ossim-plugins
cnes
src
erssar
ErsSarFacilityData.h
Go to the documentation of this file.
1
2
3
// "Copyright Centre National d'Etudes Spatiales"
4
5
// License: LGPL
6
7
// See LICENSE.txt file in the top level directory for more details.
8
9
10
// $Id$
11
12
#ifndef ErsSarFacilityData_h
13
#define ErsSarFacilityData_h
14
15
#include <iostream>
16
#include <cstdlib>
17
#include "
erssar/ErsSarRecordHeader.h
18
#include "
erssar/ErsSarRecord.h
19
20
namespace
ossimplugins
21
22
28
class
ErsSarFacilityData
public
ErsSarRecord
29
30
public
34
ErsSarFacilityData
35
39
virtual
~ErsSarFacilityData
40
44
friend
std::ostream
operator<<
std::ostream
& os,
const
ErsSarFacilityData
& data);
45
49
friend
std::istream
operator>>
std::istream
& is,
ErsSarFacilityData
& data);
50
54
ErsSarFacilityData
const
ErsSarFacilityData
& rhs);
55
59
ErsSarFacilityData
operator=
const
ErsSarFacilityData
& rhs);
60
64
ErsSarRecord
Instanciate
65
66
return
new
ErsSarFacilityData
67
68
72
ErsSarRecord
Clone
73
74
return
new
ErsSarFacilityData
this
75
76
80
void
Read
std::istream
& is)
81
82
is >> *
this
83
84
88
void
Write
std::ostream
& os)
89
90
os << *
this
91
92
96
std::string
get_name_of_facil_rec
const
97
98
return
_name_of_facil_rec
99
100
104
std::string
get_last_release_qc_date
const
105
106
return
107
111
std::string
get_last_release_cal_date
const
112
113
return
114
118
int
get_qa_summary_flag
const
119
120
return
_qa_summary_flag
121
125
int
get_prf_code_change_flag
const
126
127
return
128
132
int
get_sampling_win_change_flag
const
133
134
return
135
139
int
get_cal_gain_change_flag
const
140
141
return
142
146
int
get_quirp_qu_flag
const
147
148
return
_quirp_qu_flag
149
153
int
get_inp_data_stat_flag
const
154
155
return
_inp_data_stat_flag
156
160
int
get_dopp_cent_conf_meas_flag
const
161
162
return
163
167
int
get_dopp_cent_val_flag
const
168
169
return
_dopp_cent_val_flag
170
174
int
get_dopp_ambig_conf_meas_flag
const
175
176
return
177
181
int
get_outp_data_mean_flag
const
182
183
return
184
188
int
get_OGOB_flag
const
189
190
return
_OGOB_flag
191
195
int
get_PRF_changes
const
196
197
return
_PRF_changes
198
202
int
get_sampling_win_changes
const
203
204
return
205
209
int
get_cal_gain_changes
const
210
211
return
_cal_gain_changes
212
216
int
get_missing_lines
const
217
218
return
_missing_lines
219
223
int
get_rec_gain_changes
const
224
225
return
_rec_gain_changes
226
230
double
get_pulse_width_of_ACF_3db
const
231
232
return
233
237
double
get_first_side_lobe_lev_of_ACF
const
238
239
return
240
244
double
get_ISLR_of_ACF
const
245
246
return
_ISLR_of_ACF
247
251
double
const
252
253
return
254
258
double
const
259
260
return
261
265
double
get_inp_data_I_mean
const
266
267
return
_inp_data_I_mean
268
272
double
get_inp_data_Q_mean
const
273
274
return
_inp_data_Q_mean
275
279
double
get_inp_data_I_stddev
const
280
281
return
_inp_data_I_stddev
282
286
double
get_inp_data_Q_stddev
const
287
288
return
_inp_data_Q_stddev
289
293
double
get_cal_sys_gain
const
294
295
return
_cal_sys_gain
296
300
double
get_first_rec_gain_read
const
301
302
return
303
307
double
get_dopp_ambig_num
const
308
309
return
_dopp_ambig_num
310
314
double
get_I_channel_bias_correction
const
315
316
return
317
321
double
get_Q_channel_bias_correction
const
322
323
return
324
328
double
get_I_channel_gain_correction
const
329
330
return
331
335
double
get_Q_channel_gain_correction
const
336
337
return
338
342
double
get_Q_channel_I_Q_correction
const
343
344
return
345
349
double
get_noise_power
const
350
351
return
_noise_power
352
356
int
get_int_cal_utc
const
357
358
return
_int_cal_utc
359
363
int
get_num_valid_cal_pulses
const
364
365
return
366
370
int
get_num_valid_noise_pulses
const
371
372
return
373
377
int
get_num_valid_replicas
const
378
379
return
_num_valid_replicas
380
384
double
get_first_replica_sample
const
385
386
return
387
391
double
get_mean_cal_pulse_power
const
392
393
return
394
398
double
get_mean_noise_power
const
399
400
return
_mean_noise_power
401
405
double
get_range_comp_norm_fact
const
406
407
return
408
412
double
get_replica_power
const
413
414
return
_replica_power
415
419
double
get_first_range_pixel_mid_az_inc
const
420
421
return
422
426
double
get_center_range_pix_mid_az_inc
const
427
428
return
429
433
double
get_last_range_pix_mid_az_inc
const
434
435
return
436
440
double
get_norm_ref_range_ro
const
441
442
return
_norm_ref_range_ro
443
447
int
get_antenna_elev_flag
const
448
449
return
_antenna_elev_flag
450
454
double
get_abs_cal_const_K
const
455
456
return
_abs_cal_const_K
457
461
double
get_upp_bound_K
const
462
463
return
_upp_bound_K
464
468
double
get_low_bound_K
const
469
470
return
_low_bound_K
471
475
double
get_proc_noise_scale_fact
const
476
477
return
478
482
std::string
get_K_gen_date
const
483
484
return
_K_gen_date
485
489
std::string
get_K_vers_num
const
490
491
return
_K_vers_num
492
496
int
get_num_duplic_input_lines
const
497
498
return
499
503
double
get_estim_bit_error_rate
const
504
505
return
506
510
double
get_out_image_mean
const
511
512
return
_out_image_mean
513
517
double
get_out_image_std_dev
const
518
519
return
_out_image_std_dev
520
524
double
get_out_image_max_value
const
525
526
return
527
531
std::string
get_time_raw_data_first_input
const
532
533
return
534
538
std::string
get_time_asc_node_state_vectors
const
539
540
return
541
545
std::string
get_asc_node_pos_X_comp
const
546
547
return
548
552
std::string
get_asc_node_pos_Y_comp
const
553
554
return
555
559
std::string
get_asc_node_pos_Z_comp
const
560
561
return
562
566
std::string
get_asc_node_vel_X_comp
const
567
568
return
569
573
std::string
get_asc_node_vel_Y_comp
const
574
575
return
576
580
std::string
get_asc_node_vel_Z_comp
const
581
582
return
583
587
int
get_out_pixel_bit_length
const
588
589
return
590
594
double
get_proc_gain_param_1
const
595
596
return
_proc_gain_param_1
597
601
double
get_proc_gain_param_2
const
602
603
return
_proc_gain_param_2
604
608
double
get_proc_gain_param_3
const
609
610
return
_proc_gain_param_3
611
615
int
get_peak_loc_cross_correl_fun
const
616
617
return
618
622
double
get_3_dB_width_CCF
const
623
624
return
_3_dB_width_CCF
625
629
double
get_first_side_lobe_level
const
630
631
return
632
636
double
get_ISLR_CCF_between_last
const
637
638
return
639
643
int
get_peak_loc_CCF_betw_last
const
644
645
return
646
650
int
get_Roll_Tilt_Mode_flag
const
651
652
return
653
657
int
get_raw_data_correction_flag
const
658
659
return
660
664
int
get_look_detecion_flag
const
665
666
return
_look_detecion_flag
667
671
int
get_doppler_ambiguity_estimat_flag
const
672
673
return
674
678
int
get_azimuth_baseband_convers_flag
const
679
680
return
681
685
int
get_samples_per_line_used
const
686
687
return
688
692
int
get_range_lines_skip_factor
const
693
694
return
695
699
std::string
get_time_of_inp_state_vectors
const
700
701
return
702
706
std::string
get_inp_state_vect_pos_X_comp
const
707
708
return
709
713
std::string
get_inp_state_vect_pos_Y_comp
const
714
715
return
716
720
std::string
get_inp_state_vect_pos_Z_comp
const
721
722
return
723
727
std::string
get_inp_state_vect_vel_Vx_comp
const
728
729
return
730
734
std::string
get_inp_state_vect_vel_Vy_comp
const
735
736
return
737
741
std::string
get_inp_state_vect_vel_Vz_comp
const
742
743
return
744
748
int
get_inp_state_vector_type_flag
const
749
750
return
751
755
double
get_win_coeff_for_range_match
const
756
757
return
758
762
double
get_win_coeff_for_azi_match
const
763
764
return
765
769
int
get_update_period_range_match
const
770
771
return
772
776
double
get_look_scalar_gain_1
const
777
778
return
_look_scalar_gain_1
779
783
double
get_look_scalar_gain_2
const
784
785
return
_look_scalar_gain_2
786
790
double
get_look_scalar_gain_3
const
791
792
return
_look_scalar_gain_3
793
797
double
get_look_scalar_gain_4
const
798
799
return
_look_scalar_gain_4
800
804
double
get_look_scalar_gain_5
const
805
806
return
_look_scalar_gain_5
807
811
double
get_look_scalar_gain_6
const
812
813
return
_look_scalar_gain_6
814
818
double
get_look_scalar_gain_7
const
819
820
return
_look_scalar_gain_7
821
825
double
get_look_scalar_gain_8
const
826
827
return
_look_scalar_gain_8
828
832
int
get_samp_window_start_time_bias
const
833
834
return
835
839
double
get_doppler_centroid_cubic_coeff
const
840
841
return
842
846
int
get_PRF_code_first_range_line
const
847
848
return
849
853
int
get_PRF_code_last_range_line
const
854
855
return
856
860
int
get_samp_win_start_first
const
861
862
return
863
867
int
get_samp_win_start_last
const
868
869
return
870
874
int
get_cal_syst_gain_last_proc
const
875
876
return
877
881
int
get_receiver_gain_last_proc
const
882
883
return
884
888
int
get_first_processed_range_sample
const
889
890
return
891
895
int
get_azimuth_FFT_IFFT_ratio
const
896
897
return
898
902
int
get_num_azimuth_blocks_proc
const
903
904
return
905
909
int
get_num_input_raw_data_lines
const
910
911
return
912
916
int
get_initial_doppler_ambiguity_num
const
917
918
return
919
923
double
get_thresh_no_1_flag
const
924
925
return
_thresh_no_1_flag
926
930
double
get_thresh_no_2_flag
const
931
932
return
_thresh_no_2_flag
933
937
double
get_thresh_no_3_flag
const
938
939
return
_thresh_no_3_flag
940
944
double
get_thresh_no_4_flag
const
945
946
return
_thresh_no_4_flag
947
951
double
get_thresh_no_5_flag
const
952
953
return
_thresh_no_5_flag
954
958
double
get_thresh_no_6_flag
const
959
960
return
_thresh_no_6_flag
961
965
double
get_thresh_no_7_flag
const
966
967
return
_thresh_no_7_flag
968
972
double
get_thresh_no_8_flag
const
973
974
return
_thresh_no_8_flag
975
979
double
get_thresh_no_9_flag
const
980
981
return
_thresh_no_9_flag
982
986
double
get_thresh_no_10_flag
const
987
988
return
_thresh_no_10_flag
989
993
double
get_thresh_no_11_flag
const
994
995
return
_thresh_no_11_flag
996
1000
int
get_sat_binary_time_of_first
const
1001
1002
return
1003
1007
int
get_num_valid_pixels_per_range
const
1008
1009
return
1010
1014
int
get_num_range_samp_discarded
const
1015
1016
return
1017
1021
double
get_I_gain_imb_lower_bound
const
1022
1023
return
1024
1028
double
get_I_gain_imb_upper_bound
const
1029
1030
return
1031
1035
double
get_I_Q_quad_depar_lower_bound
const
1036
1037
return
1038
1042
double
get_I_Q_quad_depar_upper_bound
const
1043
1044
return
1045
1049
double
get_3_dB_look_bandwidth
const
1050
1051
return
1052
1056
double
get_3_dB_look_proc_dopp_bandw
const
1057
1058
return
1059
1063
int
get_range_spread_loss_comp_flag
const
1064
1065
return
1066
1070
bool
get_datation_flag
const
1071
1072
return
_datation_flag
1073
1077
int
get_max_error_range_line_timing
const
1078
1079
return
1080
1084
int
get_form_num_range_line_used
const
1085
1086
return
1087
1091
bool
get_autom_look_scal_gain_flag
const
1092
1093
return
1094
1098
int
get_max_value_look_scalar_gain
const
1099
1100
return
1101
1105
int
get_replica_norm_method_flag
const
1106
1107
return
1108
1112
double
get_coef_ground_range_1
const
1113
1114
return
1115
1119
double
get_coef_ground_range_2
const
1120
1121
return
1122
1126
double
get_coef_ground_range_3
const
1127
1128
return
1129
1133
double
get_coef_ground_range_4
const
1134
1135
return
1136
1140
double
get_coef_ant_elev_1
const
1141
1142
return
_coef_ant_elev_1
1143
1147
double
get_coef_ant_elev_2
const
1148
1149
return
_coef_ant_elev_2
1150
1154
double
get_coef_ant_elev_3
const
1155
1156
return
_coef_ant_elev_3
1157
1161
double
get_coef_ant_elev_4
const
1162
1163
return
_coef_ant_elev_4
1164
1168
double
get_coef_ant_elev_5
const
1169
1170
return
_coef_ant_elev_5
1171
1175
double
get_range_time_origin_ant
const
1176
1177
return
1178
1179
1180
1181
protected
1182
1186
std::string
_name_of_facil_rec
1190
std::string
1194
std::string
1198
int
_qa_summary_flag
1202
int
1206
int
1210
int
1214
int
_quirp_qu_flag
1218
int
_inp_data_stat_flag
1222
int
1226
int
_dopp_cent_val_flag
1230
int
1234
int
1238
int
_OGOB_flag
1242
int
_PRF_changes
1246
int
1250
int
_cal_gain_changes
1254
int
_missing_lines
1258
int
_rec_gain_changes
1262
double
1266
double
1270
double
_ISLR_of_ACF
1274
double
1278
double
1282
double
_inp_data_I_mean
1286
double
_inp_data_Q_mean
1290
double
_inp_data_I_stddev
1294
double
_inp_data_Q_stddev
1298
double
_cal_sys_gain
1302
double
1306
double
_dopp_ambig_num
1310
double
1314
double
1318
double
1322
double
1326
double
1330
double
_noise_power
1334
int
_int_cal_utc
1338
int
1342
int
1346
int
_num_valid_replicas
1350
double
1354
double
1358
double
_mean_noise_power
1362
double
1366
double
_replica_power
1370
double
1374
double
1378
double
1382
double
_norm_ref_range_ro
1386
int
_antenna_elev_flag
1390
double
_abs_cal_const_K
1394
double
_upp_bound_K
1398
double
_low_bound_K
1402
double
1406
std::string
_K_gen_date
1410
std::string
_K_vers_num
1414
int
1418
double
1422
double
_out_image_mean
1426
double
_out_image_std_dev
1430
double
1434
std::string
1438
std::string
1442
std::string
1446
std::string
1450
std::string
1454
std::string
1458
std::string
1462
std::string
1466
int
1470
double
_proc_gain_param_1
1474
double
_proc_gain_param_2
1478
double
_proc_gain_param_3
1482
int
1486
double
_3_dB_width_CCF
1490
double
1494
double
1498
int
1502
int
1506
int
1510
int
_look_detecion_flag
1514
int
1518
int
1522
int
1526
int
1530
std::string
1534
std::string
1538
std::string
1542
std::string
1546
std::string
1550
std::string
1554
std::string
1558
int
1562
double
1566
double
1570
int
1574
double
_look_scalar_gain_1
1578
double
_look_scalar_gain_2
1582
double
_look_scalar_gain_3
1586
double
_look_scalar_gain_4
1590
double
_look_scalar_gain_5
1594
double
_look_scalar_gain_6
1598
double
_look_scalar_gain_7
1602
double
_look_scalar_gain_8
1606
int
1610
double
1614
int
1618
int
1622
int
1626
int
1630
int
1634
int
1638
int
1642
int
1646
int
1650
int
1654
int
1658
double
_thresh_no_1_flag
1662
double
_thresh_no_2_flag
1666
double
_thresh_no_3_flag
1670
double
_thresh_no_4_flag
1674
double
_thresh_no_5_flag
1678
double
_thresh_no_6_flag
1682
double
_thresh_no_7_flag
1686
double
_thresh_no_8_flag
1690
double
_thresh_no_9_flag
1694
double
_thresh_no_10_flag
1698
double
_thresh_no_11_flag
1702
int
1706
int
1710
int
1714
double
1718
double
1722
double
1726
double
1730
double
1734
double
1738
int
1742
bool
_datation_flag
1746
int
1750
int
1754
bool
1758
int
1762
int
1766
double
1770
double
1774
double
1778
double
1782
double
_coef_ant_elev_1
1786
double
_coef_ant_elev_2
1790
double
_coef_ant_elev_3
1794
double
_coef_ant_elev_4
1798
double
_coef_ant_elev_5
1802
double
1803
1804
private
1805
1806
1807
1808
1809
#endif
ossimplugins::ErsSarFacilityData::_last_release_cal_date
std::string _last_release_cal_date
Definition:
ErsSarFacilityData.h:1194
ossimplugins::ErsSarFacilityData::_datation_flag
bool _datation_flag
datation_flag
Definition:
ErsSarFacilityData.h:1742
ossimplugins::ErsSarFacilityData::get_cal_syst_gain_last_proc
int get_cal_syst_gain_last_proc() const
Definition:
ErsSarFacilityData.h:874
ossimplugins::ErsSarFacilityData::_coef_ground_range_2
double _coef_ground_range_2
coef_ground_range_2
Definition:
ErsSarFacilityData.h:1770
ossimplugins::ErsSarFacilityData::get_proc_gain_param_2
double get_proc_gain_param_2() const
proc_gain_param_2
Definition:
ErsSarFacilityData.h:601
ossimplugins::ErsSarFacilityData::get_doppler_centroid_cubic_coeff
double get_doppler_centroid_cubic_coeff() const
Definition:
ErsSarFacilityData.h:839
ossimplugins::ErsSarFacilityData::_I_gain_imb_upper_bound
double _I_gain_imb_upper_bound
I_gain_imb_upper_bound.
Definition:
ErsSarFacilityData.h:1718
ossimplugins::ErsSarFacilityData::get_look_scalar_gain_5
double get_look_scalar_gain_5() const
look_scalar_gain_5
Definition:
ErsSarFacilityData.h:804
ossimplugins::ErsSarFacilityData::_coef_ant_elev_4
double _coef_ant_elev_4
coef_ant_elev_4
Definition:
ErsSarFacilityData.h:1794
ossimplugins::ErsSarFacilityData::_center_range_pix_mid_az_inc
double _center_range_pix_mid_az_inc
Definition:
ErsSarFacilityData.h:1374
ossimplugins::ErsSarFacilityData::_initial_doppler_ambiguity_num
int _initial_doppler_ambiguity_num
Definition:
ErsSarFacilityData.h:1654
ossimplugins::ErsSarFacilityData::operator>>
friend std::istream & operator>>(std::istream &is, ErsSarFacilityData &data)
This function read a ErsSarFacilityData from a stream.
Definition:
ErsSarFacilityData.cpp:339
ossimplugins::ErsSarFacilityData::Read
void Read(std::istream &is)
Read the class data from a stream.
Definition:
ossimplugins::ErsSarFacilityData::Write
void Write(std::ostream &os)
Write the class to a stream.
Definition:
ErsSarFacilityData.h:88
ossimplugins::ErsSarFacilityData::_form_num_range_line_used
int _form_num_range_line_used
Definition:
ErsSarFacilityData.h:1750
ossimplugins::ErsSarFacilityData::get_time_raw_data_first_input
std::string get_time_raw_data_first_input() const
Definition:
ErsSarFacilityData.h:531
ossimplugins::ErsSarFacilityData::Clone
ErsSarRecord * Clone()
This function is able to create a new instance of the class initialised with the data of the calling ...
Definition:
ErsSarFacilityData.h:72
ossimplugins::ErsSarFacilityData::get_sampling_win_changes
int get_sampling_win_changes() const
Definition:
ErsSarFacilityData.h:202
ossimplugins::ErsSarFacilityData::_proc_gain_param_3
double _proc_gain_param_3
proc_gain_param_3
Definition:
ErsSarFacilityData.h:1478
ossimplugins::ErsSarFacilityData::Instanciate
ErsSarRecord * Instanciate()
This function is able to create a new instance of the class.
Definition:
ErsSarFacilityData.h:64
ossimplugins::ErsSarFacilityData::get_quirp_qu_flag
int get_quirp_qu_flag() const
quirp_qu_flag
Definition:
ErsSarFacilityData.h:146
ossimplugins::ErsSarFacilityData::get_num_valid_cal_pulses
int get_num_valid_cal_pulses() const
Definition:
ErsSarFacilityData.h:363
ossimplugins::ErsSarFacilityData::_3_dB_width_CCF
double _3_dB_width_CCF
3_dB_width_CCF
Definition:
ErsSarFacilityData.h:1486
ossimplugins::ErsSarFacilityData::get_autom_look_scal_gain_flag
bool get_autom_look_scal_gain_flag() const
Definition:
ErsSarFacilityData.h:1091
ossimplugins::ErsSarFacilityData::_replica_power
double _replica_power
replica_power
Definition:
ErsSarFacilityData.h:1366
ossimplugins::ErsSarFacilityData::_PRF_code_first_range_line
int _PRF_code_first_range_line
PRF_code_first_range_line.
Definition:
ErsSarFacilityData.h:1614
ossimplugins::ErsSarFacilityData::_dopp_ambig_num
double _dopp_ambig_num
dopp_ambig_num
Definition:
ErsSarFacilityData.h:1306
ossimplugins::ErsSarFacilityData::get_abs_cal_const_K
double get_abs_cal_const_K() const
abs_cal_const_K
Definition:
ErsSarFacilityData.h:454
ossimplugins::ErsSarFacilityData::get_I_channel_gain_correction
double get_I_channel_gain_correction() const
I_channel_gain_correction.
Definition:
ErsSarFacilityData.h:328
ossimplugins::ErsSarFacilityData::get_inp_data_Q_stddev
double get_inp_data_Q_stddev() const
inp_data_Q_stddev
Definition:
ErsSarFacilityData.h:286
ossimplugins::ErsSarFacilityData::get_azimuth_FFT_IFFT_ratio
int get_azimuth_FFT_IFFT_ratio() const
Definition:
ErsSarFacilityData.h:895
ossimplugins::ErsSarFacilityData::get_thresh_no_9_flag
double get_thresh_no_9_flag() const
thresh_no_9_flag
Definition:
ErsSarFacilityData.h:979
ossimplugins::ErsSarFacilityData::get_cal_sys_gain
double get_cal_sys_gain() const
cal_sys_gain
Definition:
ErsSarFacilityData.h:293
ossimplugins::ErsSarFacilityData::_range_comp_norm_fact
double _range_comp_norm_fact
Definition:
ErsSarFacilityData.h:1362
ossimplugins::ErsSarFacilityData::get_look_scalar_gain_6
double get_look_scalar_gain_6() const
look_scalar_gain_6
Definition:
ErsSarFacilityData.h:811
ossimplugins::ErsSarFacilityData::get_inp_state_vect_pos_Z_comp
std::string get_inp_state_vect_pos_Z_comp() const
Definition:
ErsSarFacilityData.h:720
ossimplugins::ErsSarFacilityData::get_asc_node_vel_Y_comp
std::string get_asc_node_vel_Y_comp() const
asc_node_vel_Y_comp
Definition:
ErsSarFacilityData.h:573
ossimplugins::ErsSarFacilityData::get_3_dB_look_bandwidth
double get_3_dB_look_bandwidth() const
3_dB_look_bandwidth
Definition:
ErsSarFacilityData.h:1049
ossimplugins::ErsSarFacilityData::get_coef_ant_elev_2
double get_coef_ant_elev_2() const
coef_ant_elev_2
Definition:
ErsSarFacilityData.h:1147
ossimplugins::ErsSarFacilityData::_coef_ant_elev_5
double _coef_ant_elev_5
coef_ant_elev_5
Definition:
ErsSarFacilityData.h:1798
ossimplugins::ErsSarFacilityData::get_inp_state_vect_pos_X_comp
std::string get_inp_state_vect_pos_X_comp() const
Definition:
ErsSarFacilityData.h:706
ossimplugins::ErsSarFacilityData::get_dopp_cent_val_flag
int get_dopp_cent_val_flag() const
dopp_cent_val_flag
Definition:
ErsSarFacilityData.h:167
ossimplugins::ErsSarFacilityData::get_PRF_code_first_range_line
int get_PRF_code_first_range_line() const
Definition:
ErsSarFacilityData.h:846
ossimplugins::ErsSarFacilityData::_max_value_look_scalar_gain
int _max_value_look_scalar_gain
Definition:
ErsSarFacilityData.h:1758
ossimplugins::ErsSarFacilityData::get_Q_channel_gain_correction
double get_Q_channel_gain_correction() const
Q_channel_gain_correction.
Definition:
ErsSarFacilityData.h:335
ossimplugins::ErsSarFacilityData::_thresh_no_8_flag
double _thresh_no_8_flag
thresh_no_8_flag
Definition:
ErsSarFacilityData.h:1686
ossimplugins::ErsSarFacilityData::_range_time_origin_ant
double _range_time_origin_ant
Definition:
ErsSarFacilityData.h:1802
ossimplugins::ErsSarFacilityData::_look_scalar_gain_7
double _look_scalar_gain_7
look_scalar_gain_7
Definition:
ErsSarFacilityData.h:1598
ossimplugins::ErsSarFacilityData::get_thresh_no_10_flag
double get_thresh_no_10_flag() const
thresh_no_10_flag
Definition:
ErsSarFacilityData.h:986
ossimplugins::ErsSarFacilityData::_asc_node_pos_X_comp
std::string _asc_node_pos_X_comp
asc_node_pos_X_comp
Definition:
ErsSarFacilityData.h:1442
ossimplugins::ErsSarFacilityData::get_coef_ant_elev_1
double get_coef_ant_elev_1() const
coef_ant_elev_1
Definition:
ErsSarFacilityData.h:1140
ossimplugins::ErsSarFacilityData::_upp_bound_K
double _upp_bound_K
upp_bound_K
Definition:
ErsSarFacilityData.h:1394
ossimplugins::ErsSarFacilityData::_first_replica_sample
double _first_replica_sample
Definition:
ErsSarFacilityData.h:1350
ossimplugins::ErsSarFacilityData::get_form_num_range_line_used
int get_form_num_range_line_used() const
Definition:
ErsSarFacilityData.h:1084
ossimplugins::ErsSarFacilityData::_quirp_qu_flag
int _quirp_qu_flag
quirp_qu_flag
Definition:
ErsSarFacilityData.h:1214
ossimplugins::ErsSarFacilityData::get_peak_loc_cross_correl_fun
int get_peak_loc_cross_correl_fun() const
Definition:
ErsSarFacilityData.h:615
ossimplugins::ErsSarFacilityData::_out_image_std_dev
double _out_image_std_dev
out_image_std_dev
Definition:
ErsSarFacilityData.h:1426
ossimplugins::ErsSarFacilityData::get_estim_bit_error_rate
double get_estim_bit_error_rate() const
Definition:
ErsSarFacilityData.h:503
ossimplugins::ErsSarFacilityData::get_inp_state_vect_vel_Vx_comp
std::string get_inp_state_vect_vel_Vx_comp() const
Definition:
ErsSarFacilityData.h:727
ossimplugins::ErsSarFacilityData::get_3_dB_width_CCF
double get_3_dB_width_CCF() const
3_dB_width_CCF
Definition:
ErsSarFacilityData.h:622
ossimplugins::ErsSarFacilityData::_first_rec_gain_read
double _first_rec_gain_read
first_rec_gain_read
Definition:
ErsSarFacilityData.h:1302
ossimplugins::ErsSarFacilityData::_coef_ant_elev_3
double _coef_ant_elev_3
coef_ant_elev_3
Definition:
ErsSarFacilityData.h:1790
ossimplugins::ErsSarFacilityData::_samp_win_start_first
int _samp_win_start_first
Definition:
ErsSarFacilityData.h:1622
ossimplugins::ErsSarFacilityData::_look_detecion_flag
int _look_detecion_flag
look_detecion_flag
Definition:
ErsSarFacilityData.h:1510
ossimplugins::ErsSarFacilityData::get_first_side_lobe_lev_of_ACF
double get_first_side_lobe_lev_of_ACF() const
Definition:
ErsSarFacilityData.h:237
ossimplugins::ErsSarFacilityData::get_num_valid_replicas
int get_num_valid_replicas() const
num_valid_replicas
Definition:
ErsSarFacilityData.h:377
ossimplugins::ErsSarFacilityData::_coef_ground_range_3
double _coef_ground_range_3
coef_ground_range_3
Definition:
ErsSarFacilityData.h:1774
ossimplugins::ErsSarFacilityData::_I_channel_gain_correction
double _I_channel_gain_correction
Definition:
ErsSarFacilityData.h:1318
ossimplugins::ErsSarFacilityData::get_thresh_no_2_flag
double get_thresh_no_2_flag() const
thresh_no_2_flag
Definition:
ErsSarFacilityData.h:930
ossimplugins::ErsSarFacilityData::get_Q_channel_bias_correction
double get_Q_channel_bias_correction() const
Q_channel_bias_correction.
Definition:
ErsSarFacilityData.h:321
ossimplugins::ErsSarFacilityData::_inp_data_Q_stddev
double _inp_data_Q_stddev
inp_data_Q_stddev
Definition:
ErsSarFacilityData.h:1294
ossimplugins::ErsSarFacilityData::_thresh_no_7_flag
double _thresh_no_7_flag
thresh_no_7_flag
Definition:
ErsSarFacilityData.h:1682
ossimplugins::ErsSarFacilityData::_autom_look_scal_gain_flag
bool _autom_look_scal_gain_flag
Definition:
ErsSarFacilityData.h:1754
ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vz_comp
std::string _inp_state_vect_vel_Vz_comp
Definition:
ErsSarFacilityData.h:1554
ossimplugins::ErsSarFacilityData::_prf_code_change_flag
int _prf_code_change_flag
Definition:
ErsSarFacilityData.h:1202
ossimplugins::ErsSarFacilityData::_proc_gain_param_2
double _proc_gain_param_2
proc_gain_param_2
Definition:
ErsSarFacilityData.h:1474
ossimplugins::ErsSarFacilityData::_time_raw_data_first_input
std::string _time_raw_data_first_input
Definition:
ErsSarFacilityData.h:1434
ossimplugins::ErsSarFacilityData::_azimuth_FFT_IFFT_ratio
int _azimuth_FFT_IFFT_ratio
Definition:
ErsSarFacilityData.h:1642
ossimplugins::ErsSarFacilityData::_missing_lines
int _missing_lines
missing_lines
Definition:
ErsSarFacilityData.h:1254
ossimplugins::ErsSarFacilityData::_num_valid_replicas
int _num_valid_replicas
num_valid_replicas
Definition:
ErsSarFacilityData.h:1346
ossimplugins::ErsSarFacilityData::_mean_noise_power
double _mean_noise_power
mean_noise_power
Definition:
ErsSarFacilityData.h:1358
ossimplugins::ErsSarFacilityData::get_range_lines_skip_factor
int get_range_lines_skip_factor() const
Definition:
ErsSarFacilityData.h:692
ossimplugins::ErsSarFacilityData::get_mean_noise_power
double get_mean_noise_power() const
mean_noise_power
Definition:
ErsSarFacilityData.h:398
ossimplugins::ErsSarFacilityData::get_coef_ant_elev_3
double get_coef_ant_elev_3() const
coef_ant_elev_3
Definition:
ErsSarFacilityData.h:1154
ossimplugins::ErsSarFacilityData::_estim_bit_error_rate
double _estim_bit_error_rate
Definition:
ErsSarFacilityData.h:1418
ossimplugins::ErsSarFacilityData::get_ISLR_CCF_between_last
double get_ISLR_CCF_between_last() const
ISLR_CCF_between_last.
Definition:
ErsSarFacilityData.h:636
ossimplugins::ErsSarFacilityData::_thresh_no_6_flag
double _thresh_no_6_flag
thresh_no_6_flag
Definition:
ErsSarFacilityData.h:1678
ossimplugins::ErsSarFacilityData::get_PRF_changes
int get_PRF_changes() const
PRF_changes.
Definition:
ErsSarFacilityData.h:195
ossimplugins::ErsSarFacilityData::get_azimuth_baseband_convers_flag
int get_azimuth_baseband_convers_flag() const
Definition:
ErsSarFacilityData.h:678
ossimplugins::ErsSarFacilityData::get_inp_data_I_mean
double get_inp_data_I_mean() const
inp_data_I_mean
Definition:
ErsSarFacilityData.h:265
ossimplugins::ErsSarFacilityData::get_I_Q_quad_depar_upper_bound
double get_I_Q_quad_depar_upper_bound() const
I_Q_quad_depar_upper_bound.
Definition:
ErsSarFacilityData.h:1042
ossimplugins::ErsSarFacilityData::_look_scalar_gain_3
double _look_scalar_gain_3
look_scalar_gain_3
Definition:
ErsSarFacilityData.h:1582
ossimplugins::ErsSarFacilityData::get_max_error_range_line_timing
int get_max_error_range_line_timing() const
Definition:
ErsSarFacilityData.h:1077
ossimplugins::ErsSarFacilityData::get_out_image_max_value
double get_out_image_max_value() const
out_image_max_value
Definition:
ErsSarFacilityData.h:524
ossimplugins::ErsSarFacilityData::get_look_scalar_gain_1
double get_look_scalar_gain_1() const
look_scalar_gain_1
Definition:
ErsSarFacilityData.h:776
ossimplugins::ErsSarFacilityData::get_thresh_no_5_flag
double get_thresh_no_5_flag() const
thresh_no_5_flag
Definition:
ErsSarFacilityData.h:951
ossimplugins::ErsSarFacilityData::_noise_power
double _noise_power
noise_power
Definition:
ErsSarFacilityData.h:1330
ossimplugins::ErsSarFacilityData::get_low_bound_K
double get_low_bound_K() const
low_bound_K
Definition:
ErsSarFacilityData.h:468
ossimplugins::ErsSarFacilityData::ErsSarFacilityData
ErsSarFacilityData()
Constructor.
Definition:
ErsSarFacilityData.cpp:17
ossimplugins::ErsSarFacilityData::get_first_range_pixel_mid_az_inc
double get_first_range_pixel_mid_az_inc() const
Definition:
ErsSarFacilityData.h:419
ossimplugins::ErsSarFacilityData::_name_of_facil_rec
std::string _name_of_facil_rec
Definition:
ErsSarFacilityData.h:1178
ossimplugins::ErsSarFacilityData::get_samp_window_start_time_bias
int get_samp_window_start_time_bias() const
Definition:
ErsSarFacilityData.h:832
ossimplugins
Definition:
AlosPalsarData.cpp:26
ossimplugins::ErsSarFacilityData::get_first_side_lobe_level
double get_first_side_lobe_level() const
Definition:
ErsSarFacilityData.h:629
ossimplugins::ErsSarFacilityData::get_dopp_cent_conf_meas
double get_dopp_cent_conf_meas() const
dopp_cent_conf_meas
Definition:
ErsSarFacilityData.h:251
ossimplugins::ErsSarFacilityData::_sampling_win_change_flag
int _sampling_win_change_flag
Definition:
ErsSarFacilityData.h:1206
ossimplugins::ErsSarFacilityData::get_inp_state_vect_vel_Vy_comp
std::string get_inp_state_vect_vel_Vy_comp() const
Definition:
ErsSarFacilityData.h:734
ossimplugins::ErsSarFacilityData::get_inp_data_Q_mean
double get_inp_data_Q_mean() const
inp_data_Q_mean
Definition:
ErsSarFacilityData.h:272
ossimplugins::ErsSarFacilityData::_peak_loc_cross_correl_fun
int _peak_loc_cross_correl_fun
Definition:
ErsSarFacilityData.h:1482
ossimplugins::ErsSarFacilityData::get_coef_ant_elev_4
double get_coef_ant_elev_4() const
coef_ant_elev_4
Definition:
ErsSarFacilityData.h:1161
ossimplugins::ErsSarFacilityData::_I_gain_imb_lower_bound
double _I_gain_imb_lower_bound
I_gain_imb_lower_bound.
Definition:
ErsSarFacilityData.h:1714
ossimplugins::ErsSarFacilityData::_samples_per_line_used
int _samples_per_line_used
Definition:
ErsSarFacilityData.h:1522
ossimplugins::ErsSarFacilityData::_look_scalar_gain_8
double _look_scalar_gain_8
look_scalar_gain_8
Definition:
ErsSarFacilityData.h:1602
ossimplugins::ErsSarFacilityData::_num_valid_noise_pulses
int _num_valid_noise_pulses
Definition:
ErsSarFacilityData.h:1342
ossimplugins::ErsSarFacilityData::_update_period_range_match
int _update_period_range_match
Definition:
ErsSarFacilityData.h:1570
ossimplugins::ErsSarFacilityData::get_out_pixel_bit_length
int get_out_pixel_bit_length() const
Definition:
ErsSarFacilityData.h:587
ossimplugins::ErsSarFacilityData::_samp_win_start_last
int _samp_win_start_last
samp_win_start_last
Definition:
ErsSarFacilityData.h:1626
ossimplugins::ErsSarFacilityData::_cal_sys_gain
double _cal_sys_gain
cal_sys_gain
Definition:
ErsSarFacilityData.h:1298
ossimplugins::ErsSarFacilityData::_asc_node_pos_Y_comp
std::string _asc_node_pos_Y_comp
asc_node_pos_Y_comp
Definition:
ErsSarFacilityData.h:1446
ossimplugins::ErsSarFacilityData::get_norm_ref_range_ro
double get_norm_ref_range_ro() const
norm_ref_range_ro
Definition:
ErsSarFacilityData.h:440
ossimplugins::ErsSarFacilityData::_asc_node_pos_Z_comp
std::string _asc_node_pos_Z_comp
asc_node_pos_Z_comp
Definition:
ErsSarFacilityData.h:1450
ossimplugins::ErsSarFacilityData::_mean_cal_pulse_power
double _mean_cal_pulse_power
Definition:
ErsSarFacilityData.h:1354
ossimplugins::ErsSarFacilityData::get_sat_binary_time_of_first
int get_sat_binary_time_of_first() const
Definition:
ErsSarFacilityData.h:1000
ossimplugins::ErsSarFacilityData::_proc_noise_scale_fact
double _proc_noise_scale_fact
Definition:
ErsSarFacilityData.h:1402
ossimplugins::ErsSarFacilityData::get_doppler_ambiguity_estimat_flag
int get_doppler_ambiguity_estimat_flag() const
Definition:
ErsSarFacilityData.h:671
ossimplugins::ErsSarFacilityData::_thresh_no_1_flag
double _thresh_no_1_flag
thresh_no_1_flag
Definition:
ErsSarFacilityData.h:1658
ossimplugins::ErsSarFacilityData::get_rec_gain_changes
int get_rec_gain_changes() const
rec_gain_changes
Definition:
ErsSarFacilityData.h:223
ossimplugins::ErsSarFacilityData::_coef_ant_elev_2
double _coef_ant_elev_2
coef_ant_elev_2
Definition:
ErsSarFacilityData.h:1786
ossimplugins::ErsSarFacilityData::_thresh_no_11_flag
double _thresh_no_11_flag
thresh_no_11_flag
Definition:
ErsSarFacilityData.h:1698
ossimplugins::ErsSarFacilityData::get_Roll_Tilt_Mode_flag
int get_Roll_Tilt_Mode_flag() const
Roll_Tilt_Mode_flag.
Definition:
ErsSarFacilityData.h:650
ossimplugins::ErsSarFacilityData::_out_pixel_bit_length
int _out_pixel_bit_length
Definition:
ErsSarFacilityData.h:1466
ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Z_comp
std::string _inp_state_vect_pos_Z_comp
Definition:
ErsSarFacilityData.h:1542
ossimplugins::ErsSarFacilityData::get_inp_state_vect_vel_Vz_comp
std::string get_inp_state_vect_vel_Vz_comp() const
Definition:
ErsSarFacilityData.h:741
ossimplugins::ErsSarFacilityData::get_inp_state_vector_type_flag
int get_inp_state_vector_type_flag() const
Definition:
ErsSarFacilityData.h:748
ossimplugins::ErsSarFacilityData::get_K_gen_date
std::string get_K_gen_date() const
K_gen_date.
Definition:
ErsSarFacilityData.h:482
ossimplugins::ErsSarFacilityData::_3_dB_look_proc_dopp_bandw
double _3_dB_look_proc_dopp_bandw
Definition:
ErsSarFacilityData.h:1734
ossimplugins::ErsSarFacilityData::_num_range_samp_discarded
int _num_range_samp_discarded
Definition:
ErsSarFacilityData.h:1710
ossimplugins::ErsSarFacilityData::get_thresh_no_1_flag
double get_thresh_no_1_flag() const
thresh_no_1_flag
Definition:
ErsSarFacilityData.h:923
ossimplugins::ErsSarFacilityData::_outp_data_mean_flag
int _outp_data_mean_flag
outp_data_mean_flag
Definition:
ErsSarFacilityData.h:1234
ossimplugins::ErsSarFacilityData::get_sampling_win_change_flag
int get_sampling_win_change_flag() const
Definition:
ErsSarFacilityData.h:132
ossimplugins::ErsSarFacilityData::_K_gen_date
std::string _K_gen_date
K_gen_date.
Definition:
ErsSarFacilityData.h:1406
ossimplugins::ErsSarFacilityData::get_first_replica_sample
double get_first_replica_sample() const
Definition:
ErsSarFacilityData.h:384
ossimplugins::ErsSarFacilityData::_Roll_Tilt_Mode_flag
int _Roll_Tilt_Mode_flag
Definition:
ErsSarFacilityData.h:1502
ossimplugins::ErsSarFacilityData::get_initial_doppler_ambiguity_num
int get_initial_doppler_ambiguity_num() const
Definition:
ErsSarFacilityData.h:916
ossimplugins::ErsSarFacilityData::_azimuth_baseband_convers_flag
int _azimuth_baseband_convers_flag
Definition:
ErsSarFacilityData.h:1518
ossimplugins::ErsSarFacilityData::_max_error_range_line_timing
int _max_error_range_line_timing
Definition:
ErsSarFacilityData.h:1746
ossimplugins::ErsSarFacilityData::_inp_state_vector_type_flag
int _inp_state_vector_type_flag
Definition:
ErsSarFacilityData.h:1558
ossimplugins::ErsSarFacilityData::get_look_scalar_gain_3
double get_look_scalar_gain_3() const
look_scalar_gain_3
Definition:
ErsSarFacilityData.h:790
ossimplugins::ErsSarFacilityData::get_missing_lines
int get_missing_lines() const
missing_lines
Definition:
ErsSarFacilityData.h:216
ossimplugins::ErsSarFacilityData::get_look_scalar_gain_2
double get_look_scalar_gain_2() const
look_scalar_gain_2
Definition:
ErsSarFacilityData.h:783
ossimplugins::ErsSarFacilityData::_look_scalar_gain_1
double _look_scalar_gain_1
look_scalar_gain_1
Definition:
ErsSarFacilityData.h:1574
ossimplugins::ErsSarFacilityData::get_I_Q_quad_depar_lower_bound
double get_I_Q_quad_depar_lower_bound() const
I_Q_quad_depar_lower_bound.
Definition:
ErsSarFacilityData.h:1035
ossimplugins::ErsSarFacilityData::_cal_gain_change_flag
int _cal_gain_change_flag
Definition:
ErsSarFacilityData.h:1210
ossimplugins::ErsSarFacilityData::_thresh_no_10_flag
double _thresh_no_10_flag
thresh_no_10_flag
Definition:
ErsSarFacilityData.h:1694
ossimplugins::ErsSarFacilityData::get_OGOB_flag
int get_OGOB_flag() const
OGOB_flag.
Definition:
ErsSarFacilityData.h:188
ossimplugins::ErsSarFacilityData::get_num_azimuth_blocks_proc
int get_num_azimuth_blocks_proc() const
Definition:
ErsSarFacilityData.h:902
ossimplugins::ErsSarFacilityData::~ErsSarFacilityData
virtual ~ErsSarFacilityData()
Destructor.
Definition:
ErsSarFacilityData.cpp:21
ossimplugins::ErsSarFacilityData::get_asc_node_vel_X_comp
std::string get_asc_node_vel_X_comp() const
asc_node_vel_X_comp
Definition:
ErsSarFacilityData.h:566
ossimplugins::ErsSarFacilityData::get_num_valid_pixels_per_range
int get_num_valid_pixels_per_range() const
Definition:
ErsSarFacilityData.h:1007
ossimplugins::ErsSarFacilityData::_Q_channel_I_Q_correction
double _Q_channel_I_Q_correction
Q_channel_I_Q_correction.
Definition:
ErsSarFacilityData.h:1326
ossimplugins::ErsSarFacilityData::get_range_comp_norm_fact
double get_range_comp_norm_fact() const
Definition:
ErsSarFacilityData.h:405
ossimplugins::ErsSarFacilityData::get_coef_ground_range_3
double get_coef_ground_range_3() const
coef_ground_range_3
Definition:
ErsSarFacilityData.h:1126
ossimplugins::ErsSarFacilityData::get_coef_ground_range_1
double get_coef_ground_range_1() const
coef_ground_range_1
Definition:
ErsSarFacilityData.h:1112
ossimplugins::ErsSarFacilityData::_last_range_pix_mid_az_inc
double _last_range_pix_mid_az_inc
Definition:
ErsSarFacilityData.h:1378
ossimplugins::ErsSarFacilityData::get_Q_channel_I_Q_correction
double get_Q_channel_I_Q_correction() const
Definition:
ErsSarFacilityData.h:342
ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vy_comp
std::string _inp_state_vect_vel_Vy_comp
Definition:
ErsSarFacilityData.h:1550
ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_upper_bound
double _I_Q_quad_depar_upper_bound
Definition:
ErsSarFacilityData.h:1726
ossimplugins::ErsSarFacilityData::get_cal_gain_change_flag
int get_cal_gain_change_flag() const
Definition:
ossimplugins::ErsSarFacilityData::get_peak_loc_CCF_betw_last
int get_peak_loc_CCF_betw_last() const
Definition:
ErsSarFacilityData.h:643
ossimplugins::ErsSarFacilityData::get_int_cal_utc
int get_int_cal_utc() const
int_cal_utc
Definition:
ErsSarFacilityData.h:356
ossimplugins::ErsSarFacilityData::_int_cal_utc
int _int_cal_utc
int_cal_utc
Definition:
ErsSarFacilityData.h:1334
ossimplugins::ErsSarFacilityData::get_ISLR_of_ACF
double get_ISLR_of_ACF() const
ISLR_of_ACF.
Definition:
ErsSarFacilityData.h:244
ossimplugins::ErsSarFacilityData::get_look_scalar_gain_8
double get_look_scalar_gain_8() const
look_scalar_gain_8
Definition:
ErsSarFacilityData.h:825
ossimplugins::ErsSarFacilityData::_num_valid_pixels_per_range
int _num_valid_pixels_per_range
Definition:
ErsSarFacilityData.h:1706
ossimplugins::ErsSarFacilityData::get_look_scalar_gain_7
double get_look_scalar_gain_7() const
look_scalar_gain_7
Definition:
ErsSarFacilityData.h:818
ossimplugins::ErsSarFacilityData::_ISLR_of_ACF
double _ISLR_of_ACF
ISLR_of_ACF.
Definition:
ErsSarFacilityData.h:1270
ossimplugins::ErsSarFacilityData::_samp_window_start_time_bias
int _samp_window_start_time_bias
Definition:
ErsSarFacilityData.h:1606
This class is able to read the SAR leader data set summary record of the leader file.
Definition:
ossimplugins::ErsSarFacilityData::get_dopp_ambig_conf_meas
double get_dopp_ambig_conf_meas() const
Definition:
ErsSarFacilityData.h:258
ossimplugins::ErsSarFacilityData::get_coef_ground_range_4
double get_coef_ground_range_4() const
coef_ground_range_4
Definition:
ErsSarFacilityData.h:1133
ossimplugins::ErsSarFacilityData::_first_side_lobe_lev_of_ACF
double _first_side_lobe_lev_of_ACF
Definition:
ErsSarFacilityData.h:1266
ossimplugins::ErsSarFacilityData::get_datation_flag
bool get_datation_flag() const
datation_flag
Definition:
ErsSarFacilityData.h:1070
ossimplugins::ErsSarFacilityData::_first_range_pixel_mid_az_inc
double _first_range_pixel_mid_az_inc
Definition:
ErsSarFacilityData.h:1370
ossimplugins::ErsSarFacilityData::get_qa_summary_flag
int get_qa_summary_flag() const
qa_summary_flag
Definition:
ErsSarFacilityData.h:118
ossimplugins::ErsSarFacilityData::_thresh_no_4_flag
double _thresh_no_4_flag
thresh_no_4_flag
Definition:
ErsSarFacilityData.h:1670
ossimplugins::ErsSarFacilityData::get_first_processed_range_sample
int get_first_processed_range_sample() const
Definition:
ErsSarFacilityData.h:888
ossimplugins::ErsSarFacilityData::_time_of_inp_state_vectors
std::string _time_of_inp_state_vectors
Definition:
ErsSarFacilityData.h:1530
ossimplugins::ErsSarFacilityData::_rec_gain_changes
int _rec_gain_changes
rec_gain_changes
Definition:
ErsSarFacilityData.h:1258
ossimplugins::ErsSarFacilityData::_dopp_cent_val_flag
int _dopp_cent_val_flag
dopp_cent_val_flag
Definition:
ErsSarFacilityData.h:1226
ossimplugins::ErsSarFacilityData::_first_processed_range_sample
int _first_processed_range_sample
Definition:
ErsSarFacilityData.h:1638
ossimplugins::ErsSarFacilityData::get_inp_data_stat_flag
int get_inp_data_stat_flag() const
inp_data_stat_flag
Definition:
ossimplugins::ErsSarRecord
This class is the base class of all the record classes.
Definition:
ErsSarRecord.h:27
ossimplugins::ErsSarFacilityData::_Q_channel_gain_correction
double _Q_channel_gain_correction
Definition:
ErsSarFacilityData.h:1322
ossimplugins::ErsSarFacilityData::_sat_binary_time_of_first
int _sat_binary_time_of_first
Definition:
ErsSarFacilityData.h:1702
ossimplugins::ErsSarFacilityData::_thresh_no_2_flag
double _thresh_no_2_flag
thresh_no_2_flag
Definition:
ErsSarFacilityData.h:1662
ossimplugins::ErsSarFacilityData::get_raw_data_correction_flag
int get_raw_data_correction_flag() const
Definition:
ErsSarFacilityData.h:657
ossimplugins::ErsSarFacilityData::get_asc_node_pos_X_comp
std::string get_asc_node_pos_X_comp() const
asc_node_pos_X_comp
Definition:
ErsSarFacilityData.h:545
ossimplugins::ErsSarFacilityData::get_name_of_facil_rec
std::string get_name_of_facil_rec() const
name_of_facil_rec
Definition:
ErsSarFacilityData.h:96
ossimplugins::ErsSarFacilityData::get_time_asc_node_state_vectors
std::string get_time_asc_node_state_vectors() const
Definition:
ErsSarFacilityData.h:538
ossimplugins::ErsSarFacilityData::get_out_image_mean
double get_out_image_mean() const
out_image_mean
Definition:
ErsSarFacilityData.h:510
ossimplugins::ErsSarFacilityData::get_look_scalar_gain_4
double get_look_scalar_gain_4() const
look_scalar_gain_4
Definition:
ErsSarFacilityData.h:797
ossimplugins::ErsSarFacilityData::_coef_ground_range_1
double _coef_ground_range_1
coef_ground_range_1
Definition:
ErsSarFacilityData.h:1766
ossimplugins::ErsSarFacilityData::get_look_detecion_flag
int get_look_detecion_flag() const
look_detecion_flag
Definition:
ErsSarFacilityData.h:664
ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas_flag
int _dopp_cent_conf_meas_flag
Definition:
ErsSarFacilityData.h:1222
ossimplugins::ErsSarFacilityData::get_inp_data_I_stddev
double get_inp_data_I_stddev() const
inp_data_I_stddev
Definition:
ErsSarFacilityData.h:279
ossimplugins::ErsSarFacilityData::operator<<
friend std::ostream & operator<<(std::ostream &os, const ErsSarFacilityData &data)
This function write the ErsSarFacilityData in a stream.
Definition:
ErsSarFacilityData.cpp:25
ossimplugins::ErsSarFacilityData::_abs_cal_const_K
double _abs_cal_const_K
abs_cal_const_K
Definition:
ErsSarFacilityData.h:1390
ossimplugins::ErsSarFacilityData::get_upp_bound_K
double get_upp_bound_K() const
upp_bound_K
Definition:
ErsSarFacilityData.h:461
ossimplugins::ErsSarFacilityData::_thresh_no_3_flag
double _thresh_no_3_flag
thresh_no_3_flag
Definition:
ErsSarFacilityData.h:1666
ossimplugins::ErsSarFacilityData::get_thresh_no_7_flag
double get_thresh_no_7_flag() const
thresh_no_7_flag
Definition:
ErsSarFacilityData.h:965
ossimplugins::ErsSarFacilityData::get_num_duplic_input_lines
int get_num_duplic_input_lines() const
Definition:
ErsSarFacilityData.h:496
ossimplugins::ErsSarFacilityData::get_mean_cal_pulse_power
double get_mean_cal_pulse_power() const
Definition:
ErsSarFacilityData.h:391
ossimplugins::ErsSarFacilityData::get_time_of_inp_state_vectors
std::string get_time_of_inp_state_vectors() const
Definition:
ErsSarFacilityData.h:699
ossimplugins::ErsSarFacilityData::get_replica_norm_method_flag
int get_replica_norm_method_flag() const
Definition:
ErsSarFacilityData.h:1105
ossimplugins::ErsSarFacilityData::get_range_spread_loss_comp_flag
int get_range_spread_loss_comp_flag() const
Definition:
ErsSarFacilityData.h:1063
ossimplugins::ErsSarFacilityData::get_outp_data_mean_flag
int get_outp_data_mean_flag() const
outp_data_mean_flag
Definition:
ErsSarFacilityData.h:181
ossimplugins::ErsSarFacilityData::_asc_node_vel_Y_comp
std::string _asc_node_vel_Y_comp
asc_node_vel_Y_comp
Definition:
ErsSarFacilityData.h:1458
ossimplugins::ErsSarFacilityData::_sampling_win_changes
int _sampling_win_changes
Definition:
ErsSarFacilityData.h:1246
ossimplugins::ErsSarFacilityData::get_dopp_ambig_conf_meas_flag
int get_dopp_ambig_conf_meas_flag() const
Definition:
ossimplugins::ErsSarFacilityData::_norm_ref_range_ro
double _norm_ref_range_ro
norm_ref_range_ro
Definition:
ErsSarFacilityData.h:1382
ossimplugins::ErsSarFacilityData::_doppler_ambiguity_estimat_flag
int _doppler_ambiguity_estimat_flag
Definition:
ErsSarFacilityData.h:1514
ossimplugins::ErsSarFacilityData::_pulse_width_of_ACF_3db
double _pulse_width_of_ACF_3db
Definition:
ErsSarFacilityData.h:1262
ossimplugins::ErsSarFacilityData::_low_bound_K
double _low_bound_K
low_bound_K
Definition:
ErsSarFacilityData.h:1398
ossimplugins::ErsSarFacilityData::_num_input_raw_data_lines
int _num_input_raw_data_lines
Definition:
ErsSarFacilityData.h:1650
ossim::istream
std::basic_istream< char > istream
Base class for char input streams.
Definition:
ossimIosFwd.h:20
ossimplugins::ErsSarFacilityData::get_inp_state_vect_pos_Y_comp
std::string get_inp_state_vect_pos_Y_comp() const
Definition:
ErsSarFacilityData.h:713
ossimplugins::ErsSarFacilityData::get_samp_win_start_first
int get_samp_win_start_first() const
Definition:
ErsSarFacilityData.h:860
ossimplugins::ErsSarFacilityData::_look_scalar_gain_5
double _look_scalar_gain_5
look_scalar_gain_5
Definition:
ErsSarFacilityData.h:1590
ossimplugins::ErsSarFacilityData::get_I_gain_imb_upper_bound
double get_I_gain_imb_upper_bound() const
Definition:
ErsSarFacilityData.h:1028
ossimplugins::ErsSarFacilityData::get_win_coeff_for_range_match
double get_win_coeff_for_range_match() const
Definition:
ErsSarFacilityData.h:755
ossimplugins::ErsSarFacilityData::_asc_node_vel_Z_comp
std::string _asc_node_vel_Z_comp
asc_node_vel_Z_comp
Definition:
ErsSarFacilityData.h:1462
ossimplugins::ErsSarFacilityData::operator=
ErsSarFacilityData & operator=(const ErsSarFacilityData &rhs)
Copy operator.
Definition:
ErsSarFacilityData.cpp:1007
ossimplugins::ErsSarFacilityData::get_thresh_no_4_flag
double get_thresh_no_4_flag() const
thresh_no_4_flag
Definition:
ErsSarFacilityData.h:944
ossimplugins::ErsSarFacilityData::_inp_data_I_mean
double _inp_data_I_mean
inp_data_I_mean
Definition:
ErsSarFacilityData.h:1282
ossimplugins::ErsSarFacilityData::get_I_channel_bias_correction
double get_I_channel_bias_correction() const
I_channel_bias_correction.
Definition:
ErsSarFacilityData.h:314
ossimplugins::ErsSarFacilityData::_doppler_centroid_cubic_coeff
double _doppler_centroid_cubic_coeff
Definition:
ErsSarFacilityData.h:1610
ossimplugins::ErsSarFacilityData::_thresh_no_9_flag
double _thresh_no_9_flag
thresh_no_9_flag
Definition:
ErsSarFacilityData.h:1690
ossimplugins::ErsSarFacilityData::get_PRF_code_last_range_line
int get_PRF_code_last_range_line() const
PRF_code_last_range_line.
Definition:
ErsSarFacilityData.h:853
ossimplugins::ErsSarFacilityData::_antenna_elev_flag
int _antenna_elev_flag
antenna_elev_flag
Definition:
ErsSarFacilityData.h:1386
ossimplugins::ErsSarFacilityData::_look_scalar_gain_6
double _look_scalar_gain_6
look_scalar_gain_6
Definition:
ErsSarFacilityData.h:1594
ossimplugins::ErsSarFacilityData::_coef_ant_elev_1
double _coef_ant_elev_1
coef_ant_elev_1
Definition:
ErsSarFacilityData.h:1782
ossimplugins::ErsSarFacilityData::get_update_period_range_match
int get_update_period_range_match() const
Definition:
ErsSarFacilityData.h:769
ossimplugins::ErsSarFacilityData::_3_dB_look_bandwidth
double _3_dB_look_bandwidth
3_dB_look_bandwidth
Definition:
ErsSarFacilityData.h:1730
ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas
double _dopp_ambig_conf_meas
Definition:
ErsSarFacilityData.h:1278
ossimplugins::ErsSarFacilityData::get_samples_per_line_used
int get_samples_per_line_used() const
Definition:
ErsSarFacilityData.h:685
ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Y_comp
std::string _inp_state_vect_pos_Y_comp
Definition:
ErsSarFacilityData.h:1538
ossimplugins::ErsSarFacilityData::_receiver_gain_last_proc
int _receiver_gain_last_proc
Definition:
ErsSarFacilityData.h:1634
ossimplugins::ErsSarFacilityData::get_num_valid_noise_pulses
int get_num_valid_noise_pulses() const
Definition:
ErsSarFacilityData.h:370
ossimplugins::ErsSarFacilityData::get_num_input_raw_data_lines
int get_num_input_raw_data_lines() const
Definition:
ErsSarFacilityData.h:909
ossimplugins::ErsSarFacilityData::_time_asc_node_state_vectors
std::string _time_asc_node_state_vectors
Definition:
ErsSarFacilityData.h:1438
ossimplugins::ErsSarFacilityData::get_3_dB_look_proc_dopp_bandw
double get_3_dB_look_proc_dopp_bandw() const
Definition:
ErsSarFacilityData.h:1056
ossimplugins::ErsSarFacilityData::get_dopp_ambig_num
double get_dopp_ambig_num() const
dopp_ambig_num
Definition:
ErsSarFacilityData.h:307
ossimplugins::ErsSarFacilityData::_proc_gain_param_1
double _proc_gain_param_1
proc_gain_param_1
Definition:
ErsSarFacilityData.h:1470
ossimplugins::ErsSarFacilityData::_look_scalar_gain_2
double _look_scalar_gain_2
look_scalar_gain_2
Definition:
ErsSarFacilityData.h:1578
ossimplugins::ErsSarFacilityData::get_prf_code_change_flag
int get_prf_code_change_flag() const
Definition:
ossimplugins::ErsSarFacilityData::get_asc_node_pos_Z_comp
std::string get_asc_node_pos_Z_comp() const
asc_node_pos_Z_comp
Definition:
ErsSarFacilityData.h:559
ossimplugins::ErsSarFacilityData::get_first_rec_gain_read
double get_first_rec_gain_read() const
first_rec_gain_read
Definition:
ErsSarFacilityData.h:300
ossimplugins::ErsSarFacilityData::get_asc_node_vel_Z_comp
std::string get_asc_node_vel_Z_comp() const
asc_node_vel_Z_comp
Definition:
ErsSarFacilityData.h:580
ossimplugins::ErsSarFacilityData::get_coef_ant_elev_5
double get_coef_ant_elev_5() const
coef_ant_elev_5
Definition:
ErsSarFacilityData.h:1168
ossimplugins::ErsSarFacilityData::get_last_release_qc_date
std::string get_last_release_qc_date() const
Definition:
ossimplugins::ErsSarFacilityData::get_samp_win_start_last
int get_samp_win_start_last() const
samp_win_start_last
Definition:
ErsSarFacilityData.h:867
ErsSarRecord.h
ossimplugins::ErsSarFacilityData::_out_image_max_value
double _out_image_max_value
out_image_max_value
Definition:
ErsSarFacilityData.h:1430
ossimplugins::ErsSarFacilityData::_I_channel_bias_correction
double _I_channel_bias_correction
Definition:
ErsSarFacilityData.h:1310
ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vx_comp
std::string _inp_state_vect_vel_Vx_comp
Definition:
ErsSarFacilityData.h:1546
ossimplugins::ErsSarFacilityData::_inp_data_Q_mean
double _inp_data_Q_mean
inp_data_Q_mean
Definition:
ErsSarFacilityData.h:1286
ossimplugins::ErsSarFacilityData::get_proc_gain_param_1
double get_proc_gain_param_1() const
proc_gain_param_1
Definition:
ErsSarFacilityData.h:594
ossimplugins::ErsSarFacilityData::get_thresh_no_3_flag
double get_thresh_no_3_flag() const
thresh_no_3_flag
Definition:
ErsSarFacilityData.h:937
ossimplugins::ErsSarFacilityData::get_last_range_pix_mid_az_inc
double get_last_range_pix_mid_az_inc() const
Definition:
ErsSarFacilityData.h:433
ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_lower_bound
double _I_Q_quad_depar_lower_bound
Definition:
ErsSarFacilityData.h:1722
ossimplugins::ErsSarFacilityData::_inp_data_I_stddev
double _inp_data_I_stddev
inp_data_I_stddev
Definition:
ErsSarFacilityData.h:1290
ossimplugins::ErsSarFacilityData::_K_vers_num
std::string _K_vers_num
K_vers_num.
Definition:
ErsSarFacilityData.h:1410
ossimplugins::ErsSarFacilityData::_range_lines_skip_factor
int _range_lines_skip_factor
Definition:
ErsSarFacilityData.h:1526
ossimplugins::ErsSarFacilityData::get_replica_power
double get_replica_power() const
replica_power
Definition:
ErsSarFacilityData.h:412
ossimplugins::ErsSarFacilityData::_win_coeff_for_azi_match
double _win_coeff_for_azi_match
Definition:
ErsSarFacilityData.h:1566
ossimplugins::ErsSarFacilityData::get_out_image_std_dev
double get_out_image_std_dev() const
out_image_std_dev
Definition:
ErsSarFacilityData.h:517
ossimplugins::ErsSarFacilityData::get_proc_noise_scale_fact
double get_proc_noise_scale_fact() const
Definition:
ErsSarFacilityData.h:475
double _dopp_cent_conf_meas
dopp_cent_conf_meas
Definition:
ErsSarFacilityData.h:1274
ossimplugins::ErsSarFacilityData::get_proc_gain_param_3
double get_proc_gain_param_3() const
proc_gain_param_3
Definition:
ErsSarFacilityData.h:608
ossimplugins::ErsSarFacilityData::_last_release_qc_date
std::string _last_release_qc_date
Definition:
ErsSarFacilityData.h:1190
ossimplugins::ErsSarFacilityData::_asc_node_vel_X_comp
std::string _asc_node_vel_X_comp
asc_node_vel_X_comp
Definition:
ErsSarFacilityData.h:1454
ossimplugins::ErsSarFacilityData::get_win_coeff_for_azi_match
double get_win_coeff_for_azi_match() const
Definition:
ErsSarFacilityData.h:762
ossimplugins::ErsSarFacilityData::_replica_norm_method_flag
int _replica_norm_method_flag
Definition:
ErsSarFacilityData.h:1762
ossimplugins::ErsSarFacilityData::get_thresh_no_8_flag
double get_thresh_no_8_flag() const
thresh_no_8_flag
Definition:
ErsSarFacilityData.h:972
ossimplugins::ErsSarFacilityData::get_I_gain_imb_lower_bound
double get_I_gain_imb_lower_bound() const
Definition:
ErsSarFacilityData.h:1021
ossimplugins::ErsSarFacilityData::_num_valid_cal_pulses
int _num_valid_cal_pulses
Definition:
ErsSarFacilityData.h:1338
ossimplugins::ErsSarFacilityData::_raw_data_correction_flag
int _raw_data_correction_flag
Definition:
ErsSarFacilityData.h:1506
ossimplugins::ErsSarFacilityData::_peak_loc_CCF_betw_last
int _peak_loc_CCF_betw_last
Definition:
ErsSarFacilityData.h:1498
ossimplugins::ErsSarFacilityData::get_asc_node_pos_Y_comp
std::string get_asc_node_pos_Y_comp() const
asc_node_pos_Y_comp
Definition:
ErsSarFacilityData.h:552
ossimplugins::ErsSarFacilityData::get_pulse_width_of_ACF_3db
double get_pulse_width_of_ACF_3db() const
Definition:
ErsSarFacilityData.h:230
ossimplugins::ErsSarFacilityData::_look_scalar_gain_4
double _look_scalar_gain_4
look_scalar_gain_4
Definition:
ErsSarFacilityData.h:1586
ossimplugins::ErsSarFacilityData::get_dopp_cent_conf_meas_flag
int get_dopp_cent_conf_meas_flag() const
Definition:
ossimplugins::ErsSarFacilityData::get_num_range_samp_discarded
int get_num_range_samp_discarded() const
Definition:
ErsSarFacilityData.h:1014
ossimplugins::ErsSarFacilityData::_num_duplic_input_lines
int _num_duplic_input_lines
Definition:
ErsSarFacilityData.h:1414
ossimplugins::ErsSarFacilityData::_OGOB_flag
int _OGOB_flag
OGOB_flag.
Definition:
ErsSarFacilityData.h:1238
ossimplugins::ErsSarFacilityData::get_antenna_elev_flag
int get_antenna_elev_flag() const
antenna_elev_flag
Definition:
ErsSarFacilityData.h:447
ossimplugins::ErsSarFacilityData::get_coef_ground_range_2
double get_coef_ground_range_2() const
coef_ground_range_2
Definition:
ErsSarFacilityData.h:1119
ossimplugins::ErsSarFacilityData::_PRF_code_last_range_line
int _PRF_code_last_range_line
Definition:
ErsSarFacilityData.h:1618
ossimplugins::ErsSarFacilityData::get_last_release_cal_date
std::string get_last_release_cal_date() const
Definition:
ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas_flag
int _dopp_ambig_conf_meas_flag
Definition:
ErsSarFacilityData.h:1230
ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_X_comp
std::string _inp_state_vect_pos_X_comp
Definition:
ErsSarFacilityData.h:1534
ossimplugins::ErsSarFacilityData::get_max_value_look_scalar_gain
int get_max_value_look_scalar_gain() const
Definition:
ErsSarFacilityData.h:1098
ossimplugins::ErsSarFacilityData::_ISLR_CCF_between_last
double _ISLR_CCF_between_last
Definition:
ErsSarFacilityData.h:1494
ossimplugins::ErsSarFacilityData::_out_image_mean
double _out_image_mean
out_image_mean
Definition:
ErsSarFacilityData.h:1422
ossimplugins::ErsSarFacilityData::_num_azimuth_blocks_proc
int _num_azimuth_blocks_proc
Definition:
ErsSarFacilityData.h:1646
ossimplugins::ErsSarFacilityData::get_K_vers_num
std::string get_K_vers_num() const
K_vers_num.
Definition:
ErsSarFacilityData.h:489
ossimplugins::ErsSarFacilityData::_inp_data_stat_flag
int _inp_data_stat_flag
inp_data_stat_flag
Definition:
ErsSarFacilityData.h:1218
ossimplugins::ErsSarFacilityData::_win_coeff_for_range_match
double _win_coeff_for_range_match
Definition:
ErsSarFacilityData.h:1562
ossimplugins::ErsSarFacilityData::_coef_ground_range_4
double _coef_ground_range_4
coef_ground_range_4
Definition:
ErsSarFacilityData.h:1778
ossimplugins::ErsSarFacilityData::get_thresh_no_11_flag
double get_thresh_no_11_flag() const
thresh_no_11_flag
Definition:
ErsSarFacilityData.h:993
ossimplugins::ErsSarFacilityData::get_noise_power
double get_noise_power() const
noise_power
Definition:
ErsSarFacilityData.h:349
ossimplugins::ErsSarFacilityData::get_cal_gain_changes
int get_cal_gain_changes() const
cal_gain_changes
Definition:
ErsSarFacilityData.h:209
ossimplugins::ErsSarFacilityData::_range_spread_loss_comp_flag
int _range_spread_loss_comp_flag
Definition:
ErsSarFacilityData.h:1738
ossimplugins::ErsSarFacilityData::_cal_syst_gain_last_proc
int _cal_syst_gain_last_proc
Definition:
ErsSarFacilityData.h:1630
ossimplugins::ErsSarFacilityData::_qa_summary_flag
int _qa_summary_flag
qa_summary_flag
Definition:
ErsSarFacilityData.h:1198
ossimplugins::ErsSarFacilityData::_PRF_changes
int _PRF_changes
PRF_changes.
Definition:
ErsSarFacilityData.h:1242
ossim::ostream
std::basic_ostream< char > ostream
Base class for char output streams.
Definition:
ossimIosFwd.h:23
ossimplugins::ErsSarFacilityData::get_thresh_no_6_flag
double get_thresh_no_6_flag() const
thresh_no_6_flag
Definition:
ErsSarFacilityData.h:958
ossimplugins::ErsSarFacilityData::_first_side_lobe_level
double _first_side_lobe_level
Definition:
ErsSarFacilityData.h:1490
ossimplugins::ErsSarFacilityData::get_receiver_gain_last_proc
int get_receiver_gain_last_proc() const
Definition:
ErsSarFacilityData.h:881
ossimplugins::ErsSarFacilityData::get_range_time_origin_ant
double get_range_time_origin_ant() const
Definition:
ErsSarFacilityData.h:1175
ossimplugins::ErsSarFacilityData::get_center_range_pix_mid_az_inc
double get_center_range_pix_mid_az_inc() const
Definition:
ErsSarFacilityData.h:426
ossimplugins::ErsSarFacilityData::_cal_gain_changes
int _cal_gain_changes
cal_gain_changes
Definition:
ErsSarFacilityData.h:1250
ossimplugins::ErsSarFacilityData::_thresh_no_5_flag
double _thresh_no_5_flag
thresh_no_5_flag
Definition:
ErsSarFacilityData.h:1674
ossimplugins::ErsSarFacilityData::_Q_channel_bias_correction
double _Q_channel_bias_correction
Definition:
ErsSarFacilityData.h:1314
Generated on Fri Aug 3 2018 08:46:44 for OSSIM - Open Source Software Image Map by
