Public Member Functions | Protected Attributes | Static Protected Attributes | Friends | List of all members
ossimplugins::VolumeDir Class Reference
This class is able to read the volume directory file of the RadarSat file structure. More...
#include <VolumeDir.h>
 VolumeDir ()
 Constructor. More...
 ~VolumeDir ()
 Destructor. More...
 VolumeDir (const VolumeDir &rhs)
 Copy constructor. More...
VolumeDiroperator= (const VolumeDir &rhs)
 Copy operator. More...
void ClearRecords ()
 Removes all the previous records from the VolumeDir. More...
VolumeDescriptorRecordget_VolumeDescriptorRecord ()
SARLeaderFilePointerRecordget_SARLeaderFilePointerRecord ()
ImageOptionsFilePointerRecordget_ImageOptionsFilePointerRecord ()
SARTrailerFilePointerRecordget_SARTrailerFilePointerRecord ()
TextRecordget_TextRecord ()
std::map< int, RadarSatRecord * > _records
static const int VolumeDescriptorRecordID = 5
static const int SARLeaderFilePointerRecordID = 2
static const int ImageOptionsFilePointerRecordID = 3
static const int SARTrailerFilePointerRecordID = 4
static const int TextRecordID = 1
Friends
std::ostream & operator<< (std::ostream &os, const VolumeDir &data)
 This function writes the VolumeDir in a stream. More...
std::istream & operator>> (std::istream &is, VolumeDir &data)
 This function reads a VolumeDir from a stream. More...
Detailed Description
Author
CS, Mickaƫl Savinaud
Version
1.0
Date
25-02-2011
Definition at line 34 of file VolumeDir.h.
◆ VolumeDir() [1/2]
ossimplugins::VolumeDir::VolumeDir ( )
Constructor.
Definition at line 25 of file VolumeDir.cpp.
26 {
27 }
◆ ~VolumeDir()
ossimplugins::VolumeDir::~VolumeDir ( )
Destructor.
Definition at line 29 of file VolumeDir.cpp.
References ClearRecords().
30 {
31  ClearRecords();
32 }
void ClearRecords()
Definition: VolumeDir.cpp:104
◆ VolumeDir() [2/2]
ossimplugins::VolumeDir::VolumeDir ( const VolumeDir rhs)
Copy constructor.
Definition at line 81 of file VolumeDir.cpp.
References _records.
82 {
83  std::map<int, RadarSatRecord*>::const_iterator it = rhs._records.begin();
84  while(it != rhs._records.end())
85  {
86  _records[(*it).first] = (*it).second->Clone();
87  ++it;
88  }
89 }
Definition: VolumeDir.h:79
Member Function Documentation
◆ ClearRecords()
void ossimplugins::VolumeDir::ClearRecords ( )
Definition at line 104 of file VolumeDir.cpp.
Referenced by operator=(), ossimplugins::operator>>(), and ~VolumeDir().
105 {
106  std::map<int, RadarSatRecord*>::const_iterator it = _records.begin();
107  while(it != _records.end())
108  {
109  delete (*it).second;
110  ++it;
111  }
112  _records.clear();
113 }
◆ get_ImageOptionsFilePointerRecord()
ImageOptionsFilePointerRecord * ossimplugins::VolumeDir::get_ImageOptionsFilePointerRecord ( )
Definition at line 120 of file VolumeDir.cpp.
References _records, and ImageOptionsFilePointerRecordID.
121 {
123 }
FilePointerRecord ImageOptionsFilePointerRecord
Definition: VolumeDir.h:83
◆ get_SARLeaderFilePointerRecord()
SARLeaderFilePointerRecord * ossimplugins::VolumeDir::get_SARLeaderFilePointerRecord ( )
Definition at line 115 of file VolumeDir.cpp.
References _records, and SARLeaderFilePointerRecordID.
116 {
118 }
Definition: VolumeDir.h:82
FilePointerRecord SARLeaderFilePointerRecord
◆ get_SARTrailerFilePointerRecord()
SARTrailerFilePointerRecord * ossimplugins::VolumeDir::get_SARTrailerFilePointerRecord ( )
Definition at line 125 of file VolumeDir.cpp.
References _records, and SARTrailerFilePointerRecordID.
126 {
128 }
Definition: VolumeDir.h:84
FilePointerRecord SARTrailerFilePointerRecord
◆ get_TextRecord()
TextRecord * ossimplugins::VolumeDir::get_TextRecord ( )
Definition at line 130 of file VolumeDir.cpp.
References _records, and TextRecordID.
131 {
132  return (TextRecord*)_records[TextRecordID];
133 }
Definition: VolumeDir.h:85
◆ get_VolumeDescriptorRecord()
VolumeDescriptorRecord * ossimplugins::VolumeDir::get_VolumeDescriptorRecord ( )
Definition at line 135 of file VolumeDir.cpp.
References _records, and VolumeDescriptorRecordID.
136 {
137  return (VolumeDescriptorRecord*)_records[VolumeDescriptorRecordID];
138 }
Definition: VolumeDir.h:81
◆ operator=()
VolumeDir & ossimplugins::VolumeDir::operator= ( const VolumeDir rhs)
Copy operator.
Definition at line 91 of file VolumeDir.cpp.
References _records, and ClearRecords().
92 {
93  ClearRecords();
94  std::map<int, RadarSatRecord*>::const_iterator it = rhs._records.begin();
95  while(it != rhs._records.end())
96  {
97  _records[(*it).first] = (*it).second->Clone();
98  ++it;
99  }
100
101  return *this;
102 }
void ClearRecords()
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const VolumeDir data
friend
Definition at line 34 of file VolumeDir.cpp.
35 {
36  std::map<int, RadarSatRecord*>::const_iterator it = data._records.begin();
37  while(it != data._records.end())
38  {
39  (*it).second->Write(os);
40  ++it;
41  }
42  return os;
43
44 }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
VolumeDir data
friend
Definition at line 46 of file VolumeDir.cpp.
47 {
48  VolumeDirFactory factory;
49
50  data.ClearRecords();
51
52  RadarSatRecordHeader header;
53  bool eof = false;
54  while(!eof)
55  {
56  is>>header;
57  if(is.eof())
58  {
59  eof = true;
60  }
61  else
62  {
63  RadarSatRecord* record = factory.Instanciate(header.get_rec_seq());
64  if (record != NULL)
65  {
66  record->Read(is);
67  data._records[header.get_rec_seq()] = record;
68  }
69  else
70  {
71  char* buff = new char[header.get_length()-12];
72  is.read(buff, header.get_length()-12);
73  delete[] buff;
74  }
75  }
76  }
77  return is;
78 }
Member Data Documentation
◆ _records
std::map<int, RadarSatRecord*> ossimplugins::VolumeDir::_records
protected
◆ ImageOptionsFilePointerRecordID
const int ossimplugins::VolumeDir::ImageOptionsFilePointerRecordID = 3
staticprotected
Definition at line 83 of file VolumeDir.h.
Referenced by get_ImageOptionsFilePointerRecord().
◆ SARLeaderFilePointerRecordID
const int ossimplugins::VolumeDir::SARLeaderFilePointerRecordID = 2
staticprotected
Definition at line 82 of file VolumeDir.h.
Referenced by get_SARLeaderFilePointerRecord().
◆ SARTrailerFilePointerRecordID
const int ossimplugins::VolumeDir::SARTrailerFilePointerRecordID = 4
staticprotected
Definition at line 84 of file VolumeDir.h.
Referenced by get_SARTrailerFilePointerRecord().
◆ TextRecordID
const int ossimplugins::VolumeDir::TextRecordID = 1
staticprotected
Definition at line 85 of file VolumeDir.h.
Referenced by get_TextRecord().
◆ VolumeDescriptorRecordID
const int ossimplugins::VolumeDir::VolumeDescriptorRecordID = 5
staticprotected
Definition at line 81 of file VolumeDir.h.
Referenced by get_VolumeDescriptorRecord().
