Macros | Functions
cholesky.cpp File Reference
#include <cmath>
#include <ossim/matrix/include.h>
#include <ossim/matrix/newmat.h>
#include <ossim/matrix/newmatrm.h>
Go to the source code of this file.
Macros
#define WANT_MATH
#define REPORT   {}
Functions
ReturnMatrix Cholesky (const SymmetricMatrix &S)
ReturnMatrix Cholesky (const SymmetricBandMatrix &S)
void UpdateCholesky (UpperTriangularMatrix &chol, RowVector r1Modification)
void DowndateCholesky (UpperTriangularMatrix &chol, RowVector x)
void RightCircularUpdateCholesky (UpperTriangularMatrix &chol, int k, int l)
void LeftCircularUpdateCholesky (UpperTriangularMatrix &chol, int k, int l)
Macro Definition Documentation
◆ REPORT
#define REPORT   {}
Definition at line 21 of file cholesky.cpp.
Referenced by Cholesky().
◆ WANT_MATH
#define WANT_MATH
Definition at line 5 of file cholesky.cpp.
Function Documentation
◆ Cholesky() [1/2]
ReturnMatrix Cholesky ( const SymmetricMatrix S)
Definition at line 30 of file cholesky.cpp.
References GeneralMatrix::ForReturn(), GeneralMatrix::Nrows(), GeneralMatrix::Release(), REPORT, ossim::square(), and GeneralMatrix::Store().
Referenced by MLE_D_FI::NextPoint().
31 {
32  REPORT
33  Tracer trace("Cholesky");
34  int nr = S.Nrows();
36  Real* s = S.Store(); Real* t = T.Store(); Real* ti = t;
37  for (int i=0; i<nr; i++)
38  {
39  Real* tj = t; Real sum; int k;
40  for (int j=0; j<i; j++)
41  {
42  Real* tk = ti; sum = 0.0; k = j;
43  while (k--) { sum += *tj++ * *tk++; }
44  *tk = (*s++ - sum) / *tj++;
45  }
46  sum = 0.0; k = i;
47  while (k--) { sum += square(*ti++); }
48  Real d = *s++ - sum;
49  if (d<=0.0) Throw(NPDException(S));
50  *ti++ = std::sqrt(d);
51  }
52  T.Release(); return T.ForReturn();
53 }
double Real
Definition: include.h:57
T square(T x)
Definition: ossimCommon.h:334
#define REPORT
Definition: cholesky.cpp:21
int Nrows() const
Definition: newmat.h:430
Real * Store() const
Definition: newmat.h:433
◆ Cholesky() [2/2]
ReturnMatrix Cholesky ( const SymmetricBandMatrix S)
Definition at line 55 of file cholesky.cpp.
References GeneralMatrix::ForReturn(), SymmetricBandMatrix::lower, GeneralMatrix::Nrows(), GeneralMatrix::Release(), REPORT, ossim::square(), and GeneralMatrix::Store().
56 {
57  REPORT
58  Tracer trace("Band-Cholesky");
59  int nr = S.Nrows(); int m = S.lower;
60  LowerBandMatrix T(nr,m);
61  Real* s = S.Store(); Real* t = T.Store(); Real* ti = t;
62
63  for (int i=0; i<nr; i++)
64  {
65  Real* tj = t; Real sum; int l;
66  if (i<m) { REPORT l = m-i; s += l; ti += l; l = i; }
67  else { REPORT t += (m+1); l = m; }
68
69  for (int j=0; j<l; j++)
70  {
71  Real* tk = ti; sum = 0.0; int k = j; tj += (m-j);
72  while (k--) { sum += *tj++ * *tk++; }
73  *tk = (*s++ - sum) / *tj++;
74  }
75  sum = 0.0;
76  while (l--) { sum += square(*ti++); }
77  Real d = *s++ - sum;
78  if (d<=0.0) Throw(NPDException(S));
79  *ti++ = std::sqrt(d);
80  }
81
82  T.Release(); return T.ForReturn();
83 }
double Real
T square(T x)
#define REPORT
int Nrows() const
◆ DowndateCholesky()
void DowndateCholesky ( UpperTriangularMatrix chol,
RowVector  x
Definition at line 123 of file cholesky.cpp.
References GivensRotation(), GeneralMatrix::Nrows(), pythag(), GeneralMatrix::SumSquare(), BaseMatrix::t(), and x.
124 {
125  int nRC = chol.Nrows();
126
127  // solve R^T a = x
128  LowerTriangularMatrix L = chol.t();
129  ColumnVector a(nRC); a = 0.0;
130  int i, j;
131
132  for (i = 1; i <= nRC; ++i)
133  {
134  // accumulate subtr sum
135  Real subtrsum = 0.0;
136  for(int k = 1; k < i; ++k) subtrsum += a(k) * L(i,k);
137
138  a(i) = (x(i) - subtrsum) / L(i,i);
139  }
140
141  // test that l2 norm of a is < 1
142  Real squareNormA = a.SumSquare();
143  if (squareNormA >= 1.0)
144  Throw(ProgramException("DowndateCholesky() fails", chol));
145
146  Real alpha = std::sqrt(1.0 - squareNormA);
147
148  // compute and apply Givens rotations to the vector a
149  ColumnVector cGivens(nRC); cGivens = 0.0;
150  ColumnVector sGivens(nRC); sGivens = 0.0;
151  for(i = nRC; i >= 1; i--)
152  alpha = pythag(alpha, a(i), cGivens(i), sGivens(i));
153
154  // apply Givens rotations to the jth column of chol
155  ColumnVector xtilde(nRC); xtilde = 0.0;
156  for(j = nRC; j >= 1; j--)
157  {
158  // only the first j rotations have an affect on chol,0
159  for(int k = j; k >= 1; k--)
160  GivensRotation(cGivens(k), -sGivens(k), chol(k,j), xtilde(j));
161  }
162 }
ossim_uint32 x
void GivensRotation(Real cGivens, Real sGivens, Real &x, Real &y)
Definition: newmatrm.h:116
double Real
Real pythag(Real f, Real g, Real &c, Real &s)
Definition: newmatrm.cpp:186
int Nrows() const
TransposedMatrix t() const
Definition: newmat6.cpp:316
◆ LeftCircularUpdateCholesky()
void LeftCircularUpdateCholesky ( UpperTriangularMatrix chol,
int  k,
int  l
Definition at line 225 of file cholesky.cpp.
References BaseMatrix::Column(), GivensRotationR(), GeneralMatrix::Nrows(), and pythag().
226 {
227  int nRC = chol.Nrows();
228  int i, j;
229
230  // I. compute shift of column k to the lth position
231  Matrix cholCopy = chol;
232  // a. grab column k
233  ColumnVector columnK = cholCopy.Column(k);
234  // b. shift columns k+1,...l to the LEFT
235  for(j = k+1; j <= l; ++j)
236  cholCopy.Column(j-1) = cholCopy.Column(j);
237  // c. copy the elements of columnK into the lth column of cholCopy
238  cholCopy.Column(l) = 0.0;
239  for(i = 1; i <= k; ++i)
240  cholCopy(i,l) = columnK(i);
241
242  // II. apply and compute Given's rotations
243  int nGivens = l-k;
244  ColumnVector cGivens(nGivens); cGivens = 0.0;
245  ColumnVector sGivens(nGivens); sGivens = 0.0;
246  for(j = k; j <= nRC; ++j)
247  {
248  ColumnVector columnJ = cholCopy.Column(j);
249
250  // apply the previous Givens rotations to columnJ
251  int imax = j - k; if (imax > nGivens) imax = nGivens;
252  for(int i = 1; i <= imax; ++i)
253  {
254  int gIndex = i;
255  int topRowIndex = k + i - 1;
256  GivensRotationR(cGivens(gIndex), sGivens(gIndex),
257  columnJ(topRowIndex), columnJ(topRowIndex+1));
258  }
259
260  // compute a new Given's rotation when j < l
261  if(j < l)
262  {
263  int gIndex = j-k+1;
264  columnJ(j) = pythag(columnJ(j), columnJ(j+1), cGivens(gIndex), sGivens(gIndex));
265  columnJ(j+1) = 0.0;
266  }
267
268  cholCopy.Column(j) = columnJ;
269  }
270
271  chol << cholCopy;
272
273 }
GetSubMatrix Column(int) const
Definition: submat.cpp:64
void GivensRotationR(Real cGivens, Real sGivens, Real &x, Real &y)
Definition: newmatrm.h:124
Definition: newmat.h:543
int Nrows() const
◆ RightCircularUpdateCholesky()
void RightCircularUpdateCholesky ( UpperTriangularMatrix chol,
int  k,
int  l
Definition at line 170 of file cholesky.cpp.
171 {
172  int nRC = chol.Nrows();
173  int i, j;
174
175  // I. compute shift of column l to the kth position
176  Matrix cholCopy = chol;
177  // a. grab column l
178  ColumnVector columnL = cholCopy.Column(l);
179  // b. shift columns k,...l-1 to the RIGHT
180  for(j = l-1; j >= k; --j)
181  cholCopy.Column(j+1) = cholCopy.Column(j);
182  // c. copy the top k-1 elements of columnL into the kth column of cholCopy
183  cholCopy.Column(k) = 0.0;
184  for(i = 1; i < k; ++i) cholCopy(i,k) = columnL(i);
185
186  // II. determine the l-k Given's rotations
187  int nGivens = l-k;
188  ColumnVector cGivens(nGivens); cGivens = 0.0;
189  ColumnVector sGivens(nGivens); sGivens = 0.0;
190  for(i = l; i > k; i--)
191  {
192  int givensIndex = l-i+1;
193  columnL(i-1) = pythag(columnL(i-1), columnL(i),
194  cGivens(givensIndex), sGivens(givensIndex));
195  columnL(i) = 0.0;
196  }
197  // the kth entry of columnL is the new diagonal element in column k of cholCopy
198  cholCopy(k,k) = columnL(k);
199
200  // III. apply these Given's rotations to subsequent columns
201  // for columns k+1,...,l-1 we only need to apply the last nGivens-(j-k) rotations
202  for(j = k+1; j <= nRC; ++j)
203  {
204  ColumnVector columnJ = cholCopy.Column(j);
205  int imin = nGivens - (j-k) + 1; if (imin < 1) imin = 1;
206  for(int gIndex = imin; gIndex <= nGivens; ++gIndex)
207  {
208  // apply gIndex Given's rotation
209  int topRowIndex = k + nGivens - gIndex;
210  GivensRotationR(cGivens(gIndex), sGivens(gIndex),
211  columnJ(topRowIndex), columnJ(topRowIndex+1));
212  }
213  cholCopy.Column(j) = columnJ;
214  }
215
216  chol << cholCopy;
217 }
int Nrows() const
◆ UpdateCholesky()
void UpdateCholesky ( UpperTriangularMatrix chol,
Definition at line 96 of file cholesky.cpp.
References GivensRotation(), GeneralMatrix::Nrows(), and pythag().
97 {
98  int ncols = chol.Nrows();
99  ColumnVector cGivens(ncols); cGivens = 0.0;
100  ColumnVector sGivens(ncols); sGivens = 0.0;
101
102  for(int j = 1; j <= ncols; ++j) // process the jth column of chol
103  {
104  // apply the previous Givens rotations k = 1,...,j-1 to column j
105  for(int k = 1; k < j; ++k)
106  GivensRotation(cGivens(k), sGivens(k), chol(k,j), r1Modification(j));
107
108  // determine the jth Given's rotation
109  pythag(chol(j,j), r1Modification(j), cGivens(j), sGivens(j));
110
111  // apply the jth Given's rotation
112  {
113  Real tmp0 = cGivens(j) * chol(j,j) + sGivens(j) * r1Modification(j);
114  chol(j,j) = tmp0; r1Modification(j) = 0.0;
115  }
116
117  }
118
119 }
double Real
int Nrows() const
