Functions | Variables
ossimAwsPluginInit.cpp File Reference
#include "ossimAwsStreamFactory.h"
#include <ossim/plugin/ossimSharedObjectBridge.h>
#include <ossim/plugin/ossimPluginConstants.h>
#include <ossim/base/ossimStreamFactoryRegistry.h>
#include <aws/core/Aws.h>
#include "S3StreamDefaults.h"
Go to the source code of this file.
Functions
const char * getAwsDescription ()
int getAwsNumberOfClassNames ()
const char * getAwsClassName (int idx)
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize (ossimSharedObjectInfo **info, const char *)
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ()
Variables
ossimSharedObjectInfo awsInfo
ossimString awsDescription
std::vector< ossimStringawsObjList
Function Documentation
◆ getAwsClassName()
const char* getAwsClassName ( int  idx)
Definition at line 40 of file ossimAwsPluginInit.cpp.
References awsObjList.
Referenced by ossimSharedLibraryInitialize().
41  {
42  if(idx < (int)awsObjList.size())
43  {
44  return awsObjList[idx].c_str();
45  }
46  return (const char*)0;
47  }
std::vector< ossimString > awsObjList
◆ getAwsDescription()
const char* getAwsDescription ( )
Definition at line 30 of file ossimAwsPluginInit.cpp.
References awsDescription, and ossimString::c_str().
31  {
32  return awsDescription.c_str();
33  }
const char * c_str() const
Definition: ossimString.h:396
◆ getAwsNumberOfClassNames()
int getAwsNumberOfClassNames ( )
Definition at line 35 of file ossimAwsPluginInit.cpp.
36  {
37  return (int)awsObjList.size();
38  }
◆ ossimSharedLibraryFinalize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ( )
Definition at line 71 of file ossimAwsPluginInit.cpp.
References ossim::AwsStreamFactory::instance(), and ossim::StreamFactoryRegistry::instance().
72  {
74  unregisterFactory( ossim::AwsStreamFactory::instance() );
75  }
static StreamFactoryRegistry * instance()
static AwsStreamFactory * instance()
◆ ossimSharedLibraryInitialize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize ( ossimSharedObjectInfo **  info,
const char *
Definition at line 50 of file ossimAwsPluginInit.cpp.
References awsInfo, getAwsClassName(), getAwsDescription(), getAwsNumberOfClassNames(), ossimSharedObjectInfo::getClassName, ossimSharedObjectInfo::getDescription, ossimSharedObjectInfo::getNumberOfClassNames, ossim::AwsStreamFactory::instance(), ossim::StreamFactoryRegistry::instance(), and ossim::S3StreamDefaults::loadDefaults().
52  {
53  Aws::SDKOptions options;
54  Aws::InitAPI(options);
55
59
60  *info = &awsInfo;
61
63  /* Register our stream factory... */
65  registerFactory( ossim::AwsStreamFactory::instance() );
66
67  setDescription(awsDescription);
68  }
const char * getAwsClassName(int idx)
ossimSharedLibraryGetNumberOfClassNamesPtr getNumberOfClassNames
const char * getAwsDescription()
ossimSharedLibraryGetDescriptionPtr getDescription
ossimSharedLibraryGetClassNamesPtr getClassName
int getAwsNumberOfClassNames()
Variable Documentation
◆ awsDescription
Definition at line 27 of file ossimAwsPluginInit.cpp.
Referenced by getAwsDescription().
◆ awsInfo
Definition at line 26 of file ossimAwsPluginInit.cpp.
◆ awsObjList
std::vector<ossimString> awsObjList
Definition at line 28 of file ossimAwsPluginInit.cpp.
Referenced by getAwsClassName(), and getAwsNumberOfClassNames().
