precisio.h
Go to the documentation of this file.
1 //$$ precisio.h floating point constants
2
3 #ifndef PRECISION_LIB
4 #define PRECISION_LIB 0
5
6 #include <cmath>
7 #include <limits>
8
9
10 #ifdef use_namespace
11 namespace NEWMAT {
12 #endif
13
14 #ifdef _STANDARD_ // standard library available
15
16 using namespace std;
17
18 class FloatingPointPrecision
19 {
20 public:
21  static int Dig() // number of decimal digits or precision
22  { return numeric_limits<Real>::digits10 ; }
23
24  static Real Epsilon() // smallest number such that 1+Eps!=Eps
25  { return numeric_limits<Real>::epsilon(); }
26
27  static int Mantissa() // bits in mantisa
28  { return numeric_limits<Real>::digits; }
29
30  static Real Maximum() // maximum value
31  { return numeric_limits<Real>::max(); }
32
33  static int MaximumDecimalExponent() // maximum decimal exponent
34  { return numeric_limits<Real>::max_exponent10; }
35
36  static int MaximumExponent() // maximum binary exponent
37  { return numeric_limits<Real>::max_exponent; }
38
39  static Real LnMaximum() // natural log of maximum
40  { return (Real)std::log(Maximum()); }
41
42  static Real Minimum() // minimum positive value
43  { return numeric_limits<Real>::min(); }
44
45  static int MinimumDecimalExponent() // minimum decimal exponent
46  { return numeric_limits<Real>::min_exponent10; }
47
48  static int MinimumExponent() // minimum binary exponent
49  { return numeric_limits<Real>::min_exponent; }
50
51  static Real LnMinimum() // natural log of minimum
52  { return (Real)std::log(Minimum()); }
53
54  static int Radix() // exponent radix
55  { return numeric_limits<Real>::radix; }
56
57  static int Rounds() // addition rounding (1 = does round)
58  {
59  return numeric_limits<Real>::round_style ==
60  round_to_nearest ? 1 : 0;
61  }
62
63 };
64
65
66 #else // _STANDARD_ not defined
67
68 #ifndef SystemV // if there is float.h
69
70
71 #ifdef USING_FLOAT
72
73
74 class FloatingPointPrecision
75 {
76 public:
77  static int Dig()
78  { return FLT_DIG; } // number of decimal digits or precision
79
80  static Real Epsilon()
81  { return FLT_EPSILON; } // smallest number such that 1+Eps!=Eps
82
83  static int Mantissa()
84  { return FLT_MANT_DIG; } // bits in mantisa
85
86  static Real Maximum()
87  { return FLT_MAX; } // maximum value
88
89  static int MaximumDecimalExponent()
90  { return FLT_MAX_10_EXP; } // maximum decimal exponent
91
92  static int MaximumExponent()
93  { return FLT_MAX_EXP; } // maximum binary exponent
94
95  static Real LnMaximum()
96  { return (Real)std::log(Maximum()); } // natural log of maximum
97
98  static Real Minimum()
99  { return FLT_MIN; } // minimum positive value
100
101  static int MinimumDecimalExponent()
102  { return FLT_MIN_10_EXP; } // minimum decimal exponent
103
104  static int MinimumExponent()
105  { return FLT_MIN_EXP; } // minimum binary exponent
106
107  static Real LnMinimum()
108  { return (Real)std::log(Minimum()); } // natural log of minimum
109
110  static int Radix()
111  { return FLT_RADIX; } // exponent radix
112
113  static int Rounds()
114  { return FLT_ROUNDS; } // addition rounding (1 = does round)
115
116 };
117
118 #endif // USING_FLOAT
119
120
121 #ifdef USING_DOUBLE
122
123 class FloatingPointPrecision
124 {
125 public:
126
127  static int Dig()
128  { return DBL_DIG; } // number of decimal digits or precision
129
130  static Real Epsilon()
131  { return DBL_EPSILON; } // smallest number such that 1+Eps!=Eps
132
133  static int Mantissa()
134  { return DBL_MANT_DIG; } // bits in mantisa
135
136  static Real Maximum()
137  { return DBL_MAX; } // maximum value
138
139  static int MaximumDecimalExponent()
140  { return DBL_MAX_10_EXP; } // maximum decimal exponent
141
142  static int MaximumExponent()
143  { return DBL_MAX_EXP; } // maximum binary exponent
144
145  static Real LnMaximum()
146  { return (Real)std::log(Maximum()); } // natural log of maximum
147
148  static Real Minimum()
149  {
150 //#ifdef __BCPLUSPLUS__
151 // return 2.225074e-308; // minimum positive value
152 //#else
153  return DBL_MIN;
154 //#endif
155  }
156
157  static int MinimumDecimalExponent()
158  { return DBL_MIN_10_EXP; } // minimum decimal exponent
159
160  static int MinimumExponent()
161  { return DBL_MIN_EXP; } // minimum binary exponent
162
163  static Real LnMinimum()
164  { return (Real)std::log(Minimum()); } // natural log of minimum
165
166
167  static int Radix()
168  { return FLT_RADIX; } // exponent radix
169
170  static int Rounds()
171  { return FLT_ROUNDS; } // addition rounding (1 = does round)
172
173 };
174
175 #endif // USING_DOUBLE
176
177 #else // if there is no float.h
178
179 #ifdef USING_FLOAT
180
181 class FloatingPointPrecision
182 {
183 public:
184
185  static Real Epsilon()
186  { return pow(2.0,(int)(1-FSIGNIF)); }
187  // smallest number such that 1+Eps!=Eps
188
189  static Real Maximum()
190  { return MAXFLOAT; } // maximum value
191
192  static Real LnMaximum()
193  { return (Real)std::log(Maximum()); } // natural log of maximum
194
195  static Real Minimum()
196  { return MINFLOAT; } // minimum positive value
197
198  static Real LnMinimum()
199  { return (Real)std::log(Minimum()); } // natural log of minimum
200
201 };
202
203 #endif // USING_FLOAT
204
205
206 #ifdef USING_DOUBLE
207
208 class FloatingPointPrecision
209 {
210 public:
211
212  static Real Epsilon()
213  { return pow(2.0,(int)(1-DSIGNIF)); }
214  // smallest number such that 1+Eps!=Eps
215
216  static Real Maximum()
217  { return MAXDOUBLE; } // maximum value
218
219  static Real LnMaximum()
220  { return LN_MAXDOUBLE; } // natural log of maximum
221
222  static Real Minimum()
223  { return MINDOUBLE; }
224
225  static Real LnMinimum()
226  { return LN_MINDOUBLE; } // natural log of minimum
227 };
228
229 #endif // USING_DOUBLE
230
231 #endif // SystemV
232
233 #endif // _STANDARD_
234
235 #ifdef use_namespace
236 }
237 #endif // use_namespace
238
239
240
241 #endif // PRECISION_LIB
#define MINFLOAT
Definition: values.h:77
double Real
Definition: include.h:57
#define MAXDOUBLE
Definition: values.h:74
Real Maximum(const BaseMatrix &B)
Definition: newmat.h:1766
#define MINDOUBLE
Definition: values.h:76
#define FLT_EPSILON
#define FLT_MIN
#define DBL_EPSILON
#define MAXFLOAT
Definition: values.h:75
#define max(a, b)
Definition: auxiliary.h:76
#define FLT_MAX
Real Minimum(const BaseMatrix &B)
Definition: newmat.h:1767
#define min(a, b)
Definition: auxiliary.h:75
