12 #ifndef ossimNitfHistoaTag_HEADER 13 #define ossimNitfHistoaTag_HEADER 1 77 const std::string& prefix=std::string())
const;
96 char m_pdate[PDATE_SIZE+1];
105 char m_psite[PSITE_SIZE+1];
114 char m_pas[PAS_SIZE+1];
122 char m_nIpcom[NIPCOM_SIZE+1];
148 char m_ibpp[IBPP_SIZE+1];
164 char m_ipvType[IPVTYPE_SIZE+1];
237 char m_inbwc[INBWC_SIZE+1];
253 char m_dispFlag[DISP_FLAG_SIZE + 1];
263 char m_rotFlag[ROT_FLAG_SIZE + 1];
273 char m_rotAngle[ROT_ANGLE_SIZE + 1];
287 char m_asymFlag[ASYM_FLAG_SIZE + 1];
297 char m_zoomRow[ZOOMROW_SIZE + 1];
307 char m_zoomCol[ZOOMCOL_SIZE + 1];
319 char m_projFlag[PROJ_FLAG_SIZE + 1];
330 char m_sharpFlag[SHARP_FLAG_SIZE+1];
344 char m_sharpFam[SHARPFAM_SIZE+1];
356 char m_sharpMem[SHARPMEM_SIZE+1];
366 char m_magFlag[MAG_FLAG_SIZE+1];
379 char m_magLevel[MAG_LEVEL_SIZE +1];
396 char m_draFlag[DRA_FLAG_SIZE+1];
404 char m_draMult[DRA_MULT_SIZE+1];
412 char m_draSub[DRA_SUB_SIZE+1];
423 char m_ttcFlag[TTC_FLAG_SIZE+1];
436 char m_ttcFam[TTCFAM_SIZE+1];
447 char m_ttcMem[TTCMEM_SIZE+1];
459 char m_devLutFlag[DEVLUT_FLAG_SIZE+1];
472 char m_obpp[OBPP_SIZE+1];
488 char m_opvType[OPVTYPE_SIZE+1];
512 char m_outBwc[OUTBWC_SIZE+1];
552 const std::string& prefix=std::string())
const;
553 virtual void clearFields();
574 char m_systype[SYSTYPE_SIZE+1];
644 char m_pc[PC_SIZE+1];
665 char m_pe[PE_SIZE+1];
677 char m_remapFlag[REMAP_FLAG_SIZE+1];
692 char m_lutid[LUTID_SIZE+1];
707 char m_nEvents[NEVENTS_SIZE+1];
virtual void writeStream(ossim::ostream &out)=0
std::vector< ossimNitfHistoaProcessingEvent > m_eventList
virtual void parseStream(ossim::istream &in)=0
This will allow the user defined data to parse the stream.
virtual std::ostream & print(std::ostream &out, const std::string &prefix=std::string()) const
Pure virtual print method that outputs a key/value type format adding prefix to keys.
std::ostream & print(H5::H5File *file, std::ostream &out)
Print method.
std::vector< std::string > m_comment
Field IPCOM.
unsigned int ossim_uint32
All comments in this document were taken from the online resource found at:
std::basic_istream< char > istream
Base class for char input streams.
virtual ossim_uint32 getSizeInBytes() const
Returns the length in bytes of the tag from the CEL or REL field.
std::basic_ostream< char > ostream
Base class for char output streams.
