ossimRtti.cpp
Go to the documentation of this file.
1
2 #include <iostream>
3 #include <cstring>
4 #include <cstdlib>
5 #include <algorithm>
6 #include <iostream>
7 using namespace std;
8
9 #include <ossim/base/ossimRtti.h>
10
11 static const RTTITypeinfo* RTTI_base_null_type[] = { 0 };
12
13 const RTTITypeinfo* RTTIdyntypeid::a[] = { 0 };
14
15 const RTTITypeinfo RTTITypeinfo::null_type = RTTITypeinfo("NULL", RTTI_base_null_type,0,0);
16
17 void RTTITypeinfo::add_subtype(const RTTITypeinfo* t) //Adds t as last RTTITypeinfo in the
18 {
19  subtypes.push_back(t);
20  ns = subtypes.size();
21  //'subtypes' list. For this, the
22 /* const RTTITypeinfo** ptr = new const RTTITypeinfo*[ns+1]; //list is realloc'd with one extra entry.
23  int i; for(i=0;i<ns;i++) ptr[i] = subtypes[i];
24  ptr[i] = t;
25  ns++;
26  delete[] subtypes;
27  subtypes = ptr;
28  */
29 }
30
31 void RTTITypeinfo::del_subtype(const RTTITypeinfo* t) //Searches for t in the subtypes list
32 {
33  if ( subtypes.size() > 0 )
34  {
35  SubtypesConstVector::iterator iter = std::find(subtypes.begin(), subtypes.end(), t);
36  if(iter != subtypes.end())
37  {
38  subtypes.erase(iter);
39
40  // "ns" is private member of RTTITypeinfo
41  ns = subtypes.size();
42  }
43  }
44
45  //of this and removes it, if found.
46
47 // int i; for(i=0;i<ns && subtypes[i]!=t;i++);
48 // if (i<ns)
49 // for(;i<ns-1;i++) subtypes[i] = subtypes[i+1];
50 }
51
52 RTTITypeinfo::RTTITypeinfo(const char* name,
53  const RTTITypeinfo* bb[],
54  void* (*f1)(int,void*),
55  void* (*f2)())
56 {
57  n = "";
58  if(name) n = name;
59  b = bb; //ns = 0; subtypes = 0; //Create default RTTITypeinfo
60  cast = f1; //Attach casting func
61  new_obj = f2; //Attach creation func
62  int i = 0;
63  for(i=0;b[i];i++) //Add this as subtype to all its basetypes
64  ((RTTITypeinfo**)b)[i]->add_subtype(this); //REMARK: Harmless const castaway
65 }
66
67 const char* RTTITypeinfo::getname() const
68 {
69  return n.c_str();
70 }
71
72
74 {
75 // if(n)
76 // {
77 // free(n);
78 // n = NULL;
79 // }
80  int i = 0;
81  for(i=0;b[i];i++)
82  {
83  //Del this subtype from all its basetypes
84  ((RTTITypeinfo**)b)[i]->del_subtype(this); //REMARK: Harmless const castaway
85  }
86 }
87
89 {
90  int i = 0;
91  for(i=0;b[i];i++) //for all bases of this...
92  if (p->same(b[i]) || b[i]->has_base(p)) return 1; //match found, return 1 or no match, search deeper
93  return 0; //no match at all, return 0
94 }
95
96 void* RTTITypeinfo::create(const RTTITypeinfo* bt, const char* c) const //Tries to create an obj of type-name
97 { //given by char*. Searches for this type in the
98  void* p = 0; int i; //type-DAG rooted by this, creates it and returns
99  //it as cast to 'bt', where bt is either this or a
100  //direct base of this.
101  if (!strcmp(c,getname())) //Want to create an obj of this type ?
102  p = (new_obj)? new_obj() : 0; //Yes, do it if this type is instantiable.
103  else //No, try with subclasses...
104  for(i=0;i<ns && !((p=subtypes[i]->create(this,c)));i++); //Succeeded creating on ith subclass branch ?
105  if (!p) return 0; //Couldn't create it in any way, abort.
106  if (bt==this) i = -1; //Must cast to this's own type (i==-1)
107  else for(i=0;b[i] && b[i]!=bt;i++); //Search to which base of this we should cast
108  //Found: cast to ith base of this
109  return cast(i,p); //Cast to ith base of to this, return as void*
110 }
111
113 {
114  if(strcmp(name, getname())==0)
115  {
116  return *this;
117  }
118  else if(num_baseclasses() == 0)
119  {
120  if(strcmp(name, getname()) == 0)
121  {
122  return *this;
123  }
124  return null_type();
125  }
126  else
127  {
128  int index = 0;
129
130  while(index < num_baseclasses())
131  {
132  RTTItypeid typeId = baseclass(index);
133  if(typeId == *this)
134  {
135  return *this;//null_type();
136  }
137  if(strcmp(name, typeId.getname()) == 0)
138  {
139  return *this;
140  }
141  ++index;
142  }
143  index = 0;
144  while(index < num_baseclasses())
145  {
146  RTTItypeid typeId = baseclass(index);
147  if(typeId.find_baseclass(name) == typeId.null_type())
148  {
149  ++index;
150  }
151  else
152  {
153  return typeId;
154  }
155  }
156  }
157  return null_type();
158 }
void * create(const RTTITypeinfo *, const char *) const
Definition: ossimRtti.cpp:96
int same(const RTTITypeinfo *) const
Definition: ossimRtti.h:219
RTTITypeinfo(const char *name, const RTTITypeinfo *bb[], void *(*)(int, void *), void *(*)())
Definition: ossimRtti.cpp:52
static const RTTITypeinfo null_type
Definition: ossimRtti.h:195
void del_subtype(const RTTITypeinfo *)
Definition: ossimRtti.cpp:31
os2<< "> n<< " > nendobj n
static const RTTITypeinfo * a[]
Definition: ossimRtti.h:160
const char * getname() const
Definition: ossimRtti.h:265
void add_subtype(const RTTITypeinfo *)
Definition: ossimRtti.cpp:17
RTTItypeid find_baseclass(const char *name) const
Definition: ossimRtti.cpp:112
int has_base(const RTTITypeinfo *) const
Definition: ossimRtti.cpp:88
static RTTItypeid null_type()
Definition: ossimRtti.h:240
Definition: ossimRtti.cpp:67
