Go to the source code of this file.
void | set_projection_parameters (double cm, double origin, double r, int projection) |
double | central_meridian (double xmin, double xmax) |
void | set_plate_carree_parameters (double cm, double origin, double r) |
void | pcarree_xy (double *x, double *y) |
void | pcarree_latlon (double *x, double *y) |
void | set_tm_parameters (double cm, double origin, double r) |
void | tm_xy (double *x, double *y) |
void | tm_latlon (double *x, double *y) |
void | set_lambert_parameters (double cm, double origin, double r) |
void | lambert_xy (double *x, double *y) |
void | lambert_latlon (double *x, double *y) |
void | set_gnomonic_parameters (double cm, double origin, double r) |
void | gnomonic_xy (double *x, double *y) |
void | gnomonic_latlon (double *x, double *y) |
◆ GNOMONIC
◆ LAMBERT_EQUAL_AREA
#define LAMBERT_EQUAL_AREA 2 |
◆ NO_PROJECTION
◆ PLATE_CARREE
◆ TRANSVERSE_MERCATOR
#define TRANSVERSE_MERCATOR 1 |
◆ central_meridian()
double central_meridian |
double |
xmin, |
double |
xmax |
◆ gnomonic_latlon()
void gnomonic_latlon |
double * |
x, |
double * |
y |
◆ gnomonic_xy()
void gnomonic_xy |
double * |
x, |
double * |
y |
◆ lambert_latlon()
void lambert_latlon |
double * |
x, |
double * |
y |
◆ lambert_xy()
void lambert_xy |
double * |
x, |
double * |
y |
◆ pcarree_latlon()
void pcarree_latlon |
double * |
x, |
double * |
y |
◆ pcarree_xy()
void pcarree_xy |
double * |
x, |
double * |
y |
◆ set_gnomonic_parameters()
void set_gnomonic_parameters |
double |
cm, |
double |
origin, |
double |
r |
◆ set_lambert_parameters()
void set_lambert_parameters |
double |
cm, |
double |
origin, |
double |
r |
◆ set_plate_carree_parameters()
void set_plate_carree_parameters |
double |
cm, |
double |
origin, |
double |
r |
◆ set_projection_parameters()
void set_projection_parameters |
double |
cm, |
double |
origin, |
double |
r, |
int |
projection |
◆ set_tm_parameters()
void set_tm_parameters |
double |
cm, |
double |
origin, |
double |
r |
◆ tm_latlon()
void tm_latlon |
double * |
x, |
double * |
y |
◆ tm_xy()
void tm_xy |
double * |
x, |
double * |
y |
