shapefil.h
Go to the documentation of this file.
1 #ifndef _SHAPEFILE_H_INCLUDED
2 #define _SHAPEFILE_H_INCLUDED
3
4 /******************************************************************************
5  * $Id: shapefil.h 13274 2007-12-06 14:00:51Z warmerdam $
6  *
7  * Project: Shapelib
8  * Purpose: Primary include file for Shapelib.
9  * Author: Frank Warmerdam, warmerdam@pobox.com
10  *
11  ******************************************************************************
12  * Copyright (c) 1999, Frank Warmerdam
13  *
14  * This software is available under the following "MIT Style" license,
15  * or at the option of the licensee under the LGPL (see LICENSE.LGPL). This
16  * option is discussed in more detail in shapelib.html.
17  *
18  * --
19  *
20  * Permission is hereby granted, free of charge, to any person obtaining a
21  * copy of this software and associated documentation files (the "Software"),
22  * to deal in the Software without restriction, including without limitation
23  * the rights to use, copy, modify, merge, publish, distribute, sublicense,
24  * and/or sell copies of the Software, and to permit persons to whom the
25  * Software is furnished to do so, subject to the following conditions:
26  *
27  * The above copyright notice and this permission notice shall be included
28  * in all copies or substantial portions of the Software.
29  *
30  * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
31  * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
32  * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
33  * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
34  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
35  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
36  * DEALINGS IN THE SOFTWARE.
37  ******************************************************************************
38  *
39  * $Log: shapefil.h,v $
40  * Revision 1.40 2007/12/06 07:00:25 fwarmerdam
41  * dbfopen now using SAHooks for fileio
42  *
43  * Revision 1.39 2007/12/04 20:37:56 fwarmerdam
44  * preliminary implementation of hooks api for io and errors
45  *
46  * Revision 1.38 2007/11/21 22:39:56 fwarmerdam
47  * close shx file in readonly mode (GDAL #1956)
48  *
49  * Revision 1.37 2007/10/27 03:31:14 fwarmerdam
50  * limit default depth of tree to 12 levels (gdal ticket #1594)
51  *
52  * Revision 1.36 2007/09/10 23:33:15 fwarmerdam
53  * Upstreamed support for visibility flag in SHPAPI_CALL for the needs
54  * of GDAL (gdal ticket #1810).
55  *
56  * Revision 1.35 2007/09/03 19:48:10 fwarmerdam
57  * move DBFReadAttribute() static dDoubleField into dbfinfo
58  *
59  * Revision 1.34 2006/06/17 15:33:32 fwarmerdam
60  * added pszWorkField - bug 1202 (rso)
61  *
62  * Revision 1.33 2006/02/15 01:14:30 fwarmerdam
63  * added DBFAddNativeFieldType
64  *
65  * Revision 1.32 2006/01/26 15:07:32 fwarmerdam
66  * add bMeasureIsUsed flag from Craig Bruce: Bug 1249
67  *
68  * Revision 1.31 2006/01/05 01:27:27 fwarmerdam
69  * added dbf deletion mark/fetch
70  *
71  * Revision 1.30 2005/01/03 22:30:13 fwarmerdam
72  * added support for saved quadtrees
73  *
74  * Revision 1.29 2004/09/26 20:09:35 fwarmerdam
75  * avoid rcsid warnings
76  *
77  * Revision 1.28 2003/12/29 06:02:18 fwarmerdam
78  * added cpl_error.h option
79  *
80  * Revision 1.27 2003/04/21 18:30:37 warmerda
81  * added header write/update public methods
82  *
83  * Revision 1.26 2002/09/29 00:00:08 warmerda
84  * added FTLogical and logical attribute read/write calls
85  *
86  * Revision 1.25 2002/05/07 13:46:30 warmerda
87  * added DBFWriteAttributeDirectly().
88  *
89  * Revision 1.24 2002/04/10 16:59:54 warmerda
90  * added SHPRewindObject
91  *
92  * Revision 1.23 2002/01/15 14:36:07 warmerda
93  * updated email address
94  *
95  * Revision 1.22 2002/01/15 14:32:00 warmerda
96  * try to improve SHPAPI_CALL docs
97  */
98
99 #include <stdio.h>
100
101 #ifdef USE_DBMALLOC
102 #include <dbmalloc.h>
103 #endif
104
105 #ifdef USE_CPL
106 #include "cpl_error.h"
107 #include "cpl_vsi.h"
108 #endif
109
110 #ifdef __cplusplus
111 extern "C" {
112 #endif
113
114 /************************************************************************/
115 /* Configuration options. */
116 /************************************************************************/
117
118 /* -------------------------------------------------------------------- */
119 /* Should the DBFReadStringAttribute() strip leading and */
120 /* trailing white space? */
121 /* -------------------------------------------------------------------- */
122 #define TRIM_DBF_WHITESPACE
123
124 /* -------------------------------------------------------------------- */
125 /* Should we write measure values to the Multipatch object? */
126 /* Reportedly ArcView crashes if we do write it, so for now it */
127 /* is disabled. */
128 /* -------------------------------------------------------------------- */
129 #define DISABLE_MULTIPATCH_MEASURE
130
131 /* -------------------------------------------------------------------- */
132 /* SHPAPI_CALL */
133 /* */
134 /* The following two macros are present to allow forcing */
135 /* various calling conventions on the Shapelib API. */
136 /* */
137 /* To force __stdcall conventions (needed to call Shapelib */
138 /* from Visual Basic and/or Dephi I believe) the makefile could */
139 /* be modified to define: */
140 /* */
141 /* /DSHPAPI_CALL=__stdcall */
142 /* */
143 /* If it is desired to force export of the Shapelib API without */
144 /* using the shapelib.def file, use the following definition. */
145 /* */
146 /* /DSHAPELIB_DLLEXPORT */
147 /* */
148 /* To get both at once it will be necessary to hack this */
149 /* include file to define: */
150 /* */
151 /* #define SHPAPI_CALL __declspec(dllexport) __stdcall */
152 /* #define SHPAPI_CALL1 __declspec(dllexport) * __stdcall */
153 /* */
154 /* The complexity of the situtation is partly caused by the */
155 /* peculiar requirement of Visual C++ that __stdcall appear */
156 /* after any "*"'s in the return value of a function while the */
157 /* __declspec(dllexport) must appear before them. */
158 /* -------------------------------------------------------------------- */
159
160 #ifdef SHAPELIB_DLLEXPORT
161 # define SHPAPI_CALL __declspec(dllexport)
162 # define SHPAPI_CALL1(x) __declspec(dllexport) x
163 #endif
164
165 #ifndef SHPAPI_CALL
166 # if defined(USE_GCC_VISIBILITY_FLAG)
167 # define SHPAPI_CALL __attribute__ ((visibility("default")))
168 # define SHPAPI_CALL1(x) __attribute__ ((visibility("default"))) x
169 # else
170 # define SHPAPI_CALL
171 # endif
172 #endif
173
174 #ifndef SHPAPI_CALL1
175 # define SHPAPI_CALL1(x) x SHPAPI_CALL
176 #endif
177
178 /* -------------------------------------------------------------------- */
179 /* Macros for controlling CVSID and ensuring they don't appear */
180 /* as unreferenced variables resulting in lots of warnings. */
181 /* -------------------------------------------------------------------- */
182 #ifndef DISABLE_CVSID
183 # define SHP_CVSID(string) static char cpl_cvsid[] = string; \
184 static char *cvsid_aw() { return( cvsid_aw() ? ((char *) NULL) : cpl_cvsid ); }
185 #else
186 # define SHP_CVSID(string)
187 #endif
188
189 /* -------------------------------------------------------------------- */
190 /* IO/Error hook functions. */
191 /* -------------------------------------------------------------------- */
192 typedef int *SAFile;
193
194 #ifndef SAOffset
195 typedef unsigned long SAOffset;
196 #endif
197
198 typedef struct {
199  SAFile (*FOpen) ( const char *filename, const char *path);
200  SAOffset (*FRead) ( void *p, SAOffset size, SAOffset nmemb, SAFile file);
201  SAOffset (*FWrite)( void *p, SAOffset size, SAOffset nmemb, SAFile file);
202  SAOffset (*FSeek) ( SAFile file, SAOffset offset, int whence );
203  SAOffset (*FTell) ( SAFile file );
204  int (*FFlush)( SAFile file );
205  int (*FClose)( SAFile file );
206
207  void (*Error) ( const char *message );
208 } SAHooks;
209
210 void SHPAPI_CALL SASetupDefaultHooks( SAHooks *psHooks );
211
212 /************************************************************************/
213 /* SHP Support. */
214 /************************************************************************/
215 typedef struct
216 {
218
221
222  int nShapeType; /* SHPT_* */
223
224  int nFileSize; /* SHP file */
225
226  int nRecords;
230
231  double adBoundsMin[4];
232  double adBoundsMax[4];
233
234  int bUpdated;
235
236  unsigned char *pabyRec;
237  int nBufSize;
238 } SHPInfo;
239
240 typedef SHPInfo * SHPHandle;
241
242 /* -------------------------------------------------------------------- */
243 /* Shape types (nSHPType) */
244 /* -------------------------------------------------------------------- */
245 #define SHPT_NULL 0
246 #define SHPT_POINT 1
247 #define SHPT_ARC 3
248 #define SHPT_POLYGON 5
249 #define SHPT_MULTIPOINT 8
250 #define SHPT_POINTZ 11
251 #define SHPT_ARCZ 13
252 #define SHPT_POLYGONZ 15
253 #define SHPT_MULTIPOINTZ 18
254 #define SHPT_POINTM 21
255 #define SHPT_ARCM 23
256 #define SHPT_POLYGONM 25
257 #define SHPT_MULTIPOINTM 28
258 #define SHPT_MULTIPATCH 31
259
260
261 /* -------------------------------------------------------------------- */
262 /* Part types - everything but SHPT_MULTIPATCH just uses */
263 /* SHPP_RING. */
264 /* -------------------------------------------------------------------- */
265
266 #define SHPP_TRISTRIP 0
267 #define SHPP_TRIFAN 1
268 #define SHPP_OUTERRING 2
269 #define SHPP_INNERRING 3
270 #define SHPP_FIRSTRING 4
271 #define SHPP_RING 5
272
273 /* -------------------------------------------------------------------- */
274 /* SHPObject - represents on shape (without attributes) read */
275 /* from the .shp file. */
276 /* -------------------------------------------------------------------- */
277 typedef struct
278 {
279  int nSHPType;
280
281  int nShapeId; /* -1 is unknown/unassigned */
282
283  int nParts;
286
288  double *padfX;
289  double *padfY;
290  double *padfZ;
291  double *padfM;
292
293  double dfXMin;
294  double dfYMin;
295  double dfZMin;
296  double dfMMin;
297
298  double dfXMax;
299  double dfYMax;
300  double dfZMax;
301  double dfMMax;
302
304 } SHPObject;
305
306 /* -------------------------------------------------------------------- */
307 /* SHP API Prototypes */
308 /* -------------------------------------------------------------------- */
309
310 /* If pszAccess is read-only, the fpSHX field of the returned structure */
311 /* will be NULL as it is not necessary to keep the SHX file open */
313  SHPOpen( const char * pszShapeFile, const char * pszAccess );
315  SHPOpenLL( const char *pszShapeFile, const char *pszAccess,
316  SAHooks *psHooks );
318  SHPCreate( const char * pszShapeFile, int nShapeType );
320  SHPCreateLL( const char * pszShapeFile, int nShapeType,
321  SAHooks *psHooks );
322 void SHPAPI_CALL
323  SHPGetInfo( SHPHandle hSHP, int * pnEntities, int * pnShapeType,
324  double * padfMinBound, double * padfMaxBound );
325
327  SHPReadObject( SHPHandle hSHP, int iShape );
328 int SHPAPI_CALL
329  SHPWriteObject( SHPHandle hSHP, int iShape, SHPObject * psObject );
330
331 void SHPAPI_CALL
332  SHPDestroyObject( SHPObject * psObject );
333 void SHPAPI_CALL
334  SHPComputeExtents( SHPObject * psObject );
336  SHPCreateObject( int nSHPType, int nShapeId, int nParts,
337  const int * panPartStart, const int * panPartType,
338  int nVertices,
339  const double * padfX, const double * padfY,
340  const double * padfZ, const double * padfM );
342  SHPCreateSimpleObject( int nSHPType, int nVertices,
343  const double * padfX,
344  const double * padfY,
345  const double * padfZ );
346
347 int SHPAPI_CALL
348  SHPRewindObject( SHPHandle hSHP, SHPObject * psObject );
349
350 void SHPAPI_CALL SHPClose( SHPHandle hSHP );
352
353 const char SHPAPI_CALL1(*)
354  SHPTypeName( int nSHPType );
355 const char SHPAPI_CALL1(*)
356  SHPPartTypeName( int nPartType );
357
358 /* -------------------------------------------------------------------- */
359 /* Shape quadtree indexing API. */
360 /* -------------------------------------------------------------------- */
361
362 /* this can be two or four for binary or quad tree */
363 #define MAX_SUBNODE 4
364
365 /* upper limit of tree levels for automatic estimation */
366 #define MAX_DEFAULT_TREE_DEPTH 12
367
368 typedef struct shape_tree_node
369 {
370  /* region covered by this node */
371  double adfBoundsMin[4];
372  double adfBoundsMax[4];
373
374  /* list of shapes stored at this node. The papsShapeObj pointers
375  or the whole list can be NULL */
379
382
383 } SHPTreeNode;
384
385 typedef struct
386 {
388
392
394 } SHPTree;
395
397  SHPCreateTree( SHPHandle hSHP, int nDimension, int nMaxDepth,
398  double *padfBoundsMin, double *padfBoundsMax );
399 void SHPAPI_CALL
400  SHPDestroyTree( SHPTree * hTree );
401
402 int SHPAPI_CALL
403  SHPWriteTree( SHPTree *hTree, const char * pszFilename );
405  SHPReadTree( const char * pszFilename );
406
407 int SHPAPI_CALL
408  SHPTreeAddObject( SHPTree * hTree, SHPObject * psObject );
409 int SHPAPI_CALL
410  SHPTreeAddShapeId( SHPTree * hTree, SHPObject * psObject );
411 int SHPAPI_CALL
412  SHPTreeRemoveShapeId( SHPTree * hTree, int nShapeId );
413
414 void SHPAPI_CALL
415  SHPTreeTrimExtraNodes( SHPTree * hTree );
416
417 int SHPAPI_CALL1(*)
419  double * padfBoundsMin,
420  double * padfBoundsMax,
421  int * );
422 int SHPAPI_CALL
423  SHPCheckBoundsOverlap( double *, double *, double *, double *, int );
424
425 int SHPAPI_CALL1(*)
426 SHPSearchDiskTree( FILE *fp,
427  double *padfBoundsMin, double *padfBoundsMax,
428  int *pnShapeCount );
429
430 /************************************************************************/
431 /* DBF Support. */
432 /************************************************************************/
433 typedef struct
434 {
435  SAHooks sHooks;
436
437  SAFile fp;
438
439  int nRecords;
440
441  int nRecordLength;
442  int nHeaderLength;
443  int nFields;
444  int *panFieldOffset;
445  int *panFieldSize;
446  int *panFieldDecimals;
447  char *pachFieldType;
448
449  char *pszHeader;
450
451  int nCurrentRecord;
452  int bCurrentRecordModified;
453  char *pszCurrentRecord;
454
455  int nWorkFieldLength;
456  char *pszWorkField;
457
458  int bNoHeader;
459  int bUpdated;
460
461  double dfDoubleField;
462 } DBFInfo;
463
464 typedef DBFInfo * DBFHandle;
465
466 typedef enum {
467  FTString,
468  FTInteger,
469  FTDouble,
470  FTLogical,
471  FTInvalid
472 } DBFFieldType;
473
474 #define XBASE_FLDHDR_SZ 32
475
476
477 DBFHandle SHPAPI_CALL
478  DBFOpen( const char * pszDBFFile, const char * pszAccess );
479 DBFHandle SHPAPI_CALL
480  DBFOpenLL( const char * pszDBFFile, const char * pszAccess,
481  SAHooks *psHooks );
482 DBFHandle SHPAPI_CALL
483  DBFCreate( const char * pszDBFFile );
484 DBFHandle SHPAPI_CALL
485  DBFCreateLL( const char * pszDBFFile, SAHooks *psHooks );
486
487 int SHPAPI_CALL
488  DBFGetFieldCount( DBFHandle psDBF );
489 int SHPAPI_CALL
490  DBFGetRecordCount( DBFHandle psDBF );
491 int SHPAPI_CALL
492  DBFAddField( DBFHandle hDBF, const char * pszFieldName,
493  DBFFieldType eType, int nWidth, int nDecimals );
494
495 int SHPAPI_CALL
496  DBFAddNativeFieldType( DBFHandle hDBF, const char * pszFieldName,
497  char chType, int nWidth, int nDecimals );
498
499 DBFFieldType SHPAPI_CALL
500  DBFGetFieldInfo( DBFHandle psDBF, int iField,
501  char * pszFieldName, int * pnWidth, int * pnDecimals );
502
503 int SHPAPI_CALL
504  DBFGetFieldIndex(DBFHandle psDBF, const char *pszFieldName);
505
506 int SHPAPI_CALL
507  DBFReadIntegerAttribute( DBFHandle hDBF, int iShape, int iField );
508 double SHPAPI_CALL
509  DBFReadDoubleAttribute( DBFHandle hDBF, int iShape, int iField );
510 const char SHPAPI_CALL1(*)
511  DBFReadStringAttribute( DBFHandle hDBF, int iShape, int iField );
512 const char SHPAPI_CALL1(*)
513  DBFReadLogicalAttribute( DBFHandle hDBF, int iShape, int iField );
514 int SHPAPI_CALL
515  DBFIsAttributeNULL( DBFHandle hDBF, int iShape, int iField );
516
517 int SHPAPI_CALL
518  DBFWriteIntegerAttribute( DBFHandle hDBF, int iShape, int iField,
519  int nFieldValue );
520 int SHPAPI_CALL
521  DBFWriteDoubleAttribute( DBFHandle hDBF, int iShape, int iField,
522  double dFieldValue );
523 int SHPAPI_CALL
524  DBFWriteStringAttribute( DBFHandle hDBF, int iShape, int iField,
525  const char * pszFieldValue );
526 int SHPAPI_CALL
527  DBFWriteNULLAttribute( DBFHandle hDBF, int iShape, int iField );
528
529 int SHPAPI_CALL
530  DBFWriteLogicalAttribute( DBFHandle hDBF, int iShape, int iField,
531  const char lFieldValue);
532 int SHPAPI_CALL
533  DBFWriteAttributeDirectly(DBFHandle psDBF, int hEntity, int iField,
534  void * pValue );
535 const char SHPAPI_CALL1(*)
536  DBFReadTuple(DBFHandle psDBF, int hEntity );
537 int SHPAPI_CALL
538  DBFWriteTuple(DBFHandle psDBF, int hEntity, void * pRawTuple );
539
540 int SHPAPI_CALL DBFIsRecordDeleted( DBFHandle psDBF, int iShape );
541 int SHPAPI_CALL DBFMarkRecordDeleted( DBFHandle psDBF, int iShape,
542  int bIsDeleted );
543
544 DBFHandle SHPAPI_CALL
545  DBFCloneEmpty(DBFHandle psDBF, const char * pszFilename );
546
547 void SHPAPI_CALL
548  DBFClose( DBFHandle hDBF );
549 void SHPAPI_CALL
550  DBFUpdateHeader( DBFHandle hDBF );
551 char SHPAPI_CALL
552  DBFGetNativeFieldType( DBFHandle hDBF, int iField );
553
554 #ifdef __cplusplus
555 }
556 #endif
557
558 #endif /* ndef _SHAPEFILE_H_INCLUDED */
#define SHPAPI_CALL
Definition: shapefil.h:170
Definition: shapefil.h:371
double * padfZ
Definition: shapefil.h:290
DBFFieldType SHPAPI_CALL DBFGetFieldInfo(DBFHandle psDBF, int iField, char *pszFieldName, int *pnWidth, int *pnDecimals)
DBFHandle SHPAPI_CALL DBFCreateLL(const char *pszDBFFile, SAHooks *psHooks)
int SHPAPI_CALL DBFWriteIntegerAttribute(DBFHandle hDBF, int iShape, int iField, int nFieldValue)
int bUpdated
Definition: shapefil.h:234
double dfZMin
Definition: shapefil.h:295
int SHPAPI_CALL DBFGetFieldCount(DBFHandle psDBF)
void SHPAPI_CALL SHPComputeExtents(SHPObject *psObject)
struct shape_tree_node SHPTreeNode
void SHPAPI_CALL SHPTreeTrimExtraNodes(SHPTree *hTree)
int nSHPType
Definition: shapefil.h:279
#define MAX_SUBNODE
Definition: shapefil.h:363
int SHPAPI_CALL DBFIsRecordDeleted(DBFHandle psDBF, int iShape)
int SHPAPI_CALL SHPRewindObject(SHPHandle hSHP, SHPObject *psObject)
char SHPAPI_CALL DBFGetNativeFieldType(DBFHandle hDBF, int iField)
void SHPAPI_CALL DBFClose(DBFHandle hDBF)
Definition: shapefil.h:372
DBFHandle SHPAPI_CALL DBFCloneEmpty(DBFHandle psDBF, const char *pszFilename)
Definition: shapefil.h:195
void SHPAPI_CALL SHPGetInfo(SHPHandle hSHP, int *pnEntities, int *pnShapeType, double *padfMinBound, double *padfMaxBound)
int SHPAPI_CALL DBFWriteNULLAttribute(DBFHandle hDBF, int iShape, int iField)
int * SAFile
Definition: shapefil.h:192
double dfYMax
Definition: shapefil.h:299
SHPObject ** papsShapeObj
Definition: shapefil.h:378
double dfZMax
Definition: shapefil.h:300
int nParts
Definition: shapefil.h:283
int nShapeType
Definition: shapefil.h:222
int nBufSize
Definition: shapefil.h:237
void SHPAPI_CALL SHPClose(SHPHandle hSHP)
double dfXMax
Definition: shapefil.h:298
int SHPAPI_CALL SHPTreeAddShapeId(SHPTree *hTree, SHPObject *psObject)
#define SHPAPI_CALL1(x)
Definition: shapefil.h:175
int * panPartType
Definition: shapefil.h:285
int SHPAPI_CALL DBFGetFieldIndex(DBFHandle psDBF, const char *pszFieldName)
double * padfY
Definition: shapefil.h:289
int SHPAPI_CALL DBFWriteStringAttribute(DBFHandle hDBF, int iShape, int iField, const char *pszFieldValue)
int SHPAPI_CALL1 * SHPTreeFindLikelyShapes(SHPTree *hTree, double *padfBoundsMin, double *padfBoundsMax, int *);int SHPAPI_CALL SHPCheckBoundsOverlap(double *, double *, double *, double *, int
int * panRecSize
Definition: shapefil.h:229
SHPTreeNode * psRoot
Definition: shapefil.h:393
int nVertices
Definition: shapefil.h:287
SAHooks sHooks
Definition: shapefil.h:217
double SHPAPI_CALL DBFReadDoubleAttribute(DBFHandle hDBF, int iShape, int iField)
SHPTree SHPAPI_CALL1 * SHPCreateTree(SHPHandle hSHP, int nDimension, int nMaxDepth, double *padfBoundsMin, double *padfBoundsMax);void SHPAPI_CALL SHPDestroyTree(SHPTree *hTree
yy_size_t size
SHPHandle hSHP
Definition: shapefil.h:387
int SHPAPI_CALL DBFReadIntegerAttribute(DBFHandle hDBF, int iShape, int iField)
SHPHandle SHPAPI_CALL SHPOpenLL(const char *pszShapeFile, const char *pszAccess, SAHooks *psHooks)
SAFile fpSHX
Definition: shapefil.h:220
double dfMMax
Definition: shapefil.h:301
SAFile fpSHP
Definition: shapefil.h:219
int nDimension
Definition: shapefil.h:390
SHPHandle SHPAPI_CALL SHPCreate(const char *pszShapeFile, int nShapeType)
int SHPAPI_CALL DBFWriteAttributeDirectly(DBFHandle psDBF, int hEntity, int iField, void *pValue)
SHPObject SHPAPI_CALL1 * SHPReadObject(SHPHandle hSHP, int iShape);int SHPAPI_CALL SHPWriteObject(SHPHandle hSHP, int iShape, SHPObject *psObject
int SHPAPI_CALL DBFWriteLogicalAttribute(DBFHandle hDBF, int iShape, int iField, const char lFieldValue)
SHPTree SHPAPI_CALL SHPReadTree(const char *pszFilename)
double dfXMin
Definition: shapefil.h:293
int * panPartStart
Definition: shapefil.h:284
const char SHPAPI_CALL1 * DBFReadTuple(DBFHandle psDBF, int hEntity);int SHPAPI_CALL DBFWriteTuple(DBFHandle psDBF, int hEntity, void *pRawTuple
int nFileSize
Definition: shapefil.h:224
double * padfM
Definition: shapefil.h:291
int SHPAPI_CALL SHPTreeRemoveShapeId(SHPTree *hTree, int nShapeId)
double dfMMin
Definition: shapefil.h:296
int SHPAPI_CALL DBFGetRecordCount(DBFHandle psDBF)
unsigned char * pabyRec
Definition: shapefil.h:236
struct shape_tree_node * apsSubNode[MAX_SUBNODE]
Definition: shapefil.h:381
int SHPAPI_CALL DBFIsAttributeNULL(DBFHandle hDBF, int iShape, int iField)
void SHPAPI_CALL DBFUpdateHeader(DBFHandle hDBF)
int SHPAPI_CALL DBFAddField(DBFHandle hDBF, const char *pszFieldName, DBFFieldType eType, int nWidth, int nDecimals)
DBFHandle SHPAPI_CALL DBFCreate(const char *pszDBFFile)
SHPHandle SHPAPI_CALL SHPCreateLL(const char *pszShapeFile, int nShapeType, SAHooks *psHooks)
double * padfX
Definition: shapefil.h:288
double dfYMin
Definition: shapefil.h:294
int * panRecOffset
Definition: shapefil.h:228
SHPObject SHPAPI_CALL1 * SHPCreateObject(int nSHPType, int nShapeId, int nParts, const int *panPartStart, const int *panPartType, int nVertices, const double *padfX, const double *padfY, const double *padfZ, const double *padfM);SHPObject SHPAPI_CALL1(*) SHPCreateSimpleObject(int nSHPType, int nVertices, const double *padfX, const double *padfY, const double *padfZ
int nMaxRecords
Definition: shapefil.h:227
DBFHandle SHPAPI_CALL DBFOpenLL(const char *pszDBFFile, const char *pszAccess, SAHooks *psHooks)
SHPHandle SHPAPI_CALL SHPOpen(const char *pszShapeFile, const char *pszAccess)
void SHPAPI_CALL SHPWriteHeader(SHPHandle hSHP)
int SHPAPI_CALL DBFWriteDoubleAttribute(DBFHandle hDBF, int iShape, int iField, double dFieldValue)
int SHPAPI_CALL SHPWriteTree(SHPTree *hTree, const char *pszFilename)
int nTotalCount
Definition: shapefil.h:391
int * panShapeIds
Definition: shapefil.h:377
int bMeasureIsUsed
Definition: shapefil.h:303
int nMaxDepth
Definition: shapefil.h:389
int SHPAPI_CALL DBFAddNativeFieldType(DBFHandle hDBF, const char *pszFieldName, char chType, int nWidth, int nDecimals)
void SHPAPI_CALL SHPDestroyObject(SHPObject *psObject)
int SHPAPI_CALL1 * SHPSearchDiskTree(FILE *fp, double *padfBoundsMin, double *padfBoundsMax, int *pnShapeCount);typedef struct{ SAHooks sHooks;SAFile fp;int nRecords;int nRecordLength;int nHeaderLength;int nFields;int *panFieldOffset;int *panFieldSize;int *panFieldDecimals;char *pachFieldType;char *pszHeader;int nCurrentRecord;int bCurrentRecordModified;char *pszCurrentRecord;int nWorkFieldLength;char *pszWorkField;int bNoHeader;int bUpdated;double dfDoubleField;} DBFInfo;typedef DBFInfo *DBFHandle;typedef enum { FTString, FTInteger, FTDouble, FTLogical, FTInvalid} DBFFieldType;#define XBASE_FLDHDR_SZDBFHandle SHPAPI_CALL DBFOpen(const char *pszDBFFile, const char *pszAccess
int nRecords
Definition: shapefil.h:226
int SHPAPI_CALL SHPTreeAddObject(SHPTree *hTree, SHPObject *psObject)
void SHPAPI_CALL SASetupDefaultHooks(SAHooks *psHooks)
const char SHPAPI_CALL1 * DBFReadStringAttribute(DBFHandle hDBF, int iShape, int iField);const char SHPAPI_CALL1(*) DBFReadLogicalAttribute(DBFHandle hDBF, int iShape, int iField
SHPInfo * SHPHandle
Definition: shapefil.h:240
int nShapeId
Definition: shapefil.h:281
int SHPAPI_CALL DBFMarkRecordDeleted(DBFHandle psDBF, int iShape, int bIsDeleted)
const char SHPAPI_CALL1 * SHPTypeName(int nSHPType);const char SHPAPI_CALL1(*) SHPPartTypeName(int nPartType
