Public Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::RadiometricCompensationData Class Reference
This class is able to read a Radiometric Compensation data record. More...
#include <RadiometricCompensationData.h>
Inheritance diagram for ossimplugins::RadiometricCompensationData:
ossimplugins::RadarSatRecord
 RadiometricCompensationData ()
 Constructor. More...
 ~RadiometricCompensationData ()
 Destructor. More...
 RadiometricCompensationData (const RadiometricCompensationData &rhs)
 Copy constructor. More...
RadiometricCompensationDataoperator= (const RadiometricCompensationData &rhs)
 Copy operator. More...
RadarSatRecordInstanciate ()
 This function is able to create a new instance of the class. More...
RadarSatRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Reads the class data from a stream. More...
void Write (std::ostream &os)
 Writes the class to a stream. More...
int get_seq_num ()
 Record sequence number. More...
int get_chan_ind ()
 SAR channel indicator. More...
int get_n_dset ()
Number of data sets in record More...
int get_dset_size ()
Compensation data set size More...
CompensationDataRecordget_dset ()
 Compensation data set records. More...
- Public Member Functions inherited from ossimplugins::RadarSatRecord
 RadarSatRecord (std::string mnemonic)
virtual ~RadarSatRecord ()
 Destructor. More...
 RadarSatRecord (const RadarSatRecord &rhs)
std::string get_mnemonic ()
int _seq_num
int _chan_ind
int _n_dset
int _dset_size
CompensationDataRecord _dset [4]
- Protected Attributes inherited from ossimplugins::RadarSatRecord
std::string _mnemonic
Friends
std::ostream & operator<< (std::ostream &os, const RadiometricCompensationData &data)
 This function writes the RadiometricCompensationData in a stream. More...
std::istream & operator>> (std::istream &is, RadiometricCompensationData &data)
 This function reads a RadiometricCompensationData from a stream. More...
Detailed Description
Definition at line 28 of file RadiometricCompensationData.h.
◆ RadiometricCompensationData() [1/2]
ossimplugins::RadiometricCompensationData::RadiometricCompensationData ( )
Constructor.
Definition at line 16 of file RadiometricCompensationData.cpp.
Referenced by Clone(), and Instanciate().
16  : RadarSatRecord("radi_comp_rec")
17  {
18  }
RadarSatRecord(std::string mnemonic)
Constructor.
◆ ~RadiometricCompensationData()
ossimplugins::RadiometricCompensationData::~RadiometricCompensationData ( )
Destructor.
Definition at line 20 of file RadiometricCompensationData.cpp.
21  {
22  }
◆ RadiometricCompensationData() [2/2]
ossimplugins::RadiometricCompensationData::RadiometricCompensationData ( const RadiometricCompensationData rhs)
Copy constructor.
Definition at line 70 of file RadiometricCompensationData.cpp.
References _chan_ind, _dset, _dset_size, _n_dset, and _seq_num.
70  :
71  RadarSatRecord(rhs)
72  {
73  _seq_num = rhs._seq_num;
74
75  _chan_ind = rhs._chan_ind;
76
77  _n_dset = rhs._n_dset;
78
79  _dset_size = rhs._dset_size;
80
81  for (int i=0;i<4;i++)
82  {
83  _dset[i] = rhs._dset[i];
84  }
85  }
Constructor.
CompensationDataRecord _dset[4]
Member Function Documentation
◆ Clone()
RadarSatRecord* ossimplugins::RadiometricCompensationData::Clone ( )
inlinevirtual
Implements ossimplugins::RadarSatRecord.
Definition at line 71 of file RadiometricCompensationData.h.
References RadiometricCompensationData().
72  {
73  return new RadiometricCompensationData(*this);
74  };
◆ get_chan_ind()
int ossimplugins::RadiometricCompensationData::get_chan_ind ( )
inline
Definition at line 102 of file RadiometricCompensationData.h.
References _chan_ind.
103  {
104  return _chan_ind;
105  };
◆ get_dset()
CompensationDataRecord* ossimplugins::RadiometricCompensationData::get_dset ( )
inline
Definition at line 123 of file RadiometricCompensationData.h.
References _dset.
124  {
125  return _dset;
126  };
◆ get_dset_size()
int ossimplugins::RadiometricCompensationData::get_dset_size ( )
inline
Definition at line 116 of file RadiometricCompensationData.h.
References _dset_size.
117  {
118  return _dset_size;
119  };
◆ get_n_dset()
int ossimplugins::RadiometricCompensationData::get_n_dset ( )
inline
Definition at line 109 of file RadiometricCompensationData.h.
References _n_dset.
110  {
111  return _n_dset;
112  };
◆ get_seq_num()
int ossimplugins::RadiometricCompensationData::get_seq_num ( )
inline
Definition at line 95 of file RadiometricCompensationData.h.
References _seq_num.
96  {
97  return _seq_num;
98  };
◆ Instanciate()
RadarSatRecord* ossimplugins::RadiometricCompensationData::Instanciate ( )
inlinevirtual
Definition at line 63 of file RadiometricCompensationData.h.
64  {
65  return new RadiometricCompensationData();
66  };
◆ operator=()
RadiometricCompensationData & ossimplugins::RadiometricCompensationData::operator= ( const RadiometricCompensationData rhs)
Copy operator.
Definition at line 87 of file RadiometricCompensationData.cpp.
88  {
89  return *this;
90  }
◆ Read()
void ossimplugins::RadiometricCompensationData::Read ( std::istream &  is)
inlinevirtual
Definition at line 79 of file RadiometricCompensationData.h.
80  {
81  is>>*this;
82  };
◆ Write()
void ossimplugins::RadiometricCompensationData::Write ( std::ostream &  os)
inlinevirtual
Definition at line 87 of file RadiometricCompensationData.h.
88  {
89  os<<*this;
90  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const RadiometricCompensationData data
friend
Definition at line 24 of file RadiometricCompensationData.cpp.
25  {
26  os<<"seq_num:"<<data._seq_num<<std::endl;
27
28  os<<"chan_ind:"<<data._chan_ind<<std::endl;
29
30  os<<"n_dset:"<<data._n_dset<<std::endl;
31
32  os<<"dset_size:"<<data._dset_size<<std::endl;
33
34  for (int i=0;i<4;i++)
35  {
36  os<<"dset["<<i<<"]:"<<data._dset[i]<<std::endl;
37  }
38  return os;
39  }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 41 of file RadiometricCompensationData.cpp.
42  {
43  char buf[9];
44  buf[8] = '\0';
45
46  is.read(buf,4);
47  buf[4] = '\0';
48  data._seq_num = atoi(buf);
49
50  is.read(buf,4);
51  buf[4] = '\0';
52  data._chan_ind = atoi(buf);
53
54  is.read(buf,8);
55  buf[8] = '\0';
56  data._n_dset = atoi(buf);
57
58  is.read(buf,8);
59  buf[8] = '\0';
60  data._dset_size = atoi(buf);
61
62  for (int i=0;i<4;i++)
63  {
64  is>> data._dset[i];
65  }
66
67  return is;
68  }
Member Data Documentation
◆ _chan_ind
int ossimplugins::RadiometricCompensationData::_chan_ind
protected
◆ _dset
CompensationDataRecord ossimplugins::RadiometricCompensationData::_dset[4]
protected
Definition at line 148 of file RadiometricCompensationData.h.
Referenced by get_dset(), ossimplugins::operator<<(), ossimplugins::operator>>(), and RadiometricCompensationData().
◆ _dset_size
int ossimplugins::RadiometricCompensationData::_dset_size
protected
◆ _n_dset
int ossimplugins::RadiometricCompensationData::_n_dset
protected
Definition at line 140 of file RadiometricCompensationData.h.
Referenced by get_n_dset(), ossimplugins::operator<<(), ossimplugins::operator>>(), and RadiometricCompensationData().
◆ _seq_num
int ossimplugins::RadiometricCompensationData::_seq_num
protected
