For support of multithreading. More...
#include <ossimViewshedTool.h>
SectorProcessorJob (ossimViewshedTool *vs_util, ossim_uint32 sector, ossim_uint32 numRadials) | |
ossimJob () | |
virtual void | start () |
Main entry point to the job. More... | |
std::shared_ptr< ossimJob > | getSharedFromThis () |
This is a convenience method to get the shared representation of this pointer. More... | |
std::shared_ptr< const ossimJob > | getSharedFromThis () const |
void | setPercentComplete (double value) |
When the pernet complete is set for the job it will call any callbacks and nofity percentCompleteChanged. More... | |
void | setPriority (double value) |
sets the priority of the job More... | |
double | priority () const |
virtual void | release () |
If derived interfaces implement a block this will allow one to release. More... | |
State | state () const |
virtual void | resetState (int value) |
Will clear out the state and the call setState. More... | |
virtual void | setState (int value, bool on=true) |
Will allow you to set the state of the job. More... | |
bool | isCanceled () const |
virtual void | cancel () |
Sets the state if the object as cancelled. More... | |
virtual void | ready () |
Sets the state if the object as ready. More... | |
virtual void | running () |
Sets the state if the object as running. More... | |
virtual void | finished () |
Sets the state if the object as finished. More... | |
bool | isReady () const |
bool | isStopped () const |
bool | isFinished () const |
bool | isRunning () const |
void | setCallback (std::shared_ptr< ossimJobCallback > callback) |
void | setName (const ossimString &value) |
Sets the name of a job. More... | |
const ossimString & | name () const |
void | setId (const ossimString &value) |
const ossimString & | id () const |
void | setDescription (const ossimString &value) |
const ossimString & | description () const |
std::shared_ptr< ossimJobCallback > | callback () |
virtual void | run () |
Abstract method and must be overriden by the base class. More... | |
Private Attributes | |
ossimViewshedTool * | m_vsUtil |
ossim_uint32 | m_sector |
ossim_uint32 | m_numRadials |
Friends | |
class | ossimViewshedTool |
enum | State { ossimJob_NONE = 0, ossimJob_READY = 1, ossimJob_RUNNING = 2, ossimJob_CANCEL = 4, ossimJob_FINISHED = 8, ossimJob_ALL = (ossimJob_READY|ossimJob_RUNNING|ossimJob_CANCEL|ossimJob_FINISHED) } |
This is a Bit vector. More... | |
typedef std::list< std::shared_ptr< ossimJob > > | List |
std::mutex | m_jobMutex |
ossimString | m_name |
ossimString | m_description |
ossimString | m_id |
State | m_state |
double | m_priority |
std::shared_ptr< ossimJobCallback > | m_callback |
The –tbs option directs ossimViewshedUtil to create a thread for each sector (using the SectorProcessorJob). Otherwise, the threads are mapped to a single radial. There are 8 sectors total (45 deg each) so a max of 8 threads are launched. Thus it may be faster to use the RadialProcessorJob scheme (default) when the number of available cores > 8.
Definition at line 122 of file ossimViewshedTool.h.
inline |
Definition at line 126 of file ossimViewshedTool.h.
protectedvirtual |
The base ossimJob will call run from the start method after setting some variables.
Implements ossimJob.
Definition at line 890 of file ossimViewshedTool.cpp.
References RadialProcessor::doRadial(), m_numRadials, m_sector, and m_vsUtil.
friend |
Definition at line 124 of file ossimViewshedTool.h.
private |
Definition at line 135 of file ossimViewshedTool.h.
Referenced by run().
private |
Definition at line 134 of file ossimViewshedTool.h.
private |
Definition at line 133 of file ossimViewshedTool.h.
