Public Member Functions | Public Attributes | Friends | List of all members
ossimplugins::SRGRConversionParameters Class Reference
This class is able to read the ASAR SRGRConversionParameters record. More...
#include <SRGRConversionParameters.h>
Inheritance diagram for ossimplugins::SRGRConversionParameters:
ossimplugins::EnvisatAsarRecord
 SRGRConversionParameters ()
 Constructor. More...
virtual ~SRGRConversionParameters ()
 Destructor. More...
 SRGRConversionParameters (const SRGRConversionParameters &rhs)
 Copy constructor. More...
SRGRConversionParametersoperator= (const SRGRConversionParameters &rhs)
 Copy operator. More...
EnvisatAsarRecordInstanciate ()
 This function is able to create a new instance of the class. More...
EnvisatAsarRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Reads the class data from a stream. More...
void Write (std::ostream &os)
 Writes the class to a stream. More...
int get_first_zero_doppler_time_day ()
 first_zero_doppler_time day More...
unsigned int get_first_zero_doppler_time_sec ()
 first_zero_doppler_time second More...
unsigned int get_first_zero_doppler_time_microsec ()
 first_zero_doppler_time micro sec More...
bool get_attach_flag ()
 attach_flag More...
float get_slant_range_time ()
 input_mean_flag More...
float get_ground_range_origin ()
 input_std_dev_flag More...
float * get_srgr_coef ()
 input_gaps_flag More...
- Public Member Functions inherited from ossimplugins::EnvisatAsarRecord
 EnvisatAsarRecord (std::string mnemonic)
virtual ~EnvisatAsarRecord ()
 Destructor. More...
 EnvisatAsarRecord (const EnvisatAsarRecord &rhs)
std::string get_mnemonic ()
 Returns the mnemonic of the record. More...
Public Attributes
int _first_zero_doppler_time_day
unsigned int _first_zero_doppler_time_sec
 first_zero_doppler_time sec More...
unsigned int _first_zero_doppler_time_microsec
 first_zero_doppler_time microsec More...
bool _attach_flag
 attach_flag More...
float _slant_range_time
float _ground_range_origin
float _srgr_coef [5]
Friends
std::ostream & operator<< (std::ostream &os, const SRGRConversionParameters &data)
 This function writes the SRGRConversionParameters in a stream. More...
std::istream & operator>> (std::istream &is, SRGRConversionParameters &data)
 This function reads a SRGRConversionParameters from a stream. More...
Additional Inherited Members
- Protected Member Functions inherited from ossimplugins::EnvisatAsarRecord
template<typename T >
void SwitchEndian (T &value)
 This function switches the LSB value and the MSB value of the parameter. More...
- Protected Attributes inherited from ossimplugins::EnvisatAsarRecord
std::string _mnemonic
Detailed Description
Definition at line 25 of file SRGRConversionParameters.h.
◆ SRGRConversionParameters() [1/2]
ossimplugins::SRGRConversionParameters::SRGRConversionParameters ( )
Constructor.
Definition at line 16 of file SRGRConversionParameters.cpp.
Referenced by Clone(), and Instanciate().
16  : EnvisatAsarRecord("SRGRConversionParameters_rec")
17  {
18  }
EnvisatAsarRecord(std::string mnemonic)
Constructor.
◆ ~SRGRConversionParameters()
ossimplugins::SRGRConversionParameters::~SRGRConversionParameters ( )
virtual
Destructor.
Definition at line 20 of file SRGRConversionParameters.cpp.
21  {
22  }
◆ SRGRConversionParameters() [2/2]
ossimplugins::SRGRConversionParameters::SRGRConversionParameters ( const SRGRConversionParameters rhs)
Copy constructor.
Definition at line 82 of file SRGRConversionParameters.cpp.
References _srgr_coef.
82  :
83  EnvisatAsarRecord(rhs),
84  _first_zero_doppler_time_day(rhs._first_zero_doppler_time_day),
85  _first_zero_doppler_time_sec(rhs._first_zero_doppler_time_sec),
86  _first_zero_doppler_time_microsec(rhs._first_zero_doppler_time_microsec),
87  _attach_flag(rhs._attach_flag),
88  _slant_range_time(rhs._slant_range_time),
89  _ground_range_origin(rhs._ground_range_origin)
90  {
91  for (int i = 0; i<5; i++) {
92  _srgr_coef[i] = rhs._srgr_coef[i];
93  }
94  }
Constructor.
Member Function Documentation
◆ Clone()
EnvisatAsarRecord* ossimplugins::SRGRConversionParameters::Clone ( )
inlinevirtual
Implements ossimplugins::EnvisatAsarRecord.
Definition at line 69 of file SRGRConversionParameters.h.
References SRGRConversionParameters().
70  {
71  return new SRGRConversionParameters(*this);
72  };
◆ get_attach_flag()
bool ossimplugins::SRGRConversionParameters::get_attach_flag ( )
inline
attach_flag
Definition at line 115 of file SRGRConversionParameters.h.
References _attach_flag.
116  {
117  return _attach_flag;
118  };
◆ get_first_zero_doppler_time_day()
int ossimplugins::SRGRConversionParameters::get_first_zero_doppler_time_day ( )
inline
Definition at line 94 of file SRGRConversionParameters.h.
References _first_zero_doppler_time_day.
Referenced by ossimplugins::ossimEnvisatAsarModel::saveState().
95  {
97  };
◆ get_first_zero_doppler_time_microsec()
unsigned int ossimplugins::SRGRConversionParameters::get_first_zero_doppler_time_microsec ( )
inline
Definition at line 108 of file SRGRConversionParameters.h.
References _first_zero_doppler_time_microsec.
109  {
111  };
◆ get_first_zero_doppler_time_sec()
unsigned int ossimplugins::SRGRConversionParameters::get_first_zero_doppler_time_sec ( )
inline
Definition at line 101 of file SRGRConversionParameters.h.
References _first_zero_doppler_time_sec.
102  {
104  };
◆ get_ground_range_origin()
float ossimplugins::SRGRConversionParameters::get_ground_range_origin ( )
inline
input_std_dev_flag
Definition at line 129 of file SRGRConversionParameters.h.
References _ground_range_origin.
130  {
131  return _ground_range_origin;
132  };
◆ get_slant_range_time()
float ossimplugins::SRGRConversionParameters::get_slant_range_time ( )
inline
input_mean_flag
Definition at line 122 of file SRGRConversionParameters.h.
References _slant_range_time.
123  {
124  return _slant_range_time;
125  };
◆ get_srgr_coef()
float* ossimplugins::SRGRConversionParameters::get_srgr_coef ( )
inline
input_gaps_flag
Definition at line 136 of file SRGRConversionParameters.h.
137  {
138  return _srgr_coef;
139  };
◆ Instanciate()
EnvisatAsarRecord* ossimplugins::SRGRConversionParameters::Instanciate ( )
inlinevirtual
Definition at line 61 of file SRGRConversionParameters.h.
62  {
63  return new SRGRConversionParameters();
64  };
◆ operator=()
SRGRConversionParameters & ossimplugins::SRGRConversionParameters::operator= ( const SRGRConversionParameters rhs)
Copy operator.
Definition at line 96 of file SRGRConversionParameters.cpp.
References _attach_flag, _first_zero_doppler_time_day, _first_zero_doppler_time_microsec, _first_zero_doppler_time_sec, _slant_range_time, and _srgr_coef.
97  {
98  _first_zero_doppler_time_day = rhs._first_zero_doppler_time_day;
99  _first_zero_doppler_time_sec = rhs._first_zero_doppler_time_sec;
100  _first_zero_doppler_time_microsec = rhs._first_zero_doppler_time_microsec;
101  _attach_flag = rhs._attach_flag;
102  _slant_range_time = rhs._slant_range_time;
103
104  for (int i = 0; i<5; i++) {
105  _srgr_coef[i] = rhs._srgr_coef[i];
106  }
107
108  return *this;
109  }
◆ Read()
void ossimplugins::SRGRConversionParameters::Read ( std::istream &  is)
inlinevirtual
Definition at line 77 of file SRGRConversionParameters.h.
78  {
79  is>>*this;
80  };
◆ Write()
void ossimplugins::SRGRConversionParameters::Write ( std::ostream &  os)
inlinevirtual
Definition at line 85 of file SRGRConversionParameters.h.
86  {
87  os<<*this;
88  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const SRGRConversionParameters data
friend
Definition at line 24 of file SRGRConversionParameters.cpp.
25  {
26  os<<"first_zero_doppler_time_day:"<<data._first_zero_doppler_time_day<<std::endl;
27
28  os<<"first_zero_doppler_time_sec:"<<data._first_zero_doppler_time_sec<<std::endl;
29
30  os<<"first_zero_doppler_time_microsec:"<<data._first_zero_doppler_time_microsec<<std::endl;
31
32  os<<"attach_flag:"<<data._attach_flag<<std::endl;
33
34  os<<"_slant_range_time:"<<data._slant_range_time<<std::endl;
35
36  os<<"_ground_range_origin:"<<data._ground_range_origin<<std::endl;
37
38  for (int i = 0; i<5; i++) {
39  os<<"_srgr_coef[i]:"<<data._srgr_coef[i]<<std::endl;
40  }
41
42  return os;
43
44  }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 46 of file SRGRConversionParameters.cpp.
47  {
48  char buf14[15];
49  buf14[14] = '\0';
50  // char buf12[13];
51  // buf12[12] = '\0';
52
53
54  is.read((char*)&(data._first_zero_doppler_time_day),4);
55  data.SwitchEndian(data._first_zero_doppler_time_day);
56
57  is.read((char*)&(data._first_zero_doppler_time_sec),4);
58  data.SwitchEndian(data._first_zero_doppler_time_sec);
59
60  is.read((char*)&(data._first_zero_doppler_time_microsec),4);
61  data.SwitchEndian(data._first_zero_doppler_time_microsec);
62
63  is.read((char*)&(data._attach_flag),1);
64
65  is.read((char*)&(data._slant_range_time),4);
66  data.SwitchEndian(data._slant_range_time);
67
68  is.read((char*)&(data._ground_range_origin),4);
69  data.SwitchEndian(data._ground_range_origin);
70
71  for (int i = 0; i<5; i++) {
72  is.read((char*)&(data._srgr_coef[i]),4);
73  data.SwitchEndian(data._srgr_coef[i]);
74  }
75
76  is.read(buf14,14);
77
78  return is;
79  }
Member Data Documentation
◆ _attach_flag
bool ossimplugins::SRGRConversionParameters::_attach_flag
◆ _first_zero_doppler_time_day
int ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_day
Definition at line 139 of file SRGRConversionParameters.h.
Referenced by get_first_zero_doppler_time_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_zero_doppler_time_microsec
unsigned int ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_microsec
Definition at line 152 of file SRGRConversionParameters.h.
Referenced by get_first_zero_doppler_time_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _first_zero_doppler_time_sec
unsigned int ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_sec
Definition at line 148 of file SRGRConversionParameters.h.
Referenced by get_first_zero_doppler_time_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _ground_range_origin
float ossimplugins::SRGRConversionParameters::_ground_range_origin
input_std_dev_flag
Definition at line 164 of file SRGRConversionParameters.h.
Referenced by get_ground_range_origin(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _slant_range_time
float ossimplugins::SRGRConversionParameters::_slant_range_time
◆ _srgr_coef
float ossimplugins::SRGRConversionParameters::_srgr_coef[5]
