Classes | Macros | Typedefs | Functions
shapefil.h File Reference
#include <stdio.h>
Go to the source code of this file.
Classes
struct  SAHooks
struct  SHPInfo
struct  SHPObject
struct  shape_tree_node
struct  SHPTree
Macros
#define TRIM_DBF_WHITESPACE
#define DISABLE_MULTIPATCH_MEASURE
#define SHPAPI_CALL
#define SHPAPI_CALL1(x)   x SHPAPI_CALL
#define SHP_CVSID(string)
#define SHPT_NULL   0
#define SHPT_POINT   1
#define SHPT_ARC   3
#define SHPT_POLYGON   5
#define SHPT_MULTIPOINT   8
#define SHPT_POINTZ   11
#define SHPT_ARCZ   13
#define SHPT_POLYGONZ   15
#define SHPT_MULTIPOINTZ   18
#define SHPT_POINTM   21
#define SHPT_ARCM   23
#define SHPT_POLYGONM   25
#define SHPT_MULTIPOINTM   28
#define SHPT_MULTIPATCH   31
#define SHPP_TRISTRIP   0
#define SHPP_TRIFAN   1
#define SHPP_OUTERRING   2
#define SHPP_INNERRING   3
#define SHPP_FIRSTRING   4
#define SHPP_RING   5
#define MAX_SUBNODE   4
#define MAX_DEFAULT_TREE_DEPTH   12
#define XBASE_FLDHDR_SZ   32
Typedefs
typedef int * SAFile
typedef unsigned long SAOffset
typedef SHPInfoSHPHandle
typedef struct shape_tree_node SHPTreeNode
Functions
void SHPAPI_CALL SASetupDefaultHooks (SAHooks *psHooks)
SHPHandle SHPAPI_CALL SHPOpen (const char *pszShapeFile, const char *pszAccess)
SHPHandle SHPAPI_CALL SHPOpenLL (const char *pszShapeFile, const char *pszAccess, SAHooks *psHooks)
SHPHandle SHPAPI_CALL SHPCreate (const char *pszShapeFile, int nShapeType)
SHPHandle SHPAPI_CALL SHPCreateLL (const char *pszShapeFile, int nShapeType, SAHooks *psHooks)
void SHPAPI_CALL SHPGetInfo (SHPHandle hSHP, int *pnEntities, int *pnShapeType, double *padfMinBound, double *padfMaxBound)
SHPObject SHPAPI_CALL1SHPReadObject (SHPHandle hSHP, int iShape);int SHPAPI_CALL SHPWriteObject(SHPHandle hSHP, int iShape, SHPObject *psObject
void SHPAPI_CALL SHPDestroyObject (SHPObject *psObject)
void SHPAPI_CALL SHPComputeExtents (SHPObject *psObject)
SHPObject SHPAPI_CALL1SHPCreateObject (int nSHPType, int nShapeId, int nParts, const int *panPartStart, const int *panPartType, int nVertices, const double *padfX, const double *padfY, const double *padfZ, const double *padfM);SHPObject SHPAPI_CALL1(*) SHPCreateSimpleObject(int nSHPType, int nVertices, const double *padfX, const double *padfY, const double *padfZ
int SHPAPI_CALL SHPRewindObject (SHPHandle hSHP, SHPObject *psObject)
void SHPAPI_CALL SHPClose (SHPHandle hSHP)
void SHPAPI_CALL SHPWriteHeader (SHPHandle hSHP)
const char SHPAPI_CALL1SHPTypeName (int nSHPType);const char SHPAPI_CALL1(*) SHPPartTypeName(int nPartType
SHPTree SHPAPI_CALL1SHPCreateTree (SHPHandle hSHP, int nDimension, int nMaxDepth, double *padfBoundsMin, double *padfBoundsMax);void SHPAPI_CALL SHPDestroyTree(SHPTree *hTree
int SHPAPI_CALL SHPWriteTree (SHPTree *hTree, const char *pszFilename)
SHPTree SHPAPI_CALL SHPReadTree (const char *pszFilename)
int SHPAPI_CALL SHPTreeAddObject (SHPTree *hTree, SHPObject *psObject)
int SHPAPI_CALL SHPTreeAddShapeId (SHPTree *hTree, SHPObject *psObject)
int SHPAPI_CALL SHPTreeRemoveShapeId (SHPTree *hTree, int nShapeId)
void SHPAPI_CALL SHPTreeTrimExtraNodes (SHPTree *hTree)
int SHPAPI_CALL1SHPTreeFindLikelyShapes (SHPTree *hTree, double *padfBoundsMin, double *padfBoundsMax, int *);int SHPAPI_CALL SHPCheckBoundsOverlap(double *, double *, double *, double *, int
int SHPAPI_CALL1SHPSearchDiskTree (FILE *fp, double *padfBoundsMin, double *padfBoundsMax, int *pnShapeCount);typedef struct{ SAHooks sHooks;SAFile fp;int nRecords;int nRecordLength;int nHeaderLength;int nFields;int *panFieldOffset;int *panFieldSize;int *panFieldDecimals;char *pachFieldType;char *pszHeader;int nCurrentRecord;int bCurrentRecordModified;char *pszCurrentRecord;int nWorkFieldLength;char *pszWorkField;int bNoHeader;int bUpdated;double dfDoubleField;} DBFInfo;typedef DBFInfo *DBFHandle;typedef enum { FTString, FTInteger, FTDouble, FTLogical, FTInvalid} DBFFieldType;#define XBASE_FLDHDR_SZDBFHandle SHPAPI_CALL DBFOpen(const char *pszDBFFile, const char *pszAccess
DBFHandle SHPAPI_CALL DBFOpenLL (const char *pszDBFFile, const char *pszAccess, SAHooks *psHooks)
DBFHandle SHPAPI_CALL DBFCreate (const char *pszDBFFile)
DBFHandle SHPAPI_CALL DBFCreateLL (const char *pszDBFFile, SAHooks *psHooks)
int SHPAPI_CALL DBFGetFieldCount (DBFHandle psDBF)
int SHPAPI_CALL DBFGetRecordCount (DBFHandle psDBF)
int SHPAPI_CALL DBFAddField (DBFHandle hDBF, const char *pszFieldName, DBFFieldType eType, int nWidth, int nDecimals)
int SHPAPI_CALL DBFAddNativeFieldType (DBFHandle hDBF, const char *pszFieldName, char chType, int nWidth, int nDecimals)
DBFFieldType SHPAPI_CALL DBFGetFieldInfo (DBFHandle psDBF, int iField, char *pszFieldName, int *pnWidth, int *pnDecimals)
int SHPAPI_CALL DBFGetFieldIndex (DBFHandle psDBF, const char *pszFieldName)
int SHPAPI_CALL DBFReadIntegerAttribute (DBFHandle hDBF, int iShape, int iField)
double SHPAPI_CALL DBFReadDoubleAttribute (DBFHandle hDBF, int iShape, int iField)
const char SHPAPI_CALL1DBFReadStringAttribute (DBFHandle hDBF, int iShape, int iField);const char SHPAPI_CALL1(*) DBFReadLogicalAttribute(DBFHandle hDBF, int iShape, int iField
int SHPAPI_CALL DBFIsAttributeNULL (DBFHandle hDBF, int iShape, int iField)
int SHPAPI_CALL DBFWriteIntegerAttribute (DBFHandle hDBF, int iShape, int iField, int nFieldValue)
int SHPAPI_CALL DBFWriteDoubleAttribute (DBFHandle hDBF, int iShape, int iField, double dFieldValue)
int SHPAPI_CALL DBFWriteStringAttribute (DBFHandle hDBF, int iShape, int iField, const char *pszFieldValue)
int SHPAPI_CALL DBFWriteNULLAttribute (DBFHandle hDBF, int iShape, int iField)
int SHPAPI_CALL DBFWriteLogicalAttribute (DBFHandle hDBF, int iShape, int iField, const char lFieldValue)
int SHPAPI_CALL DBFWriteAttributeDirectly (DBFHandle psDBF, int hEntity, int iField, void *pValue)
const char SHPAPI_CALL1DBFReadTuple (DBFHandle psDBF, int hEntity);int SHPAPI_CALL DBFWriteTuple(DBFHandle psDBF, int hEntity, void *pRawTuple
int SHPAPI_CALL DBFIsRecordDeleted (DBFHandle psDBF, int iShape)
int SHPAPI_CALL DBFMarkRecordDeleted (DBFHandle psDBF, int iShape, int bIsDeleted)
DBFHandle SHPAPI_CALL DBFCloneEmpty (DBFHandle psDBF, const char *pszFilename)
void SHPAPI_CALL DBFClose (DBFHandle hDBF)
void SHPAPI_CALL DBFUpdateHeader (DBFHandle hDBF)
char SHPAPI_CALL DBFGetNativeFieldType (DBFHandle hDBF, int iField)
Macro Definition Documentation
◆ DISABLE_MULTIPATCH_MEASURE
Definition at line 129 of file shapefil.h.
◆ MAX_DEFAULT_TREE_DEPTH
Definition at line 366 of file shapefil.h.
◆ MAX_SUBNODE
Definition at line 363 of file shapefil.h.
◆ SHP_CVSID
#define SHP_CVSID (   string)
Value:
static char cpl_cvsid[] = string; \
static char *cvsid_aw() { return( cvsid_aw() ? ((char *) NULL) : cpl_cvsid ); }
Definition at line 183 of file shapefil.h.
◆ SHPAPI_CALL
#define SHPAPI_CALL
Definition at line 170 of file shapefil.h.
◆ SHPAPI_CALL1
#define SHPAPI_CALL1 (   x)    x SHPAPI_CALL
Definition at line 175 of file shapefil.h.
◆ SHPP_FIRSTRING
Definition at line 270 of file shapefil.h.
◆ SHPP_INNERRING
Definition at line 269 of file shapefil.h.
Referenced by ossimShapeObject::getPartByName().
◆ SHPP_OUTERRING
Definition at line 268 of file shapefil.h.
◆ SHPP_RING
#define SHPP_RING   5
◆ SHPP_TRIFAN
Definition at line 267 of file shapefil.h.
◆ SHPP_TRISTRIP
Definition at line 266 of file shapefil.h.
◆ SHPT_ARC
#define SHPT_ARC   3
Definition at line 247 of file shapefil.h.
Referenced by ossimEsriShapeFileFilter::loadShapeFile().
◆ SHPT_ARCM
Definition at line 255 of file shapefil.h.
◆ SHPT_ARCZ
Definition at line 251 of file shapefil.h.
◆ SHPT_MULTIPATCH
Definition at line 258 of file shapefil.h.
◆ SHPT_MULTIPOINT
Definition at line 249 of file shapefil.h.
◆ SHPT_MULTIPOINTM
Definition at line 257 of file shapefil.h.
◆ SHPT_MULTIPOINTZ
Definition at line 253 of file shapefil.h.
◆ SHPT_NULL
#define SHPT_NULL   0
◆ SHPT_POINT
Definition at line 246 of file shapefil.h.
◆ SHPT_POINTM
Definition at line 254 of file shapefil.h.
◆ SHPT_POINTZ
Definition at line 250 of file shapefil.h.
◆ SHPT_POLYGON
Definition at line 248 of file shapefil.h.
◆ SHPT_POLYGONM
Definition at line 256 of file shapefil.h.
◆ SHPT_POLYGONZ
Definition at line 252 of file shapefil.h.
◆ TRIM_DBF_WHITESPACE
Definition at line 122 of file shapefil.h.
◆ XBASE_FLDHDR_SZ
Typedef Documentation
◆ SAFile
typedef int* SAFile
Definition at line 192 of file shapefil.h.
◆ SAOffset
Definition at line 195 of file shapefil.h.
◆ SHPHandle
typedef SHPInfo* SHPHandle
Definition at line 240 of file shapefil.h.
◆ SHPTreeNode
Function Documentation
◆ DBFAddField()
int SHPAPI_CALL DBFAddField ( DBFHandle  hDBF,
const char *  pszFieldName,
DBFFieldType  eType,
int  nWidth,
int  nDecimals
◆ DBFAddNativeFieldType()
int SHPAPI_CALL DBFAddNativeFieldType ( DBFHandle  hDBF,
char  chType,
int  nWidth,
int  nDecimals
◆ DBFCloneEmpty()
DBFHandle SHPAPI_CALL DBFCloneEmpty ( DBFHandle  psDBF,
const char *  pszFilename
◆ DBFClose()
void SHPAPI_CALL DBFClose ( DBFHandle  hDBF)
◆ DBFCreate()
DBFHandle SHPAPI_CALL DBFCreate ( const char *  pszDBFFile)
◆ DBFCreateLL()
DBFHandle SHPAPI_CALL DBFCreateLL ( const char *  pszDBFFile,
SAHooks psHooks
◆ DBFGetFieldCount()
int SHPAPI_CALL DBFGetFieldCount ( DBFHandle  psDBF)
◆ DBFGetFieldIndex()
int SHPAPI_CALL DBFGetFieldIndex ( DBFHandle  psDBF,
◆ DBFGetFieldInfo()
DBFFieldType SHPAPI_CALL DBFGetFieldInfo ( DBFHandle  psDBF,
int  iField,
int *  pnWidth,
int *  pnDecimals
◆ DBFGetNativeFieldType()
char SHPAPI_CALL DBFGetNativeFieldType ( DBFHandle  hDBF,
int  iField
◆ DBFGetRecordCount()
int SHPAPI_CALL DBFGetRecordCount ( DBFHandle  psDBF)
◆ DBFIsAttributeNULL()
int SHPAPI_CALL DBFIsAttributeNULL ( DBFHandle  hDBF,
int  iShape,
int  iField
◆ DBFIsRecordDeleted()
int SHPAPI_CALL DBFIsRecordDeleted ( DBFHandle  psDBF,
int  iShape
◆ DBFMarkRecordDeleted()
int SHPAPI_CALL DBFMarkRecordDeleted ( DBFHandle  psDBF,
int  iShape,
int  bIsDeleted
◆ DBFOpenLL()
DBFHandle SHPAPI_CALL DBFOpenLL ( const char *  pszDBFFile,
const char *  pszAccess,
SAHooks psHooks
◆ DBFReadDoubleAttribute()
double SHPAPI_CALL DBFReadDoubleAttribute ( DBFHandle  hDBF,
int  iShape,
int  iField
◆ DBFReadIntegerAttribute()
int SHPAPI_CALL DBFReadIntegerAttribute ( DBFHandle  hDBF,
int  iShape,
int  iField
◆ DBFReadStringAttribute()
const char SHPAPI_CALL1* DBFReadStringAttribute ( DBFHandle  hDBF,
int  iShape,
int  iField
) const
◆ DBFReadTuple()
const char SHPAPI_CALL1* DBFReadTuple ( DBFHandle  psDBF,
int  hEntity
◆ DBFUpdateHeader()
void SHPAPI_CALL DBFUpdateHeader ( DBFHandle  hDBF)
◆ DBFWriteAttributeDirectly()
int SHPAPI_CALL DBFWriteAttributeDirectly ( DBFHandle  psDBF,
int  hEntity,
int  iField,
void *  pValue
◆ DBFWriteDoubleAttribute()
int SHPAPI_CALL DBFWriteDoubleAttribute ( DBFHandle  hDBF,
int  iShape,
int  iField,
double  dFieldValue
◆ DBFWriteIntegerAttribute()
int SHPAPI_CALL DBFWriteIntegerAttribute ( DBFHandle  hDBF,
int  iShape,
int  iField,
int  nFieldValue
◆ DBFWriteLogicalAttribute()
int SHPAPI_CALL DBFWriteLogicalAttribute ( DBFHandle  hDBF,
int  iShape,
int  iField,
◆ DBFWriteNULLAttribute()
int SHPAPI_CALL DBFWriteNULLAttribute ( DBFHandle  hDBF,
int  iShape,
int  iField
◆ DBFWriteStringAttribute()
int SHPAPI_CALL DBFWriteStringAttribute ( DBFHandle  hDBF,
int  iShape,
int  iField,
const char *  pszFieldValue
◆ SASetupDefaultHooks()
void SHPAPI_CALL SASetupDefaultHooks ( SAHooks psHooks)
◆ SHPClose()
void SHPAPI_CALL SHPClose ( SHPHandle  hSHP)
Referenced by ossimShapeFile::close().
◆ SHPComputeExtents()
void SHPAPI_CALL SHPComputeExtents ( SHPObject psObject)
◆ SHPCreate()
SHPHandle SHPAPI_CALL SHPCreate ( const char *  pszShapeFile,
int  nShapeType
◆ SHPCreateLL()
SHPHandle SHPAPI_CALL SHPCreateLL ( const char *  pszShapeFile,
int  nShapeType,
SAHooks psHooks
◆ SHPCreateObject()
SHPObject SHPAPI_CALL1* SHPCreateObject ( int  nSHPType,
int  nShapeId,
int  nParts,
const int *  panPartStart,
const int *  panPartType,
int  nVertices,
const double *  padfX,
const double *  padfY,
const double *  padfZ,
const double *  padfM
) const
◆ SHPCreateTree()
SHPTree SHPAPI_CALL1* SHPCreateTree ( SHPHandle  hSHP,
int  nDimension,
int  nMaxDepth,
double *  padfBoundsMin,
double *  padfBoundsMax
◆ SHPDestroyObject()
void SHPAPI_CALL SHPDestroyObject ( SHPObject psObject)
◆ SHPGetInfo()
void SHPAPI_CALL SHPGetInfo ( SHPHandle  hSHP,
int *  pnEntities,
int *  pnShapeType,
double *  padfMinBound,
double *  padfMaxBound
◆ SHPOpen()
SHPHandle SHPAPI_CALL SHPOpen ( const char *  pszShapeFile,
Referenced by ossimShapeFile::open().
◆ SHPOpenLL()
SHPHandle SHPAPI_CALL SHPOpenLL ( const char *  pszShapeFile,
SAHooks psHooks
◆ SHPReadObject()
SHPObject SHPAPI_CALL1* SHPReadObject ( SHPHandle  hSHP,
int  iShape
◆ SHPReadTree()
SHPTree SHPAPI_CALL SHPReadTree ( const char *  pszFilename)
◆ SHPRewindObject()
int SHPAPI_CALL SHPRewindObject ( SHPHandle  hSHP,
SHPObject psObject
◆ SHPSearchDiskTree()
int SHPAPI_CALL1* SHPSearchDiskTree ( FILE *  fp,
double *  padfBoundsMax,
int *  pnShapeCount
) const
◆ SHPTreeAddObject()
int SHPAPI_CALL SHPTreeAddObject ( SHPTree hTree,
SHPObject psObject
◆ SHPTreeAddShapeId()
int SHPAPI_CALL SHPTreeAddShapeId ( SHPTree hTree,
SHPObject psObject
◆ SHPTreeFindLikelyShapes()
int SHPAPI_CALL1* SHPTreeFindLikelyShapes ( SHPTree hTree,
int *
◆ SHPTreeRemoveShapeId()
int SHPAPI_CALL SHPTreeRemoveShapeId ( SHPTree hTree,
int  nShapeId
◆ SHPTreeTrimExtraNodes()
void SHPAPI_CALL SHPTreeTrimExtraNodes ( SHPTree hTree)
◆ SHPTypeName()
const char SHPAPI_CALL1* SHPTypeName ( int  nSHPType) const
◆ SHPWriteHeader()
void SHPAPI_CALL SHPWriteHeader ( SHPHandle  hSHP)
◆ SHPWriteTree()
int SHPAPI_CALL SHPWriteTree ( SHPTree hTree,
