18 #ifndef ossimGpt_HEADER 19 #define ossimGpt_HEADER 1 81 void lonr(
double radianValue)
87 double latd()
const{
return lat;}
92 void latd(
double degreeValue){lat = degreeValue;}
97 double lond()
const{
return lon;}
102 void lond(
double degreeValue){lon = degreeValue; }
114 double heightMSL()
const;
128 void heightMSL(
double heightMSL);
173 void toPoint(
const std::string& s);
220 {
if (lon <= -180.0) lon += 360.0;
else if (lon > 180.0) lon -= 360.0; }
230 if(lon < low) lon = low;
231 if(lon > high) lon = high;
236 if(lat < low) lat = low;
237 if(lat > high) lat = high;
242 if(hgt < low) hgt = low;
243 if(hgt > high) hgt = high;
250 double distanceTo(
const ossimGpt& arg_gpt)
const;
258 double azimuthTo(
const;
312 }
while (
lon > 180.0 );
314 else if (
lon < -180.0 )
319 }
while (
lon < -180.0 );
328 }
while (
lat > 360.0);
339 else if (
lat < -90.0 )
346 }
while (
lat < -360.0);
352 else if (
lat < -90.0 )
void datum(const ossimDatum *aDatum)
Note: this will not do a shift.
const ossimGpt & operator=(const ossimGpt &aPt)
ossimGpt(const ossimDpt3d &aPt)
Argument aPt (x, y, z) is understood to represent (lon, lat, hgt) relative to WGS84 datum...
void lond(double degreeValue)
Assumes the passed in value is in degrees.
bool operator!=(const ossimRefPtr< _Tp1 > &__a, const ossimRefPtr< _Tp2 > &__b) noexcept
double lond() const
Will convert the radian measure to degrees.
const ossimDatum * theDatum
Know reference location plus an implied ellipsoid.
void latd(double degreeValue)
double nan()
void clampLon(double low, double high)
void clampHgt(double low, double high)
ossim_float64 hgt
Height in meters above the ellipsiod.
std::ostream & print(H5::H5File *file, std::ostream &out)
Print method.
double latd() const
void wrap()
Wrap method to maintain longitude between -180 and +180 and latitude between -90 and +90...
void limitLonTo180()
METHOD: limitLonTo180() Converts the lon data member to a value between -180 and +180: ...
const ossimDatum * datum() const
datum().
ostream & operator<<(ostream &out, const ossimAxes &axes)
double lonr() const
Returns the longitude in radian measure.
unsigned int ossim_uint32
static ossimDatumFactory * instance()
void clampLat(double low, double high)
bool operator==(const ossimRefPtr< _Tp1 > &__a, const ossimRefPtr< _Tp2 > &__b) noexcept
void lonr(double radianValue)
Assumes the value being passed in is in radians.
std::basic_istream< char > istream
Base class for char input streams.
double latr() const
latr().
void latr(double radianValue)
Returns the latitude in radian measure.
ossimGpt(const double alat=0, const double alon=0, const double ahgt=0, const ossimDatum *aDatum=ossimDatumFactory::instance() ->wgs84())
Constructor.
void height(double height)
Sets the "hgt" data member to height.
const ossimDatum * wgs84() const
OSSIM_DLL void operator>>(ossimIStream &in, ossimOStream &out)
std::basic_ostream< char > ostream
Base class for char output streams.
bool isnan(const float &v)
