Factory for Hdf image reader. More...
#include <ossimHdf5PluginHandlerFactory.h>
virtual | ~ossimHdf5PluginHandlerFactory () |
virtual destructor More... | |
virtual ossimImageHandler * | open (const ossimFilename &fileName, bool openOverview=true) const |
open that takes a file name. More... | |
virtual ossimImageHandler * | open (const ossimKeywordlist &kwl, const char *prefix=0) const |
open that takes a keyword list and prefix. More... | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
createObject that takes a class name (ossimH5Reader) More... | |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
Creates and object given a keyword list and prefix. More... | |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Adds ossimH5Reader to the typeList. More... | |
virtual void | getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &list) const |
Method to add supported extension to the list, like "hdf". More... | |
virtual void | getSupportedRenderableNames (std::vector< ossimString > &names) const |
HDF5 defines different datasets depending on the sensor/format. More... | |
virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const |
Open method that takes a stream. More... | |
virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::ImageHandlerState > state) const |
virtual ossimRefPtr< ossimImageHandler > | openOverview (const ossimFilename &file) const |
Open overview that takes a file name. More... | |
virtual ossimRefPtr< ossimImageHandler > | openOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const |
virtual void | getImageHandlersBySuffix (ImageHandlerList &result, const ossimString &ext) const |
virtual void | getImageHandlersByMimeType (ImageHandlerList &result, const ossimString &mimeType) const |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimHdf5PluginHandlerFactory * | instance () |
static method to return instance (the only one) of this class. More... | |
ossimHdf5PluginHandlerFactory () | |
hidden from use default constructor More... | |
ossimHdf5PluginHandlerFactory (const ossimHdf5PluginHandlerFactory &) | |
hidden from use copy constructor More... | |
void | operator= (const ossimHdf5PluginHandlerFactory &) |
virtual | ~ossimReferenced () |
Static Protected Attributes | |
static ossimHdf5PluginHandlerFactory * | theInstance = 0 |
static instance of this class More... | |
typedef UniqueList< ossimString > | UniqueStringList |
typedef std::vector< ossimRefPtr< ossimImageHandler > > | ImageHandlerList |
Definition at line 23 of file ossimHdf5PluginHandlerFactory.h.
virtual destructor
Definition at line 26 of file ossimHdf5PluginHandlerFactory.cpp.
References theInstance.
protected |
Definition at line 138 of file ossimHdf5PluginHandlerFactory.cpp.
Referenced by instance().
protected |
Definition at line 140 of file ossimHdf5PluginHandlerFactory.cpp.
typeName | Should be "ossimH5Reader". |
Implements ossimObjectFactory.
Definition at line 93 of file ossimHdf5PluginHandlerFactory.cpp.
References ossimRefPtr< T >::release().
kwl | The keyword list. |
prefix | the keyword list prefix. |
Definition at line 104 of file ossimHdf5PluginHandlerFactory.cpp.
References open().
extensionList | The list to add to. |
Implements ossimImageHandlerFactoryBase.
Definition at line 118 of file ossimHdf5PluginHandlerFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back().
Referenced by open().
This static method provides all dataset names to the plugin intialization for populating a description.
Definition at line 126 of file ossimHdf5PluginHandlerFactory.cpp.
References ossimHdf5ImageHandler::getRenderableSetNames().
typeList | List to add to. |
Definition at line 111 of file ossimHdf5PluginHandlerFactory.cpp.
static |
Definition at line 31 of file ossimHdf5PluginHandlerFactory.cpp.
References ossimHdf5PluginHandlerFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
file | The file to open. |
openOverview | If true image handler will attempt to open overview. default = true |
Definition at line 40 of file ossimHdf5PluginHandlerFactory.cpp.
References ossimString::downcase(), ossimFilename::ext(), getSupportedExtensions(), ossimImageHandler::open(), ossimImageHandlerFactoryBase::openOverview(), ossimRefPtr< T >::release(), ossimImageHandler::setOpenOverviewFlag(), and ossimImageHandlerFactoryBase::UniqueList< T >::size().
Referenced by createObject().
Definition at line 75 of file ossimHdf5PluginHandlerFactory.cpp.
References ossimImageHandler::loadState(), and ossimRefPtr< T >::release().
protected |
Definition at line 142 of file ossimHdf5PluginHandlerFactory.cpp.
staticprotected |
Definition at line 102 of file ossimHdf5PluginHandlerFactory.h.
Referenced by instance(), and ~ossimHdf5PluginHandlerFactory().
