ossimKeywordNames.h
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2000 ImageLinks Inc.
3 //
4 // License: See top level LICENSE.txt file
5 //
6 // Author: Ken Melero (kmelero@remotesensing.org)
7 //
8 // Description: Common file for global Keywors.
9 //
10 //*************************************************************************
11 // $Id: ossimKeywordNames.h 23037 2014-12-11 20:37:51Z okramer $
12
13 #ifndef ossimKeywordNames_HEADER
14 #define ossimKeywordNames_HEADER
15
17
19 {
20 public:
21  //***
22  // NOTE: List keyword in alphabetical order.
23  //***
24  static const char* AZIMUTH_ANGLE_KW;
25  static const char* BAND_KW;
26  static const char* BANDS_KW;
27  static const char* BORDER_SIZE_KW;
28  static const char* BRUSH_COLOR_KW;
29  static const char* BYTE_ORDER_KW;
30  static const char* CE90_ABSOLUTE_KW;
31  static const char* CE90_RELATIVE_KW;
32  static const char* CENTER_PIXEL_X_KW;
33  static const char* CENTER_PIXEL_Y_KW;
34  static const char* CENTRAL_MERIDIAN_KW;
35  static const char* CENTRAL_POINT1_LAT_KW;
36  static const char* CENTRAL_POINT1_LON_KW;
37  static const char* CENTRAL_POINT2_LAT_KW;
38  static const char* CENTRAL_POINT2_LON_KW;
39  static const char* COMPRESS_KW;
40  static const char* COMPRESSION_QUALITY_KW;
41  static const char* COMPRESSION_TYPE_KW;
42  static const char* CONVERGENCE_THRESHOLD_KW;
43  static const char* CREATE_EX_KW;
44  static const char* CREATE_EXTERNAL_GEOMETRY_KW;
45  static const char* CREATE_IMAGE_KW;
46  static const char* CREATE_HISTOGRAM_KW;
47  static const char* CREATE_OVERVIEW_KW;
48  static const char* DATA_FILE_KW;
49  static const char* DATE_KW;
50  static const char* DATE_YEAR_KW;
51  static const char* DATE_MONTH_KW;
52  static const char* DATE_DAY_KW;
53  static const char* DATE_HOUR_KW;
54  static const char* DATE_MIN_KW;
55  static const char* DATE_SEC_KW;
56  static const char* DATE_FRACT_SEC_KW;
57  static const char* DATUM_KW;
58  static const char* DECIMAL_DEGREES_PER_PIXEL_LAT;
59  static const char* DECIMAL_DEGREES_PER_PIXEL_LON;
60  static const char* DESCRIPTION_KW;
61  static const char* ELEVATION_ANGLE_KW;
62  static const char* ELEVATION_CELL_KW;
63  static const char* ELEVATION_SOURCE_KW;
64  static const char* ELEVATION_LOOKUP_FLAG_KW;
65  static const char* ELLIPSE_CODE_KW;
66  static const char* ELLIPSE_EPSG_CODE_KW;
67  static const char* ELLIPSE_NAME_KW;
68  static const char* ENABLED_KW;
69  static const char* ENABLE_CACHE_KW;
70  static const char* EXTRACT_VERTICES_KW;
71  static const char* ENTRY_KW;
72  static const char* FALSE_EASTING_NORTHING_KW;
73  static const char* FALSE_EASTING_NORTHING_UNITS_KW;
74  static const char* FALSE_EASTING_KW;
75  static const char* FALSE_NORTHING_KW;
76  static const char* FEATURE_NAME_KW;
77  static const char* FILE_KW;
78  static const char* FILENAME_KW;
79  static const char* FILEPATH_KW;
80  static const char* FILL_FLAG_KW;
81  static const char* FRAME_INDEX_KW;
82  static const char* GCS_CODE_KW;
83  static const char* GEOM_FILE_KW;
84  static const char* HEMISPHERE_KW;
85  static const char* HORIZONTAL_SIZE_KW;
86  static const char* HAS_LUT_KW;
87  static const char* ID_KW;
88  static const char* IMAGE_CE90_KW;
89  static const char* IMAGE_FILE_KW;
90  static const char* IMAGE_ID_KW;
91  static const char* IMAGE_MODEL_TRANSFORM_MATRIX_KW;
92  static const char* IMAGE_MODEL_TRANSFORM_UNIT_KW;
93  static const char* IMAGE_PATH_KW;
94  static const char* IMAGE_TYPE_KW;
95  static const char* IMAGE_DATE_KW;
96  static const char* IMAGE_FILE_SIZE_KW;
97  static const char* INPUT_RR_LEVEL_KW;
98  static const char* INTERLEAVE_TYPE_KW;
99  static const char* JULIAN_DAY_KW;
100  static const char* LAT_INCREMENT_KW;
101  static const char* LL_LAT_KW;
102  static const char* LL_LON_KW;
103  static const char* LR_LAT_KW;
104  static const char* LR_LON_KW;
105  static const char* LL_X_KW;
106  static const char* LL_Y_KW;
107  static const char* LR_X_KW;
108  static const char* LR_Y_KW;
109  static const char* LON_INCREMENT_KW;
110  static const char* MAJOR_AXIS_KW;
111  static const char* MAX_VALUE_KW;
112  static const char* MAX_ITERATIONS_KW;
113  static const char* MAX_QUADTREE_LEVELS_KW;
114  static const char* METADATA_TYPE_KW;
115  static const char* METERS_PER_PIXEL_KW;
116  static const char* METERS_PER_PIXEL_X_KW;
117  static const char* METERS_PER_PIXEL_Y_KW;
118  static const char* MINOR_AXIS_KW;
119  static const char* MIN_VALUE_KW;
120  static const char* NULL_VALUE_KW;
121  static const char* NUMBER_BANDS_KW;
122  static const char* NUMBER_ENTRIES_KW;
123  static const char* NUMBER_INPUT_BANDS_KW;
124  static const char* NUMBER_INPUTS_KW;
125  static const char* NUMBER_OUTPUTS_KW;
126  static const char* NUMBER_OUTPUT_BANDS_KW;
127  static const char* NUMBER_LINES_KW;
128  static const char* NUMBER_REDUCED_RES_SETS_KW;
129  static const char* NUMBER_SAMPLES_KW;
130  static const char* ORIGIN_LATITUDE_KW;
131  static const char* ORIGIN_X_KW;
132  static const char* ORIGIN_Y_KW;
133  static const char* ORIGINAL_MAP_UNITS_KW;
134  static const char* OUTPUT_FILE_KW;
135  static const char* OUTPUT_FILE_PREFIX_KW;
136  static const char* OUTPUT_FILE_EXTENSION_KW;
137  static const char* OUTPUT_TILE_SIZE_KW;
139  static const char* OVERVIEW_COMPRESSION_TYPE_KW;
140  static const char* OVERVIEW_FILE_KW;
141  static const char* OVERVIEW_STOP_DIMENSION_KW;
142  static const char* PCS_CODE_KW;
143  static const char* PEN_COLOR_KW;
144  static const char* PHOTOMETRIC_KW;
145  static const char* PIXEL_SCALE_XY_KW;
146  // static const char* PIXEL_SCALE_Y_KW;
147  static const char* PIXEL_SCALE_UNITS_KW;
148  static const char* PIXEL_TYPE_KW;
149  static const char* PLANAR_CONFIG_KW;
150  static const char* POINT_WIDTH_HEIGHT_KW;
151  static const char* PROJECTION_KW;
152  static const char* QUALITY_KW;
153  static const char* QUERY_KW;
154  static const char* RADIOMETRY_KW;
155  static const char* REDUCED_RES_LEVEL_KW;
156  static const char* REF_GPT_LAT_KW;
157  static const char* REF_GPT_LON_KW;
158  static const char* REF_GPT_HGT_KW;
159  static const char* REF_IPT_LINE_KW;
160  static const char* REF_IPT_SAMP_KW;
161  static const char* ROTATION_KW;
162  static const char* SCALAR_TYPE_KW;
163  static const char* SCALE_PER_PIXEL_X_KW;
164  static const char* SCALE_PER_PIXEL_Y_KW;
165  static const char* SCALE_FACTOR_KW;
166  static const char* SCALE_X_KW;
167  static const char* SCALE_Y_KW;
168  static const char* SCALE_FACTOR_X_KW;
169  static const char* SCALE_FACTOR_Y_KW;
170  static const char* SENSOR_ID_KW;
171  static const char* SRS_NAME_KW;
172  static const char* STD_PARALLEL_1_KW;
173  static const char* STD_PARALLEL_2_KW;
174  static const char* THICKNESS_KW;
175  static const char* THREADS_KW;
176  static const char* TIE_POINT_EASTING_KW;
177  static const char* TIE_POINT_NORTHING_KW;
178  static const char* TIE_POINT_XY_KW;
179  // static const char* TIE_POINT_Y_KW;
180  static const char* TIE_POINT_UNITS_KW;
181
182  static const char* TIE_POINT_LAT_KW;
183  static const char* TIE_POINT_LON_KW;
184  static const char* TILE_SOURCE_KW;
185  static const char* TILE_TYPE_KW;
186  static const char* TILE_SIZE_X_KW;
187  static const char* TILE_SIZE_Y_KW;
188  static const char* TRANSLATION_X_KW;
189  static const char* TRANSLATION_Y_KW;
190  static const char* TYPE_KW;
191  static const char* UL_LAT_KW;
192  static const char* UL_LON_KW;
193  static const char* UNITS_KW;
194
195  static const char* UR_LAT_KW;
196  static const char* UR_LON_KW;
197  static const char* UL_X_KW;
198  static const char* UL_Y_KW;
199  static const char* UR_X_KW;
200  static const char* UR_Y_KW;
201  static const char* VALID_VERTICES_KW;
202  static const char* VERTICAL_SIZE_KW;
203  static const char* ZONE_KW;
204
205 protected:
208  const ossimKeywordNames& operator =(const ossimKeywordNames &rhs);
209 };
210
211 #endif
static const char * DATE_HOUR_KW
static const char * REF_GPT_LON_KW
static const char * IMAGE_PATH_KW
static const char * BYTE_ORDER_KW
static const char * MIN_VALUE_KW
static const char * ORIGIN_Y_KW
static const char * OVERVIEW_FILE_KW
static const char * PHOTOMETRIC_KW
static const char * MINOR_AXIS_KW
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
static const char * PROJECTION_KW
static const char * BRUSH_COLOR_KW
static const char * VALID_VERTICES_KW
static const char * FILE_KW
#define OSSIMDLLEXPORT
static const char * DATUM_KW
static const char * CENTER_PIXEL_X_KW
static const char * OUTPUT_FILE_KW
static const char * REF_GPT_LAT_KW
static const char * FALSE_EASTING_NORTHING_UNITS_KW
static const char * IMAGE_DATE_KW
static const char * ELEVATION_CELL_KW
static const char * CENTRAL_MERIDIAN_KW
static const char * CENTRAL_POINT2_LON_KW
static const char * CREATE_HISTOGRAM_KW
static const char * UL_LAT_KW
static const char * LR_X_KW
static const char * OUTPUT_TILE_SIZE_KW
static const char * OUTPUT_FILE_EXTENSION_KW
static const char * ORIGINAL_MAP_UNITS_KW
static const char * IMAGE_MODEL_TRANSFORM_MATRIX_KW
static const char * OVERVIEW_COMPRESSION_TYPE_KW
static const char * MAX_VALUE_KW
static const char * SCALE_X_KW
static const char * NULL_VALUE_KW
static const char * HORIZONTAL_SIZE_KW
static const char * SCALE_FACTOR_Y_KW
static const char * NUMBER_LINES_KW
static const char * TIE_POINT_LON_KW
static const char * METADATA_TYPE_KW
static const char * NUMBER_INPUT_BANDS_KW
static const char * TILE_SOURCE_KW
static const char * LR_LON_KW
static const char * NUMBER_ENTRIES_KW
static const char * ROTATION_KW
static const char * FILEPATH_KW
static const char * JULIAN_DAY_KW
static const char * TILE_SIZE_Y_KW
static const char * FRAME_INDEX_KW
static const char * DATE_FRACT_SEC_KW
static const char * CREATE_EX_KW
static const char * SCALE_FACTOR_X_KW
static const char * IMAGE_ID_KW
static const char * METERS_PER_PIXEL_Y_KW
static const char * TYPE_KW
static const char * SCALE_Y_KW
static const char * REF_GPT_HGT_KW
static const char * PLANAR_CONFIG_KW
static const char * GCS_CODE_KW
static const char * NUMBER_INPUTS_KW
static const char * DATE_MONTH_KW
static const char * MAX_QUADTREE_LEVELS_KW
static const char * PIXEL_SCALE_XY_KW
static const char * ELEVATION_LOOKUP_FLAG_KW
static const char * TIE_POINT_NORTHING_KW
static const char * FEATURE_NAME_KW
static const char * RADIOMETRY_KW
static const char * SCALE_PER_PIXEL_X_KW
static const char * ZONE_KW
static const char * UR_Y_KW
static const char * LR_Y_KW
static const char * SENSOR_ID_KW
static const char * LR_LAT_KW
static const char * UL_X_KW
static const char * ELLIPSE_CODE_KW
static const char * DATE_YEAR_KW
static const char * CE90_ABSOLUTE_KW
static const char * TRANSLATION_X_KW
static const char * DATE_DAY_KW
static const char * TIE_POINT_XY_KW
static const char * TIE_POINT_EASTING_KW
static const char * UR_X_KW
static const char * FALSE_NORTHING_KW
static const char * LL_LON_KW
static const char * REF_IPT_LINE_KW
static const char * QUERY_KW
static const char * CREATE_OVERVIEW_KW
static const char * MAJOR_AXIS_KW
static const char * COMPRESSION_TYPE_KW
static const char * IMAGE_CE90_KW
static const char * HAS_LUT_KW
static const char * TILE_TYPE_KW
static const char * INPUT_RR_LEVEL_KW
static const char * FILL_FLAG_KW
static const char * VERTICAL_SIZE_KW
static const char * NUMBER_OUTPUT_BANDS_KW
static const char * COMPRESS_KW
static const char * BORDER_SIZE_KW
static const char * CE90_RELATIVE_KW
static const char * EXTRACT_VERTICES_KW
static const char * STD_PARALLEL_1_KW
static const char * IMAGE_FILE_SIZE_KW
static const char * FALSE_EASTING_KW
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
static const char * LL_LAT_KW
static const char * REDUCED_RES_LEVEL_KW
static const char * NUMBER_BANDS_KW
static const char * MAX_ITERATIONS_KW
static const char * GEOM_FILE_KW
static const char * IMAGE_MODEL_TRANSFORM_UNIT_KW
static const char * LON_INCREMENT_KW
static const char * UL_Y_KW
static const char * FALSE_EASTING_NORTHING_KW
static const char * REF_IPT_SAMP_KW
static const char * AZIMUTH_ANGLE_KW
static const char * BANDS_KW
static const char * ENABLED_KW
static const char * TRANSLATION_Y_KW
static const char * CREATE_EXTERNAL_GEOMETRY_KW
static const char * BAND_KW
static const char * DATE_MIN_KW
static const char * DATE_SEC_KW
static const char * ORIGIN_LATITUDE_KW
static const char * ENTRY_KW
static const char * UNITS_KW
static const char * CENTRAL_POINT2_LAT_KW
static const char * THREADS_KW
static const char * DATE_KW
static const char * ELLIPSE_NAME_KW
static const char * PCS_CODE_KW
static const char * LL_X_KW
static const char * INTERLEAVE_TYPE_KW
static const char * ENABLE_CACHE_KW
static const char * CENTER_PIXEL_Y_KW
static const char * CREATE_IMAGE_KW
static const char * DESCRIPTION_KW
static const char * LAT_INCREMENT_KW
static const char * TILE_SIZE_X_KW
static const char * CENTRAL_POINT1_LON_KW
static const char * PIXEL_TYPE_KW
static const char * LL_Y_KW
static const char * COMPRESSION_QUALITY_KW
static const char * METERS_PER_PIXEL_KW
static const char * HEMISPHERE_KW
static const char * UL_LON_KW
static const char * UR_LAT_KW
static const char * UR_LON_KW
static const char * SCALAR_TYPE_KW
static const char * ID_KW
static const char * PEN_COLOR_KW
static const char * DATA_FILE_KW
static const char * ELLIPSE_EPSG_CODE_KW
static const char * TIE_POINT_LAT_KW
static const char * CONVERGENCE_THRESHOLD_KW
static const char * SCALE_FACTOR_KW
static const char * NUMBER_REDUCED_RES_SETS_KW
static const char * ELEVATION_ANGLE_KW
static const char * POINT_WIDTH_HEIGHT_KW
static const char * IMAGE_TYPE_KW
static const char * OVERVIEW_COMPRESSION_QUALITY_KW
static const char * STD_PARALLEL_2_KW
static const char * SCALE_PER_PIXEL_Y_KW
static const char * CENTRAL_POINT1_LAT_KW
static const char * OVERVIEW_STOP_DIMENSION_KW
static const char * IMAGE_FILE_KW
static const char * ELEVATION_SOURCE_KW
static const char * QUALITY_KW
static const char * FILENAME_KW
static const char * THICKNESS_KW
static const char * NUMBER_OUTPUTS_KW
static const char * ORIGIN_X_KW
static const char * METERS_PER_PIXEL_X_KW
static const char * NUMBER_SAMPLES_KW
static const char * SRS_NAME_KW
static const char * PIXEL_SCALE_UNITS_KW
static const char * TIE_POINT_UNITS_KW
static const char * OUTPUT_FILE_PREFIX_KW
