Public Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::ErsSarMapProjectionData Class Reference
This class is able to read the SAR leader data set summary record of the leader file. More...
#include <ErsSarMapProjectionData.h>
Inheritance diagram for ossimplugins::ErsSarMapProjectionData:
ossimplugins::ErsSarRecord
 ErsSarMapProjectionData ()
 Constructor. More...
virtual ~ErsSarMapProjectionData ()
 Destructor. More...
 ErsSarMapProjectionData (const ErsSarMapProjectionData &rhs)
 Copy constructor. More...
ErsSarMapProjectionDataoperator= (const ErsSarMapProjectionData &rhs)
 Copy operator. More...
ErsSarRecordInstanciate ()
 This function is able to create a new instance of the class. More...
ErsSarRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Read the class data from a stream. More...
void Write (std::ostream &os)
 Write the class to a stream. More...
std::string get_map_proj_des () const
 map_proj_des More...
int get_num_pix_in_line () const
 num_pix_in_line More...
int get_num_lines () const
 num_lines More...
double get_nom_interpixel_dist () const
 nom_interpixel_dist More...
double get_nom_interline_dist () const
 nom_interline_dist More...
double get_orientation_at_center () const
 orientation_at_center More...
double get_orbit_incl () const
 orbit_incl More...
double get_asc_node_long () const
 asc_node_long More...
double get_platform_heading () const
 platform_heading More...
std::string get_name_of_ref_ellipsoid () const
 name_of_ref_ellipsoid More...
double get_semi_maj_axis () const
 semi_maj_axis More...
double get_semi_min_axis () const
 semi_min_axis More...
double get_first_line_first_pixel_lat () const
 first_line_first_pixel _lat More...
double get_first_line_first_pixel_lon () const
 first_line_first_pixel_lon More...
double get_first_line_last_pixel_lat () const
 first_line_last_pixel _lat More...
double get_first_line_last_pixel_lon () const
 first_line_last_pixel_lon More...
double get_last_line_last_pixel_lat () const
 last_line_last_pixel_lat More...
double get_last_line_last_pixel_lon () const
 last_line_last_pixel_lon More...
double get_last_line_first_pixel_lat () const
 last_line_first_pixel_lat More...
double get_last_line_first_pixel_lon () const
 last_line_first_pixel_lon More...
- Public Member Functions inherited from ossimplugins::ErsSarRecord
 ErsSarRecord (std::string mnemonic)
virtual ~ErsSarRecord ()
 Destructor. More...
 ErsSarRecord (const ErsSarRecord &rhs)
std::string get_mnemonic ()
std::string _map_proj_des
int _num_pix_in_line
int _num_lines
 num_lines More...
double _nom_interpixel_dist
double _nom_interline_dist
double _orientation_at_center
double _orbit_incl
 orbit_incl More...
double _asc_node_long
double _platform_heading
std::string _name_of_ref_ellipsoid
double _semi_maj_axis
double _semi_min_axis
double _first_line_first_pixel_lat
 first_line_first_pixel_lat More...
double _first_line_first_pixel_lon
double _first_line_last_pixel_lat
 first_line_last_pixel_lat More...
double _first_line_last_pixel_lon
double _last_line_last_pixel_lat
double _last_line_last_pixel_lon
double _last_line_first_pixel_lat
double _last_line_first_pixel_lon
- Protected Attributes inherited from ossimplugins::ErsSarRecord
std::string _mnemonic
Friends
std::ostream & operator<< (std::ostream &os, const ErsSarMapProjectionData &data)
 This function write the ErsSarMapProjectionData in a stream. More...
std::istream & operator>> (std::istream &is, ErsSarMapProjectionData &data)
 This function read a ErsSarMapProjectionData from a stream. More...
Detailed Description
Definition at line 29 of file ErsSarMapProjectionData.h.
◆ ErsSarMapProjectionData() [1/2]
ossimplugins::ErsSarMapProjectionData::ErsSarMapProjectionData ( )
Constructor.
Definition at line 17 of file ErsSarMapProjectionData.cpp.
Referenced by Clone(), and Instanciate().
17  : ErsSarRecord("map_proj_data_rec")
18  {
19  }
ErsSarRecord(std::string mnemonic)
Constructor.
◆ ~ErsSarMapProjectionData()
ossimplugins::ErsSarMapProjectionData::~ErsSarMapProjectionData ( )
virtual
Destructor.
Definition at line 21 of file ErsSarMapProjectionData.cpp.
22  {
23  }
◆ ErsSarMapProjectionData() [2/2]
ossimplugins::ErsSarMapProjectionData::ErsSarMapProjectionData ( const ErsSarMapProjectionData rhs)
Copy constructor.
Definition at line 160 of file ErsSarMapProjectionData.cpp.
160  :
161  ErsSarRecord(rhs),
162  _map_proj_des(rhs._map_proj_des),
163  _num_pix_in_line(rhs._num_pix_in_line),
164  _num_lines(rhs._num_lines),
165  _nom_interpixel_dist(rhs._nom_interpixel_dist),
166  _nom_interline_dist(rhs._nom_interline_dist),
167  _orientation_at_center(rhs._orientation_at_center),
168  _orbit_incl(rhs._orbit_incl),
169  _asc_node_long(rhs._asc_node_long),
170  _platform_heading(rhs._platform_heading),
171  _name_of_ref_ellipsoid(rhs._name_of_ref_ellipsoid),
172  _semi_maj_axis(rhs._semi_maj_axis),
173  _semi_min_axis(rhs._semi_min_axis),
174  _first_line_first_pixel_lat(rhs._first_line_first_pixel_lat),
175  _first_line_first_pixel_lon(rhs._first_line_first_pixel_lon),
176  _first_line_last_pixel_lat(rhs._first_line_last_pixel_lat),
177  _first_line_last_pixel_lon(rhs._first_line_last_pixel_lon),
178  _last_line_last_pixel_lat(rhs._last_line_last_pixel_lat),
179  _last_line_last_pixel_lon(rhs._last_line_last_pixel_lon),
180  _last_line_first_pixel_lat(rhs._last_line_first_pixel_lat),
181  _last_line_first_pixel_lon(rhs._last_line_first_pixel_lon)
182  {}
Constructor.
nom_interpixel_dist
Member Function Documentation
◆ Clone()
ErsSarRecord* ossimplugins::ErsSarMapProjectionData::Clone ( )
inlinevirtual
Implements ossimplugins::ErsSarRecord.
Definition at line 73 of file ErsSarMapProjectionData.h.
References ErsSarMapProjectionData().
74  {
75  return new ErsSarMapProjectionData(*this);
76  };
◆ get_asc_node_long()
double ossimplugins::ErsSarMapProjectionData::get_asc_node_long ( ) const
inline
asc_node_long
Definition at line 146 of file ErsSarMapProjectionData.h.
References _asc_node_long.
147  {
148  return _asc_node_long;
149  };
◆ get_first_line_first_pixel_lat()
double ossimplugins::ErsSarMapProjectionData::get_first_line_first_pixel_lat ( ) const
inline
Definition at line 181 of file ErsSarMapProjectionData.h.
References _first_line_first_pixel_lat.
Referenced by ossimplugins::ErsSarLeader::saveState().
182  {
184  };
◆ get_first_line_first_pixel_lon()
double ossimplugins::ErsSarMapProjectionData::get_first_line_first_pixel_lon ( ) const
inline
Definition at line 188 of file ErsSarMapProjectionData.h.
References _first_line_first_pixel_lon.
189  {
191  };
◆ get_first_line_last_pixel_lat()
double ossimplugins::ErsSarMapProjectionData::get_first_line_last_pixel_lat ( ) const
inline
Definition at line 195 of file ErsSarMapProjectionData.h.
References _first_line_last_pixel_lat.
196  {
198  };
◆ get_first_line_last_pixel_lon()
double ossimplugins::ErsSarMapProjectionData::get_first_line_last_pixel_lon ( ) const
inline
Definition at line 202 of file ErsSarMapProjectionData.h.
References _first_line_last_pixel_lon.
203  {
205  };
◆ get_last_line_first_pixel_lat()
double ossimplugins::ErsSarMapProjectionData::get_last_line_first_pixel_lat ( ) const
inline
Definition at line 223 of file ErsSarMapProjectionData.h.
References _last_line_first_pixel_lat.
224  {
226  };
◆ get_last_line_first_pixel_lon()
double ossimplugins::ErsSarMapProjectionData::get_last_line_first_pixel_lon ( ) const
inline
Definition at line 230 of file ErsSarMapProjectionData.h.
References _last_line_first_pixel_lon.
231  {
233  };
◆ get_last_line_last_pixel_lat()
double ossimplugins::ErsSarMapProjectionData::get_last_line_last_pixel_lat ( ) const
inline
Definition at line 209 of file ErsSarMapProjectionData.h.
References _last_line_last_pixel_lat.
210  {
212  };
◆ get_last_line_last_pixel_lon()
double ossimplugins::ErsSarMapProjectionData::get_last_line_last_pixel_lon ( ) const
inline
Definition at line 216 of file ErsSarMapProjectionData.h.
References _last_line_last_pixel_lon.
217  {
219  };
◆ get_map_proj_des()
std::string ossimplugins::ErsSarMapProjectionData::get_map_proj_des ( ) const
inline
map_proj_des
Definition at line 97 of file ErsSarMapProjectionData.h.
References _map_proj_des.
98  {
99  return _map_proj_des;
100  };
◆ get_name_of_ref_ellipsoid()
std::string ossimplugins::ErsSarMapProjectionData::get_name_of_ref_ellipsoid ( ) const
inline
Definition at line 160 of file ErsSarMapProjectionData.h.
References _name_of_ref_ellipsoid.
161  {
162  return _name_of_ref_ellipsoid;
163  };
◆ get_nom_interline_dist()
double ossimplugins::ErsSarMapProjectionData::get_nom_interline_dist ( ) const
inline
nom_interline_dist
Definition at line 125 of file ErsSarMapProjectionData.h.
References _nom_interline_dist.
126  {
127  return _nom_interline_dist;
128  };
◆ get_nom_interpixel_dist()
double ossimplugins::ErsSarMapProjectionData::get_nom_interpixel_dist ( ) const
inline
nom_interpixel_dist
Definition at line 118 of file ErsSarMapProjectionData.h.
References _nom_interpixel_dist.
119  {
120  return _nom_interpixel_dist;
121  };
nom_interpixel_dist
◆ get_num_lines()
int ossimplugins::ErsSarMapProjectionData::get_num_lines ( ) const
inline
num_lines
Definition at line 111 of file ErsSarMapProjectionData.h.
References _num_lines.
112  {
113  return _num_lines;
114  };
◆ get_num_pix_in_line()
int ossimplugins::ErsSarMapProjectionData::get_num_pix_in_line ( ) const
inline
num_pix_in_line
Definition at line 104 of file ErsSarMapProjectionData.h.
References _num_pix_in_line.
105  {
106  return _num_pix_in_line;
107  };
◆ get_orbit_incl()
double ossimplugins::ErsSarMapProjectionData::get_orbit_incl ( ) const
inline
orbit_incl
Definition at line 139 of file ErsSarMapProjectionData.h.
References _orbit_incl.
140  {
141  return _orbit_incl;
142  };
◆ get_orientation_at_center()
double ossimplugins::ErsSarMapProjectionData::get_orientation_at_center ( ) const
inline
Definition at line 132 of file ErsSarMapProjectionData.h.
References _orientation_at_center.
133  {
134  return _orientation_at_center;
135  };
◆ get_platform_heading()
double ossimplugins::ErsSarMapProjectionData::get_platform_heading ( ) const
inline
platform_heading
Definition at line 153 of file ErsSarMapProjectionData.h.
References _platform_heading.
154  {
155  return _platform_heading;
156  };
◆ get_semi_maj_axis()
double ossimplugins::ErsSarMapProjectionData::get_semi_maj_axis ( ) const
inline
semi_maj_axis
Definition at line 167 of file ErsSarMapProjectionData.h.
References _semi_maj_axis.
168  {
169  return _semi_maj_axis;
170  };
◆ get_semi_min_axis()
double ossimplugins::ErsSarMapProjectionData::get_semi_min_axis ( ) const
inline
semi_min_axis
Definition at line 174 of file ErsSarMapProjectionData.h.
References _semi_min_axis.
175  {
176  return _semi_min_axis;
177  };
◆ Instanciate()
ErsSarRecord* ossimplugins::ErsSarMapProjectionData::Instanciate ( )
inlinevirtual
Definition at line 65 of file ErsSarMapProjectionData.h.
66  {
67  return new ErsSarMapProjectionData();
68  };
◆ operator=()
ErsSarMapProjectionData & ossimplugins::ErsSarMapProjectionData::operator= ( const ErsSarMapProjectionData rhs)
Copy operator.
Definition at line 184 of file ErsSarMapProjectionData.cpp.
References _asc_node_long, _first_line_first_pixel_lat, _first_line_first_pixel_lon, _first_line_last_pixel_lat, _first_line_last_pixel_lon, _last_line_first_pixel_lat, _last_line_first_pixel_lon, _last_line_last_pixel_lat, _last_line_last_pixel_lon, _map_proj_des, _name_of_ref_ellipsoid, _nom_interline_dist, _nom_interpixel_dist, _num_lines, _num_pix_in_line, _orbit_incl, _orientation_at_center, _platform_heading, _semi_maj_axis, and _semi_min_axis.
185  {
186  _map_proj_des = rhs._map_proj_des;
187  _num_pix_in_line = rhs._num_pix_in_line;
188  _num_lines = rhs._num_lines;
189  _nom_interpixel_dist = rhs._nom_interpixel_dist;
190  _nom_interline_dist = rhs._nom_interline_dist;
191  _orientation_at_center = rhs._orientation_at_center;
192  _orbit_incl = rhs._orbit_incl;
193  _asc_node_long = rhs._asc_node_long;
194  _platform_heading = rhs._platform_heading;
195  _name_of_ref_ellipsoid = rhs._name_of_ref_ellipsoid;
196  _semi_maj_axis = rhs._semi_maj_axis;
197  _semi_min_axis = rhs._semi_min_axis;
198  _first_line_first_pixel_lat = rhs._first_line_first_pixel_lat;
199  _first_line_first_pixel_lon = rhs._first_line_first_pixel_lon;
200  _first_line_last_pixel_lat = rhs._first_line_last_pixel_lat;
201  _first_line_last_pixel_lon = rhs._first_line_last_pixel_lon;
202  _last_line_last_pixel_lat = rhs._last_line_last_pixel_lat;
203  _last_line_last_pixel_lon = rhs._last_line_last_pixel_lon;
204  _last_line_first_pixel_lat = rhs._last_line_first_pixel_lat;
205  _last_line_first_pixel_lon = rhs._last_line_first_pixel_lon;
206
207  return *this;
208  }
nom_interpixel_dist
◆ Read()
void ossimplugins::ErsSarMapProjectionData::Read ( std::istream &  is)
inlinevirtual
Definition at line 81 of file ErsSarMapProjectionData.h.
82  {
83  is >> *this;
84  };
◆ Write()
void ossimplugins::ErsSarMapProjectionData::Write ( std::ostream &  os)
inlinevirtual
Definition at line 89 of file ErsSarMapProjectionData.h.
90  {
91  os << *this;
92  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const ErsSarMapProjectionData data
friend
Definition at line 25 of file ErsSarMapProjectionData.cpp.
26  {
27  os << "map_proj_des:" << data._map_proj_des.c_str() << std::endl;
28
29  os << "num_pix_in_line:" << data._num_pix_in_line << std::endl;
30
31  os << "num_lines:" << data._num_lines << std::endl;
32
33  os << "nom_interpixel_dist:" << data._nom_interpixel_dist << std::endl;
34
35  os << "nom_interline_dist:" << data._nom_interline_dist << std::endl;
36
37  os << "orientation_at_center:" << data._orientation_at_center << std::endl;
38
39  os << "orbit_incl:" << data._orbit_incl << std::endl;
40
41  os << "asc_node_long:" << data._asc_node_long << std::endl;
42
43  os << "platform_heading:" << data._platform_heading << std::endl;
44
45  os << "name_of_ref_ellipsoid:" << data._name_of_ref_ellipsoid.c_str() << std::endl;
46
47  os << "semi_maj_axis:" << data._semi_maj_axis << std::endl;
48
49  os << "semi_min_axis:" << data._semi_min_axis << std::endl;
50
51  os << "first_line_first_pixel_lat:" << data._first_line_first_pixel_lat << std::endl;
52
53  os << "first_line_first_pixel_lon:" << data._first_line_first_pixel_lon << std::endl;
54
55  os << "first_line_last_pixel_lat:" << data._first_line_last_pixel_lat << std::endl;
56
57  os << "first_line_last_pixel_lon:" << data._first_line_last_pixel_lon << std::endl;
58
59  os << "last_line_last_pixel_lat:" << data._last_line_last_pixel_lat << std::endl;
60
61  os << "last_line_last_pixel_lon:" << data._last_line_last_pixel_lon << std::endl;
62
63  os << "last_line_first_pixel_lat:" << data._last_line_first_pixel_lat << std::endl;
64
65  os << "last_line_first_pixel_lon:" << data._last_line_first_pixel_lon << std::endl;
66
67  return os;
68
69  }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 71 of file ErsSarMapProjectionData.cpp.
72  {
73  char buf16[17];
74  buf16[16] = '\0';
75  char buf32[33];
76  buf32[32] = '\0';
77  // char buf8[9];
78  // buf8[8] = '\0';
79  // char buf4[5];
80  // buf4[4] = '\0';
81
82  is.read(buf16, 16);
83
84  is.read(buf32, 32);
85  data._map_proj_des = buf32;
86
87  is.read(buf16, 16);
88  data._num_pix_in_line = atoi(buf16);
89
90  is.read(buf16, 16);
91  data._num_lines = atoi(buf16);
92
93  is.read(buf16, 16);
94  data._nom_interpixel_dist = atof(buf16);
95
96  is.read(buf16, 16);
97  data._nom_interline_dist = atof(buf16);
98
99  is.read(buf16, 16);
100  data._orientation_at_center = atof(buf16);
101
102  is.read(buf16, 16);
103  data._orbit_incl = atof(buf16);
104
105  is.read(buf16, 16);
106  data._asc_node_long = atof(buf16);
107
108  is.read(buf16, 16);
109
110  is.read(buf16, 16);
111
112  is.read(buf16, 16);
113
114  is.read(buf16, 16);
115  data._platform_heading = atof(buf16);
116
117  is.read(buf32, 32);
118  data._name_of_ref_ellipsoid = buf32;
119
120  is.read(buf16, 16);
121  data._semi_maj_axis = atof(buf16);
122
123  is.read(buf16, 16);
124  data._semi_min_axis = atof(buf16);
125
126  char buf772[772];
127  is.read(buf772, 772);
128
129  is.read(buf16, 16);
130  data._first_line_first_pixel_lat = atof(buf16);
131
132  is.read(buf16, 16);
133  data._first_line_first_pixel_lon = atof(buf16);
134
135  is.read(buf16, 16);
136  data._first_line_last_pixel_lat = atof(buf16);
137
138  is.read(buf16, 16);
139  data._first_line_last_pixel_lon = atof(buf16);
140
141  is.read(buf16, 16);
142  data._last_line_last_pixel_lat = atof(buf16);
143
144  is.read(buf16, 16);
145  data._last_line_last_pixel_lon = atof(buf16);
146
147  is.read(buf16, 16);
148  data._last_line_first_pixel_lat = atof(buf16);
149
150  is.read(buf16, 16);
151  data._last_line_first_pixel_lon = atof(buf16);
152
153  char buf420[420];
154  is.read(buf420, 420);
155
156  return is;
157  }
Member Data Documentation
◆ _asc_node_long
double ossimplugins::ErsSarMapProjectionData::_asc_node_long
protected
◆ _first_line_first_pixel_lat
double ossimplugins::ErsSarMapProjectionData::_first_line_first_pixel_lat
protected
Definition at line 287 of file ErsSarMapProjectionData.h.
Referenced by get_first_line_first_pixel_lat(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_line_first_pixel_lon
double ossimplugins::ErsSarMapProjectionData::_first_line_first_pixel_lon
protected
Definition at line 291 of file ErsSarMapProjectionData.h.
Referenced by get_first_line_first_pixel_lon(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_line_last_pixel_lat
double ossimplugins::ErsSarMapProjectionData::_first_line_last_pixel_lat
protected
Definition at line 295 of file ErsSarMapProjectionData.h.
Referenced by get_first_line_last_pixel_lat(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_line_last_pixel_lon
double ossimplugins::ErsSarMapProjectionData::_first_line_last_pixel_lon
protected
Definition at line 299 of file ErsSarMapProjectionData.h.
Referenced by get_first_line_last_pixel_lon(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _last_line_first_pixel_lat
double ossimplugins::ErsSarMapProjectionData::_last_line_first_pixel_lat
protected
Definition at line 311 of file ErsSarMapProjectionData.h.
Referenced by get_last_line_first_pixel_lat(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _last_line_first_pixel_lon
double ossimplugins::ErsSarMapProjectionData::_last_line_first_pixel_lon
protected
Definition at line 315 of file ErsSarMapProjectionData.h.
Referenced by get_last_line_first_pixel_lon(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _last_line_last_pixel_lat
double ossimplugins::ErsSarMapProjectionData::_last_line_last_pixel_lat
protected
Definition at line 303 of file ErsSarMapProjectionData.h.
Referenced by get_last_line_last_pixel_lat(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _last_line_last_pixel_lon
double ossimplugins::ErsSarMapProjectionData::_last_line_last_pixel_lon
protected
Definition at line 307 of file ErsSarMapProjectionData.h.
Referenced by get_last_line_last_pixel_lon(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _map_proj_des
std::string ossimplugins::ErsSarMapProjectionData::_map_proj_des
protected
◆ _name_of_ref_ellipsoid
std::string ossimplugins::ErsSarMapProjectionData::_name_of_ref_ellipsoid
protected
Definition at line 275 of file ErsSarMapProjectionData.h.
Referenced by get_name_of_ref_ellipsoid(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _nom_interline_dist
double ossimplugins::ErsSarMapProjectionData::_nom_interline_dist
protected
◆ _nom_interpixel_dist
double ossimplugins::ErsSarMapProjectionData::_nom_interpixel_dist
protected
◆ _num_lines
int ossimplugins::ErsSarMapProjectionData::_num_lines
protected
◆ _num_pix_in_line
int ossimplugins::ErsSarMapProjectionData::_num_pix_in_line
protected
◆ _orbit_incl
double ossimplugins::ErsSarMapProjectionData::_orbit_incl
protected
◆ _orientation_at_center
double ossimplugins::ErsSarMapProjectionData::_orientation_at_center
protected
Definition at line 259 of file ErsSarMapProjectionData.h.
Referenced by get_orientation_at_center(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _platform_heading
double ossimplugins::ErsSarMapProjectionData::_platform_heading
protected
◆ _semi_maj_axis
double ossimplugins::ErsSarMapProjectionData::_semi_maj_axis
protected
◆ _semi_min_axis
double ossimplugins::ErsSarMapProjectionData::_semi_min_axis
protected
