Classes | Public Member Functions | Static Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | Static Private Attributes | List of all members
ossim::StreamFactoryRegistry Class Reference
This is a generic stream registry. More...
#include <ossimStreamFactoryRegistry.h>
Inheritance diagram for ossim::StreamFactoryRegistry:
ossim::StreamFactoryBase
Classes
class  BufferInfo
 This is an internal class used to store the buffer information loaded from the preferences. More...
virtual ~StreamFactoryRegistry ()
void registerFactory (StreamFactoryBase *factory)
 Registers a stream factory. More...
void unregisterFactory (StreamFactoryBase *factory)
 Removes a factory from the registry. More...
virtual std::shared_ptr< ossim::istreamcreateIstream (const std::string &connectionString, const ossimKeywordlist &options=ossimKeywordlist(), std::ios_base::openmode mode=std::ios_base::in|std::ios_base::binary) const
 Will try to creates an istream interface to the connectionString passed in. More...
virtual std::shared_ptr< ossim::ostreamcreateOstream (const std::string &connectionString, const ossimKeywordlist &options=ossimKeywordlist(), std::ios_base::openmode mode=std::ios_base::out|std::ios_base::binary) const
 Will try to creates an ostream interface to the connectionString passed in. More...
virtual std::shared_ptr< ossim::iostreamcreateIOstream (const std::string &connectionString, const ossimKeywordlist &options=ossimKeywordlist(), std::ios_base::openmode mode=std::ios_base::in|std::ios_base::out|std::ios_base::binary) const
 Will try to creates an iostream interface to the connectionString passed in. More...
bool exists (const std::string &connectionString) const
 Methods to test if connection exists. More...
virtual bool exists (const std::string &connectionString, bool &continueFlag) const
void loadPreferences ()
 This will load the buffer information from the preferences. More...
- Public Member Functions inherited from ossim::StreamFactoryBase
virtual ~StreamFactoryBase ()
static StreamFactoryRegistryinstance ()
 StreamFactoryRegistry (const StreamFactoryRegistry &)
 copy constructor hidden from use More...
bool getBufferInfo (BufferInfo &bufferInfo, const ossimString &connectionString) const
Private Attributes
std::vector< StreamFactoryBase * > m_factoryList
std::vector< BufferInfom_bufferInfoList
ossimRegExp m_patternMatcher
std::mutex m_mutex
static StreamFactoryRegistrym_instance = 0
Detailed Description
We could try to create streams for http, https, s3 protocols as well as local file. We have also exposed an exists for supporting exists() calls for different stream types.
We have added support for Buffered reads. You can enable buffered reads to be block boundary. If it's not block then it will use a pubsetbuf for a buffered I/O It will read the
See also
ossimPreferences for the prefix key ossim.stream.factory.registry.istream.buffer[0-9]+ Example key list:
ossim.stream.factory.registry.istream.buffer1.enabled: false
ossim.stream.factory.registry.istream.buffer1.includePattern: ^/
ossim.stream.factory.registry.istream.buffer1.enableBlocked: true
ossim.stream.factory.registry.istream.buffer1.size: 65536
The includePattern keyword is a regular expression. Examples:
Local file example:
ossimString connectionString = "/data/foo.ntf"
std::shared_ptr<ossim::istream> in = ossim::StreamFactoryRegistry::instance()->createIstream(connectionString);
if(in)
std::vector<char> buf(1024)
in->seekg(0);
in->read(&buf.front(), buf.size());
S3 file example:
ossimString connectionString = "s3://foo-bucket/path/foo.ntf"
if(in)
in->seekg(0);
https or https file example:
ossimString connectionString = "https://foo-host/path/foo.ntf"
if(in)
in->seekg(0);
Definition at line 84 of file ossimStreamFactoryRegistry.h.
◆ ~StreamFactoryRegistry()
ossim::StreamFactoryRegistry::~StreamFactoryRegistry ( )
virtual
Definition at line 31 of file ossimStreamFactoryRegistry.cpp.
32 {
33 }
◆ StreamFactoryRegistry() [1/2]
ossim::StreamFactoryRegistry::StreamFactoryRegistry ( )
protected
Definition at line 26 of file ossimStreamFactoryRegistry.cpp.
27 {
28 }
◆ StreamFactoryRegistry() [2/2]
ossim::StreamFactoryRegistry::StreamFactoryRegistry ( const StreamFactoryRegistry )
private
Member Function Documentation
◆ createIOstream()
std::shared_ptr< ossim::iostream > ossim::StreamFactoryRegistry::createIOstream ( const std::string &  connectionString,
const ossimKeywordlist options = ossimKeywordlist(),
std::ios_base::openmode  mode = std::ios_base::in|std::ios_base::out|std::ios_base::binary
) const
virtual
Parameters
connectionStringIs the connection string used to create the stream
optionsIf a stream is found then this holds specific options for the stream. Defaults to empty options
modeIs the mode to be used. Defaults to a binary output stream.
Returns
A shared pointer to an ostream if successful.
Implements ossim::StreamFactoryBase.
Definition at line 200 of file ossimStreamFactoryRegistry.cpp.
204 {
205  std::shared_ptr<ossim::iostream> result(0);
206  return result;
207 }
◆ createIstream()
std::shared_ptr< ossim::istream > ossim::StreamFactoryRegistry::createIstream ( const std::string &  connectionString,
std::ios_base::openmode  mode = std::ios_base::in|std::ios_base::binary
) const
virtual
Parameters
connectionStringIs the connection string used to create a stream. Possible examples: s3://<bucket>/path or /data/foo.tif or https://<host>/<path>
modeIs the mode to be used. Defaults to a binary input stream.
Returns
A shared pointer to an istream if successful.
Definition at line 148 of file ossimStreamFactoryRegistry.cpp.
Referenced by ossimSrtmSupportData::computeMinMaxTemplate(), ossimImageHandler::initVertices(), ossimImageHandler::loadMetaData(), ossimTiffInfo::open(), and ossimNitfTileSource::open().
152 {
153  std::shared_ptr<ossim::istream> result(0);
154  if(traceDebug())
155  {
157  << "ossim::StreamFactoryRegistry::createIstream: ....... entered: "<< connectionString << "\n";
158  }
159
160  ossim_uint32 i = 0;
161  for(i = 0; (i < m_factoryList.size())&&(!result); ++i)
162  {
163  result = m_factoryList[i]->createIstream(connectionString, options, openMode);
164
165  if(result)
166  {
167  BufferInfo bufferInfo;
168  if(getBufferInfo(bufferInfo, connectionString))
169  {
170  if(bufferInfo.m_enableBlocked)
171  {
172  result = std::make_shared<ossim::BlockIStream>(result, bufferInfo.m_size);
173  }
174  else
175  {
176  result = std::make_shared<ossimBufferedInputStream>(result, bufferInfo.m_size);
177  }
178  }
179  }
180  }
181
182  if(traceDebug())
183  {
185  << "ossim::StreamFactoryRegistry::createIstream: ....... leaving!\n";
186  }
187
188  return result;
189 }
unsigned int ossim_uint32
bool getBufferInfo(BufferInfo &bufferInfo, const ossimString &connectionString) const
◆ createOstream()
std::shared_ptr< ossim::ostream > ossim::StreamFactoryRegistry::createOstream ( const std::string &  connectionString,
std::ios_base::openmode  mode = std::ios_base::out|std::ios_base::binary
) const
virtual
Parameters
Returns
Definition at line 191 of file ossimStreamFactoryRegistry.cpp.
195 {
196  std::shared_ptr<ossim::ostream> result(0);
197  return result;
198 }
◆ exists() [1/2]
bool ossim::StreamFactoryRegistry::exists ( const std::string &  connectionString) const
Returns
true on success, false, if not.
Definition at line 209 of file ossimStreamFactoryRegistry.cpp.
Referenced by ossimFilename::exists().
210 {
211  bool continueFlag = true;
212  return exists( connectionString, continueFlag );
213 }
bool exists(const std::string &connectionString) const
◆ exists() [2/2]
bool ossim::StreamFactoryRegistry::exists ( const std::string &  connectionString,
bool &  continueFlag
) const
virtual
Parameters
connectionString
continueFlagInitializes by this, if set to true, indicates factory handles file/url and no more factory checks are necessary.
Returns
Definition at line 215 of file ossimStreamFactoryRegistry.cpp.
217 {
218  if(traceDebug())
219  {
221  << "ossim::StreamFactoryRegistry::exists: ....... entered: "<< connectionString << "\n";
222  }
223  bool result = false;
224  for(auto factory:m_factoryList)
225  {
226
227  result = factory->exists( connectionString, continueFlag );
228  if ( ( result == true ) || (continueFlag == false ) ) break;
229  }
230
231  if(traceDebug())
232  {
234  << "ossim::StreamFactoryRegistry::createIstream: ....... leaving!\n";
235  }
236  return result;
237 }
◆ getBufferInfo()
bool ossim::StreamFactoryRegistry::getBufferInfo ( BufferInfo bufferInfo,
const ossimString connectionString
) const
private
Parameters
bufferInfoHolds the result of the first buffer info matching the connection string
connecitonStringThe connection string
Definition at line 120 of file ossimStreamFactoryRegistry.cpp.
References ossimString::c_str().
122 {
123  bool result = false;
124
125  for(std::vector<BufferInfo>::const_iterator iter = m_bufferInfoList.begin();
126  iter != m_bufferInfoList.end();
127  ++iter)
128  {
129  if(iter->m_enabled)
130  {
131  m_patternMatcher.compile(iter->m_pattern);
133  {
134  if(m_patternMatcher.find(connectionString.c_str()))
135  {
136  bufferInfo = *iter;
137  result = true;
138  break;
139  }
140  }
141  }
142  }
143
144  return result;
145 }
std::vector< BufferInfo > m_bufferInfoList
void compile(const char *)
bool is_valid() const
Definition: ossimRegExp.h:232
const char * c_str() const
Definition: ossimString.h:396
bool find(const char *)
◆ instance()
ossim::StreamFactoryRegistry * ossim::StreamFactoryRegistry::instance ( )
static
Definition at line 35 of file ossimStreamFactoryRegistry.cpp.
Referenced by ossimSrtmSupportData::computeMinMaxTemplate(), ossimInfoFactoryRegistry::create(), ossimFilename::exists(), ossimFilename::fileSize(), for(), ossimNitfFile::getNewDataExtensionSegment(), ossimNitfFile::getNewImageHeader(), ossimNitfFile::getNewLabelHeader(), ossimNitfFile::getNewSymbolHeader(), ossimNitfFile::getNewTextHeader(), ossimAuxXmlSupportData::getProjection(), ossimMultiResLevelHistogram::importHistogram(), ossimInit::initializeDefaultFactories(), ossimImageHandler::initVertices(), ossimApplanixEOFile::isEOFile(), ossimSensorModelFactory::isNitf(), ossimImageHandler::loadMetaData(), ossimNitfInfo::open(), ossimDemInfo::open(), ossimCcfInfo::open(), ossimInfoBase::open(), ossimDemHeader::open(), ossimTiffInfo::open(), ossimNitfTileSource::open(), ossimDtedHandler::open(), ossimFfRevb::ossimFfRevb(), ossimFfRevc::ossimFfRevc(), ossimSharedLibraryFinalize(), ossimSharedLibraryInitialize(), ossimCcfHead::parseCcfHeader(), ossimApplanixEOFile::parseFile(), ossimKeywordlist::parseFile(), and ossimApplanixEOFile::parseHeader().
36 {
37  // because of the loadPreferences for this factory and the fact that
38  // create stream could be recursive the lock and unlock are
39  // a little different here. We will unlock as quickly as we can
40  // After the unlock then call load preferences
41  m_instanceMutex.lock();
42  if(!m_instance)
43  {
46  m_instanceMutex.unlock();
48  }
49  else
50  {
51  m_instanceMutex.unlock();
52  }
53
54  return m_instance;
55 }
static StreamFactoryRegistry * m_instance
void registerFactory(StreamFactoryBase *factory)
static StreamFactory * instance()
void loadPreferences()
◆ loadPreferences()
void ossim::StreamFactoryRegistry::loadPreferences ( )
Definition at line 57 of file ossimStreamFactoryRegistry.cpp.
58 {
59  if(traceDebug())
60  {
62  << "ossim::StreamFactoryRegistry::loadPreferences: ....... entered!\n";
63  }
64  std::vector<ossimString> sortedList;
66  .getSortedList(sortedList, ISTREAM_BUFFER_KW);
67  if(sortedList.size())
68  {
69  m_bufferInfoList.resize(sortedList.size());
70  }
71  else
72  {
73  m_bufferInfoList.clear();
74  }
75  ossim_uint32 idx=0;
76  for(std::vector<ossimString>::const_iterator iter = sortedList.begin();
77  iter!=sortedList.end();
78  ++iter,++idx)
79  {
80  ossimString prefix = *iter;
81  ossimString bufferIStreamEnabled = ossimPreferences::instance()->findPreference(prefix+".enabled");
82  ossimString bufferIStreamBlockEnabled = ossimPreferences::instance()->findPreference(prefix+".enableBlocked");
83  ossimString bufferIStreamIncludePattern = ossimPreferences::instance()->findPreference(prefix+".includePattern");
84  ossimString bufferIStreamSize = ossimPreferences::instance()->findPreference(prefix+".size");
85
86  if(!bufferIStreamSize.empty())
87  {
88  m_bufferInfoList[idx].m_size = bufferIStreamSize.toUInt64();
89  }
90  if(!bufferIStreamEnabled.empty())
91  {
92  m_bufferInfoList[idx].m_enabled = bufferIStreamEnabled.toBool();
93  }
94  if(!bufferIStreamBlockEnabled.empty())
95  {
96  m_bufferInfoList[idx].m_enableBlocked = bufferIStreamBlockEnabled.toBool();
97  }
98  if(!bufferIStreamIncludePattern.empty())
99  {
100  m_bufferInfoList[idx].m_pattern = bufferIStreamIncludePattern;
101  }
102  if(traceDebug())
103  {
105  << "ossim::StreamFactoryRegistry adding BufferInfo: \n"
106  << "enabled: " << ossimString::toString(m_bufferInfoList[idx].m_enabled)<< "\n"
107  << "enableBlocked: " << ossimString::toString(m_bufferInfoList[idx].m_enableBlocked)<< "\n"
108  << "size: " << m_bufferInfoList[idx].m_size << "\n"
109  << "pattern: " << m_bufferInfoList[idx].m_pattern << "\n";
110  }
111
112  }
113  if(traceDebug())
114  {
116  << "ossim::StreamFactoryRegistry::loadPreferences: ....... leaving!\n";
117  }
118 }
const ossimKeywordlist & preferencesKWL() const
Numeric to string methods.
const char * findPreference(const char *key) const
bool toBool() const
String to numeric methods.
static ossimPreferences * instance()
void getSortedList(std::vector< ossimString > &prefixValues, const ossimString &prefixKey) const
This return the sorted keys if you have a list.
ossim_uint64 toUInt64() const
bool empty() const
Definition: ossimString.h:411
◆ registerFactory()
void ossim::StreamFactoryRegistry::registerFactory ( ossim::StreamFactoryBase factory)
This allows for a pluggable stream Please see ossim-plugins and look at curl, aws for example stream definitions.
Parameters
factoryTo be added to the registry
Definition at line 239 of file ossimStreamFactoryRegistry.cpp.
240 {
241  std::vector<ossim::StreamFactoryBase*>::iterator iter = std::find(
242  m_factoryList.begin(), m_factoryList.end(), factory);
243  if(iter == m_factoryList.end())
244  {
245  m_factoryList.push_back(factory);
246  }
247 }
◆ unregisterFactory()
void ossim::StreamFactoryRegistry::unregisterFactory ( StreamFactoryBase factory)
Parameters
factoryTo be removed from the registry
Definition at line 249 of file ossimStreamFactoryRegistry.cpp.
250 {
251  // std::lock_guard<std::mutex> lock(m_factoryListMutex);
252  std::vector<ossim::StreamFactoryBase*>::iterator iter = std::find(
253  m_factoryList.begin(), m_factoryList.end(), factory);
254  if(iter != m_factoryList.end())
255  {
256  m_factoryList.erase( iter );
257  }
258 }
Member Data Documentation
◆ m_bufferInfoList
std::vector<BufferInfo> ossim::StreamFactoryRegistry::m_bufferInfoList
private
Definition at line 215 of file ossimStreamFactoryRegistry.h.
◆ m_factoryList
std::vector<StreamFactoryBase*> ossim::StreamFactoryRegistry::m_factoryList
private
Definition at line 214 of file ossimStreamFactoryRegistry.h.
◆ m_instance
ossim::StreamFactoryRegistry * ossim::StreamFactoryRegistry::m_instance = 0
staticprivate
Definition at line 216 of file ossimStreamFactoryRegistry.h.
◆ m_mutex
std::mutex ossim::StreamFactoryRegistry::m_mutex
mutableprivate
Definition at line 218 of file ossimStreamFactoryRegistry.h.
◆ m_patternMatcher
ossimRegExp ossim::StreamFactoryRegistry::m_patternMatcher
mutableprivate
Definition at line 217 of file ossimStreamFactoryRegistry.h.
