ossim-plugins
cnes
src
RadarSat
CommonRecord
BeamInformationRecord.h
Go to the documentation of this file.
1
2
3
// "Copyright Centre National d'Etudes Spatiales"
4
5
// License: LGPL
6
7
// See LICENSE.txt file in the top level directory for more details.
8
9
10
// $Id$
11
12
#ifndef BeamInformationRecord_h
13
#define BeamInformationRecord_h
14
15
#include <iostream>
16
17
#include <
RadarSat/RadarSatRecord.h
18
19
namespace
ossimplugins
20
25
class
26
27
public
31
32
36
~BeamInformationRecord
37
41
const
& rhs);
42
46
operator=
const
& rhs);
47
51
friend
std::ostream
operator<<
std::ostream
& os,
const
& data);
52
56
friend
std::istream
operator>>
std::istream
& is,
& data);
57
61
std::string
get_beam_type
62
63
return
_beam_type
64
65
69
std::string
get_beam_look_src
70
71
return
_beam_look_src
72
73
77
double
get_beam_look_ang
78
79
return
_beam_look_ang
80
81
85
double
get_prf
86
87
return
_prf
88
89
protected
90
94
std::string
_beam_type
95
99
std::string
_beam_look_src
100
104
double
_beam_look_ang
105
109
double
_prf
110
private
111
112
113
114
#endif
ossimplugins::BeamInformationRecord::BeamInformationRecord
BeamInformationRecord()
Constructor.
Definition:
BeamInformationRecord.cpp:16
ossimplugins::BeamInformationRecord::_beam_look_src
std::string _beam_look_src
Elevation beam look angle source.
Definition:
BeamInformationRecord.h:99
ossimplugins::BeamInformationRecord::get_prf
double get_prf()
Actual PRF (Hz)
Definition:
BeamInformationRecord.h:85
ossimplugins::BeamInformationRecord::_beam_type
std::string _beam_type
Beam type.
Definition:
BeamInformationRecord.h:88
ossimplugins::BeamInformationRecord::get_beam_look_ang
double get_beam_look_ang()
Applied elevation beam look angle (deg)
Definition:
BeamInformationRecord.h:77
ossimplugins::BeamInformationRecord::~BeamInformationRecord
~BeamInformationRecord()
Destructor.
Definition:
BeamInformationRecord.cpp:20
ossimplugins::BeamInformationRecord::get_beam_look_src
std::string get_beam_look_src()
Definition:
BeamInformationRecord.h:69
ossimplugins
Definition:
AlosPalsarData.cpp:26
ossimplugins::BeamInformationRecord::operator=
BeamInformationRecord & operator=(const BeamInformationRecord &rhs)
Copy operator.
Definition:
BeamInformationRecord.cpp:70
This class is able to read a Beam information record.
Definition:
BeamInformationRecord.h:25
ossimplugins::BeamInformationRecord::_beam_look_ang
double _beam_look_ang
Definition:
BeamInformationRecord.h:104
ossimplugins::BeamInformationRecord::_prf
double _prf
Actual PRF (Hz)
Definition:
BeamInformationRecord.h:109
RadarSatRecord.h
ossimplugins::BeamInformationRecord::operator<<
friend std::ostream & operator<<(std::ostream &os, const BeamInformationRecord &data)
This function writes the BeamInformationRecord in a stream.
Definition:
BeamInformationRecord.cpp:24
ossim::istream
std::basic_istream< char > istream
Base class for char input streams.
Definition:
ossimIosFwd.h:20
ossimplugins::BeamInformationRecord::operator>>
friend std::istream & operator>>(std::istream &is, BeamInformationRecord &data)
This function reads a BeamInformationRecord from a stream.
Definition:
BeamInformationRecord.cpp:37
ossim::ostream
std::basic_ostream< char > ostream
Base class for char output streams.
Definition:
ossimIosFwd.h:23
ossimplugins::BeamInformationRecord::get_beam_type
std::string get_beam_type()
Beam type.
Definition:
BeamInformationRecord.h:61
Generated on Fri Aug 3 2018 08:46:44 for OSSIM - Open Source Software Image Map by
