Functions | Variables
ossimOpenCvPluginInit.cpp File Reference
#include <ossim/plugin/ossimSharedObjectBridge.h>
#include <ossim/plugin/ossimPluginConstants.h>
#include "ossimOpenCvObjectFactory.h"
#include <ossim/base/ossimString.h>
#include <ossim/base/ossimObjectFactoryRegistry.h>
Go to the source code of this file.
Functions
const char * getOpenCVDescription ()
int getOpenCVNumberOfClassNames ()
const char * getOpenCVClassName (int idx)
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize (ossimSharedObjectInfo **info)
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ()
Variables
ossimSharedObjectInfo myOpenCVInfo
ossimString theOpenCVDescription
std::vector< ossimStringtheOpenCVObjList
Function Documentation
◆ getOpenCVClassName()
const char* getOpenCVClassName ( int  idx)
Definition at line 40 of file ossimOpenCvPluginInit.cpp.
References theOpenCVObjList.
Referenced by ossimSharedLibraryInitialize().
41  {
42  if(idx < (int)theOpenCVObjList.size())
43  {
44  return theOpenCVObjList[idx].c_str();
45  }
46  return (const char*)0;
47  }
std::vector< ossimString > theOpenCVObjList
◆ getOpenCVDescription()
const char* getOpenCVDescription ( )
Definition at line 30 of file ossimOpenCvPluginInit.cpp.
References ossimString::c_str(), and theOpenCVDescription.
31  {
32  return theOpenCVDescription.c_str();
33  }
const char * c_str() const
Definition: ossimString.h:396
◆ getOpenCVNumberOfClassNames()
int getOpenCVNumberOfClassNames ( )
Definition at line 35 of file ossimOpenCvPluginInit.cpp.
36  {
37  return (int)theOpenCVObjList.size();
38  }
◆ ossimSharedLibraryFinalize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ( )
Definition at line 68 of file ossimOpenCvPluginInit.cpp.
References ossimObjectFactoryRegistry::instance(), and ossimOpenCvObjectFactory::instance().
69  {
71  unregisterFactory(ossimOpenCvObjectFactory::instance());
72  }
static ossimOpenCvObjectFactory * instance()
static method to return instance (the only one) of this class.
static ossimObjectFactoryRegistry * instance()
◆ ossimSharedLibraryInitialize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize ( ossimSharedObjectInfo **  info)
Definition at line 50 of file ossimOpenCvPluginInit.cpp.
References ossimSharedObjectInfo::getClassName, ossimSharedObjectInfo::getDescription, ossimSharedObjectInfo::getNumberOfClassNames, getOpenCVClassName(), getOpenCVDescription(), getOpenCVNumberOfClassNames(), ossimObjectFactoryRegistry::instance(), ossimOpenCvObjectFactory::instance(), and myOpenCVInfo.
52  {
56
57  *info = &myOpenCVInfo;
58
59  /* Register objects... */
61  registerFactory(ossimOpenCvObjectFactory::instance());
62
63  setOpenCVDescription(theOpenCVDescription);
65  }
const char * getOpenCVClassName(int idx)
ossimSharedLibraryGetNumberOfClassNamesPtr getNumberOfClassNames
const char * getOpenCVDescription()
ossimSharedLibraryGetDescriptionPtr getDescription
ossimSharedLibraryGetClassNamesPtr getClassName
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
Adds ossimLasWriter to the typeList.
int getOpenCVNumberOfClassNames()
Variable Documentation
◆ myOpenCVInfo
Definition at line 26 of file ossimOpenCvPluginInit.cpp.
◆ theOpenCVDescription
Definition at line 27 of file ossimOpenCvPluginInit.cpp.
Referenced by getOpenCVDescription().
◆ theOpenCVObjList
std::vector<ossimString> theOpenCVObjList
Definition at line 28 of file ossimOpenCvPluginInit.cpp.
Referenced by getOpenCVClassName(), and getOpenCVNumberOfClassNames().
