriptor::_seq_len, ossimplugins::ImageOptionsFileDescriptor::_seq_loc, ossimplugins::ImageOptionsFileDescriptor::_software_id, ossimplugins::ImageOptionsFileDescriptor::_tim_loc, ossimplugins::ImageOptionsFileDescriptor::_type_code, ossimplugins::ImageOptionsFileDescriptor::_type_id, ossimNotify(), and ossimNotifyLevel_DEBUG.
134  {
135  char buf[15805];
136  buf[15804] = '\0';
137
138  is.read(buf,2);
139  buf[2] = '\0';
140  data._ascii_flag = buf;
141
142  is.read(buf,2);
143
144  is.read(buf,12);
145  buf[12] = '\0';
146  data._format_doc = buf;
147
148  is.read(buf,2);
149  buf[2] = '\0';
150  data._format_rev = buf;
151
152  is.read(buf,2);
153  buf[2] = '\0';
154  data._design_rev = buf;
155
156  is.read(buf,12);
157  buf[12] = '\0';
158  data._software_id = buf;
159
160  is.read(buf,4);
161  buf[4] = '\0';
162  data._file_num = atoi(buf);
163
165  buf[16] = '\0';
166  data._file_name = buf;
167
168  is.read(buf,4);
169  buf[4] = '\0';
170  data._rec_seq = buf;
171
172  is.read(buf,8);
173  buf[8] = '\0';
174  data._seq_loc = atoi(buf);
175
176  is.read(buf,4);
177  buf[4] = '\0';
178  data._seq_len = atoi(buf);
179
180  is.read(buf,4);
181  buf[4] = '\0';
182  data._rec_code = buf;
183
184  is.read(buf,8);
185  buf[8] = '\0';
186  data._code_loc = atoi(buf);
187
188  is.read(buf,4);
189  buf[4] = '\0';
190  data._code_len = atoi(buf);
191
192  is.read(buf,4);
193  buf[4] = '\0';
194  data._rec_len = buf;
195
196  is.read(buf,8);
197  buf[8] = '\0';
198  data._rlen_loc = atoi(buf);
199
200  is.read(buf,4);
201  buf[4] = '\0';
202  data._rlen_len = atoi(buf);
203
204  for (int i=0;i<4;i++)
205  {
206  is.read(buf,1);
207  }
208
209  is.read(buf,64);
210
211  is.read(buf,6);
212  buf[6] = '\0';
213  data._n_dataset = atoi(buf);
214
215  is.read(buf,6);
216  buf[6] = '\0';
217  data._l_dataset = atoi(buf);
218
219  is.read(buf,24);
220
221  is.read(buf,4);
222  buf[4] = '\0';
223  data._nbit = atoi(buf);
224
225  is.read(buf,4);
226  buf[4] = '\0';
227  data._nsamp = atoi(buf);
228
229  is.read(buf,4);
230  buf[4] = '\0';
231  data._nbyte = atoi(buf);
232
233  is.read(buf,4);
234  buf[4] = '\0';
235  data._justify = buf;
236
237  is.read(buf,4);
238  buf[4] = '\0';
239  data._nchn = atoi(buf);
240
241  is.read(buf,8);
242  buf[8] = '\0';
243
244  // We should use strtol() to avoid wrong conversion with atoi()
245  char* p;
246  int result = strtol(buf, &p, 10);
247  if ( *p != 0 || p == buf)
248  {
249  if(traceDebug())
250  {
251  ossimNotify(ossimNotifyLevel_DEBUG) << "WARNING: strtol() try to convert an empty tab of characters. It may be possible in case of SCN and SCW format" << buf << "!" << std::endl;
252  ossimNotify(ossimNotifyLevel_DEBUG) << "=> _nlin = -1" << std::endl;
253  }
254  data._nlin = -1;
255  }
256  else
257  {
258  data._nlin = result;
259  };
260
261  is.read(buf,4);
262  buf[4] = '\0';
263  data._nleft = atoi(buf);
264
265  is.read(buf,8);
266  buf[8] = '\0';
267  data._ngrp = atoi(buf);
268
269  is.read(buf,4);
270  buf[4] = '\0';
271  data._nright = atoi(buf);
272
273  is.read(buf,4);
274  buf[4] = '\0';
275  data._ntop = atoi(buf);
276
277  is.read(buf,4);
278  buf[4] = '\0';
279  data._nbott = atoi(buf);
280
281  is.read(buf,4);
282  buf[4] = '\0';
283  data._intleav = buf;
284
285  is.read(buf,2);
286  buf[2] = '\0';
287  data._nrec_lin = atoi(buf);
288
289  is.read(buf,2);
290  buf[2] = '\0';
291  data._nrec_chn = atoi(buf);
292
293  is.read(buf,4);
294  buf[4] = '\0';
295  data._n_prefix = atoi(buf);
296
297  is.read(buf,8);
298  buf[8] = '\0';
299  data._n_sar = atoi(buf);
300
301  is.read(buf,4);
302  buf[4] = '\0';
303  data._n_suffix = atoi(buf);
304
305  is.read(buf,4);
306
307  is.read(buf,8);
308  buf[8] = '\0';
309  data._lin_loc = buf;
310
311  is.read(buf,8);
312  buf[8] = '\0';
313  data._chn_loc = buf;
314
315  is.read(buf,8);
316  buf[8] = '\0';
317  data._tim_loc = buf;
318
319  is.read(buf,8);
320  buf[8] = '\0';
321  data._left_loc = buf;
322
323  is.read(buf,8);
324  buf[8] = '\0';
325  data._right_loc = buf;
326
327  is.read(buf,4);
328  buf[4] = '\0';
329  data._pad_ind = buf;
330
331  is.read(buf,28);
332
333  is.read(buf,8);
334  buf[8] = '\0';
335  data._qual_loc = buf;
336
337  is.read(buf,8);
338  buf[8] = '\0';
339  data._cali_loc = buf;
340
341  is.read(buf,8);
342  buf[8] = '\0';
343  data._gain_loc = buf;
344
345  is.read(buf,8);
346  buf[8] = '\0';
347  data._bias_loc = buf;
348
349  is.read(buf,28);
350  buf[28] = '\0';
351  data._type_id = buf;
352
353  is.read(buf,4);
354  buf[4] = '\0';
355  data._type_code = buf;
356
357  is.read(buf,4);
358  buf[4] = '\0';
359  data._left_fill = atoi(buf);
360
361  is.read(buf,4);
362  buf[4] = '\0';
363  data._right_fill = atoi(buf);
364
365  is.read(buf,8);
366  buf[8] = '\0';
367  data._pix_rng = atoi(buf);
368
369  is.read(buf,15804);
370
371  return is;
372  }
◆ operator>>() [54/62]
mph data
Definition at line 190 of file mph.cpp.
References ossimplugins::mph::_abs_orbit, ossimplugins::mph::_absolute_orbit_title, ossimplugins::mph::_acq_stat_id_title, ossimplugins::mph::_acq_station, ossimplugins::mph::_clock_step, ossimplugins::mph::_clock_step_title, ossimplugins::mph::_clock_step_units, ossimplugins::mph::_cycle, ossimplugins::mph::_cycle_title, ossimplugins::mph::_delta_ut1, ossimplugins::mph::_delta_ut1_title, ossimplugins::mph::_delta_ut1_units, ossimplugins::mph::_dsd_size, ossimplugins::mph::_leap_err, ossimplugins::mph::_leap_err_title, ossimplugins::mph::_leap_sign, ossimplugins::mph::_leap_sign_title, ossimplugins::mph::_leap_utc, ossimplugins::mph::_leap_utc_title, ossimplugins::mph::_num_data_sets, ossimplugins::mph::_num_dsd, ossimplugins::mph::_number_of_ds_att_title, ossimplugins::mph::_number_of_dsd_title, ossimplugins::mph::_phase, ossimplugins::mph::_phase_title, ossimplugins::mph::_proc_center, ossimplugins::mph::_proc_center_title, ossimplugins::mph::_proc_stage, ossimplugins::mph::_proc_stage_title, ossimplugins::mph::_proc_time, ossimplugins::mph::_proc_time_title, ossimplugins::mph::_product, ossimplugins::mph::_product_err, ossimplugins::mph::_product_err_title, ossimplugins::mph::_product_name, ossimplugins::mph::_ref_doc, ossimplugins::mph::_ref_doc_title, ossimplugins::mph::_rel_orbit, ossimplugins::mph::_relative_orbit_title, ossimplugins::mph::_sat_binary_time, ossimplugins::mph::_sat_binary_time_title, ossimplugins::mph::_sensing_start, ossimplugins::mph::_sensing_start_title, ossimplugins::mph::_sensing_stop, ossimplugins::mph::_sensing_stop_title, ossimplugins::mph::_size_of_dsd_title, ossimplugins::mph::_size_of_dsd_units, ossimplugins::mph::_soft_version, ossimplugins::mph::_soft_version_title, ossimplugins::mph::_spare_4, ossimplugins::mph::_sph_size, ossimplugins::mph::_sph_size_title, ossimplugins::mph::_sph_size_units, ossimplugins::mph::_state_vector_time, ossimplugins::mph::_state_vector_time_title, ossimplugins::mph::_tot_size, ossimplugins::mph::_total_size_title, ossimplugins::mph::_total_size_units, ossimplugins::mph::_utc_sbt_time, ossimplugins::mph::_utc_sbt_time_title, ossimplugins::mph::_vector_source, ossimplugins::mph::_vector_source_title, ossimplugins::mph::_x_position, ossimplugins::mph::_x_position_title, ossimplugins::mph::_x_position_units, ossimplugins::mph::_x_velocity, ossimplugins::mph::_x_velocity_title, ossimplugins::mph::_x_velocity_units, ossimplugins::mph::_y_position, ossimplugins::mph::_y_position_title, ossimplugins::mph::_y_position_units, ossimplugins::mph::_y_velocity, ossimplugins::mph::_y_velocity_title, ossimplugins::mph::_y_velocity_units, ossimplugins::mph::_z_position, ossimplugins::mph::_z_position_title, ossimplugins::mph::_z_position_units, ossimplugins::mph::_z_velocity, ossimplugins::mph::_z_velocity_title, and ossimplugins::mph::_z_velocity_units.
191  {
192  char buf64[65];
193  buf64[64] = '\0';
194  char buf32[33];
195  buf32[32] = '\0';
196  char buf27[28];
197  buf27[27]='\0';
198  char buf16[17];
199  buf16[16]='\0';
200  // char buf15[16];
201  // buf15[15] = '\0';
202  // char buf14[15];
203  // buf14[14] = '\0';
204  // char buf13[14];
205  // buf13[13] = '\0';
206  char buf12[13];
207  buf12[12] = '\0';
208  char buf11[12];
209  buf11[11] = '\0';
210  char buf10[11];
211  buf10[10] = '\0';
212  // char buf9[10];
213  // buf9[9] = '\0';
214  char buf8[9];
215  buf8[8] = '\0';
216  char buf7[8];
217  buf7[7] = '\0';
218  char buf6[7];
219  buf6[6] = '\0';
220  // char buf5[6];
221  // buf5[5] = '\0';
222  char buf4[5];
223  buf4[4] = '\0';
224  char buf3[4];
225  buf3[3] = '\0';
226  char buf2[3];
227  buf2[2] = '\0';
228  char buf1[1];
229  buf1[0] = '\0';
230
231  is.read(buf8,8);
232  data._product_name = buf8;
233
234  is.read(buf1,1);
235
236  is.read(buf64,62);
237  buf64[62]='\0';
238  data._product = buf64;
239
240  is.read(buf1,1);
241
242  is.read(buf1,1);
243
244  is.read(buf16,11);
245  buf16[11]='\0';
246  data._proc_stage_title = buf16;
247
248  is.read(buf1,1);
249  data._proc_stage = buf1;
250
251  is.read(buf1,1);
252
253  is.read(buf8,8);
254  data._ref_doc_title = buf8;
255
256  is.read(buf1,1);
257
258  is.read(buf32,23);
259  buf32[23]='\0';
260  data._ref_doc = buf32;
261
262  is.read(buf1,1);
263
264  is.read(buf1,1);
265
266  is.read(buf64,40);
267
268  is.read(buf1,1);
269
270  is.read(buf32,20);
271  buf32[20]='\0';
272  data._acq_stat_id_title = buf32;
273
274  is.read(buf1,1);
275
276  is.read(buf32,20);
277  buf32[20]='\0';
278  data._acq_station = buf32;
279
280  is.read(buf1,1);
281
282  is.read(buf1,1);
283
284  is.read(buf16,12);
285  buf16[12]='\0';
286  data._proc_center_title = buf16;
287
288  is.read(buf1,1);
289
290  is.read(buf8,6);
291  buf8[6]='\0';
292  data._proc_center = buf8;
293
294  is.read(buf1,1);
295
296  is.read(buf1,1);
297
298  is.read(buf16,10);
299  buf16[10]='\0';
300  data._proc_time_title = buf16;
301
302  is.read(buf1,1);
303
304  is.read(buf32,27);
305  buf32[27]='\0';
306  data._proc_time = buf32;
307
308  is.read(buf1,1);
309
310  is.read(buf1,1);
311
312  is.read(buf16,13);
313  buf16[13]='\0';
314  data._soft_version_title = buf16;
315
316  is.read(buf1,1);
317
318  is.read(buf16,14);
319  buf16[14]='\0';
320  data._soft_version = buf16;
321
322  is.read(buf1,1);
323
324  is.read(buf1,1);
325
326  is.read(buf64,40);
327
328  is.read(buf1,1);
329
330  is.read(buf16,14);
331  buf16[14]='\0';
332  data._sensing_start_title = buf16;
333
334  is.read(buf1,1);
335
336  is.read(buf32,27);
337  buf32[27]='\0';
338  data._sensing_start = buf32;
339
340  is.read(buf1,1);
341
342  is.read(buf1,1);
343
344  is.read(buf16,13);
345  buf16[13]='\0';
346  data._sensing_stop_title = buf16;
347
348  is.read(buf1,1);
349
350  is.read(buf32,27);
351  buf32[27]='\0';
352  data._sensing_stop = buf32;
353
354  is.read(buf1,1);
355
356  is.read(buf1,1);
357
358  is.read(buf64,40);
359
360  is.read(buf1,1);
361
362  is.read(buf6,6);
363  data._phase_title = buf6;
364
365  is.read(buf1,1);
366  data._phase = buf1;
367
368  is.read(buf1,1);
369
370  is.read(buf6,6);
371  data._cycle_title = buf6;
372
373  is.read(buf4,4);
374  data._cycle = buf4;
375
376  is.read(buf1,1);
377
378  is.read(buf10,10);
379  data._relative_orbit_title = buf10;
380
381  is.read(buf6,6);
382  data._rel_orbit = buf6;
383
384  is.read(buf1,1);
385
386  is.read(buf10,10);
387  data._absolute_orbit_title = buf10;
388
389  is.read(buf6,6);
390  data._abs_orbit = buf6;
391
392  is.read(buf1,1);
393
394  is.read(buf32,18);
395  buf32[18]='\0';
396  data._state_vector_time_title = buf32;
397
398  is.read(buf1,1);
399
400  is.read(buf27,27);
401  data._state_vector_time = buf27;
402
403  is.read(buf1,1);
404
405  is.read(buf1,1);
406
407  is.read(buf10,10);
408  data._delta_ut1_title = buf10;
409
410  is.read(buf8,8);
411  data._delta_ut1 = buf8;
412
413  is.read(buf4,3);
414  buf4[3]='\0';
415  data._delta_ut1_units = buf4;
416
417  is.read(buf1,1);
418
419  is.read(buf11,11);
420  data._x_position_title = buf11;
421
422  is.read(buf12,12);
423  data._x_position = buf12;
424
425  is.read(buf3,3);
426  data._x_position_units = buf3;
427
428  is.read(buf1,1);
429
430  is.read(buf11,11);
431  data._y_position_title = buf11;
432
433  is.read(buf12,12);
434  data._y_position = buf12;
435
436  is.read(buf3,3);
437  data._y_position_units = buf3;
438
439  is.read(buf1,1);
440
441  is.read(buf11,11);
442  data._z_position_title = buf11;
443
444  is.read(buf12,12);
445  data._z_position = buf12;
446
447  is.read(buf3,3);
448  data._z_position_units = buf3;
449
450  is.read(buf1,1);
451
452  is.read(buf11,11);
453  data._x_velocity_title = buf11;
454
455  is.read(buf12,12);
456  data._x_velocity = buf12;
457
458  is.read(buf8,5);
459  buf8[5] = '\0';
460  data._x_velocity_units = buf8;
461
462  is.read(buf1,1);
463
464  is.read(buf11,11);
465  data._y_velocity_title = buf11;
466
467  is.read(buf12,12);
468  data._y_velocity = buf12;
469
470  is.read(buf8,5);
471  buf8[5] = '\0';
472  data._y_velocity_units = buf8;
473
474  is.read(buf1,1);
475
476  is.read(buf11,11);
477  data._z_velocity_title = buf11;
478
479  is.read(buf12,12);
480  data._z_velocity = buf12;
481
482  is.read(buf8,5);
483  buf8[5] = '\0';
484  data._z_velocity_units = buf8;
485
486  is.read(buf1,1);
487
488  is.read(buf16,14);
489  buf16[14] = '\0';
490  data._vector_source_title = buf16;
491
492  is.read(buf1,1);
493
494  is.read(buf2,2);
495  data._vector_source = buf2;
496
497  is.read(buf1,1);
498
499  is.read(buf1,1);
500
501  is.read(buf64,40);
502  buf64[40] = '\0';
503  data._spare_4 = buf64;
504
505  is.read(buf1,1);
506
507  is.read(buf16,13);
508  buf16[13] = '\0';
509  data._utc_sbt_time_title = buf16;
510
511  is.read(buf1,1);
512
513  is.read(buf27,27);
514  data._utc_sbt_time = buf27;
515
516  is.read(buf1,1);
517
518  is.read(buf1,1);
519
520  is.read(buf16,16);
521  data._sat_binary_time_title = buf16;
522
523  is.read(buf11,11);
524  data._sat_binary_time = buf11;
525
526  is.read(buf1,1);
527
528  is.read(buf11,11);
529  data._clock_step_title = buf11;
530
531  is.read(buf11,11);
532  data._clock_step = buf11;
533
534  is.read(buf4,4);
535  data._clock_step_units = buf4;
536
537  is.read(buf1,1);
538
539  is.read(buf32,32);
540
541  is.read(buf1,1);
542
543  is.read(buf10,9);
544  buf10[9] = '\0';
545  data._leap_utc_title = buf10;
546
547  is.read(buf1,1);
548
549  is.read(buf27,27);
550  data._leap_utc = buf27;
551
552  is.read(buf1,1);
553
554  is.read(buf1,1);
555
556  is.read(buf10,10);
557  data._leap_sign_title = buf10;
558
559  is.read(buf4,4);
560  data._leap_sign = buf4;
561
562  is.read(buf1,1);
563
564  is.read(buf10,9);
565  buf10[9] = '\0';
566  data._leap_err_title = buf10;
567
568  is.read(buf1,1);
569  data._leap_err = buf1;
570
571  is.read(buf1,1);
572
573  is.read(buf64,40);
574
575  is.read(buf1,1);
576
577  is.read(buf12,12);
578  data._product_err_title = buf12;
579
580  is.read(buf1,1);
581  data._product_err = buf1;
582
583  is.read(buf1,1);
584
585  is.read(buf10,9);
586  buf10[9] = '\0';
587  data._total_size_title = buf10;
588
589  is.read(buf32,21);
590  buf32[21] = '\0';
591  data._tot_size = buf32;
592
593  is.read(buf7,7);
594  data._total_size_units = buf7;
595
596  is.read(buf1,1);
597
598  is.read(buf10,9);
599  buf10[9] = '\0';
600  data._sph_size_title = buf10;
601
602  is.read(buf11,11);
603  data._sph_size = buf11;
604
605  is.read(buf8,7);
606  buf8[7] = '\0';
607  data._sph_size_units = buf8;
608
609  is.read(buf1,1);
610
611  is.read(buf8,8);
612  data._number_of_dsd_title = buf8;
613
614  is.read(buf11,11);
615  data._num_dsd = atoi(buf11);
616
617  is.read(buf1,1);
618
619  is.read(buf10,9);
620  buf10[9] = '\0';
621  data._size_of_dsd_title = buf10;
622
623  is.read(buf11,11);
624  data._dsd_size = atoi(buf11);
625
626  is.read(buf8,7);
627  buf8[7] = '\0';
628  data._size_of_dsd_units = buf8;
629
630  is.read(buf1,1);
631
632  is.read(buf16,14);
633  buf16[14] = '\0';
634  data._number_of_ds_att_title = buf16;
635
636  is.read(buf11,11);
637  data._num_data_sets = atoi(buf11);
638
639  is.read(buf1,1);
640
641  is.read(buf64,40);
642
643  is.read(buf1,1);
644
645  return is;
646  }
◆ operator>>() [55/62]
sph data
Definition at line 200 of file sph.cpp.
References ossimplugins::sph::_algo_title, ossimplugins::sph::_algorithm, ossimplugins::sph::_azimut_looks, ossimplugins::sph::_azimut_looks_title, ossimplugins::sph::_azimut_spacing, ossimplugins::sph::_azimut_spacing_title, ossimplugins::sph::_azimut_spacing_unit, ossimplugins::sph::_compression, ossimplugins::sph::_compression_title, ossimplugins::sph::_data_type, ossimplugins::sph::_data_type_title, ossimplugins::sph::_dsd_vector, ossimplugins::sph::_first_far_lat, ossimplugins::sph::_first_far_lat_title, ossimplugins::sph::_first_far_lat_units, ossimplugins::sph::_first_far_long, ossimplugins::sph::_first_far_long_title, ossimplugins::sph::_first_far_long_units, ossimplugins::sph::_first_line_time, ossimplugins::sph::_first_line_time_title, ossimplugins::sph::_first_mid_lat, ossimplugins::sph::_first_mid_lat_title, ossimplugins::sph::_first_mid_lat_units, ossimplugins::sph::_first_mid_long, ossimplugins::sph::_first_mid_long_title, ossimplugins::sph::_first_mid_long_units, ossimplugins::sph::_first_near_lat, ossimplugins::sph::_first_near_lat_title, ossimplugins::sph::_first_near_lat_units, ossimplugins::sph::_first_near_long, ossimplugins::sph::_first_near_long_title, ossimplugins::sph::_first_near_long_units, ossimplugins::sph::_last_far_lat, ossimplugins::sph::_last_far_lat_title, ossimplugins::sph::_last_far_lat_units, ossimplugins::sph::_last_far_long, ossimplugins::sph::_last_far_long_title, ossimplugins::sph::_last_far_long_units, ossimplugins::sph::_last_line_time, ossimplugins::sph::_last_line_time_title, ossimplugins::sph::_last_mid_lat, ossimplugins::sph::_last_mid_lat_title, ossimplugins::sph::_last_mid_lat_units, ossimplugins::sph::_last_mid_long, ossimplugins::sph::_last_mid_long_title, ossimplugins::sph::_last_mid_long_units, ossimplugins::sph::_last_near_lat, ossimplugins::sph::_last_near_lat_title, ossimplugins::sph::_last_near_lat_units, ossimplugins::sph::_last_near_long, ossimplugins::sph::_last_near_long_title, ossimplugins::sph::_last_near_long_units, ossimplugins::sph::_line_length, ossimplugins::sph::_line_length_title, ossimplugins::sph::_line_length_units, ossimplugins::sph::_line_time_interv_units, ossimplugins::sph::_line_time_interval, ossimplugins::sph::_line_time_interval_title, ossimplugins::sph::_mds1_tx_rx_polar, ossimplugins::sph::_mds1_tx_rx_polar_title, ossimplugins::sph::_mds2_tx_rx_polar, ossimplugins::sph::_mds2_tx_rx_polar_title, ossimplugins::sph::_num_dsd, ossimplugins::sph::_num_slices, ossimplugins::sph::_num_slices_title, ossimplugins::sph::_pass, ossimplugins::sph::_pass_title, ossimplugins::sph::_range_looks, ossimplugins::sph::_range_looks_title, ossimplugins::sph::_range_spacing, ossimplugins::sph::_range_spacing_title, ossimplugins::sph::_range_spacing_unit, ossimplugins::sph::_sample_type, ossimplugins::sph::_sample_type_title, ossimplugins::sph::_slice_pos_title, ossimplugins::sph::_slice_position, ossimplugins::sph::_sph_desc, ossimplugins::sph::_sph_desc_title, ossimplugins::sph::_strip_cont_ind, ossimplugins::sph::_strip_cont_ind_title, ossimplugins::sph::_swath, and ossimplugins::sph::_swath_title.
201  {
202  char buf64[65];
203  buf64[64] = '\0';
204  char buf32[33];
205  buf32[32] = '\0';
206  char buf27[28];
207  buf27[27] = '\0';
208  char buf16[17];
209  buf16[16]='\0';
210  char buf15[16];
211  buf15[15] = '\0';
212  char buf14[15];
213  buf14[14] = '\0';
214  char buf13[14];
215  buf13[13] = '\0';
216  char buf12[13];
217  buf12[12] = '\0';
218  char buf11[12];
219  buf11[11] = '\0';
220  char buf10[11];
221  buf10[10] = '\0';
222  char buf9[10];
223  buf9[9] = '\0';
224  char buf8[9];
225  buf8[8] = '\0';
226  char buf7[8];
227  buf7[7] = '\0';
228  char buf6[7];
229  buf6[6] = '\0';
230  char buf5[6];
231  buf5[5] = '\0';
232  char buf4[5];
233  buf4[4] = '\0';
234  char buf3[4];
235  buf3[3] = '\0';
236  // char buf2[3];
237  // buf2[2] = '\0';
238  char buf1[1];
239
240
241  is.read(buf15,15);
242  data._sph_desc_title = buf15;
243
244  is.read(buf1,1);
245
246  is.read(buf32,28);
247  buf32[28] = '\0';
248  data._sph_desc = buf32;
249
250  is.read(buf1,1);
251
252  is.read(buf1,1);
253
254  is.read(buf32,31);
255  buf32[31] = '\0';
256  data._strip_cont_ind_title = buf32;
257
258  is.read(buf4,4);
259  data._strip_cont_ind = buf4;
260
261  is.read(buf1,1);
262
263  is.read(buf15,15);
264  data._slice_pos_title = buf15;
265
266  is.read(buf4,4);
267  data._slice_position = buf4;
268
269  is.read(buf1,1);
270
271  is.read(buf11,11);
272  data._num_slices_title = buf11;
273
274  is.read(buf4,4);
275  data._num_slices = buf4;
276
277  is.read(buf1,1);
278
279  is.read(buf16,16);
280  data._first_line_time_title = buf16;
281
283
284  is.read(buf27,27);
285  data._first_line_time = buf27;
286
287  is.read(buf1,1);
288
289  is.read(buf1,1);
290
291  is.read(buf15,15);
292  data._last_line_time_title = buf15;
293
295
296  is.read(buf27,27);
297  data._last_line_time = buf27;
298
299  is.read(buf1,1);
300
301  is.read(buf1,1);
302
303  is.read(buf15,15);
304  data._first_near_lat_title = buf15;
305
306  is.read(buf11,11);
307  data._first_near_lat = buf11;
308
309  is.read(buf10,10);
310  data._first_near_lat_units = buf10;
311
312  is.read(buf1,1);
313
314  is.read(buf16,16);
315  data._first_near_long_title = buf16;
316
317  is.read(buf11,11);
318  data._first_near_long = buf11;
319
320  is.read(buf10,10);
321  data._first_near_long_units = buf10;
322
323  is.read(buf1,1);
324
325  is.read(buf14,14);
326  data._first_mid_lat_title = buf14;
327
328  is.read(buf11,11);
329  data._first_mid_lat = buf11;
330
331  is.read(buf10,10);
332  data._first_mid_lat_units = buf10;
333
335
336  is.read(buf15,15);
337  data._first_mid_long_title = buf15;
338
339  is.read(buf11,11);
340  data._first_mid_long = buf11;
341
342  is.read(buf10,10);
343  data._first_mid_long_units = buf10;
344
345  is.read(buf1,1);
346
347  is.read(buf14,14);
348  data._first_far_lat_title = buf14;
349
350  is.read(buf11,11);
351  data._first_far_lat = buf11;
352
353  is.read(buf10,10);
354  data._first_far_lat_units = buf10;
355
357
358  is.read(buf15,15);
359  data._first_far_long_title = buf15;
360
361  is.read(buf11,11);
362  data._first_far_long = buf11;
363
364  is.read(buf10,10);
365  data._first_far_long_units = buf10;
366
367  is.read(buf1,1);
368
369  is.read(buf14,14);
370  data._last_near_lat_title = buf14;
371
372  is.read(buf11,11);
373  data._last_near_lat = buf11;
374
375  is.read(buf10,10);
376  data._last_near_lat_units = buf10;
377
378  is.read(buf1,1);
379
380  is.read(buf15,15);
381  data._last_near_long_title = buf15;
382
383  is.read(buf11,11);
384  data._last_near_long = buf11;
385
387  data._last_near_long_units = buf10;
388
389  is.read(buf1,1);
390
391  is.read(buf13,13);
392  data._last_mid_lat_title = buf13;
393
394  is.read(buf11,11);
395  data._last_mid_lat = buf11;
396
397  is.read(buf10,10);
398  data._last_mid_lat_units = buf10;
399
400  is.read(buf1,1);
401
402  is.read(buf14,14);
403  data._last_mid_long_title = buf14;
404
405  is.read(buf11,11);
406  data._last_mid_long = buf11;
407
408  is.read(buf10,10);
409  data._last_mid_long_units = buf10;
410
411  is.read(buf1,1);
412
413  is.read(buf13,13);
414  data._last_far_lat_title = buf13;
415
416  is.read(buf11,11);
417  data._last_far_lat = buf11;
418
419  is.read(buf10,10);
420  data._last_far_lat_units = buf10;
421
422  is.read(buf1,1);
423
424  is.read(buf14,14);
425  data._last_far_long_title = buf14;
426
427  is.read(buf11,11);
428  data._last_far_long = buf11;
429
430  is.read(buf10,10);
431  data._last_far_long_units = buf10;
432
433  is.read(buf1,1);
434
435  is.read(buf64,35);
436
437  is.read(buf1,1);
438
439  is.read(buf6,6);
440  data._swath_title = buf6;
441
442  is.read(buf1,1);
443
444  is.read(buf3,3);
445  data._swath = buf3;
446
447  is.read(buf1,1);
448
449  is.read(buf1,1);
450
451  is.read(buf5,5);
452  data._pass_title = buf5;
453
454  is.read(buf1,1);
455
456  is.read(buf10,10);
457  data._pass = buf10;
458
459  is.read(buf1,1);
460
461  is.read(buf1,1);
462
463  is.read(buf12,12);
464  data._sample_type_title = buf12;
465
466  is.read(buf1,1);
467
468  is.read(buf8,8);
469  data._sample_type = buf8;
470
471  is.read(buf1,1);
472
473  is.read(buf1,1);
474
475  is.read(buf10,10);
476  data._algo_title = buf10;
477
478  is.read(buf1,1);
479
480  is.read(buf7,7);
481  data._algorithm = buf7;
482
483  is.read(buf1,1);
484
485  is.read(buf1,1);
486
487  is.read(buf32,17);
488  buf32[17] = '\0';
489  data._mds1_tx_rx_polar_title = buf32;
490
491  is.read(buf1,1);
492
493  is.read(buf3,3);
494  data._mds1_tx_rx_polar = buf3;
495
496  is.read(buf1,1);
497
498  is.read(buf1,1);
499
500  is.read(buf32,17);
501  buf32[17] = '\0';
502  data._mds2_tx_rx_polar_title = buf32;
503
504  is.read(buf1,1);
505
506  is.read(buf3,3);
507  data._mds2_tx_rx_polar = buf3;
508
509  is.read(buf1,1);
510
512
513  is.read(buf12,12);
514  data._compression_title = buf12;
515
517
518  is.read(buf5,5);
519  data._compression = buf5;
520
521  is.read(buf1,1);
522
523  is.read(buf1,1);
524
525  is.read(buf14,14);
526  data._azimut_looks_title = buf14;
527
528  is.read(buf4,4);
529  data._azimut_looks = buf4;
530
531  is.read(buf1,1);
532
533  is.read(buf12,12);
534  data._range_looks_title = buf12;
535
536  is.read(buf4,4);
537  data._range_looks = buf4;
538
539  is.read(buf1,1);
540
541  is.read(buf14,14);
542  data._range_spacing_title = buf14;
543
544  is.read(buf15,15);
545  data._range_spacing = buf15;
546
547  is.read(buf3,3);
548  data._range_spacing_unit = buf3;
549
550  is.read(buf1,1);
551
552  is.read(buf16,16);
553  data._azimut_spacing_title = buf16;
554
555  is.read(buf15,15);
556  data._azimut_spacing = buf15;
557
558  is.read(buf3,3);
559  data._azimut_spacing_unit = buf3;
560
561  is.read(buf1,1);
562
563  is.read(buf32,19);
564  buf32[19] = '\0';
565  data._line_time_interval_title = buf32;
566
567  is.read(buf15,15);
568  data._line_time_interval = buf15;
569
570  is.read(buf3,3);
571  data._line_time_interv_units = buf3;
572
573  is.read(buf1,1);
574
575  is.read(buf12,12);
576  data._line_length_title = buf12;
577
578  is.read(buf6,6);
579  data._line_length = buf6;
580
581  is.read(buf9,9);
582  data._line_length_units = buf9;
583
584  is.read(buf1,1);
585
586  is.read(buf10,10);
587  data._data_type_title = buf10;
588
589  is.read(buf1,1);
590
591  is.read(buf5,5);
592  data._data_type = buf5;
593
594  is.read(buf1,1);
595
597
598  is.read(buf64,50);
599
600  is.read(buf1,1);
601
602  for (int i = 0; i<data._num_dsd; i++)
603  {
604  dsd dsd_rec;
605  is>>dsd_rec;
606  data._dsd_vector.push_back(dsd_rec);
607  }
608
609  //char *buffer = (char* )malloc(data._num_dsd*data._size_dsd);
610  //is.read(buffer, data._num_dsd*data._size_dsd);
611
612  return is;
613  }
◆ operator>>() [56/62]
std::istream& ossimplugins::operator>> ( std::istream &  is,
AlosPalsarDataSetSummary data
from 1767 to 4096 to be added
Definition at line 204 of file AlosPalsarDataSetSummary.cpp.
References ossimplugins::AlosPalsarDataSetSummary::_algor_id, ossimplugins::AlosPalsarDataSetSummary::_alt_dopcen, ossimplugins::AlosPalsarDataSetSummary::_alt_rate, ossimplugins::AlosPalsarDataSetSummary::_ampl_coef, ossimplugins::AlosPalsarDataSetSummary::_asc_des, ossimplugins::AlosPalsarDataSetSummary::_auto_focus, ossimplugins::AlosPalsarDataSetSummary::_azi_res, ossimplugins::AlosPalsarDataSetSummary::_azi_weight, ossimplugins::AlosPalsarDataSetSummary::_baseband_f, ossimplugins::AlosPalsarDataSetSummary::_bnd_azi, ossimplugins::AlosPalsarDataSetSummary::_bnd_azilok, ossimplugins::AlosPalsarDataSetSummary::_bnd_rng, ossimplugins::AlosPalsarDataSetSummary::_bnd_rnglok, ossimplugins::AlosPalsarDataSetSummary::_chirp_ext_ind, ossimplugins::AlosPalsarDataSetSummary::_chn_bits, ossimplugins::AlosPalsarDataSetSummary::_clock_ang, ossimplugins::AlosPalsarDataSetSummary::_clutter_lock, ossimplugins::AlosPalsarDataSetSummary::_crt_dopcen, ossimplugins::AlosPalsarDataSetSummary::_crt_rate, ossimplugins::AlosPalsarDataSetSummary::_data_inpsrc, ossimplugins::AlosPalsarDataSetSummary::_dopcen_range, ossimplugins::AlosPalsarDataSetSummary::_earth_mass, ossimplugins::AlosPalsarDataSetSummary::_ellip_des, ossimplugins::AlosPalsarDataSetSummary::_ellip_j, ossimplugins::AlosPalsarDataSetSummary::_ellip_maj, ossimplugins::AlosPalsarDataSetSummary::_ellip_min, ossimplugins::AlosPalsarDataSetSummary::_fa, ossimplugins::AlosPalsarDataSetSummary::_fac_id, ossimplugins::AlosPalsarDataSetSummary::_fr, ossimplugins::AlosPalsarDataSetSummary::_gn_cross, ossimplugins::AlosPalsarDataSetSummary::_gn_polar, ossimplugins::AlosPalsarDataSetSummary::_grav_const, ossimplugins::AlosPalsarDataSetSummary::_i_bias, ossimplugins::AlosPalsarDataSetSummary::_incident_ang, ossimplugins::AlosPalsarDataSetSummary::_inp_sctim, ossimplugins::AlosPalsarDataSetSummary::_iq_ratio, ossimplugins::AlosPalsarDataSetSummary::_line_cont, ossimplugins::AlosPalsarDataSetSummary::_line_spacing, ossimplugins::AlosPalsarDataSetSummary::_mech_sight, ossimplugins::AlosPalsarDataSetSummary::_mission_id, ossimplugins::AlosPalsarDataSetSummary::_motion_comp, ossimplugins::AlosPalsarDataSetSummary::_n_azilok, ossimplugins::AlosPalsarDataSetSummary::_n_rnglok, ossimplugins::AlosPalsarDataSetSummary::_nchn, ossimplugins::AlosPalsarDataSetSummary::_orbit_num, ossimplugins::AlosPalsarDataSetSummary::_phas_coef, ossimplugins::AlosPalsarDataSetSummary::_pix_spacing, ossimplugins::AlosPalsarDataSetSummary::_plat_head, ossimplugins::AlosPalsarDataSetSummary::_plat_lat, ossimplugins::AlosPalsarDataSetSummary::_plat_long, ossimplugins::AlosPalsarDataSetSummary::_pro_head, ossimplugins::AlosPalsarDataSetSummary::_pro_lat, ossimplugins::AlosPalsarDataSetSummary::_pro_long, ossimplugins::AlosPalsarDataSetSummary::_prod_type, ossimplugins::AlosPalsarDataSetSummary::_pulse_code, ossimplugins::AlosPalsarDataSetSummary::_q_bias, ossimplugins::AlosPalsarDataSetSummary::_quant_desc, ossimplugins::AlosPalsarDataSetSummary::_rng_gate, ossimplugins::AlosPalsarDataSetSummary::_rng_length, ossimplugins::AlosPalsarDataSetSummary::_rng_res, ossimplugins::AlosPalsarDataSetSummary::_rng_weight, ossimplugins::AlosPalsarDataSetSummary::_rngcmp_desg, ossimplugins::AlosPalsarDataSetSummary::_rngcmp_f, ossimplugins::AlosPalsarDataSetSummary::_sar_chn, ossimplugins::AlosPalsarDataSetSummary::_sat_bintim, ossimplugins::AlosPalsarDataSetSummary::_sat_clkinc, ossimplugins::AlosPalsarDataSetSummary::_sat_clktim, ossimplugins::AlosPalsarDataSetSummary::_sc_lin, ossimplugins::AlosPalsarDataSetSummary::_sc_pix, ossimplugins::AlosPalsarDataSetSummary::_scene_des, ossimplugins::AlosPalsarDataSetSummary::_scene_id, ossimplugins::AlosPalsarDataSetSummary::_scene_len, ossimplugins::AlosPalsarDataSetSummary::_scene_wid, ossimplugins::AlosPalsarDataSetSummary::_sensor_id, ossimplugins::AlosPalsarDataSetSummary::_seq_num, ossimplugins::AlosPalsarDataSetSummary::_sys_id, ossimplugins::AlosPalsarDataSetSummary::_terrain_h, ossimplugins::AlosPalsarDataSetSummary::_time_dir_lin, ossimplugins::AlosPalsarDataSetSummary::_time_dir_pix, ossimplugins::AlosPalsarDataSetSummary::_ver_id, and ossimplugins::AlosPalsarDataSetSummary::_wave_length.
205 {
206  char buf16[17];
207  buf16[16] = '\0';
208  char buf32[33];
209  buf32[32] = '\0';
210  char buf8[9];
211  buf8[8] = '\0';
212  char buf4[5];
213  buf4[4] = '\0';
214  char buf2330[2331]; //data skip from 1767 to 4096//
215  buf2330[2330] = '\0'; //data skip from 1767 to 4096//
216
217  is.read(buf4, 4);
218  data._seq_num = atoi(buf4);
219
220  is.read(buf4, 4);
221  data._sar_chn = atoi(buf4);
222
223  is.read(buf16, 16);
224  data._scene_id = buf16;
225
226  is.read(buf32, 32);
227  data._scene_des = buf32;
228
229  is.read(buf32, 32);
230  data._inp_sctim = buf32;
231
232  is.read(buf16, 16);
233  data._asc_des = buf16;
234
235  is.read(buf16, 16);
236  data._pro_lat = atof(buf16);
237
238  is.read(buf16, 16);
239  data._pro_long = atof(buf16);
240
241  is.read(buf16, 16);
242  data._pro_head = atof(buf16);
243
244  is.read(buf16, 16);
245  data._ellip_des = buf16;
246
247  is.read(buf16, 16);
248  data._ellip_maj = atof(buf16);
249
250  is.read(buf16, 16);
251  data._ellip_min = atof(buf16);
252
253  is.read(buf16, 16);
254  data._earth_mass = atof(buf16);
255
256  is.read(buf16, 16);
257  data._grav_const = atof(buf16);
258
259  is.read(buf16, 16);
260  data._ellip_j[0] = atof(buf16);
261  is.read(buf16, 16);
262  data._ellip_j[1] = atof(buf16);
263  is.read(buf16, 16);
264  data._ellip_j[2] = atof(buf16);
265
266  is.read(buf16, 16);
267
268  is.read(buf16, 16);
269  data._terrain_h = atof(buf16);
270
271  is.read(buf8, 8);
272  data._sc_lin = atoi(buf8);
273
274  is.read(buf8, 8);
275  data._sc_pix = atoi(buf8);
276
277  is.read(buf16, 16);
278  data._scene_len = atof(buf16);
279
280  is.read(buf16, 16);
281  data._scene_wid = atof(buf16);
282
283  is.read(buf16, 16);
284
285  is.read(buf4, 4);
286  data._nchn = atoi(buf4);
287
288  is.read(buf4, 4);
289
290  is.read(buf16, 16);
291  data._mission_id = buf16;
292
293  is.read(buf32, 32);
294  data._sensor_id = buf32;
295
296  is.read(buf8, 8);
297  data._orbit_num = buf8;
298
299  is.read(buf8, 8);
300  data._plat_lat = atof(buf8);
301
302  is.read(buf8, 8);
303  data._plat_long = atof(buf8);
304
305  is.read(buf8, 8);
306  data._plat_head = atof(buf8);
307
308  is.read(buf8, 8);
309  data._clock_ang = atof(buf8);
310
311  is.read(buf8, 8);
312  data._incident_ang = atof(buf8);
313
314  is.read(buf8, 8);
315
316  is.read(buf16, 16);
317  data._wave_length = atof(buf16);
318
319  is.read(buf8, 2);
320  buf8[2] = '\0';
321  data._motion_comp = buf8;
322
323  is.read(buf16, 16);
324  data._pulse_code = buf16;
325
326  for (int i = 0; i < 5; i++)
327  {
328  is.read(buf16, 16);
329  data._ampl_coef[i] = atof(buf16);
330  }
331
332  for (int i = 0; i < 5; i++)
333  {
334  is.read(buf16, 16);
335  data._phas_coef[i] = atof(buf16);
336  }
337
338  is.read(buf8, 8);
339  data._chirp_ext_ind = atoi(buf8);
340
341  is.read(buf8, 8);
342
343  is.read(buf16, 16);
344  data._fr = atof(buf16);
345
346  is.read(buf16, 16);
347  data._rng_gate = atof(buf16);
348
349  is.read(buf16, 16);
350  data._rng_length = atof(buf16);
351
352  is.read(buf8, 4);
353  buf8[4] = '\0';
354  data._baseband_f = buf8;
355
356  is.read(buf8, 4);
357  buf8[4] = '\0';
358  data._rngcmp_f = buf8;
359
360  is.read(buf16, 16);
361  data._gn_polar = atof(buf16);
362
363  is.read(buf16, 16);
364  data._gn_cross = atof(buf16);
365
366  is.read(buf8, 8);
367  data._chn_bits = atoi(buf8);
368
369  is.read(buf16, 12);
370  buf16[12] = '\0';
371  data._quant_desc = buf16;
372
373  is.read(buf16, 16);
374  data._i_bias = atof(buf16);
375
376  is.read(buf16, 16);
377  data._q_bias = atof(buf16);
378
379  is.read(buf16, 16);
380  data._iq_ratio = atof(buf16);
381
382  is.read(buf32, 32);
383
384  is.read(buf16, 16);
385
386  is.read(buf16, 16);
387  data._mech_sight = atof(buf16);
388
389  is.read(buf4, 4);
390
391  is.read(buf16, 16);
392  data._fa = atof(buf16);
393
394  is.read(buf16, 16);
395
396  is.read(buf16, 16);
397
398  is.read(buf16, 16);
399  data._sat_bintim = buf16;
400
401  is.read(buf32, 32);
402  data._sat_clktim = buf32;
403
404  is.read(buf8, 8);
405  data._sat_clkinc = buf8;
406
407  is.read(buf8, 8);
408
409  is.read(buf16, 16);
410  data._fac_id = buf16;
411
412  is.read(buf8, 8);
413  data._sys_id = buf8;
414
415  is.read(buf8, 8);
416  data._ver_id = buf8;
417
418  is.read(buf32, 32);
419
420  is.read(buf32, 32);
421  data._prod_type = buf32;
422
423  is.read(buf32, 32);
424  data._algor_id = buf32;
425
426  is.read(buf16, 16);
427  data._n_azilok = atof(buf16);
428
429  is.read(buf16, 16);
430  data._n_rnglok = atof(buf16);
431
432  is.read(buf16, 16);
433  data._bnd_azilok = atof(buf16);
434
435  is.read(buf16, 16);
436  data._bnd_rnglok = atof(buf16);
437
438  is.read(buf16, 16);
439  data._bnd_azi = atof(buf16);
440
441  is.read(buf16, 16);
442  data._bnd_rng = atof(buf16);
443
444  is.read(buf32, 32);
445  data._azi_weight = buf32;
446
447  is.read(buf32, 32);
448  data._rng_weight = buf32;
449
450  is.read(buf16, 16);
451  data._data_inpsrc = buf16;
452
453  is.read(buf16, 16);
454  data._rng_res = atof(buf16);
455
456  is.read(buf16, 16);
457  data._azi_res = atof(buf16);
458
459  is.read(buf32, 32);
460
461  is.read(buf16, 16);
462  data._alt_dopcen[0] = atof(buf16);
463  is.read(buf16, 16);
464  data._alt_dopcen[1] = atof(buf16);
465  is.read(buf16, 16);
466  data._alt_dopcen[2] = atof(buf16);
467
468  is.read(buf16, 16);
469
470  is.read(buf16, 16);
471  data._crt_dopcen[0] = atof(buf16);
472  is.read(buf16, 16);
473  data._crt_dopcen[1] = atof(buf16);
474  is.read(buf16, 16);
475  data._crt_dopcen[2] = atof(buf16);
476
477  is.read(buf8, 8);
478  data._time_dir_pix = buf8;
479
480  is.read(buf8, 8);
481  data._time_dir_lin = buf8;
482
483  is.read(buf16, 16);
484  data._alt_rate[0] = atof(buf16);
485  is.read(buf16, 16);
486  data._alt_rate[1] = atof(buf16);
487  is.read(buf16, 16);
488  data._alt_rate[2] = atof(buf16);
489
490  is.read(buf16, 16);
491
492  is.read(buf16, 16);
493  data._crt_rate[0] = atof(buf16);
494  is.read(buf16, 16);
495  data._crt_rate[1] = atof(buf16);
496  is.read(buf16, 16);
497  data._crt_rate[2] = atof(buf16);
498
499  is.read(buf16, 16);
500
501  is.read(buf8, 8);
502  data._line_cont = buf8;
503
504  is.read(buf4, 4);
505  data._clutter_lock = buf4;
506
507  is.read(buf4, 4);
508  data._auto_focus = buf4;
509
510  is.read(buf16, 16);
511  data._line_spacing = atof(buf16);
512
513  is.read(buf16, 16);
514  data._pix_spacing = atof(buf16);
515
516  is.read(buf16, 16);
517  data._rngcmp_desg = buf16;
518
519  is.read(buf16, 16);
520  data._dopcen_range[0] = atof(buf16);
521
522  is.read(buf16, 16);
523  data._dopcen_range[1] = atof(buf16);
524
529  is.read(buf2330, 2330);
530
531  return is;
532 }
◆ operator>>() [57/62]
ErsSarDataSetSummary data
Definition at line 208 of file ErsSarDataSetSummary.cpp.
References ossimplugins::ErsSarDataSetSummary::_algor_id, ossimplugins::ErsSarDataSetSummary::_alt_dopcen, ossimplugins::ErsSarDataSetSummary::_alt_rate, ossimplugins::ErsSarDataSetSummary::_ampl_coef, ossimplugins::ErsSarDataSetSummary::_asc_des, ossimplugins::ErsSarDataSetSummary::_auto_focus, ossimplugins::ErsSarDataSetSummary::_azi_res, ossimplugins::ErsSarDataSetSummary::_azi_weight, ossimplugins::ErsSarDataSetSummary::_baseband_f, ossimplugins::ErsSarDataSetSummary::_bnd_azi, ossimplugins::ErsSarDataSetSummary::_bnd_azilok, ossimplugins::ErsSarDataSetSummary::_bnd_rng, ossimplugins::ErsSarDataSetSummary::_bnd_rnglok, ossimplugins::ErsSarDataSetSummary::_chirp_ext_ind, ossimplugins::ErsSarDataSetSummary::_chn_bits, ossimplugins::ErsSarDataSetSummary::_clock_ang, ossimplugins::ErsSarDataSetSummary::_clutter_lock, ossimplugins::ErsSarDataSetSummary::_crt_dopcen, ossimplugins::ErsSarDataSetSummary::_crt_rate, ossimplugins::ErsSarDataSetSummary::_data_inpsrc, ossimplugins::ErsSarDataSetSummary::_earth_mass, ossimplugins::ErsSarDataSetSummary::_ellip_des, ossimplugins::ErsSarDataSetSummary::_ellip_j, ossimplugins::ErsSarDataSetSummary::_ellip_maj, ossimplugins::ErsSarDataSetSummary::_ellip_min, ossimplugins::ErsSarDataSetSummary::_fa, ossimplugins::ErsSarDataSetSummary::_fac_id, ossimplugins::ErsSarDataSetSummary::_fr, ossimplugins::ErsSarDataSetSummary::_gn_cross, ossimplugins::ErsSarDataSetSummary::_gn_polar, ossimplugins::ErsSarDataSetSummary::_grav_const, ossimplugins::ErsSarDataSetSummary::_i_bias, ossimplugins::ErsSarDataSetSummary::_incident_ang, ossimplugins::ErsSarDataSetSummary::_inp_sctim, ossimplugins::ErsSarDataSetSummary::_iq_ratio, ossimplugins::ErsSarDataSetSummary::_line_cont, ossimplugins::ErsSarDataSetSummary::_line_spacing, ossimplugins::ErsSarDataSetSummary::_mech_sight, ossimplugins::ErsSarDataSetSummary::_mission_id, ossimplugins::ErsSarDataSetSummary::_motion_comp, ossimplugins::ErsSarDataSetSummary::_n_azilok, ossimplugins::ErsSarDataSetSummary::_n_rnglok, ossimplugins::ErsSarDataSetSummary::_nchn, ossimplugins::ErsSarDataSetSummary::_orbit_num, ossimplugins::ErsSarDataSetSummary::_phas_coef, ossimplugins::ErsSarDataSetSummary::_pix_spacing, ossimplugins::ErsSarDataSetSummary::_plat_head, ossimplugins::ErsSarDataSetSummary::_plat_lat, ossimplugins::ErsSarDataSetSummary::_plat_long, ossimplugins::ErsSarDataSetSummary::_pro_head, ossimplugins::ErsSarDataSetSummary::_pro_lat, ossimplugins::ErsSarDataSetSummary::_pro_long, ossimplugins::ErsSarDataSetSummary::_prod_type, ossimplugins::ErsSarDataSetSummary::_pulse_code, ossimplugins::ErsSarDataSetSummary::_q_bias, ossimplugins::ErsSarDataSetSummary::_quant_desc, ossimplugins::ErsSarDataSetSummary::_rng_gate, ossimplugins::ErsSarDataSetSummary::_rng_length, ossimplugins::ErsSarDataSetSummary::_rng_res, ossimplugins::ErsSarDataSetSummary::_rng_weight, ossimplugins::ErsSarDataSetSummary::_rngcmp_desg, ossimplugins::ErsSarDataSetSummary::_rngcmp_f, ossimplugins::ErsSarDataSetSummary::_sar_chn, ossimplugins::ErsSarDataSetSummary::_sat_bintim, ossimplugins::ErsSarDataSetSummary::_sat_clkinc, ossimplugins::ErsSarDataSetSummary::_sat_clktim, ossimplugins::ErsSarDataSetSummary::_sc_lin, ossimplugins::ErsSarDataSetSummary::_sc_pix, ossimplugins::ErsSarDataSetSummary::_scene_des, ossimplugins::ErsSarDataSetSummary::_scene_id, ossimplugins::ErsSarDataSetSummary::_scene_len, ossimplugins::ErsSarDataSetSummary::_scene_wid, ossimplugins::ErsSarDataSetSummary::_sensor_id, ossimplugins::ErsSarDataSetSummary::_seq_num, ossimplugins::ErsSarDataSetSummary::_sys_id, ossimplugins::ErsSarDataSetSummary::_terrain_h, ossimplugins::ErsSarDataSetSummary::_time_dir_lin, ossimplugins::ErsSarDataSetSummary::_time_dir_pix, ossimplugins::ErsSarDataSetSummary::_ver_id, ossimplugins::ErsSarDataSetSummary::_wave_length, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_c_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_f_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_l_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_c_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_f_pixel, and ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_l_pixel.
209 {
210  char buf16[17];
211  buf16[16] = '\0';
212  char buf32[33];
213  buf32[32] = '\0';
214  char buf8[9];
215  buf8[8] = '\0';
216  char buf4[5];
217  buf4[4] = '\0';
218
219  is.read(buf4, 4);
220  data._seq_num = atoi(buf4);
221
222  is.read(buf4, 4);
223  data._sar_chn = atoi(buf4);
224
225  is.read(buf16, 16);
226  data._scene_id = buf16;
227
228  is.read(buf32, 32);
229  data._scene_des = buf32;
230
231  is.read(buf32, 32);
232  data._inp_sctim = buf32;
233
234  is.read(buf16, 16);
235  data._asc_des = buf16;
236
237  is.read(buf16, 16);
238  data._pro_lat = atof(buf16);
239
240  is.read(buf16, 16);
241  data._pro_long = atof(buf16);
242
243  is.read(buf16, 16);
244  data._pro_head = atof(buf16);
245
246  is.read(buf16, 16);
247  data._ellip_des = buf16;
248
249  is.read(buf16, 16);
250  data._ellip_maj = atof(buf16);
251
252  is.read(buf16, 16);
253  data._ellip_min = atof(buf16);
254
255  is.read(buf16, 16);
256  data._earth_mass = atof(buf16);
257
258  is.read(buf16, 16);
259  data._grav_const = atof(buf16);
260
262  data._ellip_j[0] = atof(buf16);
264  data._ellip_j[1] = atof(buf16);
265  is.read(buf16, 16);
266  data._ellip_j[2] = atof(buf16);
267
269
270  is.read(buf16, 16);
271  data._terrain_h = atof(buf16);
272
274  data._sc_lin = atoi(buf8);
275
276  is.read(buf8, 8);
277  data._sc_pix = atoi(buf8);
278
279  is.read(buf16, 16);
280  data._scene_len = atof(buf16);
281
282  is.read(buf16, 16);
283  data._scene_wid = atof(buf16);
284
285  is.read(buf16, 16);
286
287  is.read(buf4, 4);
288  data._nchn = atoi(buf4);
289
290  is.read(buf4, 4);
291
292  is.read(buf16, 16);
293  data._mission_id = buf16;
294
295  is.read(buf32, 32);
296  data._sensor_id = buf32;
297
298  is.read(buf8, 8);
299  data._orbit_num = buf8;
300
301  is.read(buf8, 8);
302  data._plat_lat = atof(buf8);
303
304  is.read(buf8, 8);
305  data._plat_long = atof(buf8);
306
307  is.read(buf8, 8);
308  data._plat_head = atof(buf8);
309
310  is.read(buf8, 8);
311  data._clock_ang = atof(buf8);
312
313  is.read(buf8, 8);
314  data._incident_ang = atof(buf8);
315
316  is.read(buf8, 8);
317
318  is.read(buf16, 16);
319  data._wave_length = atof(buf16);
320
321  is.read(buf8, 2);
322  buf8[2] = '\0';
323  data._motion_comp = buf8;
324
325  is.read(buf16, 16);
326  data._pulse_code = buf16;
327
328  for (int i = 0; i < 5; i++)
329  {
330  is.read(buf16, 16);
331  data._ampl_coef[i] = atof(buf16);
332  }
333
334  for (int i = 0; i < 5; i++)
335  {
336  is.read(buf16, 16);
337  data._phas_coef[i] = atof(buf16);
338  }
339
340  is.read(buf8, 8);
341  data._chirp_ext_ind = atoi(buf8);
342
343  is.read(buf8, 8);
344
345  is.read(buf16, 16);
346  data._fr = atof(buf16);
347
348  is.read(buf16, 16);
349  data._rng_gate = atof(buf16);
350
351  is.read(buf16, 16);
352  data._rng_length = atof(buf16);
353
354  is.read(buf8, 4);
355  buf8[4] = '\0';
356  data._baseband_f = buf8;
357
358  is.read(buf8, 4);
359  buf8[4] = '\0';
360  data._rngcmp_f = buf8;
361
362  is.read(buf16, 16);
363  data._gn_polar = atof(buf16);
364
365  is.read(buf16, 16);
366  data._gn_cross = atof(buf16);
367
368  is.read(buf8, 8);
369  data._chn_bits = atoi(buf8);
370
371  is.read(buf16, 12);
372  buf16[12] = '\0';
373  data._quant_desc = buf16;
374
375  is.read(buf16, 16);
376  data._i_bias = atof(buf16);
377
378  is.read(buf16, 16);
379  data._q_bias = atof(buf16);
380
381  is.read(buf16, 16);
382  data._iq_ratio = atof(buf16);
383
384  is.read(buf32, 32);
385
387
388  is.read(buf16, 16);
389  data._mech_sight = atof(buf16);
390
391  is.read(buf4, 4);
392
393  is.read(buf16, 16);
394  data._fa = atof(buf16);
395
397
399
400  is.read(buf16, 16);
401  data._sat_bintim = buf16;
402
403  is.read(buf32, 32);
404  data._sat_clktim = buf32;
405
406  is.read(buf8, 8);
407  data._sat_clkinc = buf8;
408
409  is.read(buf8, 8);
410
411  is.read(buf16, 16);
412  data._fac_id = buf16;
413
414  is.read(buf8, 8);
415  data._sys_id = buf8;
416
417  is.read(buf8, 8);
418  data._ver_id = buf8;
419
421
422  is.read(buf32, 32);
423  data._prod_type = buf32;
424
425  is.read(buf32, 32);
426  data._algor_id = buf32;
427
428  is.read(buf16, 16);
429  data._n_azilok = atof(buf16);
430
431  is.read(buf16, 16);
432  data._n_rnglok = atof(buf16);
433
434  is.read(buf16, 16);
435  data._bnd_azilok = atof(buf16);
436
437  is.read(buf16, 16);
438  data._bnd_rnglok = atof(buf16);
439
440  is.read(buf16, 16);
441  data._bnd_azi = atof(buf16);
442
443  is.read(buf16, 16);
444  data._bnd_rng = atof(buf16);
445
446  is.read(buf32, 32);
447  data._azi_weight = buf32;
448
449  is.read(buf32, 32);
450  data._rng_weight = buf32;
451
452  is.read(buf16, 16);
453  data._data_inpsrc = buf16;
454
455  is.read(buf16, 16);
456  data._rng_res = atof(buf16);
457
458  is.read(buf16, 16);
459  data._azi_res = atof(buf16);
460
461  is.read(buf32, 32);
462
464  data._alt_dopcen[0] = atof(buf16);
466  data._alt_dopcen[1] = atof(buf16);
467  is.read(buf16, 16);
468  data._alt_dopcen[2] = atof(buf16);
469
471
473  data._crt_dopcen[0] = atof(buf16);
475  data._crt_dopcen[1] = atof(buf16);
476  is.read(buf16, 16);
477  data._crt_dopcen[2] = atof(buf16);
478
479  is.read(buf8, 8);
480  data._time_dir_pix = buf8;
481
482  is.read(buf8, 8);
483  data._time_dir_lin = buf8;
484
486  data._alt_rate[0] = atof(buf16);
488  data._alt_rate[1] = atof(buf16);
489  is.read(buf16, 16);
490  data._alt_rate[2] = atof(buf16);
491
493
495  data._crt_rate[0] = atof(buf16);
497  data._crt_rate[1] = atof(buf16);
498  is.read(buf16, 16);
499  data._crt_rate[2] = atof(buf16);
500
501  is.read(buf16, 16);
502
503  is.read(buf8, 8);
504  data._line_cont = buf8;
505
506  is.read(buf4, 4);
507  data._clutter_lock = buf4;
508
509  is.read(buf4, 4);
510  data._auto_focus = buf4;
511
512  is.read(buf16, 16);
513  data._line_spacing = atof(buf16);
514
515  is.read(buf16, 16);
516  data._pix_spacing = atof(buf16);
517
518  is.read(buf16, 16);
519  data._rngcmp_desg = buf16;
520
521  is.read(buf32, 32);
522
523  is.read(buf16, 16);
524  data._zero_dop_range_time_f_pixel = atof(buf16);
525
526  is.read(buf16, 16);
527  data._zero_dop_range_time_c_pixel = atof(buf16);
528
529  is.read(buf16, 16);
530  data._zero_dop_range_time_l_pixel = atof(buf16);
531
532  is.read(buf32, 24);
533  buf32[24] = '\0';
534  data._zero_dop_az_time_f_pixel = buf32;
535
536  is.read(buf32, 24);
537  buf32[24] = '\0';
538  data._zero_dop_az_time_c_pixel = buf32;
539
540  is.read(buf32, 24);
541  buf32[24] = '\0';
542  data._zero_dop_az_time_l_pixel = buf32;
543
544  return is;
545 }
◆ operator>>() [58/62]
DataSetSummary data
Definition at line 210 of file DataSetSummary.cpp.
References ossimplugins::DataSetSummary::_algor_id, ossimplugins::DataSetSummary::_alt_dopcen, ossimplugins::DataSetSummary::_alt_rate, ossimplugins::DataSetSummary::_ampl_coef, ossimplugins::DataSetSummary::_asc_des, ossimplugins::DataSetSummary::_auto_focus, ossimplugins::DataSetSummary::_azi_res, ossimplugins::DataSetSummary::_azi_weight, ossimplugins::DataSetSummary::_azim_beam, ossimplugins::DataSetSummary::_baseband_f, ossimplugins::DataSetSummary::_bnd_azi, ossimplugins::DataSetSummary::_bnd_azilok, ossimplugins::DataSetSummary::_bnd_rng, ossimplugins::DataSetSummary::_bnd_rnglok, ossimplugins::DataSetSummary::_chirp_ext_ind, ossimplugins::DataSetSummary::_chn_bits, ossimplugins::DataSetSummary::_clock_ang, ossimplugins::DataSetSummary::_clutter_lock, ossimplugins::DataSetSummary::_crt_dopcen, ossimplugins::DataSetSummary::_crt_rate, ossimplugins::DataSetSummary::_data_inpsrc, ossimplugins::DataSetSummary::_earth_mass, ossimplugins::DataSetSummary::_echo_track, ossimplugins::DataSetSummary::_ele_sight, ossimplugins::DataSetSummary::_elev_beam, ossimplugins::DataSetSummary::_ellip_des, ossimplugins::DataSetSummary::_ellip_j, ossimplugins::DataSetSummary::_ellip_maj, ossimplugins::DataSetSummary::_ellip_min, ossimplugins::DataSetSummary::_fa, ossimplugins::DataSetSummary::_fac_code, ossimplugins::DataSetSummary::_fac_id, ossimplugins::DataSetSummary::_fr, ossimplugins::DataSetSummary::_gn_cross, ossimplugins::DataSetSummary::_gn_polar, ossimplugins::DataSetSummary::_grav_const, ossimplugins::DataSetSummary::_i_bias, ossimplugins::DataSetSummary::_incident_ang, ossimplugins::DataSetSummary::_inp_sctim, ossimplugins::DataSetSummary::_iq_ratio, ossimplugins::DataSetSummary::_lev_code, ossimplugins::DataSetSummary::_line_cont, ossimplugins::DataSetSummary::_line_spacing, ossimplugins::DataSetSummary::_mech_sight, ossimplugins::DataSetSummary::_mission_id, ossimplugins::DataSetSummary::_motion_comp, ossimplugins::DataSetSummary::_n_azilok, ossimplugins::DataSetSummary::_n_rnglok, ossimplugins::DataSetSummary::_nchn, ossimplugins::DataSetSummary::_orbit_num, ossimplugins::DataSetSummary::_phas_coef, ossimplugins::DataSetSummary::_pix_spacing, ossimplugins::DataSetSummary::_plat_head, ossimplugins::DataSetSummary::_plat_lat, ossimplugins::DataSetSummary::_plat_long, ossimplugins::DataSetSummary::_pro_head, ossimplugins::DataSetSummary::_pro_lat, ossimplugins::DataSetSummary::_pro_long, ossimplugins::DataSetSummary::_prod_type, ossimplugins::DataSetSummary::_pulse_code, ossimplugins::DataSetSummary::_q_bias, ossimplugins::DataSetSummary::_quant_desc, ossimplugins::DataSetSummary::_radi_stretch, ossimplugins::DataSetSummary::_rng_gate, ossimplugins::DataSetSummary::_rng_length, ossimplugins::DataSetSummary::_rng_res, ossimplugins::DataSetSummary::_rng_weight, ossimplugins::DataSetSummary::_rngcmp_desg, ossimplugins::DataSetSummary::_rngcmp_f, ossimplugins::DataSetSummary::_sar_chn, ossimplugins::DataSetSummary::_sat_bintim, ossimplugins::DataSetSummary::_sat_clkinc, ossimplugins::DataSetSummary::_sat_clktim, ossimplugins::DataSetSummary::_sc_lin, ossimplugins::DataSetSummary::_sc_pix, ossimplugins::DataSetSummary::_scene_des, ossimplugins::DataSetSummary::_scene_id, ossimplugins::DataSetSummary::_scene_len, ossimplugins::DataSetSummary::_scene_wid, ossimplugins::DataSetSummary::_sensor_id, ossimplugins::DataSetSummary::_seq_num, ossimplugins::DataSetSummary::_sys_id, ossimplugins::DataSetSummary::_terrain_h, ossimplugins::DataSetSummary::_time_dir_lin, ossimplugins::DataSetSummary::_time_dir_pix, ossimplugins::DataSetSummary::_ver_id, and ossimplugins::DataSetSummary::_wave_length.
211 {
212  char buf16[17];
213  buf16[16]='\0';
214  char buf32[33];
215  buf32[32] = '\0';
216  char buf8[9];
217  buf8[8] = '\0';
218  char buf4[5];
219  buf4[4] = '\0';
220
221  is.read(buf4,4);
222  data._seq_num = atoi(buf4);
223
224  is.read(buf4,4);
225  data._sar_chn = atoi(buf4);
226
227  is.read(buf16,16);
228  data._scene_id = buf16;
229
230  is.read(buf32,32);
231  data._scene_des = buf32;
232
233  is.read(buf32,32);
234  data._inp_sctim = buf32;
235
236  is.read(buf16,16);
237  data._asc_des = buf16;
238
239  is.read(buf16,16);
240  data._pro_lat = atof(buf16);
241
242  is.read(buf16,16);
243  data._pro_long = atof(buf16);
244
245  is.read(buf16,16);
246  data._pro_head = atof(buf16);
247
248  is.read(buf16,16);
249  data._ellip_des = buf16;
250
251  is.read(buf16,16);
252  data._ellip_maj = atof(buf16);
253
254  is.read(buf16,16);
255  data._ellip_min = atof(buf16);
256
257  is.read(buf16,16);
258  data._earth_mass = atof(buf16);
259
261  data._grav_const = atof(buf16);
262
263  is.read(buf16,16);
264  data._ellip_j[0] = atof(buf16);
265  is.read(buf16,16);
266  data._ellip_j[1] = atof(buf16);
267  is.read(buf16,16);
268  data._ellip_j[2] = atof(buf16);
269
270  is.read(buf16,16);
271
272  is.read(buf16,16);
273  data._terrain_h = atof(buf16);
274
275  is.read(buf8,8);
276  data._sc_lin = atoi(buf8);
277
278  is.read(buf8,8);
279  data._sc_pix = atoi(buf8);
280
281  is.read(buf16,16);
282  data._scene_len = atof(buf16);
283
284  is.read(buf16,16);
285  data._scene_wid = atof(buf16);
286
287  is.read(buf16,16);
288
289  is.read(buf4,4);
290  data._nchn = atoi(buf4);
291
292  is.read(buf4,4);
293
294  is.read(buf16,16);
295  data._mission_id = buf16;
296
297  is.read(buf32,32);
298  data._sensor_id = buf32;
299
300  is.read(buf8,8);
301  data._orbit_num = buf8;
302
303  is.read(buf8,8);
304  data._plat_lat = atof(buf8);
305
306  is.read(buf8,8);
307  data._plat_long = atof(buf8);
308
309  is.read(buf8,8);
310  data._plat_head = atof(buf8);
311
312  is.read(buf8,8);
313  data._clock_ang = atof(buf8);
314
315  is.read(buf8,8);
316  data._incident_ang = atof(buf8);
317
318  is.read(buf8,8);
319
320  is.read(buf16,16);
321  data._wave_length = atof(buf16);
322
323  is.read(buf8,2);
324  buf8[2] = '\0';
325  data._motion_comp = buf8;
326
327  is.read(buf16,16);
328  data._pulse_code = buf16;
329
330  for (int i=0;i<5;i++)
331  {
332  is.read(buf16,16);
333  data._ampl_coef[i] = atof(buf16);
334  }
335
336  for (int i=0;i<5;i++)
337  {
338  is.read(buf16,16);
339  data._phas_coef[i] = atof(buf16);
340  }
341
342  is.read(buf8,8);
343  data._chirp_ext_ind = atoi(buf8);
344
345  is.read(buf8,8);
346
347  is.read(buf16,16);
348  data._fr = atof(buf16);
349
350  is.read(buf16,16);
351  data._rng_gate = atof(buf16);
352
353  is.read(buf16,16);
354  data._rng_length = atof(buf16);
355
356  is.read(buf8,4);
357  buf8[4] = '\0';
358  data._baseband_f = buf8;
359
360  is.read(buf8,4);
361  buf8[4] = '\0';
362  data._rngcmp_f = buf8;
363
364  is.read(buf16,16);
365  data._gn_polar = atof(buf16);
366
367  is.read(buf16,16);
368  data._gn_cross = atof(buf16);
369
370  is.read(buf8,8);
371  data._chn_bits = atoi(buf8);
372
373  is.read(buf16,12);
374  buf16[12] = '\0';
375  data._quant_desc = buf16;
376
377  is.read(buf16,16);
378  data._i_bias = atof(buf16);
379
380  is.read(buf16,16);
381  data._q_bias = atof(buf16);
382
383  is.read(buf16,16);
384  data._iq_ratio = atof(buf16);
385
386  is.read(buf16,16);
387
388  is.read(buf16,16);
389
390  is.read(buf16,16);
391  data._ele_sight = atof(buf16);
392
393  is.read(buf16,16);
394  data._mech_sight = atof(buf16);
395
396  is.read(buf4,4);
397  data._echo_track = buf4;
398
399  is.read(buf16,16);
400  data._fa = atof(buf16);
401
402  is.read(buf16,16);
403  data._elev_beam = atof(buf16);
404
405  is.read(buf16,16);
406  data._azim_beam = atof(buf16);
407
408  is.read(buf16,16);
409  data._sat_bintim = atoi(buf16);
410
411  is.read(buf32,32);
412  data._sat_clktim = atoi(buf32);
413
414  is.read(buf8,8);
415  data._sat_clkinc = atoi(buf8);
416
417  is.read(buf8,8);
418
419  is.read(buf16,16);
420  data._fac_id = buf16;
421
422  is.read(buf8,8);
423  data._sys_id = buf8;
424
425  is.read(buf8,8);
426  data._ver_id = buf8;
427
428  is.read(buf16,16);
429  data._fac_code = buf16;
430
431  is.read(buf16,16);
432  data._lev_code = buf16;
433
434  is.read(buf32,32);
435  data._prod_type = buf32;
436
437  is.read(buf32,32);
438  data._algor_id = buf32;
439
440  is.read(buf16,16);
441  data._n_azilok = atof(buf16);
442
443  is.read(buf16,16);
444  data._n_rnglok = atof(buf16);
445
446  is.read(buf16,16);
447  data._bnd_azilok = atof(buf16);
448
449  is.read(buf16,16);
450  data._bnd_rnglok = atof(buf16);
451
452  is.read(buf16,16);
453  data._bnd_azi = atof(buf16);
454
455  is.read(buf16,16);
456  data._bnd_rng = atof(buf16);
457
458  is.read(buf32,32);
459  data._azi_weight = buf32;
460
461  is.read(buf32,32);
462  data._rng_weight = buf32;
463
464  is.read(buf16,16);
465  data._data_inpsrc = buf16;
466
467  is.read(buf16,16);
468  data._rng_res = atof(buf16);
469
470  is.read(buf16,16);
471  data._azi_res = atof(buf16);
472
473  is.read(buf16,16);
474  data._radi_stretch[0] = atof(buf16);
475  is.read(buf16,16);
476  data._radi_stretch[1] = atof(buf16);
477
478  is.read(buf16,16);
479  data._alt_dopcen[0] = atof(buf16);
480  is.read(buf16,16);
481  data._alt_dopcen[1] = atof(buf16);
482  is.read(buf16,16);
483  data._alt_dopcen[2] = atof(buf16);
484
485  is.read(buf16,16);
486
487  is.read(buf16,16);
488  data._crt_dopcen[0] = atof(buf16);
489  is.read(buf16,16);
490  data._crt_dopcen[1] = atof(buf16);
491  is.read(buf16,16);
492  data._crt_dopcen[2] = atof(buf16);
493
494  is.read(buf8,8);
495  data._time_dir_pix = buf8;
496
497  is.read(buf8,8);
498  data._time_dir_lin = buf8;
499
500  is.read(buf16,16);
501  data._alt_rate[0] = atof(buf16);
502  is.read(buf16,16);
503  data._alt_rate[1] = atof(buf16);
504  is.read(buf16,16);
505  data._alt_rate[2] = atof(buf16);
506
507  is.read(buf16,16);
508
509  is.read(buf16,16);
510  data._crt_rate[0] = atof(buf16);
511  is.read(buf16,16);
512  data._crt_rate[1] = atof(buf16);
513  is.read(buf16,16);
514  data._crt_rate[2] = atof(buf16);
515
516  is.read(buf16,16);
517
518  is.read(buf8,8);
519  data._line_cont = buf8;
520
521  is.read(buf4,4);
522  data._clutter_lock = buf4;
523
524  is.read(buf4,4);
525  data._auto_focus = buf4;
526
527  is.read(buf16,16);
528  data._line_spacing = atof(buf16);
529
530  is.read(buf16,16);
531  data._pix_spacing = atof(buf16);
532
533  is.read(buf16,16);
534  data._rngcmp_desg = buf16;
535
536  char buf[2363];
537  buf[2362] = '\0';
538
539  is.read(buf,2362);
540
541  return is;
542 }
◆ operator>>() [59/62]
ProcessingParameters data
Definition at line 264 of file ProcessingParameters.cpp.
References ossimplugins::ProcessingParameters::_act_ing_start, ossimplugins::ProcessingParameters::_act_ing_stop, ossimplugins::ProcessingParameters::_adc_samp_rate, ossimplugins::ProcessingParameters::_angle_first, ossimplugins::ProcessingParameters::_angle_last, ossimplugins::ProcessingParameters::_appl_type, ossimplugins::ProcessingParameters::_apply_dtm, ossimplugins::ProcessingParameters::_beam_edge_conf, ossimplugins::ProcessingParameters::_beam_edge_rqd, ossimplugins::ProcessingParameters::_beam_info, ossimplugins::ProcessingParameters::_bit_err_rate, ossimplugins::ProcessingParameters::_centre_lat, ossimplugins::ProcessingParameters::_centre_long, ossimplugins::ProcessingParameters::_complete_msg, ossimplugins::ProcessingParameters::_date_incons, ossimplugins::ProcessingParameters::_delay_changes, ossimplugins::ProcessingParameters::_density_in, ossimplugins::ProcessingParameters::_density_out, ossimplugins::ProcessingParameters::_dop_amb_err, ossimplugins::ProcessingParameters::_dopamb_conf, ossimplugins::ProcessingParameters::_dopcen_est, ossimplugins::ProcessingParameters::_dopcen_inc, ossimplugins::ProcessingParameters::_eph_orb_data, ossimplugins::ProcessingParameters::_err_amp_coef, ossimplugins::ProcessingParameters::_err_phas_coef, ossimplugins::ProcessingParameters::_exp_ing_start, ossimplugins::ProcessingParameters::_exp_ing_stop, ossimplugins::ProcessingParameters::_fm_crc_err, ossimplugins::ProcessingParameters::_gics_reqd, ossimplugins::ProcessingParameters::_gn_corctn_fctr, ossimplugins::ProcessingParameters::_img_cumu_dist, ossimplugins::ProcessingParameters::_img_hist_mean, ossimplugins::ProcessingParameters::_inp_media, ossimplugins::ProcessingParameters::_large_gap, ossimplugins::ProcessingParameters::_map_system, ossimplugins::ProcessingParameters::_media_id, ossimplugins::ProcessingParameters::_miss_ln, ossimplugins::ProcessingParameters::_mn_sig_lev, ossimplugins::ProcessingParameters::_n_beams, ossimplugins::ProcessingParameters::_n_dopcen, ossimplugins::ProcessingParameters::_n_image_pix, ossimplugins::ProcessingParameters::_n_pix_updates, ossimplugins::ProcessingParameters::_n_srgr, ossimplugins::ProcessingParameters::_n_tape_id, ossimplugins::ProcessingParameters::_n_temp_set, ossimplugins::ProcessingParameters::_num_state_vectors, ossimplugins::ProcessingParameters::_orb_data_src, ossimplugins::ProcessingParameters::_pix_count, ossimplugins::ProcessingParameters::_pix_overlap, ossimplugins::ProcessingParameters::_pixel_spacing, ossimplugins::ProcessingParameters::_post_img_gn, ossimplugins::ProcessingParameters::_prc_satur_pix, ossimplugins::ProcessingParameters::_prc_zero_pix, ossimplugins::ProcessingParameters::_pre_img_gn, ossimplugins::ProcessingParameters::_prf_changes, ossimplugins::ProcessingParameters::_proc_start, ossimplugins::ProcessingParameters::_proc_stop, ossimplugins::ProcessingParameters::_prod_type, ossimplugins::ProcessingParameters::_pulse_bandw, ossimplugins::ProcessingParameters::_pulse_cnt_1, ossimplugins::ProcessingParameters::_pulse_cnt_2, ossimplugins::ProcessingParameters::_pwin_end, ossimplugins::ProcessingParameters::_pwin_start, ossimplugins::ProcessingParameters::_rec_seq, ossimplugins::ProcessingParameters::_recd_type, ossimplugins::ProcessingParameters::_rej_bf_start, ossimplugins::ProcessingParameters::_rej_few_fram, ossimplugins::ProcessingParameters::_rej_ln, ossimplugins::ProcessingParameters::_rej_many_fram, ossimplugins::ProcessingParameters::_rej_mchn_err, ossimplugins::ProcessingParameters::_rej_rec_type, ossimplugins::ProcessingParameters::_rej_vchn_err, ossimplugins::ProcessingParameters::_rep_agc_attn, ossimplugins::ProcessingParameters::_rep_energy_gn, ossimplugins::ProcessingParameters::_rng_amp_coef, ossimplugins::ProcessingParameters::_rng_phas_coef, ossimplugins::ProcessingParameters::_rng_ref_src, ossimplugins::ProcessingParameters::_satellite_id, ossimplugins::ProcessingParameters::_scene_id, ossimplugins::ProcessingParameters::_scr_data_ind, ossimplugins::ProcessingParameters::_sens_config, ossimplugins::ProcessingParameters::_sens_orient, ossimplugins::ProcessingParameters::_skipd_frams, ossimplugins::ProcessingParameters::_slow_time_coef, ossimplugins::ProcessingParameters::_span_x, ossimplugins::ProcessingParameters::_span_y, ossimplugins::ProcessingParameters::_srgr_coefset, ossimplugins::ProcessingParameters::_state_time, ossimplugins::ProcessingParameters::_state_time_inc, ossimplugins::ProcessingParameters::_sych_marker, ossimplugins::ProcessingParameters::_tape_id, ossimplugins::ProcessingParameters::_temp, ossimplugins::ProcessingParameters::_temp_set_inc, ossimplugins::ProcessingParameters::_user_id, ossimplugins::ProcessingParameters::_wo_date, and ossimplugins::ProcessingParameters::_wo_number.
265  {
266  char buf[2407];
267  buf[2406] = '\0';
268
269  is.read(buf,4);
270  buf[4] = '\0';
271  data._rec_seq = atoi(buf);
272
273  is.read(buf,4);
274  buf[4] = '\0';
275
276  is.read(buf,3);
277  buf[3] = '\0';
278  data._inp_media = buf;
279
280  is.read(buf,4);
281  buf[4] = '\0';
282  data._n_tape_id = atoi(buf);
283
284  for (int i=0;i<10;i++)
285  {
286  is.read(buf,8);
287  buf[8] = '\0';
288  data._tape_id[i] = buf;
289  }
290
291  is.read(buf,21);
292  buf[21] = '\0';
293  data._exp_ing_start = buf;
294
295  is.read(buf,21);
296  buf[21] = '\0';
297  data._exp_ing_stop = buf;
298
299  is.read(buf,21);
300  buf[21] = '\0';
301  data._act_ing_start = buf;
302
303  is.read(buf,21);
304  buf[21] = '\0';
305  data._act_ing_stop = buf;
306
307  is.read(buf,21);
308  buf[21] = '\0';
309  data._proc_start = buf;
310
311  is.read(buf,21);
312  buf[21] = '\0';
313  data._proc_stop = buf;
314
315  for (int i=0;i<10;i++)
316  {
317  is.read(buf,16);
318  buf[16] = '\0';
319  data._mn_sig_lev[i] = atof(buf);
320  }
321
322  is.read(buf,4);
323  buf[4] = '\0';
324  data._scr_data_ind = atoi(buf);
325
326  is.read(buf,8);
327  buf[8] = '\0';
328  data._miss_ln = atoi(buf);
329
330  is.read(buf,8);
331  buf[8] = '\0';
332  data._rej_ln = atoi(buf);
333
334  is.read(buf,8);
335  buf[8] = '\0';
336  data._large_gap = atoi(buf);
337
338  is.read(buf,16);
339  buf[16] = '\0';
340  data._bit_err_rate = atof(buf);
341
342  is.read(buf,16);
343  buf[16] = '\0';
344  data._fm_crc_err = atof(buf);
345
346  is.read(buf,8);
347  buf[8] = '\0';
348  data._date_incons = atoi(buf);
349
350  is.read(buf,8);
351  buf[8] = '\0';
352  data._prf_changes = atoi(buf);
353
354  is.read(buf,8);
355  buf[8] = '\0';
356  data._delay_changes = atoi(buf);
357
358  is.read(buf,8);
359  buf[8] = '\0';
360  data._skipd_frams = atoi(buf);
361
362  is.read(buf,8);
363  buf[8] = '\0';
364  data._rej_bf_start = atoi(buf);
365
366  is.read(buf,8);
367  buf[8] = '\0';
368  data._rej_few_fram = atoi(buf);
369
370  is.read(buf,8);
371  buf[8] = '\0';
372  data._rej_many_fram = atoi(buf);
373
374  is.read(buf,8);
375  buf[8] = '\0';
376  data._rej_mchn_err = atoi(buf);
377
378  is.read(buf,8);
379  buf[8] = '\0';
380  data._rej_vchn_err = atoi(buf);
381
382  is.read(buf,8);
383  buf[8] = '\0';
384  data._rej_rec_type = atoi(buf);
385
386  is.read(buf,10);
387  buf[10] = '\0';
388  data._sens_config = buf;
389
390  is.read(buf,9);
391  buf[9] = '\0';
392  data._sens_orient = buf;
393
394  is.read(buf,8);
395  buf[8] = '\0';
396  data._sych_marker = buf;
397
398  is.read(buf,12);
399  buf[12] = '\0';
400  data._rng_ref_src = buf;
401
402  for (int i=0;i<4;i++)
403  {
404  is.read(buf,16);
405  buf[16] = '\0';
406  data._rng_amp_coef[i] = atof(buf);
407  }
408
409  for (int i=0;i<4;i++)
410  {
411  is.read(buf,16);
412  buf[16] = '\0';
413  data._rng_phas_coef[i] = atof(buf);
414  }
415
416  for (int i=0;i<4;i++)
417  {
418  is.read(buf,16);
419  buf[16] = '\0';
420  data._err_amp_coef[i] = atof(buf);
421  }
422
423  for (int i=0;i<4;i++)
424  {
425  is.read(buf,16);
426  buf[16] = '\0';
427  data._err_phas_coef[i] = atof(buf);
428  }
429
430  is.read(buf,4);
431  buf[4] = '\0';
432  data._pulse_bandw = atoi(buf);
433
434
435  is.read(buf,5);
436  buf[5] = '\0';
437  data._adc_samp_rate = buf;
438
439  is.read(buf,16);
440  buf[16] = '\0';
441  data._rep_agc_attn = atof(buf);
442
443  is.read(buf,16);
444  buf[16] = '\0';
445  data._gn_corctn_fctr = atof(buf);
446
447  is.read(buf,16);
448  buf[16] = '\0';
449  data._rep_energy_gn = atof(buf);
450
451  is.read(buf,11);
452  buf[11] = '\0';
453  data._orb_data_src = buf;
454
455  is.read(buf,4);
456  buf[4] = '\0';
457  data._pulse_cnt_1 = atoi(buf);
458
459  is.read(buf,4);
460  buf[4] = '\0';
461  data._pulse_cnt_2 = atoi(buf);
462
463  is.read(buf,3);
464  buf[3] = '\0';
465  data._beam_edge_rqd = buf;
466
467  is.read(buf,16);
468  buf[16] = '\0';
469  data._beam_edge_conf = atof(buf);
470
471  is.read(buf,4);
472  buf[4] = '\0';
473  data._pix_overlap = atoi(buf);
474
475  is.read(buf,4);
476  buf[4] = '\0';
477  data._n_beams = atoi(buf);
478
479  for (int i=0;i<4;i++)
480  {
481  is>>data._beam_info[i];
482  }
483
484  is.read(buf,4);
485  buf[4] = '\0';
486  data._n_pix_updates = atoi(buf);
487
488  for (int i=0;i<20;i++)
489  {
490  is>>data._pix_count[i];
491  }
492
493  is.read(buf,16);
494  buf[16] = '\0';
495  data._pwin_start = atof(buf);
496
497  is.read(buf,16);
498  buf[16] = '\0';
499  data._pwin_end = atof(buf);
500
501  is.read(buf,9);
502  buf[9] = '\0';
503  data._recd_type = buf;
504
505  is.read(buf,16);
506  buf[16] = '\0';
507  data._temp_set_inc = atof(buf);
508
509  is.read(buf,4);
510  buf[4] = '\0';
511  data._n_temp_set = atoi(buf);
512
513  for (int i=0;i<20;i++)
514  {
515  is>>data._temp[i];
516  }
517
518  is.read(buf,8);
519  buf[8] = '\0';
520  data._n_image_pix = atoi(buf);
521
522  is.read(buf,16);
523  buf[16] = '\0';
524  data._prc_zero_pix = atof(buf);
525
526  is.read(buf,16);
527  buf[16] = '\0';
528  data._prc_satur_pix = atof(buf);
529
530  is.read(buf,16);
531  buf[16] = '\0';
532  data._img_hist_mean = atof(buf);
533
534  for (int i=0;i<3;i++)
535  {
536  is.read(buf,16);
537  buf[16] = '\0';
538  data._img_cumu_dist[i] = atof(buf);
539  }
540
541  is.read(buf,16);
542  buf[16] = '\0';
543  data._pre_img_gn = atof(buf);
544
545  is.read(buf,16);
546  buf[16] = '\0';
547  data._post_img_gn = atof(buf);
548
549  is.read(buf,16);
550  buf[16] = '\0';
551  data._dopcen_inc = atof(buf);
552
553  is.read(buf,4);
554  buf[4] = '\0';
555  data._n_dopcen = atoi(buf);
556
557  for (int i=0;i<20;i++)
558  {
559  is>>data._dopcen_est[i];
560  }
561
562  is.read(buf,4);
563  buf[4] = '\0';
564  data._dop_amb_err = atoi(buf);
565
566  is.read(buf,16);
567  buf[16] = '\0';
568  data._dopamb_conf = atof(buf);
569
570  for (int i=0;i<7;i++)
571  {
572  is.read(buf,16);
573  buf[16] = '\0';
574  data._eph_orb_data[i] = atof(buf);
575  }
576
577  is.read(buf,12);
578  buf[12] = '\0';
579  data._appl_type = buf;
580
581  for (int i=0;i<5;i++)
582  {
583  is.read(buf,22);
584  buf[22] = '\0';
585  data._slow_time_coef[i] = atof(buf);
586  }
587
588  is.read(buf,4);
589  buf[4] = '\0';
590  data._n_srgr = atoi(buf);
591
592  for (int i=0;i<20;i++)
593  {
594  is>>data._srgr_coefset[i];
595  }
596
597  is.read(buf,16);
598  buf[16] = '\0';
599  data._pixel_spacing = atof(buf);
600
601  is.read(buf,3);
602  buf[3] = '\0';
603  data._gics_reqd = buf;
604
605  is.read(buf,8);
606  buf[8] = '\0';
607  data._wo_number = buf;
608
609  is.read(buf,20);
610  buf[20] = '\0';
611  data._wo_date = buf;
612
613  is.read(buf,10);
614  buf[10] = '\0';
615  data._satellite_id = buf;
616
617  is.read(buf,20);
618  buf[20] = '\0';
619  data._user_id = buf;
620
621  is.read(buf,3);
622  buf[3] = '\0';
623  data._complete_msg = buf;
624
625  is.read(buf,15);
626  buf[15] = '\0';
627  data._scene_id = buf;
628
629  is.read(buf,4);
630  buf[4] = '\0';
631  data._density_in = buf;
632
633  is.read(buf,8);
634  buf[8] = '\0';
635  data._media_id = buf;
636
637  is.read(buf,16);
638  buf[16] = '\0';
639  data._angle_first = atof(buf);
640
641  is.read(buf,16);
642  buf[16] = '\0';
643  data._angle_last = atof(buf);
644
645  is.read(buf,3);
646  buf[3] = '\0';
647  data._prod_type = buf;
648
649  is.read(buf,16);
650  buf[16] = '\0';
651  data._map_system = buf;
652
653  is.read(buf,22);
654  buf[22] = '\0';
655  data._centre_lat = atof(buf);
656
657  is.read(buf,22);
658  buf[22] = '\0';
659  data._centre_long = atof(buf);
660
661  is.read(buf,22);
662  buf[22] = '\0';
663  data._span_x = atof(buf);
664
665  is.read(buf,22);
666  buf[22] = '\0';
667  data._span_y = atof(buf);
668
669  is.read(buf,3);
670  buf[3] = '\0';
671  data._apply_dtm = buf;
672
673  is.read(buf,4);
674  buf[4] = '\0';
675  data._density_out = buf;
676
677  is.read(buf,21);
678  buf[21] = '\0';
679  data._state_time = buf;
680
681  is.read(buf,4);
682  buf[4] = '\0';
683  data._num_state_vectors = atoi(buf);
684
685  is.read(buf,16);
686  buf[16] = '\0';
687  data._state_time_inc = atof(buf);
688
689  is.read(buf,206);
690  buf[206] = '\0';
691
692  return is;
693  }
◆ operator>>() [60/62]
MainProcessingParameters data
Definition at line 270 of file MainProcessingParameters.cpp.
References ossimplugins::MainProcessingParameters::_ant_elev_coor_flag, ossimplugins::MainProcessingParameters::_ant_scal_flag, ossimplugins::MainProcessingParameters::_attach_flag, ossimplugins::MainProcessingParameters::_avg_scene_height_ellpsoid, ossimplugins::MainProcessingParameters::_ax_fm_origin, ossimplugins::MainProcessingParameters::_az_fm_rate, ossimplugins::MainProcessingParameters::_azimut_spacing, ossimplugins::MainProcessingParameters::_bandwidth, ossimplugins::MainProcessingParameters::_beam_overlap, ossimplugins::MainProcessingParameters::_beam_param, ossimplugins::MainProcessingParameters::_calibration_factors, ossimplugins::MainProcessingParameters::_chirp_extract_flag, ossimplugins::MainProcessingParameters::_data_analysis_flag, ossimplugins::MainProcessingParameters::_data_type, ossimplugins::MainProcessingParameters::_detected_flag, ossimplugins::MainProcessingParameters::_dop_amb_coef, ossimplugins::MainProcessingParameters::_dop_amb_flag, ossimplugins::MainProcessingParameters::_dop_cen_flag, ossimplugins::MainProcessingParameters::_echo_comp, ossimplugins::MainProcessingParameters::_echo_comp_ratio, ossimplugins::MainProcessingParameters::_errors_counters, ossimplugins::MainProcessingParameters::_filter_az, ossimplugins::MainProcessingParameters::_filter_coef_az, ossimplugins::MainProcessingParameters::_filter_coef_range, ossimplugins::MainProcessingParameters::_filter_range, ossimplugins::MainProcessingParameters::_first_proc_range_samp, ossimplugins::MainProcessingParameters::_first_zero_doppler_time, ossimplugins::MainProcessingParameters::_gm_rng_comp_inv_filter_flag, ossimplugins::MainProcessingParameters::_image_parameters1, ossimplugins::MainProcessingParameters::_image_parameters2, ossimplugins::MainProcessingParameters::_init_cal_comp, ossimplugins::MainProcessingParameters::_init_cal_ratio, ossimplugins::MainProcessingParameters::_last_zero_doppler_time, ossimplugins::MainProcessingParameters::_line_time_interval, ossimplugins::MainProcessingParameters::_lines_per_burst, ossimplugins::MainProcessingParameters::_look_bw_az, ossimplugins::MainProcessingParameters::_look_sum_flag, ossimplugins::MainProcessingParameters::_noise_comp, ossimplugins::MainProcessingParameters::_noise_comp_ratio, ossimplugins::MainProcessingParameters::_noise_estimation, ossimplugins::MainProcessingParameters::_nominal_chirp, ossimplugins::MainProcessingParameters::_num_lines_proc, ossimplugins::MainProcessingParameters::_num_look_az, ossimplugins::MainProcessingParameters::_num_looks_range, ossimplugins::MainProcessingParameters::_num_output_lines, ossimplugins::MainProcessingParameters::_num_range_lines_per_burst, ossimplugins::MainProcessingParameters::_num_samples_per_line, ossimplugins::MainProcessingParameters::_output_statistics, ossimplugins::MainProcessingParameters::_parameter_code, ossimplugins::MainProcessingParameters::_per_cal_comp, ossimplugins::MainProcessingParameters::_per_cal_ratio, ossimplugins::MainProcessingParameters::_prf_values, ossimplugins::MainProcessingParameters::_radar_freq, ossimplugins::MainProcessingParameters::_range_ref, ossimplugins::MainProcessingParameters::_range_samp_rate, ossimplugins::MainProcessingParameters::_range_spacing, ossimplugins::MainProcessingParameters::_range_spread_comp_flag, ossimplugins::MainProcessingParameters::_raw_data_analysis, ossimplugins::MainProcessingParameters::_rms_equal_flag, ossimplugins::MainProcessingParameters::_srgr_flag, ossimplugins::MainProcessingParameters::_start_time_mds1, ossimplugins::MainProcessingParameters::_start_time_mds2, ossimplugins::MainProcessingParameters::_state_vector_time_1_day, ossimplugins::MainProcessingParameters::_state_vector_time_1_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_1_sec, ossimplugins::MainProcessingParameters::_state_vector_time_2_day, ossimplugins::MainProcessingParameters::_state_vector_time_2_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_2_sec, ossimplugins::MainProcessingParameters::_state_vector_time_3_day, ossimplugins::MainProcessingParameters::_state_vector_time_3_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_3_sec, ossimplugins::MainProcessingParameters::_state_vector_time_4_day, ossimplugins::MainProcessingParameters::_state_vector_time_4_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_4_sec, ossimplugins::MainProcessingParameters::_state_vector_time_5_day, ossimplugins::MainProcessingParameters::_state_vector_time_5_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_5_sec, ossimplugins::MainProcessingParameters::_swath_num, ossimplugins::MainProcessingParameters::_time_diff, ossimplugins::MainProcessingParameters::_time_diff_zero_doppler, ossimplugins::MainProcessingParameters::_time_first_SS1_echo, ossimplugins::MainProcessingParameters::_to_bw_az, ossimplugins::MainProcessingParameters::_vga_com_cal_flag, ossimplugins::MainProcessingParameters::_vga_com_echo_flag, ossimplugins::MainProcessingParameters::_vga_com_nom_time_flag, ossimplugins::MainProcessingParameters::_work_order_id, ossimplugins::MainProcessingParameters::_x_pos_1, ossimplugins::MainProcessingParameters::_x_pos_2, ossimplugins::MainProcessingParameters::_x_pos_3, ossimplugins::MainProcessingParameters::_x_pos_4, ossimplugins::MainProcessingParameters::_x_pos_5, ossimplugins::MainProcessingParameters::_x_vel_1, ossimplugins::MainProcessingParameters::_x_vel_2, ossimplugins::MainProcessingParameters::_x_vel_3, ossimplugins::MainProcessingParameters::_x_vel_4, ossimplugins::MainProcessingParameters::_x_vel_5, ossimplugins::MainProcessingParameters::_y_pos_1, ossimplugins::MainProcessingParameters::_y_pos_2, ossimplugins::MainProcessingParameters::_y_pos_3, ossimplugins::MainProcessingParameters::_y_pos_4, ossimplugins::MainProcessingParameters::_y_pos_5, ossimplugins::MainProcessingParameters::_y_vel_1, ossimplugins::MainProcessingParameters::_y_vel_2, ossimplugins::MainProcessingParameters::_y_vel_3, ossimplugins::MainProcessingParameters::_y_vel_4, ossimplugins::MainProcessingParameters::_y_vel_5, ossimplugins::MainProcessingParameters::_z_pos_1, ossimplugins::MainProcessingParameters::_z_pos_2, ossimplugins::MainProcessingParameters::_z_pos_3, ossimplugins::MainProcessingParameters::_z_pos_4, ossimplugins::MainProcessingParameters::_z_pos_5, ossimplugins::MainProcessingParameters::_z_vel_1, ossimplugins::MainProcessingParameters::_z_vel_2, ossimplugins::MainProcessingParameters::_z_vel_3, ossimplugins::MainProcessingParameters::_z_vel_4, ossimplugins::MainProcessingParameters::_z_vel_5, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
271  {
272  char buf64[65];
273  buf64[64] = '\0';
274  char buf32[33];
275  buf32[32] = '\0';
276  // char buf27[28];
277  // buf27[27] = '\0';
278  char buf20[21];
279  buf20[20] = '\0';
280  char buf16[17];
281  buf16[16]='\0';
282  // char buf15[16];
283  // buf15[15] = '\0';
284  // char buf14[15];
285  // buf14[14] = '\0';
286  // char buf13[14];
287  // buf13[13] = '\0';
288  char buf12[13];
289  buf12[12] = '\0';
290  // char buf11[12];
291  // buf11[11] = '\0';
292  // char buf10[11];
293  // buf10[10] = '\0';
294  // char buf9[10];
295  // buf9[9] = '\0';
296  // char buf8[9];
297  // buf8[8] = '\0';
298  char buf7[8];
299  buf7[7] = '\0';
300  char buf6[7];
301  buf6[6] = '\0';
302  char buf5[6];
303  buf5[5] = '\0';
304  char buf4[5];
305  buf4[4] = '\0';
306  char buf3[4];
307  buf3[3] = '\0';
308  // char buf2[3];
309  // buf2[2] = '\0';
310 // char buf1[1]; // not used avoid warning
311
312 // int * var_long; // not used avoid warning
313
314  is.read(buf12,12);
315  data._first_zero_doppler_time = buf12;
316
317  is.read((char*)&(data._attach_flag),1);
318
319  is.read(buf12,12);
320  data._last_zero_doppler_time = buf12;
321
322  is.read(buf12,12);
323  data._work_order_id = buf12;
324
325  is.read((char*)&(data._time_diff),4);
326  data.SwitchEndian(data._time_diff);
327
328  is.read(buf3,3);
329  data._swath_num = buf3;
330
331  is.read((char*)&(data._range_spacing),4);
332  data.SwitchEndian(data._range_spacing);
333
334  is.read((char*)&(data._azimut_spacing),4);
335  data.SwitchEndian(data._azimut_spacing);
336
337  is.read((char*)&(data._line_time_interval),4);
338  data.SwitchEndian(data._line_time_interval);
339
340  is.read((char*)&(data._num_output_lines),4);
341  data.SwitchEndian(data._num_output_lines);
342
343  is.read((char*)&(data._num_samples_per_line),4);
344  data.SwitchEndian(data._num_samples_per_line);
345
346  is.read(buf5,5);
347  data._data_type = buf5;
348
349  is.read((char*)&(data._num_range_lines_per_burst),4);
350  data.SwitchEndian(data._num_range_lines_per_burst);
351
352  is.read((char*)&(data._time_diff_zero_doppler),4);
353  data.SwitchEndian(data._time_diff_zero_doppler);
354
355  is.read(buf64,43);
356
357  is.read((char*)&(data._data_analysis_flag),1);
358
359  is.read((char*)&(data._ant_elev_coor_flag),1);
360
361  is.read((char*)&(data._chirp_extract_flag),1);
362
363  is.read((char*)&(data._srgr_flag),1);
364
365  is.read((char*)&(data._dop_cen_flag),1);
366
367  is.read((char*)&(data._dop_amb_flag),1);
368
369  is.read((char*)&(data._range_spread_comp_flag),1);
370
371  is.read((char*)&(data._detected_flag),1);
372
373  is.read((char*)&(data._look_sum_flag),1);
374
375  is.read((char*)&(data._rms_equal_flag),1);
376
377  is.read((char*)&(data._ant_scal_flag),1);
378
379  is.read((char*)&(data._vga_com_echo_flag),1);
380
381  is.read((char*)&(data._vga_com_cal_flag),1);
382
383  is.read((char*)&(data._vga_com_nom_time_flag),1);
384
385  is.read((char*)&(data._gm_rng_comp_inv_filter_flag),1);
386
387  is.read(buf6,6);
388
389  char buf184[185];
390  buf184[184] = '\0';
391  is.read(buf184,184);
392  data._raw_data_analysis = buf184;
393
394  is.read(buf32,32);
395
396  is.read(buf20,20);
397  data._start_time_mds1 = buf20;
398
399  is.read(buf20,20);
400  data._start_time_mds2 = buf20;
401
402  char buf120[121];
403  buf120[120] = '\0';
404  is.read(buf120,120);
405  data._parameter_code = buf120;
406
407  is.read(buf64,60);
408
409  is.read(buf64,40);
410  buf64[40] = '\0';
411  data._errors_counters = buf64;
412
413  is.read(buf32,26);
414
415  is.read(buf64,60);
416  buf64[60] = '\0';
417  data._image_parameters1 = buf64;
418
419  for (int i = 0; i<5; i++)
420  {
421  is.read((char*)&(data._prf_values[i]),4);
422  data.SwitchEndian(data._prf_values[i]);
423  }
424
425  char buf190[191];
426  buf190[190] = '\0';
427  is.read(buf190,190);
428  data._image_parameters2 = buf190;
429
430  is.read(buf64,62);
431
432  is.read((char*)&(data._first_proc_range_samp),4);
433  data.SwitchEndian(data._first_proc_range_samp);
434
435  is.read((char*)&(data._range_ref),4);
436  data.SwitchEndian(data._range_ref);
437
438  is.read((char*)&(data._range_samp_rate),4);
439  data.SwitchEndian(data._range_samp_rate);
440
441  is.read((char*)&(data._radar_freq),4);
442  data.SwitchEndian(data._radar_freq);
443
444  is.read((char*)&(data._num_looks_range),2);
445  data.SwitchEndian(data._num_looks_range);
446
447  is.read(buf7,7);
448  data._filter_range = buf7;
449
450  is.read((char*)&(data._filter_coef_range),4);
451  data.SwitchEndian(data._filter_coef_range);
452
453  is.read(buf64,40);
454  buf64[40] = '\0';
455  data._bandwidth = buf64;
456
457  char buf160[161];
458  buf160[160] = '\0';
459  is.read(buf160,160);
460  data._nominal_chirp = buf160;
461
462  is.read(buf64,60);
463
464  is.read((char*)&(data._num_lines_proc),4);
465  data.SwitchEndian(data._num_lines_proc);
466
467  is.read((char*)&(data._num_look_az),2);
468  data.SwitchEndian(data._num_look_az);
469
470  is.read((char*)&(data._look_bw_az),4);
471  data.SwitchEndian(data._look_bw_az);
472
473  is.read((char*)&(data._to_bw_az),4);
474  data.SwitchEndian(data._to_bw_az);
475
476  is.read(buf7,7);
477  data._filter_az = buf7;
478
479  is.read((char*)&(data._filter_coef_az),4);
480  data.SwitchEndian(data._filter_coef_az);
481
482  for (int i = 0; i <3; i++) {
483  is.read((char*)&(data._az_fm_rate[i]),4);
484  data.SwitchEndian(data._az_fm_rate[i]);
485  }
486
487  is.read((char*)&(data._ax_fm_origin),4);
488  data.SwitchEndian(data._ax_fm_origin);
489
490  is.read((char*)&(data._dop_amb_coef),4);
491  data.SwitchEndian(data._dop_amb_coef);
492
493  char buf128[129];
494  buf128[128] = '\0';
495  is.read(buf128,68);
496
497  is.read(buf16,16);
498  data._calibration_factors = buf16;
499
500  is.read(buf64,40);
501  buf64[40]='\0';
502  data._noise_estimation = buf64;
503
504  is.read(buf64,64);
505
506  is.read(buf12,12);
507
508  is.read(buf32,32);
509  data._output_statistics = buf32;
510
511  is.read((char*)&(data._avg_scene_height_ellpsoid),4);
512  data.SwitchEndian(data._avg_scene_height_ellpsoid);
513
514  is.read(buf64,48);
515
516  is.read(buf4,4);
517  data._echo_comp = buf4;
518
519  is.read(buf3,3);
520  data._echo_comp_ratio = buf3;
521
522  is.read(buf4,4);
523  data._init_cal_comp = buf4;
524
525  is.read(buf3,3);
526  data._init_cal_ratio = buf3;
527
529  data._per_cal_comp = buf4;
530
531  is.read(buf3,3);
532  data._per_cal_ratio = buf3;
533
534  is.read(buf4,4);
535  data._noise_comp = buf4;
536
537  is.read(buf3,3);
538  data._noise_comp_ratio = buf3;
539
540  is.read(buf64,64);
541
542  for (int i=0;i<4;i++)
543  {
544  is.read((char*)&(data._beam_overlap[i]),4);
545  data.SwitchEndian(data._beam_overlap[i]);
546  }
547  for (int i=0;i<4;i++)
548  {
549  is.read((char*)&(data._beam_param[i]),4);
550  data.SwitchEndian(data._beam_param[i]);
551  }
552  for (int i=0;i<5;i++)
553  {
554  is.read((char*)&(data._lines_per_burst[i]),4);
555  data.SwitchEndian(data._lines_per_burst[i]);
556  }
557
558  is.read(buf12,12);
559  data._time_first_SS1_echo = buf12;
560
561  is.read(buf16,16);
562
563  is.read((char*)&(data._state_vector_time_1_day),4);
564  data.SwitchEndian(data._state_vector_time_1_day);
565
566  is.read((char*)&(data._state_vector_time_1_sec),4);
567  data.SwitchEndian(data._state_vector_time_1_sec);
568
569  is.read((char*)&(data._state_vector_time_1_microsec),4);
570  data.SwitchEndian(data._state_vector_time_1_microsec);
571
572  is.read((char*)&(data._x_pos_1),4);
573  data.SwitchEndian(data._x_pos_1);
574
575  is.read((char*)&(data._y_pos_1),4);
576  data.SwitchEndian(data._y_pos_1);
577
578  is.read((char*)&(data._z_pos_1),4);
579  data.SwitchEndian(data._z_pos_1);
580
581  is.read((char*)&(data._x_vel_1),4);
582  data.SwitchEndian(data._x_vel_1);
583
584  is.read((char*)&(data._y_vel_1),4);
585  data.SwitchEndian(data._y_vel_1);
586
587  is.read((char*)&(data._z_vel_1),4);
588  data.SwitchEndian(data._z_vel_1);
589
590  is.read((char*)&(data._state_vector_time_2_day),4);
591  data.SwitchEndian(data._state_vector_time_2_day);
592
593  is.read((char*)&(data._state_vector_time_2_sec),4);
594  data.SwitchEndian(data._state_vector_time_2_sec);
595
596  is.read((char*)&(data._state_vector_time_2_microsec),4);
597  data.SwitchEndian(data._state_vector_time_2_microsec);
598
599  is.read((char*)&(data._x_pos_2),4);
600  data.SwitchEndian(data._x_pos_2);
601
602  is.read((char*)&(data._y_pos_2),4);
603  data.SwitchEndian(data._y_pos_2);
604
605  is.read((char*)&(data._z_pos_2),4);
606  data.SwitchEndian(data._z_pos_2);
607
608  is.read((char*)&(data._x_vel_2),4);
609  data.SwitchEndian(data._x_vel_2);
610
611  is.read((char*)&(data._y_vel_2),4);
612  data.SwitchEndian(data._y_vel_2);
613
614  is.read((char*)&(data._z_vel_2),4);
615  data.SwitchEndian(data._z_vel_2);
616
617  is.read((char*)&(data._state_vector_time_3_day),4);
618  data.SwitchEndian(data._state_vector_time_3_day);
619
620  is.read((char*)&(data._state_vector_time_3_sec),4);
621  data.SwitchEndian(data._state_vector_time_3_sec);
622
623  is.read((char*)&(data._state_vector_time_3_microsec),4);
624  data.SwitchEndian(data._state_vector_time_3_microsec);
625
626  is.read((char*)&(data._x_pos_3),4);
627  data.SwitchEndian(data._x_pos_3);
628
629  is.read((char*)&(data._y_pos_3),4);
630  data.SwitchEndian(data._y_pos_3);
631
632  is.read((char*)&(data._z_pos_3),4);
633  data.SwitchEndian(data._z_pos_3);
634
635  is.read((char*)&(data._x_vel_3),4);
636  data.SwitchEndian(data._x_vel_3);
637
638  is.read((char*)&(data._y_vel_3),4);
639  data.SwitchEndian(data._y_vel_3);
640
641  is.read((char*)&(data._z_vel_3),4);
642  data.SwitchEndian(data._z_vel_3);
643
644  is.read((char*)&(data._state_vector_time_4_day),4);
645  data.SwitchEndian(data._state_vector_time_4_day);
646
647  is.read((char*)&(data._state_vector_time_4_sec),4);
648  data.SwitchEndian(data._state_vector_time_4_sec);
649
650  is.read((char*)&(data._state_vector_time_4_microsec),4);
651  data.SwitchEndian(data._state_vector_time_4_microsec);
652
653  is.read((char*)&(data._x_pos_4),4);
654  data.SwitchEndian(data._x_pos_4);
655
656  is.read((char*)&(data._y_pos_4),4);
657  data.SwitchEndian(data._y_pos_4);
658
659  is.read((char*)&(data._z_pos_4),4);
660  data.SwitchEndian(data._z_pos_4);
661
662  is.read((char*)&(data._x_vel_4),4);
663  data.SwitchEndian(data._x_vel_4);
664
665  is.read((char*)&(data._y_vel_4),4);
666  data.SwitchEndian(data._y_vel_4);
667
668  is.read((char*)&(data._z_vel_4),4);
669  data.SwitchEndian(data._z_vel_4);
670
671  is.read((char*)&(data._state_vector_time_5_day),4);
672  data.SwitchEndian(data._state_vector_time_5_day);
673
674  is.read((char*)&(data._state_vector_time_5_sec),4);
675  data.SwitchEndian(data._state_vector_time_5_sec);
676
677  is.read((char*)&(data._state_vector_time_5_microsec),4);
678  data.SwitchEndian(data._state_vector_time_5_microsec);
679
680  is.read((char*)&(data._x_pos_5),4);
681  data.SwitchEndian(data._x_pos_5);
682
683  is.read((char*)&(data._y_pos_5),4);
684  data.SwitchEndian(data._y_pos_5);
685
686  is.read((char*)&(data._z_pos_5),4);
687  data.SwitchEndian(data._z_pos_5);
688
689  is.read((char*)&(data._x_vel_5),4);
690  data.SwitchEndian(data._x_vel_5);
691
692  is.read((char*)&(data._y_vel_5),4);
693  data.SwitchEndian(data._y_vel_5);
694
695  is.read((char*)&(data._z_vel_5),4);
696  data.SwitchEndian(data._z_vel_5);
697
698  is.read(buf64,64);
699
700  return is;
701
702  }
◆ operator>>() [61/62]
std::istream& ossimplugins::operator>> ( std::istream &  is,
ErsSarFacilityData data
Definition at line 339 of file ErsSarFacilityData.cpp.
References ossimplugins::ErsSarFacilityData::_3_dB_look_bandwidth, ossimplugins::ErsSarFacilityData::_3_dB_look_proc_dopp_bandw, ossimplugins::ErsSarFacilityData::_3_dB_width_CCF, ossimplugins::ErsSarFacilityData::_abs_cal_const_K, ossimplugins::ErsSarFacilityData::_antenna_elev_flag, ossimplugins::ErsSarFacilityData::_asc_node_pos_X_comp, ossimplugins::ErsSarFacilityData::_asc_node_pos_Y_comp, ossimplugins::ErsSarFacilityData::_asc_node_pos_Z_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_X_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_Y_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_Z_comp, ossimplugins::ErsSarFacilityData::_autom_look_scal_gain_flag, ossimplugins::ErsSarFacilityData::_azimuth_baseband_convers_flag, ossimplugins::ErsSarFacilityData::_azimuth_FFT_IFFT_ratio, ossimplugins::ErsSarFacilityData::_cal_gain_change_flag, ossimplugins::ErsSarFacilityData::_cal_gain_changes, ossimplugins::ErsSarFacilityData::_cal_sys_gain, ossimplugins::ErsSarFacilityData::_cal_syst_gain_last_proc, ossimplugins::ErsSarFacilityData::_center_range_pix_mid_az_inc, ossimplugins::ErsSarFacilityData::_coef_ant_elev_1, ossimplugins::ErsSarFacilityData::_coef_ant_elev_2, ossimplugins::ErsSarFacilityData::_coef_ant_elev_3, ossimplugins::ErsSarFacilityData::_coef_ant_elev_4, ossimplugins::ErsSarFacilityData::_coef_ant_elev_5, ossimplugins::ErsSarFacilityData::_coef_ground_range_1, ossimplugins::ErsSarFacilityData::_coef_ground_range_2, ossimplugins::ErsSarFacilityData::_coef_ground_range_3, ossimplugins::ErsSarFacilityData::_coef_ground_range_4, ossimplugins::ErsSarFacilityData::_datation_flag, ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas, ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas_flag, ossimplugins::ErsSarFacilityData::_dopp_ambig_num, ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas, ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas_flag, ossimplugins::ErsSarFacilityData::_dopp_cent_val_flag, ossimplugins::ErsSarFacilityData::_doppler_ambiguity_estimat_flag, ossimplugins::ErsSarFacilityData::_doppler_centroid_cubic_coeff, ossimplugins::ErsSarFacilityData::_estim_bit_error_rate, ossimplugins::ErsSarFacilityData::_first_processed_range_sample, ossimplugins::ErsSarFacilityData::_first_range_pixel_mid_az_inc, ossimplugins::ErsSarFacilityData::_first_rec_gain_read, ossimplugins::ErsSarFacilityData::_first_replica_sample, ossimplugins::ErsSarFacilityData::_first_side_lobe_lev_of_ACF, ossimplugins::ErsSarFacilityData::_first_side_lobe_level, ossimplugins::ErsSarFacilityData::_form_num_range_line_used, ossimplugins::ErsSarFacilityData::_I_channel_bias_correction, ossimplugins::ErsSarFacilityData::_I_channel_gain_correction, ossimplugins::ErsSarFacilityData::_I_gain_imb_lower_bound, ossimplugins::ErsSarFacilityData::_I_gain_imb_upper_bound, ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_lower_bound, ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_upper_bound, ossimplugins::ErsSarFacilityData::_initial_doppler_ambiguity_num, ossimplugins::ErsSarFacilityData::_inp_data_I_mean, ossimplugins::ErsSarFacilityData::_inp_data_I_stddev, ossimplugins::ErsSarFacilityData::_inp_data_Q_mean, ossimplugins::ErsSarFacilityData::_inp_data_Q_stddev, ossimplugins::ErsSarFacilityData::_inp_data_stat_flag, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_X_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Y_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Z_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vx_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vy_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vz_comp, ossimplugins::ErsSarFacilityData::_inp_state_vector_type_flag, ossimplugins::ErsSarFacilityData::_int_cal_utc, ossimplugins::ErsSarFacilityData::_ISLR_CCF_between_last, ossimplugins::ErsSarFacilityData::_ISLR_of_ACF, ossimplugins::ErsSarFacilityData::_K_gen_date, ossimplugins::ErsSarFacilityData::_K_vers_num, ossimplugins::ErsSarFacilityData::_last_range_pix_mid_az_inc, ossimplugins::ErsSarFacilityData::_last_release_cal_date, ossimplugins::ErsSarFacilityData::_last_release_qc_date, ossimplugins::ErsSarFacilityData::_look_detecion_flag, ossimplugins::ErsSarFacilityData::_look_scalar_gain_1, ossimplugins::ErsSarFacilityData::_look_scalar_gain_2, ossimplugins::ErsSarFacilityData::_look_scalar_gain_3, ossimplugins::ErsSarFacilityData::_look_scalar_gain_4, ossimplugins::ErsSarFacilityData::_look_scalar_gain_5, ossimplugins::ErsSarFacilityData::_look_scalar_gain_6, ossimplugins::ErsSarFacilityData::_look_scalar_gain_7, ossimplugins::ErsSarFacilityData::_look_scalar_gain_8, ossimplugins::ErsSarFacilityData::_low_bound_K, ossimplugins::ErsSarFacilityData::_max_error_range_line_timing, ossimplugins::ErsSarFacilityData::_max_value_look_scalar_gain, ossimplugins::ErsSarFacilityData::_mean_cal_pulse_power, ossimplugins::ErsSarFacilityData::_mean_noise_power, ossimplugins::ErsSarFacilityData::_missing_lines, ossimplugins::ErsSarFacilityData::_name_of_facil_rec, ossimplugins::ErsSarFacilityData::_noise_power, ossimplugins::ErsSarFacilityData::_norm_ref_range_ro, ossimplugins::ErsSarFacilityData::_num_azimuth_blocks_proc, ossimplugins::ErsSarFacilityData::_num_duplic_input_lines, ossimplugins::ErsSarFacilityData::_num_input_raw_data_lines, ossimplugins::ErsSarFacilityData::_num_range_samp_discarded, ossimplugins::ErsSarFacilityData::_num_valid_cal_pulses, ossimplugins::ErsSarFacilityData::_num_valid_noise_pulses, ossimplugins::ErsSarFacilityData::_num_valid_pixels_per_range, ossimplugins::ErsSarFacilityData::_num_valid_replicas, ossimplugins::ErsSarFacilityData::_OGOB_flag, ossimplugins::ErsSarFacilityData::_out_image_max_value, ossimplugins::ErsSarFacilityData::_out_image_mean, ossimplugins::ErsSarFacilityData::_out_image_std_dev, ossimplugins::ErsSarFacilityData::_out_pixel_bit_length, ossimplugins::ErsSarFacilityData::_outp_data_mean_flag, ossimplugins::ErsSarFacilityData::_peak_loc_CCF_betw_last, ossimplugins::ErsSarFacilityData::_peak_loc_cross_correl_fun, ossimplugins::ErsSarFacilityData::_PRF_changes, ossimplugins::ErsSarFacilityData::_prf_code_change_flag, ossimplugins::ErsSarFacilityData::_PRF_code_first_range_line, ossimplugins::ErsSarFacilityData::_PRF_code_last_range_line, ossimplugins::ErsSarFacilityData::_proc_gain_param_1, ossimplugins::ErsSarFacilityData::_proc_gain_param_2, ossimplugins::ErsSarFacilityData::_proc_gain_param_3, ossimplugins::ErsSarFacilityData::_proc_noise_scale_fact, ossimplugins::ErsSarFacilityData::_pulse_width_of_ACF_3db, ossimplugins::ErsSarFacilityData::_Q_channel_bias_correction, ossimplugins::ErsSarFacilityData::_Q_channel_gain_correction, ossimplugins::ErsSarFacilityData::_Q_channel_I_Q_correction, ossimplugins::ErsSarFacilityData::_qa_summary_flag, ossimplugins::ErsSarFacilityData::_quirp_qu_flag, ossimplugins::ErsSarFacilityData::_range_comp_norm_fact, ossimplugins::ErsSarFacilityData::_range_lines_skip_factor, ossimplugins::ErsSarFacilityData::_range_spread_loss_comp_flag, ossimplugins::ErsSarFacilityData::_range_time_origin_ant, ossimplugins::ErsSarFacilityData::_raw_data_correction_flag, ossimplugins::ErsSarFacilityData::_rec_gain_changes, ossimplugins::ErsSarFacilityData::_receiver_gain_last_proc, ossimplugins::ErsSarFacilityData::_replica_norm_method_flag, ossimplugins::ErsSarFacilityData::_replica_power, ossimplugins::ErsSarFacilityData::_Roll_Tilt_Mode_flag, ossimplugins::ErsSarFacilityData::_samp_win_start_first, ossimplugins::ErsSarFacilityData::_samp_win_start_last, ossimplugins::ErsSarFacilityData::_samp_window_start_time_bias, ossimplugins::ErsSarFacilityData::_samples_per_line_used, ossimplugins::ErsSarFacilityData::_sampling_win_change_flag, ossimplugins::ErsSarFacilityData::_sampling_win_changes, ossimplugins::ErsSarFacilityData::_sat_binary_time_of_first, ossimplugins::ErsSarFacilityData::_thresh_no_10_flag, ossimplugins::ErsSarFacilityData::_thresh_no_11_flag, ossimplugins::ErsSarFacilityData::_thresh_no_1_flag, ossimplugins::ErsSarFacilityData::_thresh_no_2_flag, ossimplugins::ErsSarFacilityData::_thresh_no_3_flag, ossimplugins::ErsSarFacilityData::_thresh_no_4_flag, ossimplugins::ErsSarFacilityData::_thresh_no_5_flag, ossimplugins::ErsSarFacilityData::_thresh_no_6_flag, ossimplugins::ErsSarFacilityData::_thresh_no_7_flag, ossimplugins::ErsSarFacilityData::_thresh_no_8_flag, ossimplugins::ErsSarFacilityData::_thresh_no_9_flag, ossimplugins::ErsSarFacilityData::_time_asc_node_state_vectors, ossimplugins::ErsSarFacilityData::_time_of_inp_state_vectors, ossimplugins::ErsSarFacilityData::_time_raw_data_first_input, ossimplugins::ErsSarFacilityData::_update_period_range_match, ossimplugins::ErsSarFacilityData::_upp_bound_K, ossimplugins::ErsSarFacilityData::_win_coeff_for_azi_match, and ossimplugins::ErsSarFacilityData::_win_coeff_for_range_match.
340  {
341  char buf64[65];
342  buf64[64] = '\0';
343  // char buf32[33];
344  // buf32[32] = '\0';
345  char buf24[25];
346  buf24[24] = '\0';
347  char buf22[23];
348  buf22[22] = '\0';
349  char buf20[21];
350  buf20[20] = '\0';
351  char buf16[17];
352  buf16[16] = '\0';
353  char buf12[13];
354  buf12[12] = '\0';
355  char buf7[8];
356  buf7[7] = '\0';
357  char buf8[9];
358  buf8[8] = '\0';
359  char buf6[7];
360  buf6[6] = '\0';
361  char buf4[5];
362  buf4[4] = '\0';
363  char buf2[3];
364  buf2[2] = '\0';
365  char buf1[2];
366  buf1[1] = '\0';
367
368  is.read(buf64, 64);
369  data._name_of_facil_rec = buf64;
370
371  is.read(buf6, 6);
372  data._last_release_qc_date = buf6;
373
374  is.read(buf2, 2);
375
376  is.read(buf6, 6);
377  data._last_release_cal_date = buf6;
378
379  is.read(buf4, 4);
380  data._qa_summary_flag = atoi(buf4);
381
382  is.read(buf4, 4);
383  data._prf_code_change_flag = atoi(buf4);
384
385  is.read(buf4, 4);
386  data._sampling_win_change_flag = atoi(buf4);
387
388  is.read(buf4, 4);
389  data._cal_gain_change_flag = atoi(buf4);
390
392  data._quirp_qu_flag = atoi(buf4);
393
394  is.read(buf4, 4);
395  data._inp_data_stat_flag = atoi(buf4);
396
397  is.read(buf4, 4);
398  data._dopp_cent_conf_meas_flag = atoi(buf4);
399
400  is.read(buf4, 4);
401  data._dopp_cent_val_flag = atoi(buf4);
402
403  is.read(buf4, 4);
404  data._dopp_ambig_conf_meas_flag = atoi(buf4);
405
406  is.read(buf4, 4);
407  data._outp_data_mean_flag = atoi(buf4);
408
409  is.read(buf4, 4);
410  data._OGOB_flag = atoi(buf4);
411
412  is.read(buf4, 4);
413  data._PRF_changes = atoi(buf4);
414
415  is.read(buf4, 4);
416  data._sampling_win_changes = atoi(buf4);
417
418  is.read(buf4, 4);
419  data._cal_gain_changes = atoi(buf4);
420
421  is.read(buf4, 4);
422  data._missing_lines = atoi(buf4);
423
424  is.read(buf4, 4);
425  data._rec_gain_changes = atoi(buf4);
426
427  is.read(buf16, 16);
428  data._pulse_width_of_ACF_3db = atof(buf16);
429
430  is.read(buf16, 16);
431  data._first_side_lobe_lev_of_ACF = atof(buf16);
432
433  is.read(buf16, 16);
434  data._ISLR_of_ACF = atof(buf16);
435
436  is.read(buf16, 16);
437  data._dopp_cent_conf_meas = atof(buf16);
438
439  is.read(buf16, 16);
440  data._dopp_ambig_conf_meas = atof(buf16);
441
442  is.read(buf16, 16);
443  data._inp_data_I_mean = atof(buf16);
444
445  is.read(buf16, 16);
446  data._inp_data_Q_mean = atof(buf16);
447
448  is.read(buf16, 16);
449  data._inp_data_I_stddev = atof(buf16);
450
451  is.read(buf16, 16);
452  data._inp_data_Q_stddev = atof(buf16);
453
454  is.read(buf16, 16);
455  data._cal_sys_gain = atof(buf16);
456
457  is.read(buf16, 16);
458  data._first_rec_gain_read = atof(buf16);
459
460  is.read(buf16, 16);
461  data._dopp_ambig_num = atof(buf16);
462
463  is.read(buf16, 16);
464
465  is.read(buf16, 16);
466  data._I_channel_bias_correction = atof(buf16);
467
468  is.read(buf16, 16);
469  data._Q_channel_bias_correction = atof(buf16);
470
471  is.read(buf16, 16);
472  data._I_channel_gain_correction = atof(buf16);
473
474  is.read(buf16, 16);
475  data._Q_channel_gain_correction = atof(buf16);
476
477  is.read(buf16, 16);
478  data._Q_channel_I_Q_correction = atof(buf16);
479
480  is.read(buf16, 16);
481
482  is.read(buf16, 16);
483  data._noise_power = atof(buf16);
484
485  is.read(buf16, 16);
486  data._int_cal_utc = atoi(buf16);
487
488  is.read(buf4, 4);
489  data._num_valid_cal_pulses = atoi(buf4);
490
491  is.read(buf4, 4);
492  data._num_valid_noise_pulses = atoi(buf4);
493
494  is.read(buf4, 4);
495  data._num_valid_replicas = atoi(buf4);
496
497  is.read(buf16, 16);
498  data._first_replica_sample = atof(buf16);
499
500  is.read(buf16, 16);
501  data._mean_cal_pulse_power = atof(buf16);
502
503  is.read(buf16, 16);
504  data._mean_noise_power = atof(buf16);
505
506  is.read(buf16, 16);
507  data._range_comp_norm_fact = atof(buf16);
508
509  is.read(buf16, 16);
510  data._replica_power = atof(buf16);
511
513  data._first_range_pixel_mid_az_inc = atof(buf16);
514
516  data._center_range_pix_mid_az_inc = atof(buf16);
517
519  data._last_range_pix_mid_az_inc = atof(buf16);
520
521  is.read(buf16, 16);
522  data._norm_ref_range_ro = atof(buf16);
523
524  is.read(buf12, 12);
525
526  is.read(buf4, 4);
527  data._antenna_elev_flag = atoi(buf4);
528
530  data._abs_cal_const_K = atof(buf16);
531
532  is.read(buf16, 16);
533  data._upp_bound_K = atof(buf16);
534
535  is.read(buf16, 16);
536  data._low_bound_K = atof(buf16);
537
538  is.read(buf16, 16);
539  data._proc_noise_scale_fact = atof(buf16);
540
541  is.read(buf6, 6);
542  data._K_gen_date = buf6;
543
544  is.read(buf4, 4);
545  data._K_vers_num = buf4;
546
547  is.read(buf4, 4);
548  data._num_duplic_input_lines = atoi(buf4);
549
550  is.read(buf16, 16);
551  data._estim_bit_error_rate = atof(buf16);
552
553  is.read(buf12, 12);
554
555  is.read(buf16, 16);
556  data._out_image_mean = atof(buf16);
557
558  is.read(buf16, 16);
559  data._out_image_std_dev = atof(buf16);
560
561  is.read(buf16, 16);
562  data._out_image_max_value = atof(buf16);
563
564  is.read(buf24, 24);
565  data._time_raw_data_first_input = buf24;
566
567  is.read(buf24, 24);
568  data._time_asc_node_state_vectors = buf24;
569
570  is.read(buf22, 22);
571  data._asc_node_pos_X_comp = buf22;
572
573  is.read(buf22, 22);
574  data._asc_node_pos_Y_comp = buf22;
575
576  is.read(buf22, 22);
577  data._asc_node_pos_Z_comp = buf22;
578
579  is.read(buf22, 22);
580  data._asc_node_vel_X_comp = buf22;
581
582  is.read(buf22, 22);
583  data._asc_node_vel_Y_comp = buf22;
584
585  is.read(buf22, 22);
586  data._asc_node_vel_Z_comp = buf22;
587
588  is.read(buf4, 4);
589  data._out_pixel_bit_length = atoi(buf4);
590
591  is.read(buf16, 16);
592  data._proc_gain_param_1 = atof(buf16);
593
594  is.read(buf16, 16);
595  data._proc_gain_param_2 = atof(buf16);
596
597  is.read(buf16, 16);
598  data._proc_gain_param_3 = atof(buf16);
599
600  is.read(buf4, 4);
601  data._peak_loc_cross_correl_fun = atoi(buf4);
602
603  is.read(buf16, 16);
604  data._3_dB_width_CCF = atof(buf16);
605
606  is.read(buf16, 16);
607  data._first_side_lobe_level = atof(buf16);
608
609  is.read(buf16, 16);
610  data._ISLR_CCF_between_last = atof(buf16);
611
612  is.read(buf4, 4);
613  data._peak_loc_CCF_betw_last = atoi(buf4);
614
615  is.read(buf4, 4);
616  data._Roll_Tilt_Mode_flag = atoi(buf4);
617
618  is.read(buf4, 4);
619  data._raw_data_correction_flag = atoi(buf4);
620
621  is.read(buf4, 4);
622  data._look_detecion_flag = atoi(buf4);
623
624  is.read(buf4, 4);
625  data._doppler_ambiguity_estimat_flag = atoi(buf4);
626
627  is.read(buf4, 4);
628  data._azimuth_baseband_convers_flag = atoi(buf4);
629
630  is.read(buf4, 4);
631  data._samples_per_line_used = atoi(buf4);
632
633  is.read(buf4, 4);
634  data._range_lines_skip_factor = atoi(buf4);
635
636  is.read(buf24, 24);
637  data._time_of_inp_state_vectors = buf24;
638
639  is.read(buf22, 22);
640  data._inp_state_vect_pos_X_comp = buf22;
641
642  is.read(buf22, 22);
643  data._inp_state_vect_pos_Y_comp = buf22;
644
645  is.read(buf22, 22);
646  data._inp_state_vect_pos_Z_comp = buf22;
647
648  is.read(buf22, 22);
649  data._inp_state_vect_vel_Vx_comp = buf22;
650
651  is.read(buf22, 22);
652  data._inp_state_vect_vel_Vy_comp = buf22;
653
654  is.read(buf22, 22);
655  data._inp_state_vect_vel_Vz_comp = buf22;
656
657  is.read(buf4, 4);
658  data._inp_state_vector_type_flag = atoi(buf4);
659
660  is.read(buf16, 16);
661  data._win_coeff_for_range_match = atof(buf16);
662
663  is.read(buf16, 16);
664  data._win_coeff_for_azi_match = atof(buf16);
665
666  is.read(buf4, 4);
667  data._update_period_range_match = atoi(buf4);
668
669  is.read(buf16, 16);
670  data._look_scalar_gain_1 = atof(buf16);
671
672  is.read(buf16, 16);
673  data._look_scalar_gain_2 = atof(buf16);
674
675  is.read(buf16, 16);
676  data._look_scalar_gain_3 = atof(buf16);
677
678  is.read(buf16, 16);
679  data._look_scalar_gain_4 = atof(buf16);
680
681  is.read(buf16, 16);
682  data._look_scalar_gain_5 = atof(buf16);
683
684  is.read(buf16, 16);
685  data._look_scalar_gain_6 = atof(buf16);
686
687  is.read(buf16, 16);
688  data._look_scalar_gain_7 = atof(buf16);
689
690  is.read(buf16, 16);
691  data._look_scalar_gain_8 = atof(buf16);
692
693  is.read(buf4, 4);
694  data._samp_window_start_time_bias = atoi(buf4);
695
696  is.read(buf22, 22);
697  data._doppler_centroid_cubic_coeff = atof(buf22);
698
699  is.read(buf4, 4);
700  data._PRF_code_first_range_line = atoi(buf4);
701
702  is.read(buf4, 4);
703  data._PRF_code_last_range_line = atoi(buf4);
704
705  is.read(buf4, 4);
706  data._samp_win_start_first = atoi(buf4);
707
708  is.read(buf4, 4);
709  data._samp_win_start_last = atoi(buf4);
710
711  is.read(buf4, 4);
712  data._cal_syst_gain_last_proc = atoi(buf4);
713
714  is.read(buf4, 4);
715  data._receiver_gain_last_proc = atoi(buf4);
716
717  is.read(buf4, 4);
718  data._first_processed_range_sample = atoi(buf4);
719
720  is.read(buf4, 4);
721  data._azimuth_FFT_IFFT_ratio = atoi(buf4);
722
723  is.read(buf4, 4);
724  data._num_azimuth_blocks_proc = atoi(buf4);
725
726  is.read(buf8, 8);
727  data._num_input_raw_data_lines = atol(buf8);
728
729  is.read(buf4, 4);
730  data._initial_doppler_ambiguity_num = atoi(buf4);
731
732  is.read(buf16, 16);
733  data._thresh_no_1_flag = atof(buf16);
734
735  is.read(buf16, 16);
736  data._thresh_no_2_flag = atof(buf16);
737
738  is.read(buf16, 16);
739  data._thresh_no_3_flag = atof(buf16);
740
741  is.read(buf16, 16);
742  data._thresh_no_4_flag = atof(buf16);
743
744  is.read(buf16, 16);
745  data._thresh_no_5_flag = atof(buf16);
746
747  is.read(buf16, 16);
748  data._thresh_no_6_flag = atof(buf16);
749
750  is.read(buf16, 16);
751  data._thresh_no_7_flag = atof(buf16);
752
753  is.read(buf16, 16);
754  data._thresh_no_8_flag = atof(buf16);
755
756  is.read(buf16, 16);
757  data._thresh_no_9_flag = atof(buf16);
758
759  is.read(buf16, 16);
760  data._thresh_no_10_flag = atof(buf16);
761
762  is.read(buf16, 16);
763  data._thresh_no_11_flag = atof(buf16);
764
765  is.read(buf16, 16);
766  data._sat_binary_time_of_first = atol(buf16);
767
768  is.read(buf4, 4);
769  data._num_valid_pixels_per_range = atoi(buf4);
770
771  is.read(buf4, 4);
772  data._num_range_samp_discarded = atoi(buf4);
773
774  is.read(buf16, 16);
775  data._I_gain_imb_lower_bound = atof(buf16);
776
777  is.read(buf16, 16);
778  data._I_gain_imb_upper_bound = atof(buf16);
779
780  is.read(buf16, 16);
781  data._I_Q_quad_depar_lower_bound = atof(buf16);
782
783  is.read(buf16, 16);
784  data._I_Q_quad_depar_upper_bound = atof(buf16);
785
786  is.read(buf16, 16);
787  data._3_dB_look_bandwidth = atof(buf16);
788
789  is.read(buf16, 16);
790  data._3_dB_look_proc_dopp_bandw = atof(buf16);
791
792  is.read(buf4, 4);
793  data._range_spread_loss_comp_flag = atoi(buf4);
794
795  is.read(buf1, 1);
796  data._datation_flag = (atoi(buf1) == 0) ? false : true;
797
798  is.read(buf7, 7);
799  data._max_error_range_line_timing = atoi(buf7);
800
801  is.read(buf7, 7);
802  data._form_num_range_line_used = atoi(buf7);
803
804  is.read(buf1, 1);
805  data._autom_look_scal_gain_flag = (atoi(buf1) == 0) ? false : true;
806
807  is.read(buf4, 4);
808  data._max_value_look_scalar_gain = atoi(buf4);
809
810  is.read(buf4, 4);
811  data._replica_norm_method_flag = atoi(buf4);
812
813  is.read(buf20, 20);
814  data._coef_ground_range_1 = atof(buf20);
815
816  is.read(buf20, 20);
817  data._coef_ground_range_2 = atof(buf20);
818
819  is.read(buf20, 20);
820  data._coef_ground_range_3 = atof(buf20);
821
822  is.read(buf20, 20);
823  data._coef_ground_range_4 = atof(buf20);
824
825  is.read(buf20, 20);
826  data._coef_ant_elev_1 = atof(buf20);
827
828  is.read(buf20, 20);
829  data._coef_ant_elev_2 = atof(buf20);
830
831  is.read(buf20, 20);
832  data._coef_ant_elev_3 = atof(buf20);
833
834  is.read(buf20, 20);
835  data._coef_ant_elev_4 = atof(buf20);
836
837  is.read(buf20, 20);
838  data._coef_ant_elev_5 = atof(buf20);
839
840  is.read(buf16, 16);
841  data._range_time_origin_ant = atof(buf16);
842
843  char buf10238[10238];
844  is.read(buf10238, 10238);
845  return is;
846  }
◆ operator>>() [62/62]
AlosPalsarFacilityData data
Definition at line 340 of file AlosPalsarFacilityData.cpp.
References ossimplugins::AlosPalsarFacilityData::_3_dB_look_bandwidth, ossimplugins::AlosPalsarFacilityData::_3_dB_look_proc_dopp_bandw, ossimplugins::AlosPalsarFacilityData::_3_dB_width_CCF, ossimplugins::AlosPalsarFacilityData::_abs_cal_const_K, ossimplugins::AlosPalsarFacilityData::_antenna_elev_flag, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_X_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Y_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Z_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_X_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Y_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Z_comp, ossimplugins::AlosPalsarFacilityData::_autom_look_scal_gain_flag, ossimplugins::AlosPalsarFacilityData::_azimuth_baseband_convers_flag, ossimplugins::AlosPalsarFacilityData::_azimuth_FFT_IFFT_ratio, ossimplugins::AlosPalsarFacilityData::_cal_gain_change_flag, ossimplugins::AlosPalsarFacilityData::_cal_gain_changes, ossimplugins::AlosPalsarFacilityData::_cal_sys_gain, ossimplugins::AlosPalsarFacilityData::_cal_syst_gain_last_proc, ossimplugins::AlosPalsarFacilityData::_center_range_pix_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_1, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_2, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_3, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_4, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_5, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_1, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_2, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_3, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_4, ossimplugins::AlosPalsarFacilityData::_datation_flag, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas_flag, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_num, ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas, ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas_flag, ossimplugins::AlosPalsarFacilityData::_dopp_cent_val_flag, ossimplugins::AlosPalsarFacilityData::_doppler_ambiguity_estimat_flag, ossimplugins::AlosPalsarFacilityData::_doppler_centroid_cubic_coeff, ossimplugins::AlosPalsarFacilityData::_estim_bit_error_rate, ossimplugins::AlosPalsarFacilityData::_first_processed_range_sample, ossimplugins::AlosPalsarFacilityData::_first_range_pixel_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_first_rec_gain_read, ossimplugins::AlosPalsarFacilityData::_first_replica_sample, ossimplugins::AlosPalsarFacilityData::_first_side_lobe_lev_of_ACF, ossimplugins::AlosPalsarFacilityData::_first_side_lobe_level, ossimplugins::AlosPalsarFacilityData::_form_num_range_line_used, ossimplugins::AlosPalsarFacilityData::_I_channel_bias_correction, ossimplugins::AlosPalsarFacilityData::_I_channel_gain_correction, ossimplugins::AlosPalsarFacilityData::_I_gain_imb_lower_bound, ossimplugins::AlosPalsarFacilityData::_I_gain_imb_upper_bound, ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_lower_bound, ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_upper_bound, ossimplugins::AlosPalsarFacilityData::_initial_doppler_ambiguity_num, ossimplugins::AlosPalsarFacilityData::_inp_data_I_mean, ossimplugins::AlosPalsarFacilityData::_inp_data_I_stddev, ossimplugins::AlosPalsarFacilityData::_inp_data_Q_mean, ossimplugins::AlosPalsarFacilityData::_inp_data_Q_stddev, ossimplugins::AlosPalsarFacilityData::_inp_data_stat_flag, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_X_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Y_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Z_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vx_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vy_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vz_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vector_type_flag, ossimplugins::AlosPalsarFacilityData::_int_cal_utc, ossimplugins::AlosPalsarFacilityData::_ISLR_CCF_between_last, ossimplugins::AlosPalsarFacilityData::_ISLR_of_ACF, ossimplugins::AlosPalsarFacilityData::_K_gen_date, ossimplugins::AlosPalsarFacilityData::_K_vers_num, ossimplugins::AlosPalsarFacilityData::_last_range_pix_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_last_release_cal_date, ossimplugins::AlosPalsarFacilityData::_last_release_qc_date, ossimplugins::AlosPalsarFacilityData::_look_detecion_flag, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_1, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_2, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_3, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_4, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_5, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_6, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_7, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_8, ossimplugins::AlosPalsarFacilityData::_low_bound_K, ossimplugins::AlosPalsarFacilityData::_max_error_range_line_timing, ossimplugins::AlosPalsarFacilityData::_max_value_look_scalar_gain, ossimplugins::AlosPalsarFacilityData::_mean_cal_pulse_power, ossimplugins::AlosPalsarFacilityData::_mean_noise_power, ossimplugins::AlosPalsarFacilityData::_missing_lines, ossimplugins::AlosPalsarFacilityData::_name_of_facil_rec, ossimplugins::AlosPalsarFacilityData::_noise_power, ossimplugins::AlosPalsarFacilityData::_norm_ref_range_ro, ossimplugins::AlosPalsarFacilityData::_num_azimuth_blocks_proc, ossimplugins::AlosPalsarFacilityData::_num_duplic_input_lines, ossimplugins::AlosPalsarFacilityData::_num_input_raw_data_lines, ossimplugins::AlosPalsarFacilityData::_num_range_samp_discarded, ossimplugins::AlosPalsarFacilityData::_num_valid_cal_pulses, ossimplugins::AlosPalsarFacilityData::_num_valid_noise_pulses, ossimplugins::AlosPalsarFacilityData::_num_valid_pixels_per_range, ossimplugins::AlosPalsarFacilityData::_num_valid_replicas, ossimplugins::AlosPalsarFacilityData::_OGOB_flag, ossimplugins::AlosPalsarFacilityData::_out_image_max_value, ossimplugins::AlosPalsarFacilityData::_out_image_mean, ossimplugins::AlosPalsarFacilityData::_out_image_std_dev, ossimplugins::AlosPalsarFacilityData::_out_pixel_bit_length, ossimplugins::AlosPalsarFacilityData::_outp_data_mean_flag, ossimplugins::AlosPalsarFacilityData::_peak_loc_CCF_betw_last, ossimplugins::AlosPalsarFacilityData::_peak_loc_cross_correl_fun, ossimplugins::AlosPalsarFacilityData::_PRF_changes, ossimplugins::AlosPalsarFacilityData::_prf_code_change_flag, ossimplugins::AlosPalsarFacilityData::_PRF_code_first_range_line, ossimplugins::AlosPalsarFacilityData::_PRF_code_last_range_line, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_1, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_2, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_3, ossimplugins::AlosPalsarFacilityData::_proc_noise_scale_fact, ossimplugins::AlosPalsarFacilityData::_pulse_width_of_ACF_3db, ossimplugins::AlosPalsarFacilityData::_Q_channel_bias_correction, ossimplugins::AlosPalsarFacilityData::_Q_channel_gain_correction, ossimplugins::AlosPalsarFacilityData::_Q_channel_I_Q_correction, ossimplugins::AlosPalsarFacilityData::_qa_summary_flag, ossimplugins::AlosPalsarFacilityData::_quirp_qu_flag, ossimplugins::AlosPalsarFacilityData::_range_comp_norm_fact, ossimplugins::AlosPalsarFacilityData::_range_lines_skip_factor, ossimplugins::AlosPalsarFacilityData::_range_spread_loss_comp_flag, ossimplugins::AlosPalsarFacilityData::_range_time_origin_ant, ossimplugins::AlosPalsarFacilityData::_raw_data_correction_flag, ossimplugins::AlosPalsarFacilityData::_rec_gain_changes, ossimplugins::AlosPalsarFacilityData::_receiver_gain_last_proc, ossimplugins::AlosPalsarFacilityData::_replica_norm_method_flag, ossimplugins::AlosPalsarFacilityData::_replica_power, ossimplugins::AlosPalsarFacilityData::_Roll_Tilt_Mode_flag, ossimplugins::AlosPalsarFacilityData::_samp_win_start_first, ossimplugins::AlosPalsarFacilityData::_samp_win_start_last, ossimplugins::AlosPalsarFacilityData::_samp_window_start_time_bias, ossimplugins::AlosPalsarFacilityData::_samples_per_line_used, ossimplugins::AlosPalsarFacilityData::_sampling_win_change_flag, ossimplugins::AlosPalsarFacilityData::_sampling_win_changes, ossimplugins::AlosPalsarFacilityData::_sat_binary_time_of_first, ossimplugins::AlosPalsarFacilityData::_thresh_no_10_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_11_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_1_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_2_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_3_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_4_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_5_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_6_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_7_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_8_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_9_flag, ossimplugins::AlosPalsarFacilityData::_time_asc_node_state_vectors, ossimplugins::AlosPalsarFacilityData::_time_of_inp_state_vectors, ossimplugins::AlosPalsarFacilityData::_time_raw_data_first_input, ossimplugins::AlosPalsarFacilityData::_update_period_range_match, ossimplugins::AlosPalsarFacilityData::_upp_bound_K, ossimplugins::AlosPalsarFacilityData::_win_coeff_for_azi_match, and ossimplugins::AlosPalsarFacilityData::_win_coeff_for_range_match.
341  {
342  char buf64[65];
343  buf64[64] = '\0';
344  char buf32[33];
345  buf32[32] = '\0';
346  char buf24[25];
347  buf24[24] = '\0';
348  char buf22[23];
349  buf22[22] = '\0';
350  char buf20[21];
351  buf20[20] = '\0';
352  char buf16[17];
353  buf16[16] = '\0';
354  char buf12[13];
355  buf12[12] = '\0';
356  char buf7[8];
357  buf7[7] = '\0';
358  char buf8[9];
359  buf8[8] = '\0';
360  char buf6[7];
361  buf6[6] = '\0';
362  char buf4[5];
363  buf4[4] = '\0';
364  char buf2[3];
365  buf2[2] = '\0';
366  char buf1[2];
367  buf1[1] = '\0';
368
369  is.read(buf64, 64);
370  data._name_of_facil_rec = buf64;
371
372  is.read(buf6, 6);
373  data._last_release_qc_date = buf6;
374
375  is.read(buf2, 2);
376
377  is.read(buf6, 6);
378  data._last_release_cal_date = buf6;
379
380  is.read(buf4, 4);
381  data._qa_summary_flag = atoi(buf4);
382
383  is.read(buf4, 4);
384  data._prf_code_change_flag = atoi(buf4);
385
386  is.read(buf4, 4);
387  data._sampling_win_change_flag = atoi(buf4);
388
389  is.read(buf4, 4);
390  data._cal_gain_change_flag = atoi(buf4);
391
392  is.read(buf4, 4);
393  data._quirp_qu_flag = atoi(buf4);
394
395  is.read(buf4, 4);
396  data._inp_data_stat_flag = atoi(buf4);
397
398  is.read(buf4, 4);
399  data._dopp_cent_conf_meas_flag = atoi(buf4);
400
401  is.read(buf4, 4);
402  data._dopp_cent_val_flag = atoi(buf4);
403
404  is.read(buf4, 4);
405  data._dopp_ambig_conf_meas_flag = atoi(buf4);
406
407  is.read(buf4, 4);
408  data._outp_data_mean_flag = atoi(buf4);
409
410  is.read(buf4, 4);
411  data._OGOB_flag = atoi(buf4);
412
413  is.read(buf4, 4);
414  data._PRF_changes = atoi(buf4);
415
416  is.read(buf4, 4);
417  data._sampling_win_changes = atoi(buf4);
418
419  is.read(buf4, 4);
420  data._cal_gain_changes = atoi(buf4);
421
422  is.read(buf4, 4);
423  data._missing_lines = atoi(buf4);
424
425  is.read(buf4, 4);
426  data._rec_gain_changes = atoi(buf4);
427
428  is.read(buf16, 16);
429  data._pulse_width_of_ACF_3db = atof(buf16);
430
431  is.read(buf16, 16);
432  data._first_side_lobe_lev_of_ACF = atof(buf16);
433
434  is.read(buf16, 16);
435  data._ISLR_of_ACF = atof(buf16);
436
437  is.read(buf16, 16);
438  data._dopp_cent_conf_meas = atof(buf16);
439
440  is.read(buf16, 16);
441  data._dopp_ambig_conf_meas = atof(buf16);
442
443  is.read(buf16, 16);
444  data._inp_data_I_mean = atof(buf16);
445
446  is.read(buf16, 16);
447  data._inp_data_Q_mean = atof(buf16);
448
449  is.read(buf16, 16);
450  data._inp_data_I_stddev = atof(buf16);
451
452  is.read(buf16, 16);
453  data._inp_data_Q_stddev = atof(buf16);
454
455  is.read(buf16, 16);
456  data._cal_sys_gain = atof(buf16);
457
458  is.read(buf16, 16);
459  data._first_rec_gain_read = atof(buf16);
460
461  is.read(buf16, 16);
462  data._dopp_ambig_num = atof(buf16);
463
464  is.read(buf16, 16);
465
466  is.read(buf16, 16);
467  data._I_channel_bias_correction = atof(buf16);
468
469  is.read(buf16, 16);
470  data._Q_channel_bias_correction = atof(buf16);
471
472  is.read(buf16, 16);
473  data._I_channel_gain_correction = atof(buf16);
474
475  is.read(buf16, 16);
476  data._Q_channel_gain_correction = atof(buf16);
477
478  is.read(buf16, 16);
479  data._Q_channel_I_Q_correction = atof(buf16);
480
481  is.read(buf16, 16);
482
483  is.read(buf16, 16);
484  data._noise_power = atof(buf16);
485
486  is.read(buf16, 16);
487  data._int_cal_utc = atoi(buf16);
488
489  is.read(buf4, 4);
490  data._num_valid_cal_pulses = atoi(buf4);
491
492  is.read(buf4, 4);
493  data._num_valid_noise_pulses = atoi(buf4);
494
495  is.read(buf4, 4);
496  data._num_valid_replicas = atoi(buf4);
497
498  is.read(buf16, 16);
499  data._first_replica_sample = atof(buf16);
500
501  is.read(buf16, 16);
502  data._mean_cal_pulse_power = atof(buf16);
503
504  is.read(buf16, 16);
505  data._mean_noise_power = atof(buf16);
506
507  is.read(buf16, 16);
508  data._range_comp_norm_fact = atof(buf16);
509
510  is.read(buf16, 16);
511  data._replica_power = atof(buf16);
512
513  is.read(buf16, 16);
514  data._first_range_pixel_mid_az_inc = atof(buf16);
515
516  is.read(buf16, 16);
517  data._center_range_pix_mid_az_inc = atof(buf16);
518
519  is.read(buf16, 16);
520  data._last_range_pix_mid_az_inc = atof(buf16);
521
522  is.read(buf16, 16);
523  data._norm_ref_range_ro = atof(buf16);
524
525  is.read(buf12, 12);
526
527  is.read(buf4, 4);
528  data._antenna_elev_flag = atoi(buf4);
529
530  is.read(buf16, 16);
531  data._abs_cal_const_K = atof(buf16);
532
533  is.read(buf16, 16);
534  data._upp_bound_K = atof(buf16);
535
536  is.read(buf16, 16);
537  data._low_bound_K = atof(buf16);
538
539  is.read(buf16, 16);
540  data._proc_noise_scale_fact = atof(buf16);
541
542  is.read(buf6, 6);
543  data._K_gen_date = buf6;
544
545  is.read(buf4, 4);
546  data._K_vers_num = buf4;
547
548  is.read(buf4, 4);
549  data._num_duplic_input_lines = atoi(buf4);
550
551  is.read(buf16, 16);
552  data._estim_bit_error_rate = atof(buf16);
553
554  is.read(buf12, 12);
555
556  is.read(buf16, 16);
557  data._out_image_mean = atof(buf16);
558
559  is.read(buf16, 16);
560  data._out_image_std_dev = atof(buf16);
561
562  is.read(buf16, 16);
563  data._out_image_max_value = atof(buf16);
564
565  is.read(buf24, 24);
566  data._time_raw_data_first_input = buf24;
567
568  is.read(buf24, 24);
569  data._time_asc_node_state_vectors = buf24;
570
571  is.read(buf22, 22);
572  data._asc_node_pos_X_comp = buf22;
573
574  is.read(buf22, 22);
575  data._asc_node_pos_Y_comp = buf22;
576
577  is.read(buf22, 22);
578  data._asc_node_pos_Z_comp = buf22;
579
580  is.read(buf22, 22);
581  data._asc_node_vel_X_comp = buf22;
582
583  is.read(buf22, 22);
584  data._asc_node_vel_Y_comp = buf22;
585
586  is.read(buf22, 22);
587  data._asc_node_vel_Z_comp = buf22;
588
589  is.read(buf4, 4);
590  data._out_pixel_bit_length = atoi(buf4);
591
592  is.read(buf16, 16);
593  data._proc_gain_param_1 = atof(buf16);
594
595  is.read(buf16, 16);
596  data._proc_gain_param_2 = atof(buf16);
597
598  is.read(buf16, 16);
599  data._proc_gain_param_3 = atof(buf16);
600
601  is.read(buf4, 4);
602  data._peak_loc_cross_correl_fun = atoi(buf4);
603
604  is.read(buf16, 16);
605  data._3_dB_width_CCF = atof(buf16);
606
607  is.read(buf16, 16);
608  data._first_side_lobe_level = atof(buf16);
609
610  is.read(buf16, 16);
611  data._ISLR_CCF_between_last = atof(buf16);
612
613  is.read(buf4, 4);
614  data._peak_loc_CCF_betw_last = atoi(buf4);
615
616  is.read(buf4, 4);
617  data._Roll_Tilt_Mode_flag = atoi(buf4);
618
619  is.read(buf4, 4);
620  data._raw_data_correction_flag = atoi(buf4);
621
622  is.read(buf4, 4);
623  data._look_detecion_flag = atoi(buf4);
624
625  is.read(buf4, 4);
626  data._doppler_ambiguity_estimat_flag = atoi(buf4);
627
628  is.read(buf4, 4);
629  data._azimuth_baseband_convers_flag = atoi(buf4);
630
631  is.read(buf4, 4);
632  data._samples_per_line_used = atoi(buf4);
633
634  is.read(buf4, 4);
635  data._range_lines_skip_factor = atoi(buf4);
636
637  is.read(buf24, 24);
638  data._time_of_inp_state_vectors = buf24;
639
640  is.read(buf22, 22);
641  data._inp_state_vect_pos_X_comp = buf22;
642
643  is.read(buf22, 22);
644  data._inp_state_vect_pos_Y_comp = buf22;
645
646  is.read(buf22, 22);
647  data._inp_state_vect_pos_Z_comp = buf22;
648
649  is.read(buf22, 22);
650  data._inp_state_vect_vel_Vx_comp = buf22;
651
652  is.read(buf22, 22);
653  data._inp_state_vect_vel_Vy_comp = buf22;
654
655  is.read(buf22, 22);
656  data._inp_state_vect_vel_Vz_comp = buf22;
657
658  is.read(buf4, 4);
659  data._inp_state_vector_type_flag = atoi(buf4);
660
661  is.read(buf16, 16);
662  data._win_coeff_for_range_match = atof(buf16);
663
664  is.read(buf16, 16);
665  data._win_coeff_for_azi_match = atof(buf16);
666
667  is.read(buf4, 4);
668  data._update_period_range_match = atoi(buf4);
669
670  is.read(buf16, 16);
671  data._look_scalar_gain_1 = atof(buf16);
672
673  is.read(buf16, 16);
674  data._look_scalar_gain_2 = atof(buf16);
675
676  is.read(buf16, 16);
677  data._look_scalar_gain_3 = atof(buf16);
678
679  is.read(buf16, 16);
680  data._look_scalar_gain_4 = atof(buf16);
681
682  is.read(buf16, 16);
683  data._look_scalar_gain_5 = atof(buf16);
684
685  is.read(buf16, 16);
686  data._look_scalar_gain_6 = atof(buf16);
687
688  is.read(buf16, 16);
689  data._look_scalar_gain_7 = atof(buf16);
690
691  is.read(buf16, 16);
692  data._look_scalar_gain_8 = atof(buf16);
693
694  is.read(buf4, 4);
695  data._samp_window_start_time_bias = atoi(buf4);
696
697  is.read(buf22, 22);
698  data._doppler_centroid_cubic_coeff = atof(buf22);
699
700  is.read(buf4, 4);
701  data._PRF_code_first_range_line = atoi(buf4);
702
703  is.read(buf4, 4);
704  data._PRF_code_last_range_line = atoi(buf4);
705
706  is.read(buf4, 4);
707  data._samp_win_start_first = atoi(buf4);
708
709  is.read(buf4, 4);
710  data._samp_win_start_last = atoi(buf4);
711
712  is.read(buf4, 4);
713  data._cal_syst_gain_last_proc = atoi(buf4);
714
715  is.read(buf4, 4);
716  data._receiver_gain_last_proc = atoi(buf4);
717
718  is.read(buf4, 4);
719  data._first_processed_range_sample = atoi(buf4);
720
721  is.read(buf4, 4);
722  data._azimuth_FFT_IFFT_ratio = atoi(buf4);
723
724  is.read(buf4, 4);
725  data._num_azimuth_blocks_proc = atoi(buf4);
726
727  is.read(buf8, 8);
728  data._num_input_raw_data_lines = atol(buf8);
729
730  is.read(buf4, 4);
731  data._initial_doppler_ambiguity_num = atoi(buf4);
732
733  is.read(buf16, 16);
734  data._thresh_no_1_flag = atof(buf16);
735
736  is.read(buf16, 16);
737  data._thresh_no_2_flag = atof(buf16);
738
739  is.read(buf16, 16);
740  data._thresh_no_3_flag = atof(buf16);
741
742  is.read(buf16, 16);
743  data._thresh_no_4_flag = atof(buf16);
744
745  is.read(buf16, 16);
746  data._thresh_no_5_flag = atof(buf16);
747
748  is.read(buf16, 16);
749  data._thresh_no_6_flag = atof(buf16);
750
751  is.read(buf16, 16);
752  data._thresh_no_7_flag = atof(buf16);
753
754  is.read(buf16, 16);
755  data._thresh_no_8_flag = atof(buf16);
756
757  is.read(buf16, 16);
758  data._thresh_no_9_flag = atof(buf16);
759
760  is.read(buf16, 16);
761  data._thresh_no_10_flag = atof(buf16);
762
763  is.read(buf16, 16);
764  data._thresh_no_11_flag = atof(buf16);
765
766  is.read(buf16, 16);
767  data._sat_binary_time_of_first = atol(buf16);
768
769  is.read(buf4, 4);
770  data._num_valid_pixels_per_range = atoi(buf4);
771
772  is.read(buf4, 4);
773  data._num_range_samp_discarded = atoi(buf4);
774
775  is.read(buf16, 16);
776  data._I_gain_imb_lower_bound = atof(buf16);
777
778  is.read(buf16, 16);
779  data._I_gain_imb_upper_bound = atof(buf16);
780
781  is.read(buf16, 16);
782  data._I_Q_quad_depar_lower_bound = atof(buf16);
783
784  is.read(buf16, 16);
785  data._I_Q_quad_depar_upper_bound = atof(buf16);
786
787  is.read(buf16, 16);
788  data._3_dB_look_bandwidth = atof(buf16);
789
790  is.read(buf16, 16);
791  data._3_dB_look_proc_dopp_bandw = atof(buf16);
792
793  is.read(buf4, 4);
794  data._range_spread_loss_comp_flag = atoi(buf4);
795
796  is.read(buf1, 1);
797  data._datation_flag = atoi(buf1) != 0;
798
799  is.read(buf7, 7);
800  data._max_error_range_line_timing = atoi(buf7);
801
802  is.read(buf7, 7);
803  data._form_num_range_line_used = atoi(buf7);
804
805  is.read(buf1, 1);
806  data._autom_look_scal_gain_flag = atoi(buf1) != 0;
807
808  is.read(buf4, 4);
809  data._max_value_look_scalar_gain = atoi(buf4);
810
811  is.read(buf4, 4);
812  data._replica_norm_method_flag = atoi(buf4);
813
814  is.read(buf20, 20);
815  data._coef_ground_range_1 = atof(buf20);
816
817  is.read(buf20, 20);
818  data._coef_ground_range_2 = atof(buf20);
819
820  is.read(buf20, 20);
821  data._coef_ground_range_3 = atof(buf20);
822
823  is.read(buf20, 20);
824  data._coef_ground_range_4 = atof(buf20);
825
826  is.read(buf20, 20);
827  data._coef_ant_elev_1 = atof(buf20);
828
829  is.read(buf20, 20);
830  data._coef_ant_elev_2 = atof(buf20);
831
832  is.read(buf20, 20);
833  data._coef_ant_elev_3 = atof(buf20);
834
835  is.read(buf20, 20);
836  data._coef_ant_elev_4 = atof(buf20);
837
838  is.read(buf20, 20);
839  data._coef_ant_elev_5 = atof(buf20);
840
841  is.read(buf16, 16);
842  data._range_time_origin_ant = atof(buf16);
843
844  char buf10238[10238];
845  is.read(buf10238, 10238);
846  return is;
847  }
◆ ossimSharedLibraryFinalize()
OSSIM_PLUGINS_DLL void ossimplugins::ossimSharedLibraryFinalize ( )
Definition at line 88 of file ossimPluginInit.cpp.
References ossimplugins::ossimPluginProjectionFactory::instance(), ossimProjectionFactoryRegistry::instance(), ossimplugins::ossimPluginReaderFactory::instance(), and ossimImageHandlerRegistry::instance().
89  {
91  unregisterFactory(ossimPluginReaderFactory::instance());
92
94  unregisterFactory(ossimPluginProjectionFactory::instance());
95  }
static ossimProjectionFactoryRegistry * instance()
static ossimImageHandlerRegistry * instance()
◆ ossimSharedLibraryInitialize()
OSSIM_PLUGINS_DLL void ossimplugins::ossimSharedLibraryInitialize ( ossimSharedObjectInfo **  info)
Register the readers...
Register the projection factory. Note that this must be pushed to the front of the factory or bilinear projection will be picked up.
Definition at line 61 of file ossimPluginInit.cpp.
References cnesDescription, cnesInfo, cnesObjList, ossimSharedObjectInfo::getClassName, getCnesClassName(), getCnesDescription(), getCnesNumberOfClassNames(), ossimSharedObjectInfo::getDescription, ossimSharedObjectInfo::getNumberOfClassNames, ossimplugins::ossimPluginProjectionFactory::getTypeNameList(), ossimplugins::ossimPluginReaderFactory::getTypeNameList(), ossimplugins::ossimPluginProjectionFactory::instance(), ossimProjectionFactoryRegistry::instance(), ossimplugins::ossimPluginReaderFactory::instance(), and ossimImageHandlerRegistry::instance().
63  {
67
68  *info = &cnesInfo;
69
72  registerFactory(ossimPluginReaderFactory::instance());
73
80  registerFactoryToFront(ossimPluginProjectionFactory::instance());
81
82  setCnesDescription(cnesDescription);
83  ossimPluginReaderFactory::instance()->getTypeNameList(cnesObjList);
84  ossimPluginProjectionFactory::instance()->getTypeNameList(cnesObjList);
85  }
const char * getCnesDescription()
ossimString cnesDescription
ossimSharedLibraryGetNumberOfClassNamesPtr getNumberOfClassNames
int getCnesNumberOfClassNames()
std::vector< ossimString > cnesObjList
ossimSharedLibraryGetDescriptionPtr getDescription
ossimSharedLibraryGetClassNamesPtr getClassName
ossimSharedObjectInfo cnesInfo
const char * getCnesClassName(int idx)
◆ RTTI_DEF1() [1/14]
ossimplugins::RTTI_DEF1 ( ossimCosmoSkymedModel  ,
"ossimCosmoSkymedModel"  ,
ossimGeometricSarSensorModel
◆ RTTI_DEF1() [2/14]
ossimplugins::RTTI_DEF1 ( ossimPluginReaderFactory  ,
"ossimPluginReaderFactory"  ,
ossimImageHandlerFactoryBase
◆ RTTI_DEF1() [3/14]
ossimplugins::RTTI_DEF1 ( ossimTileMapModel  ,
"ossimTileMapModel"  ,
ossimSensorModel
◆ RTTI_DEF1() [4/14]
ossimplugins::RTTI_DEF1 ( ossimFormosatModel  ,
"ossimFormosatModel"  ,
ossimSensorModel
◆ RTTI_DEF1() [5/14]
ossimplugins::RTTI_DEF1 ( ossimEnvisatAsarModel  ,
"ossimEnvisatAsarModel"  ,
◆ RTTI_DEF1() [6/14]
ossimplugins::RTTI_DEF1 ( ossimErsSarModel  ,
"ossimErsSarModel"  ,
◆ RTTI_DEF1() [7/14]
ossimplugins::RTTI_DEF1 ( ossimGeometricSarSensorModel  ,
"ossimGeometricSarSensorModel"  ,
ossimSensorModel
◆ RTTI_DEF1() [8/14]
ossimplugins::RTTI_DEF1 ( ossimAlosPalsarModel  ,
"ossimAlosPalsarModel"  ,
◆ RTTI_DEF1() [9/14]
ossimplugins::RTTI_DEF1 ( ossimRadarSatModel  ,
"ossimRadarSatModel"  ,
◆ RTTI_DEF1() [10/14]
ossimplugins::RTTI_DEF1 ( ossimRadarSat2Model  ,
"ossimRadarSat2Model"  ,
◆ RTTI_DEF1() [11/14]
ossimplugins::RTTI_DEF1 ( ossimRadarSat2RPCModel  ,
"ossimRadarSat2RPCModel"  ,
ossimRpcModel
◆ RTTI_DEF1() [12/14]
ossimplugins::RTTI_DEF1 ( ossimSpot6Model  ,
"ossimSpot6Model"  ,
ossimRpcModel
◆ RTTI_DEF1() [13/14]
ossimplugins::RTTI_DEF1 ( ossimPleiadesModel  ,
"ossimPleiadesModel"  ,
ossimRpcModel
◆ RTTI_DEF1() [14/14]
ossimplugins::RTTI_DEF1 ( ossimTerraSarModel  ,
"ossimTerraSarModel"  ,
◆ SwitchEndian()
void ossimplugins::SwitchEndian ( int &  value)
Definition at line 67 of file ProcessedDataRecord.cpp.
68  {
69  char buffer[4];
70  char res[4];
71
72  memcpy(buffer,&value,4);
73  res[0] = buffer[3];
74  res[1] = buffer[2];
75  res[2] = buffer[1];
76  res[3] = buffer[0];
77
78  memcpy(&value,res,4);
79  }
Variable Documentation
◆ _ds_name
std::string ossimplugins::_ds_name
Definition at line 124 of file dsd.cpp.
◆ _ds_offset
double ossimplugins::_ds_offset
Definition at line 127 of file dsd.cpp.
◆ _ds_size
double ossimplugins::_ds_size
Definition at line 128 of file dsd.cpp.
◆ _ds_type
std::string ossimplugins::_ds_type
Definition at line 125 of file dsd.cpp.
◆ _dsr_size
int ossimplugins::_dsr_size
Definition at line 130 of file dsd.cpp.
◆ _filename
std::string ossimplugins::_filename
Definition at line 126 of file dsd.cpp.
◆ _num_dsr
int ossimplugins::_num_dsr
Definition at line 129 of file dsd.cpp.
◆ cnesDescription
ossimString ossimplugins::cnesDescription
Definition at line 41 of file ossimPluginInit.cpp.
Referenced by getCnesDescription(), and ossimSharedLibraryInitialize().
◆ cnesInfo
ossimSharedObjectInfo ossimplugins::cnesInfo
Definition at line 40 of file ossimPluginInit.cpp.
Referenced by ossimSharedLibraryInitialize().
◆ cnesObjList
std::vector<ossimString> ossimplugins::cnesObjList
