ossimImageMpiMWriterSequenceConnection.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Garrett Potts
6 //
7 // Description:
8 //
9 // This class is specific to the Master connection and is optimized
10 // for the writer sequence and batch processing chain. For the Slave
11 // implementation look for the ossimImageMpiSWriterSequenceConnection.cc and .h
12 // files. The Master connection is currently implemented to allways do
13 // a recieve and does no processing itself. The slave connection does
14 // all the actual work and processing.
15 //
16 //*******************************************************************
17 // $Id: ossimImageMpiMWriterSequenceConnection.cpp 12099 2007-12-01 16:09:36Z dburken $
18
19
20 #include <ossim/ossimConfig.h> /* To pick up OSSIM_HAS_MPI. */
21
22 #ifdef OSSIM_HAS_MPI
23 # if OSSIM_HAS_MPI
24 # include <mpi.h>
25 # endif
26 #endif
27
32 #include <ossim/base/ossimTrace.h>
33 #include <ossim/base/ossimEndian.h>
34
35 static ossimTrace traceDebug = ossimTrace("ossimImageMpiMWriterSequenceConnection:debug");
36
37 RTTI_DEF1(ossimImageMpiMWriterSequenceConnection, "ossimImageMpiMWriterSequenceConnection", ossimImageSourceSequencer)
38
39
41  ossimImageSource* inputSource,
42  ossimObject* owner)
43  :ossimImageSourceSequencer(inputSource, owner),
44  theOutputTile(NULL)
45 {
46  theRank = 0;
47  theNumberOfProcessors = 1;
48
49 #ifdef OSSIM_HAS_MPI
50 # if OSSIM_HAS_MPI
51  MPI_Comm_rank(MPI_COMM_WORLD, &theRank);
52  MPI_Comm_size(MPI_COMM_WORLD, &theNumberOfProcessors);
53 # endif
54 #endif
55
56  if(theRank!=0)
57  {
58  theCurrentTileNumber = theRank -1;
59  }
60  else
61  {
62  theCurrentTileNumber = 0;
63  }
64  theNeedToSendRequest = true;
65 }
66
68  :ossimImageSourceSequencer(NULL, owner),
69  theOutputTile(NULL)
70 {
71  theRank = 0;
73
74 #ifdef OSSIM_HAS_MPI
75 # if OSSIM_HAS_MPI
76  MPI_Comm_rank(MPI_COMM_WORLD, &theRank);
77  MPI_Comm_size(MPI_COMM_WORLD, &theNumberOfProcessors);
78 # endif
79 #endif
80
81  if(theRank!=0)
82  {
84  }
85  else
86  {
88  }
89  theNeedToSendRequest = true;
90 }
91
93 {
94 }
95
97 {
99
101  theOutputTile = NULL;
102
104  {
107  }
108 }
109
111 {
113  if(theRank != 0)
114  {
115  // we will subtract one since the masters job is just
116  // writting and not issue getTiles.
118
119  }
120  else
121  {
122  // the master will start at 0
124  }
125 }
126
131 {
132 #if OSSIM_HAS_MPI
133  ossimEndian endian;
134  if(!theOutputTile)
135  {
136  initialize();
137  if (!theOutputTile)
138  {
139  return theOutputTile;
140  }
141  }
142
143  void* buf = theOutputTile->getBuf();
144
145  ossim_uint32 numberOfTiles = getNumberOfTiles();
146  int errorValue = 0;
147
148  if(theCurrentTileNumber >= numberOfTiles)
149  {
150  return NULL;
151  }
152  errorValue = MPI_Recv(buf,
154  MPI_UNSIGNED_CHAR,
156  0,
157  MPI_COMM_WORLD,
158  MPI_STATUS_IGNORE);
159  if((endian.getSystemEndianType()!=OSSIM_BIG_ENDIAN)&&
161  {
162  endian.swap(theOutputTile->getScalarType(),
163  buf,
165  }
166
167 #if 0
168  // Since MPI can run on different platforms
169  // I am not sure if MPI has built in byte
170  // swap. If so I will name each datatype
171  // so it can handle byte swap. Does anyone
172  // know if MPI does byte swapping.
173  switch(theOutputTile->getScalarType())
174  {
175  case OSSIM_UINT8:
176  {
177  // we add 1 to the rank so we don't wait on a message
178  // to ourself (rank = 0).
179  errorValue = MPI_Recv(buf,
181  MPI_UNSIGNED_CHAR,
183  0,
184  MPI_COMM_WORLD,
185  MPI_STATUS_IGNORE);
186  break;
187  }
188  case OSSIM_SINT8:
189  {
190  // we add 1 to the rank so we don't wait on a message
191  // to ourself (rank = 0).
192  errorValue = MPI_Recv(buf,
194  MPI_CHAR,
196  0,
197  MPI_COMM_WORLD,
198  MPI_STATUS_IGNORE);
199  break;
200  }
201  case OSSIM_UINT16:
202  case OSSIM_USHORT11:
203  case OSSIM_USHORT12:
204  case OSSIM_USHORT13:
205  case OSSIM_USHORT14:
206  case OSSIM_USHORT15:
207  {
208  errorValue = MPI_Recv(buf,
210  MPI_UNSIGNED_SHORT,
212  0,
213  MPI_COMM_WORLD,
214  MPI_STATUS_IGNORE);
215  break;
216  }
217  case OSSIM_SINT16:
218  {
219  errorValue = MPI_Recv(buf,
221  MPI_SHORT,
223  0,
224  MPI_COMM_WORLD,
225  MPI_STATUS_IGNORE);
226  break;
227  }
228  case OSSIM_SINT32:
229  {
230  errorValue = MPI_Recv(buf,
232  MPI_LONG,
234  0,
235  MPI_COMM_WORLD,
236  MPI_STATUS_IGNORE);
237  break;
238  }
239  case OSSIM_UINT32:
240  {
241  errorValue = MPI_Recv(buf,
243  MPI_UNSIGNED_LONG,
245  0,
246  MPI_COMM_WORLD,
247  MPI_STATUS_IGNORE);
248  break;
249  }
250  case OSSIM_FLOAT32:
252  {
253  errorValue = MPI_Recv(buf,
255  MPI_FLOAT,
257  0,
258  MPI_COMM_WORLD,
259  MPI_STATUS_IGNORE);
260  break;
261  }
262  case OSSIM_FLOAT64:
264  {
265  errorValue = MPI_Recv(buf,
267  MPI_DOUBLE,
269  0,
270  MPI_COMM_WORLD,
271  MPI_STATUS_IGNORE);
272  break;
273  }
274  default:
275  {
276  break;
277  }
278  }
279 #endif
280  ossimIpt origin;
282  origin);
283  theOutputTile->setOrigin(origin);
286  return theOutputTile;
287 #else
289 #endif
290
291 }
8 bit signed integer
64 bit floating point
16 bit unsigned integer
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
16 bit signed integer
32 bit floating point
32 bit unsigned integer
virtual void initialize()
Initialize the data buffer.
virtual ossim_uint32 getSizeInBytes() const
Returns the total number of bytes for all bands.
virtual bool getTileOrigin(ossim_int64 id, ossimIpt &origin) const
32 bit signed integer
unsigned int ossim_uint32
ossimByteOrder getSystemEndianType() const
Definition: ossimEndian.h:78
virtual void setOrigin(const ossimIpt &origin)
virtual ossim_uint32 getSize() const
Returns the total number of pixels in a tile for all bands.
8 bit unsigned integer
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
