#include <ossimKeywordNames.h>
Static Public Attributes | |
static const char * | AZIMUTH_ANGLE_KW = "azimuth_angle" |
static const char * | BAND_KW = "band" |
static const char * | BANDS_KW = "bands" |
static const char * | BORDER_SIZE_KW = "border_size" |
static const char * | BRUSH_COLOR_KW = "brush_color" |
static const char * | BYTE_ORDER_KW = "byte_order" |
static const char * | CE90_ABSOLUTE_KW = "ce90_absolute" |
static const char * | CE90_RELATIVE_KW = "ce90_relative" |
static const char * | CENTER_PIXEL_X_KW = "center_pixel_x" |
static const char * | CENTER_PIXEL_Y_KW = "center_pixel_y" |
static const char * | CENTRAL_MERIDIAN_KW = "central_meridian" |
static const char * | CENTRAL_POINT1_LAT_KW = "central_point1_lat" |
static const char * | CENTRAL_POINT1_LON_KW = "central_point1_lon" |
static const char * | CENTRAL_POINT2_LAT_KW = "central_point2_lat" |
static const char * | CENTRAL_POINT2_LON_KW = "central_point2_lon" |
static const char * | COMPRESS_KW = "compress" |
static const char * | COMPRESSION_QUALITY_KW = "compression_quality" |
static const char * | COMPRESSION_TYPE_KW = "compression_type" |
static const char * | CONVERGENCE_THRESHOLD_KW = "convergence_threshold" |
static const char * | CREATE_EX_KW |
static const char * | CREATE_EXTERNAL_GEOMETRY_KW = "create_external_geometry" |
static const char * | CREATE_IMAGE_KW = "create_image" |
static const char * | CREATE_HISTOGRAM_KW = "create_histogram" |
static const char * | CREATE_OVERVIEW_KW = "create_overview" |
static const char * | DATA_FILE_KW = "data_file" |
static const char * | DATE_KW = "date" |
static const char * | DATE_YEAR_KW = "year" |
static const char * | DATE_MONTH_KW = "month" |
static const char * | DATE_DAY_KW = "day" |
static const char * | DATE_HOUR_KW = "hour" |
static const char * | DATE_MIN_KW = "min" |
static const char * | DATE_SEC_KW = "sec" |
static const char * | DATE_FRACT_SEC_KW = "fract_sec" |
static const char * | DATUM_KW = "datum" |
static const char * | DECIMAL_DEGREES_PER_PIXEL_LAT = "decimal_degrees_per_pixel_lat" |
static const char * | DECIMAL_DEGREES_PER_PIXEL_LON = "decimal_degrees_per_pixel_lon" |
static const char * | DESCRIPTION_KW = "description" |
static const char * | ELEVATION_ANGLE_KW = "elevation_angle" |
static const char * | ELEVATION_CELL_KW = "elevation_cell" |
static const char * | ELEVATION_SOURCE_KW = "elevation_source" |
static const char * | ELEVATION_LOOKUP_FLAG_KW = "elevation_lookup_flag" |
static const char * | ELLIPSE_CODE_KW = "ellipse_code" |
static const char * | ELLIPSE_EPSG_CODE_KW = "ellipse_epsg_code" |
static const char * | ELLIPSE_NAME_KW = "ellipse_name" |
static const char * | ENABLED_KW = "enabled" |
static const char * | ENABLE_CACHE_KW = "enable_cache" |
static const char * | EXTRACT_VERTICES_KW = "extract_vertices" |
static const char * | ENTRY_KW = "entry" |
static const char * | FALSE_EASTING_NORTHING_KW = "false_easting_northing" |
static const char * | FALSE_EASTING_NORTHING_UNITS_KW = "false_easting_northing_units" |
static const char * | FALSE_EASTING_KW = "false_easting" |
static const char * | FALSE_NORTHING_KW = "false_northing" |
static const char * | FEATURE_NAME_KW = "feature_name" |
static const char * | FILE_KW = "file" |
static const char * | FILENAME_KW = "filename" |
static const char * | FILEPATH_KW = "filepath" |
static const char * | FILL_FLAG_KW = "fill_flag" |
static const char * | FRAME_INDEX_KW = "frame_index" |
static const char * | GCS_CODE_KW = "gcs_code" |
static const char * | GEOM_FILE_KW = "geom_file" |
static const char * | HEMISPHERE_KW = "hemisphere" |
static const char * | HORIZONTAL_SIZE_KW = "horizontal_size" |
static const char * | HAS_LUT_KW = "has_lut" |
static const char * | ID_KW ="id" |
static const char * | IMAGE_CE90_KW = "estimated_image_ce90" |
static const char * | IMAGE_FILE_KW = "image_file" |
static const char * | IMAGE_ID_KW = "image_id" |
static const char * | IMAGE_MODEL_TRANSFORM_MATRIX_KW = "image_model_transform_matrix" |
static const char * | IMAGE_MODEL_TRANSFORM_UNIT_KW = "image_model_transform_unit" |
static const char * | IMAGE_PATH_KW = "image_path" |
static const char * | IMAGE_TYPE_KW = "image_type" |
static const char * | IMAGE_DATE_KW = "image_date" |
static const char * | IMAGE_FILE_SIZE_KW = "image_file_size" |
static const char * | INPUT_RR_LEVEL_KW = "input_rr_level" |
static const char * | INTERLEAVE_TYPE_KW = "interleave_type" |
static const char * | JULIAN_DAY_KW = "julian_day" |
static const char * | LAT_INCREMENT_KW = "lat_increment" |
static const char * | LL_LAT_KW = "ll_lat" |
static const char * | LL_LON_KW = "ll_lon" |
static const char * | LR_LAT_KW = "lr_lat" |
static const char * | LR_LON_KW = "lr_lon" |
static const char * | LL_X_KW = "ll_x" |
static const char * | LL_Y_KW = "ll_y" |
static const char * | LR_X_KW = "lr_x" |
static const char * | LR_Y_KW = "lr_y" |
static const char * | LON_INCREMENT_KW = "lon_increment" |
static const char * | MAJOR_AXIS_KW = "major_axis" |
static const char * | MAX_VALUE_KW = "max_value" |
static const char * | MAX_ITERATIONS_KW = "max_iterations" |
static const char * | MAX_QUADTREE_LEVELS_KW = "max_quadtree_levels" |
static const char * | METADATA_TYPE_KW = "metadata_type" |
static const char * | METERS_PER_PIXEL_KW = "meters_per_pixel" |
static const char * | METERS_PER_PIXEL_X_KW = "meters_per_pixel_x" |
static const char * | METERS_PER_PIXEL_Y_KW = "meters_per_pixel_y" |
static const char * | MINOR_AXIS_KW = "minor_axis" |
static const char * | MIN_VALUE_KW = "min_value" |
static const char * | NULL_VALUE_KW = "null_value" |
static const char * | NUMBER_BANDS_KW = "number_bands" |
static const char * | NUMBER_ENTRIES_KW = "number_entries" |
static const char * | NUMBER_INPUT_BANDS_KW = "number_input_bands" |
static const char * | NUMBER_INPUTS_KW = "number_inputs" |
static const char * | NUMBER_OUTPUTS_KW = "number_outputs" |
static const char * | NUMBER_OUTPUT_BANDS_KW = "number_output_bands" |
static const char * | NUMBER_LINES_KW = "number_lines" |
static const char * | NUMBER_REDUCED_RES_SETS_KW = "number_reduced_res_sets" |
static const char * | NUMBER_SAMPLES_KW = "number_samples" |
static const char * | ORIGIN_LATITUDE_KW = "origin_latitude" |
static const char * | ORIGIN_X_KW = "origin_x" |
static const char * | ORIGIN_Y_KW = "origin_y" |
static const char * | ORIGINAL_MAP_UNITS_KW = "original_map_units" |
static const char * | OUTPUT_FILE_KW = "output_file" |
static const char * | OUTPUT_FILE_PREFIX_KW = "output_file_prefix" |
static const char * | OUTPUT_FILE_EXTENSION_KW = "output_file_extension" |
static const char * | OUTPUT_TILE_SIZE_KW = "output_tile_size" |
static const char * | OVERVIEW_COMPRESSION_QUALITY_KW = "overview_compression_quality" |
static const char * | OVERVIEW_COMPRESSION_TYPE_KW = "overview_compression_type" |
static const char * | OVERVIEW_FILE_KW = "overview_file" |
static const char * | OVERVIEW_STOP_DIMENSION_KW = "overview_stop_dimension" |
static const char * | PCS_CODE_KW = "pcs_code" |
static const char * | PEN_COLOR_KW = "pen_color" |
static const char * | PHOTOMETRIC_KW = "photometric" |
static const char * | PIXEL_SCALE_XY_KW = "pixel_scale_xy" |
static const char * | PIXEL_SCALE_UNITS_KW = "pixel_scale_units" |
static const char * | PIXEL_TYPE_KW = "pixel_type" |
static const char * | PLANAR_CONFIG_KW = "planar_config" |
static const char * | POINT_WIDTH_HEIGHT_KW = "point_width_height" |
static const char * | PROJECTION_KW = "projection" |
static const char * | QUALITY_KW = "quality" |
static const char * | QUERY_KW = "query" |
static const char * | RADIOMETRY_KW = "radiometry" |
static const char * | REDUCED_RES_LEVEL_KW = "reduced_res_level" |
static const char * | REF_GPT_LAT_KW = "ref_point_lat" |
static const char * | REF_GPT_LON_KW = "ref_point_lon" |
static const char * | REF_GPT_HGT_KW = "ref_point_hgt" |
static const char * | REF_IPT_LINE_KW = "ref_point_line" |
static const char * | REF_IPT_SAMP_KW = "ref_point_samp" |
static const char * | ROTATION_KW = "rotation" |
static const char * | SCALAR_TYPE_KW = "scalar_type" |
static const char * | SCALE_PER_PIXEL_X_KW = "scale_per_pixel_x" |
static const char * | SCALE_PER_PIXEL_Y_KW = "scale_per_pixel_y" |
static const char * | SCALE_FACTOR_KW = "scale_factor" |
static const char * | SCALE_X_KW = "scale_x" |
static const char * | SCALE_Y_KW = "scale_y" |
static const char * | SCALE_FACTOR_X_KW = "scale_factor_x" |
static const char * | SCALE_FACTOR_Y_KW = "scale_factor_y" |
static const char * | SENSOR_ID_KW = "sensor" |
static const char * | SRS_NAME_KW = "srs_name" |
static const char * | STD_PARALLEL_1_KW = "std_parallel_1" |
static const char * | STD_PARALLEL_2_KW = "std_parallel_2" |
static const char * | THICKNESS_KW = "thickness" |
static const char * | THREADS_KW = "threads" |
static const char * | TIE_POINT_EASTING_KW = "tie_point_easting" |
static const char * | TIE_POINT_NORTHING_KW = "tie_point_northing" |
static const char * | TIE_POINT_XY_KW = "tie_point_xy" |
static const char * | TIE_POINT_UNITS_KW = "tie_point_units" |
static const char * | TIE_POINT_LAT_KW = "tie_point_lat" |
static const char * | TIE_POINT_LON_KW = "tie_point_lon" |
static const char * | TILE_SOURCE_KW = "tile_source" |
static const char * | TILE_TYPE_KW = "tile_type" |
static const char * | TILE_SIZE_X_KW = "tile_size_x" |
static const char * | TILE_SIZE_Y_KW = "tile_size_y" |
static const char * | TRANSLATION_X_KW = "translation_x" |
static const char * | TRANSLATION_Y_KW = "translation_y" |
static const char * | TYPE_KW = "type" |
static const char * | UL_LAT_KW = "ul_lat" |
static const char * | UL_LON_KW = "ul_lon" |
static const char * | UNITS_KW = "units" |
static const char * | UR_LAT_KW = "ur_lat" |
static const char * | UR_LON_KW = "ur_lon" |
static const char * | UL_X_KW = "ul_x" |
static const char * | UL_Y_KW = "ul_y" |
static const char * | UR_X_KW = "ur_x" |
static const char * | UR_Y_KW = "ur_y" |
static const char * | VALID_VERTICES_KW = "valid_vertices_file" |
static const char * | VERTICAL_SIZE_KW = "vertical_size" |
static const char * | ZONE_KW = "zone" |
ossimKeywordNames () | |
ossimKeywordNames (const ossimKeywordNames &rhs) | |
const ossimKeywordNames & | operator= (const ossimKeywordNames &rhs) |
Definition at line 18 of file ossimKeywordNames.h.
protected |
Definition at line 191 of file ossimKeywordNames.cpp.
protected |
Definition at line 194 of file ossimKeywordNames.cpp.
protected |
Definition at line 197 of file ossimKeywordNames.cpp.
static |
Definition at line 24 of file ossimKeywordNames.h.
Referenced by ossimChipperUtil::hasBumpShadeArg(), ossimHillshadeTool::initialize(), ossimHillshadeTool::initProcessingChain(), ossimIkonosMetaData::loadState(), ossimQuickbirdMetaData::loadState(), ossimplugins::ossimSpot6DimapSupportData::loadState(), ossimplugins::ossimPleiadesDimapSupportData::loadState(), ossimTopographicCorrectionFilter::loadState(), ossimSpotDimapSupportData::loadState(), ossimFormosatDimapSupportData::loadState(), ossimBumpShadeTileSource::loadState(), ossimIkonosMetaData::saveState(), ossimQuickbirdMetaData::saveState(), ossimplugins::ossimSpot6DimapSupportData::saveState(), ossimplugins::ossimPleiadesDimapSupportData::saveState(), ossimTopographicCorrectionFilter::saveState(), ossimSpotDimapSupportData::saveState(), ossimFormosatDimapSupportData::saveState(), and ossimBumpShadeTileSource::saveState().
static |
Definition at line 25 of file ossimKeywordNames.h.
Referenced by ossimImageMetaData::saveState().
static |
Definition at line 26 of file ossimKeywordNames.h.
Referenced by ossimImageUtil::createThumbnail(), ossimChipProcTool::getBandList(), ossimChipperUtil::getBandList(), ossimChipperUtil::hasBandSelection(), ossimBandSelector::loadState(), ossimTiffTileSource::loadState(), ossimBandSelector::saveState(), and ossimTiffTileSource::saveState().
static |
Definition at line 27 of file ossimKeywordNames.h.
Referenced by ossimGdalOgrVectorAnnotation::getProperty(), ossimGdalOgrVectorAnnotation::getPropertyNames(), ossimGdalOgrVectorAnnotation::loadOmdFile(), ossimGdalOgrVectorAnnotation::loadState(), ossimEsriShapeFileFilter::loadState(), ossimGdalOgrVectorAnnotation::saveState(), ossimEsriShapeFileFilter::saveState(), and ossimGdalOgrVectorAnnotation::setProperty().
static |
Definition at line 28 of file ossimKeywordNames.h.
Referenced by ossimGdalOgrVectorAnnotation::getProperty(), ossimGdalOgrVectorAnnotation::getPropertyNames(), ossimGdalOgrVectorAnnotation::loadOmdFile(), ossimGdalOgrVectorAnnotation::loadState(), ossimSrcRecord::loadState(), ossimEsriShapeFileFilter::loadState(), ossimGdalOgrVectorAnnotation::saveState(), ossimEsriShapeFileFilter::saveState(), and ossimGdalOgrVectorAnnotation::setProperty().
static |
Definition at line 29 of file ossimKeywordNames.h.
Referenced by ossimHdf5Info::dumpNumericalTypeInfo(), ossimGeneralRasterWriter::loadState(), ossim_hdf5::printObject(), and ossimGeneralRasterWriter::saveState().
static |
Definition at line 30 of file ossimKeywordNames.h.
static |
Definition at line 31 of file ossimKeywordNames.h.
static |
Definition at line 32 of file ossimKeywordNames.h.
static |
Definition at line 33 of file ossimKeywordNames.h.
static |
Definition at line 34 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), ossimChipperUtil::getCentralMeridian(), ossimSrtmSupportData::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimChipProcTool::getProjectionOrigin(), ossimNewZealandMapGridProjection::loadState(), ossimMapProjection::loadState(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimMapProjection::print(), and ossimMapProjection::saveState().
static |
Definition at line 35 of file ossimKeywordNames.h.
Referenced by ossimObliqueMercatorProjection::loadState(), and ossimObliqueMercatorProjection::saveState().
static |
Definition at line 36 of file ossimKeywordNames.h.
static |
Definition at line 37 of file ossimKeywordNames.h.
static |
Definition at line 38 of file ossimKeywordNames.h.
static |
Definition at line 39 of file ossimKeywordNames.h.
static |
Definition at line 40 of file ossimKeywordNames.h.
Referenced by ossimGpkgWriter::getCompressionQuality(), ossimJpegWriter::getProperty(), ossimTiffWriter::getProperty(), ossimOpjCompressor::getProperty(), ossimKakaduCompressor::getProperty(), ossimJpegWriter::getPropertyNames(), ossimTiffWriter::getPropertyNames(), ossimOpjCompressor::getPropertyNames(), ossimKakaduCompressor::getPropertyNames(), ossimJpegWriter::loadState(), ossimOpjCompressor::loadState(), ossimKakaduCompressor::loadState(), ossimJpegWriter::saveState(), ossimOpjCompressor::saveState(), ossimKakaduCompressor::saveState(), ossimGpkgWriter::setCompressionQuality(), ossimJpegWriter::setProperty(), and ossimTiffWriter::setProperty().
static |
Definition at line 41 of file ossimKeywordNames.h.
Referenced by ossimTiffWriter::getProperty(), ossimTiffWriter::getPropertyNames(), and ossimTiffWriter::setProperty().
static |
Definition at line 42 of file ossimKeywordNames.h.
Referenced by ossim2dTo2dTransform::loadState(), and ossim2dTo2dTransform::saveState().
static |
Definition at line 43 of file ossimKeywordNames.h.
static |
Definition at line 44 of file ossimKeywordNames.h.
Referenced by ossimImageFileWriter::getPropertyNames(), ossimImageFileWriter::loadState(), ossimImageFileWriter::saveState(), and ossimImageFileWriter::setProperty().
static |
Definition at line 46 of file ossimKeywordNames.h.
static |
Definition at line 45 of file ossimKeywordNames.h.
static |
Definition at line 47 of file ossimKeywordNames.h.
static |
Definition at line 48 of file ossimKeywordNames.h.
static |
Definition at line 52 of file ossimKeywordNames.h.
static |
Definition at line 56 of file ossimKeywordNames.h.
static |
Definition at line 53 of file ossimKeywordNames.h.
static |
Definition at line 49 of file ossimKeywordNames.h.
static |
Definition at line 54 of file ossimKeywordNames.h.
static |
Definition at line 51 of file ossimKeywordNames.h.
static |
Definition at line 55 of file ossimKeywordNames.h.
static |
Definition at line 50 of file ossimKeywordNames.h.
static |
Definition at line 57 of file ossimKeywordNames.h.
Referenced by ossimDatumFactory::create(), ossimOgcWktTranslator::fromOssimKwl(), ossimMrSidReader::getGeoProjection(), ossimDoqqTileSource::getImageGeometry(), ossimSrtmSupportData::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimQuadProjection::loadState(), ossimNewZealandMapGridProjection::loadState(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimMapProjection::print(), ossimCadrgProjection::saveState(), ossimQuadProjection::saveState(), ossimMapProjection::saveState(), ossimSpaceImagingGeom::spaceImagingToOssimKeyword(), ossimERS::toOssimProjectionGeom(), and ossimERSFileWriter::writeFile().
static |
Definition at line 58 of file ossimKeywordNames.h.
Referenced by ossimSrtmSupportData::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimInfo::getImageGeometryInfo(), ossimElevImageSource::saveState(), ossimSrtmSupportData::saveState(), and ossimERS::toOssimProjectionGeom().
static |
Definition at line 59 of file ossimKeywordNames.h.
static |
Definition at line 60 of file ossimKeywordNames.h.
Referenced by ossimAdjustmentInfo::loadState(), ossimEnviHeader::loadState(), ossimConnectableObject::loadState(), ossimAdjustmentInfo::saveState(), ossimAdjustableParameterInfo::saveState(), and ossimConnectableObject::saveState().
static |
Definition at line 61 of file ossimKeywordNames.h.
Referenced by ossimHillshadeTool::initProcessingChain(), ossimQuickbirdMetaData::loadState(), ossimIkonosMetaData::loadState(), ossimplugins::ossimSpot6DimapSupportData::loadState(), ossimplugins::ossimPleiadesDimapSupportData::loadState(), ossimTopographicCorrectionFilter::loadState(), ossimSpotDimapSupportData::loadState(), ossimFormosatDimapSupportData::loadState(), ossimBumpShadeTileSource::loadState(), ossimQuickbirdMetaData::saveState(), ossimIkonosMetaData::saveState(), ossimplugins::ossimSpot6DimapSupportData::saveState(), ossimplugins::ossimPleiadesDimapSupportData::saveState(), ossimTopographicCorrectionFilter::saveState(), ossimSpotDimapSupportData::saveState(), ossimFormosatDimapSupportData::saveState(), and ossimBumpShadeTileSource::saveState().
static |
Definition at line 62 of file ossimKeywordNames.h.
static |
Definition at line 64 of file ossimKeywordNames.h.
Referenced by ossimMapProjection::loadState(), and ossimMapProjection::saveState().
static |
Definition at line 63 of file ossimKeywordNames.h.
Referenced by ossimSlopeTool::initProcessingChain(), and ossimChipProcTool::loadDemFiles().
static |
Definition at line 65 of file ossimKeywordNames.h.
Referenced by ossimEllipsoid::loadState(), and ossimEllipsoid::saveState().
static |
Definition at line 66 of file ossimKeywordNames.h.
static |
Definition at line 67 of file ossimKeywordNames.h.
Referenced by ossimEllipsoid::saveState().
static |
Definition at line 69 of file ossimKeywordNames.h.
Referenced by ossimNitfTileSource::getProperty(), ossimNitfTileSource::getPropertyNames(), ossimCacheTileSource::loadState(), ossimCacheTileSource::saveState(), ossimNitfTileSource::saveState(), and ossimNitfTileSource::setProperty().
static |
Definition at line 68 of file ossimKeywordNames.h.
Referenced by ossimSource::getProperty(), ossimImageSource::getProperty(), ossimSource::getPropertyNames(), ossimGammaRemapper::loadState(), ossimSource::loadState(), ossimGeoidImage::loadState(), ossimSource::saveState(), ossimGeoidImage::saveState(), and ossimSource::setProperty().
static |
Definition at line 71 of file ossimKeywordNames.h.
Referenced by ossimChipperUtil::getEntryNumber(), ossimInfo::getImageInfo(), ossimVerticesFinderTool::getKwlTemplate(), ossimImageHandler::getProperty(), ossimImageHandler::getPropertyNames(), ossimVerticesFinderTool::initialize(), ossimSubImageTool::initialize(), ossimChipProcTool::loadImageFiles(), ossimSrcRecord::loadState(), operator<<(), ossimPointCloudImageHandler::saveState(), ossimNBandLutDataObject::saveState(), ossimSrcRecord::setEntryIndex(), and ossimImageHandler::setProperty().
static |
Definition at line 70 of file ossimKeywordNames.h.
static |
Definition at line 74 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), and ossimTiffInfo::getFalseEasting().
static |
Definition at line 72 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimMapProjection::print(), and ossimMapProjection::saveState().
static |
Definition at line 73 of file ossimKeywordNames.h.
static |
Definition at line 75 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), and ossimTiffInfo::getFalseNorthing().
static |
Definition at line 76 of file ossimKeywordNames.h.
Referenced by ossimEsriShapeFileFilter::loadState(), and ossimEsriShapeFileFilter::saveState().
static |
Definition at line 77 of file ossimKeywordNames.h.
static |
Definition at line 78 of file ossimKeywordNames.h.
Referenced by ossimPointCloudImageHandlerFactory::createObject(), ossimGdalFactory::createObject(), ossimImageWriterFactoryRegistry::createWriter(), ossimIgenGenerator::generateGeoTiledSpecList(), ossimIgenGenerator::generatePixelTiledSpecList(), ossimGpkgWriter::getFilename(), ossimIgenGenerator::getImageFilenamesFromSpecList(), ossimNBandToIndexFilter::getProperty(), ossimWatermarkFilter::getProperty(), ossimMetadataFileWriter::getProperty(), ossimImageFileWriter::getProperty(), ossimNBandToIndexFilter::getPropertyNames(), ossimWatermarkFilter::getPropertyNames(), ossimMetadataFileWriter::getPropertyNames(), ossimImageFileWriter::getPropertyNames(), ossimDoqqTileSource::loadState(), ossimVpfAnnotationSource::loadState(), ossimHistogramSource::loadState(), ossimLandsatTopoCorrectionFilter::loadState(), ossimERSTileSource::loadState(), ossimMapViewController::loadState(), ossimElevationDatabase::loadState(), ossimGeneralRasterWriter::loadState(), ossimGdalOgrVectorAnnotation::loadState(), ossimSrcRecord::loadState(), ossimMetadataFileWriter::loadState(), ossimSrtmSupportData::loadState(), ossimEsriShapeFileFilter::loadState(), ossimImageFileWriter::loadState(), ossimEnviHeader::loadState(), ossimNBandLutDataObject::loadState(), ossimVpfAnnotationSource::saveState(), ossimHistogramSource::saveState(), ossimLandsatTopoCorrectionFilter::saveState(), ossimMapViewController::saveState(), ossimGdalOgrVectorAnnotation::saveState(), ossimWatermarkFilter::saveState(), ossimSrtmSupportData::saveState(), ossimEsriShapeFileFilter::saveState(), ossimGeneralRasterInfo::saveState(), ossimImageFileWriter::saveState(), ossimImageHandler::saveState(), ossimSrcRecord::setFilename(), ossimGeneralRasterElevHandler::setFilename(), ossimNBandToIndexFilter::setProperty(), ossimWatermarkFilter::setProperty(), ossimMetadataFileWriter::setProperty(), and ossimImageFileWriter::setProperty().
static |
Definition at line 79 of file ossimKeywordNames.h.
Referenced by ossimImageFileWriter::loadState().
static |
Definition at line 80 of file ossimKeywordNames.h.
Referenced by ossimGdalOgrVectorAnnotation::getProperty(), ossimGdalOgrVectorAnnotation::getPropertyNames(), ossimGdalOgrVectorAnnotation::loadState(), ossimSrcRecord::loadState(), ossimEsriShapeFileFilter::loadState(), ossimGdalOgrVectorAnnotation::saveState(), ossimEsriShapeFileFilter::saveState(), and ossimGdalOgrVectorAnnotation::setProperty().
static |
Definition at line 81 of file ossimKeywordNames.h.
static |
Definition at line 82 of file ossimKeywordNames.h.
Referenced by ossimEpsgDatumFactory::create().
static |
Definition at line 83 of file ossimKeywordNames.h.
Referenced by ossimSensorModelFactory::createProjection(), ossimMapProjectionFactory::createProjection(), and ossimSrcRecord::setGeom().
static |
Definition at line 86 of file ossimKeywordNames.h.
static |
Definition at line 84 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), ossimChipperUtil::getHemisphere(), ossimDemHeader::getImageGeometry(), ossimUtmProjection::loadState(), ossimChipProcTool::newUtmProjection(), ossimUtmProjection::saveState(), ossimERS::toOssimProjectionGeom(), and ossimERSFileWriter::writeFile().
static |
Definition at line 85 of file ossimKeywordNames.h.
static |
Definition at line 87 of file ossimKeywordNames.h.
Referenced by ossimConnectableObject::loadState(), and ossimConnectableObject::saveState().
static |
Definition at line 88 of file ossimKeywordNames.h.
static |
Definition at line 95 of file ossimKeywordNames.h.
Referenced by ossimplugins::ossimSpot6DimapSupportData::loadState(), ossimplugins::ossimPleiadesDimapSupportData::loadState(), ossimSpotDimapSupportData::loadState(), ossimFormosatDimapSupportData::loadState(), ossimplugins::ossimSpot6DimapSupportData::saveState(), ossimplugins::ossimPleiadesDimapSupportData::saveState(), ossimSpotDimapSupportData::saveState(), and ossimFormosatDimapSupportData::saveState().
static |
Definition at line 89 of file ossimKeywordNames.h.
Referenced by ossimChipProcTool::getBandList(), ossimBandMergeTool::getKwlTemplate(), ossimVerticesFinderTool::getKwlTemplate(), ossimVerticesFinderTool::initialize(), ossimBandMergeTool::initialize(), ossimSubImageTool::initialize(), ossimSlopeTool::initProcessingChain(), ossimHdf5Tool::loadImageFiles(), ossimChipProcTool::loadImageFiles(), ossimSrtmSupportData::loadState(), and ossimChipProcTool::processRemainingArgs().
static |
Definition at line 96 of file ossimKeywordNames.h.
static |
Definition at line 90 of file ossimKeywordNames.h.
static |
Definition at line 91 of file ossimKeywordNames.h.
Referenced by ossimMapProjection::saveState().
static |
Definition at line 92 of file ossimKeywordNames.h.
static |
Definition at line 93 of file ossimKeywordNames.h.
static |
Definition at line 94 of file ossimKeywordNames.h.
Referenced by ossimGdalImageWriterFactory::createWriter(), ossimImageWriterFactory::createWriter(), ossimPdfWriter::getImageType(), ossimPdfWriter::getProperty(), ossimImageFileWriter::getProperty(), ossimPdfWriter::getPropertyNames(), and ossimPdfWriter::setProperty().
static |
Definition at line 97 of file ossimKeywordNames.h.
Referenced by ossimGeneralRasterWriter::loadState().
static |
Definition at line 98 of file ossimKeywordNames.h.
Referenced by ossimGeneralRasterTileSource::getHdrInfo(), ossimInterleaveTypeLut::getKeyword(), and ossimGeneralRasterTileSource::getXmlInfo().
static |
Definition at line 99 of file ossimKeywordNames.h.
static |
Definition at line 100 of file ossimKeywordNames.h.
static |
Definition at line 101 of file ossimKeywordNames.h.
Referenced by ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimCadrgProjection::loadState(), ossimQuadProjection::loadState(), ossimCadrgProjection::saveState(), and ossimQuadProjection::saveState().
static |
Definition at line 102 of file ossimKeywordNames.h.
static |
Definition at line 105 of file ossimKeywordNames.h.
static |
Definition at line 106 of file ossimKeywordNames.h.
static |
Definition at line 109 of file ossimKeywordNames.h.
static |
Definition at line 103 of file ossimKeywordNames.h.
static |
Definition at line 104 of file ossimKeywordNames.h.
static |
Definition at line 107 of file ossimKeywordNames.h.
Referenced by ossimInfo::getImageInfo(), ossimQuadTreeWarpNode::loadState(), and ossimQuadTreeWarpNode::saveState().
static |
Definition at line 108 of file ossimKeywordNames.h.
static |
Definition at line 110 of file ossimKeywordNames.h.
Referenced by ossimEllipsoid::loadState(), ossimMapProjection::print(), and ossimEllipsoid::saveState().
static |
Definition at line 112 of file ossimKeywordNames.h.
static |
Definition at line 113 of file ossimKeywordNames.h.
static |
Definition at line 111 of file ossimKeywordNames.h.
Referenced by ossimDtedTileSource::loadMetaData(), ossimSrtmSupportData::loadOmd(), ossimElevImageSource::saveState(), ossimImageMetaData::saveState(), and ossimImageMetaData::updateMetaData().
static |
Definition at line 114 of file ossimKeywordNames.h.
static |
Definition at line 115 of file ossimKeywordNames.h.
Referenced by ossimRangeDomeTileSource::getProperty(), ossimPointCloudImageHandler::getProperty(), ossimRangeDomeTileSource::loadState(), ossimRangeDomeTileSource::saveState(), ossimPointCloudImageHandler::saveState(), ossimRangeDomeTileSource::setProperty(), ossimPointCloudImageHandler::setProperty(), and writeRaster().
static |
Definition at line 116 of file ossimKeywordNames.h.
Referenced by ossimDoqqTileSource::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimInfo::getImageGeometryInfo(), ossimTiffWorld::loadFromOssimGeom(), ossimMapProjection::print(), ossimSpaceImagingGeom::spaceImagingToOssimKeyword(), and ossimERS::toOssimProjectionGeom().
static |
Definition at line 117 of file ossimKeywordNames.h.
Referenced by ossimDoqqTileSource::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimInfo::getImageGeometryInfo(), ossimTiffWorld::loadFromOssimGeom(), ossimRangeDomeTileSource::loadState(), ossimMapProjection::print(), ossimSpaceImagingGeom::spaceImagingToOssimKeyword(), and ossimERS::toOssimProjectionGeom().
static |
Definition at line 119 of file ossimKeywordNames.h.
static |
Definition at line 118 of file ossimKeywordNames.h.
Referenced by ossimMapProjection::print(), and ossimEllipsoid::saveState().
static |
Definition at line 120 of file ossimKeywordNames.h.
Referenced by ossimGeneralRasterTileSource::getHdrInfo(), ossimNBandLutDataObject::loadState(), ossimImageMetaData::saveState(), ossimNBandLutDataObject::saveState(), and ossimImageMetaData::updateMetaData().
static |
Definition at line 121 of file ossimKeywordNames.h.
Referenced by ossimImageMetaData::getBandCount(), ossimGeneralRasterTileSource::getHdrInfo(), ossimImageHandler::getProperty(), ossimImageHandler::getPropertyNames(), ossimGeneralRasterTileSource::getXmlInfo(), ossimIkonosMetaData::loadState(), ossimplugins::ossimSpot6DimapSupportData::loadState(), ossimplugins::ossimPleiadesDimapSupportData::loadState(), ossimTopographicCorrectionFilter::loadState(), ossimSpotDimapSupportData::loadState(), ossimFormosatDimapSupportData::loadState(), ossimEnviHeader::loadState(), ossimNBandLutDataObject::loadState(), operator<<(), ossimIkonosMetaData::saveState(), ossimplugins::ossimSpot6DimapSupportData::saveState(), ossimplugins::ossimPleiadesDimapSupportData::saveState(), ossimSrtmSupportData::saveState(), ossimTopographicCorrectionFilter::saveState(), ossimImageMetaData::saveState(), ossimPiecewiseRemapper::saveState(), ossimSpotDimapSupportData::saveState(), ossimFormosatDimapSupportData::saveState(), ossimNBandLutDataObject::saveState(), and ossimSpaceImagingGeom::spaceImagingToOssimKeyword().
static |
Definition at line 122 of file ossimKeywordNames.h.
Referenced by ossimInfo::getImageGeometryInfo(), ossimInfo::getImageInfo(), ossimNBandLutDataObject::loadState(), operator<<(), and ossimNBandLutDataObject::saveState().
static |
Definition at line 123 of file ossimKeywordNames.h.
Referenced by ossimAdrgTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), and ossimInfo::getImageInfo().
static |
Definition at line 124 of file ossimKeywordNames.h.
static |
Definition at line 127 of file ossimKeywordNames.h.
Referenced by ossimGmlSupportData::addLineSamps(), ossimMrSidReader::getGeoProjection(), ossimGeneralRasterTileSource::getHdrInfo(), ossimElevImageSource::getImageGeometry(), ossimSrtmSupportData::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimInfo::getImageInfo(), ossimImageHandler::getProperty(), ossimImageHandler::getPropertyNames(), ossimGeneralRasterTileSource::getXmlInfo(), ossimSrtmSupportData::loadOmd(), ossimCadrgProjection::loadState(), ossimEnviHeader::loadState(), ossimCadrgProjection::saveState(), ossimElevImageSource::saveState(), ossimSrtmSupportData::saveState(), and ossimSpaceImagingGeom::spaceImagingToOssimKeyword().
static |
Definition at line 126 of file ossimKeywordNames.h.
Referenced by ossimAdrgTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimInfo::getImageInfo(), and ossimBandSelector::saveState().
static |
Definition at line 125 of file ossimKeywordNames.h.
static |
Definition at line 128 of file ossimKeywordNames.h.
Referenced by ossimAdrgTileSource::getImageGeometry(), ossimImageHandler::getProperty(), and ossimImageHandler::getPropertyNames().
static |
Definition at line 129 of file ossimKeywordNames.h.
static |
Definition at line 130 of file ossimKeywordNames.h.
Referenced by ossimGmlSupportData::addScale(), ossimOgcWktTranslator::fromOssimKwl(), ossimSrtmSupportData::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimChipperUtil::getOriginLatitude(), ossimChipProcTool::getProjectionOrigin(), ossimNewZealandMapGridProjection::loadState(), ossimMapProjection::loadState(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimMapProjection::print(), and ossimMapProjection::saveState().
static |
Definition at line 131 of file ossimKeywordNames.h.
static |
Definition at line 132 of file ossimKeywordNames.h.
static |
Definition at line 133 of file ossimKeywordNames.h.
static |
Definition at line 136 of file ossimKeywordNames.h.
static |
Definition at line 134 of file ossimKeywordNames.h.
Referenced by ossimShorelineTool::execute(), ossimVerticesFinderTool::getKwlTemplate(), ossimAutRegUtil::getOutputFilename(), ossimChipperUtil::getOutputFilename(), ossimVerticesFinderTool::initialize(), ossimSubImageTool::initialize(), ossimBitMaskWriter::loadState(), and ossimChipProcTool::processRemainingArgs().
static |
Definition at line 135 of file ossimKeywordNames.h.
static |
Definition at line 137 of file ossimKeywordNames.h.
Referenced by ossimTiffWriter::getProperty(), ossimPdfWriter::getProperty(), ossimTiffWriter::getPropertyNames(), ossimPdfWriter::getPropertyNames(), ossimPdfWriter::getTileSize(), ossimTiffWriter::setProperty(), and ossimPdfWriter::setProperty().
static |
Definition at line 138 of file ossimKeywordNames.h.
static |
Definition at line 139 of file ossimKeywordNames.h.
static |
Definition at line 140 of file ossimKeywordNames.h.
Referenced by ossimSrcRecord::setOverview().
static |
Definition at line 141 of file ossimKeywordNames.h.
Referenced by ossim::computeLevels(), and ossimOverviewBuilderBase::initializePreferenceSettings().
static |
Definition at line 142 of file ossimKeywordNames.h.
Referenced by ossimEpsgProjectionFactory::createProjection(), ossimEpsgProjectionDatabase::createProjFromFormatBRecord(), ossimOgcWktTranslator::fromOssimKwl(), ossimMrSidReader::getGeoProjection(), ossimGmlSupportData::getImageGeometryFromRectifiedGrid(), ossimTiffInfo::getPcsCode(), ossimGeoPdfReader::getVPGeoProjection(), ossimMapProjection::loadState(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimMapProjection::print(), and ossimMapProjection::saveState().
static |
Definition at line 143 of file ossimKeywordNames.h.
static |
Definition at line 144 of file ossimKeywordNames.h.
static |
Definition at line 147 of file ossimKeywordNames.h.
Referenced by ossimGmlSupportData::addScale(), ossimEpsgProjectionFactory::createProjection(), ossimMrSidReader::getGeoProjection(), ossimAdrgTileSource::getImageGeometry(), ossimMapProjection::loadState(), ossimMapProjection::print(), ossimMapProjection::saveState(), and ossimTiffWorld::saveToOssimGeom().
static |
Definition at line 145 of file ossimKeywordNames.h.
Referenced by ossimGmlSupportData::addScale(), ossimEpsgProjectionFactory::createProjection(), ossimMrSidReader::getGeoProjection(), ossimAdrgTileSource::getImageGeometry(), ossimTiffWorld::loadFromOssimGeom(), ossimMapProjection::loadState(), ossimMapProjection::print(), ossimMapProjection::saveState(), ossimTiffWorld::saveToOssimGeom(), and ossimERSFileWriter::writeFile().
static |
Definition at line 148 of file ossimKeywordNames.h.
Referenced by ossimIgenGenerator::addPixelType(), ossimMetadataFileWriter::loadState(), ossimMapProjectionInfo::loadState(), ossimImageFileWriter::loadState(), and ossimTiffWorld::saveToOssimGeom().
static |
Definition at line 149 of file ossimKeywordNames.h.
static |
Definition at line 150 of file ossimKeywordNames.h.
Referenced by ossimGdalOgrVectorAnnotation::getProperty(), ossimGdalOgrVectorAnnotation::getPropertyNames(), ossimGdalOgrVectorAnnotation::loadState(), ossimEsriShapeFileFilter::loadState(), ossimGdalOgrVectorAnnotation::saveState(), ossimEsriShapeFileFilter::saveState(), and ossimGdalOgrVectorAnnotation::setProperty().
static |
Definition at line 151 of file ossimKeywordNames.h.
Referenced by ossimChipProcTool::createOutputProjection(), ossimEpsgProjectionFactory::createProjection(), ossimMrSidReader::getGeoProjection(), and ossimChipperUtil::getOutputProjectionType().
static |
Definition at line 152 of file ossimKeywordNames.h.
Referenced by ossimJpegCodec::getProperty(), ossimKakaduJpipHandler::getPropertyNames(), ossimJpegCodec::getPropertyNames(), ossimKakaduJpipHandler::loadState(), ossimJpegCodec::loadState(), ossimKakaduJpipHandler::saveState(), ossimJpegCodec::saveState(), and ossimJpegCodec::setProperty().
static |
Definition at line 153 of file ossimKeywordNames.h.
Referenced by ossimGdalOgrVectorAnnotation::loadState(), ossimSrcRecord::loadState(), and ossimGdalOgrVectorAnnotation::saveState().
static |
Definition at line 154 of file ossimKeywordNames.h.
static |
Definition at line 155 of file ossimKeywordNames.h.
static |
Definition at line 158 of file ossimKeywordNames.h.
static |
Definition at line 156 of file ossimKeywordNames.h.
static |
Definition at line 157 of file ossimKeywordNames.h.
static |
Definition at line 159 of file ossimKeywordNames.h.
static |
Definition at line 160 of file ossimKeywordNames.h.
static |
Definition at line 161 of file ossimKeywordNames.h.
Referenced by ossimAffineTransform::loadState(), and ossimAffineTransform::saveState().
static |
Definition at line 162 of file ossimKeywordNames.h.
Referenced by ossimHdf5Info::dumpDataset(), ossimHdf5Info::dumpNumericalTypeInfo(), ossimGeneralRasterTileSource::getHdrInfo(), ossimScalarTypeLut::getKeyword(), ossimCastTileSourceFilter::getProperty(), ossimImageHandler::getProperty(), ossimCastTileSourceFilter::getPropertyNames(), ossimImageHandler::getPropertyNames(), ossimGeneralRasterTileSource::getXmlInfo(), ossimRectilinearDataObject::loadState(), ossim_hdf5::printObject(), ossimTableRemapper::saveState(), ossimCastTileSourceFilter::saveState(), ossimImageMetaData::saveState(), ossimRectilinearDataObject::saveState(), ossimNBandLutDataObject::saveState(), ossimCastTileSourceFilter::setProperty(), and ossimImageMetaData::updateMetaData().
static |
Definition at line 165 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), ossimTiffInfo::getScaleFactor(), ossimTransMercatorProjection::loadState(), ossimTransCylEquAreaProjection::loadState(), ossimMercatorProjection::loadState(), ossimObliqueMercatorProjection::loadState(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimTransMercatorProjection::print(), ossimBngProjection::saveState(), ossimTransMercatorProjection::saveState(), ossimTransCylEquAreaProjection::saveState(), ossimMercatorProjection::saveState(), ossimObliqueMercatorProjection::saveState(), and ossimGeoTiff::writeTags().
static |
Definition at line 168 of file ossimKeywordNames.h.
static |
Definition at line 169 of file ossimKeywordNames.h.
static |
Definition at line 163 of file ossimKeywordNames.h.
Referenced by ossimImageToPlaneNormalFilter::loadState(), and ossimImageToPlaneNormalFilter::saveState().
static |
Definition at line 164 of file ossimKeywordNames.h.
static |
Definition at line 166 of file ossimKeywordNames.h.
Referenced by ossimAffineTransform::loadState(), ossimFilterResampler::loadState(), ossimScaleFilter::loadState(), ossimAffineTransform::saveState(), ossimFilterResampler::saveState(), and ossimScaleFilter::saveState().
static |
Definition at line 167 of file ossimKeywordNames.h.
static |
Definition at line 170 of file ossimKeywordNames.h.
static |
Definition at line 171 of file ossimKeywordNames.h.
Referenced by ossimGmlSupportData::getImageGeometryFromRectifiedGrid(), and ossimMapProjection::saveState().
static |
Definition at line 172 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), ossimTiffInfo::getStdParallelOne(), ossimLambertConformalConicProjection::loadState(), ossimAlbersProjection::loadState(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimLambertConformalConicProjection::print(), ossimLambertConformalConicProjection::saveState(), ossimAlbersProjection::saveState(), and ossimGeoTiff::writeTags().
static |
Definition at line 173 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), ossimTiffInfo::getStdParallelTwo(), ossimLambertConformalConicProjection::loadState(), ossimAlbersProjection::loadState(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimLambertConformalConicProjection::print(), ossimLambertConformalConicProjection::saveState(), ossimAlbersProjection::saveState(), and ossimGeoTiff::writeTags().
static |
Definition at line 174 of file ossimKeywordNames.h.
static |
Definition at line 175 of file ossimKeywordNames.h.
static |
Definition at line 176 of file ossimKeywordNames.h.
Referenced by ossimDoqqTileSource::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimTiffWorld::loadFromOssimGeom(), ossimSpaceImagingGeom::spaceImagingToOssimKeyword(), and ossimERS::toOssimProjectionGeom().
static |
Definition at line 182 of file ossimKeywordNames.h.
Referenced by ossimSrtmSupportData::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimInfo::getImageGeometryInfo(), ossimSrtmSupportData::loadOmd(), ossimElevImageSource::loadState(), ossimElevImageSource::saveState(), ossimSrtmSupportData::saveState(), and ossimERS::toOssimProjectionGeom().
static |
Definition at line 183 of file ossimKeywordNames.h.
Referenced by ossimSrtmSupportData::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimInfo::getImageGeometryInfo(), ossimSrtmSupportData::loadOmd(), ossimElevImageSource::saveState(), ossimSrtmSupportData::saveState(), and ossimERS::toOssimProjectionGeom().
static |
Definition at line 177 of file ossimKeywordNames.h.
static |
Definition at line 180 of file ossimKeywordNames.h.
Referenced by ossimGmlSupportData::addTie(), ossimEpsgProjectionFactory::createProjection(), ossimMapProjectionInfo::getGeom(), ossimMrSidReader::getGeoProjection(), ossimAdrgTileSource::getImageGeometry(), ossimMapProjection::print(), ossimMapProjection::saveState(), and ossimTiffWorld::saveToOssimGeom().
static |
Definition at line 178 of file ossimKeywordNames.h.
Referenced by ossimGmlSupportData::addTie(), ossimEpsgProjectionFactory::createProjection(), ossimMapProjectionInfo::getGeom(), ossimMrSidReader::getGeoProjection(), ossimAdrgTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimTiffWorld::loadFromOssimGeom(), ossimMapProjection::print(), ossimMapProjection::saveState(), ossimTiffWorld::saveToOssimGeom(), and ossimERSFileWriter::writeFile().
static |
Definition at line 186 of file ossimKeywordNames.h.
static |
Definition at line 187 of file ossimKeywordNames.h.
static |
Definition at line 184 of file ossimKeywordNames.h.
static |
Definition at line 185 of file ossimKeywordNames.h.
static |
Definition at line 188 of file ossimKeywordNames.h.
static |
Definition at line 189 of file ossimKeywordNames.h.
static |
Definition at line 190 of file ossimKeywordNames.h.
Referenced by ossimPngCodecFactory::createCodec(), ossimCodecFactory::createCodec(), ossimKakaduCodecFactory::createCodec(), ossimElevationDatabaseFactory::createDatabase(), ossimImageGeometryFactory::createGeometry(), ossimImageReconstructionFilterFactory::createObject(), ossimBaseObjectFactory::createObject(), ossimImageMetaDataWriterFactory::createObject(), ossimPointCloudImageHandlerFactory::createObject(), ossimGdalFactory::createObject(), ossimHdf5ProjectionFactory::createProjection(), ossimSensorModelFactory::createProjection(), ossimGdalProjectionFactory::createProjection(), ossimMiscProjectionFactory::createProjection(), ossimplugins::ossimPluginProjectionFactory::createProjection(), ossimMapProjectionFactory::createProjection(), ossim::ImageHandlerStateFactory::createState(), ossimToolFactoryBase::createTool(), ossim2dTo2dTransformFactory::createTransform(), ossimProjectionViewControllerFactory::createViewController(), ossimGdalImageWriterFactory::createWriter(), ossimImageWriterFactory::createWriter(), ossimImageWriterFactoryRegistry::createWriter(), ossimOpjWriterFactory::createWriter(), ossimPngWriterFactory::createWriter(), ossimSqliteWriterFactory::createWriter(), ossimKakaduWriterFactory::createWriter(), ossimKmlSuperOverlayWriterFactory::createWriter(), ossimOgcWktTranslator::fromOssimKwl(), ossimImageHandler::getExternalImageGeometry(), ossimMrSidReader::getGeoProjection(), ossimDoqqTileSource::getImageGeometry(), ossimSrtmSupportData::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimGmlSupportData::getImageGeometryFromRectifiedGrid(), ossimplugins::ossimRadarSatModel::internalSaveState(), ossimIkonosMetaData::loadState(), ossimQuickbirdMetaData::loadState(), ossimPolarStereoProjection::loadState(), ossimAdjMapModel::loadState(), ossimGnomonicProjection::loadState(), ossimStereographicProjection::loadState(), ossimPolyconicProjection::loadState(), ossimCassiniProjection::loadState(), ossimMillerProjection::loadState(), ossimOrthoGraphicProjection::loadState(), ossimBonneProjection::loadState(), ossimMollweidProjection::loadState(), ossimVanDerGrintenProjection::loadState(), ossimEckert4Projection::loadState(), ossimEckert6Projection::loadState(), ossimSinusoidalProjection::loadState(), ossimCylEquAreaProjection::loadState(), ossimplugins::ossimTileMapModel::loadState(), ossimTransMercatorProjection::loadState(), ossimAzimEquDistProjection::loadState(), ossimTransCylEquAreaProjection::loadState(), ossimMercatorProjection::loadState(), ossimGeoidImage::loadState(), ossimplugins::ossimErsSarModel::loadState(), ossimObliqueMercatorProjection::loadState(), ossimplugins::ossimRadarSatModel::loadState(), ossimplugins::ossimAlosPalsarModel::loadState(), ossimplugins::ossimRadarSat2RPCModel::loadState(), ossimplugins::ossimSpot6DimapSupportData::loadState(), ossimplugins::ossimTerraSarModel::loadState(), ossimplugins::ossimPleiadesDimapSupportData::loadState(), ossimplugins::ossimRadarSat2Model::loadState(), ossimLambertConformalConicProjection::loadState(), ossimAlbersProjection::loadState(), ossimSpotDimapSupportData::loadState(), ossimFormosatDimapSupportData::loadState(), ossimGeoPdfReader::loadState(), ossimImageGeometry::loadState(), ossimStatePlaneProjectionInfo::populateProjectionKeywords(), ossimMapProjection::print(), ossimBngProjection::saveState(), ossimPolynomProjection::saveState(), ossimHdf5GridModel::saveState(), ossimObject::saveState(), ossimIkonosMetaData::saveState(), ossimQuickbirdMetaData::saveState(), ossimMultiResLevelHistogram::saveState(), ossimAdjMapModel::saveState(), ossimplugins::ossimTileMapModel::saveState(), ossimGeoidImage::saveState(), ossimplugins::ossimEnvisatAsarModel::saveState(), ossimplugins::ErsSarLeader::saveState(), ossimplugins::ossimAlosPalsarModel::saveState(), ossimProjection::saveState(), ossimplugins::ossimSpot6DimapSupportData::saveState(), ossimplugins::ossimPleiadesDimapSupportData::saveState(), ossimGeoPolygon::saveState(), ossimPolyArea2d::saveState(), ossimSpotDimapSupportData::saveState(), ossimFormosatDimapSupportData::saveState(), ossimPolygon::saveState(), ossimPolyLine::saveState(), ossimImageFileWriter::saveState(), ossimNBandLutDataObject::saveState(), ossimIrect::saveState(), ossimDrect::saveState(), ossimSpaceImagingGeom::spaceImagingToOssimKeyword(), ossimERS::toOssimProjectionGeom(), ossimERSFileWriter::writeFile(), ossimAdjMapModel::writeGeomTemplate(), and ossimplugins::ossimTileMapModel::writeGeomTemplate().
static |
Definition at line 191 of file ossimKeywordNames.h.
static |
Definition at line 192 of file ossimKeywordNames.h.
static |
Definition at line 197 of file ossimKeywordNames.h.
Referenced by ossimInfo::getImageInfo(), ossimQuadProjection::loadState(), ossimQuadTreeWarpNode::loadState(), ossimQuadProjection::saveState(), and ossimQuadTreeWarpNode::saveState().
static |
Definition at line 198 of file ossimKeywordNames.h.
static |
Definition at line 193 of file ossimKeywordNames.h.
Referenced by ossimUnitTypeLut::getKeyword(), ossimGdalOgrVectorAnnotation::saveState(), and ossimAdjustableParameterInfo::saveState().
static |
Definition at line 195 of file ossimKeywordNames.h.
static |
Definition at line 196 of file ossimKeywordNames.h.
static |
Definition at line 199 of file ossimKeywordNames.h.
static |
Definition at line 200 of file ossimKeywordNames.h.
static |
Definition at line 201 of file ossimKeywordNames.h.
static |
Definition at line 202 of file ossimKeywordNames.h.
static |
Definition at line 203 of file ossimKeywordNames.h.
Referenced by ossimOgcWktTranslator::fromOssimKwl(), ossimDoqqTileSource::getImageGeometry(), ossimDemHeader::getImageGeometry(), ossimChipperUtil::getZone(), ossimCadrgProjection::loadState(), ossimUtmProjection::loadState(), ossimChipProcTool::newUtmProjection(), ossimCadrgProjection::saveState(), ossimUtmProjection::saveState(), ossimSpaceImagingGeom::spaceImagingToOssimKeyword(), ossimERS::toOssimProjectionGeom(), and ossimERSFileWriter::writeFile().
