Public Member Functions | Public Attributes | Friends | List of all members
ossimplugins::AntennaElevationPatterns Class Reference
This class is able to read the ASAR AntennaElevationPatterns record. More...
#include <AntennaElevationPatterns.h>
Inheritance diagram for ossimplugins::AntennaElevationPatterns:
ossimplugins::EnvisatAsarRecord
 AntennaElevationPatterns ()
 Constructor. More...
virtual ~AntennaElevationPatterns ()
 Destructor. More...
 AntennaElevationPatterns (const AntennaElevationPatterns &rhs)
 Copy constructor. More...
AntennaElevationPatternsoperator= (const AntennaElevationPatterns &rhs)
 Copy operator. More...
EnvisatAsarRecordInstanciate ()
 This function is able to create a new instance of the class. More...
EnvisatAsarRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Reads the class data from a stream. More...
void Write (std::ostream &os)
 Writes the class to a stream. More...
std::string get_zero_doppler_time ()
 zero_doppler_time More...
bool get_attach_flag ()
 attach_flag More...
std::string get_swath ()
 swath More...
float * get_elevation_pattern ()
 Elevation Pattern. More...
- Public Member Functions inherited from ossimplugins::EnvisatAsarRecord
 EnvisatAsarRecord (std::string mnemonic)
virtual ~EnvisatAsarRecord ()
 Destructor. More...
 EnvisatAsarRecord (const EnvisatAsarRecord &rhs)
std::string get_mnemonic ()
 Returns the mnemonic of the record. More...
Public Attributes
std::string _zero_doppler_time
bool _attach_flag
 attach_flag More...
std::string _swath
 swath More...
float _elevation_pattern [33]
Friends
std::ostream & operator<< (std::ostream &os, const AntennaElevationPatterns &data)
 This function writes the AntennaElevationPatterns in a stream. More...
std::istream & operator>> (std::istream &is, AntennaElevationPatterns &data)
 This function reads a AntennaElevationPatterns from a stream. More...
Additional Inherited Members
- Protected Member Functions inherited from ossimplugins::EnvisatAsarRecord
template<typename T >
void SwitchEndian (T &value)
 This function switches the LSB value and the MSB value of the parameter. More...
- Protected Attributes inherited from ossimplugins::EnvisatAsarRecord
std::string _mnemonic
Detailed Description
Definition at line 25 of file AntennaElevationPatterns.h.
◆ AntennaElevationPatterns() [1/2]
ossimplugins::AntennaElevationPatterns::AntennaElevationPatterns ( )
Constructor.
Definition at line 16 of file AntennaElevationPatterns.cpp.
Referenced by Clone(), and Instanciate().
16  : EnvisatAsarRecord("AntennaElevationPatterns_rec")
17  {
18  }
EnvisatAsarRecord(std::string mnemonic)
Constructor.
◆ ~AntennaElevationPatterns()
ossimplugins::AntennaElevationPatterns::~AntennaElevationPatterns ( )
virtual
Destructor.
Definition at line 20 of file AntennaElevationPatterns.cpp.
21  {
22  }
◆ AntennaElevationPatterns() [2/2]
ossimplugins::AntennaElevationPatterns::AntennaElevationPatterns ( const AntennaElevationPatterns rhs)
Copy constructor.
Definition at line 72 of file AntennaElevationPatterns.cpp.
References _elevation_pattern.
72  :
73  EnvisatAsarRecord(rhs),
74  _zero_doppler_time(rhs._zero_doppler_time),
75  _attach_flag(rhs._attach_flag),
76  _swath(rhs._swath)
77  {
78  for (int i = 0; i<33; i++) {
79  _elevation_pattern[i] = rhs._elevation_pattern[i];
80  }
81  }
zero_doppler_time
float _elevation_pattern[33]
Elevation Pattern.
Constructor.
Member Function Documentation
◆ Clone()
EnvisatAsarRecord* ossimplugins::AntennaElevationPatterns::Clone ( )
inlinevirtual
Implements ossimplugins::EnvisatAsarRecord.
Definition at line 69 of file AntennaElevationPatterns.h.
References AntennaElevationPatterns().
70  {
71  return new AntennaElevationPatterns(*this);
72  };
◆ get_attach_flag()
bool ossimplugins::AntennaElevationPatterns::get_attach_flag ( )
inline
attach_flag
Definition at line 101 of file AntennaElevationPatterns.h.
References _attach_flag.
102  {
103  return _attach_flag;
104  };
◆ get_elevation_pattern()
float* ossimplugins::AntennaElevationPatterns::get_elevation_pattern ( )
inline
Elevation Pattern.
Definition at line 115 of file AntennaElevationPatterns.h.
116  {
117  return _elevation_pattern;
118  };
Elevation Pattern.
◆ get_swath()
std::string ossimplugins::AntennaElevationPatterns::get_swath ( )
inline
swath
Definition at line 108 of file AntennaElevationPatterns.h.
References _swath.
109  {
110  return _swath;
111  };
◆ get_zero_doppler_time()
std::string ossimplugins::AntennaElevationPatterns::get_zero_doppler_time ( )
inline
zero_doppler_time
Definition at line 94 of file AntennaElevationPatterns.h.
References _zero_doppler_time.
95  {
96  return _zero_doppler_time;
97  };
zero_doppler_time
◆ Instanciate()
EnvisatAsarRecord* ossimplugins::AntennaElevationPatterns::Instanciate ( )
inlinevirtual
Definition at line 61 of file AntennaElevationPatterns.h.
62  {
63  return new AntennaElevationPatterns();
64  };
◆ operator=()
AntennaElevationPatterns & ossimplugins::AntennaElevationPatterns::operator= ( const AntennaElevationPatterns rhs)
Copy operator.
Definition at line 84 of file AntennaElevationPatterns.cpp.
References _attach_flag, _elevation_pattern, _swath, and _zero_doppler_time.
85  {
86  _zero_doppler_time = rhs._zero_doppler_time;
87  _attach_flag = rhs._attach_flag;
88  _swath = rhs._swath;
89
90  for (int i = 0; i<33; i++) {
91  _elevation_pattern[i] = rhs._elevation_pattern[i];
92  }
93
94  return *this;
95  }
zero_doppler_time
Elevation Pattern.
◆ Read()
void ossimplugins::AntennaElevationPatterns::Read ( std::istream &  is)
inlinevirtual
Definition at line 77 of file AntennaElevationPatterns.h.
78  {
79  is>>*this;
80  };
◆ Write()
void ossimplugins::AntennaElevationPatterns::Write ( std::ostream &  os)
inlinevirtual
Definition at line 85 of file AntennaElevationPatterns.h.
86  {
87  os<<*this;
88  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const AntennaElevationPatterns data
friend
Definition at line 25 of file AntennaElevationPatterns.cpp.
26  {
27  os<<"zero_doppler_time:"<<data._zero_doppler_time.c_str()<<std::endl;
28
29  os<<"attach_flag:"<<data._attach_flag<<std::endl;
30
31  os<<"swath:"<<data._swath.c_str()<<std::endl;
32
33  for (int i = 0; i<33; i++) {
34  os<<"elevation pattern:"<<data._elevation_pattern[i]<<std::endl;
35  }
36
37  return os;
38
39  }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 41 of file AntennaElevationPatterns.cpp.
42  {
43  char buf16[17];
44  buf16[16]='\0';
45  char buf12[13];
46  buf12[12] = '\0';
47  char buf3[4];
48  buf3[3] = '\0';
49  // char buf2[3];
50  // buf2[2] = '\0';
51 // char buf1[1]; // avoid not used warning
52
53  is.read(buf12,12);
54  data._zero_doppler_time = buf12;
55
56  is.read((char*)&(data._attach_flag),1);
57
58  is.read(buf3,3);
59  data._swath = buf3;
60
61  for (int i = 0; i<33; i++) {
62  is.read((char*)&(data._elevation_pattern[i]),4);
63  data.SwitchEndian(data._elevation_pattern[i]);
64  }
65
66  is.read(buf16,14);
67
68  return is;
69
70  }
Member Data Documentation
◆ _attach_flag
bool ossimplugins::AntennaElevationPatterns::_attach_flag
◆ _elevation_pattern
float ossimplugins::AntennaElevationPatterns::_elevation_pattern[33]
◆ _swath
std::string ossimplugins::AntennaElevationPatterns::_swath
◆ _zero_doppler_time
std::string ossimplugins::AntennaElevationPatterns::_zero_doppler_time
