14 os << dynamic_cast<const ossimGpt&>(*this);
20 os << std::setiosflags(std::ios::fixed) << std::setprecision(15);
32 os << std::setiosflags(std::ios::fixed) << std::setprecision(15);
82 is.get(tempChars, SZ,
84 tempChars[SZ-1] =
'\0';
85 tempString = tempChars;
87 if (tempString ==
"nan")
93 pt.
score = tempString.toDouble();
126 if (aGmlVersion[static_cast<std::string::size_type>(0)] ==
'2')
128 node->
setTag(
"SimpleTiePoint");
165 if (aGmlVersion[static_cast<std::string::size_type>(0)] ==
'2')
void setTag(const ossimString &tag)
double lond() const
Will convert the radian measure to degrees.
double nan()
Numeric to string methods.
std::ostream & print(std::ostream &os) const
text serialization
ossimDpt tie
Public data members.
ossimRefPtr< ossimXmlNode > addNode(const ossimString &relPath, const ossimString &text="")
const ossimRefPtr< ossimXmlNode > & findFirstNode(const ossimString &rel_xpath) const
double latd() const
const ossimDatum * datum() const
datum().
bool importFromGmlNode(ossimRefPtr< ossimXmlNode > aGmlNode, ossimString aGmlVersion="2.1.2")
const ossimString & getText() const
const char * COORDINATES_GML2
std::istream & operator>>(std::istream &is, ossimTieGpt &pt)
std::ostream & printTab(std::ostream &os) const
static ossimDatumFactory * instance()
ossimRefPtr< ossimXmlNode > exportAsGmlNode(ossimString aGmlVersion="2.1.2") const
GML feauture (XML) serialization.
storage class for tie point between ground and image based on ossimGpt
std::basic_istream< char > istream
Base class for char input streams.
std::ostream & operator<<(std::ostream &os, const ossimTieGpt &pt)
void addChildNode(ossimRefPtr< ossimXmlNode > node)
std::basic_ostream< char > ostream
Base class for char output streams.
bool isnan(const float &v)
