Functions
vpfselec.h File Reference
Go to the source code of this file.
Functions
set_type read_selected_features (view_type *view, int themenum)
void save_selected_features (view_type *view, int themenum, set_type selset)
set_type get_selected_features (view_type *view, int themenum, library_type library)
set_type bounding_select (char *path, extent_type mapextent, int dec_degrees)
int completely_within (extent_type extent1, extent_type extent2)
set_typeget_selected_primitives (view_type *view, int themenum, library_type *library, map_environment_type *mapenv, int *status)
int draw_selected_features (view_type *view, int themenum, library_type *library, map_environment_type *mapenv)
Function Documentation
◆ bounding_select()
set_type bounding_select ( char *  path,
int  dec_degrees
◆ completely_within()
int completely_within ( extent_type  extent1,
extent_type  extent2
◆ draw_selected_features()
int draw_selected_features ( view_type view,
int  themenum,
library_type library,
map_environment_type mapenv
◆ get_selected_features()
set_type get_selected_features ( view_type view,
int  themenum,
◆ get_selected_primitives()
set_type* get_selected_primitives ( view_type view,
int  themenum,
map_environment_type mapenv,
int *  status
◆ read_selected_features()
set_type read_selected_features ( view_type view,
int  themenum
◆ save_selected_features()
void save_selected_features ( view_type view,
int  themenum,
set_type  selset
