This class is a factory able to construct Record base classes given the id of the record wanted. More...
#include <EnvisatAsarRecordFactory.h>
EnvisatAsarRecordFactory () | |
Constructor. More... | |
~EnvisatAsarRecordFactory () | |
Destructor. More... | |
void | RegisterRecord (std::string id, EnvisatAsarRecord *record) |
Adds a new Record type available in this factory. More... | |
EnvisatAsarRecord * | Instanciate (std::string id) |
Instanciatse a new Record. More... | |
Protected Attributes | |
std::map< std::string, EnvisatAsarRecord * > | _availableRecords |
Contains all the available Records for the factory. More... | |
Definition at line 26 of file EnvisatAsarRecordFactory.h.
ossimplugins::EnvisatAsarRecordFactory::EnvisatAsarRecordFactory | ( | ) |
ossimplugins::EnvisatAsarRecordFactory::~EnvisatAsarRecordFactory | ( | ) |
EnvisatAsarRecord * ossimplugins::EnvisatAsarRecordFactory::Instanciate | ( | std::string | id | ) |
id | Id of the Record we want to instanciate |
Definition at line 24 of file EnvisatAsarRecordFactory.cpp.
References _availableRecords, and ossimplugins::EnvisatAsarRecord::Instanciate().
Referenced by ossimplugins::operator>>().
void ossimplugins::EnvisatAsarRecordFactory::RegisterRecord | ( | std::string | id, |
EnvisatAsarRecord * | record | ||
record | Record to add in the factory |
id | Id of the new avalaible Record |
Definition at line 37 of file EnvisatAsarRecordFactory.cpp.
References _availableRecords.
Referenced by ossimplugins::EnvisatAsarDataFactory::EnvisatAsarDataFactory().
protected |
Definition at line 55 of file EnvisatAsarRecordFactory.h.
Referenced by Instanciate(), and RegisterRecord().
