Classes | Macros | Functions
set.h File Reference
#include <stdio.h>
Go to the source code of this file.
Classes
struct  set_type
Macros
#define SET_ON(set)   memset(set.buf,255,(set.size>>3L)+1L)
#define SET_OFF(set)   memset(set.buf,0,(set.size>>3L)+1L)
Functions
set_type set_init (long int n)
int set_empty (set_type set)
void set_insert (long int element, set_type set)
void set_delete (long int element, set_type set)
int set_member (long int element, set_type set)
long int set_min (set_type set)
long int set_max (set_type set)
long int num_in_set (set_type set)
void set_on (set_type set)
void set_off (set_type set)
int set_equal (set_type a, set_type b)
void set_assign (set_type *a, set_type b)
set_type set_union (set_type a, set_type b)
set_type set_intersection (set_type a, set_type b)
set_type set_difference (set_type a, set_type b)
void set_nuke (set_type *set)
Macro Definition Documentation
◆ SET_OFF
#define SET_OFF (   set)    memset(set.buf,0,(set.size>>3L)+1L)
Definition at line 45 of file set.h.
◆ SET_ON
#define SET_ON (   set)    memset(set.buf,255,(set.size>>3L)+1L)
Definition at line 44 of file set.h.
Function Documentation
◆ num_in_set()
long int num_in_set ( set_type  set)
◆ set_assign()
void set_assign ( set_type a,
set_type  b
◆ set_delete()
void set_delete ( long int  element,
set_type  set
◆ set_difference()
set_type set_difference ( set_type  a,
set_type  b
◆ set_empty()
int set_empty ( set_type  set)
◆ set_equal()
int set_equal ( set_type  a,
set_type  b
◆ set_init()
set_type set_init ( long int  n)
◆ set_insert()
void set_insert ( long int  element,
set_type  set
◆ set_intersection()
set_type set_intersection ( set_type  a,
set_type  b
◆ set_max()
long int set_max ( set_type  set)
◆ set_member()
int set_member ( long int  element,
set_type  set
◆ set_min()
long int set_min ( set_type  set)
◆ set_nuke()
void set_nuke ( set_type set)
◆ set_off()
void set_off ( set_type  set)
◆ set_on()
void set_on ( set_type  set)
◆ set_union()
set_type set_union ( set_type  a,
set_type  b
