Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | Friends | List of all members
ossimNBandLutDataObject Class Reference
class ossimNBandLutDataObject More...
#include <ossimNBandLutDataObject.h>
Inheritance diagram for ossimNBandLutDataObject:
ossimObject ossimReferenced
Public Types
typedef ossim_int32 LUT_ENTRY_TYPE
 ossimNBandLutDataObject (ossim_uint32 numberOfEntries=0, ossim_uint32 numberOfBands=0, ossimScalarType bandScalarType=OSSIM_UINT8, ossim_int32 nullPixelIndex=-1)
 ossimNBandLutDataObject (const ossimNBandLutDataObject &lut)
ossimObjectdup () const
void create (ossim_uint32 numberOfEntries, ossim_uint32 numberOfBands=3)
const LUT_ENTRY_TYPEoperator[] (ossim_uint32 idx) const
const LUT_ENTRY_TYPEoperator[] (ossim_int32 idx) const
const LUT_ENTRY_TYPEoperator[] (double normalizedIndex) const
bool hasNullPixelIndex () const
void getMinMax (ossim_uint32 band, LUT_ENTRY_TYPE &minValue, LUT_ENTRY_TYPE &maxValue)
 Will return the min max value for a given band. More...
ossim_int32 getFirstNullAlphaIndex () const
void setNullPixelIndex (ossim_int32 idx)
 Allows you to specify which entry is to be designated as an invalid entry. More...
ossim_int32 getNullPixelIndex () const
ossim_uint32 getNumberOfBands () const
ossim_uint32 getNumberOfEntries () const
ossim_uint32 findIndex (ossim_int32 *values) const
 This method gives you a way to find an entry index closest to the passed in band values. More...
ossim_uint32 findIndex (ossim_int32 *values, ossim_uint32 size) const
void clearLut ()
 Will do a simple memset to '\0' all. More...
const ossimNBandLutDataObjectoperator= (const ossimNBandLutDataObject &lut)
 does a deep copy from the passed in lut to the object. More...
bool operator== (const ossimNBandLutDataObject &lut) const
 Determines if the state of this lut is identical to the passed in lut. More...
bool open (const ossimFilename &lutFile)
 Reads in an external lut file. More...
std::vector< ossimStringgetEntryLabels (ossim_uint32 band)
void setEntryLables (ossim_uint32 band, std::vector< ossimString > entryLabels)
 Loads the state of the object by reading in the keywords listed in the save state. More...
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
virtual ~ossimNBandLutDataObject ()
virtual ~ossimReferenced ()
LUT_ENTRY_TYPEtheLut
ossim_uint32 theNumberOfEntries
ossim_uint32 theNumberOfBands
ossimScalarType theBandScalarType
ossim_int32 theNullPixelIndex
std::map< ossim_uint32, std::vector< ossimString > > m_entryLabels
Friends
std::ostream & operator<< (std::ostream &out, const ossimNBandLutDataObject &lut)
Detailed Description
Sample CADRG LUT taken from an arbitrary CADRG image entry. This is a keywordlist support by the loadstate of this class.
entry0:  25 39 116
entry1:  245 242 242
entry10:  92 89 115
entry100:  74 55 85
entry101:  233 165 53
entry102:  75 2 4
entry103:  162 118 42
entry104:  233 159 130
entry105:  189 129 40
entry106:  154 109 66
entry107:  145 97 85
entry108:  121 86 31
entry109:  238 151 118
entry11:  52 31 76
entry110:  239 167 42
entry111:  236 137 100
entry112:  179 112 88
entry113:  92 37 33
entry114:  121 66 24
entry115:  120 133 151
entry116:  76 92 192
entry117:  36 50 117
entry118:  57 75 191
entry119:  125 45 50
entry12:  235 217 204
entry120:  102 65 81
entry121:  172 148 199
entry122:  204 145 95
entry123:  81 19 5
entry124:  91 4 1
entry125:  109 54 31
entry126:  137 114 118
entry127:  230 150 52
entry128:  82 38 87
entry129:  190 120 76
entry13:  244 218 172
entry130:  170 109 45
entry131:  95 20 22
entry132:  150 80 61
entry133:  225 122 82
entry134:  122 37 16
entry135:  146 88 49
entry136:  122 94 122
entry137:  230 135 63
entry138:  137 73 75
entry139:  119 46 29
entry14:  189 167 141
entry140:  190 142 128
entry141:  242 216 187
entry142:  176 125 95
entry143:  193 117 143
entry144:  19 0 0
entry145:  12 1 42
entry146:  24 4 26
entry147:  38 40 52
entry148:  8 24 175
entry149:  40 23 45
entry15:  245 213 142
entry150:  39 11 58
entry151:  10 0 22
entry152:  236 148 41
entry153:  101 41 11
entry154:  230 113 67
entry155:  148 44 46
entry156:  225 144 133
entry157:  115 2 13
entry158:  159 79 49
entry159:  164 95 33
entry16:  246 241 205
entry160:  97 6 22
entry161:  175 90 133
entry162:  112 23 20
entry163:  105 22 6
entry164:  148 59 33
entry165:  215 118 104
entry166:  211 122 41
entry167:  233 129 34
entry168:  153 73 25
entry169:  208 102 39
entry17:  240 215 89
entry170:  206 101 133
entry171:  229 113 96
entry172:  127 16 25
entry173:  224 104 28
entry174:  171 76 74
entry175:  221 94 78
entry176:  229 86 94
entry177:  213 80 57
entry178:  161 44 36
entry179:  155 54 19
entry18:  115 92 157
entry180:  130 25 5
entry181:  150 29 24
entry182:  198 54 34
entry183:  224 61 70
entry184:  213 82 37
entry185:  186 28 31
entry186:  200 64 15
entry187:  110 2 2
entry188:  195 38 12
entry189:  151 6 8
entry19:  160 163 37
entry190:  193 13 10
entry191:  205 1 3
entry192:  44 62 193
entry193:  35 14 16
entry194:  15 30 118
entry195:  28 47 189
entry196:  25 3 80
entry197:  7 16 118
entry198:  33 10 6
entry199:  39 24 95
entry2:  216 212 237
entry20:  38 29 21
entry200:  82 58 159
entry201:  55 29 142
entry202:  33 4 23
entry203:  17 14 36
entry204:  58 26 41
entry205:  11 13 14
entry206:  74 87 85
entry207:  50 60 41
entry208:  119 123 98
entry209:  193 187 172
entry21:  208 202 156
entry210:  124 126 128
entry211:  47 68 84
entry212:  110 119 60
entry213:  63 145 121
entry214:  154 166 147
entry215:  107 156 104
entry22:  242 202 152
entry23:  168 148 140
entry24:  31 22 25
entry25:  245 205 114
entry26:  245 191 137
entry27:  175 161 172
entry28:  17 6 11
entry29:  172 170 137
entry3:  247 230 113
entry30:  51 27 20
entry31:  239 210 73
entry32:  185 176 129
entry33:  35 2 13
entry34:  60 52 51
entry35:  101 78 70
entry36:  141 124 101
entry37:  206 184 107
entry38:  244 174 106
entry39:  82 98 136
entry4:  246 231 132
entry40:  190 191 239
entry41:  241 188 161
entry42:  67 51 38
entry43:  244 184 122
entry44:  211 201 142
entry45:  61 27 16
entry46:  182 182 82
entry47:  243 188 87
entry48:  86 83 60
entry49:  61 40 43
entry5:  204 198 166
entry50:  146 141 93
entry51:  44 4 4
entry52:  231 210 51
entry53:  85 74 39
entry54:  197 169 127
entry55:  182 151 60
entry56:  121 98 73
entry57:  243 182 145
entry58:  58 18 21
entry59:  241 157 91
entry6:  2 0 2
entry60:  59 4 1
entry61:  155 162 223
entry62:  154 133 80
entry63:  73 21 16
entry64:  195 183 116
entry65:  76 51 29
entry66:  234 181 63
entry67:  58 59 98
entry68:  42 22 79
entry69:  134 143 219
entry7:  204 204 239
entry70:  106 117 205
entry71:  48 65 117
entry72:  63 54 117
entry73:  125 93 62
entry74:  137 138 41
entry75:  104 68 59
entry76:  113 99 41
entry77:  76 30 11
entry78:  239 184 48
entry79:  161 129 98
entry8:  31 4 66
entry80:  241 170 126
entry81:  145 109 105
entry82:  207 163 116
entry83:  79 41 40
entry84:  175 138 41
entry85:  10 0 56
entry86:  180 151 77
entry87:  72 12 24
entry88:  242 154 105
entry89:  91 26 15
entry9:  246 238 162
entry90:  160 118 53
entry91:  228 166 141
entry92:  231 160 69
entry93:  61 2 11
entry94:  132 83 60
entry95:  86 46 24
entry96:  243 143 86
entry97:  108 60 46
entry98:  109 76 38
entry99:  96 86 84
null_value:  -1
number_bands:  3
number_entries:  216
scalar_type:  ossim_uint8
type:  ossimNBandLutDataObject
NOTES:
  • The null_value keyword above is the index in the lut that correspnds to an invalid pixel value.
  • Each entry will have number_bands. SO if number of bands is 3 then there will be 3 values Where the first value is for band 1, ... etc.
  • scalar_type is a hint as to the scalar type of the entries. Is the resulting lut for 8 bit, 16 bit , etc data.
  • You should always use the LUT_ENTRY_TYPE when getting values from the lut. This value could change to an ossim_float32 precision and if you use the LUT_ENTRY_TYPE then your code will not have to change.
Definition at line 259 of file ossimNBandLutDataObject.h.
Member Typedef Documentation
◆ LUT_ENTRY_TYPE
Definition at line 263 of file ossimNBandLutDataObject.h.
◆ ossimNBandLutDataObject() [1/2]
ossimNBandLutDataObject::ossimNBandLutDataObject ( ossim_uint32  numberOfEntries = 0,
ossim_uint32  numberOfBands = 0,
ossimScalarType  bandScalarType = OSSIM_UINT8,
ossim_int32  nullPixelIndex = -1
Will allocate 256 values for the color table
Definition at line 51 of file ossimNBandLutDataObject.cpp.
References create().
55  :theLut(0),
58  theBandScalarType(bandScalarType),
59  theNullPixelIndex(nullPixelIndex)
60 {
61  create(numberOfEntries, numberOfBands);
62 }
void create(ossim_uint32 numberOfEntries, ossim_uint32 numberOfBands=3)
◆ ossimNBandLutDataObject() [2/2]
ossimNBandLutDataObject::ossimNBandLutDataObject ( const ossimNBandLutDataObject lut)
Definition at line 64 of file ossimNBandLutDataObject.cpp.
65  :theLut(0),
71 {
72  *this = lut;
73 }
◆ ~ossimNBandLutDataObject()
ossimNBandLutDataObject::~ossimNBandLutDataObject ( )
protectedvirtual
Definition at line 75 of file ossimNBandLutDataObject.cpp.
References m_entryLabels, theLut, theNumberOfBands, and theNumberOfEntries.
76 {
77  if(theLut)
78  {
79  delete [] theLut;
80  theLut = 0;
81  }
83  theNumberOfBands = 0;
84  m_entryLabels.clear();
85 }
Member Function Documentation
◆ clearLut()
void ossimNBandLutDataObject::clearLut ( )
Definition at line 150 of file ossimNBandLutDataObject.cpp.
References theLut, theNumberOfBands, and theNumberOfEntries.
Referenced by loadState().
◆ create()
void ossimNBandLutDataObject::create ( ossim_uint32  numberOfEntries,
ossim_uint32  numberOfBands = 3
Definition at line 87 of file ossimNBandLutDataObject.cpp.
Referenced by ossimNitfImageHeader::createLut(), loadState(), operator=(), and ossimNBandLutDataObject().
89 {
90  if(theLut)
91  {
92  delete [] theLut;
93  theLut = 0;
94  }
95  if(numberOfEntries&&numberOfBands)
96  {
97  theLut = new ossimNBandLutDataObject::LUT_ENTRY_TYPE[numberOfEntries*numberOfBands];
98  theNumberOfEntries = numberOfEntries;
99  theNumberOfBands = numberOfBands;
100  }
101  else
102  {
103  theNumberOfEntries = 0;
104  theNumberOfBands = 0;
105  }
106 }
◆ dup()
ossimObject* ossimNBandLutDataObject::dup ( ) const
inlinevirtual
Definition at line 275 of file ossimNBandLutDataObject.h.
Referenced by ossimGdalWriter::setLut(), and ossimTiffWriter::setLut().
276  {
277  return new ossimNBandLutDataObject(*this);
278  }
ossimNBandLutDataObject(ossim_uint32 numberOfEntries=0, ossim_uint32 numberOfBands=0, ossimScalarType bandScalarType=OSSIM_UINT8, ossim_int32 nullPixelIndex=-1)
◆ findIndex() [1/2]
ossim_uint32 ossimNBandLutDataObject::findIndex ( ossim_int32 values) const
Parameters
valuesIs an array of band values. This array must be equal to the number of bands for the lut.
Returns
Returns the nearest index to the passed in value.
Definition at line 108 of file ossimNBandLutDataObject.cpp.
References theNumberOfBands.
Referenced by ossimNBandToIndexFilter::convertInputTileToOutputTemplate().
110 {
111  return findIndex(bandValues, theNumberOfBands);
112 }
ossim_uint32 findIndex(ossim_int32 *values) const
◆ findIndex() [2/2]
ossim_uint32 ossimNBandLutDataObject::findIndex ( ossim_int32 values,
ossim_uint32  size
) const
Parameters
sizeSize of values array. Note if size is less than the LUT number of bands, the trailing bands get dropped. This allows finding an index dropping the alpha channel.
Returns
Definition at line 114 of file ossimNBandLutDataObject.cpp.
References DBL_EPSILON, distance(), size, theLut, theNumberOfBands, and theNumberOfEntries.
116 {
117  ossim_uint32 result = 0;
118
119  if ( (theNumberOfEntries > 0) && (size <= theNumberOfBands) )
120  {
122  ossim_uint32 idx = 0;
123  ossim_uint32 bandIdx = 0;
125
126  for(idx = 0; idx < theNumberOfEntries; ++idx,lutPtr+=theNumberOfBands)
127  {
128  ossim_float64 sumSquare = 0.0;
129
130  for(bandIdx = 0; bandIdx < size; ++bandIdx)
131  {
132  ossim_int64 delta = lutPtr[bandIdx] - bandValues[bandIdx];
133  sumSquare += (delta*delta);
134  }
135  if((ossimNBandLutDataObject::LUT_ENTRY_TYPE)sumSquare == 0)
136  {
137  return idx;
138  }
139  else if( sumSquare < distance)
140  {
141  result = idx;
142  distance = sumSquare;
143  }
144  }
145  }
146
147  return result;
148 }
double ossim_float64
yy_size_t size
unsigned int ossim_uint32
#define DBL_EPSILON
long long ossim_int64
float distance(double lat1, double lon1, double lat2, double lon2, int units)
◆ getEntryLabels()
std::vector< ossimString > ossimNBandLutDataObject::getEntryLabels ( ossim_uint32  band)
Definition at line 376 of file ossimNBandLutDataObject.cpp.
References m_entryLabels.
Referenced by ossimGdalWriter::writeColorMap().
377 {
378  std::map<ossim_uint32, std::vector<ossimString> >::iterator it = m_entryLabels.find(band);
379  if (it != m_entryLabels.end())
380  {
381  return it->second;
382  }
383  return std::vector<ossimString>();
384 }
◆ getFirstNullAlphaIndex()
ossim_int32 ossimNBandLutDataObject::getFirstNullAlphaIndex ( ) const
Returns
First index with alpha of 0 or -1 if not found or there is no alpha.
Currently only works on 4 band data. May consider adding an alpha channel class data member in the future.
Definition at line 189 of file ossimNBandLutDataObject.cpp.
Referenced by ossimGdalTileSource::setPreservePaletteIndexesFlag().
190 {
191  ossim_int32 result = -1;
192  if ( (theNumberOfBands == 4) && (theNumberOfEntries > 0) )
193  {
194  ossim_uint32 idx = 0;
195  LUT_ENTRY_TYPE* bandPtr = theLut+3; // Index to the first alpha channel.
196  for ( idx = 0; idx < theNumberOfEntries; ++idx, bandPtr+=theNumberOfBands )
197  {
198  if ( *bandPtr == 0 )
199  {
200  result = *bandPtr;
201  break;
202  }
203  }
204  }
205  return result;
206 }
int ossim_int32
◆ getMinMax()
void ossimNBandLutDataObject::getMinMax ( ossim_uint32  band,
ossimNBandLutDataObject::LUT_ENTRY_TYPE minValue,
ossimNBandLutDataObject::LUT_ENTRY_TYPE maxValue
Parameters
bandband number to query. This is 0 based so the first band is indicated by the value of 0.
minValueis the minimum value returned for the passed in band
maxValueis the maximum value returned for the passed in band
Definition at line 158 of file ossimNBandLutDataObject.cpp.
References theLut, theNullPixelIndex, theNumberOfBands, and theNumberOfEntries.
Referenced by ossimNBandToIndexFilter::initialize().
161 {
162  minValue = 0;
163  maxValue = 0;
164  ossim_uint32 idx = 0;
165  LUT_ENTRY_TYPE *bandPtr = theLut+band;
166  if((band < theNumberOfBands)&&
167  (theNumberOfEntries > 0))
168  {
169  minValue = theLut[band];
170  maxValue = theLut[band];
171
172  for(idx = 0; idx < theNumberOfEntries; ++idx,bandPtr+=theNumberOfBands)
173  {
174  if((ossim_int32)idx != theNullPixelIndex)
175  {
176  if(bandPtr[band] < minValue)
177  {
178  minValue = bandPtr[band];
179  }
180  if(bandPtr[band] > maxValue)
181  {
182  maxValue = bandPtr[band];
183  }
184  }
185  }
186  }
187 }
int ossim_int32
◆ getNullPixelIndex()
ossim_int32 ossimNBandLutDataObject::getNullPixelIndex ( ) const
inline
Returns
Return either a positive value indicating the entry designated for a null pixel value or a -1 to say no null pixel has been designated yet.
Definition at line 379 of file ossimNBandLutDataObject.h.
Referenced by ossimNBandToIndexFilter::getNullPixelValue(), ossimGdalTileSource::getNullPixelValue(), and ossimNBandToIndexFilter::initialize().
◆ getNumberOfBands()
ossim_uint32 ossimNBandLutDataObject::getNumberOfBands ( ) const
inline
◆ getNumberOfEntries()
ossim_uint32 ossimNBandLutDataObject::getNumberOfEntries ( ) const
inline
◆ hasNullPixelIndex()
bool ossimNBandLutDataObject::hasNullPixelIndex ( ) const
inline
Definition at line 342 of file ossimNBandLutDataObject.h.
343  {
344  return (theNullPixelIndex >= 0);
345  }
◆ loadState()
bool ossimNBandLutDataObject::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Parameters
kwlThe keywordlist to extract the classes keywords from to restore its state.
prefixOptional prefix value used to prefix each keyword.
Definition at line 299 of file ossimNBandLutDataObject.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), clearLut(), create(), ossimFilename::exists(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimLookUpTable::getEntryNumber(), ossimScalarTypeLut::instance(), ossimLookUpTable::NOT_FOUND, ossimKeywordNames::NULL_VALUE_KW, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_ENTRIES_KW, theBandScalarType, theLut, theNullPixelIndex, theNumberOfBands, theNumberOfEntries, ossimString::toInt32(), ossimString::toString(), and ossimString::trim().
Referenced by ossimNBandToIndexFilter::loadState(), open(), and ossimNBandToIndexFilter::setProperty().
300 {
301  const char* nullPixelIndex = kwl.find(prefix, ossimKeywordNames::NULL_VALUE_KW);
302  const char* lutFile = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
303  ossimKeywordlist fileLut;
304  const ossimKeywordlist* tempKwl = &kwl;
305  ossimString tempPrefix = prefix;
306
307  // check to see if we should open an external file
308  // if so point the fileLut to the one that we use
309  if(lutFile)
310  {
311  ossimFilename filename(lutFile);
312  if(filename.exists())
313  {
314  fileLut.addFile(filename.c_str());
315  tempKwl = &fileLut;
316  tempPrefix = "";
317  }
318  }
319
320  if(nullPixelIndex)
321  {
322  theNullPixelIndex = ossimString(nullPixelIndex).toInt32();
323  }
324  else
325  {
326  theNullPixelIndex = -1;
327  }
328  int scalar = ossimScalarTypeLut::instance()->getEntryNumber(kwl, prefix);
329
330  if (scalar != ossimLookUpTable::NOT_FOUND)
331  {
332  theBandScalarType = static_cast<ossimScalarType>(scalar);
333  }
334  const char* numberOfBands = tempKwl->find(tempPrefix, ossimKeywordNames::NUMBER_BANDS_KW);
335  const char* numberOfEntries = tempKwl->find(tempPrefix, ossimKeywordNames::NUMBER_ENTRIES_KW);
336
337  if (numberOfBands && numberOfEntries)
338  {
339  create(ossimString(numberOfEntries).toUInt32(),
340  ossimString(numberOfBands).toUInt32());
341  }
342
343  clearLut();
345
346  if(lutPtr)
347  {
348  ossim_uint32 entryIdx;
349  ossim_uint32 bandIdx;
350  for(entryIdx = 0; entryIdx < theNumberOfEntries; ++entryIdx)
351  {
352  ossimString newPrefix = "entry";
353  newPrefix += ossimString::toString(entryIdx);
354  ossimString v = tempKwl->find(tempPrefix, newPrefix.c_str());
355  v = v.trim();
356  if(v != "")
357  {
358  std::istringstream istr(v);
359  ossimString lutValue;
360  for(bandIdx = 0; bandIdx < theNumberOfBands; ++bandIdx)
361  {
362  if(!istr.fail())
363  {
364  istr >> lutValue;
365  lutPtr[bandIdx] = lutValue.toInt32();
366  }
367  }
368  }
369  lutPtr += theNumberOfBands;
370  }
371  }
372
373  return true;
374 }
bool addFile(const char *file)
static const char * NULL_VALUE_KW
Numeric to string methods.
static const char * NUMBER_ENTRIES_KW
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
ossim_int32 toInt32() const
void clearLut()
Will do a simple memset to &#39;\0&#39; all.
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
static const char * NUMBER_BANDS_KW
ossimScalarType
const char * c_str() const
Definition: ossimString.h:396
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
static const char * FILENAME_KW
◆ open()
bool ossimNBandLutDataObject::open ( const ossimFilename lutFile)
The external file is in a keywordlist format specified by the saveState.
Definition at line 291 of file ossimNBandLutDataObject.cpp.
References ossimKeywordlist::addFile(), and loadState().
Referenced by ossimGdalWriter::setProperty(), and ossimTiffWriter::setProperty().
292 {
293  ossimKeywordlist kwl;
294  kwl.addFile(lutFile);
295
296  return loadState(kwl);
297 }
◆ operator=()
const ossimNBandLutDataObject & ossimNBandLutDataObject::operator= ( const ossimNBandLutDataObject lut)
Parameters
lutThe lut to copy.
Definition at line 208 of file ossimNBandLutDataObject.cpp.
References create(), theBandScalarType, theLut, theNullPixelIndex, theNumberOfBands, and theNumberOfEntries.
209 {
211  {
212  delete [] theLut;
213  theLut = 0;
214  }
215
219  lut.theNumberOfBands);
220
221  if(theLut)
222  {
224  }
225
226  return *this;
227 }
◆ operator==()
bool ossimNBandLutDataObject::operator== ( const ossimNBandLutDataObject lut) const
Parameters
lutChecks equality of the this object to the lut parameter.
Returns
True if equal and false otherwise
Definition at line 229 of file ossimNBandLutDataObject.cpp.
References theBandScalarType, theLut, theNullPixelIndex, theNumberOfBands, and theNumberOfEntries.
230 {
232  {
233  return false;
234  }
235
236  if(!theLut && !lut.theLut) return true;
237  if(theNullPixelIndex != lut.theNullPixelIndex) return false;
238  if(theBandScalarType != lut.theBandScalarType) return false;
239
240  if(theLut&&lut.theLut)
241  {
243  }
244  return false;
245 }
◆ operator[]() [1/6]
const LUT_ENTRY_TYPE* ossimNBandLutDataObject::operator[] ( ossim_uint32  idx) const
inline
Definition at line 281 of file ossimNBandLutDataObject.h.
282  {
283  if(theLut)
284  {
285  return &theLut[idx*theNumberOfBands];
286  }
287
288  return 0;
289  }
◆ operator[]() [2/6]
inline
Definition at line 290 of file ossimNBandLutDataObject.h.
291  {
292  if(theLut)
293  {
294  return &theLut[idx*theNumberOfBands];
295  }
296
297  return 0;
298  }
◆ operator[]() [3/6]
const LUT_ENTRY_TYPE* ossimNBandLutDataObject::operator[] ( ossim_int32  idx) const
inline
Definition at line 299 of file ossimNBandLutDataObject.h.
300  {
301  if(theLut)
302  {
303  return &theLut[idx*theNumberOfBands];
304  }
305
306  return 0;
307  }
◆ operator[]() [4/6]
inline
Definition at line 308 of file ossimNBandLutDataObject.h.
309  {
310  if(theLut)
311  {
312  return &theLut[idx*theNumberOfBands];
313  }
314
315  return 0;
316  }
◆ operator[]() [5/6]
const LUT_ENTRY_TYPE* ossimNBandLutDataObject::operator[] ( double  normalizedIndex) const
inline
Definition at line 317 of file ossimNBandLutDataObject.h.
318  {
319  int idx = int(normalizedIndex*theNumberOfEntries);
320  if (idx < 0)
321  {
322  idx = 0;
323  }
324  return (*this)[idx];
325  }
◆ operator[]() [6/6]
inline
Parameters
normalizedIndexIf a double precision value is passed in then it is assumed to be in normalized space where the value ranges from 0.0 to 1.0
Returns
the starting address of the band values.
Definition at line 332 of file ossimNBandLutDataObject.h.
333  {
334  ossim_uint32 idx = int(normalizedIndex*(theNumberOfEntries-1));
335  if (idx >= theNumberOfEntries)
336  {
337  idx = theNumberOfEntries-1;
338  }
339  return (*this)[idx];
340  }
◆ saveState()
bool ossimNBandLutDataObject::saveState ( ossimKeywordlist kwl,
) const
virtual
Keywords:
entry0:
entry1:
entry<number_entries-1>:
null_value:  -1
number_bands:  3
number_entries:  216
Where entry<idx> is repeasted for each entry number where idx start from 0 and goes to number_entries-1
each entry must have number_bands values.
Parameters
kwlThe keyword list to store the keywords to. Each keyword could be prefixed by an optional prefix parameter.
prefixThe optional prefix parameter used to prefix each keyword.
Definition at line 247 of file ossimNBandLutDataObject.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordNames::ENTRY_KW, ossimObject::getClassName(), ossimScalarTypeLut::instance(), ossimKeywordNames::NULL_VALUE_KW, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_ENTRIES_KW, ossimKeywordNames::SCALAR_TYPE_KW, theBandScalarType, theLut, theNullPixelIndex, theNumberOfBands, theNumberOfEntries, ossimString::toString(), and ossimKeywordNames::TYPE_KW.
Referenced by ossimInfo::getImagePalette(), and ossimNBandToIndexFilter::saveState().
248 {
249  kwl.add(prefix,
251  getClassName(),
252  true);
253  kwl.add(prefix,
256  true);
257  kwl.add(prefix,
260  true);
261  kwl.add(prefix,
264  true);
265  kwl.add(prefix,
268  true);
269
271  for(ossim_uint32 idx = 0; idx < theNumberOfEntries; ++idx, lutPtr+=theNumberOfBands)
272  {
274  newPrefix += ossimString::toString(idx);
275  std::ostringstream ostr;
276  ossim_uint32 bandIdx = 0;
277  for(bandIdx = 0; bandIdx < theNumberOfBands; ++bandIdx)
278  {
279  ostr << lutPtr[bandIdx]
280  << " ";
281  }
282  kwl.add(prefix,
283  newPrefix,
284  ostr.str().c_str(),
285  true);
286  }
287
288  return true;
289 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
static const char * TYPE_KW
static const char * ENTRY_KW
static const char * SCALAR_TYPE_KW
◆ setEntryLables()
void ossimNBandLutDataObject::setEntryLables ( ossim_uint32  band,
std::vector< ossimString entryLabels
Definition at line 386 of file ossimNBandLutDataObject.cpp.
Referenced by ossimGdalTileSource::populateLut().
387 {
388  m_entryLabels[band] = entryLabels;
389 }
◆ setNullPixelIndex()
void ossimNBandLutDataObject::setNullPixelIndex ( ossim_int32  idx)
inline
Note: setting this to -1 indicates no null entry is set.
Parameters
idxis the entry number that will be used for the null value
Definition at line 372 of file ossimNBandLutDataObject.h.
Referenced by ossimGdalTileSource::populateLut(), and ossimGdalTileSource::setPreservePaletteIndexesFlag().
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
friend
Definition at line 23 of file ossimNBandLutDataObject.cpp.
25 {
26  if(lut.theLut)
27  {
29  << lut.theNumberOfEntries << std::endl;
31  << lut.theNumberOfBands << std::endl;
32  out << "null_pixel_index: " << lut.theNullPixelIndex << std::endl;
33  for(ossim_uint32 idx = 0; idx < lut.theNumberOfEntries; ++idx)
34  {
35  const ossimNBandLutDataObject::LUT_ENTRY_TYPE *bandPtr =lut[idx];
36  ossim_uint32 bandIdx = 0;
37  out << ossimKeywordNames::ENTRY_KW << idx << ": ";
38  for(bandIdx = 0; bandIdx < lut.theNumberOfBands; ++bandIdx)
39  {
40  out << bandPtr[bandIdx] << " ";
41  }
42  if(idx < (lut.theNumberOfEntries-1))
43  {
44  out << std::endl;
45  }
46  }
47  }
48  return out;
49 }
Member Data Documentation
◆ m_entryLabels
std::map<ossim_uint32, std::vector<ossimString> > ossimNBandLutDataObject::m_entryLabels
protected
◆ theBandScalarType
ossimScalarType ossimNBandLutDataObject::theBandScalarType
protected
Definition at line 482 of file ossimNBandLutDataObject.h.
Referenced by loadState(), operator=(), operator==(), and saveState().
◆ theLut
LUT_ENTRY_TYPE* ossimNBandLutDataObject::theLut
protected
◆ theNullPixelIndex
ossim_int32 ossimNBandLutDataObject::theNullPixelIndex
protected
◆ theNumberOfBands
ossim_uint32 ossimNBandLutDataObject::theNumberOfBands
protected
◆ theNumberOfEntries
ossim_uint32 ossimNBandLutDataObject::theNumberOfEntries
protected
