Public Member Functions | Private Attributes | List of all members
ossimLeastSquaresBilin Class Reference
Provide 2D Least Squares Bilinear model fitting The math model is that of a bilinear surface of the form: More...
#include <ossimLeastSquaresBilin.h>
 ossimLeastSquaresBilin (const ossimLeastSquaresBilin &)
 ossimLeastSquaresBilin ()
 Instantiate as zero surface. More...
ossimLeastSquaresBilinoperator= (const ossimLeastSquaresBilin &)
virtual ~ossimLeastSquaresBilin ()
 Free internal storage. More...
virtual void clear ()
 Will clear everything and set it up to for another solve. More...
virtual void addSample (double x, double yy, double zmea)
 add a single data sample. More...
virtual bool getLSParms (double &pa, double &pb_x, double &pc_y, double &pd_xy) const
 return LS solution parameters. More...
virtual void setLSParams (double pa, double pb_x, double pc_y, double pd_xy)
virtual double lsFitValue (double xx, double yy) const
 interpolate LS-fit value at location (xx,yy) - returns z(xx,yy). More...
bool solveLS ()
 compute least squares parameter solution - true if succesfull. More...
Private Attributes
double bl_a
 constant term. More...
double bl_b
 linear-X term. More...
double bl_c
 linear-Y term. More...
double bl_d
 cross-XY term More...
NEWMAT::Matrix * AtA
 Normal system coefficient matrix. More...
NEWMAT::Matrix * Atb
 Normal system RHS vector. More...
Detailed Description
z(x,y) = a + b*x + c*y + d*x*y
The getLSParms() method returns parameter values which are the least squares solution associated with the samples added via addSample(). Note that it is necessary to add at least four sample to obtain a solution.
Definition at line 27 of file ossimLeastSquaresBilin.h.
◆ ossimLeastSquaresBilin() [1/2]
ossimLeastSquaresBilin::ossimLeastSquaresBilin ( const ossimLeastSquaresBilin rhs)
Definition at line 34 of file ossimLeastSquaresBilin.cpp.
References AtA, Atb, bl_a, bl_b, bl_c, and bl_d.
35 {
36  // allocate normal system accumulation matrices
37  AtA = new NEWMAT::Matrix(4,4);
38  Atb = new NEWMAT::Matrix(4,1);
39
40  bl_a = rhs.bl_a;
41  bl_b = rhs.bl_b;
42  bl_c = rhs.bl_c;
43  bl_d = rhs.bl_d;
44
45  *AtA = *rhs.AtA;
46  *Atb = *rhs.Atb;
47 }
double bl_c
linear-Y term.
double bl_a
constant term.
double bl_b
linear-X term.
◆ ossimLeastSquaresBilin() [2/2]
ossimLeastSquaresBilin::ossimLeastSquaresBilin ( )
Definition at line 16 of file ossimLeastSquaresBilin.cpp.
References AtA, and Atb.
17  : bl_a(0.0)
18  , bl_b(0.0)
19  , bl_c(0.0)
20  , bl_d(0.0)
21  , AtA(NULL)
22  , Atb(NULL)
23 {
24  // allocate normal system accumulation matrices
25  AtA = new NEWMAT::Matrix(4,4);
26  Atb = new NEWMAT::Matrix(4,1);
27
28  // ensure initilization to zero
29  *AtA = 0.0;
30  *Atb = 0.0;
31
32  return;
33 }
double bl_c
linear-Y term.
double bl_a
constant term.
double bl_b
linear-X term.
◆ ~ossimLeastSquaresBilin()
ossimLeastSquaresBilin::~ossimLeastSquaresBilin ( )
virtual
Definition at line 49 of file ossimLeastSquaresBilin.cpp.
50 {
51  if(AtA)
52  {
53  delete AtA;
54  AtA = NULL;
55  }
56  if(Atb)
57  {
58  delete Atb;
59  Atb = NULL;
60  }
61 }
Member Function Documentation
◆ addSample()
void ossimLeastSquaresBilin::addSample ( double  x,
double  yy,
double  zmea
virtual
Parameters
xx"x" coordinate of sample location.
yy"y" "y" coordinate of sample location.
zmeasample value measured at (xx,yy)
Definition at line 85 of file ossimLeastSquaresBilin.cpp.
Referenced by ossimBilinearProjection::initializeBilinear(), ossim2dBilinearTransform::setFromPoints(), and ossim2dTo2dMatrixTransform::setFromPoints().
86 {
87  // form normal system layer
88  NEWMAT::Matrix AtA_layer(4,1);
89  AtA_layer(1,1) = 1.0;
90  AtA_layer(2,1) = xx;
91  AtA_layer(3,1) = yy;
92  AtA_layer(4,1) = xx*yy;
93
94  // accumulate layer into normal system
95  *AtA += AtA_layer * AtA_layer.t();
96  *Atb += AtA_layer * zmea;
97
98 }
◆ clear()
void ossimLeastSquaresBilin::clear ( )
virtual
Just add points and call the solve method.
Definition at line 75 of file ossimLeastSquaresBilin.cpp.
Referenced by ossimBilinearProjection::initializeBilinear().
76 {
77  *AtA = 0.0;
78  *Atb = 0.0;
79  bl_a = 0.0;
80  bl_b = 0.0;
81  bl_c = 0.0;
82  bl_d = 0.0;
83 }
double bl_c
linear-Y term.
double bl_a
constant term.
double bl_b
linear-X term.
◆ getLSParms()
bool ossimLeastSquaresBilin::getLSParms ( double &  pa,
double &  pb_x,
double &  pc_y,
double &  pd_xy
) const
virtual
Parameters
paset to constant coefficient.
pb_xset to linear coefficient of "x"
pc_yset to linear coefficient of "y"
pd_xyset to cross coefficient of "x*y"
Definition at line 113 of file ossimLeastSquaresBilin.cpp.
References bl_a, bl_b, bl_c, and bl_d.
Referenced by ossim2dBilinearTransform::setFromPoints(), and ossim2dTo2dMatrixTransform::setFromPoints().
117 {
118  pa = bl_a;
119  pb_x = bl_b;
120  pc_y = bl_c;
121  pd_xy = bl_d;
122
123  return true;
124 }
double bl_c
linear-Y term.
double bl_a
constant term.
double bl_b
linear-X term.
◆ lsFitValue()
virtual double ossimLeastSquaresBilin::lsFitValue ( double  xx,
double  yy
) const
inlinevirtual
Parameters
xx"x" coordinate at which to interpolate.
yy"y" "y" coordinate at which to interpolate.
Definition at line 89 of file ossimLeastSquaresBilin.h.
Referenced by ossimBilinearProjection::lineSampleHeightToWorld(), ossimBilinearProjection::setTiePoints(), and ossimBilinearProjection::worldToLineSample().
90  {
91  return (bl_a + bl_b*xx + bl_c*yy + bl_d*xx*yy);
92  }
double bl_c
linear-Y term.
double bl_a
constant term.
double bl_b
linear-X term.
◆ operator=()
ossimLeastSquaresBilin & ossimLeastSquaresBilin::operator= ( const ossimLeastSquaresBilin rhs)
Definition at line 62 of file ossimLeastSquaresBilin.cpp.
63 {
64  bl_a = rhs.bl_a;
65  bl_b = rhs.bl_b;
66  bl_c = rhs.bl_c;
67  bl_d = rhs.bl_d;
68
69  *AtA = *rhs.AtA;
70  *Atb = *rhs.Atb;
71
72  return *this;
73 }
double bl_c
linear-Y term.
double bl_a
constant term.
double bl_b
linear-X term.
◆ setLSParams()
void ossimLeastSquaresBilin::setLSParams ( double  pa,
double  pb_x,
double  pc_y,
double  pd_xy
virtual
Parameters
Definition at line 126 of file ossimLeastSquaresBilin.cpp.
130 {
131  bl_a = pa;
132  bl_b = pb_x;
133  bl_c = pc_y;
134  bl_d = pd_xy;
135 }
double bl_c
linear-Y term.
double bl_a
constant term.
double bl_b
linear-X term.
◆ solveLS()
bool ossimLeastSquaresBilin::solveLS ( )
Definition at line 100 of file ossimLeastSquaresBilin.cpp.
References AtA, bl_a, bl_b, bl_c, and bl_d.
101 {
102  NEWMAT::Matrix Soln(4,1);
103  Soln = AtA->i() * (*Atb);
104  bl_a = Soln(1,1);
105  bl_b = Soln(2,1);
106  bl_c = Soln(3,1);
107  bl_d = Soln(4,1);
108
109
110  return true;
111 }
double bl_c
linear-Y term.
double bl_a
constant term.
double bl_b
linear-X term.
Member Data Documentation
◆ AtA
NEWMAT::Matrix* ossimLeastSquaresBilin::AtA
private
Definition at line 123 of file ossimLeastSquaresBilin.h.
Referenced by addSample(), clear(), operator=(), ossimLeastSquaresBilin(), solveLS(), and ~ossimLeastSquaresBilin().
◆ Atb
NEWMAT::Matrix* ossimLeastSquaresBilin::Atb
private
Definition at line 128 of file ossimLeastSquaresBilin.h.
Referenced by addSample(), clear(), operator=(), ossimLeastSquaresBilin(), and ~ossimLeastSquaresBilin().
◆ bl_a
double ossimLeastSquaresBilin::bl_a
private
constant term.
Definition at line 103 of file ossimLeastSquaresBilin.h.
Referenced by clear(), getLSParms(), operator=(), ossimLeastSquaresBilin(), setLSParams(), and solveLS().
◆ bl_b
double ossimLeastSquaresBilin::bl_b
private
linear-X term.
Definition at line 108 of file ossimLeastSquaresBilin.h.
◆ bl_c
double ossimLeastSquaresBilin::bl_c
private
linear-Y term.
Definition at line 113 of file ossimLeastSquaresBilin.h.
◆ bl_d
double ossimLeastSquaresBilin::bl_d
private
cross-XY term
Definition at line 118 of file ossimLeastSquaresBilin.h.
