AlosPalsarData.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // "Copyright Centre National d'Etudes Spatiales"
4 // "Copyright Centre for Remote Imaging, Sensing and Processing"
5 //
6 // License: LGPL
7 //
8 // See LICENSE.txt file in the top level directory for more details.
9 //
10 //----------------------------------------------------------------------------
11 // $Id$
12
15
18
19 #include <ossim/base/ossimTrace.h>
22
23 // Static trace for debugging
24 static ossimTrace traceDebug("ossimAlosPalsarData:debug");
25
26 namespace ossimplugins
27 {
28
31
33 {
34
35 }
36
38 {
39  ClearRecords();
40 }
41
43 {
44  std::map<int, AlosPalsarRecord*>::const_iterator it = data._records.begin();
45  while (it != data._records.end())
46  {
47  (*it).second->Write(os);
48  ++it;
49  }
50  return os;
51
52 }
53
55 {
56
57  data.ClearRecords();
58
60
61  is >> header;
62
64  if (record != NULL)
65  {
66  record->Read(is);
67  data._records[header.get_rec_seq()] = record;
68  }
69  else
70  {
71  char* buff = new char[header.get_length()-12];
72  is.read(buff, header.get_length() - 12);
73  delete [] buff;
74  }
75
76  std::streampos filePosition;
77
78  filePosition = is.tellg();
79  is >> header;
80
81  record = new AlosPalsarSignalData;
82
83  if (record != NULL)
84  {
85  record->Read(is);
86  data._records[header.get_rec_seq()] = record;
87 // std::cout << "Record sequence number = " << header.get_rec_seq() << std::endl;
88  }
89  is.seekg(filePosition); // Rewind file pointer to start of record
90  // Then, advance pointer to next record
91  is.seekg(static_cast<std::streamoff>(header.get_length()), std::ios::cur);
92
93  return is;
94 }
95
96
98 {
99  std::map<int, AlosPalsarRecord*>::const_iterator it = rhs._records.begin();
100  while (it != rhs._records.end())
101  {
102  _records[(*it).first] = (*it).second->Clone();
103  ++it;
104  }
105 }
106
108 {
109  ClearRecords();
110  std::map<int, AlosPalsarRecord*>::const_iterator it = rhs._records.begin();
111  while (it != rhs._records.end())
112  {
113  _records[(*it).first] = (*it).second->Clone();
114  ++it;
115  }
116
117  return *this;
118 }
119
121 {
122  std::map<int, AlosPalsarRecord*>::const_iterator it = _records.begin();
123  while (it != _records.end())
124  {
125  delete(*it).second;
126  ++it;
127  }
128  _records.clear();
129 }
130
132  const char* prefix) const
133 {
134
135  static const char MODULE[] = "AlosPalsarData::saveState";
136
137  if (traceDebug())
138  {
139  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
140  }
141
142  bool result = true;
143
144  /*
145  * Adding metadata necessary to the sensor model in the keywordlist
146  */
148  if (datafiledesc != NULL)
149  {
150  kwl.add(prefix, "num_lines", datafiledesc->get_num_lines(), true);
151  kwl.add(prefix, "num_pix_in_line", datafiledesc->get_num_pix_in_line(), true);
152  }
153  else
154  {
155  result = false;
156  }
157
158  const AlosPalsarSignalData *signalData = get_AlosPalsarSignalData();
159  if (datafiledesc != NULL)
160  {
161  kwl.add(prefix, "pulse_repetition_frequency", signalData->get_pulse_repetition_frequency(), true);
162  // slant range to 1st data sample in metres
163  kwl.add(prefix, "slant_range_to_1st_data_sample", signalData->get_slant_range_to_1st_data_sample(), true);
164  }
165  else
166  {
167  result = false;
168  }
169
170
171  return result;
172 }
173
174
176 {
177  return dynamic_cast<const AlosPalsarDataFileDescriptor*>(_records.find(AlosPalsarDataFileDescriptorID)->second);
178 }
179
181 {
182  // TODO: Check if _records[AlosPalsarSignalDataID] works
183  return dynamic_cast<const AlosPalsarSignalData*>(_records.find(AlosPalsarSignalDataID)->second);
184 }
185
186 }
This class is able to read the header of the Signal Data Records of the image file.
This class is able to read a record header.
virtual ~AlosPalsarData()
Destructor.
This class is the base class of all the record classes.
This class is able to read the SAR leader file descriptor record of the leader file.
static const int AlosPalsarDataFileDescriptorID
std::ostream & operator<<(std::ostream &os, const AlosPalsarData &data)
This class is able to read the Leader file of the AlosPalsar file structure.
AlosPalsarData & operator=(const AlosPalsarData &rhs)
Copy operator.
Method to save object state to a keyword list.
std::istream & operator>>(std::istream &is, AlosPalsarData &data)
std::basic_istream< char > istream
Base class for char input streams.
Definition: ossimIosFwd.h:20
const AlosPalsarDataFileDescriptor * get_AlosPalsarDataFileDescriptor() const
static const int AlosPalsarSignalDataID
void ClearRecords()
Remove all the previous records from the AlosPalsarData.
virtual void Read(std::istream &is)=0
Read the class data from a stream.
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
const AlosPalsarSignalData * get_AlosPalsarSignalData() const
