ImageOptionsFileDescriptor.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // "Copyright Centre National d'Etudes Spatiales"
4 //
5 // License: LGPL
6 //
7 // See LICENSE.txt file in the top level directory for more details.
8 //
9 //----------------------------------------------------------------------------
10 // $Id$
11
13 #include <ossim/base/ossimNotify.h>
14 #include <ossim/base/ossimTrace.h>
15
16 namespace ossimplugins
17 {
18  static ossimTrace traceDebug("ImageOptionsFileDescriptor:debug");
19
21  {
22  }
23
25  {
26  }
27
29  {
30  os<<"ascii_flag:"<<data._ascii_flag.c_str()<<std::endl;
31
32  os<<"format_doc:"<<data._format_doc.c_str()<<std::endl;
33
34  os<<"format_rev:"<<data._format_rev.c_str()<<std::endl;
35
36  os<<"design_rev:"<<data._design_rev.c_str()<<std::endl;
37
38  os<<"software_id:"<<data._software_id.c_str()<<std::endl;
39
40  os<<"file_num:"<<data._file_num<<std::endl;
41
42  os<<"file_name:"<<data._file_name.c_str()<<std::endl;
43
44  os<<"rec_seq:"<<data._rec_seq.c_str()<<std::endl;
45
46  os<<"seq_loc:"<<data._seq_loc<<std::endl;
47
48  os<<"seq_len:"<<data._seq_len<<std::endl;
49
50  os<<"rec_code:"<<data._rec_code.c_str()<<std::endl;
51
52  os<<"code_loc:"<<data._code_loc<<std::endl;
53
54  os<<"code_len:"<<data._code_len<<std::endl;
55
56  os<<"rec_len:"<<data._rec_len.c_str()<<std::endl;
57
58  os<<"rlen_loc:"<<data._rlen_loc<<std::endl;
59
60  os<<"rlen_len:"<<data._rlen_len<<std::endl;
61
62  os<<"n_dataset:"<<data._n_dataset<<std::endl;
63
64  os<<"l_dataset:"<<data._l_dataset<<std::endl;
65
66  os<<"nbit:"<<data._nbit<<std::endl;
67
68  os<<"nsamp:"<<data._nsamp<<std::endl;
69
70  os<<"nbyte:"<<data._nbyte<<std::endl;
71
72  os<<"justify:"<<data._justify.c_str()<<std::endl;
73
74  os<<"nchn:"<<data._nchn<<std::endl;
75
76  os<<"nlin:"<<data._nlin<<std::endl;
77
78  os<<"nleft:"<<data._nleft<<std::endl;
79
80  os<<"ngrp:"<<data._ngrp<<std::endl;
81
82  os<<"nright:"<<data._nright<<std::endl;
83
84  os<<"ntop:"<<data._ntop<<std::endl;
85
86  os<<"nbott:"<<data._nbott<<std::endl;
87
88  os<<"intleav:"<<data._intleav.c_str()<<std::endl;
89
90  os<<"nrec_lin:"<<data._nrec_lin<<std::endl;
91
92  os<<"nrec_chn:"<<data._nrec_chn<<std::endl;
93
94  os<<"n_prefix:"<<data._n_prefix<<std::endl;
95
96  os<<"n_sar:"<<data._n_sar<<std::endl;
97
98  os<<"n_suffix:"<<data._n_suffix<<std::endl;
99
100  os<<"lin_loc:"<<data._lin_loc.c_str()<<std::endl;
101
102  os<<"chn_loc:"<<data._chn_loc.c_str()<<std::endl;
103
104  os<<"tim_loc:"<<data._tim_loc.c_str()<<std::endl;
105
106  os<<"left_loc:"<<data._left_loc.c_str()<<std::endl;
107
108  os<<"right_loc:"<<data._right_loc.c_str()<<std::endl;
109
110  os<<"pad_ind:"<<data._pad_ind.c_str()<<std::endl;
111
112  os<<"qual_loc:"<<data._qual_loc.c_str()<<std::endl;
113
114  os<<"cali_loc:"<<data._cali_loc.c_str()<<std::endl;
115
116  os<<"gain_loc:"<<data._gain_loc.c_str()<<std::endl;
117
118  os<<"bias_loc:"<<data._bias_loc.c_str()<<std::endl;
119
120  os<<"type_id:"<<data._type_id.c_str()<<std::endl;
121
122  os<<"type_code:"<<data._type_code.c_str()<<std::endl;
123
124  os<<"left_fill:"<<data._left_fill<<std::endl;
125
126  os<<"right_fill:"<<data._right_fill<<std::endl;
127
128  os<<"pix_rng:"<<data._pix_rng<<std::endl;
129
130  return os;
131  }
132
134  {
135  char buf[15805];
136  buf[15804] = '\0';
137
138  is.read(buf,2);
139  buf[2] = '\0';
140  data._ascii_flag = buf;
141
142  is.read(buf,2);
143
144  is.read(buf,12);
145  buf[12] = '\0';
146  data._format_doc = buf;
147
148  is.read(buf,2);
149  buf[2] = '\0';
150  data._format_rev = buf;
151
152  is.read(buf,2);
153  buf[2] = '\0';
154  data._design_rev = buf;
155
156  is.read(buf,12);
157  buf[12] = '\0';
158  data._software_id = buf;
159
160  is.read(buf,4);
161  buf[4] = '\0';
162  data._file_num = atoi(buf);
163
164  is.read(buf,16);
165  buf[16] = '\0';
166  data._file_name = buf;
167
168  is.read(buf,4);
169  buf[4] = '\0';
170  data._rec_seq = buf;
171
172  is.read(buf,8);
173  buf[8] = '\0';
174  data._seq_loc = atoi(buf);
175
176  is.read(buf,4);
177  buf[4] = '\0';
178  data._seq_len = atoi(buf);
179
180  is.read(buf,4);
181  buf[4] = '\0';
182  data._rec_code = buf;
183
184  is.read(buf,8);
185  buf[8] = '\0';
186  data._code_loc = atoi(buf);
187
188  is.read(buf,4);
189  buf[4] = '\0';
190  data._code_len = atoi(buf);
191
192  is.read(buf,4);
193  buf[4] = '\0';
194  data._rec_len = buf;
195
196  is.read(buf,8);
197  buf[8] = '\0';
198  data._rlen_loc = atoi(buf);
199
200  is.read(buf,4);
201  buf[4] = '\0';
202  data._rlen_len = atoi(buf);
203
204  for (int i=0;i<4;i++)
205  {
206  is.read(buf,1);
207  }
208
209  is.read(buf,64);
210
211  is.read(buf,6);
212  buf[6] = '\0';
213  data._n_dataset = atoi(buf);
214
215  is.read(buf,6);
216  buf[6] = '\0';
217  data._l_dataset = atoi(buf);
218
219  is.read(buf,24);
220
221  is.read(buf,4);
222  buf[4] = '\0';
223  data._nbit = atoi(buf);
224
225  is.read(buf,4);
226  buf[4] = '\0';
227  data._nsamp = atoi(buf);
228
229  is.read(buf,4);
230  buf[4] = '\0';
231  data._nbyte = atoi(buf);
232
233  is.read(buf,4);
234  buf[4] = '\0';
235  data._justify = buf;
236
237  is.read(buf,4);
238  buf[4] = '\0';
239  data._nchn = atoi(buf);
240
241  is.read(buf,8);
242  buf[8] = '\0';
243
244  // We should use strtol() to avoid wrong conversion with atoi()
245  char* p;
246  int result = strtol(buf, &p, 10);
247  if ( *p != 0 || p == buf)
248  {
249  if(traceDebug())
250  {
251  ossimNotify(ossimNotifyLevel_DEBUG) << "WARNING: strtol() try to convert an empty tab of characters. It may be possible in case of SCN and SCW format" << buf << "!" << std::endl;
252  ossimNotify(ossimNotifyLevel_DEBUG) << "=> _nlin = -1" << std::endl;
253  }
254  data._nlin = -1;
255  }
256  else
257  {
258  data._nlin = result;
259  };
260
261  is.read(buf,4);
262  buf[4] = '\0';
263  data._nleft = atoi(buf);
264
265  is.read(buf,8);
266  buf[8] = '\0';
267  data._ngrp = atoi(buf);
268
269  is.read(buf,4);
270  buf[4] = '\0';
271  data._nright = atoi(buf);
272
273  is.read(buf,4);
274  buf[4] = '\0';
275  data._ntop = atoi(buf);
276
277  is.read(buf,4);
278  buf[4] = '\0';
279  data._nbott = atoi(buf);
280
281  is.read(buf,4);
282  buf[4] = '\0';
283  data._intleav = buf;
284
285  is.read(buf,2);
286  buf[2] = '\0';
287  data._nrec_lin = atoi(buf);
288
289  is.read(buf,2);
290  buf[2] = '\0';
291  data._nrec_chn = atoi(buf);
292
293  is.read(buf,4);
294  buf[4] = '\0';
295  data._n_prefix = atoi(buf);
296
297  is.read(buf,8);
298  buf[8] = '\0';
299  data._n_sar = atoi(buf);
300
301  is.read(buf,4);
302  buf[4] = '\0';
303  data._n_suffix = atoi(buf);
304
305  is.read(buf,4);
306
307  is.read(buf,8);
308  buf[8] = '\0';
309  data._lin_loc = buf;
310
311  is.read(buf,8);
312  buf[8] = '\0';
313  data._chn_loc = buf;
314
315  is.read(buf,8);
316  buf[8] = '\0';
317  data._tim_loc = buf;
318
319  is.read(buf,8);
320  buf[8] = '\0';
321  data._left_loc = buf;
322
323  is.read(buf,8);
324  buf[8] = '\0';
325  data._right_loc = buf;
326
327  is.read(buf,4);
328  buf[4] = '\0';
329  data._pad_ind = buf;
330
331  is.read(buf,28);
332
333  is.read(buf,8);
334  buf[8] = '\0';
335  data._qual_loc = buf;
336
337  is.read(buf,8);
338  buf[8] = '\0';
339  data._cali_loc = buf;
340
341  is.read(buf,8);
342  buf[8] = '\0';
343  data._gain_loc = buf;
344
345  is.read(buf,8);
346  buf[8] = '\0';
347  data._bias_loc = buf;
348
349  is.read(buf,28);
350  buf[28] = '\0';
351  data._type_id = buf;
352
353  is.read(buf,4);
354  buf[4] = '\0';
355  data._type_code = buf;
356
357  is.read(buf,4);
358  buf[4] = '\0';
359  data._left_fill = atoi(buf);
360
361  is.read(buf,4);
362  buf[4] = '\0';
363  data._right_fill = atoi(buf);
364
365  is.read(buf,8);
366  buf[8] = '\0';
367  data._pix_rng = atoi(buf);
368
369  is.read(buf,15804);
370
371  return is;
372  }
373
375  RadarSatRecord(rhs)
376  {
377
378
379  }
380
382  {
383  return *this;
384  }
385 }
std::string _rec_len
Record length/location flag
int _nrec_lin
Number of physical records per line
ImageOptionsFileDescriptor & operator=(const ImageOptionsFileDescriptor &rhs)
Copy operator.
int _n_sar
Number of bytes of SAR data (or pixel data) per record
std::string _justify
Sample justification and order
int _n_suffix
Number of bytes of suffix data per record
This class is the base class of all the record classes.
std::string _design_rev
File design revision
std::string _rec_code
Record code/location flag
std::ostream & operator<<(std::ostream &os, const AlosPalsarData &data)
std::string _rec_seq
Record sequence/location flag
std::istream & operator>>(std::istream &is, AlosPalsarData &data)
std::string _format_doc
Format control document
This class is able to read an Image options file descriptor record.
std::string _cali_loc
Calibration info locator
std::basic_istream< char > istream
Base class for char input streams.
Definition: ossimIosFwd.h:20
int _n_prefix
Number of bytes of prefix data per record
std::string _chn_loc
Channel number locator
int _nrec_chn
Number of physical records per multi-channel line in this file
std::string _format_rev
Format document revision
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
