Public Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::AlosPalsarRadiometricData Class Reference
This class is able to read a radiometric data record. More...
#include <AlosPalsarRadiometricData.h>
Inheritance diagram for ossimplugins::AlosPalsarRadiometricData:
ossimplugins::AlosPalsarRecord
 AlosPalsarRadiometricData ()
 Constructor. More...
virtual ~AlosPalsarRadiometricData ()
 Destructor. More...
 AlosPalsarRadiometricData (const AlosPalsarRadiometricData &rhs)
 Copy constructor. More...
AlosPalsarRadiometricDataoperator= (const AlosPalsarRadiometricData &rhs)
 Copy operator. More...
AlosPalsarRecordInstanciate ()
 This function is able to create a new instance of the class. More...
AlosPalsarRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Read the class data from a stream. More...
void Write (std::ostream &os)
 Write the class to a stream. More...
double get_calibration_factor () const
 Calibration factor. More...
- Public Member Functions inherited from ossimplugins::AlosPalsarRecord
 AlosPalsarRecord (std::string mnemonic)
virtual ~AlosPalsarRecord ()
 Destructor. More...
 AlosPalsarRecord (const AlosPalsarRecord &rhs)
std::string get_mnemonic ()
double _calibration_factor
 Data sampling interval. More...
- Protected Attributes inherited from ossimplugins::AlosPalsarRecord
std::string _mnemonic
Friends
std::ostream & operator<< (std::ostream &os, const AlosPalsarRadiometricData &data)
 This function writes the Alos Palsar radiometric data in a stream. More...
std::istream & operator>> (std::istream &is, AlosPalsarRadiometricData &data)
 This function reads Alos Palsar radiometric data from a stream. More...
Detailed Description
Definition at line 29 of file AlosPalsarRadiometricData.h.
◆ AlosPalsarRadiometricData() [1/2]
ossimplugins::AlosPalsarRadiometricData::AlosPalsarRadiometricData ( )
Constructor.
Definition at line 19 of file AlosPalsarRadiometricData.cpp.
Referenced by Clone(), and Instanciate().
19  : AlosPalsarRecord("radio_data_rec")
20 {
21 }
AlosPalsarRecord(std::string mnemonic)
Constructor.
◆ ~AlosPalsarRadiometricData()
ossimplugins::AlosPalsarRadiometricData::~AlosPalsarRadiometricData ( )
virtual
Destructor.
Definition at line 23 of file AlosPalsarRadiometricData.cpp.
24 {
25 }
◆ AlosPalsarRadiometricData() [2/2]
ossimplugins::AlosPalsarRadiometricData::AlosPalsarRadiometricData ( const AlosPalsarRadiometricData rhs)
Copy constructor.
Definition at line 50 of file AlosPalsarRadiometricData.cpp.
References _calibration_factor.
50  :
51  AlosPalsarRecord(rhs)
52 {
53  _calibration_factor = rhs._calibration_factor;
54 }
Constructor.
Member Function Documentation
◆ Clone()
AlosPalsarRecord* ossimplugins::AlosPalsarRadiometricData::Clone ( )
inlinevirtual
Implements ossimplugins::AlosPalsarRecord.
Definition at line 72 of file AlosPalsarRadiometricData.h.
References AlosPalsarRadiometricData().
73  {
74  return new AlosPalsarRadiometricData(*this);
75  };
◆ get_calibration_factor()
double ossimplugins::AlosPalsarRadiometricData::get_calibration_factor ( ) const
inline
Calibration factor.
Definition at line 96 of file AlosPalsarRadiometricData.h.
Referenced by ossimplugins::AlosPalsarLeader::saveState().
97  {
98  return _calibration_factor;
99  };
◆ Instanciate()
AlosPalsarRecord* ossimplugins::AlosPalsarRadiometricData::Instanciate ( )
inlinevirtual
Definition at line 64 of file AlosPalsarRadiometricData.h.
65  {
66  return new AlosPalsarRadiometricData();
67  };
◆ operator=()
AlosPalsarRadiometricData & ossimplugins::AlosPalsarRadiometricData::operator= ( const AlosPalsarRadiometricData rhs)
Copy operator.
Definition at line 56 of file AlosPalsarRadiometricData.cpp.
57 {
58  _calibration_factor = rhs._calibration_factor;
59
60  return *this;
61 }
◆ Read()
void ossimplugins::AlosPalsarRadiometricData::Read ( std::istream &  is)
inlinevirtual
Definition at line 80 of file AlosPalsarRadiometricData.h.
81  {
82  is >> *this;
83  };
◆ Write()
void ossimplugins::AlosPalsarRadiometricData::Write ( std::ostream &  os)
inlinevirtual
Definition at line 88 of file AlosPalsarRadiometricData.h.
89  {
90  os << *this;
91  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const AlosPalsarRadiometricData data
friend
Definition at line 27 of file AlosPalsarRadiometricData.cpp.
28 {
29  os << "calibration_factor:" << data._calibration_factor << std::endl;
30
31  return os;
32 }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 34 of file AlosPalsarRadiometricData.cpp.
35 {
36  char buf[9];
37
38  is.seekg(8, std::ios::cur);
39
40  is.read(buf, 8);
41  buf[8] = '\0';
42  data._calibration_factor = atof(buf);
43
44  is.seekg(9824, std::ios::cur); //skip the rest of the radiometric data record
45  is.seekg(12477692, std::ios::cur); //skip to the 11th facility-related data record
46
47  return is;
48 }
Member Data Documentation
◆ _calibration_factor
double ossimplugins::AlosPalsarRadiometricData::_calibration_factor
protected
