11 #ifndef ossimPngWriter_HEADER 12 #define ossimPngWriter_HEADER 63 virtual bool isOpen()
const;
73 const char* prefix=0)
const;
80 const char* prefix=0);
102 virtual void getPropertyNames(std::vector<ossimString>& propertyNames)
const;
176 static void pngWriteData(png_structp png_ptr, png_bytep data,
183 static void pngFlush(png_structp png_ptr);
ossim_uint16 theTransparentGreen
ossim_uint16 theBackgroundBlue
void writeTransparentColorChunk(png_structp pp, png_infop info)
Write transparent color chunk (tRNS) Location: Multiple:
void writePhysicalScale(png_structp pp, png_infop info)
Write physical scale (sCAL) Location: before first IDAT Multiple: no.
bool theTimeFlag
Time support, either on or off.
void writeLatinTextChunk(png_structp pp, png_infop info)
Write any text (tEXt, zTXt).
virtual ossimString getLongName() const
ossim_int32 theInterlaceSupport
Interlace support: PNG_INTERLACE_ADAM7 PNG_INTERLACE_NONE.
virtual ossimString getClassName() const
Will set the property whose name matches the argument "property->getName()".
void writeBackgroundColorChunk(png_structp pp, png_infop info)
Write background color chunk (bKGD) Location: After PLTE, before first IDAT.
ossim_int32 thePngFilter
PNG_NO_FILTERS 0x00 PNG_FILTER_NONE 0x08 PNG_FILTER_SUB 0x10 PNG_FILTER_UP 0x20 PNG_FILTER_AVG 0x40 P...
bool theBackgroundFlag
For background support.
saves the state of the object.
void setAlphaChannelFlag(bool flag)
Set the writer to add an alpha channel to the output png image.
virtual void getImageTypeList(std::vector< ossimString > &imageTypeList) const
void getImageTypeList(std::vector<ossimString>& imageTypeList)const
void writeImageOffset(png_structp pp, png_infop info)
Write image offset (oFFs) Location: before first IDAT Multiple: no.
virtual bool writeStream()
Method to write the image to a stream.
ossim_uint16 theTransparentGray
void writeFractalParameters(png_structp pp, png_infop info)
Write fractal parameters (fRAc) Location: anywhere Multiple: yes.
Pure virtual base class for image file writers.
unsigned short ossim_uint16
virtual ossimString getExtension() const
Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for...
bool setCompressionLevel(const ossimString &level)
Set the png compression level from a string.
ossim_uint16 theBackgroundGray
Callback method for a flush.
std::ostream * theOutputStream
Pushes this's names onto the list of property names.
void writeInternationalTextChunk(png_structp pp, png_infop info)
Write any text (iTXt).
void writeSuggestedPalette(png_structp pp, png_infop info)
Write suggested palette (sPLT) Location: before first IDAT Multiple: yes.
ossim_uint16 theBackgroundRed
ossimString getCompressionLevel() const
Get the png compression level as a string.
virtual bool isOpen() const
ossim_int32 theCompressionLevel
Compression level from zlib.h: Z_NO_COMPRESSION 0 Z_BEST_SPEED 1 Z_BEST_COMPRESSION 9 Z_DEFAULT_COMPR...
bool isLutEnabled() const
void writePixelCalibration(png_structp pp, png_infop info)
Write pixel calibration (pCAL) Location: after PLTE, before first IDAT Multiple: no.
bool theAlphaChannelFlag
For alpha channel support.
virtual bool writeFile()
Writes the file to disk or a stream.
bool getAlphaChannelFlag(void) const
Retrieve the writer's setting for whether or not to add an alpha channel to the output png image...
bool hasImageType(const ossimString &imageType) const
bool hasImageType(const ossimString& imageType) const
bool theGammaFlag
For gamma support.
void writeHistogram(png_structp pp, png_infop info)
Write histogram (hIST) Location: after PLTE, before first IDAT Multiple: no.
ossim_int32 getColorType(ossim_int32 bands) const
Get the png color type.
void writeGammaChunk(png_structp pp, png_infop info)
Write gamm chunk (gAMMA) Location: Before PLTE, before first IDAT.
bool theTransparentFlag
For transparent color support.
virtual ~ossimPngWriter()
virtual ossimString getShortName() const
void writeOptionalChunks(png_structp pp, png_infop info)
writes optionial chunks.
void writeTimeStampChunk(png_structp pp, png_infop info)
Write time stamp chunk (tIME).
class ossimNBandLutDataObject
ossim_uint16 theTransparentBlue
ossim_uint16 theBackgroundGreen
void writeSignificantBits(png_structp pp, png_infop info)
Write significant bits (sBIT) Location: before PLTE and first IDAT Multiple: no.
ossim_uint16 theTransparentRed
void writePhysicalPixelDimensions(png_structp pp, png_infop info)
Write physical pixel dimensions (pHYs) Location: before first IDAT Multiple: no.
void setLut(const ossimNBandLutDataObject &lut)
ossim_int32 getBitDepth(ossimScalarType outputScalar) const
ossim_int32 theCompressionStratagy
Z_FILTERED 1 Z_HUFFMAN_ONLY 2 Z_RLE 3 Z_FIXED 4 Z_DEFAULT_STRATEGY 0.
virtual bool setOutputStream(std::ostream &stream)
Sets the output stream to write to.
bool doSwap(ossimScalarType outputScalar) const
std::basic_ostream< char > ostream
Base class for char output streams.
static void pngWriteData(png_structp png_ptr, png_bytep data, png_size_t length)
Callback method for writing to stream.
