ossimLeastSquaresBilin.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Garrett Potts (gpotts@imagelinks.com
6 //
7 // Description: Source code produced by Dave Knopp
8 //
9 //*******************************************************************
10 // $Id: ossimLeastSquaresBilin.cpp 9963 2006-11-28 21:11:01Z gpotts $
11 #include <iostream> // for debugging
12 using namespace std;
15
17  : bl_a(0.0)
18  , bl_b(0.0)
19  , bl_c(0.0)
20  , bl_d(0.0)
21  , AtA(NULL)
22  , Atb(NULL)
23 {
24  // allocate normal system accumulation matrices
25  AtA = new NEWMAT::Matrix(4,4);
26  Atb = new NEWMAT::Matrix(4,1);
27
28  // ensure initilization to zero
29  *AtA = 0.0;
30  *Atb = 0.0;
31
32  return;
33 }
35 {
36  // allocate normal system accumulation matrices
37  AtA = new NEWMAT::Matrix(4,4);
38  Atb = new NEWMAT::Matrix(4,1);
39
40  bl_a = rhs.bl_a;
41  bl_b = rhs.bl_b;
42  bl_c = rhs.bl_c;
43  bl_d = rhs.bl_d;
44
45  *AtA = *rhs.AtA;
46  *Atb = *rhs.Atb;
47 }
48
50 {
51  if(AtA)
52  {
53  delete AtA;
54  AtA = NULL;
55  }
56  if(Atb)
57  {
58  delete Atb;
59  Atb = NULL;
60  }
61 }
63 {
64  bl_a = rhs.bl_a;
65  bl_b = rhs.bl_b;
66  bl_c = rhs.bl_c;
67  bl_d = rhs.bl_d;
68
69  *AtA = *rhs.AtA;
70  *Atb = *rhs.Atb;
71
72  return *this;
73 }
74
76 {
77  *AtA = 0.0;
78  *Atb = 0.0;
79  bl_a = 0.0;
80  bl_b = 0.0;
81  bl_c = 0.0;
82  bl_d = 0.0;
83 }
84
85 void ossimLeastSquaresBilin::addSample(double xx, double yy, double zmea)
86 {
87  // form normal system layer
88  NEWMAT::Matrix AtA_layer(4,1);
89  AtA_layer(1,1) = 1.0;
90  AtA_layer(2,1) = xx;
91  AtA_layer(3,1) = yy;
92  AtA_layer(4,1) = xx*yy;
93
94  // accumulate layer into normal system
95  *AtA += AtA_layer * AtA_layer.t();
96  *Atb += AtA_layer * zmea;
97
98 }
99
101 {
102  NEWMAT::Matrix Soln(4,1);
103  Soln = AtA->i() * (*Atb);
104  bl_a = Soln(1,1);
105  bl_b = Soln(2,1);
106  bl_c = Soln(3,1);
107  bl_d = Soln(4,1);
108
109
110  return true;
111 }
112
114  double& pb_x,
115  double& pc_y,
116  double& pd_xy)const
117 {
118  pa = bl_a;
119  pb_x = bl_b;
120  pc_y = bl_c;
121  pd_xy = bl_d;
122
123  return true;
124 }
125
127  double pb_x,
128  double pc_y,
129  double pd_xy)
130 {
131  bl_a = pa;
132  bl_b = pb_x;
133  bl_c = pc_y;
134  bl_d = pd_xy;
135 }
136
137
double bl_c
linear-Y term.
virtual void clear()
Will clear everything and set it up to for another solve.
ossimLeastSquaresBilin & operator=(const ossimLeastSquaresBilin &)
virtual void addSample(double x, double yy, double zmea)
add a single data sample.
double bl_a
constant term.
virtual ~ossimLeastSquaresBilin()
Free internal storage.
virtual void setLSParams(double pa, double pb_x, double pc_y, double pd_xy)
NEWMAT::Matrix * AtA
Normal system coefficient matrix.
Instantiate as zero surface.
Provide 2D Least Squares Bilinear model fitting The math model is that of a bilinear surface of the ...
virtual bool getLSParms(double &pa, double &pb_x, double &pc_y, double &pd_xy) const
return LS solution parameters.
double bl_b
linear-X term.
bool solveLS()
compute least squares parameter solution - true if succesfull.
NEWMAT::Matrix * Atb
Normal system RHS vector.
