9 #ifndef ossimRgbImage_HEADER 10 #define ossimRgbImage_HEADER 46 virtual void initialize();
104 void drawFilledPolygon(
const std::vector<ossimDpt>& p);
109 void drawFilledPolygon(
const std::vector<ossimIpt>& p);
132 void drawArc(
double cx,
159 void drawFilledEllipse(
int cx,
169 void drawEllipse(
int cx,
174 bool drawAxes =
false);
180 void drawFilledArc(
double cx,
191 void drawFilledArc(
int cx,
198 void drawPolygon(
199 void drawPolygon(
222 void drawLine(
double x1,
232 void drawLine(
int x1,
242 void drawLine(
const ossimIpt& start,
249 void drawLine(
const ossimDpt& start,
256 void drawRectangle(
double x1,
264 void drawRectangle(
int x1,
273 void drawFilledRectangle(
double x1,
282 void drawFilledRectangle(
int x1,
ossim_uint8 theGreen
The green component of the color used in drawing the shapes.
ossimReferenced allows for shared object ref counting if the reference count ever gets to 0 or less i...
ossim_int32 theThickness
Holds the draw thickness.
ossim_int32 theWidth
This is here so we don't have to call theWidth and theHeight of the ossimImageData.
ossim_int32 theHeight
ossimRefPtr< ossimImageData > theImageData
This object operates on the ossimImageData.
void slowPlotPixel(ossim_int32 x, ossim_int32 y, ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
This will plot a pixel and will do inside outside compares.
os2<< "> n<< " > nendobj n
ossim_uint8 * theBands[3]
This is a fast access to the start of each band.
ossim_uint8 theRed
The red component of the color used in drawing the shapes.
ossim_uint8 theBlue
The blue component of the color used in drawing the shapes.
ossim_int32 * theOffsets
This will hold precomputed offsets to the start of each row.
void fastPlotPixel(ossim_int32 x, ossim_int32 y, ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
same thing as slowPlotPixel but without the inside outside compare
unsigned char ossim_uint8
