12 #ifndef DataHistogramSignalData_h 13 #define DataHistogramSignalData_h int get_ntab()
Number of histogram table data sets in this record.
virtual ~DataHistogramSignalData()
Destructor.
int get_sar_chn()
SAR channel indicator.
This class is able to read a data histogram record.
friend std::ostream & operator<<(std::ostream &os, const DataHistogramSignalData &data)
This function writes the DataHistogramSignalData in a stream.
void Read(std::istream &is)
Reads the class data from a stream.
Constructor.
DataHistogramSignalData DataHistogramProcessedData8
int _rec_seq
Record sequence number.
int _ntab
This class is the base class of all the record classes.
DataHistogramRecord _histogram
Histogram data record.
This class is able to read a data histogram record - Signal data.
RadarSatRecord * Clone()
This function is able to create a new instance of the class initialised with the data of the calling ...
int get_ltab()
Histogram table data set size.
DataHistogramRecord get_histogram()
int _sar_chn
std::basic_istream< char > istream
Base class for char input streams.
DataHistogramSignalData & operator=(const DataHistogramSignalData &rhs)
Copy operator.
void Write(std::ostream &os)
Writes the class to a stream.
int _ltab
std::basic_ostream< char > ostream
Base class for char output streams.
int get_rec_seq()
friend std::istream & operator>>(std::istream &is, DataHistogramSignalData &data)
This function reads a DataHistogramSignalData from a stream.
RadarSatRecord * Instanciate()
This function is able to create a new instance of the class.
