Functions | Variables
ossimHdf5PluginInit.cpp File Reference
#include <ossim/plugin/ossimSharedObjectBridge.h>
#include <ossim/imaging/ossimImageHandlerRegistry.h>
#include <ossim/imaging/ossimImageWriterFactoryRegistry.h>
#include <ossim/imaging/ossimOverviewBuilderFactoryRegistry.h>
#include <ossim/projection/ossimProjectionFactoryRegistry.h>
#include <ossim/support_data/ossimInfoFactoryRegistry.h>
#include <ossim/plugin/ossimPluginConstants.h>
#include "ossimHdf5PluginHandlerFactory.h"
#include "ossimViirsHandler.h"
Go to the source code of this file.
Functions
const char * getDescription ()
int getNumberOfClassNames ()
const char * getClassName (int idx)
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize (ossimSharedObjectInfo **info)
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ()
Variables
ossimSharedObjectInfo myInfo
ossimString theDescription
std::vector< ossimStringtheObjList
Function Documentation
◆ getClassName()
const char* getClassName ( int  idx)
Definition at line 59 of file ossimHdf5PluginInit.cpp.
References theObjList.
Referenced by ossimSharedLibraryInitialize().
60  {
61  if(idx < (int)theObjList.size())
62  {
63  return theObjList[0].c_str();
64  }
65  return (const char*)0;
66  }
std::vector< ossimString > theObjList
◆ getDescription()
const char* getDescription ( )
Definition at line 49 of file ossimHdf5PluginInit.cpp.
References ossimString::c_str(), and theDescription.
50  {
51  return theDescription.c_str();
52  }
const char * c_str() const
Definition: ossimString.h:396
◆ getNumberOfClassNames()
int getNumberOfClassNames ( )
Definition at line 54 of file ossimHdf5PluginInit.cpp.
55  {
56  return (int)theObjList.size();
57  }
◆ ossimSharedLibraryFinalize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ( )
Definition at line 90 of file ossimHdf5PluginInit.cpp.
References ossimHdf5PluginHandlerFactory::instance(), and ossimImageHandlerRegistry::instance().
91  {
93  unregisterFactory(ossimHdf5PluginHandlerFactory::instance());
94
95 // ossimProjectionFactoryRegistry::instance()->
96 // unregisterFactory(ossimHdf5ProjectionFactory::instance());
97  }
static ossimHdf5PluginHandlerFactory * instance()
static method to return instance (the only one) of this class.
static ossimImageHandlerRegistry * instance()
◆ ossimSharedLibraryInitialize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize ( ossimSharedObjectInfo **  info)
Definition at line 69 of file ossimHdf5PluginInit.cpp.
References ossimSharedObjectInfo::getClassName, getClassName(), ossimSharedObjectInfo::getDescription, getDescription(), ossimSharedObjectInfo::getNumberOfClassNames, getNumberOfClassNames(), ossimHdf5PluginHandlerFactory::instance(), ossimImageHandlerRegistry::instance(), and myInfo.
70  {
74
75  *info = &myInfo;
76
77
78  /* Register the readers... */
80  registerFactory(ossimHdf5PluginHandlerFactory::instance());
81
82  /* Register hdf projection factory... */
83 // ossimProjectionFactoryRegistry::instance()->
84 // registerFactoryToFront(ossimHdf5ProjectionFactory::instance());
85
86  setDescription(theDescription);
87  }
ossimSharedLibraryGetNumberOfClassNamesPtr getNumberOfClassNames
const char * getClassName(int idx)
const char * getDescription()
ossimSharedLibraryGetDescriptionPtr getDescription
ossimSharedLibraryGetClassNamesPtr getClassName
int getNumberOfClassNames()
Variable Documentation
◆ myInfo
Definition at line 45 of file ossimHdf5PluginInit.cpp.
◆ theDescription
Definition at line 46 of file ossimHdf5PluginInit.cpp.
Referenced by getDescription().
◆ theObjList
std::vector<ossimString> theObjList
Definition at line 47 of file ossimHdf5PluginInit.cpp.
Referenced by getClassName(), and getNumberOfClassNames().
