Enumerations | Functions
ossim_hdf5 Namespace Reference
Enumerations
enum  { MAX_RECURSION_LEVEL = 8 }
Functions
std::ostream & print (H5::H5File *file, std::ostream &out)
 Print method. More...
void printIterative (H5::H5File *file, const std::string &groupName, const std::string &prefix, ossim_uint32 &recursedCount, std::ostream &out)
 Iterative print method. More...
void printObject (H5::H5File *file, const std::string &objectName, const std::string &prefix, std::ostream &out)
 Prints an object. More...
void printEnumType (H5::DataSet &dataset, H5::EnumType &dataType, const std::string &prefix, std::ostream &out)
void printIntType (H5::DataSet &dataset, H5::IntType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out)
void printFloatType (H5::DataSet &dataset, H5::FloatType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out)
void printArrayType (H5::DataSet &dataset, H5::ArrayType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out)
void printStrType (H5::DataSet &dataset, H5::StrType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out)
void printCompound (H5::DataSet &dataset, const std::string &prefix, std::ostream &out)
 Prints a compound object. More...
bool getGroupAttributeValue (H5::H5File *file, const std::string &group, const std::string &key, std::string &value)
 Gets string value for attribute key. More...
bool getDatasetAttributeValue (H5::H5File *file, const std::string &objectName, const std::string &key, std::string &value)
void printAttribute (const H5::Attribute &attr, const std::string &prefix, std::ostream &out)
void combine (const std::string &left, const std::string &right, char separator, std::string &result)
void getDatasetNames (H5::H5File *file, std::vector< std::string > &names)
std::string getDatatypeClassType (ossim_int32 type)
bool isLoadableAsImage (H5::H5File *file, const std::string &datasetName)
void iterateGroupForDatasetNames (H5::H5File *file, const std::string &group, std::vector< std::string > &names, ossim_uint32 &recursedCount)
void getExtents (const H5::DataSet *dataset, std::vector< ossim_uint32 > &extents)
ossimScalarType getScalarType (const H5::DataSet *dataset)
ossimScalarType getScalarType (ossim_int32 typeClass, size_t size, bool isSigned)
 Gets scalar type from args. More...
ossimByteOrder getByteOrder (const H5::AbstractDs *dataset)
ossimByteOrder getByteOrder (const H5::DataType *dataType)
bool getValidBoundingRect (H5::DataSet &dataset, const std::string &name, ossimIrect &rect)
 Gets the valid bounding rect of the dataset excluding nulls on front and back. More...
ossimRefPtr< ossimProjectiongetBilinearProjection (H5::DataSet &latDataSet, H5::DataSet &lonDataSet, const ossimIrect &validRect)
 Gets bilinear projection from Latitude, Longitude layer. More...
bool crossesDateline (H5::DataSet &dataset, const ossimIrect &validRect)
 Checks for dateline cross. More...
bool crossesDateline (const std::vector< ossim_float32 > &lineBuffer)
Enumeration Type Documentation
◆ anonymous enum
anonymous enum
Enumerator
MAX_RECURSION_LEVEL
Definition at line 53 of file ossimH5Util.h.
54  {
55  //---
56  // Used by iterateGroupForDatasetNames which can recursively call itself
57  // to avoid blowing away the stack on an error.
58  //---
60  };
Function Documentation
◆ combine()
void ossim_hdf5::combine ( const std::string &  left,
const std::string &  right,
char  separator,
std::string &  result
Definition at line 1025 of file ossimH5Util.cpp.
Referenced by iterateGroupForDatasetNames(), and printIterative().
1029 {
1030  if ( left.size() && right.size() )
1031  {
1032  result = left;
1033  if ( ( left[ left.size()-1 ] != separator ) && ( right[0] != separator ) )
1034  {
1035  result.push_back(separator);
1036  }
1037  result += right;
1038  }
1039 }
◆ crossesDateline() [1/2]
bool ossim_hdf5::crossesDateline ( H5::DataSet &  dataset,
const ossimIrect validRect
Parameters
dataset
validRectInitialized by this.
Returns
true if dateline cross is detected, false if not.
Definition at line 1774 of file ossimH5Util.cpp.
References ossim::byteOrder(), getByteOrder(), ossimLookUpTable::getEntryString(), getScalarType(), ossimIrect::height(), ossimScalarTypeLut::instance(), ossimIrect::ll(), OSSIM_FLOAT32, ossimNotify(), ossimNotifyLevel_WARN, ossimEndian::swap(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimImageGeometry::calculatePolyBounds(), and ossimH5GridModel::setGridNodes().
1775 {
1776  bool result = false;
1777
1778  H5::DataSpace dataspace = dataset.getSpace();
1779
1780  // Number of dimensions of the input dataspace:
1781  const ossim_int32 DIM_COUNT = dataspace.getSimpleExtentNdims();
1782
1783  if ( DIM_COUNT == 2 )
1784  {
1785  const ossim_uint32 ROWS = validRect.height();
1786  const ossim_uint32 COLS = validRect.width();
1787
1788  // Get the extents. Assuming dimensions are same for lat lon dataset.
1789  std::vector<hsize_t> dimsOut(DIM_COUNT);
1790  dataspace.getSimpleExtentDims( &dimsOut.front(), 0 );
1791
1792  if ( (ROWS <= dimsOut[0]) && (COLS <= dimsOut[1]) )
1793  {
1794  std::vector<hsize_t> inputCount(DIM_COUNT);
1795  std::vector<hsize_t> inputOffset(DIM_COUNT);
1796
1797  inputCount[0] = 1; // row
1798  inputCount[1] = COLS; // col
1799
1800  // Output dataspace dimensions.
1801  const ossim_int32 OUT_DIM_COUNT = 3;
1802  std::vector<hsize_t> outputCount(OUT_DIM_COUNT);
1803  outputCount[0] = 1; // single band
1804  outputCount[1] = 1; // single line
1805  outputCount[2] = COLS; // single sample
1806
1807  // Output dataspace offset.
1808  std::vector<hsize_t> outputOffset(OUT_DIM_COUNT);
1809  outputOffset[0] = 0;
1810  outputOffset[1] = 0;
1811  outputOffset[2] = 0;
1812
1813  ossimScalarType scalar = ossim_hdf5::getScalarType( &dataset );
1814  if ( scalar == OSSIM_FLOAT32 )
1815  {
1816  // See if we need to swap bytes:
1817  ossimEndian* endian = 0;
1818  if ( ( ossim::byteOrder() != ossim_hdf5::getByteOrder( &dataset ) ) )
1819  {
1820  endian = new ossimEndian();
1821  }
1822
1823  // Native type:
1824  H5::DataType datatype = dataset.getDataType();
1825
1826  // Output dataspace always the same one line.
1827  H5::DataSpace bufferDataSpace( OUT_DIM_COUNT, &outputCount.front());
1828  bufferDataSpace.selectHyperslab( H5S_SELECT_SET,
1829  &outputCount.front(),
1830  &outputOffset.front() );
1831
1832  //---
1833  // Dataset sample has NULL lines at the end so scan for valid rect.
1834  // Use "<= -999" for test as per NOAA as it seems the NULL value is
1835  // fuzzy. e.g. -999.3.
1836  //---
1837
1838  // Buffer to hold a line:
1839  std::vector<ossim_float32> lineBuffer(validRect.width());
1840
1841  // Read the first line:
1842  inputOffset[0] = static_cast<hsize_t>(validRect.ul().y);
1843  inputOffset[1] = static_cast<hsize_t>(validRect.ul().x);
1844  dataspace.selectHyperslab( H5S_SELECT_SET,
1845  &inputCount.front(),
1846  &inputOffset.front() );
1847  dataset.read( &(lineBuffer.front()), datatype, bufferDataSpace, dataspace );
1848
1849  if ( endian )
1850  {
1851  // If the endian pointer is initialized(not zero) swap the bytes.
1852  endian->swap( &(lineBuffer.front()), COLS );
1853  }
1854
1855  // Test the first line:
1856  result = ossim_hdf5::crossesDateline( lineBuffer );
1857
1858  if ( !result )
1859  {
1860  // Test the last line:
1861  inputOffset[0] = static_cast<hsize_t>(validRect.ll().y);
1862  inputOffset[1] = static_cast<hsize_t>(validRect.ll().x);
1863  dataspace.selectHyperslab( H5S_SELECT_SET,
1864  &inputCount.front(),
1865  &inputOffset.front() );
1866  dataset.read( &(lineBuffer.front()), datatype, bufferDataSpace, dataspace );
1867
1868  result = ossim_hdf5::crossesDateline( lineBuffer );
1869  }
1870
1871  if ( endian )
1872  {
1873  delete endian;
1874  endian = 0;
1875  }
1876  }
1877  else // Matches: if ( scalar == OSSIM_FLOAT32 ){...}
1878  {
1880  << "ossim_hdf5::crossesDateline WARNING!"
1881  << "\nUnhandled scalar type: "
1883  << std::endl;
1884  }
1885
1886  } // Matches: if ( dimsOut...
1887
1888  } // Matches: if ( IN_DIM_COUNT == 2 )
1889
1890  dataspace.close();
1891
1892  return result;
1893
1894 } // End: ossim_hdf5::crossesDateline(...)
virtual ossimString getEntryString(ossim_int32 entry_number) const
ossim_uint32 height() const
Definition: ossimIrect.h:487
ossimScalarType getScalarType(const H5::DataSet *dataset)
const ossimIpt & ul() const
Definition: ossimIrect.h:274
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
32 bit floating point
const ossimIpt & ll() const
Definition: ossimIrect.h:277
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
unsigned int ossim_uint32
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossimByteOrder getByteOrder(const H5::AbstractDs *dataset)
ossimScalarType
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
bool crossesDateline(H5::DataSet &dataset, const ossimIrect &validRect)
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
int ossim_int32
◆ crossesDateline() [2/2]
bool ossim_hdf5::crossesDateline ( const std::vector< ossim_float32 > &  lineBuffer)
Definition at line 1896 of file ossimH5Util.cpp.
1897 {
1898  bool result = false;
1899
1900  ossim_int32 longitude = 0;
1901  bool found179 = false;
1902  bool found181 = false;
1903
1904  for ( ossim_uint32 i = 0; i < lineBuffer.size(); ++i)
1905  {
1906  longitude = (ossim_int32)lineBuffer[i]; // Cast to integer.
1907
1908  // look for 179 -> -179...
1909  if ( !found179 )
1910  {
1911  if ( longitude == 179 )
1912  {
1913  found179 = true;
1914  continue;
1915  }
1916  }
1917  else // found179 == true
1918  {
1919  if ( longitude == 178 )
1920  {
1921  break; // Going West, 179 -> 178
1922  }
1923  else if ( longitude == -179 )
1924  {
1925  result = true;
1926  break;
1927  }
1928  }
1929
1930  // look for -179 -> 179...
1931  if ( !found181 )
1932  {
1933  if ( longitude == -179 )
1934  {
1935  found181 = true;
1936  continue;
1937  }
1938  }
1939  else // found181 == true
1940  {
1941  if ( longitude == -178 )
1942  {
1943  break; // Going East -179 -> -178
1944  }
1945  else if ( longitude == 179 )
1946  {
1947  result = true;
1948  break;
1949  }
1950  }
1951  }
1952
1953  return result;
1954
1955 } // End: ossim_hdf5::crossesDateline( lineBuffer )
int ossim_int32
◆ getBilinearProjection()
ossimRefPtr< ossimProjection > ossim_hdf5::getBilinearProjection ( H5::DataSet &  latDataSet,
H5::DataSet &  lonDataSet,
Parameters
latDataSetH5::DataSet& to layer, e.g. /All_Data/VIIRS-DNB-GEO_All/Latitude
lonDataSetH5::DataSet& to layer, e.g. /All_Data/VIIRS-DNB-GEO_All/Longitude
Definition at line 1957 of file ossimH5Util.cpp.
References ossim::byteOrder(), ossimRefPtr< T >::get(), getByteOrder(), ossimLookUpTable::getEntryString(), getScalarType(), ossimScalarTypeLut::instance(), ossimGpt::lat, ossimGpt::lon, ossimIrect::lr(), OSSIM_FLOAT32, ossimNotify(), ossimNotifyLevel_WARN, ossimBilinearProjection::setTiePoints(), ossimEndian::swap(), ossimIrect::ul(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by ossimH5ImageHandler::getInternalImageGeometry(), and ossimH5GridModel::setGridNodes().
1959 {
1961
1962  // Get dataspace of the dataset.
1963  H5::DataSpace latDataSpace = latDataSet.getSpace();
1964  H5::DataSpace lonDataSpace = lonDataSet.getSpace();
1965
1966  // Number of dimensions of the input dataspace:
1967  const ossim_int32 DIM_COUNT = latDataSpace.getSimpleExtentNdims();
1968
1969  if ( DIM_COUNT == 2 )
1970  {
1971  // Get the extents. Assuming dimensions are same for lat lon dataset.
1972  std::vector<hsize_t> dimsOut(DIM_COUNT);
1973  latDataSpace.getSimpleExtentDims( &dimsOut.front(), 0 );
1974
1975  if ( dimsOut[0] && dimsOut[1] )
1976  {
1977  std::vector<hsize_t> inputCount(DIM_COUNT);
1978  std::vector<hsize_t> inputOffset(DIM_COUNT);
1979
1980  inputOffset[0] = 0;
1981  inputOffset[1] = 0;
1982
1983  inputCount[0] = 1;
1984  inputCount[1] = 1;
1985
1986  // Output dataspace dimensions.
1987  const ossim_int32 OUT_DIM_COUNT = 3;
1988  std::vector<hsize_t> outputCount(OUT_DIM_COUNT);
1989  outputCount[0] = 1; // single band
1990  outputCount[1] = 1; // single line
1991  outputCount[2] = 1; // single sample
1992
1993  // Output dataspace offset.
1994  std::vector<hsize_t> outputOffset(OUT_DIM_COUNT);
1995  outputOffset[0] = 0;
1996  outputOffset[1] = 0;
1997  outputOffset[2] = 0;
1998
1999  ossimScalarType scalar = ossim_hdf5::getScalarType( &latDataSet );
2000  if ( scalar == OSSIM_FLOAT32 )
2001  {
2002  // See if we need to swap bytes:
2003  ossimEndian* endian = 0;
2004  if ( ( ossim::byteOrder() != ossim_hdf5::getByteOrder( &latDataSet ) ) )
2005  {
2006  endian = new ossimEndian();
2007  }
2008
2009  // Native type:
2010  H5::DataType latDataType = latDataSet.getDataType();
2011  H5::DataType lonDataType = lonDataSet.getDataType();
2012
2013  std::vector<ossimDpt> ipts;
2014  std::vector<ossimGpt> gpts;
2015  ossimGpt gpt(0.0, 0.0, 0.0); // Assuming WGS84...
2016  ossim_float32 latValue = 0.0;
2017  ossim_float32 lonValue = 0.0;
2018
2019  // Only grab every 256th value.:
2020  const ossim_int32 GRID_SIZE = 256;
2021
2022  // Output dataspace always the same one pixel.
2023  H5::DataSpace bufferDataSpace( OUT_DIM_COUNT, &outputCount.front());
2024  bufferDataSpace.selectHyperslab( H5S_SELECT_SET,
2025  &outputCount.front(),
2026  &outputOffset.front() );
2027
2028  //---
2029  // Dataset sample has NULL lines at the end so scan for valid rect.
2030  // Use "<= -999" for test as per NOAA as it seems the NULL value is
2031  // fuzzy. e.g. -999.3.
2032  //---
2033  const ossim_float32 NULL_VALUE = -999.0;
2034
2035  //---
2036  // Get the tie points within the valid rect:
2037  //---
2038  ossimDpt ipt = validRect.ul();
2039  while ( ipt.y <= validRect.lr().y )
2040  {
2041  inputOffset[0] = static_cast<hsize_t>(ipt.y);
2042
2043  // Sample loop:
2044  ipt.x = validRect.ul().x;
2045  while ( ipt.x <= validRect.lr().x )
2046  {
2047  inputOffset[1] = static_cast<hsize_t>(ipt.x);
2048
2049  latDataSpace.selectHyperslab( H5S_SELECT_SET,
2050  &inputCount.front(),
2051  &inputOffset.front() );
2052  lonDataSpace.selectHyperslab( H5S_SELECT_SET,
2053  &inputCount.front(),
2054  &inputOffset.front() );
2055
2056  // Read data from file into the buffer.
2057  latDataSet.read( &latValue, latDataType, bufferDataSpace, latDataSpace );
2058  lonDataSet.read( &lonValue, lonDataType, bufferDataSpace, lonDataSpace );
2059
2060  if ( endian )
2061  {
2062  // If the endian pointer is initialized(not zero) swap the bytes.
2063  endian->swap( latValue );
2064  endian->swap( lonValue );
2065  }
2066
2067  if ( ( latValue > NULL_VALUE ) && ( lonValue > NULL_VALUE ) )
2068  {
2069  gpt.lat = latValue;
2070  gpt.lon = lonValue;
2071  gpts.push_back( gpt );
2072
2073  // Add the image point subtracting the image offset.
2074  ossimIpt shiftedIpt = ipt - validRect.ul();
2075  ipts.push_back( shiftedIpt );
2076  }
2077
2078  // Go to next point:
2079  if ( ipt.x < validRect.lr().x )
2080  {
2081  ipt.x += GRID_SIZE;
2082  if ( ipt.x > validRect.lr().x )
2083  {
2084  ipt.x = validRect.lr().x; // Clamp to last sample.
2085  }
2086  }
2087  else
2088  {
2089  break; // At the end:
2090  }
2091
2092  } // End sample loop.
2093
2094  if ( ipt.y < validRect.lr().y )
2095  {
2096  ipt.y += GRID_SIZE;
2097  if ( ipt.y > validRect.lr().y )
2098  {
2099  ipt.y = validRect.lr().y; // Clamp to last line.
2100  }
2101  }
2102  else
2103  {
2104  break; // At the end:
2105  }
2106
2107  } // End line loop.
2108
2109  if ( ipts.size() )
2110  {
2111  // Create the projection:
2113
2114  // Add the tie points:
2115  bp->setTiePoints( ipts, gpts );
2116
2117  // Assign to output projection:
2118  proj = bp.get();
2119  }
2120
2121  // Cleanup:
2122  if ( endian )
2123  {
2124  delete endian;
2125  endian = 0;
2126  }
2127  }
2128  else // Matches: if ( scalar == OSSIM_FLOAT32 ){...}
2129  {
2131  << "ossim_hdf5::getBilinearProjection WARNING!"
2132  << "\nUnhandled scalar type: "
2134  << std::endl;
2135  }
2136
2137  } // Matches: if ( dimsOut...
2138
2139  } // Matches: if ( IN_DIM_COUNT == 2 )
2140
2141  latDataSpace.close();
2142  lonDataSpace.close();
2143
2144  return proj;
2145
2146 } // End: ossim_hdf5::getBilinearProjection()
float ossim_float32
double y
Definition: ossimDpt.h:165
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual ossim_float64 setTiePoints(const std::vector< ossimDpt > &lsPt, const std::vector< ossimGpt > &geoPt)
ossimScalarType
ossim_int32 y
double x
Definition: ossimDpt.h:164
ossim_int32 x
int ossim_int32
◆ getByteOrder() [1/2]
ossimByteOrder ossim_hdf5::getByteOrder ( const H5::AbstractDs *  dataset)
Definition at line 1531 of file ossimH5Util.cpp.
References ossim::byteOrder(), OSSIM_BIG_ENDIAN, and OSSIM_LITTLE_ENDIAN.
Referenced by crossesDateline(), getBilinearProjection(), getValidBoundingRect(), ossimH5ImageDataset::initialize(), printArrayType(), printAttribute(), printFloatType(), printIntType(), printObject(), and ossimH5GridModel::setGridNodes().
1532 {
1534  if ( obj )
1535  {
1536  // Get the class of the datatype that is used by the dataset.
1537  H5T_class_t typeClass = obj->getTypeClass();
1538
1539  H5T_order_t order = H5T_ORDER_NONE;
1540
1541  if ( typeClass == H5T_INTEGER )
1542  {
1543  H5::IntType intype = obj->getIntType();
1544  order = intype.getOrder();
1545  }
1546  else if ( typeClass == H5T_FLOAT )
1547  {
1548  H5::FloatType floatType = obj->getFloatType();
1549  order = floatType.getOrder();
1550  }
1551
1552  if ( order == H5T_ORDER_LE )
1553  {
1555  }
1556  else if ( order == H5T_ORDER_BE )
1557  {
1559  }
1560  }
1561  return byteOrder;
1562 }
ossimByteOrder
◆ getByteOrder() [2/2]
ossimByteOrder ossim_hdf5::getByteOrder ( const H5::DataType *  dataType)
Definition at line 1505 of file ossimH5Util.cpp.
1506 {
1508
1509  if(dataType)
1510  {
1511  const H5::AtomType* atomType = dynamic_cast<const H5::AtomType*>(dataType);
1512
1513  if(atomType)
1514  {
1515  H5T_order_t h5order = atomType->getOrder();
1516
1517  if(h5order == H5T_ORDER_LE)
1518  {
1520  }
1521  else if(h5order == H5T_ORDER_BE)
1522  {
1524  }
1525  }
1526  }
1527
1528  return byteOrder;
1529 }
ossimByteOrder
◆ getDatasetAttributeValue()
bool ossim_hdf5::getDatasetAttributeValue ( H5::H5File *  file,
const std::string &  objectName,
const std::string &  key,
std::string &  value
This assumes H5::Attribute type class is a H5T_STRING.
Parameters
filePointer to H5File instance.
datasetData to open. Examples: "/" "/Data_Products/VIIRS-DNB-GEO"
keyThis is key string. Examples: "Mission_Name" "N_Collection_Short_Name"
valueInitialized by this.
Returns
Definition at line 779 of file ossimH5Util.cpp.
References ossimNotify(), and ossimNotifyLevel_WARN.
Referenced by ossimH5ImageHandler::addMetadata().
783 {
784  static const char MODULE[] = "ossim_hdf5::getDatasetAttributeValue";
785
786  bool result = false;
787
788  if ( file )
789  {
790  try // HDF5 library throws exceptions so wrap with try{}catch...
791  {
792  // Open the dataset:
793  H5::DataSet dataset = file->openDataSet( objectName );
794
795  // Lookw for key:
796  H5::Attribute attr = dataset.openAttribute( key );
797
798  std::string name = attr.getName();
799  H5::DataType type = attr.getDataType();
800  H5T_class_t typeClass = attr.getTypeClass();
801
802  if ( ( name == key ) && ( typeClass == H5T_STRING ) )
803  {
804  attr.read( type, value );
805  result = true;
806  }
807
808  // Cleanup:
809  attr.close();
810  dataset.close();
811  }
812  catch( const H5::Exception& e )
813  {
815  << MODULE << " WARNING: Caught exception!\n"
816  << e.getDetailMsg() << std::endl;
817  }
818  catch( ... )
819  {
821  << MODULE << " WARNING: Caught unknown exception!" << std::endl;
822  }
823  }
824
825  return result;
826
827 } // End: ossim_hdf5::getDatasetAttributeValue
◆ getDatasetNames()
void ossim_hdf5::getDatasetNames ( H5::H5File *  file,
std::vector< std::string > &  names
Definition at line 1041 of file ossimH5Util.cpp.
References iterateGroupForDatasetNames().
Referenced by ossimH5ImageHandler::getLatLonDatasetNames(), and print().
1043 {
1044  datasetNames.clear();
1045
1046  if ( file )
1047  {
1048  std::string groupName = "/";
1049  ossim_uint32 recurseCount = 0;
1050  ossim_hdf5::iterateGroupForDatasetNames( file, groupName, datasetNames, recurseCount );
1051 #if 0
1052  std::vector<std::string>::const_iterator i = datasetNames.begin();
1053  while ( i != datasetNames.end() )
1054  {
1055  std::cout << "dataset: " << (*i) << std::endl;
1056  ++i;
1057  }
1058 #endif
1059  }
1060 }
void iterateGroupForDatasetNames(H5::H5File *file, const std::string &group, std::vector< std::string > &names, ossim_uint32 &recursedCount)
◆ getDatatypeClassType()
std::string ossim_hdf5::getDatatypeClassType ( ossim_int32  type)
Definition at line 1062 of file ossimH5Util.cpp.
Referenced by printCompound(), and printObject().
1063 {
1064  H5T_class_t classType = (H5T_class_t)type;
1065
1066  std::string result;
1067  switch ( classType )
1068  {
1069  case H5T_INTEGER:
1070  result = "H5T_INTEGER";
1071  break;
1072  case H5T_FLOAT:
1073  result = "H5T_FLOAT";
1074  break;
1075  case H5T_TIME:
1076  result = "H5T_TIME";
1077  break;
1078  case H5T_STRING:
1079  result = "H5T_STRING";
1080  break;
1081  case H5T_BITFIELD:
1082  result = "H5T_BITFIELD";
1083  break;
1084  case H5T_OPAQUE:
1085  result = "H5T_OPAQUE";
1086  break;
1087  case H5T_COMPOUND:
1088  result = "H5T_COMPOUND";
1089  break;
1090  case H5T_REFERENCE:
1091  result = "H5T_REFERENCE";
1092  break;
1093  case H5T_ENUM:
1094  result = "H5T_ENUM";
1095  break;
1096  case H5T_VLEN:
1097  result = "H5T_VLEN";
1098  break;
1099  case H5T_ARRAY:
1100  result = "H5T_ARRAY";
1101  break;
1102  case H5T_NO_CLASS:
1103  default:
1104  result = "H5T_NO_CLASS";
1105  break;
1106  }
1107  return result;
1108 }
◆ getExtents()
void ossim_hdf5::getExtents ( const H5::DataSet *  dataset,
std::vector< ossim_uint32 > &  extents
Definition at line 1255 of file ossimH5Util.cpp.
Referenced by ossimH5ImageHandler::addImageDatasetEntries(), ossimH5ImageDataset::initialize(), isLoadableAsImage(), and printObject().
1257 {
1258  extents.clear();
1259
1260  if ( dataset )
1261  {
1262  // Get dataspace of the dataset.
1263  H5::DataSpace dataspace = dataset->getSpace();
1264
1265  // Number of dimensions:
1266  int ndims = dataspace.getSimpleExtentNdims();
1267  if ( ndims )
1268  {
1269  //hsize_t dims_out[ndims];
1270  std::vector<hsize_t> dims_out(ndims);
1271  dataspace.getSimpleExtentDims( &dims_out.front(), 0 );
1272  for ( ossim_int32 i = 0; i < ndims; ++i )
1273  {
1274  extents.push_back(static_cast<ossim_uint32>(dims_out[i]));
1275  }
1276  }
1277
1278  dataspace.close();
1279  }
1280 }
int ossim_int32
◆ getGroupAttributeValue()
bool ossim_hdf5::getGroupAttributeValue ( H5::H5File *  file,
const std::string &  group,
std::string &  value
Parameters
groupGroup to open. Examples: "/" "/Data_Products/VIIRS-DNB-GEO"
Returns
Definition at line 725 of file ossimH5Util.cpp.
Referenced by ossimH5ImageHandler::addMetadata(), ossimH5ImageHandler::getLatLonDatasets(), and ossimH5ImageHandler::isNppMission().
729 {
730  static const char MODULE[] = "ossim_hdf5::getGroupAttributeValue";
731
732  bool result = false;
733
734  if ( file )
735  {
736  try // HDF5 library throws exceptions so wrap with try{}catch...
737  {
738  // Open the root group:
739  H5::Group* h5Group = new H5::Group( file->openGroup( group ) );
740
741  // Lookw for key:
742  H5::Attribute attr = h5Group->openAttribute( key );
743  std::string name = attr.getName();
744  H5::DataType type = attr.getDataType();
745  H5T_class_t typeClass = attr.getTypeClass();
746
747  if ( ( name == key ) && ( typeClass == H5T_STRING ) )
748  {
749  attr.read( type, value );
750  result = true;
751  }
752
753  // Cleanup:
754  attr.close();
755  h5Group->close();
756  delete h5Group;
757  h5Group = 0;
758  }
759  catch( const H5::Exception& e )
760  {
761  if (traceDebug())
762  {
764  << MODULE << " WARNING: Caught exception!\n"
765  << e.getDetailMsg() << std::endl;
766  }
767  }
768  catch( ... )
769  {
771  << MODULE << " WARNING: Caught unknown exception!" << std::endl;
772  }
773  }
774
775  return result;
776
777 } // End: ossim_hdf5::getGroupAttributeValue
◆ getScalarType() [1/2]
ossimScalarType ossim_hdf5::getScalarType ( const H5::DataSet *  dataset)
Definition at line 1282 of file ossimH5Util.cpp.
References OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT64, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT64, and OSSIM_UINT8.
Referenced by crossesDateline(), getBilinearProjection(), ossimHdf5ImageHandler::getTile(), ossimH5ImageHandler::getTile(), getValidBoundingRect(), ossimH5ImageDataset::initialize(), printAttribute(), printIntType(), printObject(), and ossimH5GridModel::setGridNodes().
1283 {
1284  // cout << "typeClass: " << typeClass << "\nid: " << id << endl;
1285
1287
1288  if ( dataset )
1289  {
1290  ossim_int32 typeClass = dataset->getTypeClass();
1291
1292  if ( ( typeClass == H5T_INTEGER ) || ( typeClass == H5T_FLOAT ) )
1293  {
1294  // hid_t mem_type_id = H5Dget_type(id);
1295  hid_t mem_type_id = H5Dget_type( dataset->getId() );
1296
1297  // cout << "mem_type_id: " << mem_type_id << endl;
1298
1299  if( mem_type_id > -1 )
1300  {
1301  hid_t native_type = H5Tget_native_type(mem_type_id, H5T_DIR_DEFAULT);
1302  // hid_t native_type = H5Tget_native_type(id, H5T_DIR_DEFAULT);
1303
1304  if( H5Tequal(H5T_NATIVE_CHAR, native_type) )
1305  {
1306  scalar = OSSIM_SINT8;
1307  }
1308  else if ( H5Tequal( H5T_NATIVE_UCHAR, native_type) )
1309  {
1310  scalar = OSSIM_UINT8;
1311  }
1312  else if( H5Tequal( H5T_NATIVE_SHORT, native_type) )
1313  {
1314  scalar = OSSIM_SINT16;
1315  }
1316  else if(H5Tequal(H5T_NATIVE_USHORT, native_type))
1317  {
1318  scalar = OSSIM_UINT16;
1319  }
1320  else if(H5Tequal( H5T_NATIVE_INT, native_type))
1321  {
1322  scalar = OSSIM_SINT32;
1323  }
1324  else if(H5Tequal( H5T_NATIVE_UINT, native_type ) )
1325  {
1326  scalar = OSSIM_UINT32;
1327  }
1328  else if(H5Tequal( H5T_NATIVE_LONG, native_type))
1329  {
1330  scalar = OSSIM_SINT32;
1331  }
1332  else if(H5Tequal( H5T_NATIVE_ULONG, native_type))
1333  {
1334  scalar = OSSIM_UINT32;
1335  }
1336  else if(H5Tequal( H5T_NATIVE_LLONG, native_type))
1337  {
1338  scalar = OSSIM_SINT64;
1339  }
1340  else if(H5Tequal( H5T_NATIVE_ULLONG, native_type))
1341  {
1342  scalar = OSSIM_UINT64;
1343  }
1344  else if(H5Tequal( H5T_NATIVE_FLOAT, native_type))
1345  {
1346  scalar = OSSIM_FLOAT32;
1347  }
1348  else if(H5Tequal( H5T_NATIVE_DOUBLE, native_type))
1349  {
1350  scalar = OSSIM_FLOAT64;
1351  }
1352  }
1353
1354  } // Matches: if ( ( typeClass == ...
1355
1356  } // Matches: if ( dataset ){
1357
1358  return scalar;
1359
1360 } // End: ossim_hdf5::getScalarType( const H5::DataSet* dataset )
8 bit signed integer
64 bit floating point
16 bit unsigned integer
16 bit signed integer
32 bit unsigned integer
64 bit signed integer
32 bit signed integer
ossimScalarType
64 bit unsigned integer
8 bit unsigned integer
int ossim_int32
◆ getScalarType() [2/2]
ossimScalarType ossim_hdf5::getScalarType ( ossim_int32  typeClass,
size_t  size,
bool  isSigned
Parameters
typeClassH5T_INTEGER or H5T_FLOAT
sizeIn bytes of attribute.
isSignedInteger data only, true if signed, false if not.
Returns
ossimScalarType
Definition at line 1362 of file ossimH5Util.cpp.
References ossim::isSigned(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT64, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT64, OSSIM_UINT8, ossimNotify(), ossimNotifyLevel_WARN, and size.
1365 {
1367
1368  H5T_class_t h5tClassType = (H5T_class_t)typeClass;
1369
1370  if ( h5tClassType == H5T_INTEGER )
1371  {
1372  if ( size == 1 )
1373  {
1374  if (!isSigned)
1375  {
1376  scalar = OSSIM_UINT8;
1377  }
1378  else
1379  {
1380  scalar = OSSIM_SINT8;
1381  }
1382  }
1383  else if ( size == 2 )
1384  {
1385  if (!isSigned)
1386  {
1387  scalar = OSSIM_UINT16;
1388  }
1389  else
1390  {
1391  scalar = OSSIM_SINT16;
1392  }
1393  }
1394  else if ( size == 4 )
1395  {
1396  if (!isSigned)
1397  {
1398  scalar = OSSIM_UINT32;
1399  }
1400  else
1401  {
1402  scalar = OSSIM_SINT32;
1403  }
1404  }
1405  else if ( size == 8 )
1406  {
1407  if (!isSigned)
1408  {
1409  scalar = OSSIM_UINT64;
1410  }
1411  else
1412  {
1413  scalar = OSSIM_SINT64;
1414  }
1415  }
1416  else
1417  {
1419  << "unhandled scalar size: " << size << endl;
1420  }
1421  }
1422  else if ( h5tClassType == H5T_FLOAT )
1423  {
1424  if ( size == 4 )
1425  {
1426  scalar = OSSIM_FLOAT32;
1427  }
1428  else
1429  {
1430  scalar = OSSIM_FLOAT64;
1431  }
1432  }
1433  else
1434  {
1436  << "unhandled type class: " << h5tClassType << endl;
1437  }
1438
1439  return scalar;
1440 }
OSSIM_DLL bool isSigned(ossimScalarType scalarType)
yy_size_t size
ossimScalarType
◆ getValidBoundingRect()
bool ossim_hdf5::getValidBoundingRect ( H5::DataSet &  dataset,
const std::string &  name,
ossimIrect rect
Parameters
dataset
nameName of dataset. Used for null scanning.
rectInitialized by this.
Definition at line 1564 of file ossimH5Util.cpp.
References ossim::almostEqual(), ossim::byteOrder(), getByteOrder(), ossimLookUpTable::getEntryString(), getScalarType(), ossimScalarTypeLut::instance(), ossimIrect::lr(), OSSIM_FLOAT32, ossimNotify(), ossimNotifyLevel_WARN, ossimEndian::swap(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimH5ImageDataset::initialize().
1567 {
1568  bool result = false;
1569  H5::DataSpace imageDataspace = dataset.getSpace();
1570  const ossim_int32 IN_DIM_COUNT = imageDataspace.getSimpleExtentNdims();
1571
1572  if ( IN_DIM_COUNT == 2 )
1573  {
1574  // Get the extents. Assuming dimensions are same for lat lon dataset.
1575  std::vector<hsize_t> dimsOut(IN_DIM_COUNT);
1576  imageDataspace.getSimpleExtentDims( &dimsOut.front(), 0 );
1577
1578  if ( dimsOut[0] && dimsOut[1] )
1579  {
1580
1581  //---
1582  // Capture the rectangle:
1583  // dimsOut[0] is height, dimsOut[1] is width:
1584  //---
1585  rect = ossimIrect( 0, 0,
1586  static_cast<ossim_int32>( dimsOut[1]-1 ),
1587  static_cast<ossim_int32>( dimsOut[0]-1 ) );
1588
1589  const ossim_int32 WIDTH = rect.width();
1590
1591  std::vector<hsize_t> inputCount(IN_DIM_COUNT);
1592  std::vector<hsize_t> inputOffset(IN_DIM_COUNT);
1593
1594  inputOffset[0] = 0;
1595  inputOffset[1] = 0;
1596
1597  inputCount[0] = 1;
1598  inputCount[1] = WIDTH;
1599
1600  // Output dataspace dimensions.
1601  const ossim_int32 OUT_DIM_COUNT = 3;
1602  std::vector<hsize_t> outputCount(OUT_DIM_COUNT);
1603  outputCount[0] = 1; // single band
1604  outputCount[1] = 1; // single line
1605  outputCount[2] = WIDTH; // whole line
1606
1607  // Output dataspace offset.
1608  std::vector<hsize_t> outputOffset(OUT_DIM_COUNT);
1609  outputOffset[0] = 0;
1610  outputOffset[1] = 0;
1611  outputOffset[2] = 0;
1612
1613  ossimScalarType scalar = ossim_hdf5::getScalarType( &dataset );
1614  if ( scalar == OSSIM_FLOAT32 )
1615  {
1616  // See if we need to swap bytes:
1617  ossimEndian* endian = 0;
1618  if ( ( ossim::byteOrder() != ossim_hdf5::getByteOrder( &dataset ) ) )
1619  {
1620  endian = new ossimEndian();
1621  }
1622
1623  // Native type:
1624  H5::DataType datatype = dataset.getDataType();
1625
1626  // Output dataspace always the same one line.
1627  H5::DataSpace bufferDataSpace( OUT_DIM_COUNT, &outputCount.front());
1628  bufferDataSpace.selectHyperslab( H5S_SELECT_SET,
1629  &outputCount.front(),
1630  &outputOffset.front() );
1631
1632  //---
1633  // Dataset sample has NULL lines at the end so scan for valid rect.
1634  // Use "<= -999" for test as per NOAA as it seems the NULL value is
1635  // fuzzy. e.g. -999.3.
1636  //---
1637  const ossim_float32 NULL_VALUE = -999.0;
1638
1639  //---
1640  // VIIRS Radiance data has a -1.5e-9 in the first column.
1641  // Treat this as a null.
1642  //---
1643  const ossim_float32 NULL_VALUE2 = ( name == "/All_Data/VIIRS-DNB-SDR_All/Radiance" )
1644  ? -1.5e-9 : NULL_VALUE;
1645  const ossim_float32 TOLERANCE = 0.1e-9; // For ossim::almostEqual()
1646
1647  // Hold one line:
1648  std::vector<ossim_float32> values( WIDTH );
1649
1650  // Find the ul pixel:
1651  ossimIpt ulIpt = rect.ul();
1652  bool found = false;
1653
1654  // Line loop to find upper left pixel:
1655  while ( ulIpt.y <= rect.lr().y )
1656  {
1657  inputOffset[0] = static_cast<hsize_t>(ulIpt.y);
1658  imageDataspace.selectHyperslab( H5S_SELECT_SET,
1659  &inputCount.front(),
1660  &inputOffset.front() );
1661
1662  // Read data from file into the buffer.
1663  dataset.read( (void*)&values.front(), datatype, bufferDataSpace, imageDataspace );
1664
1665  if ( endian )
1666  {
1667  // If the endian pointer is initialized(not zero) swap the bytes.
1668  endian->swap( scalar, (void*)&values.front(), WIDTH );
1669  }
1670
1671  // Sample loop:
1672  ulIpt.x = rect.ul().x;
1673  ossim_int32 index = 0;
1674  while ( ulIpt.x <= rect.lr().x )
1675  {
1676  if ( !ossim::almostEqual(values[index], NULL_VALUE2, TOLERANCE) &&
1677  ( values[index] > NULL_VALUE ) )
1678  {
1679  found = true; // Found valid pixel.
1680  break;
1681  }
1682  ++ulIpt.x;
1683  ++index;
1684
1685  } // End: sample loop
1686
1687  if ( found )
1688  {
1689  break;
1690  }
1691
1692  ++ulIpt.y;
1693
1694  } // End line loop to find ul pixel:
1695
1696  // Find the lower right pixel:
1697  ossimIpt lrIpt = rect.lr();
1698  found = false;
1699
1700  // Line loop to find last pixel:
1701  while ( lrIpt.y >= rect.ul().y )
1702  {
1703  inputOffset[0] = static_cast<hsize_t>(lrIpt.y);
1704  imageDataspace.selectHyperslab( H5S_SELECT_SET,
1705  &inputCount.front(),
1706  &inputOffset.front() );
1707
1708  // Read data from file into the buffer.
1709  dataset.read( (void*)&values.front(), datatype, bufferDataSpace, imageDataspace );
1710
1711  if ( endian )
1712  {
1713  // If the endian pointer is initialized(not zero) swap the bytes.
1714  endian->swap( scalar, (void*)&values.front(), WIDTH );
1715  }
1716
1717  // Sample loop:
1718  lrIpt.x = rect.lr().x;
1719  ossim_int32 index = WIDTH-1;
1720
1721  while ( lrIpt.x >= rect.ul().x )
1722  {
1723  if ( !ossim::almostEqual(values[index], NULL_VALUE2, TOLERANCE) &&
1724  ( values[index] > NULL_VALUE ) )
1725  {
1726  found = true; // Found valid pixel.
1727  break;
1728  }
1729  --lrIpt.x;
1730  --index;
1731
1732  } // End: sample loop
1733
1734  if ( found )
1735  {
1736  break;
1737  }
1738
1739  --lrIpt.y;
1740
1741  } // End line loop to find lower right pixel.
1742
1743  rect = ossimIrect( ulIpt, lrIpt );
1744
1745  // Cleanup:
1746  if ( endian )
1747  {
1748  delete endian;
1749  endian = 0;
1750  }
1751
1752  result = true;
1753
1754  }
1755  else // Matches: if ( scalar == OSSIM_FLOAT32 ){...}
1756  {
1758  << "ossim_hdf5::getBoundingRect WARNING!"
1759  << "\nUnhandled scalar type: "
1761  << std::endl;
1762  }
1763
1764  } // Matches: if ( dimsOut...
1765
1766  } // Matches: if ( IN_DIM_COUNT == 2 )
1767
1768  imageDataspace.close();
1769
1770  return result;
1771
1772 } // End: ossim_hdf5::getBoundingRect(...)
float ossim_float32
bool almostEqual(T x, T y, T tolerance=FLT_EPSILON)
Definition: ossimCommon.h:53
ossimScalarType
ossim_int32 y
ossim_int32 x
int ossim_int32
◆ isLoadableAsImage()
bool ossim_hdf5::isLoadableAsImage ( H5::H5File *  file,
const std::string &  datasetName
Definition at line 1110 of file ossimH5Util.cpp.
References getExtents(), ossimH5Options::instance(), and ossimH5Options::isDatasetRenderable().
1111 {
1112  bool result = false;
1113
1114  // std::cout << "isLoadable entered..." << std::endl;
1115  if ( file && datasetName.size() )
1116  {
1117  if ( ossimH5Options::instance()->isDatasetRenderable(datasetName)) //isExcludedDataset( datasetName ) == false )
1118  {
1119  H5::DataSet dataset = file->openDataSet( datasetName );
1120
1121  // Get the class of the datatype that is used by the dataset.
1122  H5T_class_t type_class = dataset.getTypeClass();
1123  // std::cout << "Class type: " << ossim_hdf5::getDatatypeClassType( type_class )
1124  // << std::endl;
1125
1126  if ( ( type_class == H5T_INTEGER ) || ( type_class == H5T_FLOAT ) )
1127  {
1128  // Get dataspace of the dataset.
1129  // H5::DataSpace dataspace = dataset.getSpace();
1130
1131  // Get the extents:
1132  std::vector<ossim_uint32> extents;
1133  ossim_hdf5::getExtents( &dataset, extents );
1134
1135  if ( extents.size() >= 2 )
1136  {
1137  if ( ( extents[0] > 1 ) && ( extents[1] > 1 ) )
1138  {
1139  // std::cout << "Accepting dataset: " << datasetName << std::endl;
1140  result = true;
1141  }
1142  }
1143
1144  }
1145
1146  dataset.close();
1147  }
1148  }
1149
1150  // std::cout << "isLoadable exit status: " << (result?"true":"false") << std::endl;
1151
1152  return result;
1153 }
static ossimH5Options * instance()
void getExtents(const H5::DataSet *dataset, std::vector< ossim_uint32 > &extents)
bool isDatasetRenderable(const std::string &datasetName) const
◆ iterateGroupForDatasetNames()
void ossim_hdf5::iterateGroupForDatasetNames ( H5::H5File *  file,
std::vector< std::string > &  names,
ossim_uint32 recursedCount
Definition at line 1184 of file ossimH5Util.cpp.
References combine(), ossimH5Options::instance(), ossimNotify(), and ossimNotifyLevel_WARN.
Referenced by getDatasetNames().
1188 {
1189  if ( file && groupName.size() )
1190  {
1191  ++recursedCount;
1192
1193  // std::cout << "iterateGroup: " << groupName << std::endl;
1194
1195  H5::Group* group = new H5::Group( file->openGroup(groupName) );
1196
1197  const hsize_t OBJ_COUNT = group->getNumObjs();
1198
1199  for ( hsize_t i = 0; i < OBJ_COUNT; ++i )
1200  {
1201  std::string objName = group->getObjnameByIdx(i);
1202
1203  if ( objName.size() )
1204  {
1205  char separator = '/';
1206  std::string combinedName;
1207  combine( groupName, objName, separator, combinedName );
1208
1209  H5G_obj_t objType = group->getObjTypeByIdx(i);
1210
1211 #if 0
1212  std::cout << "combinedName: " << combinedName
1213  << "\ngetObjnameByIdx[" << i << "]: " << objName
1214  << "\ngetObjTypeByIdx[" << i << "]: " << objType
1215  << std::endl;
1216 #endif
1217
1218  if ( objType == H5G_GROUP )
1219  {
1220  // Recursive call:
1221  if ( recursedCount < ossimH5Options::instance()->getMaxRecursionLevel())
1222  {
1224  file, combinedName, datasetNames, recursedCount );
1225  }
1226  else
1227  {
1229  << "ossim_hdf5::iterateGroupForDatasetNames WARNING!"
1230  << "\nMax iterations reached!" << std::endl;
1231  }
1232  }
1233  else if ( objType == H5G_DATASET )
1234  {
1235  datasetNames.push_back( combinedName );
1236  }
1237  else
1238  {
1240  << "ossim_hdf5::iterateGroupForDatasetNames WARNING!"
1241  << "\nUnhandled object type: " << objType << std::endl;
1242  }
1243  }
1244  }
1245
1246  group->close();
1247  delete group;
1248  group = 0;
1249  --recursedCount;
1250
1251  } // Matches: if ( file )
1252
1253 } // End: void ossim_hdf5::iterateGroupForDatasetNames
void combine(const std::string &left, const std::string &right, char separator, std::string &result)
◆ print()
std::ostream & ossim_hdf5::print ( H5::H5File *  file,
std::ostream &  out
Print method.
Parameters
outStream to print to.
Returns
std::ostream&
Definition at line 41 of file ossimH5Util.cpp.
References ossimString::empty(), getDatasetNames(), and printIterative().
Referenced by ossimplugins::ossimTerraSarModel::findTSXLeader(), ATP::AutoTiePoint::print(), and ossim::print().
42 {
43  if ( file )
44  {
45  std::string groupName = "/";
46  std::string prefix = "hdf5";
47  ossim_uint32 recurseCount = 0;
48
49  std::vector<std::string> datasetNames;
50
51
52  getDatasetNames(file, datasetNames );
53
54 //std::cout << "DATASET NAMES ======= " << datasetNames.size() << "\n";
55  ossim_uint32 datasetNameIdx = 0;
56  ossimString dataSetNamesStr;
57  for(;datasetNameIdx<datasetNames.size();++datasetNameIdx)
58  {
59  if(dataSetNamesStr.empty())
60  {
61  dataSetNamesStr = datasetNames[datasetNameIdx];
62  }
63  else
64  {
65  dataSetNamesStr = dataSetNamesStr + ", " + datasetNames[datasetNameIdx];
66  }
67  }
68  if(!dataSetNamesStr.empty())
69  {
70  out << prefix << ".datasetnames: " << dataSetNamesStr << "\n";
71  }
72
73  ossim_hdf5::printIterative( file, groupName, prefix, recurseCount, out );
74  }
75
76  return out;
77 }
void printIterative(H5::H5File *file, const std::string &groupName, const std::string &prefix, ossim_uint32 &recursedCount, std::ostream &out)
Definition: ossimH5Util.cpp:79
bool empty() const
Definition: ossimString.h:411
void getDatasetNames(H5::H5File *file, std::vector< std::string > &names)
◆ printArrayType()
void ossim_hdf5::printArrayType ( H5::DataSet &  dataset,
H5::ArrayType &  dataType,
const char *  dataPtr,
const std::string &  prefix,
std::ostream &  out
Definition at line 450 of file ossimH5Util.cpp.
References ossim::byteOrder(), getByteOrder(), ossimEndian::swap(), and ossimString::toString().
Referenced by printCompound().
455 {
456  ossim_uint32 arrayNdims = dataType.getArrayNDims();
457  ossimByteOrder order = getByteOrder(&dataType);
458  ossimEndian endian;
459  H5::DataType superType = dataType.getSuper();
460  //out << prefix<<".class_type: " << ossim_hdf5::getDatatypeClassType( dataType.getClass() ) << "\n";
461  if(arrayNdims)
462  {
463  std::vector<hsize_t> dims(arrayNdims);
464  dataType.getArrayDims(&dims.front());
465  if(dims.size() > 0)
466  {
467  std::stringstream dimOut;
468  ossimString dimString;
469  ossim_uint32 idx = 1;
470  ossim_uint32 nArrayElements = dims[0];
471  std::copy(dims.begin(), --dims.end(),
472  std::ostream_iterator<hsize_t>(dimOut,","));
473  for(;idx<dims.size();++idx)
474  {
475  nArrayElements*=dims[idx];
476  }
477  dimString = ossimString("(") + dimOut.str() + ossimString::toString(dims[dims.size()-1])+")";
478  out << prefix << ".dimensions: " << dimString << "\n";
479  ossim_uint32 typeSize = superType.getSize();
480  switch(superType.getClass())
481  {
482  case H5T_STRING:
483  {
484  out<<prefix<<".values: (";
485  const char* startPtr = 0;
486  const char* endPtr = 0;
487  const char* mem = 0;
488  H5T_str_t pad;
489  ossim_int32 strSize = 0;
490  for(idx=0;idx<nArrayElements;++idx)
491  {
492  mem = ((const char*)dataPtr) + (idx * typeSize);
493  if(superType.isVariableStr())
494  {
495  startPtr = *(char**) mem;
496  if(startPtr) strSize = std::strlen(startPtr);
497  else strSize = 0;
498  }
499  else
500  {
501  startPtr = mem;
502  }
503  if(startPtr)
504  {
505  ossim_uint32 charIdx = 0;
506  endPtr = startPtr;
507  for (; ((charIdx < strSize) && (*endPtr)); ++charIdx,++endPtr);
508
509  //std::cout << "WHAT????? " << ossimString(startPtr, endPtr)<<std::endl;
510  }
511  ossimString value = ossimString(startPtr, endPtr);
512  if(idx == 0)
513  {
514  out << "\""<<value<< "\"";
515  }
516  else
517  {
518  out << ", \""<<value<< "\"";
519  }
520  }
521  //out<<prefix<<".array_type: H5T_STRING\n";
522 // out<<prefix<<".values: <NOT SUPPORTED>";
523  break;
524  }
525  case H5T_INTEGER:
526  {
527  //out<<prefix<<".array_type: H5T_INTEGER\n";
528  out<<prefix<<".values: (";
529  for(idx=0;idx<nArrayElements;++idx)
530  {
531  if(typeSize == 2)
532  {
533  ossim_int16 value = *reinterpret_cast<const ossim_int16*>(dataPtr);
534  if(order!=ossim::byteOrder())
535  {
536  endian.swap(value);
537  }
538  if((idx + 1) <nArrayElements)
539  {
540  out << ossimString::toString(value) << ", ";
541  }
542  else
543  {
544  out << ossimString::toString(value);
545  }
546  }
547  else if(typeSize == 4)
548  {
549  ossim_int32 value = *reinterpret_cast<const ossim_int32*>(dataPtr);
550  if(order!=ossim::byteOrder())
551  {
552  endian.swap(value);
553  }
554  if((idx + 1) <nArrayElements)
555  {
556  out << ossimString::toString(value) << ", ";
557  }
558  else
559  {
560  out << ossimString::toString(value);
561  }
562  }
563  dataPtr+=typeSize;
564  }
565  break;
566  }
567  case H5T_FLOAT:
568  {
569  //out<<prefix<<".array_type: H5T_FLOAT\n";
570  out<<prefix<<".values: (";
571  for(idx=0;idx<nArrayElements;++idx)
572  {
573  if(typeSize == 4)
574  {
575  ossim_float32 value = *reinterpret_cast<const ossim_float32*>(dataPtr);
576  if(order!=ossim::byteOrder())
577  {
578  endian.swap(value);
579  }
580  if((idx + 1) <nArrayElements)
581  {
582  out << ossimString::toString(value) << ", ";
583  }
584  else
585  {
586  out << ossimString::toString(value);
587  }
588  }
589  else if(typeSize == 8)
590  {
591  ossim_float64 value = *reinterpret_cast<const ossim_float64*>(dataPtr);
592  if(order!=ossim::byteOrder())
593  {
594  endian.swap(value);
595  }
596  if((idx + 1) <nArrayElements)
597  {
598  out << ossimString::toString(value) << ", ";
599  }
600  else
601  {
602  out << ossimString::toString(value);
603  }
604  }
605  dataPtr+=typeSize;
606  }
607  break;
608  }
609  default:
610  {
611  break;
612  }
613  }
614  out<<")\n";
615
616  }
617  }
618 }
std::basic_stringstream< char > stringstream
Class for char mixed input and output memory streams.
Definition: ossimIosFwd.h:38
float ossim_float32
Numeric to string methods.
double ossim_float64
ossimByteOrder
short ossim_int16
int ossim_int32
◆ printAttribute()
void ossim_hdf5::printAttribute ( const H5::Attribute &  attr,
std::ostream &  out
Definition at line 829 of file ossimH5Util.cpp.
References ossim::byteOrder(), getByteOrder(), getScalarType(), ossim::isSigned(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT64, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT64, OSSIM_UINT8, size, ossimString::string(), ossimEndian::swap(), and ossimString::toString().
Referenced by printIterative(), and printObject().
832 {
833  std::string name = attr.getName();
834  H5::DataType type = attr.getDataType();
835  H5T_class_t typeClass = attr.getTypeClass();
836  size_t size = type.getSize();
837
838  std::string value; // Initialized below.
839
840  if ( ( typeClass == H5T_INTEGER ) || ( typeClass == H5T_FLOAT ) )
841  {
842  bool isSigned = false;
843  if ( typeClass == H5T_INTEGER )
844  {
845  H5::IntType intType = attr.getIntType();
846  isSigned = intType.getSign() == H5T_SGN_NONE ? false : true;
847  }
848
849  ossimScalarType scalar = ossim_hdf5::getScalarType( typeClass, size, isSigned );
850  ossimByteOrder order = ossim_hdf5::getByteOrder( &attr );
851  ossimEndian* endian = 0;
852  if ( ( size > 1 ) && ( order != ossim::byteOrder() ) )
853  {
854  endian = new ossimEndian(); // If set used as flag to byte swap.
855  }
856
857  if ( typeClass == H5T_INTEGER )
858  {
859  switch ( scalar )
860  {
861  case OSSIM_UINT8:
862  {
863  if ( size == 1 )
864  {
865  ossim_uint8 i;
866  attr.read( type, (void*)&i );
867  value = ossimString::toString( ossim_int32(i) ).string();
868  }
869  break;
870  }
871  case OSSIM_SINT8:
872  {
873  if ( size == 1 )
874  {
875  ossim_sint8 i;
876  attr.read( type, (void*)&i );
877  value = ossimString::toString( ossim_int32(i) ).string();
878  }
879  break;
880  }
881  case OSSIM_UINT16:
882  {
883  if ( size == 2 )
884  {
885  ossim_uint16 i;
886  attr.read( type, (void*)&i );
887  if ( endian )
888  {
889  endian->swap( i );
890  }
891  value = ossimString::toString( i ).string();
892  }
893  break;
894  }
895  case OSSIM_SINT16:
896  {
897  if ( size == 2 )
898  {
899  ossim_sint16 i;
900  attr.read( type, (void*)&i );
901  if ( endian )
902  {
903  endian->swap( i );
904  }
905  value = ossimString::toString( i ).string();
906  }
907  break;
908  }
909  case OSSIM_UINT32:
910  {
911  if ( size == 4 )
912  {
913  ossim_uint32 i;
914  attr.read( type, (void*)&i );
915  if ( endian )
916  {
917  endian->swap( i );
918  }
919  value = ossimString::toString( i ).string();
920  }
921  break;
922  }
923  case OSSIM_SINT32:
924  {
925  if ( size == 4 )
926  {
927  ossim_sint32 i;
928  attr.read( type, (void*)&i );
929  if ( endian )
930  {
931  endian->swap( i );
932  }
933  value = ossimString::toString( i ).string();
934  }
935  break;
936  }
937  case OSSIM_UINT64:
938  {
939  if ( size == 8 )
940  {
941  ossim_uint64 i;
942  attr.read( type, (void*)&i );
943  if ( endian )
944  {
945  endian->swap( i );
946  }
947  value = ossimString::toString( i ).string();
948  }
949  break;
950  }
951  case OSSIM_SINT64:
952  {
953  if ( size == 8 )
954  {
955  ossim_sint32 i;
956  attr.read( type, (void*)&i );
957  if ( endian )
958  {
959  endian->swap( i );
960  }
961  value = ossimString::toString( i ).string();
962  }
963  break;
964  }
965  default:
966  break;
967  }
968  }
969  else if ( typeClass == H5T_FLOAT )
970  {
971  if ( scalar == OSSIM_FLOAT32 )
972  {
973  if ( size == 4 )
974  {
975  ossim_float32 f;
976  attr.read( type, (void*)&f );
977  if ( endian )
978  {
979  endian->swap( f );
980  }
981  value = ossimString::toString( f ).string();
982  }
983  }
984  if ( scalar == OSSIM_FLOAT64 )
985  {
986  if ( size == 8 )
987  {
988  ossim_float64 f;
989  attr.read( type, (void*)&f );
990  if ( endian )
991  {
992  endian->swap( f );
993  }
994  value = ossimString::toString( f ).string();
995  }
996  }
997  }
998
999  if ( endian )
1000  {
1001  delete endian;
1002  endian = 0;
1003  }
1004  }
1005  else if ( typeClass == H5T_STRING )
1006  {
1007  attr.read( type, value );
1008  }
1009  else
1010  {
1011  if(traceDebug())
1012  {
1014  << "ossimH5Util::printAttribute WARN: Unhandled type class: " << ossim_hdf5::getDatatypeClassType( typeClass ) << "\n"
1015  << std::endl;
1016  }
1017  }
1018
1019  out << prefix << "." << name << ": " << value << std::endl;
1020
1021  type.close();
1022
1023 } // End: ossim_hdf5::printAttribute
float ossim_float32
signed char ossim_sint8
unsigned short ossim_uint16
yy_size_t size
signed short ossim_sint16
unsigned long long ossim_uint64
signed int ossim_sint32
ossimByteOrder
ossimScalarType
unsigned char ossim_uint8
std::string getDatatypeClassType(ossim_int32 type)
int ossim_int32
const std::string & string() const
Definition: ossimString.h:414
◆ printCompound()
void ossim_hdf5::printCompound ( H5::DataSet &  dataset,
std::ostream &  out
Parameters
datasetreference to a opened dataset.
prefixkeyword for the output prefix for each memeber of the compound.
Definition at line 620 of file ossimH5Util.cpp.
References getDatatypeClassType(), printArrayType(), printEnumType(), printFloatType(), printIntType(), printStrType(), and size.
Referenced by printObject().
623 {
624  H5::CompType compound(dataset);
625  H5::DataSpace dataspace = dataset.getSpace();
626  ossim_uint32 dimensions = dataspace.getSimpleExtentNdims();
627  ossim_uint32 nElements = dataspace.getSimpleExtentNpoints();
628  ossim_int32 nMembers = compound.getNmembers();
629  ossim_uint64 size = compound.getSize();
630  ossim_int32 memberIdx = 0;
631  ossim_int32 elementIdx = 0;
632  H5::DataType compType = dataset.getDataType();
633  std::vector<char> compData(size*nElements);
634  dataset.read((void*)&compData.front(),compType);
635  char* compDataPtr = &compData.front();
636
637  if(dimensions!=1)
638  {
639  return;
640  }
641
642  for(;elementIdx<nElements;++elementIdx)
643  {
644  std::string elementPrefix = prefix;//+"."+"element"+ossimString::toString(elementIdx);
645  //std::cout << "ELEMENTS: " << elements << std::endl;
646  for(memberIdx=0;memberIdx < nMembers;++memberIdx)
647  {
648  H5::DataType dataType = compound.getMemberDataType(memberIdx);
649  H5std_string memberName = compound.getMemberName(memberIdx);
650  ossim_uint32 memberOffset = compound.getMemberOffset(memberIdx) ;
651  std::string newPrefix = elementPrefix + "."+ memberName;
652  switch(dataType.getClass())
653  {
654  case H5T_COMPOUND:
655  {
656  ossim_hdf5::printCompound(dataset, newPrefix, out);
657  break;
658  }
659  case H5T_INTEGER:
660  {
661  H5::IntType dataType = compound.getMemberIntType(memberIdx);
662  ossim_hdf5::printIntType(dataset, dataType, &compDataPtr[memberOffset], newPrefix, out);
663  break;
664  }
665  case H5T_FLOAT:
666  {
667  H5::FloatType dataType = compound.getMemberFloatType(memberIdx);
668  ossim_hdf5::printFloatType(dataset, dataType, &compDataPtr[memberOffset], newPrefix, out);
669  break;
670  }
671  case H5T_TIME:
672  case H5T_STRING:
673  {
674  H5::StrType dataType = compound.getMemberStrType(memberIdx);
675  ossim_hdf5::printStrType(dataset, dataType, &compDataPtr[memberOffset], newPrefix, out);
676  break;
677  }
678  case H5T_BITFIELD:
679  {
680  out << newPrefix << ": <H5T_BITFIELD NOT HANDLED>\n";
681  break;
682  }
683  case H5T_OPAQUE:
684  {
685  out << newPrefix << ": <H5T_OPAQUE NOT HANDLED>\n";
686  break;
687  }
688  case H5T_REFERENCE:
689  {
690  out << newPrefix << ": <H5T_REFERENCE NOT HANDLED>\n";
691  break;
692  }
693  case H5T_ENUM:
694  {
695  H5::EnumType dataType = compound.getMemberEnumType(memberIdx);
696  ossim_hdf5::printEnumType(dataset, dataType, newPrefix, out);
697  break;
698  }
699  case H5T_VLEN:
700  {
701  out << newPrefix << ": <H5T_VLEN NOT HANDLED>\n";
702  break;
703  }
704  case H5T_ARRAY:
705  {
706  H5::ArrayType dataType = compound.getMemberArrayType(memberIdx);
707  ossim_hdf5::printArrayType(dataset, dataType, &compDataPtr[memberOffset], newPrefix, out);
708  break;
709  }
710  case H5T_NO_CLASS:
711  default:
712  {
713  out<< newPrefix << ".class_type: "
714  << ossim_hdf5::getDatatypeClassType( dataType.getClass() ) << "\n";
715  out << newPrefix << ": <NOT HANDLED>\n";
716  break;
717  }
718  }
719  }
720  compDataPtr+=size;
721  }
722 }
void printCompound(H5::DataSet &dataset, const std::string &prefix, std::ostream &out)
void printIntType(H5::DataSet &dataset, H5::IntType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out)
void printFloatType(H5::DataSet &dataset, H5::FloatType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out)
yy_size_t size
void printStrType(H5::DataSet &dataset, H5::StrType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out)
void printEnumType(H5::DataSet &dataset, H5::EnumType &dataType, const std::string &prefix, std::ostream &out)
void printArrayType(H5::DataSet &dataset, H5::ArrayType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out)
int ossim_int32
◆ printEnumType()
void ossim_hdf5::printEnumType ( H5::DataSet &  dataset,
H5::EnumType &  dataType,
std::ostream &  out
Definition at line 283 of file ossimH5Util.cpp.
287 {
288  ossim_int32 nEnumMembers = dataType.getNmembers();
289  ossim_int32 enumMemberIdx = 0;
290  ossim_int32 enumTypeSize = dataType.getSize();
291  if(dataType.getSize() == 4)
292  {
293  out << prefix << ".class_type: H5T_ENUM\n";
294  for(;enumMemberIdx<nEnumMembers;++enumMemberIdx)
295  {
296  try{
297  ossim_int32 value = 0;
298
299  dataType.getMemberValue(enumMemberIdx, &value);
300  H5std_string name = dataType.nameOf(&value, 2048);
301  out << prefix << "." << name << ": " <<value <<"\n";
302  }
303  catch(H5::Exception& e)
304  {
305  }
306  }
307  }
308 }
int ossim_int32
◆ printFloatType()
void ossim_hdf5::printFloatType ( H5::DataSet &  dataset,
H5::FloatType &  dataType,
std::ostream &  out
Definition at line 405 of file ossimH5Util.cpp.
410 {
411  ossim_uint32 floatSize = dataType.getSize();
412  ossimByteOrder order = getByteOrder(&dataType);
413  ossimEndian endian;
414
415  if(floatSize == 4)
416  {
417  ossim_float32 value = *reinterpret_cast<const ossim_float32*>(dataPtr);
418  if(order!=ossim::byteOrder())
419  {
420  endian.swap(value);
421  }
422  out << prefix<<": "<<ossimString::toString(value)<<"\n";
423  }
424  else if(floatSize == 8)
425  {
426  ossim_float64 value = *reinterpret_cast<const ossim_float64*>(dataPtr);
427  if(order!=ossim::byteOrder())
428  {
429  endian.swap(value);
430  // std::cout << "NOT THE SAME ORDER!!!!!!!!!!!!\n";
431  }
432  out << prefix<<": "<<ossimString::toString(value)<<"\n";
433  }
434 }
float ossim_float32
ossimByteOrder
◆ printIntType()
void ossim_hdf5::printIntType ( H5::DataSet &  dataset,
H5::IntType &  dataType,
std::ostream &  out
Definition at line 310 of file ossimH5Util.cpp.
References ossim::byteOrder(), getByteOrder(), getScalarType(), ossim::isSigned(), OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT64, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT64, OSSIM_UINT8, ossimEndian::swap(), and ossimString::toString().
315 {
316  ossim_uint32 dataTypeSize = dataType.getSize();
317  ossimByteOrder order = getByteOrder(&dataType);
318  ossimEndian endian;
319  bool isSigned = dataType.getSign() == H5T_SGN_NONE ? false : true;
320  ossimString valueStr;
321  ossimScalarType scalarType = getScalarType(dataType.getClass(), dataTypeSize, isSigned);
322  switch(scalarType)
323  {
324  case OSSIM_UINT8:
325  {
326  ossim_uint8 value = *reinterpret_cast<const ossim_uint8*>(dataPtr);
327  valueStr = ossimString::toString(value);
328  break;
329  }
330  case OSSIM_SINT8:
331  {
332  ossim_int8 value = *reinterpret_cast<const ossim_int8*>(dataPtr);
333  valueStr = ossimString::toString(value);
334  break;
335  }
336  case OSSIM_UINT16:
337  {
338  ossim_uint16 value = *reinterpret_cast<const ossim_uint16*>(dataPtr);
339  if(order!=ossim::byteOrder())
340  {
341  endian.swap(value);
342  }
343  valueStr = ossimString::toString(value);
344  break;
345  }
346  case OSSIM_SINT16:
347  {
348  ossim_int16 value = *reinterpret_cast<const ossim_int16*>(dataPtr);
349  if(order!=ossim::byteOrder())
350  {
351  endian.swap(value);
352  }
353  valueStr = ossimString::toString(value);
354  break;
355  }
356  case OSSIM_UINT32:
357  {
358  ossim_uint32 value = *reinterpret_cast<const ossim_uint32*>(dataPtr);
359  if(order!=ossim::byteOrder())
360  {
361  endian.swap(value);
362  }
363  valueStr = ossimString::toString(value);
364  break;
365  }
366  case OSSIM_SINT32:
367  {
368  ossim_int32 value = *reinterpret_cast<const ossim_int32*>(dataPtr);
369  if(order!=ossim::byteOrder())
370  {
371  endian.swap(value);
372  }
373  valueStr = ossimString::toString(value);
374  break;
375  }
376  case OSSIM_UINT64:
377  {
378  ossim_uint64 value = *reinterpret_cast<const ossim_uint64*>(dataPtr);
379  if(order!=ossim::byteOrder())
380  {
381  endian.swap(value);
382  }
383  valueStr = ossimString::toString(value);
384  break;
385  }
386  case OSSIM_SINT64:
387  {
388  ossim_int64 value = *reinterpret_cast<const ossim_int64*>(dataPtr);
389  if(order!=ossim::byteOrder())
390  {
391  endian.swap(value);
392  }
393  valueStr = ossimString::toString(value);
394  break;
395  }
396  default:
397  {
398  valueStr = "<UNHANDLED SCALAR TYPE>";
399  break;
400  }
401  }
402  out << prefix<<": "<<valueStr<<"\n";
403 }
char ossim_int8
Previous DLL import export section.
ossimByteOrder
ossimScalarType
short ossim_int16
long long ossim_int64
int ossim_int32
◆ printIterative()
void ossim_hdf5::printIterative ( H5::H5File *  file,
const std::string &  groupName,
ossim_uint32 recursedCount,
std::ostream &  out
Parameters
prefixto start the walk with.
recursedCountCallers should start at zero. This is used internally to avoid an infinite loop as this method recursively calls itself.
Definition at line 79 of file ossimH5Util.cpp.
References combine(), ossimH5Options::instance(), ossimNotify(), ossimNotifyLevel_WARN, printAttribute(), and printObject().
Referenced by print().
84 {
85  if ( file && groupName.size() )
86  {
87  ++recursedCount;
88
89  H5::Group* group = new H5::Group( file->openGroup(groupName) );
90
91  // Print attributes:
92  const ossim_uint32 ATTRS_COUNT = group->getNumAttrs();
93  for ( ossim_uint32 aIdx = 0; aIdx < ATTRS_COUNT; ++aIdx )
94  {
95  H5::Attribute attr( group->openAttribute( aIdx ) );
96  ossim_hdf5::printAttribute( attr, prefix, out );
97  }
98
99  const hsize_t OBJ_COUNT = group->getNumObjs();
100  for ( hsize_t i = 0; i < OBJ_COUNT; ++i )
101  {
102  std::string objName = group->getObjnameByIdx(i);
103
104  if ( objName.size() )
105  {
106  char separator = '/';
107  std::string combinedName;
108  combine( groupName, objName, separator, combinedName );
109
110  separator = '.';
111  std::string combinedPrefix;
112  combine( prefix, objName, separator, combinedPrefix );
113
114  H5G_obj_t objType = group->getObjTypeByIdx(i);
115
116 #if 0
117  std::cout << "combinedName: " << combinedName
118  << "\ncombinedPrefix: " << combinedPrefix
119  << "\ngetObjnameByIdx[" << i << "]: " << objName
120  << "\ngetObjTypeByIdx[" << i << "]: " << objType
121  << std::endl;
122 #endif
123
124  if ( objType == H5G_GROUP )
125  {
126  // Recursive call:
127  if ( recursedCount < ossimH5Options::instance()->getMaxRecursionLevel())//ossim_hdf5::MAX_RECURSION_LEVEL )
128  {
130  file, combinedName, combinedPrefix, recursedCount, out );
131  }
132  else
133  {
135  << "ossim_hdf5::printIterative WARNING!"
136  << "\nMax iterations reached!" << std::endl;
137  }
138  }
139  else if ( objType == H5G_DATASET )
140  {
141  printObject( file, combinedName, combinedPrefix, out );
142  }
143  else
144  {
146  << "ossim_hdf5::printIterative WARNING!"
147  << "\nUnhandled object type: " << objType << std::endl;
148  }
149  }
150  }
151
152  group->close();
153  delete group;
154  group = 0;
155  --recursedCount;
156
157  } // Matches: if ( file )
158
159 } // End: void ossim_hdf5::printIterative method.
void printAttribute(const H5::Attribute &attr, const std::string &prefix, std::ostream &out)
void printObject(H5::H5File *file, const std::string &objectName, const std::string &prefix, std::ostream &out)
Prints an object.
◆ printObject()
void ossim_hdf5::printObject ( H5::H5File *  file,
std::ostream &  out
Prints an object.
Parameters
Definition at line 161 of file ossimH5Util.cpp.
References ossimKeywordNames::BYTE_ORDER_KW, ossim::byteOrder(), getByteOrder(), getDatatypeClassType(), ossimLookUpTable::getEntryString(), getExtents(), getScalarType(), ossimScalarTypeLut::instance(), ossim::isSigned(), OSSIM_BIG_ENDIAN, OSSIM_SCALAR_UNKNOWN, printAttribute(), printCompound(), printEnumType(), ossimKeywordNames::SCALAR_TYPE_KW, ossim::scalarSizeInBytes(), ossimString::string(), and ossimString::toString().
Referenced by printIterative().
165 {
166 #if 0
167  std::cout << "printObject entered..."
168  << "\nobjectName: " << objectName
169  << "\nprefix: " << prefix
170  << std::endl;
171 #endif
172
173  H5::DataSet dataset = file->openDataSet( objectName );
174  // Get the class of the datatype that is used by the dataset.
175  H5T_class_t type_class = dataset.getTypeClass();
176  out << prefix << ".class_type: "
177  << ossim_hdf5::getDatatypeClassType( type_class ) << std::endl;
178
179  const ossim_uint32 ATTRS_COUNT = dataset.getNumAttrs();
180  for ( ossim_uint32 aIdx = 0; aIdx < ATTRS_COUNT; ++aIdx )
181  {
182  H5::Attribute attr = dataset.openAttribute( aIdx );
183  ossim_hdf5::printAttribute( attr, prefix, out );
184  }
185
186  switch(type_class)
187  {
188  case H5T_COMPOUND:
189  {
190  ossim_hdf5::printCompound(dataset, prefix, out);
191  break;
192  }
193  case H5T_ENUM:
194  {
195  H5::EnumType dataType = dataset.getEnumType();
196  ossim_hdf5::printEnumType(dataset, dataType,
197  prefix, out);
198  break;
199  }
200  case H5T_REFERENCE:
201  {
202  out << prefix << ".class_type: "
203  << ossim_hdf5::getDatatypeClassType( type_class ) << std::endl;
204
205  break;
206  }
207  default:
208  {
209  //std::cout << "TYPE CLASS NOT HANDLED ===== " << type_class << std::endl;
210  break;
211  }
212  }
213  //std::cout << "NPOINTS === "
214  // Extents:
215  std::vector<ossim_uint32> extents;
216  ossim_hdf5::getExtents( &dataset, extents );
217  for ( ossim_uint32 i = 0; i < extents.size(); ++i )
218  {
219  ossimString os;
220  std::string exStr = ".extent";
221  exStr += os.toString(i).string();
222  out << prefix << exStr << ": " << extents[i] << std::endl;
223  }
224
225  ossimScalarType scalar;
226  switch(type_class)
227  {
228  case H5T_INTEGER:
229  {
230  H5::IntType dataType = dataset.getIntType();
231  bool isSigned = dataType.getSign() == H5T_SGN_NONE ? false : true;
232
233  scalar = ossim_hdf5::getScalarType( type_class, dataType.getSize(), isSigned);
234
235  break;
236  }
237  case H5T_FLOAT:
238  {
239  H5::FloatType dataType = dataset.getFloatType();
240  bool isSigned = true;
241
242  scalar = ossim_hdf5::getScalarType( type_class, dataType.getSize(), isSigned);
243  break;
244  }
245  default:
246  {
247  scalar = OSSIM_SCALAR_UNKNOWN;
248  }
249  }
250  //dataset.getId() );
251  if ( scalar != OSSIM_SCALAR_UNKNOWN)
252  {
253  out << prefix << "." << ossimKeywordNames::SCALAR_TYPE_KW << ": "
254  << ossimScalarTypeLut::instance()->getEntryString( scalar ) << std::endl;
255
256  if ( ossim::scalarSizeInBytes( scalar ) > 1 )
257  {
259  std::string byteOrderString = "little_endian";
260  if ( byteOrder == OSSIM_BIG_ENDIAN )
261  {
262  byteOrderString = "big_endian";
263  }
264  out << prefix << "." <<ossimKeywordNames::BYTE_ORDER_KW << ": "
265  << byteOrderString << std::endl;
266  }
267  }
268
269 #if 0
270  // Attributes:
271  int numberOfAttrs = dataset.getNumAttrs();
272  cout << "numberOfAttrs: " << numberOfAttrs << endl;
273  for ( ossim_int32 attrIdx = 0; attrIdx < numberOfAttrs; ++attrIdx )
274  {
275  H5::Attribute attribute = dataset.openAttribute( attrIdx );
276  cout << "attribute.from class: " << attribute.fromClass() << endl;
277  }
278 #endif
279  dataset.close();
280
281 } // End: printObject
Prints a compound object.
static const char * BYTE_ORDER_KW
OSSIM_DLL ossim_uint32 scalarSizeInBytes(ossimScalarType scalarType)
ossimByteOrder
ossimScalarType
static const char * SCALAR_TYPE_KW
int ossim_int32
◆ printStrType()
void ossim_hdf5::printStrType ( H5::DataSet &  dataset,
H5::StrType &  dataType,
std::ostream &  out
Definition at line 436 of file ossimH5Util.cpp.
441 {
442  const char* startPtr = dataPtr;
443  const char* endPtr = dataPtr;
444  const char* maxPtr = dataPtr + dataType.getSize();
445  while((endPtr != maxPtr)&&(*endPtr!='\0')) ++endPtr;
446  ossimString value(startPtr, endPtr);
447  out << prefix <<": "<<value<<"\n";
448 }
