Public Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::ProcessingParameters Class Reference
This class is able to read a Detailed processing parameters record. More...
#include <ProcessingParameters.h>
Inheritance diagram for ossimplugins::ProcessingParameters:
ossimplugins::RadarSatRecord
 ProcessingParameters ()
 Constructor. More...
 ~ProcessingParameters ()
 Destructor. More...
 ProcessingParameters (const ProcessingParameters &rhs)
 Copy constructor. More...
ProcessingParametersoperator= (const ProcessingParameters &rhs)
 Copy operator. More...
RadarSatRecordInstanciate ()
 This function is able to create a new instance of the class. More...
RadarSatRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Reads the class data from a stream. More...
void Write (std::ostream &os)
 Writes the class to a stream. More...
int get_rec_seq ()
 Record sequence number. More...
std::string get_inp_media ()
Input media More...
int get_n_tape_id ()
Number of tape input ids More...
std::string * get_tape_id ()
Tape identifiers More...
std::string get_exp_ing_start ()
Expected ingest start time More...
std::string get_exp_ing_stop ()
Expected ingest stop time More...
std::string get_act_ing_start ()
Actual ingest start time More...
std::string get_act_ing_stop ()
Actual ingest stop time More...
std::string get_proc_start ()
Processing start time More...
std::string get_proc_stop ()
Processing stop time More...
double * get_mn_sig_lev ()
Mean signal levels across range More...
int get_scr_data_ind ()
Source data quality indicator More...
int get_miss_ln ()
Number of missing lines More...
int get_rej_ln ()
Number of rejected lines More...
int get_large_gap ()
Number of time inconsistencies (large gaps) More...
double get_bit_err_rate ()
Measured bit error rate More...
double get_fm_crc_err ()
Percent of frames with CRC errors More...
int get_date_incons ()
Number of date inconsistencies More...
int get_prf_changes ()
Number of unexpected PRF changes More...
int get_delay_changes ()
Number of delay changes More...
int get_skipd_frams ()
Number of skipped frames More...
int get_rej_bf_start ()
Range lines rejected before start time More...
int get_rej_few_fram ()
Range lines rejected due to too few frames More...
int get_rej_many_fram ()
Range lines rejected due to too many frames More...
int get_rej_mchn_err ()
Frames rejected due to master channel error More...
int get_rej_vchn_err ()
Frames rejected due to virtual channel error More...
int get_rej_rec_type ()
Frames rejected due to incorrect recording type More...
std::string get_sens_config ()
Sensor configuration More...
std::string get_sens_orient ()
Sensor orientation More...
std::string get_sych_marker ()
Frame synch marker More...
std::string get_rng_ref_src ()
Range reference function source More...
double * get_rng_amp_coef ()
Range reference amplitude coefficients More...
double * get_rng_phas_coef ()
Range reference phase coefficients More...
double * get_err_amp_coef ()
Error function amplitude coefficients More...
double * get_err_phas_coef ()
Error function phase coefficients More...
int get_pulse_bandw ()
Pulse bandwidth code More...
std::string get_adc_samp_rate ()
ADC sampling rate More...
double get_rep_agc_attn ()
Replica AGC attenuation More...
double get_gn_corctn_fctr ()
Gain correction factor (dB) More...
double get_rep_energy_gn ()
Replica energy gain correction More...
std::string get_orb_data_src ()
Orbit data source More...
int get_pulse_cnt_1 ()
Pulse count 1 More...
int get_pulse_cnt_2 ()
Pulse count 2 More...
std::string get_beam_edge_rqd ()
Beam edge detection requested More...
double get_beam_edge_conf ()
Beam edge confidence measure More...
int get_pix_overlap ()
Number of pixels in beam overlap More...
int get_n_beams ()
Number of beams More...
BeamInformationRecordget_beam_info ()
Beam info More...
int get_n_pix_updates ()
Number of pixel count updates More...
BeamPixelCountRecordget_pix_count ()
 Beam pixel counts. More...
double get_pwin_start ()
Processing window start time (sec) More...
double get_pwin_end ()
Processing window end time (sec) More...
std::string get_recd_type ()
Recording type More...
double get_temp_set_inc ()
Time increment between temperature settings (sec) More...
int get_n_temp_set ()
Number of temperature settings More...
TemperatureSettingsRecordget_temp ()
 Temperature settings. More...
int get_n_image_pix ()
Number of image pixels More...
double get_prc_zero_pix ()
Percent zero pixels More...
double get_prc_satur_pix ()
Percent saturated pixels More...
double get_img_hist_mean ()
Image histogram mean intensity More...
double * get_img_cumu_dist ()
Image cumulative distribution More...
double get_pre_img_gn ()
Pre-image calibration gain factor More...
double get_post_img_gn ()
Post-image calibration gain factor More...
double get_dopcen_inc ()
Time increment between Dopcen estimates (sec) More...
int get_n_dopcen ()
Number of Doppler centroid estimates More...
DopplerCentroidEstimateRecordget_dopcen_est ()
 Doppler centroid estimates. More...
int get_dop_amb_err ()
Doppler ambiguity error More...
double get_dopamb_conf ()
Doppler ambiguity confidence measure More...
double * get_eph_orb_data ()
Ephemeris orbit data More...
std::string get_appl_type ()
Application type More...
double * get_slow_time_coef ()
Slow time coefficients More...
int get_n_srgr ()
Number of SRGR coefficient sets More...
SRGRCoefficientSetRecordget_srgr_coefset ()
 SRGR coefficient sets. More...
double get_pixel_spacing ()
SGF product pixel spacing More...
std::string get_gics_reqd ()
GICS product required More...
std::string get_wo_number ()
Work order identifier More...
std::string get_wo_date ()
Work order entry date More...
std::string get_satellite_id ()
Satellite identifier More...
std::string get_user_id ()
User id More...
std::string get_complete_msg ()
Completion message required flag More...
std::string get_scene_id ()
SGF product scene identifier More...
std::string get_density_in ()
Density of SGF product media More...
std::string get_media_id ()
SGF product identifier More...
double get_angle_first ()
Incidence angle of first pixel in SGF product line More...
double get_angle_last ()
Incidence angle of last pixel in SGF product line More...
std::string get_prod_type ()
GICS output product type More...
std::string get_map_system ()
Map system identifier More...
double get_centre_lat ()
GICS output product scene centre latitude More...
double get_centre_long ()
GICS output product scene centre longitude More...
double get_span_x ()
GICS output product size - map eastings (km) More...
double get_span_y ()
GICS output product size - map northings (km) More...
std::string get_apply_dtm ()
DTM correction to be applied flag More...
std::string get_density_out ()
GICS output product density More...
std::string get_state_time ()
Time of the first state vector More...
int get_num_state_vectors ()
Number of state vectors More...
double get_state_time_inc ()
Time increment between state vectors More...
- Public Member Functions inherited from ossimplugins::RadarSatRecord
 RadarSatRecord (std::string mnemonic)
virtual ~RadarSatRecord ()
 Destructor. More...
 RadarSatRecord (const RadarSatRecord &rhs)
std::string get_mnemonic ()
int _rec_seq
std::string _inp_media
Input media More...
int _n_tape_id
std::string _tape_id [10]
std::string _exp_ing_start
std::string _exp_ing_stop
std::string _act_ing_start
std::string _act_ing_stop
std::string _proc_start
std::string _proc_stop
double _mn_sig_lev [10]
int _scr_data_ind
int _miss_ln
int _rej_ln
int _large_gap
double _bit_err_rate
double _fm_crc_err
int _date_incons
int _prf_changes
int _delay_changes
int _skipd_frams
int _rej_bf_start
int _rej_few_fram
int _rej_many_fram
int _rej_mchn_err
int _rej_vchn_err
int _rej_rec_type
std::string _sens_config
std::string _sens_orient
std::string _sych_marker
std::string _rng_ref_src
double _rng_amp_coef [4]
double _rng_phas_coef [4]
double _err_amp_coef [16]
double _err_phas_coef [4]
int _pulse_bandw
std::string _adc_samp_rate
double _rep_agc_attn
double _gn_corctn_fctr
double _rep_energy_gn
std::string _orb_data_src
int _pulse_cnt_1
int _pulse_cnt_2
std::string _beam_edge_rqd
double _beam_edge_conf
int _pix_overlap
int _n_beams
BeamInformationRecord _beam_info [4]
Beam info More...
int _n_pix_updates
BeamPixelCountRecord _pix_count [20]
double _pwin_start
double _pwin_end
std::string _recd_type
double _temp_set_inc
int _n_temp_set
TemperatureSettingsRecord _temp [20]
int _n_image_pix
double _prc_zero_pix
double _prc_satur_pix
double _img_hist_mean
double _img_cumu_dist [3]
double _pre_img_gn
double _post_img_gn
double _dopcen_inc
int _n_dopcen
DopplerCentroidEstimateRecord _dopcen_est [20]
int _dop_amb_err
double _dopamb_conf
double _eph_orb_data [7]
std::string _appl_type
double _slow_time_coef [5]
int _n_srgr
SRGRCoefficientSetRecord _srgr_coefset [20]
double _pixel_spacing
std::string _gics_reqd
std::string _wo_number
std::string _wo_date
std::string _satellite_id
std::string _user_id
User id More...
std::string _complete_msg
std::string _scene_id
std::string _density_in
std::string _media_id
double _angle_first
double _angle_last
std::string _prod_type
std::string _map_system
double _centre_lat
double _centre_long
double _span_x
double _span_y
std::string _apply_dtm
std::string _density_out
std::string _state_time
int _num_state_vectors
double _state_time_inc
- Protected Attributes inherited from ossimplugins::RadarSatRecord
std::string _mnemonic
Friends
std::ostream & operator<< (std::ostream &os, const ProcessingParameters &data)
 This function writes the ProcessingParameters in a stream. More...
std::istream & operator>> (std::istream &is, ProcessingParameters &data)
 This function reads a ProcessingParameters from a stream. More...
Detailed Description
Definition at line 31 of file ProcessingParameters.h.
◆ ProcessingParameters() [1/2]
ossimplugins::ProcessingParameters::ProcessingParameters ( )
Constructor.
Definition at line 16 of file ProcessingParameters.cpp.
Referenced by Clone(), and Instanciate().
16  : RadarSatRecord("proc_param_rec")
17  {
18  }
RadarSatRecord(std::string mnemonic)
Constructor.
◆ ~ProcessingParameters()
ossimplugins::ProcessingParameters::~ProcessingParameters ( )
Destructor.
Definition at line 20 of file ProcessingParameters.cpp.
21  {
22  }
◆ ProcessingParameters() [2/2]
ossimplugins::ProcessingParameters::ProcessingParameters ( const ProcessingParameters rhs)
Copy constructor.
Definition at line 695 of file ProcessingParameters.cpp.
695  :
696  RadarSatRecord(rhs)
697  {
698
699  }
Constructor.
Member Function Documentation
◆ Clone()
RadarSatRecord* ossimplugins::ProcessingParameters::Clone ( )
inlinevirtual
Implements ossimplugins::RadarSatRecord.
Definition at line 74 of file ProcessingParameters.h.
References ProcessingParameters().
75  {
76  return new ProcessingParameters(*this);
77  };
◆ get_act_ing_start()
std::string ossimplugins::ProcessingParameters::get_act_ing_start ( )
inline
Definition at line 141 of file ProcessingParameters.h.
References _act_ing_start.
142  {
143  return _act_ing_start;
144  };
◆ get_act_ing_stop()
std::string ossimplugins::ProcessingParameters::get_act_ing_stop ( )
inline
Definition at line 148 of file ProcessingParameters.h.
References _act_ing_stop.
149  {
150  return _act_ing_stop;
151  };
◆ get_adc_samp_rate()
std::string ossimplugins::ProcessingParameters::get_adc_samp_rate ( )
inline
ADC sampling rate
Definition at line 351 of file ProcessingParameters.h.
References _adc_samp_rate.
352  {
353  return _adc_samp_rate;
354  };
ADC sampling rate
◆ get_angle_first()
double ossimplugins::ProcessingParameters::get_angle_first ( )
inline
Definition at line 681 of file ProcessingParameters.h.
References _angle_first.
682  {
683  return _angle_first;
684  };
double _angle_first
◆ get_angle_last()
double ossimplugins::ProcessingParameters::get_angle_last ( )
inline
Definition at line 688 of file ProcessingParameters.h.
References _angle_last.
689  {
690  return _angle_last;
691  };
double _angle_last
◆ get_appl_type()
std::string ossimplugins::ProcessingParameters::get_appl_type ( )
inline
Application type
Definition at line 582 of file ProcessingParameters.h.
References _appl_type.
583  {
584  return _appl_type;
585  };
Application type
◆ get_apply_dtm()
std::string ossimplugins::ProcessingParameters::get_apply_dtm ( )
inline
Definition at line 737 of file ProcessingParameters.h.
References _apply_dtm.
738  {
739  return _apply_dtm;
740  };
◆ get_beam_edge_conf()
double ossimplugins::ProcessingParameters::get_beam_edge_conf ( )
inline
Definition at line 407 of file ProcessingParameters.h.
References _beam_edge_conf.
408  {
409  return _beam_edge_conf;
410  };
◆ get_beam_edge_rqd()
std::string ossimplugins::ProcessingParameters::get_beam_edge_rqd ( )
inline
Definition at line 400 of file ProcessingParameters.h.
References _beam_edge_rqd.
401  {
402  return _beam_edge_rqd;
403  };
◆ get_beam_info()
BeamInformationRecord* ossimplugins::ProcessingParameters::get_beam_info ( )
inline
Beam info
Definition at line 428 of file ProcessingParameters.h.
References _beam_info.
429  {
430  return _beam_info;
431  };
BeamInformationRecord _beam_info[4]
Beam info
◆ get_bit_err_rate()
double ossimplugins::ProcessingParameters::get_bit_err_rate ( )
inline
Definition at line 204 of file ProcessingParameters.h.
References _bit_err_rate.
205  {
206  return _bit_err_rate;
207  };
◆ get_centre_lat()
double ossimplugins::ProcessingParameters::get_centre_lat ( )
inline
Definition at line 709 of file ProcessingParameters.h.
References _centre_lat.
710  {
711  return _centre_lat;
712  };
double _centre_lat
◆ get_centre_long()
double ossimplugins::ProcessingParameters::get_centre_long ( )
inline
Definition at line 716 of file ProcessingParameters.h.
References _centre_long.
717  {
718  return _centre_long;
719  };
double _centre_long
◆ get_complete_msg()
std::string ossimplugins::ProcessingParameters::get_complete_msg ( )
inline
Definition at line 653 of file ProcessingParameters.h.
References _complete_msg.
654  {
655  return _complete_msg;
656  };
◆ get_date_incons()
int ossimplugins::ProcessingParameters::get_date_incons ( )
inline
Definition at line 218 of file ProcessingParameters.h.
References _date_incons.
219  {
220  return _date_incons;
221  };
int _date_incons
◆ get_delay_changes()
int ossimplugins::ProcessingParameters::get_delay_changes ( )
inline
Definition at line 232 of file ProcessingParameters.h.
References _delay_changes.
233  {
234  return _delay_changes;
235  };
int _delay_changes
◆ get_density_in()
std::string ossimplugins::ProcessingParameters::get_density_in ( )
inline
Definition at line 667 of file ProcessingParameters.h.
References _density_in.
668  {
669  return _density_in;
670  };
◆ get_density_out()
std::string ossimplugins::ProcessingParameters::get_density_out ( )
inline
Definition at line 744 of file ProcessingParameters.h.
References _density_out.
745  {
746  return _density_out;
747  };
◆ get_dop_amb_err()
int ossimplugins::ProcessingParameters::get_dop_amb_err ( )
inline
Definition at line 561 of file ProcessingParameters.h.
References _dop_amb_err.
562  {
563  return _dop_amb_err;
564  };
int _dop_amb_err
◆ get_dopamb_conf()
double ossimplugins::ProcessingParameters::get_dopamb_conf ( )
inline
Definition at line 568 of file ProcessingParameters.h.
References _dopamb_conf.
569  {
570  return _dopamb_conf;
571  };
double _dopamb_conf
◆ get_dopcen_est()
DopplerCentroidEstimateRecord* ossimplugins::ProcessingParameters::get_dopcen_est ( )
inline
Definition at line 554 of file ProcessingParameters.h.
References _dopcen_est.
555  {
556  return _dopcen_est;
557  };
DopplerCentroidEstimateRecord _dopcen_est[20]
◆ get_dopcen_inc()
double ossimplugins::ProcessingParameters::get_dopcen_inc ( )
inline
Definition at line 540 of file ProcessingParameters.h.
References _dopcen_inc.
541  {
542  return _dopcen_inc;
543  };
double _dopcen_inc
◆ get_eph_orb_data()
double* ossimplugins::ProcessingParameters::get_eph_orb_data ( )
inline
Definition at line 575 of file ProcessingParameters.h.
References _eph_orb_data.
576  {
577  return _eph_orb_data;
578  };
double _eph_orb_data[7]
◆ get_err_amp_coef()
double* ossimplugins::ProcessingParameters::get_err_amp_coef ( )
inline
Definition at line 330 of file ProcessingParameters.h.
References _err_amp_coef.
331  {
332  return _err_amp_coef;
333  };
double _err_amp_coef[16]
◆ get_err_phas_coef()
double* ossimplugins::ProcessingParameters::get_err_phas_coef ( )
inline
Definition at line 337 of file ProcessingParameters.h.
References _err_phas_coef.
338  {
339  return _err_phas_coef;
340  };
double _err_phas_coef[4]
◆ get_exp_ing_start()
std::string ossimplugins::ProcessingParameters::get_exp_ing_start ( )
inline
Definition at line 127 of file ProcessingParameters.h.
References _exp_ing_start.
128  {
129  return _exp_ing_start;
130  };
◆ get_exp_ing_stop()
std::string ossimplugins::ProcessingParameters::get_exp_ing_stop ( )
inline
Definition at line 134 of file ProcessingParameters.h.
References _exp_ing_stop.
135  {
136  return _exp_ing_stop;
137  };
◆ get_fm_crc_err()
double ossimplugins::ProcessingParameters::get_fm_crc_err ( )
inline
Definition at line 211 of file ProcessingParameters.h.
References _fm_crc_err.
212  {
213  return _fm_crc_err;
214  };
double _fm_crc_err
◆ get_gics_reqd()
std::string ossimplugins::ProcessingParameters::get_gics_reqd ( )
inline
Definition at line 618 of file ProcessingParameters.h.
References _gics_reqd.
619  {
620  return _gics_reqd;
621  };
◆ get_gn_corctn_fctr()
double ossimplugins::ProcessingParameters::get_gn_corctn_fctr ( )
inline
Definition at line 365 of file ProcessingParameters.h.
References _gn_corctn_fctr.
366  {
367  return _gn_corctn_fctr;
368  };
◆ get_img_cumu_dist()
double* ossimplugins::ProcessingParameters::get_img_cumu_dist ( )
inline
Definition at line 519 of file ProcessingParameters.h.
References _img_cumu_dist.
520  {
521  return _img_cumu_dist;
522  };
double _img_cumu_dist[3]
◆ get_img_hist_mean()
double ossimplugins::ProcessingParameters::get_img_hist_mean ( )
inline
Definition at line 512 of file ProcessingParameters.h.
References _img_hist_mean.
513  {
514  return _img_hist_mean;
515  };
◆ get_inp_media()
std::string ossimplugins::ProcessingParameters::get_inp_media ( )
inline
Input media
Definition at line 106 of file ProcessingParameters.h.
References _inp_media.
107  {
108  return _inp_media;
109  };
◆ get_large_gap()
int ossimplugins::ProcessingParameters::get_large_gap ( )
inline
Definition at line 197 of file ProcessingParameters.h.
References _large_gap.
198  {
199  return _large_gap;
200  };
int _large_gap
◆ get_map_system()
std::string ossimplugins::ProcessingParameters::get_map_system ( )
inline
Definition at line 702 of file ProcessingParameters.h.
References _map_system.
703  {
704  return _map_system;
705  };
◆ get_media_id()
std::string ossimplugins::ProcessingParameters::get_media_id ( )
inline
Definition at line 674 of file ProcessingParameters.h.
References _media_id.
675  {
676  return _media_id;
677  };
◆ get_miss_ln()
int ossimplugins::ProcessingParameters::get_miss_ln ( )
inline
Definition at line 183 of file ProcessingParameters.h.
References _miss_ln.
184  {
185  return _miss_ln;
186  };
int _miss_ln
◆ get_mn_sig_lev()
double* ossimplugins::ProcessingParameters::get_mn_sig_lev ( )
inline
Definition at line 169 of file ProcessingParameters.h.
References _mn_sig_lev.
170  {
171  return _mn_sig_lev;
172  };
double _mn_sig_lev[10]
◆ get_n_beams()
int ossimplugins::ProcessingParameters::get_n_beams ( )
inline
Number of beams
Definition at line 421 of file ProcessingParameters.h.
References _n_beams.
422  {
423  return _n_beams;
424  };
◆ get_n_dopcen()
int ossimplugins::ProcessingParameters::get_n_dopcen ( )
inline
Definition at line 547 of file ProcessingParameters.h.
References _n_dopcen.
548  {
549  return _n_dopcen;
550  };
int _n_dopcen
◆ get_n_image_pix()
int ossimplugins::ProcessingParameters::get_n_image_pix ( )
inline
Definition at line 491 of file ProcessingParameters.h.
References _n_image_pix.
492  {
493  return _n_image_pix;
494  };
int _n_image_pix
◆ get_n_pix_updates()
int ossimplugins::ProcessingParameters::get_n_pix_updates ( )
inline
Definition at line 435 of file ProcessingParameters.h.
References _n_pix_updates.
436  {
437  return _n_pix_updates;
438  };
int _n_pix_updates
◆ get_n_srgr()
int ossimplugins::ProcessingParameters::get_n_srgr ( )
inline
Definition at line 597 of file ProcessingParameters.h.
References _n_srgr.
Referenced by ossimplugins::ossimRadarSatModel::internalSaveState().
598  {
599  return _n_srgr;
600  };
int _n_srgr
◆ get_n_tape_id()
int ossimplugins::ProcessingParameters::get_n_tape_id ( )
inline
Definition at line 113 of file ProcessingParameters.h.
References _n_tape_id.
114  {
115  return _n_tape_id;
116  };
int _n_tape_id
◆ get_n_temp_set()
int ossimplugins::ProcessingParameters::get_n_temp_set ( )
inline
Definition at line 477 of file ProcessingParameters.h.
References _n_temp_set.
478  {
479  return _n_temp_set;
480  };
int _n_temp_set
◆ get_num_state_vectors()
int ossimplugins::ProcessingParameters::get_num_state_vectors ( )
inline
Definition at line 758 of file ProcessingParameters.h.
References _num_state_vectors.
759  {
760  return _num_state_vectors;
761  };
◆ get_orb_data_src()
std::string ossimplugins::ProcessingParameters::get_orb_data_src ( )
inline
Orbit data source
Definition at line 379 of file ProcessingParameters.h.
References _orb_data_src.
380  {
381  return _orb_data_src;
382  };
Orbit data source
◆ get_pix_count()
BeamPixelCountRecord* ossimplugins::ProcessingParameters::get_pix_count ( )
inline
Beam pixel counts.
Definition at line 442 of file ProcessingParameters.h.
References _pix_count.
443  {
444  return _pix_count;
445  };
BeamPixelCountRecord _pix_count[20]
Beam pixel counts.
◆ get_pix_overlap()
int ossimplugins::ProcessingParameters::get_pix_overlap ( )
inline
Definition at line 414 of file ProcessingParameters.h.
References _pix_overlap.
415  {
416  return _pix_overlap;
417  };
int _pix_overlap
◆ get_pixel_spacing()
double ossimplugins::ProcessingParameters::get_pixel_spacing ( )
inline
Definition at line 611 of file ProcessingParameters.h.
References _pixel_spacing.
612  {
613  return _pixel_spacing;
614  };
◆ get_post_img_gn()
double ossimplugins::ProcessingParameters::get_post_img_gn ( )
inline
Definition at line 533 of file ProcessingParameters.h.
References _post_img_gn.
534  {
535  return _post_img_gn;
536  };
double _post_img_gn
◆ get_prc_satur_pix()
double ossimplugins::ProcessingParameters::get_prc_satur_pix ( )
inline
Definition at line 505 of file ProcessingParameters.h.
References _prc_satur_pix.
506  {
507  return _prc_satur_pix;
508  };
◆ get_prc_zero_pix()
double ossimplugins::ProcessingParameters::get_prc_zero_pix ( )
inline
Percent zero pixels
Definition at line 498 of file ProcessingParameters.h.
References _prc_zero_pix.
499  {
500  return _prc_zero_pix;
501  };
Percent zero pixels
◆ get_pre_img_gn()
double ossimplugins::ProcessingParameters::get_pre_img_gn ( )
inline
Definition at line 526 of file ProcessingParameters.h.
References _pre_img_gn.
527  {
528  return _pre_img_gn;
529  };
double _pre_img_gn
◆ get_prf_changes()
int ossimplugins::ProcessingParameters::get_prf_changes ( )
inline
Definition at line 225 of file ProcessingParameters.h.
References _prf_changes.
226  {
227  return _prf_changes;
228  };
int _prf_changes
◆ get_proc_start()
std::string ossimplugins::ProcessingParameters::get_proc_start ( )
inline
Definition at line 155 of file ProcessingParameters.h.
References _proc_start.
156  {
157  return _proc_start;
158  };
◆ get_proc_stop()
std::string ossimplugins::ProcessingParameters::get_proc_stop ( )
inline
Definition at line 162 of file ProcessingParameters.h.
References _proc_stop.
163  {
164  return _proc_stop;
165  };
◆ get_prod_type()
std::string ossimplugins::ProcessingParameters::get_prod_type ( )
inline
Definition at line 695 of file ProcessingParameters.h.
References _prod_type.
696  {
697  return _prod_type;
698  };
◆ get_pulse_bandw()
int ossimplugins::ProcessingParameters::get_pulse_bandw ( )
inline
Definition at line 344 of file ProcessingParameters.h.
References _pulse_bandw.
345  {
346  return _pulse_bandw;
347  };
int _pulse_bandw
◆ get_pulse_cnt_1()
int ossimplugins::ProcessingParameters::get_pulse_cnt_1 ( )
inline
Pulse count 1
Definition at line 386 of file ProcessingParameters.h.
References _pulse_cnt_1.
387  {
388  return _pulse_cnt_1;
389  };
◆ get_pulse_cnt_2()
int ossimplugins::ProcessingParameters::get_pulse_cnt_2 ( )
inline
Pulse count 2
Definition at line 393 of file ProcessingParameters.h.
References _pulse_cnt_2.
394  {
395  return _pulse_cnt_2;
396  };
◆ get_pwin_end()
double ossimplugins::ProcessingParameters::get_pwin_end ( )
inline
Definition at line 456 of file ProcessingParameters.h.
References _pwin_end.
457  {
458  return _pwin_end;
459  };
double _pwin_end
◆ get_pwin_start()
double ossimplugins::ProcessingParameters::get_pwin_start ( )
inline
Definition at line 449 of file ProcessingParameters.h.
References _pwin_start.
450  {
451  return _pwin_start;
452  };
double _pwin_start
◆ get_rec_seq()
int ossimplugins::ProcessingParameters::get_rec_seq ( )
inline
Definition at line 98 of file ProcessingParameters.h.
References _rec_seq.
99  {
100  return _rec_seq;
101  };
int _rec_seq
◆ get_recd_type()
std::string ossimplugins::ProcessingParameters::get_recd_type ( )
inline
Recording type
Definition at line 463 of file ProcessingParameters.h.
References _recd_type.
464  {
465  return _recd_type;
466  };
Recording type
◆ get_rej_bf_start()
int ossimplugins::ProcessingParameters::get_rej_bf_start ( )
inline
Definition at line 246 of file ProcessingParameters.h.
References _rej_bf_start.
247  {
248  return _rej_bf_start;
249  };
int _rej_bf_start
◆ get_rej_few_fram()
int ossimplugins::ProcessingParameters::get_rej_few_fram ( )
inline
Definition at line 253 of file ProcessingParameters.h.
References _rej_few_fram.
254  {
255  return _rej_few_fram;
256  };
int _rej_few_fram
◆ get_rej_ln()
int ossimplugins::ProcessingParameters::get_rej_ln ( )
inline
Definition at line 190 of file ProcessingParameters.h.
References _rej_ln.
191  {
192  return _rej_ln;
193  };
int _rej_ln
◆ get_rej_many_fram()
int ossimplugins::ProcessingParameters::get_rej_many_fram ( )
inline
Definition at line 260 of file ProcessingParameters.h.
References _rej_many_fram.
261  {
262  return _rej_many_fram;
263  };
int _rej_many_fram
◆ get_rej_mchn_err()
int ossimplugins::ProcessingParameters::get_rej_mchn_err ( )
inline
Definition at line 267 of file ProcessingParameters.h.
References _rej_mchn_err.
268  {
269  return _rej_mchn_err;
270  };
int _rej_mchn_err
◆ get_rej_rec_type()
int ossimplugins::ProcessingParameters::get_rej_rec_type ( )
inline
Definition at line 281 of file ProcessingParameters.h.
References _rej_rec_type.
282  {
283  return _rej_rec_type;
284  };
int _rej_rec_type
◆ get_rej_vchn_err()
int ossimplugins::ProcessingParameters::get_rej_vchn_err ( )
inline
Definition at line 274 of file ProcessingParameters.h.
References _rej_vchn_err.
275  {
276  return _rej_vchn_err;
277  };
int _rej_vchn_err
◆ get_rep_agc_attn()
double ossimplugins::ProcessingParameters::get_rep_agc_attn ( )
inline
Definition at line 358 of file ProcessingParameters.h.
References _rep_agc_attn.
359  {
360  return _rep_agc_attn;
361  };
◆ get_rep_energy_gn()
double ossimplugins::ProcessingParameters::get_rep_energy_gn ( )
inline
Definition at line 372 of file ProcessingParameters.h.
References _rep_energy_gn.
373  {
374  return _rep_energy_gn;
375  };
◆ get_rng_amp_coef()
double* ossimplugins::ProcessingParameters::get_rng_amp_coef ( )
inline
Definition at line 316 of file ProcessingParameters.h.
References _rng_amp_coef.
317  {
318  return _rng_amp_coef;
319  };
double _rng_amp_coef[4]
◆ get_rng_phas_coef()
double* ossimplugins::ProcessingParameters::get_rng_phas_coef ( )
inline
Definition at line 323 of file ProcessingParameters.h.
References _rng_phas_coef.
324  {
325  return _rng_phas_coef;
326  };
double _rng_phas_coef[4]
◆ get_rng_ref_src()
std::string ossimplugins::ProcessingParameters::get_rng_ref_src ( )
inline
Definition at line 309 of file ProcessingParameters.h.
References _rng_ref_src.
310  {
311  return _rng_ref_src;
312  };
◆ get_satellite_id()
std::string ossimplugins::ProcessingParameters::get_satellite_id ( )
inline
Definition at line 639 of file ProcessingParameters.h.
References _satellite_id.
640  {
641  return _satellite_id;
642  };
◆ get_scene_id()
std::string ossimplugins::ProcessingParameters::get_scene_id ( )
inline
Definition at line 660 of file ProcessingParameters.h.
References _scene_id.
661  {
662  return _scene_id;
663  };
◆ get_scr_data_ind()
int ossimplugins::ProcessingParameters::get_scr_data_ind ( )
inline
Definition at line 176 of file ProcessingParameters.h.
References _scr_data_ind.
177  {
178  return _scr_data_ind;
179  };
int _scr_data_ind
◆ get_sens_config()
std::string ossimplugins::ProcessingParameters::get_sens_config ( )
inline
Definition at line 288 of file ProcessingParameters.h.
References _sens_config.
289  {
290  return _sens_config;
291  };
◆ get_sens_orient()
std::string ossimplugins::ProcessingParameters::get_sens_orient ( )
inline
Sensor orientation
Definition at line 295 of file ProcessingParameters.h.
References _sens_orient.
296  {
297  return _sens_orient;
298  };
Sensor orientation
◆ get_skipd_frams()
int ossimplugins::ProcessingParameters::get_skipd_frams ( )
inline
Definition at line 239 of file ProcessingParameters.h.
References _skipd_frams.
240  {
241  return _skipd_frams;
242  };
int _skipd_frams
◆ get_slow_time_coef()
double* ossimplugins::ProcessingParameters::get_slow_time_coef ( )
inline
Todo:
Verifier le type de la variable lors de la lecture de la donnee
Definition at line 590 of file ProcessingParameters.h.
References _slow_time_coef.
591  {
592  return _slow_time_coef;
593  };
double _slow_time_coef[5]
◆ get_span_x()
double ossimplugins::ProcessingParameters::get_span_x ( )
inline
Definition at line 723 of file ProcessingParameters.h.
References _span_x.
724  {
725  return _span_x;
726  };
double _span_x
◆ get_span_y()
double ossimplugins::ProcessingParameters::get_span_y ( )
inline
Definition at line 730 of file ProcessingParameters.h.
References _span_y.
731  {
732  return _span_y;
733  };
double _span_y
◆ get_srgr_coefset()
SRGRCoefficientSetRecord* ossimplugins::ProcessingParameters::get_srgr_coefset ( )
inline
Definition at line 604 of file ProcessingParameters.h.
References _srgr_coefset.
605  {
606  return _srgr_coefset;
607  };
SRGRCoefficientSetRecord _srgr_coefset[20]
◆ get_state_time()
std::string ossimplugins::ProcessingParameters::get_state_time ( )
inline
Definition at line 751 of file ProcessingParameters.h.
References _state_time.
752  {
753  return _state_time;
754  };
◆ get_state_time_inc()
double ossimplugins::ProcessingParameters::get_state_time_inc ( )
inline
Definition at line 765 of file ProcessingParameters.h.
References _state_time_inc.
766  {
767  return _state_time_inc;
768  };
◆ get_sych_marker()
std::string ossimplugins::ProcessingParameters::get_sych_marker ( )
inline
Frame synch marker
Definition at line 302 of file ProcessingParameters.h.
References _sych_marker.
303  {
304  return _sych_marker;
305  };
Frame synch marker
◆ get_tape_id()
std::string* ossimplugins::ProcessingParameters::get_tape_id ( )
inline
Tape identifiers
Definition at line 120 of file ProcessingParameters.h.
References _tape_id.
121  {
122  return _tape_id;
123  };
std::string _tape_id[10]
Tape identifiers
◆ get_temp()
TemperatureSettingsRecord* ossimplugins::ProcessingParameters::get_temp ( )
inline
Definition at line 484 of file ProcessingParameters.h.
References _temp.
485  {
486  return _temp;
487  };
TemperatureSettingsRecord _temp[20]
◆ get_temp_set_inc()
double ossimplugins::ProcessingParameters::get_temp_set_inc ( )
inline
Definition at line 470 of file ProcessingParameters.h.
References _temp_set_inc.
471  {
472  return _temp_set_inc;
473  };
◆ get_user_id()
std::string ossimplugins::ProcessingParameters::get_user_id ( )
inline
User id
Definition at line 646 of file ProcessingParameters.h.
References _user_id.
647  {
648  return _user_id;
649  };
◆ get_wo_date()
std::string ossimplugins::ProcessingParameters::get_wo_date ( )
inline
Definition at line 632 of file ProcessingParameters.h.
References _wo_date.
633  {
634  return _wo_date;
635  };
◆ get_wo_number()
std::string ossimplugins::ProcessingParameters::get_wo_number ( )
inline
Definition at line 625 of file ProcessingParameters.h.
References _wo_number.
626  {
627  return _wo_number;
628  };
◆ Instanciate()
RadarSatRecord* ossimplugins::ProcessingParameters::Instanciate ( )
inlinevirtual
Definition at line 66 of file ProcessingParameters.h.
67  {
68  return new ProcessingParameters();
69  };
◆ operator=()
ProcessingParameters & ossimplugins::ProcessingParameters::operator= ( const ProcessingParameters rhs)
Copy operator.
Definition at line 701 of file ProcessingParameters.cpp.
702  {
703  /*
704  int _rec_seq
705
706  std::string _spare1
707
708  std::string _inp_media
709
710  int _n_tape_id
711
712  std::string _tape_id
713
714  std::string _exp_ing_start
715
716  std::string _exp_ing_stop
717
718  std::string _act_ing_start
719
720  std::string _act_ing_stop
721
722  std::string _proc_start
723
724  std::string _proc_stop
725
726  double* _mn_sig_lev
727
728  int _scr_data_ind
729
730  int _miss_ln
731
732  int _rej_ln
733
734  int _large_gap
735
736  double _bit_err_rate
737
738  double _fm_crc_err
739
740  int _date_incons
741
742  int _prf_changes
743
744  int _delay_changes
745
746  int _skipd_frams
747
748  int _rej_bf_start
749
750  int _rej_few_fram
751
752  int _rej_many_fram
753
754  int _rej_mchn_err
755
756  int _rej_vchn_err
757
758  int _rej_rec_type
759
760  std::string _sens_config
761
762  std::string _sens_orient
763
764  int _sych_marker
765
766  std::string _rng_ref_src
767
768  double* _rng_amp_coef
769
770  double* _rng_phas_coef
771
772  double* _err_amp_coef
773
774  double* _err_phas_coef
775
776  int _pulse_bandw
777
778  int _adc_samp_rate
779
780  double _rep_agc_attn
781
782  double _gn_corctn_fctr
783
784  double _rep_energy_gn
785
786  std::string _orb_data_src
787
788  int _pulse_cnt_1
789
790  int _pulse_cnt_2
791
792  std::string _beam_edge_rqd
793
794  double _beam_edge_conf
795
796  int _pix_overlap
797
798  int _n_beams
799
800  BeamInformationRecord* _beam_info
801
802  int _n_pix_updates
803
804  BeamPixelCountRecord* _pix_count
805
806  double _pwin_start
807
808  double _pwin_end
809
810  std::string _recd_type
811
812  double _temp_set_inc
813
814  int* _n_temp_set
815
816  TemperatureSettingsRecord* _temp
817
818  int _n_image_pix
819
820  double _prc_zero_pix
821
822  double _prc_satur_pix
823
824  double _img_hist_mean
825
826  double* _img_cumu_dist
827
828  double _pre_img_gn
829
830  double _post_img_gn
831
832  double _dopcen_inc
833
834  int _n_dopcen
835
836  DopplerCentroidEstimateRecord* _dopcen_est
837
838  int _dop_amb_err
839
840  double _dopamb_conf
841
842  double* _eph_orb_data
843
844  std::string _appl_type
845
846  double* _slow_time_coef
847
848  int _n_srgr
849
850  SRGRCoefficientSetRecord* _srgr_coefset
851
852  double _pixel_spacing
853
854  std::string _gics_reqd
855
856  std::string _wo_number
857
858  std::string _wo_date
859
860  std::string _satellite_id
861
862  std::string _user_id
863
864  std::string _complete_msg
865
866  std::string _scene_id
867
868  std::string _density_in
869
870  std::string _media_id
871
872  double _angle_first
873
874  double _angle_last
875
876  std::string _prod_type
877
878  std::string _map_system
879
880  double _centre_lat
881
882  double _centre_long
883
884  double _span_x
885
886  double _span_y
887
888  std::string _apply_dtm
889
890  std::string _density_out
891
892  std::string _state_time
893
894  int _num_state_vectors
895
896  double _state_time_inc
897
898  std::string _spare2*/
899  return *this;
900  }
◆ Read()
void ossimplugins::ProcessingParameters::Read ( std::istream &  is)
inlinevirtual
Definition at line 82 of file ProcessingParameters.h.
83  {
84  is>>*this;
85  };
◆ Write()
void ossimplugins::ProcessingParameters::Write ( std::ostream &  os)
inlinevirtual
Definition at line 90 of file ProcessingParameters.h.
91  {
92  os<<*this;
93  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const ProcessingParameters data
friend
Definition at line 24 of file ProcessingParameters.cpp.
25  {
26  os<<"rec_seq:"<<data._rec_seq<<std::endl;
27
28  os<<"inp_media:"<<data._inp_media.c_str()<<std::endl;
29
30  os<<"n_tape_id:"<<data._n_tape_id<<std::endl;
31
32  for (int i=0;i<10;i++)
33  {
34  os<<"tape_id["<<i<<"]:"<<data._tape_id[i].c_str()<<std::endl;
35  }
36
37  os<<"exp_ing_start:"<<data._exp_ing_start.c_str()<<std::endl;
38
39  os<<"exp_ing_stop:"<<data._exp_ing_stop.c_str()<<std::endl;
40
41  os<<"act_ing_start:"<<data._act_ing_start.c_str()<<std::endl;
42
43  os<<"act_ing_stop:"<<data._act_ing_stop.c_str()<<std::endl;
44
45  os<<"proc_start:"<<data._proc_start.c_str()<<std::endl;
46
47  os<<"proc_stop:"<<data._proc_stop.c_str()<<std::endl;
48
49  for (int i=0;i<10;i++)
50  {
51  os<<"mn_sig_lev["<<i<<"]:"<<data._mn_sig_lev[i]<<std::endl;
52  }
53
54  os<<"scr_data_ind:"<<data._scr_data_ind<<std::endl;
55
56  os<<"miss_ln:"<<data._miss_ln<<std::endl;
57
58  os<<"rej_ln:"<<data._rej_ln<<std::endl;
59
60  os<<"large_gap:"<<data._large_gap<<std::endl;
61
62  os<<"bit_err_rate:"<<data._bit_err_rate<<std::endl;
63
64  os<<"fm_crc_err:"<<data._fm_crc_err<<std::endl;
65
66  os<<"date_incons:"<<data._date_incons<<std::endl;
67
68  os<<"prf_changes:"<<data._prf_changes<<std::endl;
69
70  os<<"delay_changes:"<<data._delay_changes<<std::endl;
71
72  os<<"skipd_frams:"<<data._skipd_frams<<std::endl;
73
74  os<<"rej_bf_start:"<<data._rej_bf_start<<std::endl;
75
76  os<<"rej_few_fram:"<<data._rej_few_fram<<std::endl;
77
78  os<<"rej_many_fram:"<<data._rej_many_fram<<std::endl;
79
80  os<<"rej_mchn_err:"<<data._rej_mchn_err<<std::endl;
81
82  os<<"rej_vchn_err:"<<data._rej_vchn_err<<std::endl;
83
84  os<<"rej_rec_type:"<<data._rej_rec_type<<std::endl;
85
86  os<<"sens_config:"<<data._sens_config.c_str()<<std::endl;
87
88  os<<"sens_orient:"<<data._sens_orient.c_str()<<std::endl;
89
90  os<<"sych_marker:"<<data._sych_marker.c_str()<<std::endl;
91
92  os<<"rng_ref_src:"<<data._rng_ref_src.c_str()<<std::endl;
93
94  for (int i=0;i<4;i++)
95  {
96  os<<"rng_amp_coef["<<i<<"]:"<<data._rng_amp_coef[i]<<std::endl;
97  }
98
99  for (int i=0;i<4;i++)
100  {
101  os<<"rng_phas_coef["<<i<<"]:"<<data._rng_phas_coef[i]<<std::endl;
102  }
103
104  for (int i=0;i<4;i++)
105  {
106  os<<"err_amp_coef["<<i<<"]:"<<data._err_amp_coef[i]<<std::endl;
107  }
108
109  for (int i=0;i<4;i++)
110  {
111  os<<"err_phas_coef["<<i<<"]:"<<data._err_phas_coef[i]<<std::endl;
112  }
113
114  os<<"pulse_bandw:"<<data._pulse_bandw<<std::endl;
115
116
117  os<<"adc_samp_rate:"<<data._adc_samp_rate.c_str()<<std::endl;
118
119  os<<"rep_agc_attn:"<<data._rep_agc_attn<<std::endl;
120
121  os<<"gn_corctn_fctr:"<<data._gn_corctn_fctr<<std::endl;
122
123  os<<"rep_energy_gn:"<<data._rep_energy_gn<<std::endl;
124
125  os<<"orb_data_src:"<<data._orb_data_src.c_str()<<std::endl;
126
127  os<<"pulse_cnt_1:"<<data._pulse_cnt_1<<std::endl;
128
129  os<<"pulse_cnt_2:"<<data._pulse_cnt_2<<std::endl;
130
131  os<<"beam_edge_rqd:"<<data._beam_edge_rqd.c_str()<<std::endl;
132
133  os<<"beam_edge_conf:"<<data._beam_edge_conf<<std::endl;
134
135  os<<"pix_overlap:"<<data._pix_overlap<<std::endl;
136
137  os<<"n_beams:"<<data._n_beams<<std::endl;
138
139  for (int i=0;i<4;i++)
140  {
141  os<<"beam_info["<<i<<"]:"<<data._beam_info[i]<<std::endl;
142  }
143
144  os<<"n_pix_updates:"<<data._n_pix_updates<<std::endl;
145
146  for (int i=0;i<4;i++)
147  {
148  os<<"pix_count["<<i<<"]:"<<data._pix_count[i]<<std::endl;
149  }
150
151  os<<"pwin_start:"<<data._pwin_start<<std::endl;
152
153  os<<"pwin_end:"<<data._pwin_end<<std::endl;
154
155  os<<"recd_type:"<<data._recd_type.c_str()<<std::endl;
156
157  os<<"temp_set_inc:"<<data._temp_set_inc<<std::endl;
158
159  os<<"n_temp_set:"<<data._n_temp_set<<std::endl;
160
161  for (int i=0;i<20;i++)
162  {
163  os<<"temp["<<i<<"]:"<<data._temp[i]<<std::endl;
164  }
165
166  os<<"n_image_pix:"<<data._n_image_pix<<std::endl;
167
168  os<<"prc_zero_pix:"<<data._prc_zero_pix<<std::endl;
169
170  os<<"prc_satur_pix:"<<data._prc_satur_pix<<std::endl;
171
172  os<<"img_hist_mean:"<<data._img_hist_mean<<std::endl;
173
174  for (int i=0;i<3;i++)
175  {
176  os<<"img_cumu_dist["<<i<<"]:"<<data._img_cumu_dist[i]<<std::endl;
177  }
178
179  os<<"pre_img_gn:"<<data._pre_img_gn<<std::endl;
180
181  os<<"post_img_gn:"<<data._post_img_gn<<std::endl;
182
183  os<<"dopcen_inc:"<<data._dopcen_inc<<std::endl;
184
185  os<<"n_dopcen:"<<data._n_dopcen<<std::endl;
186
187  for (int i=0;i<20;i++)
188  {
189  os<<"dopcen_est["<<i<<"]:"<<data._dopcen_est[i]<<std::endl;
190  }
191
192  os<<"dop_amb_err:"<<data._dop_amb_err<<std::endl;
193
194  os<<"dopamb_conf:"<<data._dopamb_conf<<std::endl;
195
196  for (int i=0;i<7;i++)
197  {
198  os<<"eph_orb_data["<<i<<"]:"<<data._eph_orb_data[i]<<std::endl;
199  }
200
201  os<<"appl_type:"<<data._appl_type.c_str()<<std::endl;
202
203  for (int i=0;i<5;i++)
204  {
205  os<<"slow_time_coef["<<i<<"]:"<<data._slow_time_coef[i]<<std::endl;
206  }
207
208  os<<"n_srgr:"<<data._n_srgr<<std::endl;
209
210  for (int i=0;i<20;i++)
211  {
212  os<<"srgr_coefset["<<i<<"]:"<<data._srgr_coefset[i]<<std::endl;
213  }
214
215  os<<"pixel_spacing:"<<data._pixel_spacing<<std::endl;
216
217  os<<"gics_reqd:"<<data._gics_reqd.c_str()<<std::endl;
218
219  os<<"wo_number:"<<data._wo_number.c_str()<<std::endl;
220
221  os<<"wo_date:"<<data._wo_date.c_str()<<std::endl;
222
223  os<<"satellite_id:"<<data._satellite_id.c_str()<<std::endl;
224
225  os<<"user_id:"<<data._user_id.c_str()<<std::endl;
226
227  os<<"complete_msg:"<<data._complete_msg.c_str()<<std::endl;
228
229  os<<"scene_id:"<<data._scene_id.c_str()<<std::endl;
230
231  os<<"density_in:"<<data._density_in.c_str()<<std::endl;
232
233  os<<"media_id:"<<data._media_id.c_str()<<std::endl;
234
235  os<<"angle_first:"<<data._angle_first<<std::endl;
236
237  os<<"angle_last:"<<data._angle_last<<std::endl;
238
239  os<<"prod_type:"<<data._prod_type.c_str()<<std::endl;
240
241  os<<"map_system:"<<data._map_system.c_str()<<std::endl;
242
243  os<<"centre_lat:"<<data._centre_lat<<std::endl;
244
245  os<<"centre_long:"<<data._centre_long<<std::endl;
246
247  os<<"span_x:"<<data._span_x<<std::endl;
248
249  os<<"span_y:"<<data._span_y<<std::endl;
250
251  os<<"apply_dtm:"<<data._apply_dtm.c_str()<<std::endl;
252
253  os<<"density_out:"<<data._density_out.c_str()<<std::endl;
254
255  os<<"state_time:"<<data._state_time.c_str()<<std::endl;
256
257  os<<"num_state_vectors:"<<data._num_state_vectors<<std::endl;
258
259  os<<"state_time_inc:"<<data._state_time_inc<<std::endl;
260
261  return os;
262  }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 264 of file ProcessingParameters.cpp.
265  {
266  char buf[2407];
267  buf[2406] = '\0';
268
269  is.read(buf,4);
270  buf[4] = '\0';
271  data._rec_seq = atoi(buf);
272
273  is.read(buf,4);
274  buf[4] = '\0';
275
276  is.read(buf,3);
277  buf[3] = '\0';
278  data._inp_media = buf;
279
280  is.read(buf,4);
281  buf[4] = '\0';
282  data._n_tape_id = atoi(buf);
283
284  for (int i=0;i<10;i++)
285  {
286  is.read(buf,8);
287  buf[8] = '\0';
288  data._tape_id[i] = buf;
289  }
290
291  is.read(buf,21);
292  buf[21] = '\0';
293  data._exp_ing_start = buf;
294
295  is.read(buf,21);
296  buf[21] = '\0';
297  data._exp_ing_stop = buf;
298
299  is.read(buf,21);
300  buf[21] = '\0';
301  data._act_ing_start = buf;
302
303  is.read(buf,21);
304  buf[21] = '\0';
305  data._act_ing_stop = buf;
306
307  is.read(buf,21);
308  buf[21] = '\0';
309  data._proc_start = buf;
310
311  is.read(buf,21);
312  buf[21] = '\0';
313  data._proc_stop = buf;
314
315  for (int i=0;i<10;i++)
316  {
317  is.read(buf,16);
318  buf[16] = '\0';
319  data._mn_sig_lev[i] = atof(buf);
320  }
321
322  is.read(buf,4);
323  buf[4] = '\0';
324  data._scr_data_ind = atoi(buf);
325
326  is.read(buf,8);
327  buf[8] = '\0';
328  data._miss_ln = atoi(buf);
329
330  is.read(buf,8);
331  buf[8] = '\0';
332  data._rej_ln = atoi(buf);
333
334  is.read(buf,8);
335  buf[8] = '\0';
336  data._large_gap = atoi(buf);
337
338  is.read(buf,16);
339  buf[16] = '\0';
340  data._bit_err_rate = atof(buf);
341
342  is.read(buf,16);
343  buf[16] = '\0';
344  data._fm_crc_err = atof(buf);
345
346  is.read(buf,8);
347  buf[8] = '\0';
348  data._date_incons = atoi(buf);
349
350  is.read(buf,8);
351  buf[8] = '\0';
352  data._prf_changes = atoi(buf);
353
354  is.read(buf,8);
355  buf[8] = '\0';
356  data._delay_changes = atoi(buf);
357
358  is.read(buf,8);
359  buf[8] = '\0';
360  data._skipd_frams = atoi(buf);
361
362  is.read(buf,8);
363  buf[8] = '\0';
364  data._rej_bf_start = atoi(buf);
365
366  is.read(buf,8);
367  buf[8] = '\0';
368  data._rej_few_fram = atoi(buf);
369
370  is.read(buf,8);
371  buf[8] = '\0';
372  data._rej_many_fram = atoi(buf);
373
374  is.read(buf,8);
375  buf[8] = '\0';
376  data._rej_mchn_err = atoi(buf);
377
378  is.read(buf,8);
379  buf[8] = '\0';
380  data._rej_vchn_err = atoi(buf);
381
382  is.read(buf,8);
383  buf[8] = '\0';
384  data._rej_rec_type = atoi(buf);
385
386  is.read(buf,10);
387  buf[10] = '\0';
388  data._sens_config = buf;
389
390  is.read(buf,9);
391  buf[9] = '\0';
392  data._sens_orient = buf;
393
394  is.read(buf,8);
395  buf[8] = '\0';
396  data._sych_marker = buf;
397
398  is.read(buf,12);
399  buf[12] = '\0';
400  data._rng_ref_src = buf;
401
402  for (int i=0;i<4;i++)
403  {
404  is.read(buf,16);
405  buf[16] = '\0';
406  data._rng_amp_coef[i] = atof(buf);
407  }
408
409  for (int i=0;i<4;i++)
410  {
411  is.read(buf,16);
412  buf[16] = '\0';
413  data._rng_phas_coef[i] = atof(buf);
414  }
415
416  for (int i=0;i<4;i++)
417  {
418  is.read(buf,16);
419  buf[16] = '\0';
420  data._err_amp_coef[i] = atof(buf);
421  }
422
423  for (int i=0;i<4;i++)
424  {
425  is.read(buf,16);
426  buf[16] = '\0';
427  data._err_phas_coef[i] = atof(buf);
428  }
429
430  is.read(buf,4);
431  buf[4] = '\0';
432  data._pulse_bandw = atoi(buf);
433
434
435  is.read(buf,5);
436  buf[5] = '\0';
437  data._adc_samp_rate = buf;
438
439  is.read(buf,16);
440  buf[16] = '\0';
441  data._rep_agc_attn = atof(buf);
442
443  is.read(buf,16);
444  buf[16] = '\0';
445  data._gn_corctn_fctr = atof(buf);
446
447  is.read(buf,16);
448  buf[16] = '\0';
449  data._rep_energy_gn = atof(buf);
450
451  is.read(buf,11);
452  buf[11] = '\0';
453  data._orb_data_src = buf;
454
455  is.read(buf,4);
456  buf[4] = '\0';
457  data._pulse_cnt_1 = atoi(buf);
458
459  is.read(buf,4);
460  buf[4] = '\0';
461  data._pulse_cnt_2 = atoi(buf);
462
463  is.read(buf,3);
464  buf[3] = '\0';
465  data._beam_edge_rqd = buf;
466
467  is.read(buf,16);
468  buf[16] = '\0';
469  data._beam_edge_conf = atof(buf);
470
471  is.read(buf,4);
472  buf[4] = '\0';
473  data._pix_overlap = atoi(buf);
474
475  is.read(buf,4);
476  buf[4] = '\0';
477  data._n_beams = atoi(buf);
478
479  for (int i=0;i<4;i++)
480  {
481  is>>data._beam_info[i];
482  }
483
484  is.read(buf,4);
485  buf[4] = '\0';
486  data._n_pix_updates = atoi(buf);
487
488  for (int i=0;i<20;i++)
489  {
490  is>>data._pix_count[i];
491  }
492
493  is.read(buf,16);
494  buf[16] = '\0';
495  data._pwin_start = atof(buf);
496
497  is.read(buf,16);
498  buf[16] = '\0';
499  data._pwin_end = atof(buf);
500
501  is.read(buf,9);
502  buf[9] = '\0';
503  data._recd_type = buf;
504
505  is.read(buf,16);
506  buf[16] = '\0';
507  data._temp_set_inc = atof(buf);
508
509  is.read(buf,4);
510  buf[4] = '\0';
511  data._n_temp_set = atoi(buf);
512
513  for (int i=0;i<20;i++)
514  {
515  is>>data._temp[i];
516  }
517
518  is.read(buf,8);
519  buf[8] = '\0';
520  data._n_image_pix = atoi(buf);
521
522  is.read(buf,16);
523  buf[16] = '\0';
524  data._prc_zero_pix = atof(buf);
525
526  is.read(buf,16);
527  buf[16] = '\0';
528  data._prc_satur_pix = atof(buf);
529
530  is.read(buf,16);
531  buf[16] = '\0';
532  data._img_hist_mean = atof(buf);
533
534  for (int i=0;i<3;i++)
535  {
536  is.read(buf,16);
537  buf[16] = '\0';
538  data._img_cumu_dist[i] = atof(buf);
539  }
540
541  is.read(buf,16);
542  buf[16] = '\0';
543  data._pre_img_gn = atof(buf);
544
545  is.read(buf,16);
546  buf[16] = '\0';
547  data._post_img_gn = atof(buf);
548
549  is.read(buf,16);
550  buf[16] = '\0';
551  data._dopcen_inc = atof(buf);
552
553  is.read(buf,4);
554  buf[4] = '\0';
555  data._n_dopcen = atoi(buf);
556
557  for (int i=0;i<20;i++)
558  {
559  is>>data._dopcen_est[i];
560  }
561
562  is.read(buf,4);
563  buf[4] = '\0';
564  data._dop_amb_err = atoi(buf);
565
566  is.read(buf,16);
567  buf[16] = '\0';
568  data._dopamb_conf = atof(buf);
569
570  for (int i=0;i<7;i++)
571  {
572  is.read(buf,16);
573  buf[16] = '\0';
574  data._eph_orb_data[i] = atof(buf);
575  }
576
577  is.read(buf,12);
578  buf[12] = '\0';
579  data._appl_type = buf;
580
581  for (int i=0;i<5;i++)
582  {
583  is.read(buf,22);
584  buf[22] = '\0';
585  data._slow_time_coef[i] = atof(buf);
586  }
587
588  is.read(buf,4);
589  buf[4] = '\0';
590  data._n_srgr = atoi(buf);
591
592  for (int i=0;i<20;i++)
593  {
594  is>>data._srgr_coefset[i];
595  }
596
597  is.read(buf,16);
598  buf[16] = '\0';
599  data._pixel_spacing = atof(buf);
600
601  is.read(buf,3);
602  buf[3] = '\0';
603  data._gics_reqd = buf;
604
605  is.read(buf,8);
606  buf[8] = '\0';
607  data._wo_number = buf;
608
609  is.read(buf,20);
610  buf[20] = '\0';
611  data._wo_date = buf;
612
613  is.read(buf,10);
614  buf[10] = '\0';
615  data._satellite_id = buf;
616
617  is.read(buf,20);
618  buf[20] = '\0';
619  data._user_id = buf;
620
621  is.read(buf,3);
622  buf[3] = '\0';
623  data._complete_msg = buf;
624
625  is.read(buf,15);
626  buf[15] = '\0';
627  data._scene_id = buf;
628
629  is.read(buf,4);
630  buf[4] = '\0';
631  data._density_in = buf;
632
633  is.read(buf,8);
634  buf[8] = '\0';
635  data._media_id = buf;
636
637  is.read(buf,16);
638  buf[16] = '\0';
639  data._angle_first = atof(buf);
640
641  is.read(buf,16);
642  buf[16] = '\0';
643  data._angle_last = atof(buf);
644
645  is.read(buf,3);
646  buf[3] = '\0';
647  data._prod_type = buf;
648
649  is.read(buf,16);
650  buf[16] = '\0';
651  data._map_system = buf;
652
653  is.read(buf,22);
654  buf[22] = '\0';
655  data._centre_lat = atof(buf);
656
657  is.read(buf,22);
658  buf[22] = '\0';
659  data._centre_long = atof(buf);
660
661  is.read(buf,22);
662  buf[22] = '\0';
663  data._span_x = atof(buf);
664
665  is.read(buf,22);
666  buf[22] = '\0';
667  data._span_y = atof(buf);
668
669  is.read(buf,3);
670  buf[3] = '\0';
671  data._apply_dtm = buf;
672
673  is.read(buf,4);
674  buf[4] = '\0';
675  data._density_out = buf;
676
677  is.read(buf,21);
678  buf[21] = '\0';
679  data._state_time = buf;
680
681  is.read(buf,4);
682  buf[4] = '\0';
683  data._num_state_vectors = atoi(buf);
684
685  is.read(buf,16);
686  buf[16] = '\0';
687  data._state_time_inc = atof(buf);
688
689  is.read(buf,206);
690  buf[206] = '\0';
691
692  return is;
693  }
Member Data Documentation
◆ _act_ing_start
std::string ossimplugins::ProcessingParameters::_act_ing_start
protected
Definition at line 799 of file ProcessingParameters.h.
Referenced by get_act_ing_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _act_ing_stop
std::string ossimplugins::ProcessingParameters::_act_ing_stop
protected
Definition at line 803 of file ProcessingParameters.h.
Referenced by get_act_ing_stop(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _adc_samp_rate
std::string ossimplugins::ProcessingParameters::_adc_samp_rate
protected
ADC sampling rate
Definition at line 919 of file ProcessingParameters.h.
Referenced by get_adc_samp_rate(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _angle_first
double ossimplugins::ProcessingParameters::_angle_first
protected
Definition at line 1108 of file ProcessingParameters.h.
Referenced by get_angle_first(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _angle_last
double ossimplugins::ProcessingParameters::_angle_last
protected
Definition at line 1112 of file ProcessingParameters.h.
Referenced by get_angle_last(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _appl_type
std::string ossimplugins::ProcessingParameters::_appl_type
protected
Application type
Definition at line 1051 of file ProcessingParameters.h.
Referenced by get_appl_type(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _apply_dtm
std::string ossimplugins::ProcessingParameters::_apply_dtm
protected
Definition at line 1140 of file ProcessingParameters.h.
Referenced by get_apply_dtm(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _beam_edge_conf
double ossimplugins::ProcessingParameters::_beam_edge_conf
protected
Definition at line 951 of file ProcessingParameters.h.
Referenced by get_beam_edge_conf(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _beam_edge_rqd
std::string ossimplugins::ProcessingParameters::_beam_edge_rqd
protected
Definition at line 947 of file ProcessingParameters.h.
Referenced by get_beam_edge_rqd(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _beam_info
BeamInformationRecord ossimplugins::ProcessingParameters::_beam_info[4]
protected
Beam info
Definition at line 963 of file ProcessingParameters.h.
Referenced by get_beam_info(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _bit_err_rate
double ossimplugins::ProcessingParameters::_bit_err_rate
protected
Definition at line 835 of file ProcessingParameters.h.
Referenced by get_bit_err_rate(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _centre_lat
double ossimplugins::ProcessingParameters::_centre_lat
protected
Definition at line 1124 of file ProcessingParameters.h.
Referenced by get_centre_lat(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _centre_long
double ossimplugins::ProcessingParameters::_centre_long
protected
Definition at line 1128 of file ProcessingParameters.h.
Referenced by get_centre_long(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _complete_msg
std::string ossimplugins::ProcessingParameters::_complete_msg
protected
Definition at line 1092 of file ProcessingParameters.h.
Referenced by get_complete_msg(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _date_incons
int ossimplugins::ProcessingParameters::_date_incons
protected
Definition at line 843 of file ProcessingParameters.h.
Referenced by get_date_incons(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _delay_changes
int ossimplugins::ProcessingParameters::_delay_changes
protected
Definition at line 851 of file ProcessingParameters.h.
Referenced by get_delay_changes(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _density_in
std::string ossimplugins::ProcessingParameters::_density_in
protected
Definition at line 1100 of file ProcessingParameters.h.
Referenced by get_density_in(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _density_out
std::string ossimplugins::ProcessingParameters::_density_out
protected
Definition at line 1144 of file ProcessingParameters.h.
Referenced by get_density_out(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _dop_amb_err
int ossimplugins::ProcessingParameters::_dop_amb_err
protected
Definition at line 1039 of file ProcessingParameters.h.
Referenced by get_dop_amb_err(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _dopamb_conf
double ossimplugins::ProcessingParameters::_dopamb_conf
protected
Definition at line 1043 of file ProcessingParameters.h.
Referenced by get_dopamb_conf(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _dopcen_est
DopplerCentroidEstimateRecord ossimplugins::ProcessingParameters::_dopcen_est[20]
protected
Definition at line 1035 of file ProcessingParameters.h.
Referenced by get_dopcen_est(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _dopcen_inc
double ossimplugins::ProcessingParameters::_dopcen_inc
protected
Definition at line 1027 of file ProcessingParameters.h.
Referenced by get_dopcen_inc(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _eph_orb_data
double ossimplugins::ProcessingParameters::_eph_orb_data[7]
protected
◆ _err_amp_coef
double ossimplugins::ProcessingParameters::_err_amp_coef[16]
protected
Definition at line 907 of file ProcessingParameters.h.
Referenced by get_err_amp_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _err_phas_coef
double ossimplugins::ProcessingParameters::_err_phas_coef[4]
protected
Definition at line 911 of file ProcessingParameters.h.
Referenced by get_err_phas_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _exp_ing_start
std::string ossimplugins::ProcessingParameters::_exp_ing_start
protected
Definition at line 791 of file ProcessingParameters.h.
Referenced by get_exp_ing_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _exp_ing_stop
std::string ossimplugins::ProcessingParameters::_exp_ing_stop
protected
Definition at line 795 of file ProcessingParameters.h.
Referenced by get_exp_ing_stop(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _fm_crc_err
double ossimplugins::ProcessingParameters::_fm_crc_err
protected
Definition at line 839 of file ProcessingParameters.h.
Referenced by get_fm_crc_err(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _gics_reqd
std::string ossimplugins::ProcessingParameters::_gics_reqd
protected
Definition at line 1072 of file ProcessingParameters.h.
Referenced by get_gics_reqd(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _gn_corctn_fctr
double ossimplugins::ProcessingParameters::_gn_corctn_fctr
protected
Definition at line 927 of file ProcessingParameters.h.
Referenced by get_gn_corctn_fctr(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _img_cumu_dist
double ossimplugins::ProcessingParameters::_img_cumu_dist[3]
protected
Definition at line 1015 of file ProcessingParameters.h.
Referenced by get_img_cumu_dist(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _img_hist_mean
double ossimplugins::ProcessingParameters::_img_hist_mean
protected
Definition at line 1011 of file ProcessingParameters.h.
Referenced by get_img_hist_mean(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _inp_media
std::string ossimplugins::ProcessingParameters::_inp_media
protected
Input media
Definition at line 779 of file ProcessingParameters.h.
Referenced by get_inp_media(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _large_gap
int ossimplugins::ProcessingParameters::_large_gap
protected
Definition at line 831 of file ProcessingParameters.h.
Referenced by get_large_gap(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _map_system
std::string ossimplugins::ProcessingParameters::_map_system
protected
Definition at line 1120 of file ProcessingParameters.h.
Referenced by get_map_system(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _media_id
std::string ossimplugins::ProcessingParameters::_media_id
protected
Definition at line 1104 of file ProcessingParameters.h.
Referenced by get_media_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _miss_ln
int ossimplugins::ProcessingParameters::_miss_ln
protected
Definition at line 823 of file ProcessingParameters.h.
Referenced by get_miss_ln(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _mn_sig_lev
double ossimplugins::ProcessingParameters::_mn_sig_lev[10]
protected
Definition at line 815 of file ProcessingParameters.h.
Referenced by get_mn_sig_lev(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _n_beams
int ossimplugins::ProcessingParameters::_n_beams
protected
Number of beams
Definition at line 959 of file ProcessingParameters.h.
Referenced by get_n_beams(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _n_dopcen
int ossimplugins::ProcessingParameters::_n_dopcen
protected
Definition at line 1031 of file ProcessingParameters.h.
Referenced by get_n_dopcen(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _n_image_pix
int ossimplugins::ProcessingParameters::_n_image_pix
protected
Definition at line 999 of file ProcessingParameters.h.
Referenced by get_n_image_pix(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _n_pix_updates
int ossimplugins::ProcessingParameters::_n_pix_updates
protected
Definition at line 967 of file ProcessingParameters.h.
Referenced by get_n_pix_updates(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _n_srgr
int ossimplugins::ProcessingParameters::_n_srgr
protected
Definition at line 1060 of file ProcessingParameters.h.
Referenced by get_n_srgr(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _n_tape_id
int ossimplugins::ProcessingParameters::_n_tape_id
protected
Definition at line 783 of file ProcessingParameters.h.
Referenced by get_n_tape_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _n_temp_set
int ossimplugins::ProcessingParameters::_n_temp_set
protected
Definition at line 991 of file ProcessingParameters.h.
Referenced by get_n_temp_set(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _num_state_vectors
int ossimplugins::ProcessingParameters::_num_state_vectors
protected
Definition at line 1152 of file ProcessingParameters.h.
Referenced by get_num_state_vectors(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _orb_data_src
std::string ossimplugins::ProcessingParameters::_orb_data_src
protected
Orbit data source
Definition at line 935 of file ProcessingParameters.h.
Referenced by get_orb_data_src(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pix_count
BeamPixelCountRecord ossimplugins::ProcessingParameters::_pix_count[20]
protected
Beam pixel counts.
Definition at line 971 of file ProcessingParameters.h.
Referenced by get_pix_count(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pix_overlap
int ossimplugins::ProcessingParameters::_pix_overlap
protected
Definition at line 955 of file ProcessingParameters.h.
Referenced by get_pix_overlap(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pixel_spacing
double ossimplugins::ProcessingParameters::_pixel_spacing
protected
Definition at line 1068 of file ProcessingParameters.h.
Referenced by get_pixel_spacing(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _post_img_gn
double ossimplugins::ProcessingParameters::_post_img_gn
protected
Definition at line 1023 of file ProcessingParameters.h.
Referenced by get_post_img_gn(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _prc_satur_pix
double ossimplugins::ProcessingParameters::_prc_satur_pix
protected
Definition at line 1007 of file ProcessingParameters.h.
Referenced by get_prc_satur_pix(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _prc_zero_pix
double ossimplugins::ProcessingParameters::_prc_zero_pix
protected
Percent zero pixels
Definition at line 1003 of file ProcessingParameters.h.
Referenced by get_prc_zero_pix(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pre_img_gn
double ossimplugins::ProcessingParameters::_pre_img_gn
protected
Definition at line 1019 of file ProcessingParameters.h.
Referenced by get_pre_img_gn(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _prf_changes
int ossimplugins::ProcessingParameters::_prf_changes
protected
Number of unexpected PRF changes
Definition at line 847 of file ProcessingParameters.h.
Referenced by get_prf_changes(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _proc_start
std::string ossimplugins::ProcessingParameters::_proc_start
protected
Processing start time
Definition at line 807 of file ProcessingParameters.h.
Referenced by get_proc_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _proc_stop
std::string ossimplugins::ProcessingParameters::_proc_stop
protected
Processing stop time
Definition at line 811 of file ProcessingParameters.h.
Referenced by get_proc_stop(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _prod_type
std::string ossimplugins::ProcessingParameters::_prod_type
protected
Definition at line 1116 of file ProcessingParameters.h.
Referenced by get_prod_type(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pulse_bandw
int ossimplugins::ProcessingParameters::_pulse_bandw
protected
Pulse bandwidth code
Definition at line 915 of file ProcessingParameters.h.
Referenced by get_pulse_bandw(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pulse_cnt_1
int ossimplugins::ProcessingParameters::_pulse_cnt_1
protected
Pulse count 1
Definition at line 939 of file ProcessingParameters.h.
Referenced by get_pulse_cnt_1(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pulse_cnt_2
int ossimplugins::ProcessingParameters::_pulse_cnt_2
protected
Pulse count 2
Definition at line 943 of file ProcessingParameters.h.
Referenced by get_pulse_cnt_2(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pwin_end
double ossimplugins::ProcessingParameters::_pwin_end
protected
Processing window end time (sec)
Definition at line 979 of file ProcessingParameters.h.
Referenced by get_pwin_end(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _pwin_start
double ossimplugins::ProcessingParameters::_pwin_start
protected
Processing window start time (sec)
Definition at line 975 of file ProcessingParameters.h.
Referenced by get_pwin_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rec_seq
int ossimplugins::ProcessingParameters::_rec_seq
protected
Record sequence number.
Definition at line 768 of file ProcessingParameters.h.
Referenced by get_rec_seq(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _recd_type
std::string ossimplugins::ProcessingParameters::_recd_type
protected
Recording type
Definition at line 983 of file ProcessingParameters.h.
Referenced by get_recd_type(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rej_bf_start
int ossimplugins::ProcessingParameters::_rej_bf_start
protected
Range lines rejected before start time
Definition at line 859 of file ProcessingParameters.h.
Referenced by get_rej_bf_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rej_few_fram
int ossimplugins::ProcessingParameters::_rej_few_fram
protected
Range lines rejected due to too few frames
Definition at line 863 of file ProcessingParameters.h.
Referenced by get_rej_few_fram(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rej_ln
int ossimplugins::ProcessingParameters::_rej_ln
protected
Number of rejected lines
Definition at line 827 of file ProcessingParameters.h.
Referenced by get_rej_ln(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rej_many_fram
int ossimplugins::ProcessingParameters::_rej_many_fram
protected
Range lines rejected due to too many frames
Definition at line 867 of file ProcessingParameters.h.
Referenced by get_rej_many_fram(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rej_mchn_err
int ossimplugins::ProcessingParameters::_rej_mchn_err
protected
Frames rejected due to master channel error
Definition at line 871 of file ProcessingParameters.h.
Referenced by get_rej_mchn_err(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rej_rec_type
int ossimplugins::ProcessingParameters::_rej_rec_type
protected
Frames rejected due to incorrect recording type
Definition at line 879 of file ProcessingParameters.h.
Referenced by get_rej_rec_type(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rej_vchn_err
int ossimplugins::ProcessingParameters::_rej_vchn_err
protected
Frames rejected due to virtual channel error
Definition at line 875 of file ProcessingParameters.h.
Referenced by get_rej_vchn_err(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rep_agc_attn
double ossimplugins::ProcessingParameters::_rep_agc_attn
protected
Replica AGC attenuation
Definition at line 923 of file ProcessingParameters.h.
Referenced by get_rep_agc_attn(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rep_energy_gn
double ossimplugins::ProcessingParameters::_rep_energy_gn
protected
Replica energy gain correction
Definition at line 931 of file ProcessingParameters.h.
Referenced by get_rep_energy_gn(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rng_amp_coef
double ossimplugins::ProcessingParameters::_rng_amp_coef[4]
protected
Range reference amplitude coefficients
Definition at line 899 of file ProcessingParameters.h.
Referenced by get_rng_amp_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rng_phas_coef
double ossimplugins::ProcessingParameters::_rng_phas_coef[4]
protected
Range reference phase coefficients
Definition at line 903 of file ProcessingParameters.h.
Referenced by get_rng_phas_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rng_ref_src
std::string ossimplugins::ProcessingParameters::_rng_ref_src
protected
Range reference function source
Definition at line 895 of file ProcessingParameters.h.
Referenced by get_rng_ref_src(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _satellite_id
std::string ossimplugins::ProcessingParameters::_satellite_id
protected
Satellite identifier
Definition at line 1084 of file ProcessingParameters.h.
Referenced by get_satellite_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _scene_id
std::string ossimplugins::ProcessingParameters::_scene_id
protected
SGF product scene identifier
Definition at line 1096 of file ProcessingParameters.h.
Referenced by get_scene_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _scr_data_ind
int ossimplugins::ProcessingParameters::_scr_data_ind
protected
Source data quality indicator
Definition at line 819 of file ProcessingParameters.h.
Referenced by get_scr_data_ind(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _sens_config
std::string ossimplugins::ProcessingParameters::_sens_config
protected
Sensor configuration
Definition at line 883 of file ProcessingParameters.h.
Referenced by get_sens_config(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _sens_orient
std::string ossimplugins::ProcessingParameters::_sens_orient
protected
Sensor orientation
Definition at line 887 of file ProcessingParameters.h.
Referenced by get_sens_orient(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _skipd_frams
int ossimplugins::ProcessingParameters::_skipd_frams
protected
Number of skipped frames
Definition at line 855 of file ProcessingParameters.h.
Referenced by get_skipd_frams(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _slow_time_coef
double ossimplugins::ProcessingParameters::_slow_time_coef[5]
protected
Slow time coefficients
Todo:
Definition at line 1056 of file ProcessingParameters.h.
Referenced by get_slow_time_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _span_x
double ossimplugins::ProcessingParameters::_span_x
protected
GICS output product size - map eastings (km)
Definition at line 1132 of file ProcessingParameters.h.
Referenced by get_span_x(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _span_y
double ossimplugins::ProcessingParameters::_span_y
protected
GICS output product size - map northings (km)
Definition at line 1136 of file ProcessingParameters.h.
Referenced by get_span_y(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _srgr_coefset
SRGRCoefficientSetRecord ossimplugins::ProcessingParameters::_srgr_coefset[20]
protected
SRGR coefficient sets.
Definition at line 1064 of file ProcessingParameters.h.
Referenced by get_srgr_coefset(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _state_time
std::string ossimplugins::ProcessingParameters::_state_time
protected
Time of the first state vector
Definition at line 1148 of file ProcessingParameters.h.
Referenced by get_state_time(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _state_time_inc
double ossimplugins::ProcessingParameters::_state_time_inc
protected
Time increment between state vectors
Definition at line 1156 of file ProcessingParameters.h.
Referenced by get_state_time_inc(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _sych_marker
std::string ossimplugins::ProcessingParameters::_sych_marker
protected
Frame synch marker
Definition at line 891 of file ProcessingParameters.h.
Referenced by get_sych_marker(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _tape_id
std::string ossimplugins::ProcessingParameters::_tape_id[10]
protected
Tape identifiers
Definition at line 787 of file ProcessingParameters.h.
Referenced by get_tape_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _temp
TemperatureSettingsRecord ossimplugins::ProcessingParameters::_temp[20]
protected
Temperature settings.
Definition at line 995 of file ProcessingParameters.h.
Referenced by get_temp(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _temp_set_inc
double ossimplugins::ProcessingParameters::_temp_set_inc
protected
Time increment between temperature settings (sec)
Definition at line 987 of file ProcessingParameters.h.
Referenced by get_temp_set_inc(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _user_id
std::string ossimplugins::ProcessingParameters::_user_id
protected
User id
Definition at line 1088 of file ProcessingParameters.h.
Referenced by get_user_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _wo_date
std::string ossimplugins::ProcessingParameters::_wo_date
protected
Work order entry date
Definition at line 1080 of file ProcessingParameters.h.
Referenced by get_wo_date(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _wo_number
std::string ossimplugins::ProcessingParameters::_wo_number
protected
Work order identifier
Definition at line 1076 of file ProcessingParameters.h.
Referenced by get_wo_number(), ossimplugins::operator<<(), and ossimplugins::operator>>().
